04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
26-MAU-MIB
26-MAU-MIB 107.67 KB
MAU-MIB
About this MIB
This MIB is defined in RFC 3636 and contains interface media attachment unit (MAU) information.
The document might not be updated in time. For the latest detailed informatin, see the offical document at https://www.iana.org/assignments/ianamau-mib/ianamau-mib.
MIB file name
rfc3636-mau.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).snmpDot3MauMgt(26)
Tabular objects
ifMauTable
About this table
Use this table to obtain the interface MAU state.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifMauIfIndex and ifMauIndex.
Object (OID)
Access
Value range
Implementation
ifMauIfIndex (1.3.6.1.2.1.26.2.1.1.1)
read-only
InterfaceIndex
Standard MIB values.
Index of the interface in this entry.
As per the MIB.
ifMauIndex (1.3.6.1.2.1.26.2.1.1.2)
read-only
Integer32
Integer32 (1..2147483647)
Interface MAU index.
As per the MIB.
ifMauType (1.3.6.1.2.1.26.2.1.1.3)
read-only
AutonomousType
Interface MAU operation type. The value (1) indicates autonegotiation. The value (2) indicates autonegotiation is not enabled or applied on an interface.
As per the MIB.
ifMauStatus (1.3.6.1.2.1.26.2.1.1.4)
read-write
INTEGER
other(1),
unknown(2),
operational(3),
standby(4),
shutdown(5),
reset(6)
Current state of the interface MAU.
The object can only be read.
ifMauMediaAvailable (1.3.6.1.2.1.26.2.1.1.5)
read-only
INTEGER
other(1),
unknown(2),
available(3),
notAvailable(4),
remoteFault(5),
invalidSignal(6),
remoteJabber(7),
remoteLinkLoss(8),
remoteTest(9),
offline(10),
autoNegError(11),
pmdLinkFault(12),
wisFrameLoss(13),
wisSignalLoss(14),
pcsLinkFault(15),
excessiveBER(16),
dxsLinkFault(17),
pxsLinkFault(18)
Current availability state of the interface MAU.
As per the MIB.
ifMauMediaAvailableStateExits (1.3.6.1.2.1.26.2.1.1.6)
read-only
Counter32
Number of switchovers from state available(3) to another state on an interface MAU.
As per the MIB.
ifMauJabberState (1.3.6.1.2.1.26.2.1.1.7)
read-only
INTEGER
other(1),
unknown(2),
noJabber(3),
jabbering(4)
Jabber state of an interface MAU.
As per the MIB.
ifMauJabberingStateEnters (1.3.6.1.2.1.26.2.1.1.8)
read-only
Counter32
Number of the jabber state switchovers to the jabbering(4) state on an interface MAU.
As per the MIB.
ifMauFalseCarriers (1.3.6.1.2.1.26.2.1.1.9)
read-only
Counter32
Number of false carrier events on an interface MAU.
As per the MIB.
ifMauTypeList (1.3.6.1.2.1.26.2.1.1.10)
read-only
Integer32
Interface MAU type list (as a best practice, do not use this object).
As per the MIB.
ifMauDefaultType (1.3.6.1.2.1.26.2.1.1.11)
read-write
AutonomousType
Default interface MAU type.
ifMauAutoNegSupported (1.3.6.1.2.1.26.2.1.1.12)
read-only
TruthValue
true(1),
false(2)
Whether an interface MAU supports autonegotiation.
As per the MIB.
ifMauTypeListBits (1.3.6.1.2.1.26.2.1.1.13)
read-only
BITS
bOther(0),
bAUI(1),
b10base5(2),
bFoirl(3),
b10base2(4),
b10baseT(5),
b10baseFP(6),
b10baseFB(7),
b10baseFL(8),
b10broad36(9),
b10baseTHD(10),
b10baseTFD(11),
b10baseFLHD(12),
b10baseFLFD(13),
b100baseT4(14),
b100baseTXHD(15),
b100baseTXFD(16),
b100baseFXHD(17),
b100baseFXFD(18),
b100baseT2HD(19),
b100baseT2FD(20),
b1000baseXHD(21),
b1000baseXFD(22),
b1000baseLXHD(23),
b1000baseLXFD(24),
b1000baseSXHD(25),
b1000baseSXFD(26),
b1000baseCXHD(27),
b1000baseCXFD(28),
b1000baseTHD(29),
b1000baseTFD(30),
b10GbaseX(31),
b10GbaseLX4(32),
b10GbaseR(33),
b10GbaseER(34),
b10GbaseLR(35),
b10GbaseSR(36),
b10GbaseW(37),
b10GbaseEW(38),
b10GbaseLW(39),
b10GbaseSW(40),
-- new since RFC 3636
b10GbaseCX4(41),
b2BaseTL(42),
b10PassTS(43),
b100BaseBX10D(44),
b100BaseBX10U(45),
