H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
38-Information Center Command
38-Information Center Command 127 KB
Chapter 1  Information Center Configuration Commands
1.1  Information Center Configuration Commands
1.1.1  display channel
display channel [ channel-number | channel-name ]
View
Parameter
channel-number: Channel number, ranging from 0 to 9, corresponding to the 10 channels of the system.
channel-name: Channel name, by default, the name of channel 0 to channel 9 is (in turn) console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, channel9.
Use the display channel command to display the settings of an information channel.
If no argument is specified, the settings of all channels are displayed.
Example
# Display the settings of information channel 0.
<H3C> display channel 0
channel number:0, channel name:console
MODU_ID  NAME     ENABLE LOG_LEVEL     ENABLE TRAP_LEVEL    ENABLE DEBUG_LEVEL
ffff0000 default  Y      warning       Y      debugging     Y      debugging
1.1.2  display info-center
display info-center [ unit unit-id ]
View
Parameter
unit-id: Unit ID.
Use the display info-center command to display the operation status of information center, the configuration of information channels, the format of time stamp and the information output in case of fabric.
Related command: info-center enable, info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, info-center trapbuffer, info-center snmp channel, and info-center timestamp
Example
# Display the operation status of information center, the configuration of information channels, the format of time stamp of the current system and the information output status in the IRF system.
<H3C> display info-center
Information Center: enabled
Log host:
         the interface name of the source address : Vlan-interface1
         192.168.0.2, channel number : 2, channel name : loghost
         language : english, host facility local : 7
Console:
         channel number : 0, channel name : console
Monitor:
         channel number : 1, channel name : monitor
SNMP Agent:
         channel number : 5, channel name : snmpagent
Log buffer:
         enabled,max buffer size : 1024, current buffer size : 512,
         current messages : 512, channel number : 4, channel name : logbuffer
         dropped messages : 0, overwrote messages : 586
Trap buffer:
         enabled,max buffer size : 1024, current buffer size : 256,
         current messages : 5, channel number : 3, channel name : trapbuffer
         dropped messages : 0, overwrote messages : 0
Information timestamp setting:
         log - date, trap - date, debug - boot
IRF SWITCH OF Device--Unit>1: LOG = enable; TRAP = enable; DEBUG = enable
Table 1-1 Description on the fields of the display info-center command
Information Center
Whether the information center is enabled
Log host
Information about the log host, including its IP address, name and number of information channel, language and level of the log host
Console
Information about the console port, including name and channel of its information channel
Monitor
Information about the monitor port, including name and channel of its information channel
SNMP Agent
Information about SNMP Agent, including name and number of its information channel
Log buffer
Information about the log buffer, including its state (enabled or disabled), its maximum size, current size, current messages, information channel name and number, dropped messages, and overwritten messages
Trap buffer
Information about the trap buffer, including its state (enabled or disabled), maximum size, current size, current messages, channel number and name, dropped messages, and overwritten messages
Information about time stamp setting, describing log information, trap information, and the time stamp format of the debugging information
Information about the state of the device (enabled or disabled), describing whether the log, trap and debugging information are enabled on the device
1.1.3  display logbuffer
display logbuffer [ unit unit-id ] [ level severity | size buffersize ]* [ | { begin | exclude | include } regular-expression ]
View
Parameter
unit-id: Unit ID.
level severity: Specifies an information severity level. The severity argument ranges from 1 to 8.
Table 1-2 Severity definitions made on the information center
Severity
Value
emergencies
1
Emergent errors
alerts
2
Errors that need to be corrected immediately
critical
3
Critical errors
errors
4
Errors that need to be considered but are not critical
warnings
5
Warnings that prompt possible errors
notifications
6
Information that needs to be noticed
informational
7
Normal prompting information
debugging
8
Debugging information
size buffersize: Specifies the size of the log buffer (number of messages the log buffer holds) you want to display. The buffersize argument ranges from 1 to 1,024 and defaults to 512.
|: Filters output log information with a regular expression.
begin: Displays the log information beginning with the specified characters.
exclude: Displays the log information excluding the specified characters.
include: Displays the log information including the specified characters.
regular-expression: Regular expression.
