H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
26-QoS-QoS Profile Command
26-QoS-QoS Profile Command 171 KB
Chapter 1  QoS Commands
1.1  QoS Commands
1.1.1  display protocol-priority
View
Parameter
None
Use the display protocol-priority command to display the priority of the protocol packet.
Example
# Display the priority of the protocol packet.
<H3C> display protocol-priority
Protocol: telnet
  DSCP: be(0)
1.1.2  display qos cos-local-precedence-map
View
Parameter
None
Use the display qos cos-local-precedence-map command to display the “COS-to-local-precedence” mapping table.
Example
# Display the “COS-to-local-precedence” mapping table.
<H3C> display qos cos-local-precedence-map
cos-local-precedence-map:
              cos(802.1p) :    0    1    2     3     4     5     6     7
 local precedence(queue) :     0    1    2     3     4     5     6     7
1.1.3  display qos-interface all
display qos-interface { interface-type interface-number | unit-id } all
View
Parameter
interface-type interface-number: Port index.
unit-id: Unit ID of the switch.
Use the display qos-interface all command to display all the QoS configuration of the ports. If you do not input port parameters, this command will display the QoS parameter configuration of all the ports of the switch, including priority remark, queue scheduling, rate limit, etc; if you input port parameters, this command will display QoS parameter configuration of the port, including priority remark, queue scheduling, rate limit, etc.
When the IRF feature is enabled, the interface-type interface-number argument or the unit-id argument must be input.
Example
# Display all the QoS parameter configuration on Ethernet1/0/1.
<H3C> display qos-interface Ethernet 1/0/1 all
Ethernet1/0/1: traffic-limit
 Inbound:
   Matches: Acl 3001 rule 1  running
     Target rate: 640 kbps
     Exceed action: remark-dscp 4
Ethernet1/0/1: traffic-priority
 Inbound:
   Matches: Acl 2000 rule 0  running
     Priority action: dscp ef
Ethernet1/0/1: line-rate
   Inbound: 128 kbps
   Outbound: 1024 kbps
Ethernet1/0/1:
 Queue scheduling mode: strict-priority
1.1.4  display qos-interface line-rate
display qos-interface { interface-type interface-number | unit-id } line-rate
View
Parameter
Use the display qos-interface line-rate command to display the rate limit configuration of a port or all the ports of a switch. If you do not specify the interface-type interface-number argument, this command will display the rate limit configuration of all the ports of a switch; if you specify that argument, this command will display the rate limit configuration of a specific port.
Example
# Display the rate limit configuration of a specific port.
<H3C> display qos-interface 1 line-rate
   Inbound: 128 kbps
1.1.5  display qos-interface traffic-limit
display qos-interface { interface-type interface-number | unit-id } traffic-limit
View
Parameter
Use the display qos-interface traffic-limit command to display the traffic limit configuration of a port or all the ports of a switch, including the applied ACLs for traffic limit, committed information rate (CIR), and the corresponding actions.
Related command: traffic-limit.
Example
# Display the traffic limit configuration.
<H3C> display qos-interface Ethernet 1/0/1 traffic-limit
 Inbound:
1.1.6  display qos-interface traffic-priority
display qos-interface { interface-type interface-number | unit-id } traffic-priority
View
Parameter
Use the display qos-interface traffic-priority command to display the traffic priority configuration. The information displayed includes the ACL corresponding to the traffic tagged with priority, priority type and value.
Related command: traffic-priority.
Example
# Display the traffic priority configuration.
<H3C> display qos-interface Ethernet 1/0/1 traffic-priority
 Inbound:
1.1.7  display qos-interface traffic-redirect
display qos-interface { interface-type interface-number | unit-id } traffic-redirect
View
Parameter
Use the display qos-interface traffic-redirect command to display the redirection configuration of a port or all the ports of a switch. The displayed information includes the corresponding ACLs of the traffic to be redirected, the destination interfaces, etc.
Related command: traffic-redirect.