b100BaseLX10(46),
b1000BaseBX10D(47),
b1000BaseBX10U(48),
b1000BaseLX10(49),
b1000BasePX10D(50),
b1000BasePX10U(51),
b1000BasePX20D(52),
b1000BasePX20U(53),
b10GbaseT(54),
b10GbaseLRM(55),
b1000baseKX(56),
b10GbaseKX4(57),
b10GbaseKR(58),
b10G1GbasePRXD1(59),
b10G1GbasePRXD2(60),
b10G1GbasePRXD3(61),
b10G1GbasePRXU1(62),
b10G1GbasePRXU2(63),
b10G1GbasePRXU3(64),
b10GbasePRD1(65),
b10GbasePRD2(66),
b10GbasePRD3(67),
b10GbasePRU1(68),
b10GbasePRU3(69),
b40GbaseKR4(70),
b40GbaseCR4(71),
b40GbaseSR4(72),
b40GbaseFR(73),
b40GbaseLR4(74),
b100GbaseCR10(75),
b100GbaseSR10(76),
b100GbaseLR4(77),
b100GbaseER4(78),
b1000baseT1(79),
b1000basePX30D(80),
b1000basePX30U(81),
b1000basePX40D(82),
b1000basePX40U(83),
b10G1GbasePRXD4(84),
b10G1GbasePRXU4(85),
b10GbasePRD4(86),
b10GbasePRU4(87),
b25GbaseCR(88),
b25GbaseCRS(89),
b25GbaseKR(90),
b25GbaseKRS(91),
b25GbaseR(92),
b25GbaseSR(93),
b25GbaseT(94),
b40GbaseER4(95),
b40GbaseR(96),
b40GbaseT(97),
b100GbaseCR4(98),
b100GbaseKR4(99),
b100GbaseKP4(100),
b100GbaseR(101),
b100GbaseSR4(102),
b2p5GbaseT(103),
b5GbaseT(104),
b100baseT1(105),
b1000baseRHA(106),
b1000baseRHB(107),
b1000baseRHC(108),
b2p5GbaseKX(109),
b2p5GbaseX(110),
b5GbaseKR(111),
b5GbaseR(112),
b10GpassXR(113),
b25GbaseLR(114),
b25GbaseER(115),
b50GbaseR(116),
b50GbaseCR(117),
b50GbaseKR(118),
b50GbaseSR(119),
b50GbaseFR(120),
b50GbaseLR(121),
b50GbaseER(122),
b100GbaseCR2(123),
b100GbaseKR2(124),
b100GbaseSR2(125),
b100GbaseDR(126),
b200GbaseR(127),
b200GbaseDR4(128),
b200GbaseFR4(129),
b200GbaseLR4(130),
b200GbaseCR4(131),
b200GbaseKR4(132),
b200GbaseSR4(133),
b200GbaseER4(134),
b400GbaseR(135),
b400GbaseSR16(136),
b400GbaseDR4(137),
b400GbaseFR8(138),
b400GbaseLR8(139),
b400GbaseER8(140),
b10baseT1L(141),
b10baseT1SHD(142),
b10baseT1SMD(143),
b10baseT1SFD(144),
Set of possible IEEE 802.3 types that the MAU could be.
As per the MIB.
ifMauHCFalseCarriers (1.3.6.1.2.1.26.2.1.1.14)
read-only
Counter64
Number of false carrier events on an interface MAU. A 64-bit counter is used to avoid counter rollover.
As per the MIB.
ifJackTable
About this table
Use this table to obtain the external jack information of an interface MAU.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifMauIfIndex, ifMauIndex, and ifJackIndex.
Object (OID)
Access
Value range
Implementation
ifJackIndex (1.3.6.1.2.1.26.2.2.1.1)
not-accessible
Integer32
Index of the external jack of an interface MAU.
As per the MIB.
ifJackType (1.3.6.1.2.1.26.2.2.1.2)
read-only
JackType
Type of the external jack of an interface MAU.
As per the MIB.
ifMauAutoNegTable
About this table
Use this table to obtain the autonegotiation information of an interface MAU.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
ifMauAutoNegAdminStatus (1.3.6.1.2.1.26.5.1.1.1)
read-write
INTEGER
enabled(1),
disabled(2)
Autonegotiation enabling state of an interface MAU.
ifMauAutoNegRemoteSignaling (1.3.6.1.2.1.26.5.1.1.2)
read-only
INTEGER
detected(1),
notdetected(2)
Whether the remote end of the link is using autonegotiation signaling.
As per the MIB.
ifMauAutoNegConfig (1.3.6.1.2.1.26.5.1.1.4)
read-only
INTEGER
other(1),
configuring(2),
complete(3),
disabled(4),
parallelDetectFail(5)
Current autonegotiation state of an interface MAU.
As per the MIB.
ifMauAutoNegCapability (1.3.6.1.2.1.26.5.1.1.5)
read-only
Integer32
Autonegotiation type list of an interface MAU.
As per the MIB.
ifMauAutoNegCapAdvertised (1.3.6.1.2.1.26.5.1.1.6)
read-write
Integer32
Autonegotiation type list advertised by an interface MAU.
ifMauAutoNegCapReceived (1.3.6.1.2.1.26.5.1.1.7)
read-only
Integer32
Received autonegotiation type list from a remote autonegotiation entity.
