H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
44-Appendix
44-Appendix 83 KB
Appendix A  Command Index
The command index includes all the commands in the Comware Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary
Routing Protocol
3-1
access-limit
AAA-RADIUS-HWTACACS-EAD
1-1
accounting
1-2
accounting domain
DHCP
4-1
accounting optional
1-3
accounting optional
1-28
accounting-on enable
1-28
acl
Login
2-1
acl
ACL
1-1
active region-configuration
MSTP
1-1
add-member
Cluster
1-15
address-check
DHCP
2-1
administrator-address
Cluster
1-16
am enable
Access Management
1-1
am ip-pool
Access Management
1-1
am trap enable
Access Management
1-3
am user-bind
Port Security-Port Binding
2-2
am user-bind interface
2-1
apply cost
Routing Protocol
4-1
apply poe-profile
PoE-PoE Profile
2-1
apply qos-profile
QoS-QoS Profile
2-1
apply tag
Routing Protocol
4-2
area
Routing Protocol
3-2
arp check enable
ARP
1-1
arp static
ARP
1-1
arp timer aging
ARP
1-2
asbr-summary
Routing Protocol
3-3
ascii
FTP and TFTP
1-7
attribute
1-4
authentication
1-5
authentication-mode
Login
1-1
authentication-mode
Routing Protocol
3-4
authorization
1-6
auto-build
Cluster
1-17
auto-execute command
Login
1-2
B
backup current-configuration
File System Management
1-21
bims-server
DHCP
1-1
binary
FTP and TFTP
1-7
boot attribute-switch
1-1
boot boot-loader
1-2
boot boot-loader
System Maintenance and Debugging
3-1
boot boot-loader backup-attribute
1-3
boot bootrom
3-1
boot web-package
1-4
bpdu-drop any
MSTP
1-2
bpdu-tunnel
VLAN VPN
2-1
bpdu-tunnel uplink
VLAN VPN
2-2
broadcast-suppression
Port Basic Configuration
1-1
bsr-policy
Multicast
6-1
build
Cluster
1-18
bye
SSH Terminal Service
2-3
bye
FTP and TFTP
1-8
C
cache-sa-enable
Multicast
7-1
c-bsr
Multicast
6-2
cd
2-3
cd
1-7
cd
FTP and TFTP
1-9
cdup
2-4
cdup
FTP and TFTP
1-10
change self-unit
IRF Fabric
1-1
change unit-id
IRF Fabric
1-1
check region-configuration
MSTP
1-2
checkzero
Routing Protocol
2-1
clock datetime
1-1
clock summer-time
1-1
clock timezone
1-2
close
FTP and TFTP
1-11
cluster
Cluster
1-20
cluster enable
Cluster
1-20
cluster switch-to
Cluster
1-21
cluster-mac
Cluster
1-22
cluster-mac syn-interval
Cluster
1-23
command-privilege level
CLI
1-1
copy
1-7
copy configuration
1-2
count
HWPing
1-1
c-rp
Multicast
6-3
crp-policy
Multicast
6-4
cut connection
1-7
D
databits
Login
1-3
data-flow-format
1-30
data-flow-format
1-61
debugging
FTP and TFTP
1-11
debugging
1-10
default cost
Routing Protocol
2-2
default cost
Routing Protocol
3-5
default interval
Routing Protocol
3-5
default limit
Routing Protocol
3-6
default tag
Routing Protocol
3-7
default type
Routing Protocol
3-8
default-cost
Routing Protocol
3-8
default-route-advertise
Routing Protocol
3-9
delete
2-5
delete
1-8
delete
FTP and TFTP
1-12
delete static-routes all
Routing Protocol
1-11
delete-member
Cluster
1-24
description
VLAN
1-1
description
Management VLAN
1-1
description
1-5
description
ACL
1-2
destination-ip
HWPing
1-1
detect-group
Auto Detect
1-1
detect-list
Auto Detect
1-1
dhcp enable
DHCP
1-2
dhcp relay information enable
DHCP
2-2
dhcp relay information strategy
DHCP
2-3
dhcp select global
DHCP
1-3
dhcp select interface
DHCP
1-4
dhcp server bims-server
DHCP
1-6
dhcp server detect
DHCP
1-7
dhcp server dns-list
DHCP
1-7
dhcp server domain-name
DHCP
1-9
dhcp server expired
DHCP
1-10
dhcp server forbidden-ip
DHCP
1-11
dhcp server ip-pool
DHCP
1-12
dhcp server nbns-list
DHCP
1-13
dhcp server netbios-type
DHCP
1-15
dhcp server option
DHCP
1-16
dhcp server ping
DHCP
1-17
dhcp server relay information enable
DHCP
1-18
dhcp server static-bind
DHCP
1-19
dhcp server voice-config
DHCP
1-20
dhcp server voice-config interface
DHCP
1-21
dhcp-relay hand
DHCP
2-2
dhcp-security static
DHCP
2-4
dhcp-security tracker
DHCP
2-5
dhcp-server
DHCP
2-6
dhcp-server detect
DHCP
2-7
dhcp-server ip
DHCP
2-8
dhcp-snooping
DHCP
3-1
dhcp-snooping trust
DHCP
3-1
dir
2-5
dir
1-10
dir
FTP and TFTP
1-13
disconnect
FTP and TFTP
1-14
display acl
