H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
43-Access Management Command
43-Access Management Command 42 KB
Chapter 1  Access Management Configuration Commands
1.1  Access Management Configuration Commands
1.1.1  am enable
am enable
undo am enable
View
Parameter
None
Using am enable command, you can enable the access management function.
Using undo am enable command, you can disable the function.
By default, Access management function disabled.
When using the access management function, It is recommended to cancel the static ARP configuration to ensure that the binding of IP address and Ethernet switch take effect. If you have configured the static ARP for an IP address in the current port IP address pool from some other port, the system will prompt to cancel the static ARP setting.
Example
# Enable the access management function.
<H3C> system-view
[H3C] am enable
1.1.2  am ip-pool
am ip-pool address-list
undo am ip-pool { all | address-list }
View
Ethernet port view
Parameter
all: Configures to operate on all the IP addresses (or IP address pools).
ip-pool: Configures IP address pool for access management.
address-list: Specifies IP address list in the start-ip-address [ ip-address-number ] & < 1-10 > format. start-ip-address is the start address of an IP address range in the pool. ip-address-number specifies how many IP addresses following start-ip-address in the range. & < 1-10 > means you can specify ten IP address ranges at most.
Using am ip-pool command, you can configure the IP address pool for access management on a port. The packet whose source IP address is in the specified pool is allowed to be forwarded on Layer 3 via the port of the switch.
Using undo am ip-pool command, you can cancel the access management IP pool of the port.
By default, All the IP address pools for access control on the port are null and all the packets are permitted through.
Note that
l           The access control IP address pool of a port and the IP address of the Layer 3 interface to which the port belongs must be on the same network segment.
l           If the IP address pool to be configured contains the IP addresses configured in the static ARP at other ports, then the system prompts you to delete the static ARP to make the later binding effective.
Example
# Configure the access management IP address pool on Ethernet1/0/1 and permits the addresses from 202.112.66.2 through 202.112.66.20 and the specified 202.112.65.1 to access the port.
<H3C> system-view
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] am ip-pool 202.112.66.2 19 202.112.65.1
1.1.3  am trap enable
am trap enable
undo am trap enable
View
Parameter
None
Using am trap enable command, you can enable the access management trap function.
Using undo am trap enable command, you can disable the access management trap function.
By default, The access management trap disabled.
Example
# Enable the access management trap.
<H3C> system-view
[H3C] am trap enable
1.1.4  display am
display am [ interface-list ]
View
Parameter
interface-list: Specifies a list of ports isolated from the specified port in the { interface-type interface-number [ to interface-type interface-number ] } &<1-10> format. interface-type is port type and interface-number is port number. For details about interface-type, interface-number, refer to the Port Command Manual. &<1-10> indicates the preceding parameter can be input up to 10 times.
Using display am command, you can view the current access management configurations on part or all of the ports.
Example
# Display the access management configurations on Ethernet1/0/1 and Ethernet1/0/2.
<H3C> display am ethernet1/0/1 ethernet1/0/2
Ethernet1/0/1
 Status       : enabled
 IP Pools     : (NULL)
Ethernet1/0/2
 Status       : enabled
 IP Pools     : (NULL)
Table 1-1  Description of information generated by the command display am
Ethernet
Port to be displayed
Status
AM state on the port: enabled or disabled
IP Pools
IP pools. NULL represents no configuration. Each IP address section is represented in X.X.X.X (number), of these, “X.X.X.X” represents the first address, and “number” represents that “number” consecutive IP addresses from the beginning of this address are within the IP pools
1.1.5  display isolate port
View
Any View
Parameter
None
Use the display isolate port command to display information about the Ethernet ports added to the isolation group.
Example
# Display information about the Ethernet ports added to the isolation group.
<H3C> display isolate port
 Isolated port(s) on UNIT 1:
 Ethernet1/0/1
1.1.6  port isolate
port isolate
undo port isolate
View
Ethernet port view
Parameter
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
By default, the isolation group contains no port.
Example
# Add Ethernet1/0/1, Ethernet1/0/2 to the isolation group.
<H3C> system-view
[H3C] interface ethernet1/0/1
[H3C-Ethernet1/0/1] port isolate
[H3C-Ethernet1/0/1] quit
[H3C] interface ethernet1/0/2
[H3C-Ethernet1/0/2] port isolate
