- 04-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PROTOCOL-VLAN-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-SUBNET-VLAN-MIB
- 12-HH3C-VMAP-MIB
- 13-HH3C-VOICE-VLAN-MIB
- 14-HH3C-LswMSTP-MIB
- 15-HH3C-LswVLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-MED-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-Q-BRIDGE-MIB
- 28-RBRIDGE-MIB
| 14-HH3C-LswMSTP-MIB | 380.29 KB |
hh3cdot1sMstAdminFormatSelector
hh3cdot1sMstAdminRevisionLevel
hh3cdot1sMstOperFormatSelector
HH3C-LswMSTP-MIB
About this MIB
Spanning tree protocols eliminate loops by selectively blocking ports to prune the loop structure into a loop-free tree structure.
This MIB defines private MIB objects for MSTP.
MIB file name
hh3c-splat-mstp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).products(2).lanSw(23).lswCommon(1).hwdotlsMstp(14)
Scalar objects
hh3cdot1sStpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpStatus (1.3.6.1.4.1.25506.8.35.14.1) |
read-write |
EnabledStatus |
enabled(1) disabled(2) |
MSTP status. |
As per the MIB. |
hh3cdot1sStpForceVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpForceVersion (1.3.6.1.4.1.25506.8.35.14.2) |
read-write |
INTEGER |
stp(0) rstp(2) mstp(3) |
Spanning tree mode. |
Same as MIB definition. The value for PVST is 2. |
hh3cdot1sStpDiameter
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpDiameter (1.3.6.1.4.1.25506.8.35.14.3) |
read-write |
INTEGER |
2..7 |
Network diameter. |
This object is related to the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects defined in IEEE 802.1d. Modification to the hh3cdot1sStpDiameter object will change the values of those objects. Modification to any of the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects will invalidate the value of the hh3cdot1sStpDiameter object. |
hh3cdot1sMstBridgeMaxHops
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstBridgeMaxHops (1.3.6.1.4.1.25506.8.35.14.4) |
read-write |
INTEGER |
1..40 |
Maximum hops of an MST region. |
As per the MIB. |
hh3cdot1sMstMasterBridgeID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.5) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge in an MSTP region. |
As per the MIB. |
hh3cdot1sMstMasterPathCost
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstMasterPathCost (1.3.6.1.4.1.25506.8.35.14.6) |
read-only |
INTEGER |
Standard MIB values. |
Cost of the path to the root bridge. |
As per the MIB. |
hh3cdot1sMstBpduGuard
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstBpduGuard (1.3.6.1.4.1.25506.8.35.14.7) |
read-write |
EnabledStatus |
BPDU guard. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminFormatSelector (1.3.6.1.4.1.25506.8.35.14.8) |
read-write |
INTEGER |
0. |
Bridge selection factor. |
This object is configurable, and you can set it only to 0. |
hh3cdot1sMstAdminRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminRegionName (1.3.6.1.4.1.25506.8.35.14.9) |
read-write |
OCTET STRING |
SIZE (1..32) |
MST region name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstAdminRevisionLevel (1.3.6.1.4.1.25506.8.35.14.10) |
read-write |
INTEGER |
0..65535 |
MSTP revision level. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperFormatSelector (1.3.6.1.4.1.25506.8.35.14.11) |
read-only |
INTEGER |
Effective selection factor of an MSTP region. |
As per the MIB. |
hh3cdot1sMstOperRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperRegionName (1.3.6.1.4.1.25506.8.35.14.12) |
read-only |
OCTET STRING |
SIZE (0..32) |
Effective MST region name. |
As per the MIB. |
hh3cdot1sMstOperRevisionLevel
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperRevisionLevel (1.3.6.1.4.1.25506.8.35.14.13) |
read-only |
INTEGER |
0..65535 |
Effective MSTP revision level. |
As per the MIB. |
hh3cdot1sMstOperConfigDigest
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstOperConfigDigest (1.3.6.1.4.1.25506.8.35.14.14) |
read-only |
OCTET STRING
SIZE (0..16) |
Effective configuration digest of an MST region. |
As per the MIB. |
hh3cdot1sMstRegionConfActive
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstRegionConfActive (1.3.6.1.4.1.25506.8.35.14.15) |
read-write |
INTEGER |
enable(1) disable(2) |