ACL
1-3
display am
Access Management
1-3
display am user-bind
2-3
display arp
ARP
1-3
display arp |
ARP
1-4
display arp count
ARP
1-5
display arp timer aging
ARP
1-6
display boot-loader
1-5
display boot-loader
3-2
display bootp client
Management VLAN
2-1
display brief interface
1-5
display channel
Information Center
1-1
display clock
1-6
display cluster
Cluster
1-25
display cluster candidates
Cluster
1-26
display cluster members
Cluster
1-28
display connection
1-8
display cpu
3-3
display current-configuration
Configuration File Management
1-1
display debugging
1-7
display debugging fabric by-module
1-8
display detect-group
Auto Detect
1-2
display device
3-4
display dhcp client
Management VLAN
2-2
display dhcp server conflict
DHCP
1-23
display dhcp server expired
DHCP
1-23
display dhcp server free-ip
DHCP
1-25
display dhcp server ip-in-use
DHCP
1-25
display dhcp server statistics
DHCP
1-26
display dhcp server tree
DHCP
1-28
display dhcp-security
DHCP
2-9
display dhcp-server
DHCP
2-10
display dhcp-server interface
DHCP
2-12
display dhcp-snooping
DHCP
3-2
display dhcp-snooping trust
DHCP
3-3
display diagnostic-information
1-11
display dldp
DLDP
1-1
display dns domain
DNS
1-1
display dns dynamic-host
DNS
1-1
display dns server
DNS
1-2
display domain
1-10
display dot1x
802.1x
1-1
display fan
3-4
display fib
IP Address and Performance Configuration
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib ip-prefix
2-5
display fib statistics
2-6
display ftm
IRF Fabric
1-3
display ftp source-ip
FTP and TFTP
1-15
display ftp-server
FTP and TFTP
1-1
display ftp-server source-ip
FTP and TFTP
1-2
display ftp-user
FTP and TFTP
1-2
display garp statistics
GVRP
1-1
display garp timer
GVRP
1-1
display gvrp statistics
GVRP
1-6
display gvrp status
GVRP
1-6
display habp
802.1x
2-1
display habp table
802.1x
2-2
display habp traffic
802.1x
2-2
display history-command
CLI
1-2
display hwping
HWPing
1-2
display hwtacacs
1-62
display icmp statistics
2-6
display igmp group
Multicast
5-1
display igmp interface
Multicast
5-2
display igmp-snooping configuration
Multicast
1-1
display igmp-snooping group
Multicast
1-2
display igmp-snooping statistics
Multicast
1-3
display info-center
Information Center
1-1
display interface
1-7
display interface Vlan-interface
VLAN
1-1
Management VLAN
1-2
display ip host
DNS
1-3
display ip interface
1-1
display ip interface Vlan-interface
Management VLAN
1-3
display ip ip-prefix
Routing Protocol
4-2
display ip routing-table
Management VLAN
1-5
Routing Protocol
1-1
display ip routing-table ip-address
Management VLAN
1-6
Routing Protocol
1-2
display ip routing-table ip-address1 ip-address2
Management VLAN
1-8
Routing Protocol
1-6
display ip routing-table protocol
Management VLAN
1-9
Routing Protocol
1-7
display ip routing-table radix
Management VLAN
1-10
Routing Protocol
1-8
display ip routing-table statistics
Management VLAN
1-11
Routing Protocol
1-9
display ip routing-table verbose
Management VLAN
1-12
Routing Protocol
1-10
display ip socket
2-8
display ip statistics
2-9
display irf-fabric
IRF Fabric
1-4
display isolate port
Port Isolation
1-1
Access Management
1-4
display lacp system-id
Link Aggregation
1-5
display link-aggregation interface
Link Aggregation
1-1
display link-aggregation summary
Link Aggregation
1-2
display link-aggregation verbose
Link Aggregation
1-3
display local-server statistics
1-31
display local-user
1-12
display logbuffer
Information Center
1-3
display logbuffer summary
Information Center
1-5
display loopback-detection
1-10
display mac-address
MAC Address Table
1-2
display mac-address aging-time
MAC Address Table
1-1
display mac-address multicast static
Multicast
3-2
display mac-address security
1-1
display mac-authentication
Centralized MAC Address Authentication
1-1
display memory
Routing Protocol
5-1
display memory
3-5
display memory limit
Routing Protocol
5-2
display mirror
Mirroring
1-10
display mirroring-group
Mirroring
1-1
display mpm forwarding-table