Use the display logbuffer command to display the status of the log buffer and the records in the log buffer.
Example
# Display the status of the log buffer and the records in the log buffer.
<H3C> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 0
Current messages : 91
1.1.4  display logbuffer summary
display logbuffer summary [ level severity ]
View
Parameter
Level severity: Specifies an information severity level. The severity argument ranges from 1 to 8.
Use the display logbuffer summary command to display the statistics of the log buffer.
Example
# Display the summary of the log buffer.
<H3C> display logbuffer summary
EMERG ALERT CRIT ERROR WARN NOTIF INFO DEBUG
    0     0    0     0   94     0    1     0
1.1.5  display trapbuffer
display trapbuffer [ unit unit-id ] [ size buffersize ]
View
Parameter
unit-id: Unit ID.
size buffersize: Specifies the size of the trap buffer (number of messages the buffer holds) you want to display. The buffersize argument ranges from 1 to 1,024 and defaults to 256.
Use the display trapbuffer command to display the status of the trap buffer and the records in the trap buffer.
If you execute the command with the size buffersize parameter, the device will display the latest trap records.
Example
# Display the status of the trap buffer and the records in the trap buffer.
<H3C> display trapbuffer
Trapping Buffer Configuration and contents:
enabled
allowed max buffer size : 1024
actual buffer size : 256
channel number : 3 , channel name : trapbuffer
current messages : 6
#Dec 31 14:01:25 2004 H3C DEV/2/LOAD FINISHED:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.20: frameIndex is 0, slotIndex 0.4
#Dec 31 14:01:33 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
 Trap 1.3.6.1.4.1.2011.2.23.1.12.1.11: frameIndex is 0, slotIndex 0.2
#Dec 31 14:01:40 2004 H3C DEV/2/BOARD STATE CHANGE TO NORMAL:
1.1.6  info-center channel name
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
Parameter
channel-name: Channel name, up to 30 characters in length. The name must start with an English letter, containing no special character but numbers and English letters only..
Use the info-center channel name command to name the channel whose number is channel-number as channel-name.
Use the undo info-center channel command to restore the default name of the channel whose number is channel-number.
By default, the name of channel 0 to channel 9 is (in turn) console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, channel9.
Note that you cannot configure two different channel numbers with the same name.
Example
# Name channel 0 as “execconsole”.
<H3C> system-view
[H3C] info-center channel 0 name execconsole
1.1.7  info-center console channel
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
Parameter
Use the info-center console channel command to set the channel through which information is output to the console.
Use the undo info-center console channel command to restore the default channel.
By default, the switch outputs information to the console.
This command works only when the information center is enabled.
Related command: info-center enable and display info-center.
Example
# Configure channel 0 to output information to the console.
<H3C> system-view
[H3C] info-center console channel 0
1.1.8  info-center enable
info-center enable
undo info-center enable
View
Parameter
None
Use the info-center enable command to enable the information center.
Use the undo info-center enable command to disable the information center.
The switch can output system information to the log host, the console, and other destinations only when the information center is enabled.
By default, the information center is enabled.
Related command: display info-center, info-center loghost, info-center logbuffer, info-center console channel, info-center monitor channel, info-center trapbuffer, and info-center snmp channel.
Example
# Enable the information center.
<H3C> system-view
[H3C] info-center enable
1.1.9  info-center logbuffer
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ]*
undo info-center logbuffer [ channel | size ]
View
Parameter
channel: Sets the channel through which information outputs to the log buffer.
size buffersize: Specifies the size of the log buffer (number of messages the buffer holds) you want to display. The buffersize argument ranges from 0 to 1,024 and defaults to 512.