As per the MIB.
ifMauAutoNegRestart (1.3.6.1.2.1.26.5.1.1.8)
read-write
INTEGER
restart(1),
norestart(2)
Whether autonegotiation will be restarted on an interface MAU.
ifMauAutoNegCapabilityBits (1.3.6.1.2.1.26.5.1.1.9)
read-only
BITS
bOther(0),
b10baseT(1),
b10baseTFD(2),
b100baseT4(3),
b100baseTX(4),
b100baseTXFD(5),
b100baseT2(6),
b100baseT2FD(7),
bfdxPause(8),
bfdxAPause(9),
bfdxSPause(10),
bfdxBPause(11),
b1000baseX(12),
b1000baseXFD(13),
b1000baseT(14),
b1000baseTFD(15),
b10GbaseT(16),
b1000baseKX(17),
b10GbaseKX4(18),
b10GbaseKR(19),
b40GbaseKR4(20),
b40GbaseCR4(21),
b100GbaseCR10(22),
b1000baseT1(23),
b25GbaseRS(24),
b25GbaseR(25),
bRSFEC25Greq(26),
bBaseFEC25Greq(27),
b25GbaseT(28),
b40GbaseT(29),
b100GbaseCR4(30),
b100GbaseKR4(31),
b100GbaseKP4(32),
bForceMS(33),
b2p5GbaseT(34),
b5GBaseT(35),
b2p5GbaseKX(36),
b5GbaseKR(37),
b50GbaseR(38),
b100GbaseR2(39),
b200GbaseR4(40),
b10baseT1L(41),
b10baseT1S(42),
Set of capabilities of the local autonegotiation entity.
As per the MIB.
ifMauAutoNegCapAdvertisedBits (1.3.6.1.2.1.26.5.1.1.10)
read-write
BITS
bOther(0),
b10baseT(1),
b10baseTFD(2),
b100baseT4(3),
b100baseTX(4),
b100baseTXFD(5),
b100baseT2(6),
b100baseT2FD(7),
bFdxPause(8),
bFdxAPause(9),
bFdxSPause(10),
bFdxBPause(11),
b1000baseX(12),
b1000baseXFD(13),
b1000baseT(14),
b1000baseTFD(15),
b10GbaseT(16),
b1000baseKX(17),
b10GbaseKX4(18),
b10GbaseKR(19),
b40GbaseKR4(20),
b40GbaseCR4(21),
b100GbaseCR10(22),
b1000baseT1(23),
b25GbaseRS(24),
b25GbaseR(25),
bRSFEC25Greq(26),
bBaseFEC25Greq(27),
b25GbaseT(28),
b40GbaseT(29),
b100GbaseCR4(30),
b100GbaseKR4(31),
b100GbaseKP4(32),
bForceMS(33),
b2p5GbaseT(34),
b5GBaseT(35),
b2p5GbaseKX(36),
b5GbaseKR(37),
b50GbaseR(38),
b100GbaseR2(39),
b200GbaseR4(40),
b10baseT1L(41),
b10baseT1S(42),
Set of capabilities advertised by the local autonegotiation entity.
ifMauAutoNegCapReceivedBits (1.3.6.1.2.1.26.5.1.1.11)
read-only
BITS
bOther(0),
b10baseT(1),
b10baseTFD(2),
b100baseT4(3),
b100baseTX(4),
b100baseTXFD(5),
b100baseT2(6),
b100baseT2FD(7),
bFdxPause(8),
bFdxAPause(9),
bFdxSPause(10),
bFdxBPause(11),
b1000baseX(12),
b1000baseXFD(13),
b1000baseT(14),
b1000baseTFD(15),
b10GbaseT(16),
b1000baseKX(17),
b10GbaseKX4(18),
b10GbaseKR(19),
b40GbaseKR4(20),
b40GbaseCR4(21),
b100GbaseCR10(22),
b1000baseT1(23),
b25GbaseRS(24),
b25GbaseR(25),
bRSFEC25Greq(26),
bBaseFEC25Greq(27),
b25GbaseT(28),
b40GbaseT(29),
b100GbaseCR4(30),
b100GbaseKR4(31),
b100GbaseKP4(32),
bForceMS(33),
b2p5GbaseT(34),
b5GBaseT(35),
b2p5GbaseKX(36),
b5GbaseKR(37),
b50GbaseR(38),
b100GbaseR2(39),
b200GbaseR4(40),
b10baseT1L(41),
b10baseT1S(42),
Set of capabilities received from the remote autonegotiation entity.
As per the MIB.
ifMauAutoNegRemoteFaultAdvertised (1.3.6.1.2.1.26.5.1.1.12)
read-write
INTEGER
noError(1),
offline(2),
linkFailure(3),
autoNegError(4)
Local fault indications that this MAU has detected and will advertise at the next autonegotiation interaction.
ifMauAutoNegRemoteFaultReceived (1.3.6.1.2.1.26.5.1.1.13)
read-only
INTEGER
noError(1),
offline(2),
linkFailure(3),
autoNegError(4)
Fault indications received by the local end from the far end.
As per the MIB.
