04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
24-LLDP-MIB
24-LLDP-MIB 196.13 KB
LLDP-MIB
About this MIB
Use this MIB to configure the following LLDP information:
·     LLDP configuration.
·     LLDP statistics.
·     LLDP local system information.
·     LLDP neighbor system information.
MIB file name
lldp.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2)
Scalar objects
lldpMessageTxInterval
Object (OID)
Access
Value range
Implementation
lldpMessageTxInterval (1.0.8802.1.1.2.1.1.1)
read-write
Integer32
Integer32 (5..32768)
LLDP frame transmission interval.
As per the MIB.
lldpMessageTxHoldMultiplier
Object (OID)
Access
Value range
Implementation
lldpMessageTxHoldMultiplier (1.0.8802.1.1.2.1.1.2)
read-write
Integer32
Integer32 (2..10)
TTL multiplier.
As per the MIB.
lldpReinitDelay
Object (OID)
Access
Value range
Implementation
lldpReinitDelay (1.0.8802.1.1.2.1.1.3)
read-write
Integer32
Integer32 (1..10)
LLDP reinitialization delay.
As per the MIB.
lldpTxDelay
Object (OID)
Access
Value range
Implementation
lldpTxDelay (1.0.8802.1.1.2.1.1.4)
read-write
Integer32
Integer32 (1..8192)
LLDP frame transmission delay.
The value is fixed at 2, which indicates that this delay is not supported.
lldpNotificationInterval
Object (OID)
Access
Value range
Implementation
lldpNotificationInterval (1.0.8802.1.1.2.1.1.5)
read-write
Integer32
Integer32 (5..3600)
Trap transmission interval.
As per the MIB.
lldpStatsRemTablesLastChangeTime
Object (OID)
Access
Value range
Implementation
lldpStatsRemTablesLastChangeTime (1.0.8802.1.1.2.1.2.1)
read-only
TimeStamp
Standard MIB values.
Time when LLDP information about a neighboring device was last updated.
As per the MIB.
lldpStatsRemTablesInserts
Object (OID)
Access
Value range
Implementation
lldpStatsRemTablesInserts (1.0.8802.1.1.2.1.2.2)
read-only
ZeroBasedCounter32
Number of neighbors added by LLDP.
As per the MIB.
lldpStatsRemTablesDeletes
Object (OID)
Access
Value range
Implementation
lldpStatsRemTablesDeletes (1.0.8802.1.1.2.1.2.3)
read-only
ZeroBasedCounter32
Number of neighbors deleted by LLDP.
As per the MIB.
lldpStatsRemTablesDrops
Object (OID)
Access
Value range
Implementation
lldpStatsRemTablesDrops (1.0.8802.1.1.2.1.2.4)
read-only
ZeroBasedCounter32
Number of neighbors discarded by LLDP.
As per the MIB.
lldpStatsRemTablesAgeouts
Object (OID)
Access
Value range
Implementation
lldpStatsRemTablesAgeouts (1.0.8802.1.1.2.1.2.5)
read-only
ZeroBasedCounter32
Neighbor ageout count.
As per the MIB.
lldpLocChassisIdSubtype
Object (OID)
Access
Value range
Implementation
lldpLocChassisIdSubtype (1.0.8802.1.1.2.1.3.1)
read-only
LldpChassisIdSubtype
Local chassis ID subtype.
As per the MIB.
lldpLocChassisId
Object (OID)
Access
Value range
Implementation
lldpLocChassisId (1.0.8802.1.1.2.1.3.2)
read-only
LldpChassisId
Local chassis ID.
As per the MIB.
lldpLocSysName
Object (OID)
Access
Value range
Implementation
lldpLocSysName (1.0.8802.1.1.2.1.3.3)
read-only
SnmpAdminString
OCTET STRING (0..255)
Local system name.
As per the MIB.
lldpLocSysDesc
Object (OID)
Access
Value range
Implementation
lldpLocSysDesc (1.0.8802.1.1.2.1.3.4)
read-only
SnmpAdminString
Local system description.
As per the MIB.
lldpLocSysCapSupported
Object (OID)
Access
Value range
Implementation
lldpLocSysCapSupported (1.0.8802.1.1.2.1.3.5)
read-only
LldpSystemCapabilitiesMap
Capabilities supported by the local system.