Multicast
2-1
display mpm group
Multicast
2-2
display msdp brief
Multicast
7-1
display msdp peer-status
Multicast
7-2
display msdp sa-cache
Multicast
7-3
display msdp sa-count
Multicast
7-5
display multicast forwarding-table
Multicast
2-3
display multicast routing-table
Multicast
2-5
display multicast-source-deny
Multicast
2-6
display ndp
Cluster
1-1
display ntdp
Cluster
1-7
display ntdp device-list
Cluster
1-8
display ntp-service sessions
NTP
1-1
display ntp-service status
NTP
1-2
display ntp-service trace
NTP
1-4
display ospf abr-asbr
Routing Protocol
3-11
display ospf asbr-summary
Routing Protocol
3-11
display ospf brief
Routing Protocol
3-13
display ospf cumulative
Routing Protocol
3-15
display ospf error
Routing Protocol
3-16
display ospf interface
Routing Protocol
3-19
display ospf lsdb
Routing Protocol
3-20
display ospf nexthop
Routing Protocol
3-23
display ospf peer
Routing Protocol
3-24
display ospf request-queue
Routing Protocol
3-27
display ospf retrans-queue
Routing Protocol
3-28
display ospf routing
Routing Protocol
3-29
display ospf vlink
Routing Protocol
3-30
display packet-filter
ACL
1-4
display pim bsr-info
Multicast
6-5
display pim interface
Multicast
6-6
display pim neighbor
Multicast
6-7
display pim routing-table
Multicast
6-8
display pim rp-info
Multicast
6-9
display poe interface
PoE-PoE Profile
1-1
display poe interface power
PoE-PoE Profile
1-4
display poe powersupply
PoE-PoE Profile
1-5
display poe temperature-protection
PoE-PoE Profile
1-6
display poe-profile
PoE-PoE Profile
2-2
display port
1-14
display port vlan-vpn
VLAN VPN
1-1
display port-security
1-1
display power
3-6
display protocol-priority
QoS-QoS Profile
1-1
display protocol-vlan interface
VLAN
1-10
display protocol-vlan vlan
VLAN
1-11
display qos cos-local-precedence-map
QoS-QoS Profile
1-1
display qos-interface all
QoS-QoS Profile
1-2
display qos-interface line-rate
QoS-QoS Profile
1-3
display qos-interface mirrored-to
Mirroring
1-2
Mirroring
1-11
display qos-interface traffic-limit
QoS-QoS Profile
1-3
display qos-interface traffic-priority
QoS-QoS Profile
1-4
display qos-interface traffic-redirect
QoS-QoS Profile
1-5
display qos-interface traffic-statistic
QoS-QoS Profile
1-5
display qos-profile
QoS-QoS Profile
2-2
display queue-scheduler
QoS-QoS Profile
1-6
display radius scheme
1-32
display radius statistics
1-34
display resilient-arp
ARP
2-1
display rip
Routing Protocol
2-2
display rip interface
Routing Protocol
2-4
display rip routing
Routing Protocol
2-5
display rmon alarm
SNMP-RMON
2-1
display rmon event
SNMP-RMON
2-2
display rmon eventlog
SNMP-RMON
2-3
display rmon history
SNMP-RMON
2-4
display rmon history unit
IRF Fabric
1-5
display rmon prialarm
SNMP-RMON
2-6
display rmon statistics
SNMP-RMON
2-7
display rmon statistics unit
IRF Fabric
1-6
display route-policy
Routing Protocol
4-3
display rsa local-key-pair public
1-1
display rsa peer-public-key
1-3
display saved-configuration
1-7
display schedule reboot
3-6
display sftp source-ip
2-6
display snmp-agent
SNMP-RMON
1-1
display snmp-agent community
SNMP-RMON
1-1
display snmp-agent group
SNMP-RMON
1-2
display snmp-agent mib-view
SNMP-RMON
1-3
display snmp-agent statistics
SNMP-RMON
1-5
display snmp-agent sys-info
SNMP-RMON
1-6
display snmp-agent trap-list
SNMP-RMON
1-6
display snmp-agent usm-user
SNMP-RMON
1-7
display ssh server
1-4
display ssh server-info
1-5
display ssh user-information
1-6
display ssh2 source-ip
1-6
display ssh-server source-ip
1-7
display startup
1-10
display stop-accounting-buffer
1-35
1-63
display storm-constrain
1-11
display stp
MSTP
1-4
display stp region-configuration
MSTP
1-6
display tcp statistics
2-11
display tcp status
2-13
display telnet source-ip
Login
1-4
display telnet-server source-ip
Login
1-4
display tftp source-ip
FTP and TFTP
1-31
display this
1-11
display time-range
ACL
1-4
display transceiver-information interface
1-13
display trapbuffer
Information Center
1-5
display udp statistics
2-14