Activate MST region configuration. |
Default: Enabled. If you set the value to disable, MST region configuration is read-only and does not take effect. |
hh3cdot1sMstDefaultVlanAllo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstDefaultVlanAllo (1.3.6.1.4.1.25506.8.35.14.16) |
read-write |
INTEGER |
enable(1) unused(65535) |
Default VLAN-to-instance mappings in an MST region. |
As per the MIB. |
hh3cdot1sMstDefaultRegionName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstDefaultRegionName (1.3.6.1.4.1.25506.8.35.14.17) |
read-write |
INTEGER |
Default MST region name. |
As per the MIB. |
hh3cdot1sStpPathCostStandard
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sStpPathCostStandard (1.3.6.1.4.1.25506.8.35.14.21) |
read-write |
INTEGER |
legacy(0) dot1d-1998(1) dot1t(2) |
Standard for calculating the default path costs. |
· legacy—Private standard. · dot1d-1998—IEEE 802.1d-1998. · dot1t—IEEE 802.1t. |
hh3cMstiTcGuardVal
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiTcGuardVal (1.3.6.1.4.1.25506.8.35.14.22.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..255) |
TC threshold. |
As per the MIB. |
hh3cPvstPvid
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPvstPvid (1.3.6.1.4.1.25506.8.35.14.22.2) |
Integer32 |
Integer32 (1..4094) |
PVID. |
As per the MIB. |
hh3cPvstPvidInPdu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPvstPvidInPdu (1.3.6.1.4.1.25506.8.35.14.22.3) |
Integer32 |
PVID carried in packets. |
As per the MIB. |
hh3cMstiLpuStgNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiLpuStgNum (1.3.6.1.4.1.25506.8.35.14.22.4) |
Integer32 |
STG count of the LPU. |
As per the MIB. |
hh3cMstiMpuStgNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiMpuStgNum (1.3.6.1.4.1.25506.8.35.14.22.5) |
Integer32 |
STG count of the MPU. |
As per the MIB. |
hh3cMstiVlanID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiVlanID (1.3.6.1.4.1.25506.8.35.14.22.6) |
Integer32 |
VLAN ID. |
As per the MIB. |
hh3cMstiBridgeIDInPdu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiBridgeIDInPdu (1.3.6.1.4.1.25506.8.35.14.22.7) |
BridgeId |
OCTET STRING (8) |
Bridge ID carried in low-priority BPDUs. |
As per the MIB. |
hh3cMstiPortPriorityInPdu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiPortPriorityInPdu (1.3.6.1.4.1.25506.8.35.14.22.8) |
Integer32 |
Integer32 (1..65535) |
Port priority carried in low-priority BPDUs. |
As per the MIB. |
hh3cMstiPortNumInPdu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMstiPortNumInPdu (1.3.6.1.4.1.25506.8.35.14.22.9) |
Integer32 |
Port ID carried in low-priority BPDUs. |
As per the MIB. |
Tabular objects
hh3cdot1sVIDAllocationTable
About this table
Use this table to configure MSTP VLAN settings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cdot1sMstVID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstVID (1.3.6.1.4.1.25506.8.35.14.18.1.1) |
read-only |
INTEGER |
1..4094 |
VLAN ID |
As per the MIB. |
hh3cdot1sAdminMstID (1.3.6.1.4.1.25506.8.35.14.18.1.2) |
read-write |
INTEGER |
0..4094 |
Configured MST region mapping. |
As per the MIB. |
hh3cdot1sOperMstID (1.3.6.1.4.1.25506.8.35.14.18.1.3) |
read-only |
INTEGER |
0..4094 |
Effective MST region mapping. |
As per the MIB. |
hh3cdot1sInstanceTable
About this table
Use this table to configure MST region settings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cdot1sInstanceID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sInstanceID (1.3.6.1.4.1.25506.8.35.14.19.1.1) |
read-only |
INTEGER |
0..4094 |
Instance ID. |
As per the MIB. |
hh3cdot1sMstiBridgeID (1.3.6.1.4.1.25506.8.35.14.19.1.2) |
read-only |
BridgeId |
OCTET STRING (8) |
Bridge ID. |
As per the MIB. |
hh3cdot1sMstiBridgePriority (1.3.6.1.4.1.25506.8.35.14.19.1.3) |
read-write |
INTEGER |
0..61440 |
Bridge priority. |
As per the MIB. |
hh3cdot1sMstiDesignedRoot (1.3.6.1.4.1.25506.8.35.14.19.1.4) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge. |
As per the MIB. |
hh3cdot1sMstiRootPathCost (1.3.6.1.4.1.25506.8.35.14.19.1.5) |
read-only |
INTEGER |
Path cost from the MSTI to the root bridge. |
As per the MIB. |
hh3cdot1sMstiRootPort (1.3.6.1.4.1.25506.8.35.14.19.1.6) |
read-only |
INTEGER |