As per the MIB.
lldpLocSysCapEnabled
Object (OID)
Access
Value range
Implementation
lldpLocSysCapEnabled (1.0.8802.1.1.2.1.3.6)
read-only
Capabilities enabled on the local system.
As per the MIB.
Tabular objects
lldpPortConfigTable
About this table
Use this table to configure LLDP on a port.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is lldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.1.6.
Object (OID)
Access
Value range
Implementation
lldpPortConfigPortNum (1.0.8802.1.1.2.1.1.6.1.1)
not-accessible
LldpPortNumber
Port number.
As per the MIB.
lldpPortConfigAdminStatus (1.0.8802.1.1.2.1.1.6.1.2)
read-write
INTEGER
txOnly(1)
rxOnly(2)
txAndRx(3)
disabled(4)
LLDP operating mode.
As per the MIB.
lldpPortConfigNotificationEnable (1.0.8802.1.1.2.1.1.6.1.3)
read-write
TruthValue
Trapping status.
As per the MIB.
lldpPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.1.6.1.4)
read-write
BITS
BITS {
portDesc(0)
sysName(1)
sysDesc(2)
sysCap(3)
Optional TLVs that the port can send.
Default: All bits are set to 1, which indicates that all basic optional TLVs are enabled.
lldpConfigManAddrTable
About this table
Use this table to configure management addresses.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpLocManAddrSubtype and lldpLocManAddr.
The table OID is 1.0.8802.1.1.2.1.1.7.
Object (OID)
Access
Value range
Implementation
lldpConfigManAddrPortsTxEnable (1.0.8802.1.1.2.1.1.7.1.1)
read-write
LldpPortList
Ports that can send management addresses.
Each bit set in this list represents a port. By default, all bits are set to 1, which indicates that all ports can send management addresses.
lldpStatsTxPortTable
About this table
Use this table to obtain outgoing LLDP packet statistics about ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpStatsTxPortNum.
The table OID is 1.0.8802.1.1.2.1.2.6.
Object (OID)
Access
Value range
Implementation
lldpStatsTxPortNum (1.0.8802.1.1.2.1.2.6.1.1)
not-accessible
LldpPortNumber
Port number.
As per the MIB.
lldpStatsTxPortFramesTotal (1.0.8802.1.1.2.1.2.6.1.2)
read-only
Counter32
Total outgoing frame count.
As per the MIB.
lldpStatsRxPortTable
About this table
Use this table to obtain incoming LLDP packet statistics about ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpStatsRxPortNum.
The table OID is 1.0.8802.1.1.2.1.2.7.
Object (OID)
Access
Value range
Implementation
lldpStatsRxPortNum (1.0.8802.1.1.2.1.2.7.1.1)
not-accessible
LldpPortNumber
Port number.
As per the MIB.
lldpStatsRxPortFramesDiscardedTotal (1.0.8802.1.1.2.1.2.7.1.2)
read-only
Counter32
Discarded incoming frame count.
As per the MIB.
lldpStatsRxPortFramesErrors (1.0.8802.1.1.2.1.2.7.1.3)
read-only
Counter32
Error incoming frame count.
As per the MIB.
lldpStatsRxPortFramesTotal (1.0.8802.1.1.2.1.2.7.1.4)
read-only
Counter32
Total incoming frame count.
As per the MIB.
lldpStatsRxPortTLVsDiscardedTotal (1.0.8802.1.1.2.1.2.7.1.5)
read-only
Counter32
Discarded incoming TLV count.
As per the MIB.
lldpStatsRxPortTLVsUnrecognizedTotal (1.0.8802.1.1.2.1.2.7.1.6)
read-only
Counter32
Unrecognized incoming TLV count.
As per the MIB.
lldpStatsRxPortAgeoutsTotal (1.0.8802.1.1.2.1.2.7.1.7)
read-only
ZeroBasedCounter32
As per the MIB.
lldpLocPortTable
About this table
Use this table to obtain LLDP information about local ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpLocPortNum.
The table OID is 1.0.8802.1.1.2.1.3.7.