display udp-helper server
UDP Helper
1-1
display unit
1-15
display user-interface
Login
1-5
display users
Login
1-7
display users
1-8
display version
1-9
display vlan
VLAN
1-3
display vlan
Volice VLAN
1-3
display voice vlan error-info
Volice VLAN
1-1
display voice vlan oui
Volice VLAN
1-1
display voice vlan status
Volice VLAN
1-2
display vrrp
VRRP
1-1
display web users
Login
1-8
display webcache
Web Cache Redirection
1-1
dldp
DLDP
1-2
dldp authentication-mode
DLDP
1-3
dldp delaydown-timer
DLDP
1-7
dldp interval
DLDP
1-4
dldp reset
DLDP
1-5
dldp unidirectional-shutdown
DLDP
1-5
dldp work-mode
DLDP
1-6
dns domain
DNS
1-4
dns resolve
DNS
1-5
dns server
DNS
1-6
dns-list
DHCP
1-30
domain
1-13
domain-name
DHCP
1-31
dot1x
802.1x
1-5
dot1x authentication-method
802.1x
1-7
dot1x dhcp-launch
802.1x
1-8
dot1x guest-vlan
802.1x
1-8
dot1x max-user
802.1x
1-10
dot1x port-control
802.1x
1-11
dot1x port-method
802.1x
1-12
dot1x quiet-period
802.1x
1-13
dot1x retry
802.1x
1-14
dot1x retry-version-max
802.1x
1-15
dot1x supp-proxy-check
802.1x
1-16
dot1x timer
802.1x
1-18
dot1x version-check
802.1x
1-20
Duplex
1-17
E
enable log updown
1-17
enable snmp trap updown
SNMP-RMON
1-8
execute
1-12
exit
2-7
expired
DHCP
1-32
F
fabric save-unit-id
IRF Fabric
1-6
fabric-port enable
IRF Fabric
1-8
file prompt
1-12
filter-policy export
Routing Protocol
2-6
Routing Protocol
3-31
filter-policy import
Routing Protocol
2-7
Routing Protocol
3-32
fixdisk
1-13
flow interval
1-19
flow-control
1-18
format
1-14
free user-interface
Login
1-9
free web-users
Login
2-1
frequency
HWPing
1-5
ftm fabric-vlan
IRF Fabric
1-9
ftp
2-4
ftp
FTP and TFTP
1-16
ftp { cluster | remote-server } source-interface
FTP and TFTP
1-16
ftp { cluster | remote-server } source-ip
FTP and TFTP
1-17
ftp cluster
Cluster
1-30
ftp disconnect
FTP and TFTP
1-3
ftp server enable
2-1
ftp server enable
FTP and TFTP
1-4
ftp source-interface
FTP and TFTP
1-17
ftp source-ip
FTP and TFTP
1-18
ftp timeout
FTP and TFTP
1-4
ftp-server
Cluster
1-31
ftp-server source-interface
FTP and TFTP
1-5
FTP and TFTP
1-6
G
garp timer
GVRP
1-2
garp timer leaveall
GVRP
1-4
gateway-list
DHCP
1-33
get
2-7
get
2-5
get
FTP and TFTP
1-19
giant-frame statistics enable
1-20
gratuitous-arp-learning enable
ARP
1-7
gvrp
GVRP
1-7
gvrp registration
GVRP
1-8
H
habp enable
802.1x
2-3
habp server vlan
802.1x
2-4
habp timer
802.1x
2-5
header
Login
1-9
help
2-8
history-command max-size
Login
1-12
holdtime
Cluster
1-32
host-route
Routing Protocol
2-8
hwping
HWPing
1-6
hwping-agent enable
HWPing
1-7
hwtacacs nas-ip
1-64
hwtacacs scheme
1-65
I
idle-cut
1-14
idle-timeout
Login
1-12
if-match
Routing Protocol
4-4
if-match cost
Routing Protocol
4-5
if-match interface
Routing Protocol
4-6
if-match ip next-hop
Routing Protocol
4-7
if-match tag
Routing Protocol
4-8
igmp enable
Multicast
5-3
igmp group-limit
Multicast
5-4
igmp group-policy
Multicast
5-5
igmp group-policy vlan
Multicast
5-6
igmp host-join port
Multicast
5-7
igmp host-join vlan
Multicast
5-8
igmp lastmember-queryinterval
Multicast
5-9
igmp max-response-time
Multicast
5-10
igmp proxy
Multicast
5-11
igmp robust-count
Multicast
5-12
igmp timer other-querier-present
Multicast
5-13
igmp timer query
Multicast
5-14
igmp version
Multicast
5-15
igmp-snooping
Multicast
1-4
igmp-snooping fast-leave
Multicast
1-5
igmp-snooping general-query source-ip
Multicast
1-6
igmp-snooping group-limit
Multicast
1-7
igmp-snooping group-policy
Multicast
1-8
igmp-snooping host-aging-time
Multicast
1-10
igmp-snooping max-response-time
Multicast
1-11
igmp-snooping querier
Multicast
1-12
igmp-snooping query-interval
Multicast
1-12
igmp-snooping router-aging-time
Multicast
1-13
import-route
Routing Protocol
2-8
import-route
Routing Protocol
3-33
import-source
Multicast
7-6
info-center channel name
Information Center
1-6
info-center console channel
Information Center
1-7
info-center enable
Information Center
1-8
info-center logbuffer
Information Center
1-8
info-center loghost