Example
# Display the redirect configuration.
<H3C> display qos-interface Ethernet 1/0/1 traffic-redirect
Ethernet1/0/1: traffic-redirect
 Inbound:
   Matches: Acl 3000 rule 0  running
     Redirected to: interface Ethernet1/0/22
1.1.8  display qos-interface traffic-statistic
display qos-interface { interface-type interface-number | unit-id } traffic-statistic
View
Parameter
Use the display qos-interface traffic-statistic command to display the traffic statistics information. The information displayed includes the ACL corresponding to the traffic to be counted and the number of packets counted.
Related command: traffic-statistic.
Example
# Display the traffic statistics information.
<H3C> display qos-interface Ethernet 1/0/1 traffic-statistic
Ethernet1/0/1: traffic-statistic
 Inbound:
   Matches: Acl 2000 rule 2  running
     0 packet inprofile
     0 packet outprofile
1.1.9  display queue-scheduler
View
Parameter
None
Use the display queue-scheduler command to display global queue scheduling mode and corresponding configuration.
Related command: queue-scheduler.
Example
# Display the global queue scheduling mode.
<H3C> display queue-scheduler
1.1.10  line-rate
line-rate { inbound | outbound } target-rate
undo line-rate{ inbound | outbound }
View
Ethernet port view
Parameter
inbound: Limits the rate of inbound packets.
outbound: Limits the rate of outbound packets.
target-rate: Total rate (in Kbps) to limit both the inbound and outbound packets on the port, with the granularity of rate limit being 64 Kbps. If the number you input is in the range of N*64 to (N+1)*64 (N is a natural number), the switch will set the value to (N+1)*64 Kbps automatically. The target rate range for fast Ethernet ports and Gigabit Ethernet ports respectively is:
l           Fast Ethernet port: 64 to 99,968
l           Gigabit Ethernet port: 64 to 1,000,000
Use the line-rate command to limit the rate of the packets on the port.
Use the undo line-rate command to cancel the rate limit configuration on the port.
The granularity of rate limit is 64 Kbps.
Example
# Limit the rate of inbound packets on Ethernet1/0/1 to 128 Kbps.
<H3C> system-view
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] line-rate inbound 128
1.1.11  priority
priority priority-level
undo priority
View
Ethernet port view
Parameter
priority-level: Priority level of the port, ranging from 0 to 7.
Use the priority command to configure the priority of Ethernet port.
Use the undo priority command to restore the default port priority.
By default, the switch uses the port priority instead of the 802.1p priority carried by a packet.
After this command is configured, the switch will replace the packet 802.1p priority with the priority of the receiving port, according to which the packet will be put into the corresponding egress queue.
Example
# Set the priority of Ethernet1/0/1 port to 6.
<H3C> system-view
[H3C-Ethernet1/0/1] priority 6
1.1.12  priority trust
priority trust
undo priority
View
Ethernet port view
Parameter
None
Use the priority trust command to configure the system to use the packet 802.1p priority instead of the port priority.
Use the undo priority command to configure the system not to use packet 802.1p priority.
By default, the system replaces the priority carried by a packet with the port priority.
Example
# Configure the system to use the packet priority on Ethernet1/0/1.
<H3C> system-view
[H3C-Ethernet1/0/1] priority trust
1.1.13  protocol-priority protocol-type
protocol-priority protocol-type protocol-type { ip-precedence ip-precedence | dscp dscp-value }
undo protocol-priority protocol-type protocol-type
View
Parameter
protocol-type protocol-type: Specifies the protocol type. Only TELNET, SNMP, ICMP and OSPF are supported currently.
ip-precedence ip-precedence: Specifies the IP precedence, in the range of 0 to 7. You can enter the keywords as shown in Table 1-1 .
Table 1-1 Description on IP precedence values
Keyword
IP precedence value (decimal)
IP precedence value (binary)
routine
0
000
priority
1
001
immediate
2
010
flash
3
011
flash-override
4
100
critical
5
101
internet
6
110
network
7
111
dscp dscp-value: Specifies the DSCP priority, in the range of 0 to 63. You can also enter the keywords listed in Table 1-2.
