H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
11-Port Isolation Command
11-Port Isolation Command 26 KB
Chapter 1  Port Isolation Configuration Commands
1.1  Port Isolation Configuration Commands
1.1.1  display isolate port
View
Parameter
None
Use the display isolate port command to display information about the Ethernet ports added to the isolation group.
Example
# Display information about the Ethernet ports added to the isolation group.
<H3C> display isolate port
Isolated port(s) on UNIT 1:
 Ethernet1/0/2, Ethernet1/0/3, Ethernet1/0/4
The information above shows that Ethernet1/0/2, Ethernet1/0/3, and Ethernet1/04 are in the isolation group.
1.1.2  port isolate
port isolate
undo port isolate
View
Ethernet port view
Parameter
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
&  Note:
When the port isolate command or the undo port isolate command is executed on a member port of an aggregation group, the other ports in the same aggregation group on the local unit will be added to or removed from the isolation group together at the same time.
By default, the isolation group contains no port.
Example
# Add Ethernet1/0/1 to the isolation group.
<H3C> system-view
[H3C] interface ethernet1/0/1
[H3C-Ethernet1/0/1] port isolate
All aggregated ports in same unit will join isolated group together
# Remove Ethernet1/0/1 from the isolation group.
[H3C-Ethernet1/0/1] undo port isolate
