- H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Configuration Command
- 06-Management VLAN Command
- 07-Voice VLAN Command
- 08-GVRP Command
- 09-Port Basic Configuration Command
- 10-Link Aggregation Command
- 11-Port Isolation Command
- 12-Port Security-Port Binding Command
- 13-DLDP Command
- 14-MAC Address Table Command
- 15-Auto Detect Command
- 16-MSTP Command
- 17-Routing Protocol Command
- 18-Multicast Command
- 19-802.1x Command
- 20-AAA-RADIUS-HWTACACS-EAD Command
- 21-VRRP Command
- 22-Centralized MAC Address Authentication Command
- 23-ARP Command
- 24-DHCP Command
- 25-ACL Command
- 26-QoS-QoS Profile Command
- 27-Web Cache Redirection Command
- 28-Mirroring Command
- 29-IRF Fabric Command
- 30-Cluster Command
- 31-PoE-PoE Profile Command
- 32-UDP Helper Command
- 33-SNMP-RMON Command
- 34-NTP Command
- 35-SSH Terminal Service Command
- 36-File System Management Command
- 37-FTP and TFTP Command
- 38-Information Center Command
- 39-System Maintenance and Debugging Command
- 40-VLAN-VPN Command
- 41-HWPing Command
- 42-DNS Command
- 43-Access Management Command
- 44-Appendix
| 00-1Cover | 72 KB |
H3C S3600 Series Ethernet Switches |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08192T-20070724-C-1.04 Product Version: Release 1510 |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3600 Series Ethernet Switches-Release 1510 documentation set includes the following:
Manual |
H3C S3600 Series Ethernet Switches Operation Manual-Release 1510 |
It is used for assisting the users in data configurations and typical applications. |
H3C S3600 Series Ethernet Switches Installation Manual |
It provides information for the system installation. |
Organization
H3C S3600 Series Ethernet Switches Command Manual-Release 1510 is organized as follows:
Part |
Contents |
1 CLI |
Introduces the commands used for switching between the command levels and command level setting. |
2 Login |
Introduces the commands used for logging into the Ethernet switch. |
3 Configuration File Management |
Introduces the commands used for configuration file management. |
4 VLAN |
Introduces the commands used for configuring VLAN. |
5 IP Address and Performance Configuration |
Introduces the commands used for IP address configuration and IP performance configuration. |
6 Management VLAN |
Introduces the commands used for configuring the management VLAN and DHCP/BOOTP client configuration. |
7 Voice VLAN |
Introduces the commands used for voice VLAN configuration. |
8 GVRP |
Introduces the commands used for GVRP configuration. |
9 Port Basic Configuration |
Introduces the commands used for basic port configuration. |
10 Link Aggregation |
Introduces the commands used for link aggregation. |
11 Port Isolation |
Introduces the commands used for port isolation. |
12 Port Security-Port Binding |
Introduces the commands used for port security configuration and port binding. |
13 DLDP |
Introduces the commands used for DLDP configuration. |
14 MAC Address Table |
Introduces the commands used for MAC address forwarding table management. |
15 Auto Detect |
Introduces the commands used for auto detect configuration. |
16 MSTP |
Introduces the STP-related commands. |
17 Routing Protocol |
Introduces the commands used for routing protocol configuration. |
18 Multicast |
Introduces the commands used for multicast configuration. |
19 802.1x |
Introduces the commands used for 802.1x configuration. |
20 AAA-RADIUS-HWTACACS-EAD |
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration. |
21 VRRP |
Introduces the commands used for VRRP configuration. |
22 Centralized MAC Address Authentication |
Introduces the commands used for centralized MAC address authentication configuration. |
23 ARP |
Introduces the ARP-related commands. |
24 DHCP |
Introduces the commands used for DHCP server, DHCP relay, and DHCP-snooping configuration. |
25 ACL |
Introduces the ACL-related commands. |
26 QoS-QoS Profile |
Introduces the commands used for QoS and QoS profile configuration. |
27 Web Cache Redirection |
Introduces the commands used for Web cache redirection configuration. |
28 Mirroring |
Introduces the commands used for port mirroring. |
29 IRF Fabric |
Introduces the commands used for IRF fabric configuration. |
30 Cluster |
Introduces the commands used for cluster management. |
31 PoE-PoE Profile |
Introduces the commands used for PoE and PoE profile configuration. |
32 UDP Helper |
Introduces the commands used for UDP Helper configuration. |
33 SNMP-RMON |
Introduces the commands used for SNMP and RMON configuration. |
34 NTP |
Introduces the NTP-related commands. |
35 SSH Terminal Service |
Introduces the commands used for SSH configuration. |
36 File System Management |
Introduces the commands used for file system management. |
37 FTP and TFTP |
Introduces the FTP-/TFTP-related commands. |
38 Information Center |
Introduces the commands used for information center configuration. |
39 System Maintenance and Debugging |
Introduces the commands used for system maintenance and debugging. |
40 VLAN-VPN |
Introduces the commands used for VLAN VPN configuration. |
41 HWPing |
Introduces the commands used for HWPing configuration. |
42 DNS |
Introduces the commands used for DNS configuration. |
43 Access Management |
Introduces the commands used for Access Management configuration |
44 Appendix |
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
A line starting with the # sign is comments. |
II. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