Table 1-2 Description on DSCP values
Keyword
DSCP value (decimal)
DSCP value (binary)
ef
46
101110
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
be (default)
0
000000
Use the protocol-priority command to set the global traffic priority for a specific protocol type.
Use the undo protocol-priority command to cancel the settings.
&  Note:
The precedence of OSPF protocol packets cannot be changed on S3600-SI series switches.
Example
# Set the IP precedence of SNMP protocol packets to 3.
<H3C> system-view
[H3C] protocol-priority protocol-type snmp ip-precedence 3
1.1.14  qos cos-local-precedence-map
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
undo qos cos-local-precedence-map
View
Parameter
cos0-map-local-prec: Local precedence to which CoS 0 is to be mapped, in the range of 0 to 7.
cos1-map-local-prec: Local precedence to which CoS 1 is to be mapped, in the range of 0 to 7.
cos2-map-local-prec: Local precedence to which CoS 2 is to be mapped, in the range of 0 to 7.
cos3-map-local-prec: Local precedence to which CoS 3 is to be mapped, in the range of 0 to 7.
cos4-map-local-prec: Local precedence to which CoS 4 is to be mapped, in the range of 0 to 7.
cos5-map-local-prec: Local precedence to which CoS 5 is to be mapped, in the range of 0 to 7.
cos6-map-local-prec: Local precedence to which CoS 6 is to be mapped, in the range of 0 to 7.
cos7-map-local-prec: Local precedence to which CoS 7 is to be mapped, in the range of 0 to 7.
Use the qos cos-local-precedence-map command to configure the “CoS-to-local-precedence” mapping table.
Use the undo qos cos-local-precedence-map command to restore the default values.
The following is the default “CoS-to-local-precedence” mapping table.
Table 1-3 Default “CoS-to-local-precedence” mapping table
CoS value
Local precedence
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Example
# Configure the “CoS-to-local-precedence” mapping table.
<H3C> system-view
[H3C] qos cos-local-precedence-map 0 1 2 3 4 5 6 7
The following is the configured "CoS-to-local-precedence” mapping table.
Table 1-4 “CoS-to-local-precedence” mapping table
CoS value
Local precedence
0
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
1.1.15  queue-scheduler
I. In system view
queue-scheduler { strict-priority | wfq queue0-width queue1-width queue2-width queue3-width queue4-width queue5-width queue6-width queue7-width | wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight }
undo queue-scheduler
II. In Ethernet port view
queue-scheduler { wfq queue0-width queue1-width queue2-width queue3-width queue4-width queue5-width queue6-width queue7-width | wrr queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight }
View
System view/Ethernet port view
Parameter
strict-priority: Indicates that the queue uses strict priority (SP) scheduling algorithm.
wfq: Indicates that the queue uses weighted fair queue (WFQ) scheduling.
queue0-width queue1-width queue2-width queue3-width queue4-width queue5-width queue6-width queue7-width: Minimum delivery bandwidth of each WFQ queue in Kbps. Its granularity is 64 Kbps. If the number you enter is in the range of N*64 to (N+1)*64 (N is a natural number), the switch sets the value to (N+1)*64 automatically. The value for fast Ethernet ports is in the range of 64 to 99,968, and the value for Gigabit Ethernet ports is in the range of 64 to 1,000,000. A value of 0 means the corresponding queue uses the SP scheduling.
wrr: Indicates that the queue uses weighted round robin (WRR) scheduling.
queue0-weight queue1-weight queue2-weight queue3-weight queue4-weight queue5-weight queue6-weight queue7-weight: Indicates that the queue uses the WRR scheduling. The value ranges from 0 to 15. A value of 0 means the corresponding queue uses the SP scheduling.
Use the queue-scheduler command to configure the queue scheduling mode.
Use the undo queue-scheduler command to restore the default value.