Object (OID)
Access
Value range
Implementation
lldpLocPortNum (1.0.8802.1.1.2.1.3.7.1.1)
not-accessible
LldpPortNumber
Port number.
As per the MIB.
lldpLocPortIdSubtype (1.0.8802.1.1.2.1.3.7.1.2)
read-only
LldpPortIdSubtype
Port ID subtype.
As per the MIB.
lldpLocPortId (1.0.8802.1.1.2.1.3.7.1.3)
read-only
LldpPortId
Port ID.
If the port has a MED neighbor, the port ID is the MAC address of the port. If the port does not have a MED neighbor, the port ID is the name of the port.
lldpLocPortDesc (1.0.8802.1.1.2.1.3.7.1.4)
read-only
SnmpAdminString
Port description.
As per the MIB.
lldpLocManAddrTable
About this table
Use this table to obtain local management address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpLocManAddrSubtype, lldpLocManAddr.
The table OID is 1.0.8802.1.1.2.1.3.8.
Object (OID)
Access
Value range
Implementation
lldpLocManAddrSubtype (1.0.8802.1.1.2.1.3.8.1.1)
not-accessible
AddressFamilyNumbers
Management address subtype.
As per the MIB.
lldpLocManAddr (1.0.8802.1.1.2.1.3.8.1.2)
not-accessible
LldpManAddress
Management address.
As per the MIB.
lldpLocManAddrLen (1.0.8802.1.1.2.1.3.8.1.3)
read-only
Integer32
Management address length.
As per the MIB.
lldpLocManAddrIfSubtype (1.0.8802.1.1.2.1.3.8.1.4)
read-only
LldpManAddrIfSubtype
The enumeration value that identifies the port numbering method used for defining the port number associated with the local system.
The subtype is IfIndex.
lldpLocManAddrIfId (1.0.8802.1.1.2.1.3.8.1.5)
read-only
Integer32
Index of the port associated with the management address.
If no port is associated with the management address, the value of this object is 0.
lldpLocManAddrOID (1.0.8802.1.1.2.1.3.8.1.6)
read-only
OBJECT IDENTIFIER
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the local system agent.
Not supported.
lldpRemTable
About this table
Use this table to obtain neighbor configuration and related local indexes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.4.1.
Object (OID)
Access
Value range
Implementation
lldpRemTimeMark (1.0.8802.1.1.2.1.4.1.1.1)
not-accessible
TimeFilter
Time mark for a neighbor.
The time mark is the time when this object is created or the remote system is updated.
You can use the time mark to search for remote system records.
lldpRemLocalPortNum (1.0.8802.1.1.2.1.4.1.1.2)
not-accessible
LldpPortNumber
Local port receiving the neighbor information.
As per the MIB.
lldpRemIndex (1.0.8802.1.1.2.1.4.1.1.3)
not-accessible
Integer32
Integer32 (1..2147483647)
Neighbor index.
As per the MIB.
lldpRemChassisIdSubtype (1.0.8802.1.1.2.1.4.1.1.4)
read-only
Neighbor chassis ID subtype.
As per the MIB.
lldpRemChassisId (1.0.8802.1.1.2.1.4.1.1.5)
read-only
LldpChassisId
Neighbor chassis ID.
As per the MIB.
lldpRemPortIdSubtype (1.0.8802.1.1.2.1.4.1.1.6)
read-only
LldpPortIdSubtype
Neighbor port ID subtype.
As per the MIB.
lldpRemPortId (1.0.8802.1.1.2.1.4.1.1.7)
read-only
LldpPortId
Neighbor port ID.
As per the MIB.
lldpRemPortDesc (1.0.8802.1.1.2.1.4.1.1.8)
read-only
SnmpAdminString
Neighbor port description.
As per the MIB.
lldpRemSysName (1.0.8802.1.1.2.1.4.1.1.9)
read-only
SnmpAdminString
Neighbor system name.
As per the MIB.
lldpRemSysDesc (1.0.8802.1.1.2.1.4.1.1.10)
read-only
SnmpAdminString
Neighbor system description.
As per the MIB.
lldpRemSysCapSupported (1.0.8802.1.1.2.1.4.1.1.11)
read-only
Capabilities supported by the neighbor system.