Information Center
1-9
info-center loghost source
Information Center
1-10
info-center monitor channel
Information Center
1-11
info-center snmp channel
Information Center
1-12
info-center source
Information Center
1-13
info-center switch-on
Information Center
1-15
info-center synchronous
Information Center
1-14
info-center timestamp
Information Center
1-16
info-center timestamp loghost
Information Center
1-17
info-center trapbuffer
Information Center
1-18
instance
MSTP
1-7
interface
1-21
VLAN
1-4
Management VLAN
1-13
ip address
1-3
ip address
Management VLAN
1-14
ip address bootp-alloc
Management VLAN
2-3
ip address dhcp-alloc
Management VLAN
2-3
ip forward-broadcast
2-16
ip host
DNS
1-6
ip http acl
Login
2-2
ip http shutdown
Login
1-13
ip ip-prefix
Routing Protocol
4-8
ip route-static
Management VLAN
1-15
ip route-static
Auto Detect
2-1
ip route-static
Routing Protocol
1-12
ip-pool
Cluster
1-32
irf-fabric authentication-mode
IRF Fabric
1-10
J
jumboframe enable
1-21
K
key
1-37
key
1-65
L
lacp enable
Link Aggregation
1-6
lacp port-priority
Link Aggregation
1-6
lacp system-priority
Link Aggregation
1-7
language-mode
1-3
lcd
FTP and TFTP
1-20
level
1-15
line-rate
QoS-QoS Profile
1-7
link-aggregation group agg-id description
Link Aggregation
1-7
link-aggregation group agg-id mode
Link Aggregation
1-8
local-server
1-38
local-server nas-ip
1-38
local-user
1-16
local-user
2-1
local-user password-display-mode
1-17
2-2
lock
Login
1-14
logging-host
Cluster
1-33
log-peer-change
Routing Protocol
3-34
loopback
1-22
loopback-detection control enable
1-23
loopback-detection enable
1-24
loopback-detection interval-time
1-25
loopback-detection per-vlan enable
1-25
ls
2-8
ls
FTP and TFTP
1-21
M
mac-address
MAC Address Table
1-4
mac-address max-mac-count
MAC Address Table
1-5
mac-address multicast interface
Multicast
3-1
mac-address multicast vlan
Multicast
3-2
1-4
mac-address timer
MAC Address Table
1-6
mac-authentication
1-3
mac-authentication authmode usernameasmacaddress
1-5
mac-authentication authmode usernamefixed
1-6
mac-authentication authpassword
1-7
mac-authentication authusername
1-7
mac-authentication domain
1-8
mac-authentication interface
1-4
mac-authentication timer
1-9
management-vlan
Management VLAN
1-16
management-vlan
Cluster
1-34
mdi
1-26
memory
Routing Protocol
5-3
memory auto-establish disable
Routing Protocol
5-4
memory auto-establish enable
Routing Protocol
5-5
messenger
1-18
mirrored-to
Mirroring
1-3
mirrored-to
Mirroring
1-12
mirroring-group
Mirroring
1-5
mirroring-group mirroring-port
Mirroring
1-5
mirroring-group monitor-port
Mirroring
1-6
mirroring-group reflector-port
Mirroring
1-7
mirroring-group remote-probe vlan
Mirroring
1-8
mirroring-port
Mirroring
1-8
mirroring-port
Mirroring
1-13
mkdir
2-9
mkdir
1-15
mkdir
FTP and TFTP
1-22
monitor-port
Mirroring
1-9
monitor-port
Mirroring
1-14
more
1-15
move
1-16
msdp
Multicast
7-6
msdp-tracert
Multicast
7-7
mtracert
Multicast
7-9
multicast route-limit
Multicast
2-7
multicast routing-enable
Multicast
2-8
Multicast
2-9
multicast-suppression
1-27
multi-path-number
Routing Protocol
3-35
N
name
VLAN
1-5
name
1-19
nas-ip
1-40
nas-ip
1-66
nbns-list
DHCP
1-34
ndp enable
Cluster
1-3
ndp timer aging
Cluster
1-4
ndp timer hello
Cluster
1-5
netbios-type
DHCP
1-34
network
Routing Protocol
2-10
network
Routing Protocol
3-35
network
DHCP
1-35
nm-interface Vlan-interface
Cluster
1-35
nslookup type
DNS
1-7
nssa
Routing Protocol
3-36
ntdp enable
Cluster
1-10
ntdp explore
Cluster
1-11
ntdp hop
Cluster
1-11
ntdp timer
Cluster
1-12
ntdp timer hop-delay
Cluster
1-13
ntdp timer port-delay
Cluster
1-14
ntp-service access
NTP
1-4
ntp-service authentication enable
NTP
1-5
ntp-service authentication-keyid
NTP
1-6
ntp-service broadcast-client
NTP
1-7
ntp-service broadcast-server
NTP
1-7
ntp-service in-interface disable
NTP
1-8
ntp-service max-dynamic-sessions
NTP
1-9
ntp-service multicast-client
NTP
1-10
ntp-service multicast-server
NTP
1-10
ntp-service reliable authentication-keyid