The queue scheduling algorithm defined by executing the queue-scheduler command in system view takes effect on all the ports of the switch. The queue scheduling algorithm defined by executing the queue-scheduler command in Ethernet port view takes effect on the current port only. If the weight (or bandwidth value) of the WRR (or WFQ) queue scheduling algorithm defined globally cannot satisfy the requirement of a port, you can modify the weight (or bandwidth value) of the queue scheduling algorithm for this port in Ethernet port view of this port. On this port, the newly defined queue weight (or bandwidth value) will replace the globally defined one. You cannot use the display queue-scheduler command to display the queue weight (or bandwidth value) defined in Ethernet port view.
A port of the switch supports eight egress queues and you can configure a queue scheduling mode, which can be SP, WRR, or WFQ as needed to achieve the implementation of WRR+SP or WFQ+SP. For example, with WRR or WFQ, if you set the weight or the minimum bandwidth of one or more queues to 0, the SP applies to the queue(s) and WRR or WFQ apply to other queues.
By default, the WRR algorithm is selected for all outbound queues on a port, and their weight values are 1, 2, 3, 4, 5, 9, 13, and 15.
Related command: display queue-scheduler.
Example
# Set WRR as the queue scheduling mode, and set the weight value of each queue to 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
<H3C> system-view
[H3C-Ethernet1/0/1] queue-scheduler wrr 1 2 3 4 5 6 7 8
1.1.16  reset traffic-statistic
reset traffic-statistic inbound acl-rule
View
Ethernet port view
Parameter
inbound: Specifies to clear the statistics of the inbound packets on the port.
acl-rule: Applied ACL which can be the combination of various ACL rules. For the ways of combining ACLs and the description on related parameters, refer to Table 1-5 and Table 1-6.
Table 1-5 Ways of applying combined ACLs
ACL combination
Form of the acl-rule argument
Apply all the rules in an IP ACL separately
ip-group acl-number
Apply a rule in an IP ACL separately
ip-group acl-number rule rule-id
Apply all the rules in a Link ACL separately
link-group acl-number
Apply a rule in a Link ACL separately
link-group acl-number rule rule-id
Apply all the rules in a user-defined ACL separately
user-group acl-number
Apply a rule in a user-defined ACL separately
user-group acl-number rule rule-id
Apply a rule in an IP ACL and a rule in a Link ACL at the same time
ip-group acl-number rule rule-id link-group acl-number rule rule-id
Table 1-6 Description on the parameters in the ACL combination
Parameter
ip-group acl-number
The number of a basic or advanced ACL, in the range of 2,000 to 3,999
The number of a Layer 2 ACL, in the range of 4,000 to 4,999
The number of a user-defined ACL, in the range of 5,000 to 5,999
rule-id
The number of an ACL rule, in the range of 0 to 65,534. If this argument is not specified, it refers to all the rules in the ACL
Use the reset traffic-statistic command to clear the statistics of all or the specified traffic.
Example
# Clear the statistics of the inbound traffic that matches ACL 2000 on Ethernet1/0/1.
<H3C> system-view
[H3C-Ethernet1/0/1] reset traffic-statistic inbound ip-group 2000
1.1.17  traffic-limit
traffic-limit inbound acl-rule target-rate [ exceed action ]
undo traffic-limit inbound acl-rule
View
Ethernet port view
Parameter
inbound: Imposes traffic limit on the packets received through the interface.
acl-rule: Applied ACL rules which can be the combination of various ACL rules. For the ways of combining ACLs and the description on related parameters, refer to Table 1-5 and Table 1-6.
target-rate: Total rate (in Kbps) to be set, with the granularity of traffic limit being 64 Kbps. If the specified number ranges from N*64 to (N+1)*64, where N is a natural number, the switch automatically sets (N+1)*64 as the parameter value. This argument ranges from 64 to 99,968 inclusive for a fast Ethernet port and from 64 to 1,000,000 inclusive for a Gigabit Ethernet port.
exceed action: Optional. The action is taken when the traffic exceeds the threshold. The action can be:
l           drop: Drops the packets.
l           remark-dscp value: Sets a new DSCP value.