Use the info-center logbuffer command to enable information output to the log buffer.
Use the undo info-center logbuffer command to disable the information output.
By default, the switch outputs information to the log buffer, which can hold 512 records by default.
Example
# Configure the switch to output information to the log buffer with the size of 50.
<H3C> system-view
[H3C] info-center logbuffer size 50
1.1.10  info-center loghost
info-center loghost host-ip-addr [ channel { channel-number | channel-name } | facility local-number | language { chinese | english } ]*
undo info-center loghost host-ip-addr
View
Parameter
host-ip-addr: IP address of a log host.
channel: Sets the information channel for the log host.
facility: Configures the recording process of the log host.
local-number: Recording tool of the log host, ranging from local0 to local7.
language: Configures the log recording language.
chinese, english: Switches the log recording language between Chinese and English.
Use the info-center loghost command to enable information output to a log host through setting the IP address of the log host.
Use the undo info-center loghost command to disable the information output to the log host.
By default, the switch does not output information to the log host.
&  Note:
Be sure to set the correct IP address in the info-center loghost command. A loopback IP address will cause an error message, prompting that the address is invalid.
Example
# Configure the Ethernet switch to send information to the UNIX workstation whose IP address is 202.38.160.1.
<H3C> system-view
[H3C] info-center loghost 202.38.160.1
1.1.11  info-center loghost source
undo info-center loghost source
View
Parameter
Use the info-center loghost source command to configure the source interface through which information is sent to the log host.
Use the undo info-center loghost source command to cancel the source interface configuration.
Example
# Configure VLAN-interface 1 as the source interface through which information is sent to the log host.
<H3C> system-view
[H3C] info-center loghost source Vlan-interface 1
1.1.12  info-center monitor channel
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
Parameter
Use the info-center monitor channel command to set the channel through which information is output to user terminals.
Use the undo info-center monitor channel command to restore the information output channel to the default channel.
By default, the switch outputs information to user terminals.
Example
# Set channel 0 to send information to user terminals.
<H3C> system-view
[H3C] info-center monitor channel 0
1.1.13  info-center snmp channel
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
Parameter
Use the info-center snmp channel command to set the channel through which information is output to the SNMP agent.
Use the undo info-center snmp channel command to restore the default channel through which information is output to the SNMP agent, that is, channel 5.
Related command: snmp-agent and display info-center.
Example
# Set the switch to output information to the SNMP agent through channel 6.
<H3C> system-view
[H3C] info-center snmp channel 6
1.1.14  info-center source
info-center source { modu-name | default } channel { channel-number | channel-name } [ { log | trap | debug } { level severity | state state } ]*
undo info-center source { modu-name | default } channel { channel-number | channel-name }
View
Parameter
modu-name: Module name.
default: Defaults the settings of all modules.
channel-number: Number of information channel to be used.
log: Specifies to output log information.
trap: Specifies to output trap information.
debug: Specifies to output debugging information.
level: Specifies an information severity level.
severity: Information severity level. The information with severity level greater than this level will not be output.
state: Sets the information state.
state: Can be on or off.
Use the info-center source command to specify the information source in the information center and the output direction.
Use the undo info-center source command to cancel the configuration of information source and output direction.
This command can be used for filtering of log, trap or debugging information. For example, it can control information output from the IP module to any direction. You can configure to output information with severity higher than “warning” to the log host, and information with severity higher than “informational” to the log buffer. You can also configure to output trap information to the log host at the same time.
The info-center source command determines the output direction according to channel name or channel number. Each output direction is assigned with a default information channel at present, as shown in Table 1-3.
Table 1-3 Default information channel
Output direction
Information channel name
Console
console
Monitor terminal
monitor
Log host
loghost
Log buffer
logbuffer
Trap buffer
trapbuffer
SNMP
snmpagent
Each information channel is configured with a default record, whose module name is default and module number is 0xffff0000. In the record, the default settings for log, trap and debugging information may differ with channels. If no record is configured for a channel, this default record is adopted.
