H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
23-ARP Command
23-ARP Command 68 KB
Chapter 1  ARP Configuration Commands
1.1  ARP Configuration Commands
1.1.1  arp check enable
arp check enable
undo arp check enable
View
Parameter
None
Use the arp check enable command to enable the ARP entry checking function on a switch, that is, to disable the switch from creating ARP entries for multicast MAC addresses.
Use the undo arp check enable command to disable the ARP entry checking function. In this case, the switch creates ARP entries for multicast MAC addresses.
By default, the ARP entry checking function is enabled.
Example
# Configure to create multicast MAC address ARP entries for MAC addresses learned.
<H3C> system-view
[H3C] undo arp check enable
1.1.2  arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ]
arp static ip-address mac-address vlan-id (in Ethernet port view)
undo arp ip-address
View
System view/Ethernet port view
Parameter
ip-address: IP address contained in the ARP mapping entry to be created/removed.
mac-address: MAC address contained in the ARP mapping entry to be created, in the format of H-H-H.
vlan-id: ID of the VLAN to which the static ARP entry belongs, in the range of 1 to 4,094.
interface-type: Type of the port to which the static ARP entry belongs.
interface-number: Number of the port to which the static ARP entry belongs.
Use the arp static command to create a static ARP mapping entry.
Use the undo arp command to remove an ARP mapping entry.
By default, the system ARP mapping table is empty and the dynamic address mapping entries are generated by ARP.
Note that:
l           Static ARP mapping entries are valid as long as the Ethernet switch operates. However, an ARP mapping entry is removed if the corresponding VLAN is removed. By default, a dynamic ARP mapping entry remains valid for 20 minutes.
l           As for the arp static command, the value of the vlan-id argument must be the ID of an existing VLAN, and the port identified by the interface-type and interface-number arguments must belong to the VLAN.
l           Currently, static ARP mapping entries cannot be configured on aggregation ports.
Related command: reset arp, and display arp.
Example
# Create a static ARP mapping entry, with the IP address of 202.38.10.2, the MAC address of 000f-e201-0000. The ARP mapping entry belongs to Ethernet1/0/1 which belongs to VLAN 1.
<H3C> system-view
[H3C] arp static 202.38.10.2 000f-e201-0000 1 Ethernet 1/0/1
1.1.3  arp timer aging
arp timer aging aging-time
undo arp timer aging
View
Parameter
aging-time: Aging time (in minutes) of the dynamic ARP mapping entries. This argument ranges from 1 to 1,440.
Use the arp timer aging command to configure the aging time for dynamic ARP mapping entries.
Use the undo arp timer aging command to restore the default aging time.
By default, the aging time for dynamic ARP mapping entries is 20 minutes.
Related command: display arp timer aging.
Example
# Configure the aging time to be 10 minutes for dynamic ARP mapping entries.
<H3C> system-view
[H3C] arp timer aging 10
1.1.4  display arp
display arp [ dynamic | static | ip-address ]
View
Parameter
dynamic: Displays dynamic ARP mapping entries.
static: Displays static ARP mapping entries.
ip-address: IP address. ARP mapping entries containing the IP address are to be displayed.
Use the display arp command to display specific ARP mapping entries.
If you execute this command with no keyword/argument specified, all the ARP mapping entries are displayed.
Related command: arp static, and reset arp.
Example
# Display all the ARP mapping entries.
<H3C> display arp
            Type: S-Static   D-Dynamic
IP Address       MAC Address     VLAN ID  Port Name / AL ID      Aging Type
10.2.72.162      000a-000a-0aaa  N/A      N/A                    N/A   S
192.168.0.77     0000-e8f5-6a4a  1        Ethernet1/0/2          13    D
192.168.0.2      000d-88f8-4e88  1        Ethernet1/0/2          14    D
192.168.0.200    0014-222c-9d6a  1        Ethernet1/0/2          14    D
192.168.0.45     000d-88f6-44c1  1        Ethernet1/0/2          15    D
192.168.0.110    0011-4301-991e  1        Ethernet1/0/2          15    D
192.168.0.32     0000-e8f5-73ee  1        Ethernet1/0/2          16    D
192.168.0.3      0014-222c-aa69  1        Ethernet1/0/2          16    D
192.168.0.17     000d-88f6-379c  1        Ethernet1/0/2          17    D
192.168.0.115    000d-88f7-9f7d  1        Ethernet1/0/2          18    D
192.168.0.43     000c-760a-172d  1        Ethernet1/0/2          18    D
192.168.0.33     000d-88f6-44ba  1        Ethernet1/0/2          20    D
192.168.0.35     000f-fc02-2181  1        Ethernet1/0/2          20    D
192.168.0.5      000f-fc80-2b38  1        Ethernet1/0/2          20    D
---   14 entries found   ---
Table 1-1 Description on the fields of the display arp command
IP Address
IP address contained in an ARP mapping entry
MAC Address
MAC address contained in an ARP mapping entry
VLAN ID
ID of the VLAN which an ARP mapping entry belongs to
Port Name / AL ID
Name of the port which an ARP mapping entry belongs to
Aging
Aging time (in minutes) of a dynamic ARP mapping entry
Type of an ARP mapping entry
1.1.5  display arp |
display arp [ dynamic | static] | { begin | exclude | include } text
View
Parameter
| { begin | exclude | include } text: Regular expression, where:
begin: Displays the ARP mapping entries from the first ARP entry that contains the specified string given by the text argument.
exclude: Displays the ARP mapping entries that do not contain the specified string given by the text argument.
include: Displays the ARP mapping entries that contain the specified string given by the text argument.
text: String used to filter ARP mapping entries.