Root port. |
As per the MIB. |
hh3cdot1sMstiRootType (1.3.6.1.4.1.25506.8.35.14.19.1.7) |
read-write |
INTEGER |
normal(0) secondary(1) primary(2) |
Root bridge type. |
As per the MIB. |
hh3cdot1sMstiRemainingHops (1.3.6.1.4.1.25506.8.35.14.19.1.8) |
read-only |
INTEGER |
Remaining hops. |
As per the MIB. |
hh3cdot1sMstiAdminMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.9) |
read-only |
OCTET STRING |
SIZE (0..256) |
Lower part of the VLAN ID list mapped to the instance. |
As per the MIB. |
hh3cdot1sMstiAdminMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.10) |
read-only |
OCTET STRING |
SIZE (0..256) |
Higher part of the VLAN ID list mapped to the instance. |
As per the MIB. |
hh3cdot1sMstiOperMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.11) |
read-only |
OCTET STRING |
SIZE (0..256) |
Lower part of the effective VLAN ID list. |
As per the MIB. |
hh3cdot1sMstiOperMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.12) |
read-only |
OCTET STRING |
SIZE (0..256) |
Higher part of the effective VLAN ID list. |
As per the MIB. |
hh3cdot1sPortTable
About this table
Use this table to configure MSTP on ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are hh3cdot1sInstanceID and hh3cdot1sMstiPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1sMstiPortIndex (1.3.6.1.4.1.25506.8.35.14.20.1.1) |
read-only |
INTEGER |
(0..65535) |
Port index. |
As per the MIB. |
hh3cdot1sMstiState (1.3.6.1.4.1.25506.8.35.14.20.1.2) |
read-only |
INTEGER |
disabled(1) discarding(2) learning(4) forwarding(5) |
Port status. |
Does not support disabled. |
hh3cdot1sMstiPortPriority (1.3.6.1.4.1.25506.8.35.14.20.1.3) |
read-write |
INTEGER |
0..240 |
Port priority. |
As per the MIB. |
hh3cdot1sMstiPathCost (1.3.6.1.4.1.25506.8.35.14.20.1.4) |
read-write |
INTEGER |
1..200000000 |
Port path cost. |
As per the MIB. |
hh3cdot1sMstiDesignatedRoot (1.3.6.1.4.1.25506.8.35.14.20.1.5) |
read-only |
BridgeId |
OCTET STRING (8) |
Root bridge. |
As per the MIB. |
hh3cdot1sMstiDesignatedCost (1.3.6.1.4.1.25506.8.35.14.20.1.6) |
read-only |
INTEGER |
Path cost of the designated port. |
As per the MIB. |
hh3cdot1sMstiDesignatedBridge (1.3.6.1.4.1.25506.8.35.14.20.1.7) |
read-only |
BridgeId |
OCTET STRING (8) |
Designated bridge. |
As per the MIB. |
hh3cdot1sMstiDesignatedPort (1.3.6.1.4.1.25506.8.35.14.20.1.8) |
read-only |
OCTET STRING |
SIZE (2) |
Designated port. |
As per the MIB. |
hh3cdot1sMstiMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.20.1.9) |
read-only |
BridgeId |
OCTET STRING (8) |
Master bridge. |
As per the MIB. |
hh3cdot1sMstiMasterPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.10) |
read-only |
INTEGER |
Path cost to the master bridge. |
As per the MIB. |
hh3cdot1sMstiStpPortEdgeport (1.3.6.1.4.1.25506.8.35.14.20.1.11) |
read-write |
EnabledStatus |
Whether the port is an edge port. |
As per the MIB. |
hh3cdot1sMstiStpPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.12) |
read-write |
INTEGER |
forceTrue(1) forceFalse(2) auto(3) |
Whether to set the port link type to point-to-point. |
As per the MIB. |
hh3cdot1sMstiStpMcheck (1.3.6.1.4.1.25506.8.35.14.20.1.13) |
read-write |
INTEGER |
Perform mCheck. |
As per the MIB. |
hh3cdot1sMstiStpTransLimit (1.3.6.1.4.1.25506.8.35.14.20.1.14) |
read-write |
INTEGER |
1..255 |
BPDU transmission rate. |
Default: 10. |
hh3cdot1sMstiStpRXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.15) |
read-only |
Counter32 |
Incoming BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.16) |
read-only |
Counter32 |
Outgoing BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.17) |
read-only |
Counter32 |
Incoming TCN BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.18) |
read-only |
Counter32 |
Outgoing TCN BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.19) |
read-only |
Counter32 |
Incoming RSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.20) |
read-only |
Counter32 |
Outgoing RSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpRXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.21) |
read-only |
Counter32 |
Incoming MSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpTXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.22) |