Use the traffic-limit command to activate ACL-based traffic identification, impose traffic limit, and take different actions on packets within/exceeding the traffic limit.
Use the undo traffic-limit command to remove traffic limit.
The granularity of traffic limit is 64 Kbps.
This command is only effective for the ACL rules whose actions are permit.
Example
# Impose traffic limit on packets that are received on Ethernet1/0/1 and match the permit rule in ACL 4000. Set the rate limit to 128 Kbps and drop the packets exceeding the rate.
<H3C> system-view
[H3C-Ethernet1/0/1] traffic-limit inbound link-group 4000 128 exceed drop
1.1.18  traffic-priority
traffic-priority { inbound | outbound } acl-rule { { dscp dscp-value | ip-precedence { pre-value | from-cos } } | cos { pre-value | from-ipprec } | local-precedence pre-value }*
undo traffic-priority { inbound | outbound } acl-rule
View
Ethernet port view
Parameter
inbound: Performs priority remarking on the packets received by the interface.
outbound: Performs priority remarking on the packets sent by the interface.
dscp dscp-value: Sets DSCP priority, ranging from 0 to 63. You can also enter the keywords listed in Table 1-2.
ip-precedence { pre-value | from-cos }: Sets IP precedence. pre-value ranges from 0 to 7. You can also enter the keywords listed in Table 1-1. from-cos means to set IP precedence of the packet to be the same as the 802.1p priority.
cos { pre-value | from-ipprec }: Sets 802.1p priority. The pre-value argument ranges from 0 to 7. You can also enter the keywords list in Table 1-7. from-ipprec means to set 802.1p priority of the packet to be the same as the IP precedence.
Table 1-7 Description on 802.1p priority values
Keyword
CoS value (decimal)
CoS value (binary)
best-effort
0
000
background
1
001
spare
2
010
excellent-effort
3
011
controlled-load
4
100
video
5
101
voice
6
110
network-management
7
111
local-precedence pre-value: Sets local precedence. The pre-value argument ranges from 0 to 7.
Use the traffic-priority command to apply ACLs in traffic classification and remark priority for the traffic matching the ACLs. This command is effective only for the ACL rules whose actions are permit.
Use the undo traffic-priority command to remove the function of remarking priority for the specified traffic.
&  Note:
The CoS precedence and the local-precedence cannot be applied simultaneously on the switch.
Related command: display qos-interface traffic-priority.
Example
# Remark the 802.1p priority of the packets that are received on Ethernet1/0/1 and match the permit rule in ACL 4000 as 1.
<H3C> system-view
[H3C-Ethernet1/0/1] traffic-priority inbound link-group 4000 cos 1
1.1.19  traffic-redirect
traffic-redirect { inbound | outbound } acl-rule { cpu | interface interface-type interface-number }
undo traffic-redirect { inbound | outbound } acl-rule
View
Ethernet port view
Parameter
inbound: Performs traffic redirecting on the packets received by the interface.
outbound: Performs traffic redirecting on the packets sent by the interface.
cpu: Redirects the traffic to the CPU.
interface interface-type interface-number: Redirects the packets to the specified Ethernet port. The interface-type argument refers to the port type.
Use the traffic-redirect command to activate the ACL to identify and redirect the traffic (whose action is permit).
Use the undo traffic-redirect command to cancel the redirection.
Related command: display qos-interface traffic-redirect.
&  Note:
l      After the packets are redirected to CPU, they cannot be forwarded normally.
l      If the traffic is redirected to a Combo port in down state, the system automatically redirects the traffic to the port corresponding to the Combo port in up state.
Example
# Redirect the packets that are received on Ethernet1/0/1 and match the permit rule in ACL 2000 to Ethernet1/0/7.
<H3C> system-view
[H3C-Ethernet1/0/1] traffic-redirect inbound ip-group 2000 interface Ethernet 1/0/7
1.1.20  traffic-statistic
undo traffic-statistic inbound acl-rule
View
Ethernet port view
Parameter
inbound: Performs traffic statistics on the packets received by the interface.