As per the MIB.
lldpRemSysCapEnabled (1.0.8802.1.1.2.1.4.1.1.12)
read-only
Capabilities enabled on the neighbor system.
As per the MIB.
lldpRemManAddrTable
About this table
Use this table to obtain neighbor management address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemManAddrSubtype, and lldpRemManAddr.
The table OID is 1.0.8802.1.1.2.1.4.2.
Object (OID)
Access
Value range
Implementation
lldpRemManAddrSubtype (1.0.8802.1.1.2.1.4.2.1.1)
not-accessible
As per the MIB.
lldpRemManAddr (1.0.8802.1.1.2.1.4.2.1.2)
not-accessible
LldpManAddress
Management address.
As per the MIB.
lldpRemManAddrIfSubtype (1.0.8802.1.1.2.1.4.2.1.3)
read-only
The enumeration value that identifies the port numbering method used for defining the port number associated with the remote system.
As per the MIB.
lldpRemManAddrIfId (1.0.8802.1.1.2.1.4.2.1.4)
read-only
Integer32
As per the MIB.
lldpRemManAddrOID (1.0.8802.1.1.2.1.4.2.1.5)
read-only
OBJECT IDENTIFIER
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the remote system agent.
Not supported
lldpRemUnknownTLVTable
About this table
Use this table to display the unrecognized TLVs received from neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpRemunknownTLVType.
The table OID is 1.0.8802.1.1.2.1.4.3.
Object (OID)
Access
Value range
Implementation
lldpRemUnknownTLVType (1.0.8802.1.1.2.1.4.3.1.1)
not-accessible
Integer32
Integer32 (9..126)
TLV type.
As per the MIB.
lldpRemUnknownTLVInfo (1.0.8802.1.1.2.1.4.3.1.2)
read-only
OCTET STRING
OCTET STRING (0..511)
TLV string.
As per the MIB.
lldpRemOrgDefInfoTable
About this table
Use this table to display the neighbor organizationally defined information not recognized by the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemOrgDefInfoOUI, lldpRemOrgDefInfoSubtype, and lldpRemOrgDefInfoIndex.
The table OID is 1.0.8802.1.1.2.1.4.4.
Object (OID)
Access
Value range
Implementation
lldpRemOrgDefInfoOUI (1.0.8802.1.1.2.1.4.4.1.1)
not-accessible
OCTET STRING
OCTET STRING (3)
Organizationally Unique Identifier (OUI).
As per the MIB.
lldpRemOrgDefInfoSubtype (1.0.8802.1.1.2.1.4.4.1.2)
not-accessible
Integer32
Integer32 (1..255)
Subtype of the organizationally defined information.
As per the MIB.
lldpRemOrgDefInfoIndex (1.0.8802.1.1.2.1.4.4.1.3)
not-accessible
Integer32
Index of the organizationally defined information.
As per the MIB.
lldpRemOrgDefInfo (1.0.8802.1.1.2.1.4.4.1.4)
read-only
OCTET STRING
OCTET STRING (0..507)
Organizationally defined information.
As per the MIB.
Notifications
lldpRemTablesChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.0.8802.1.1.2.0.0.1
Neighbor events.
Informational
Warning
OFF
This notification is generated when the value of the lldpStatsRemTableLastChangeTime object changes.
You can set the notification transmission interval by configuring the lldpNotificationInterval object.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpPortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpPortConfigNotificationEnable object to false(2).
Objects
OID (object name)
Index
Value range
1.0.8802.1.1.2.1.2.2 (lldpStatsRemTablesInserts)
Neighbor creation.
No
ZeroBasedCounter32
1.0.8802.1.1.2.1.2.3 (lldpStatsRemTablesDeletes)
Neighbor deletion.
No
ZeroBasedCounter32
1.0.8802.1.1.2.1.2.4 (lldpStatsRemTablesDrops)
Neighbor discard.
No
ZeroBasedCounter32
1.0.8802.1.1.2.1.2.5 (lldpStatsRemTablesAgeouts)
Neighbor ageout.
No
ZeroBasedCounter32
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Verify that the topology changes are as expected.
If you cannot resolve the issue, contact H3C Support.