Use the display arp | command to display the ARP mapping entries related to string in a specified way.
Example
# Display all the ARP mapping entries that contain the string “77”.
<H3C> display arp | include 77
192.168.0.77     0000-e8f5-6a4a  1        Ethernet1/0/2          12    D
---   1 entry found   ---
# Display all the ARP entries that do not contain the string “68”.
<H3C> display arp | exclude 68
Refer to Table 1-1 for the description on the above output information.
1.1.6  display arp count
display arp count [ [ dynamic | static ] [ | { begin | exclude | include } text ] | ip-address ]
View
Parameter
dynamic: Counts the dynamic ARP mapping entries.
static: Counts the static ARP mapping entries.
begin: Counts the ARP mapping entries from the first ARP entry that contains the string given by the text argument.
exclude: Counts the ARP mapping entries that do not contain the string given by the text argument.
include: Counts the ARP mapping entries that contain the string given by the text argument.
ip-address: IP address. The ARP mapping entries containing the IP address are to be counted in.
Use the display arp count command to display the number of the specified ARP mapping entries. If no parameter is specified, the total number of ARP mapping entries is displayed.
Example
# Display the total number of ARP mapping entries.
<H3C> display arp count
 1 entry found
1.1.7  display arp timer aging
View
Parameter
None
Use the display arp timer aging command to display the setting of the ARP aging timer.
Related command: arp timer aging.
Example
# Display the setting of the ARP aging timer.
<H3C> display arp timer aging
Current ARP aging time is 20 minute(s)(default)
The displayed information shows that the ARP aging timer is set to 20 minutes.
1.1.8  gratuitous-arp-learning enable
undo gratuitous-arp-learning enable
View
Parameter
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the gratuitous ARP packet learning function.
By default, the gratuitous ARP packet learning function is enabled.
With the gratuitous ARP packet learning function enabled, a switch operates as follows when receiving a gratuitous ARP packet:
l           If the cache of the switch contains ARP mapping entries that match the packet, the switch updates the ARP mapping entries using the sender hardware address carried in the gratuitous ARP packet.
l           If no ARP mapping entry in the cache matches the packet, an ARP mapping entry corresponding to the packet is created.
Example
# Enable the gratuitous ARP packet learning function on a switch.
<H3C> system-view
[H3C] gratuitous-arp-learning enable
1.1.9  reset arp
reset arp [ dynamic | static | interface interface-type interface-number ]
View
Parameter
dynamic: Clears dynamic ARP mapping entries.
static: Clears static ARP mapping entries.
interface-type: Port type.
interface-number: Port number.
Use the reset arp command to clear specific ARP mapping entries.
Related command: arp static, and display arp.
Example
# Clear static ARP mapping entries.
<H3C> reset arp static
Chapter 2  Resilient ARP Configuration Commands
2.1  Resilient ARP Configuration Commands
2.1.1  display resilient-arp
display resilient-arp [ unit unit-id ]
View
Parameter
unit-id: Unit ID ranging from 1 to 8.
Use the display resilient-arp command to display the Resilient ARP state information of each unit and the VLAN interface that can transmit Resilient ARP packets.
If the unit-id argument is not specified, this command is to display the Resilient ARP state information of all units. If the unit-id argument is specified, this command is to display the Resilient ARP state information of the specified unit.
Example
# Display the information about the Resilient ARP state of unit 1.
<H3C> display resilient-arp unit 1
The state of unit 1 is: L3Master
The sending interface(s):
Vlan-interface2
Vlan-interface1
The above output information means that the current Resilient ARP state of unit 1 is L3Master, and VLAN interfaces through which the Resilient ARP packets are sent are VLAN-interface2 and VLAN-interface1.
2.1.2  resilient-arp enable
undo resilient-arp enable
View
Parameter
None
Use the resilient-arp enable command to enable the Resilient ARP function.
Use the undo resilient-arp enable command to disable the Resilient ARP function.
By default, the Resilient ARP function is enabled.
Related command: display resilient-arp.
Example
# Enable the Resilient ARP function.
<H3C> system-view
[H3C] resilient-arp enable
2.1.3  resilient-arp interface vlan-interface
resilient-arp interface vlan-interface vlan-id
undo resilient-arp interface vlan-interface vlan-id
View
Parameter
vlan-id: VLAN interface ID.
Use the resilient-arp interface vlan-interface command to configure the VLAN interface through which Resilient ARP packets are sent.
Use the undo resilient-arp interface vlan-interface command to remove the VLAN interface through which Resilient ARP packets are sent.
By default, Resilient ARP packets are sent through the VLAN–interface1.
Example
# Configure the Resilient ARP packets to be sent from the VLAN-interface2.
<H3C> system-view
[H3C] resilient-arp interface vlan-interface 2