NTP
1-11
ntp-service source-interface
NTP
1-12
ntp-service unicast-peer
NTP
1-13
ntp-service unicast-server
NTP
1-14
O
open
FTP and TFTP
1-23
option
Auto Detect
1-4
option
DHCP
1-36
originating-rp
Multicast
7-10
ospf
Routing Protocol
3-37
ospf authentication-mode
Routing Protocol
3-38
ospf cost
Routing Protocol
3-39
ospf dr-priority
Routing Protocol
3-40
ospf mib-binding
Routing Protocol
3-41
ospf mtu-enable
Routing Protocol
3-41
ospf network-type
Routing Protocol
3-42
ospf timer dead
Routing Protocol
3-44
ospf timer hello
Routing Protocol
3-44
ospf timer poll
Routing Protocol
3-45
ospf timer retransmit
Routing Protocol
3-46
ospf trans-delay
Routing Protocol
3-47
P
packet-filter
ACL
1-5
packet-filter
QoS-QoS Profile
2-2
parity
Login
1-15
passive
FTP and TFTP
1-24
password
1-20
password
2-3
peer
Routing Protocol
2-11
peer
Routing Protocol
3-47
peer connect-interface
Multicast
7-14
peer description
Multicast
7-11
peer mesh-group
Multicast
7-11
peer minimum-ttl
Multicast
7-12
peer request-sa-enable
Multicast
7-13
peer sa-cache-maximum
Multicast
7-13
peer sa-policy
Multicast
7-15
peer sa-request-policy
Multicast
7-16
peer-public-key end
1-7
pim
Multicast
6-11
pim bsr-boundary
Multicast
6-11
pim dm
Multicast
6-12
pim neighbor-limit
Multicast
6-13
pim neighbor-policy
Multicast
6-14
pim sm
Multicast
6-14
pim timer hello
Multicast
6-15
ping
2-1
poe enable
PoE-PoE Profile
1-7
poe legacy enable
PoE-PoE Profile
1-8
poe max-power
PoE-PoE Profile
1-9
poe mode
PoE-PoE Profile
1-9
poe power-management
PoE-PoE Profile
1-10
poe priority
PoE-PoE Profile
1-11
PoE-PoE Profile
1-12
poe update
PoE-PoE Profile
1-13
poe-profile
PoE-PoE Profile
2-3
port
VLAN
1-9
port access vlan
1-28
port hybrid protocol-vlan vlan
VLAN
1-12
port hybrid pvid vlan
1-29
port hybrid vlan
1-29
port isolate
Port Isolation
1-1
port isolate
Access Management
1-5
port link-aggregation group
Link Aggregation
1-9
port link-type
1-30
port trunk permit vlan
1-31
port trunk pvid vlan
1-32
port-security authorization ignore
1-8
port-security enable
1-5
port-security intrusion-mode
1-6
port-security max-mac-count
1-9
port-security ntk-mode
1-9
port-security oui
1-11
port-security port-mode
1-12
port-security timer disableport
1-15
port-security trap
1-16
preference
Routing Protocol
2-11
preference
Routing Protocol
3-48
primary accounting
1-41
primary accounting
1-67
primary authentication
1-42
1-68
primary authorization
1-69
priority
QoS-QoS Profile
1-7
priority trust
QoS-QoS Profile
1-8
protocol inbound
Login
1-16
protocol inbound
1-8
protocol-priority protocol-type
QoS-QoS Profile
1-9
protocol-vlan
VLAN
1-13
public-key-code begin
1-9
public-key-code end
1-10
put
2-10
put
FTP and TFTP
1-24
pwd
2-10
pwd
1-16
pwd
FTP and TFTP
1-25
Q
QoS-QoS Profile
1-11
qos-profile
QoS-QoS Profile
2-3
qos-profile port-based
QoS-QoS Profile
2-4
queue-scheduler
QoS-QoS Profile
1-13
2-11
FTP and TFTP
1-26
1-4
R
radius client
1-43
radius nas-ip
1-43
radius scheme
1-45
radius trap
1-46
radius-scheme
1-21
reboot
3-7
reboot member
Cluster
1-36
region-name
MSTP
1-8
register-policy
Multicast
6-16
remotehelp
FTP and TFTP
1-27
remote-probe vlan
Mirroring
1-10
remove
2-11
rename
2-12
rename
1-17
rename
FTP and TFTP
1-28
reset
Routing Protocol
2-12
reset arp
ARP
1-8
reset counters interface
1-33
reset dhcp server conflict
DHCP
1-37
reset dhcp server ip-in-use
DHCP
1-38
reset dhcp server statistics
DHCP
1-38
reset dhcp-server
DHCP
2-12
reset dns dynamic-host
DNS
1-8
reset dot1x statistics
802.1x
1-21
reset ftm statistics
IRF Fabric
1-11
reset garp statistics
GVRP
1-5
reset hwtacacs statistics
1-70
reset igmp group
Multicast
5-16
reset igmp-snooping statistics
Multicast
1-14
reset ip statistics
2-16
reset lacp statistics
Link Aggregation
1-10
reset logbuffer
Information Center
1-19
reset mac-authentication
1-10
reset msdp peer
Multicast
7-17
reset msdp sa-cache
Multicast
7-17
reset msdp statistics
Multicast
7-18
reset multicast forwarding-table
Multicast
2-10