Use the traffic-statistic command to activate the ACL to identify traffic and perform statistics on the traffic (whose action is permit).
Use the undo traffic-statistic command to cancel the traffic statistics.
The statistics generated with the traffic-statistic command includes the times transmitted data is matched by the switch. You can use the display qos-interface traffic-statistic command to display the statistics information.
Related command: display qos-interface traffic-statistic.
Example
# Perform traffic statistics on the packets that are received on Ethernet1/0/1 and match the permit rule in ACL 2000.
<H3C> system-view
[H3C-Ethernet1/0/1] traffic-statistic inbound ip-group 2000
1.1.21  wred
wred queue-index qstart probability
undo wred queue-index
View
Ethernet port view
Parameter
queue-index: Queue index in the range of 0 to 7.
qstart: Number of the packets that the queue can hold, in the range of 1 to 128.
probability: Drop probability in the range of 0 to 92 (percentage).
Use the wred command to configure WRED parameters.
Use the undo wred command to restore default setting.
By default, WRED function is disabled.
Example
# Configure WRED parameters for queue 2 on Ethernet1/0/1. When the number of packets in queue 2 exceeds 64, packets are dropped at random. The drop probability is 20%.
<H3C> system-view
[H3C-Ethernet1/0/1] wred 2 64 20
Chapter 2  QoS Profile Configuration Commands
2.1  QoS Profile Configuration Commands
2.1.1  apply qos-profile
I. In system view
apply qos-profile profile-name interface interface-list
undo apply qos-profile profile-name interface interface-list
View
Parameter
profile-name: QoS profile name, a string of 1 to 32 characters, starting with English letters [a-z, A-Z] and excluding reserved keywords, such as all, interface, user, undo, user-based, port-based, and name.
interface-list: List of Ethernet ports. You can specify multiple Ethernet ports by providing this argument in the form of interface-list=interface-type interface-number [ to interface-type interface-number ].
Use the apply qos-profile command to apply the QoS profile configuration to the current port manually.
Use the undo apply qos-profile command to remove the QoS profile configuration from the current port.
You cannot delete the specific QoS profile that has been applied to the port.
Example
# Apply the QoS profile named a123 to Ethernet1/0/1.
<H3C> system-view
[H3C-Ethernet1/0/1] apply qos-profile a123
# Apply the QoS profile named a123 to Ethernet1/0/1 through Ethernet1/0/4.
<H3C> system-view
[H3C] apply qos-profile a123 interface Ethernet 1/0/1 to Ethernet 1/0/4
2.1.2  display qos-profile
display qos-profile { all | name profile-name | interface interface-type interface-number | user user-name }
View
Parameter
all: Displays all QoS profiles.
profile-name: QoS profile with the specified name. profile-name is a string of 1 to 32 characters, starting with English letters [a-z, A-Z] and excluding reserved keywords, such as all, interface, user, undo, user-base, port-based, and name.
interface interface-type interface-number: Displays the QoS profile applied on a specific port.
user user-name: Displays the QoS profile mapped to a specific user. user-name is a string of 1 to 80 characters.
Use the display qos-profile command to display QoS profile configuration information.
Example
# Display QoS profile configuration information.
<H3C> display qos-profile all
2.1.3  packet-filter
packet-filter { inbound | outbound } acl-rule
undo packet-filter { inbound | outbound } acl-rule
View
QoS profile view
Parameter
inbound: Filters the inbound packets on the port.
outbound: Filters the outbound packets on the port.
Use the packet-filter command to add packet filtering action to the QoS profile.
Use the undo packet-filter command to remove packet filtering action from the QoS profile.
Example
# Add the packet filtering action to the QoS profile named a123. The action is to filter the inbound packets matching ACL 4000.
<H3C> system-view
[H3C] qos-profile a123
[H3C-qos-profile-a123] packet-filter inbound link-group 4000
2.1.4  qos-profile
undo qos-profile profile-name
View
Parameter
Use the qos-profile command to create a QoS profile and enter the corresponding view. For an existing QoS profile, use this command to directly enter the corresponding view.
