04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
11-HH3C-SUBNET-VLAN-MIB
11-HH3C-SUBNET-VLAN-MIB 74.16 KB
About this MIB
Use this MIB to manage and obtain information about IP subnet-based VLANs on a device that supports the subnet-based VLAN feature.
MIB file name
hh3c-subnet-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSubnetVlan(61)
Scalar objects
hh3cSubnetNumAllVlan
Object (OID)
Access
Value range
Implementation
hh3cSubnetNumAllVlan (1.3.6.1.4.1.25506.2.61.1.1.1)
read-only
Integer32
Standard MIB values.
Maximum number subnets that can be configured for all VLANs.
Implementation varies by product.
hh3cSubnetNumPerVlan
Object (OID)
Access
Value range
Implementation
hh3cSubnetNumPerVlan (1.3.6.1.4.1.25506.2.61.1.1.2)
read-only
Integer32
Maximum number of subnets that can be configured for a single VLAN.
hh3cSubnetNumAllPort
Object (OID)
Access
Value range
Implementation
hh3cSubnetNumAllPort (1.3.6.1.4.1.25506.2.61.1.1.3)
read-only
Integer32
Maximum number of subnets that can be configured for all ports.
hh3cSubnetNumPerPort
Object (OID)
Access
Value range
Implementation
hh3cSubnetNumPerPort (1.3.6.1.4.1.25506.2.61.1.1.4)
read-only
Integer32
Maximum number of subnets that can be configured for a single port.
Tabular objects
hh3cSubnetVlanTable
About this table
Use this table to configure and obtain information about VLAN-to-IP subnet or address mappings.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cSubnetVlanVlanId and hh3cSubnetVlanSubnetIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.61.1.2.1.1)
not-accessible
Integer32
Subnet-based VLAN ID.
As per the MIB.
(1.3.6.1.4.1.25506.2.61.1.2.1.2)
not-accessible
Integer32
IP subnet index.
As per the MIB.
hh3cSubnetVlanVlanIpAddressType
(1.3.6.1.4.1.25506.2.61.1.2.1.3)
read-create
InetAddressType
IP subnet address type.
This object cannot be separately modified after the VLAN-to-IP subnet mapping is configured.
hh3cSubnetVlanIpAddressValue
(1.3.6.1.4.1.25506.2.61.1.2.1.4)
read-create
InetAddress
OCTET STRING (0..255)
IP subnet address.
hh3cSubnetVlanNetMaskValue
(1.3.6.1.4.1.25506.2.61.1.2.1.5)
read-create
InetAddress
IP subnet mask.
This object cannot be separately modified after the VLAN-to-IP subnet mapping is configured. When no value is specified, the default is 255.255.255.0.
hh3cSubnetVlanRowStatus
(1.3.6.1.4.1.25506.2.61.1.2.1.6)
read-create
RowStatus
Subnet-based VLAN row state.
Only the following operations are supported:
active(1), createAndGo(4), and destroy(6)
hh3cSubnetVlanPortCreateTable
About this table
Use this table to configure and obtain information about port-to-IP subnet-based VLAN mappings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cSubnetVlanPortCreateIndex and hh3cSubnetVlanPortCreateVlanId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.61.1.3.1.1)
not-accessible
Integer32
Port index.
As per the MIB.
(1.3.6.1.4.1.25506.2.61.1.3.1.2)
not-accessible
Integer32
ID of an IP subnet-based VLAN created on a port.
As per the MIB.
hh3cSubnetVlanPortInfoVlanId
(1.3.6.1.4.1.25506.2.61.1.3.1.3)
read-only
Integer32
ID of an IP subnet-based VLAN on a port.
As per the MIB.
hh3cSubnetVlanPortRowStatus
(1.3.6.1.4.1.25506.2.61.1.3.1.4)
read-create
RowStatus
Port's subnet-based VLAN row state.
As per the MIB.
hh3cSubnetVlanPortStatus
( 1.3.6.1.4.1.25506.2.61.1.3.1.5 )
read-only
INTEGER
active (1),
inactive (2)
Subnet-based VLAN state on a port.
Active:
The subnet-based VLAN has been associated with the specified IP address. The h3cSubnetVlanPortCreateVlanId object has the corresponding data in the h3cSubnetVlanTable table, the link type of the port is hybrid, and the port is assigned to the VLAN.