reset multicast routing-table
Multicast
2-11
reset ndp statistics
Cluster
1-6
reset ospf
Routing Protocol
3-49
reset pim neighbor
Multicast
6-17
reset pim routing-table
Multicast
6-17
reset radius statistics
1-47
reset recycle-bin
1-17
reset saved-configuration
1-12
reset stop-accounting-buffer
1-47
1-70
reset stp
MSTP
1-9
reset tcp statistics
2-17
reset traffic-statistic
QoS-QoS Profile
1-14
reset trapbuffer
Information Center
1-19
reset udp statistics
2-17
reset udp-helper packet
UDP Helper
1-1
reset vrrp statistics
VRRP
1-3
resilient-arp enable
ARP
2-1
resilient-arp interface vlan-interface
ARP
2-2
restore startup-configuration from
1-22
retry
Auto Detect
1-5
retry
1-48
retry realtime-accounting
1-49
retry stop-accounting
1-50
1-71
return
1-4
revision-level
MSTP
1-9
rip
Routing Protocol
2-13
rip authentication-mode
Routing Protocol
2-13
rip input
Routing Protocol
2-15
rip metricin
Routing Protocol
2-15
rip metricout
Routing Protocol
2-16
rip output
Routing Protocol
2-17
rip split-horizon
Routing Protocol
2-18
rip version
Routing Protocol
2-19
rip work
Routing Protocol
2-19
rmdir
2-12
rmdir
1-18
rmdir
FTP and TFTP
1-29
rmon alarm
SNMP-RMON
2-9
rmon event
SNMP-RMON
2-11
rmon history
SNMP-RMON
2-12
rmon prialarm
SNMP-RMON
2-13
rmon statistics
SNMP-RMON
2-15
route-policy
Routing Protocol
4-10
router id
Routing Protocol
3-50
rsa local-key-pair create
1-11
rsa local-key-pair destroy
1-12
rsa peer-public-key
1-13
rsa peer-public-key import sshkey
1-14
rule (for Advanced ACLs)
ACL
1-8
rule (for Basic ACLs)
ACL
1-7
rule (for Layer 2 ACLs)
ACL
1-15
rule (for user-defined ACLs)
ACL
1-18
rule comment
ACL
1-19
S
save
1-13
schedule reboot at
3-8
schedule reboot delay
3-9
schedule reboot regularity
3-10
scheme
1-21
screen-length
Login
1-17
secondary accounting
1-51
1-72
secondary authentication
1-52
1-73
secondary authorization
1-74
security-policy-server
2-1
self-service-url
1-23
send
Login
1-17
server-type
1-53
service-type
Login
1-18
service-type
1-24
service-type multicast
Multicast
1-14
set authentication password
Login
1-20
set unit name
IRF Fabric
1-11
sftp
2-13
sftp server enable
2-1
sftp source-interface
2-14
sftp source-ip
2-15
sftp timeout
2-2
shell
Login
1-21
shutdown
VLAN
1-6
shutdown
Management VLAN
1-17
shutdown
1-34
shutdown
Multicast
7-18
silent-interface
Routing Protocol
3-50
snmp-agent
SNMP-RMON
1-9
Login
2-3
SNMP-RMON
1-10
snmp-agent group
Login
2-3
snmp-agent group
SNMP-RMON
1-11
snmp-agent local-engineid
SNMP-RMON
1-12
snmp-agent log
SNMP-RMON
1-13
snmp-agent mib-view
SNMP-RMON
1-14
snmp-agent packet max-size
SNMP-RMON
1-14
snmp-agent sys-info
SNMP-RMON
1-15
snmp-agent target-host
SNMP-RMON
1-16
snmp-agent trap enable
SNMP-RMON
1-17
snmp-agent trap enable ospf
Routing Protocol
3-51
snmp-agent trap life
SNMP-RMON
1-19
snmp-agent trap queue-size
SNMP-RMON
1-19
snmp-agent trap source
SNMP-RMON
1-20
snmp-agent usm-user
Login
2-5
snmp-agent usm-user
SNMP-RMON
1-21
snmp-host
Cluster
1-36
source-policy
Multicast
6-20
speed
Login
1-22
speed
1-34
speed auto
1-39
spf-schedule-interval
Routing Protocol
3-52
spt-switch-threshold
Multicast
6-19
ssh authentication-type default
1-14
ssh client assign rsa-key
1-16
ssh client first-time enable
1-16
ssh server authentication-retries
1-17
ssh server compatible-ssh1x enable
1-18
ssh server rekey-interval
1-19
ssh server timeout
1-20
ssh user
1-21
ssh user assign rsa-key
1-21
ssh user authentication-type
1-22
ssh user service-type
2-1
ssh2
1-24
ssh2 source-interface
1-25
ssh2 source-ip
1-26
ssh-server source-interface
1-26
1-27
standby detect-group
Auto Detect
2-2
startup bootrom-access enable
1-6
startup saved-configuration
1-15
state
1-25
state
1-54
static-bind client-identifier
DHCP
1-39
static-bind ip-address
DHCP
1-40
static-bind mac-address
DHCP
1-41
static-rp
Multicast
6-21
static-rpf-peer
Multicast
7-19
stop-accounting-buffer enable
1-55
stopbits
Login
1-23
storm-constrain
1-35
storm-constrain control
1-36
storm-constrain enable
1-38