Use the undo qos-profile command to delete a QoS profile.
You cannot delete a QoS profile that has been applied to the port.
Example
# Create a QoS profile named a123.
<H3C> system-view
2.1.5  qos-profile port-based
undo qos-profile port-based
View
Ethernet port view
Parameter
None
Use the qos-profile port-based command to configure the application of the QoS profile on the port to be port-based.
Use the undo qos-profile port-based command to restore the default application mode.
By default, a QoS profile is applied on a port in user-based mode.
l           If the 802.1x authentication is MAC-based, you must configure the QoS profile application mode to be user-based.
l           If the 802.1x authentication is port-based, you must configure the QoS profile application mode to be port-based.
After you configure the QoS profiles and the user passes the authentication, the switch delivers the right profile dynamically to the port through which the user is connected. The QoS profile can be delivered to the port in one of the following two modes:
l           User-based mode: If the source station information (source MAC address, source IP address, or source MAC address + source IP address) has been defined in the ACL that is applied in the traffic actions, the switch cannot deliver the QoS profile dynamically; if no source station information is available, the switch generates a new ACL by adding the source MAC address and source IP address of the user into the existing ACL, and then applies all traffic actions in the QoS profile on the user port.
l           Port-based mode: The switch delivers the traffic actions in the QoS profile directly to the user port. In this mode, all the users connected through one port should use the same QoS profile.
Example
# Configure the application mode of the QoS profile on Ethernet1/0/1 as the port-based mode.
<H3C> system-view
[H3C-Ethernet1/0/1] qos-profile port-based
2.1.6  traffic-limit
traffic-limit inbound acl-rule target-rate [ exceed exceed-action ]
View
QoS profile view
Parameter
inbound: Imposes traffic limit on the inbound packets through the port.
target-rate: Total traffic (in Kbps) to be set, with the granularity of traffic limit being 64Kbps. If the number user input ranges from N*64 to (N+1)*64, where N is a natural number, the switch automatically sets (N+1)*64 as the parameter value. The value of port rate ranges from 64 to 1,000,000.
exceed action: Specifies the action to be taken when the traffic threshold is exceeded (optional). Two actions are available:
l           drop: Drops packets.
Use the traffic-limit command to add traffic policing action to the QoS profile.
Use the undo traffic-limit command to remove traffic policing action from the QoS profile.
You cannot remove traffic policing action from the specific QoS profile that has been applied to the port.
Example
# Add this traffic policing action to the QoS profile named a123: Limit traffic matching ACL 2000, set the target rate to 128 Kbps, and drop the packets that exceed this target rate.
<H3C> system-view
[H3C-qos-profile-a123] traffic-limit inbound  ip-group 2000 128 exceed drop
2.1.7  traffic-priority
View
QoS profile view
Parameter
inbound: Remarks the preference value for the inbound packets on the port.
outbound: Remarks the preference value for the outbound packets through the port.
dscp dscp-value: Sets DSCP preference value, in the range 0 to 63. You can also enter keywords listed in Table 1-2.
ip-precedence { pre-value | from-cos }: Sets IP preference value. pre-value is in the range of 0 to 7. You can also enter keywords listed in Table 1-1. from-cos sets the IP preference value consistent with 802.1p preference value.
cos { pre-value | from-ipprec }: Sets 802.1p preference value. pre-value is in the range of 0 to 7. You can also enter keywords listed in Table 1-7. from-ipprec sets the 802.1p preference value consistent with the IP preference value.
local-precedence pre-value: Sets local preference value, in the range of 0 to 7.
Use the traffic-priority command to enable the ACL and preference marking.
Use the undo traffic-priority command to remove the preference marking.
You cannot remove preference marking from a QoS profile that has been applied to the port.
&  Note:
Example
# Add preference marking to the QoS profile named a123. The action is to set the local preference of the inbound packets matching ACL 2000 to 0.
<H3C> system-view
[H3C-qos-profile-a123] traffic-priority inbound ip-group 2000 local-precedence 0