Example
# Configure to output the log information of the VLAN module on the SNMP channel, and only output the log information above the “emergencies” severity.
<H3C> system-view
[H3C] info-center source vlan channel snmpagent log level emergencies
1.1.15  info-center synchronous
undo info-center synchronous
View
Parameter
None
Use the info-center synchronous command to enable synchronous terminal output, so that if system information (such as log information) is output when the user is inputting information, the command prompt and input information are echoed after the output (note that, the command prompt is echoed in command edit state but is not echoed in interactive state).
Use the undo info-center synchronous command to disable synchronous terminal output.
By default, the synchronous terminal output function is disabled.
&  Note:
l      By enabling the synchronous terminal output function with the info-center synchronous command, you can avoid users’ input from being interrupted by system information output.
l      Running the info-center synchronous command during debugging information collection may result in a command prompt echoed after each item of debugging information. To avoid unnecessary output, it is recommended to disable synchronous terminal output in such cases.
Example
# Enable synchronous terminal output.
<H3C> system-view
[H3C] info-center synchronous
 Current IC terminal output sync is on
1.1.16  info-center switch-on
info-center switch-on { unit unit-id | master | all } [ debugging | logging | trapping ]*
undo info-center switch-on { unit unit-id | master | all } [ debugging | logging | trapping ]*
View
Parameter
unit unit-id: Specifies a switch on which information output function is to be enabled/disabled.
master: Controls the switch that serves as master.
all: Controls all switches within the fabric.
debugging: Enables the debugging information output source.
logging: Enables the log information output source.
trapping: Enables the trap information output source.
Use the info-center switch-on command to enable information output function for a specified switch in a fabric.
Use the undo info-center switch-on command to disable the corresponding information output function for a switch.
By default, debugging information output is enabled and log and trap information output is disabled for the master switch in the fabric. Debugging, log and trap information output for other switches is disabled in the fabric.
After the switches supporting IRF form a fabric, the log, debugging and trap information of each switch in the fabric can be synchronized. Each switch sends its own information to other switches in the fabric and receives information sent by other switches at the same time to update the information on itself. In this way, the switch ensures the synchronization of log, debugging and trap information in the whole fabric.
The switch provides command lines to enable or disable information output for each switch. If you disable information output for a switch, the switch will no longer send information to other switches, but still receive information sent by other switches.
You can enable or disable a specified type of information output for a specified switch as required.
Example
# Enable trap information output for the switch whose Unit ID is 2 in the fabric.
<H3C> system-view
[H3C] info-center switch-on unit 2 trapping
1.1.17  info-center timestamp
info-center timestamp { log | trap | debugging } { boot | date | none }
undo info-center timestamp { log | trap | debugging }
View
Parameter
log: Specifies log information.
trap: Specifies trap information.
debugging: Specifies debugging information.
boot: Specifies to adopt the time elapsed since system boot, which is in the format of “xxxxxx.yyyyyy”, where xxxxxx is the high 32 bits and yyyyyy the low 32 bits of the elapsed milliseconds.
date: Specifies to adopt the current system date and time, which is in format “Mmm dd hh:mm:ss:ms yyyy” for English environment and “yyyy/mm/dd-hh:mm:ss:ms” for Chinese environment.
none: Specifies not to include time stamp in specified output information.
Use the info-center timestamp command to set the format of time stamp included in the log/trap/debugging information.
Use the undo info-center timestamp command to restore the default time stamp format.
By default, the date time stamp is adopted for all types of information.
Example
# Set the boot time stamp for debugging information.
<H3C> system-view
[H3C] info-center timestamp debugging boot
1.1.18  info-center timestamp loghost
info-center timestamp loghost { date | no-year-date | none }
undo info-center timestamp loghost
View
Parameter
no-year-date: Specifies to adopt the current system date and time excluding the year, which is in format “Mmm dd hh:mm:ss:ms” for English environment and “mm/dd-hh:mm:ss:ms” for Chinese environment.
none: Specifies not to include time stamp in output information.