read-only |
Counter32 |
Outgoing MSTP BPDU count. |
As per the MIB. |
hh3cdot1sMstiStpClearStatistics (1.3.6.1.4.1.25506.8.35.14.20.1.23) |
read-write |
INTEGER |
clear(1) unused(65535) |
Clear packet statistics. |
As per the MIB. |
hh3cdot1sMstiStpDefaultPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.24) |
read-write |
INTEGER |
Default port path cost. |
As per the MIB. |
hh3cdot1sMstiStpStatus (1.3.6.1.4.1.25506.8.35.14.20.1.25) |
read-write |
EnabledStatus |
Spanning tree feature status. |
As per the MIB. |
hh3cdot1sMstiPortRootGuard (1.3.6.1.4.1.25506.8.35.14.20.1.26) |
read-write |
EnabledStatus |
Root guard status. |
As per the MIB. |
hh3cdot1sMstiPortLoopGuard (1.3.6.1.4.1.25506.8.35.14.20.1.27) |
read-write |
EnabledStatus |
Loop guard status. |
As per the MIB. |
hh3cdot1sMstiStpPortSendingBPDUType (1.3.6.1.4.1.25506.8.35.14.20.1.28) |
read-only |
INTEGER |
stp(1) rstp(2) mstp(3) |
BPDU type. |
As per the MIB. |
hh3cdot1sMstiStpOperPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.29) |
read-only |
TruthValue |
true(1) false(2) |
Whether the port link type is point-to-point. |
As per the MIB. |
hh3cdot1sMstiStpPortAdminBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.30) |
read-write |
Hh3cdot1sFormatStatus |
legacy(1) dot1s(2) auto(3) |
Set the mode used by the port to recognize and send MSTP BPDUs. |
· legacy—The port receives and sends only compatible-format MSTP BPDUs. · dot1s—The port receives and sends only standard-format (802.1s-compliant) MSTP BPDUs. · auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly. This mode takes effect only on the CIST. |
hh3cdot1sMstiStpPortOperBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.31) |
read-only |
Read the mode used by the port to send MSTP BPDUs. |
· legacy—The port sends only compatible-format MSTP BPDUs. · dot1s—The port sends only standard-format (802.1s-compliant) MSTP BPDUs. · auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly. This mode takes effect only on the CIST. |
hh3cdot1sMstiStpPortRoleRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.32) |
read-write |
EnabledStatus |
Port role restriction status. |
As per the MIB. |
hh3cdot1sMstiStpPortTcRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.33) |
read-write |
EnabledStatus |
TC-BPDU transmission restriction status. |
As per the MIB. |
hh3cdot1sMstiStpPortDisputed(1.3.6.1.4.1.25506.8.35.14.20.1.34) |
read-only |
TruthValue |
true(1) false(2) |
Dispute guard status. |
As per the MIB. |
hh3cdot1sMstiPortLoopbackGuard(1.3.6.1.4.1.25506.8.35.14.20.1.35) |
read-write |
EnabledStatus |
enabled(1), disabled(2) |
Loopback guard status. |
As per the MIB. |
Notifications
hh3cPortMstiStateForwarding
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.1 |
A port transits to the forwarding state. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification might be generated when a port transits to the forwarding state in the following situations:
· The network topology changes after a new link is added.
· The network topology changes after a port comes up or goes down.
System impact
The network topology changes.
Status control
ON
CLI: Use the stp port-log command.
OFF
CLI: Use the undo stp port-log command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.14.19.1.1 (hh3cdot1sInstanceID) |
Instance ID. |
hh3cdot1sInstanceID |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.20.1.1 (hh3cdot1sMstiPortIndex) |
Port index. |
hh3cdot1sInstanceID hh3cdot1sMstiPortIndex |
INTEGER |
1..65535 |
Recommended action
To resolve this issue:
1. Check for link failures after the network topology becomes stable.
2. Identify whether the spanning tree feature is enabled on a new physical link.
3. Identify whether a spanning tree-enabled port in the network topology has come up or gone down.
4. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPortMstiStateDiscarding
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.2 |
A port transits to the discarding state. |
Informational |
Warning |
N/A |
OFF |
This notification might be generated when a port transits to the discarding state in the following situations:
· The network topology changes.