storm-constrain interval
1-37
stp
MSTP
1-10
stp bpdu-protection
MSTP
1-11
stp bridge-diameter
MSTP
1-12
stp compliance
MSTP
1-13
stp config-digest-snooping
MSTP
1-14
stp cost
MSTP
1-16
stp edged-port
MSTP
1-17
stp interface
MSTP
1-18
stp interface config-digest-snooping
MSTP
1-19
stp interface cost
MSTP
1-21
stp interface edged-port
MSTP
1-22
stp interface loop-protection
MSTP
1-23
stp interface mcheck
MSTP
1-24
stp interface no-agreement-check
MSTP
1-25
stp interface point-to-point
MSTP
1-26
stp interface port priority
MSTP
1-27
stp interface root-protection
MSTP
1-28
stp interface transmit-limit
MSTP
1-29
stp loop-protection
MSTP
1-30
stp max-hops
MSTP
1-31
stp mcheck
MSTP
1-32
stp mode
MSTP
1-33
stp no-agreement-check
MSTP
1-34
stp pathcost-standard
MSTP
1-35
stp point-to-point
MSTP
1-37
stp port priority
MSTP
1-38
stp priority
MSTP
1-39
MSTP
1-40
stp root primary
MSTP
1-41
stp root secondary
MSTP
1-42
stp root-protection
MSTP
1-43
stp tc-protection
MSTP
1-44
stp timer forward-delay
MSTP
1-45
stp timer hello
MSTP
1-46
stp timer max-age
MSTP
1-47
stp timer-factor
MSTP
1-48
stp transmit-limit
MSTP
1-49
stub
Routing Protocol
3-53
summary
Routing Protocol
2-20
super
CLI
1-2
super password
CLI
1-3
sysname
Login
1-23
sysname
IRF Fabric
1-12
sysname
1-5
1-6
T
tcp timer fin-timeout
2-18
tcp timer syn-timeout
2-18
tcp window
2-19
telnet
Login
1-24
telnet source-interface
Login
1-26
telnet source-ip
Login
1-27
telnet-server source-interface
Login
1-25
Login
1-26
terminal debugging
Information Center
1-20
terminal debugging
1-12
terminal logging
Information Center
1-20
terminal monitor
Information Center
1-21
terminal trapping
Information Center
1-22
test-enable
HWPing
1-7
test-type
HWPing
1-8
tftp
FTP and TFTP
1-32
tftp cluster get
Cluster
1-37
tftp cluster put
Cluster
1-38
tftp get
2-5
tftp get
FTP and TFTP
1-32
tftp put
FTP and TFTP
1-34
tftp source-interface
FTP and TFTP
1-36
tftp source-ip
FTP and TFTP
1-36
tftp tftp-server source-interface
FTP and TFTP
1-34
tftp tftp-server source-ip
FTP and TFTP
1-35
tftp-server
Cluster
1-38
tftp-server acl
FTP and TFTP
1-37
timeout
HWPing
1-8
timer
1-56
timer
Cluster
1-39
timer loop
Auto Detect
1-5
timer quiet
1-57
timer quiet
1-75
timer realtime-accounting
1-58
1-75
timer response-timeout
1-59
1-77
timer retry
Multicast
7-20
timer wait
Auto Detect
1-6
time-range
ACL
1-20
timers
Routing Protocol
2-21
tracert
2-3
traffic-limit
QoS-QoS Profile
1-16
traffic-limit
QoS-QoS Profile
2-5
traffic-priority
QoS-QoS Profile
1-17
traffic-priority
QoS-QoS Profile
2-6
traffic-redirect
QoS-QoS Profile
1-18
traffic-share-across-interface
Routing Protocol
2-22
traffic-statistic
QoS-QoS Profile
1-20
U
udp-helper enable
UDP Helper
1-2
udp-helper port
UDP Helper
1-2
udp-helper server
UDP Helper
1-3
undelete
1-19
unicast-suppression
1-39
unknown-multicast drop enable
Multicast
4-1
update fabric
1-19
update fabric
3-11
user
FTP and TFTP
1-30
user privilege level
Login
1-28
user-interface
Login
1-28
user-name-format
1-60
user-name-format
1-77
V
verbose
FTP and TFTP
1-30
virtual-cable-test
1-40
vlan
VLAN
1-7
vlan to
VLAN
1-8
vlan-assignment-mode
1-26
vlan-mapping modulo
MSTP
1-50
vlan-vpn enable
VLAN VPN
1-2
vlan-vpn inner-cos-trust
VLAN VPN
1-3
vlan-vpn tpid
VLAN VPN
1-3
vlan-vpn tunnel
MSTP
1-51
vlink-peer
Routing Protocol
3-54
voice vlan
Volice VLAN
1-4
voice vlan aging
Volice VLAN
1-5
voice vlan enable
Volice VLAN
1-6
voice vlan mac-address
Volice VLAN
1-6
voice vlan mode
Volice VLAN
1-7
voice vlan security enable
Volice VLAN
1-8
voice-config
DHCP
1-42
vrrp authentication-mode
VRRP
1-3
vrrp method
VRRP
1-4
vrrp ping-enable
VRRP
1-5
vrrp vlan-interface vrid track
VRRP
1-6
vrrp vrid preempt-mode
VRRP
1-7
vrrp vrid priority
VRRP
1-8
vrrp vrid timer advertise
VRRP
1-9
vrrp vrid track
VRRP
1-10
vrrp vrid track detect-group
Auto Detect
2-3
VRRP
1-11
vrrp vrid virtual-ip
VRRP
1-12
W
webcache address
1-2
webcache redirect-vlan
1-3
wred
QoS-QoS Profile
1-20
X
xmodem get
3-12
Y
Z
