H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
32-UDP Helper Command
32-UDP Helper Command 28 KB
Chapter 1  UDP Helper Configuration Commands
1.1  UDP Helper Configuration Commands
1.1.1  display udp-helper server
display udp-helper server [ interface Vlan-interface vlan-id ]
View
Parameter
vlan-id: VLAN interface number.
Use the display udp-helper server command to display the information of the destination server corresponding to the VLAN interface.
Example
# Display the information of the destination server corresponding to VLAN interface 1.
<H3C> display udp-helper server interface Vlan-interface 1
interface name       server address      packets send
Vlan-interface1      192.1.1.2           0
The information above shows that the IP address of the destination server corresponding to VLAN interface 1 is 192.1.1.2, and no packets have been forwarded.
1.1.2  reset udp-helper packet
View
Parameter
None
Use the reset udp-helper packet command to clear statistics about the packets forwarded by UDP Helper.
Example
# Clear statistics about the packets forwarded by UDP Helper.
<H3C> reset udp-helper packet
1.1.3  udp-helper enable
udp-helper enable
undo udp-helper enable
View
Parameter
None
Use the udp-helper enable command to enable UDP Helper function.
Use the undo udp-helper enable command to disable UDP Helper function.
By default, UDP Helper is disabled.
Example
# Enable UDP Helper.
<H3C> system-view
[H3C] udp-helper enable
1.1.4  udp-helper port
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
View
Parameter
port-number: Number of the port whose UDP packets are to be forwarded, in the range 0 to 65535 (except for 67 and 68).
dns: Domain name system, corresponding to UDP port 53.
netbios-ds: NetBios datagram service, corresponding to UDP port 138.
netbios-ns: NetBios name service, corresponding to UDP port 137.
tacacs: TAC access control system, corresponding to UDP port 49.
tftp: Trivial file transfer protocol, corresponding to UDP port 69.
time: Time service, corresponding to UDP port 37.
Use the udp-helper port command to specify the UDP port whose UDP broadcast packets are to be forwarded.
Use the undo udp-helper port command to cancel the configuration.
Example
# Specify port 651 to be the UDP port to forward UDP broadcast packets.
<H3C> system-view
[H3C] udp-helper port 651
1.1.5  udp-helper server
udp-helper server ip-address
undo udp-helper server [ ip-address ]
View
VLAN interface view
Parameter
ip-address: IP address of the destination server, in dotted decimal notation.
Use the udp-helper server command to specify the destination server for the UDP broadcast packets to be forwarded.
Use the undo udp-helper server command to remove the destination server for the UDP broadcast packets to be forwarded.
No destination server is configured by default.
Related command: display udp-helper server.
Example
# Specify to forward UDP packets of VLAN1 interface to the destination server at 192.1.1.2.
<H3C> system-view
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] udp-helper server 192.1.1.2