Use the info-center timestamp loghost command to set the format of time stamp to be sent to the log host.
Use the undo info-center timestamp loghost command to restore the default time stamp format.
By default, the date time stamp is adopted.
Example
# Set the no-year-date time stamp for output information sent to the log host.
<H3C> system-view
[H3C] info-center timestamp loghost no-year-date
1.1.19  info-center trapbuffer
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ]*
undo info-center trapbuffer [ channel | size ]
View
Parameter
size: Sets the size of the trap buffer.
buffersize: Size of the trap buffer, represented by the number of messages it holds, ranging from 0 to 1,024 and defaulting to 256.
channel: Sets the channel through which information is sent to the trap buffer.
channel-name: Channel name. By default, the name of channel 0 to channel 9 is (in turn) console, monitor, loghost, trapbuffer, logbuffer, snmpagent, channel6, channel7, channel8, channel9.
Use the info-center trapbuffer command to enable information output to the trap buffer.
Use the undo info-center trapbuffer command to disable information output to the trap buffer.
By default, the switch output information to the trap buffer.
This command takes effect only after the information center function is enabled.
Example
# Enable the switch to send information to the trap buffer, whose size is set to 30.
<H3C> system-view
[H3C] info-center trapbuffer size 30
1.1.20  reset logbuffer
reset logbuffer [ unit unit-id ]
View
Parameter
unit-id: Unit ID.
Use the reset logbuffer command to clear information in the log buffer.
Example
# Clear information in the log buffer.
<H3C> reset logbuffer
1.1.21  reset trapbuffer
reset trapbuffer [ unit unit-id ]
View
Parameter
unit-id: Unit ID.
Use the reset trapbuffer command to clear information in the trap buffer.
Example
# Clear information in the trap buffer.
<H3C> reset trapbuffer
1.1.22  terminal debugging
terminal debugging
undo terminal debugging
View
Parameter
None
Use the terminal debugging command to enable debugging terminal display.
Use the undo terminal debugging command to disable debugging terminal display.
By default, debugging terminal display is disabled.
You can execute the terminal debugging command to display debugging information on a user terminal.
Related command: debugging commands in the System Maintenance and Debugging module of the manual.
Example
# Enable debugging terminal display.
<H3C> terminal debugging
1.1.23  terminal logging
terminal logging
undo terminal logging
View
Parameter
None
Use the terminal logging command to enable log terminal display.
Use the undo terminal logging command to disable log terminal display.
By default, log terminal display is enabled for console users and terminal users.
Example
# Disable log terminal display.
<H3C> undo terminal logging
1.1.24  terminal monitor
terminal monitor
undo terminal monitor
View
Parameter
None
Use the terminal monitor command to enable the debugging/log/trap terminal display function.
Use the undo terminal monitor command to disable the function.
By default, this function is enabled for console users and terminal users.
This command works only on the current terminal. The debugging/log/trap information can be output on the current terminal only after the command is executed in user view. Disabling the function has the same effect as executing the following three commands: undo terminal debugging, undo terminal logging and undo terminal trapping. That is, no debugging/log/trap information will be displayed on the current terminal. If the function is enabled, you can run the terminal debugging/undo terminal debugging, terminal logging/undo terminal logging or terminal trapping/undo terminal trapping command to enable or disable debug/log/trap terminal output respectively.
Example
# Disable terminal display.
<H3C> undo terminal monitor
1.1.25  terminal trapping
terminal trapping
View
Parameter
None
Use the terminal trapping command to enable trap terminal display.
Use the undo terminal trapping command to disable trap terminal display.
By default, trap terminal display is enabled.
Example
# Enable trap terminal display.
<H3C> terminal trapping