· The network topology is recalculated after a new link is added.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Port index. |
INTEGER |
1..65535 |
Recommended action
1. Identify whether a new physical link is added in the spanning tree network after the network topology becomes stable.
2. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cBridgeLostRootPrimary
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.3 |
The device loses its root bridge role after another device is elected as root bridge. |
Informational |
Warning |
N/A |
ON |
This table does not contain indexes. For information about the index or indexes of a MIB object instance, see the section for that MIB object.
This notification might be generated when the device loses its root bridge role after another device is elected as root bridge in the following situations:
· A new link is added to the network topology.
· The priority of a device changes in the network topology.
System impact
The network topology might not be presented as expected.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Recommended action
1. Identify whether a new physical link is added in the spanning tree network.
2. Identify whether a priority change operation has been performed and verify that the operation is correct.
3. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPortMstiRootGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.4 |
A root guard-enabled port receives a configuration BPDU with a higher priority. |
Informational |
Warning |
N/A |
OFF |
This notification might be generated when the following events occur:
· A root guard-enabled port receives a configuration BPDU with a priority higher than the current bridge.
· The priority of a device in the network topology changes.
System impact
Status control
ON
CLI: Use the stp root-protection command.
MIB: Set hh3cdot1sMstiPortRootGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortRootGuard to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Port index. |
INTEGER |
1..65535 |
Recommended action
hh3cPortMstiBpduGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.5 |
A BPDU guard-enabled edge port receives configuration BPDUs. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when a BPDU guard-enabled edge port receives configuration BPDUs.
System impact
The user network connected to the port is interrupted.
Status control
ON
CLI: Use the stp bpdu-protection command.
MIB: Set hh3cdot1sMstBpduGuard to true(1).
OFF
MIB: Set hh3cdot1sMstBpduGuard to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.17.2.15.1.1 (dot1dStpPort) |
Port index. |
dot1dStpPort |
INTEGER |
1..65535 |
Recommended action
· Verify that the downstream device is an endpoint device.
· Check for possible attacks from other devices.
hh3cPortMstiLoopGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.6 |
An alternate port or root port does not receive a BPDU upon BPDU reception timeout. |
Informational |
Warning |
N/A |
OFF |
This notification might be generated when an alternate port or root port does not receive a BPDU upon BPDU reception timeout in the following situations:
· The peer port does not send a BPDU to the local end before the BPDU reception time expires. The spanning tree feature might be disabled on the peer port.
· The link connected to the peer end is congested. Verify that traffic can be forwarded correctly.
System impact
The alternate port or root port cannot forward service traffic.
Status control
ON
CLI: Use the stp loop-protection command.
MIB: Set hh3cdot1sMstiPortLoopGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortLoopGuard to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Port index. |
INTEGER |
1..65535 |
Recommended action
· Verify that the spanning tree status of the upstream device is correct.
hh3cMstiNewRoot
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.7 |
A new root bridge is elected. |
Informational |
Warning |
N/A |
OFF |
This notification might be generated when a new root bridge is elected in the following situations:
· The current bridge joins a new network topology.
· The priority of the current bridge increases.
· The original root bridge fails.
· The priority of the original root bridge decreases.
System impact
The network topology changes. Service traffic loss might occur.
Status control
ON
CLI: Use the snmp trap enable stp new-root command.
OFF
CLI: Use the undo snmp trap enable stp new-root command.
Objects
OID |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.19.1.4 (hh3cdot1sMstiDesignedRoot) |
Root bridge information. |
BridgeId |
BridgeId |
Recommended action
· Verify the bridge priorities of the devices.
hh3cMstiTopologyChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.9 |
The network topology changes after the spanning tree state of ports changes. |
Informational |
Warning |
N/A |
ON |
This notification might be generated when the spanning tree state changes of ports cause network topology changes in the following situations:
· The network topology changes after the priority of a device changes.
· Network topology change causes discarding port change after the cost value or priority of a port is changed.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Recommended action
2. Identify whether a spanning tree-enabled port has come up or gone down in the network topology.
hh3cPortMstiLostEdge
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.10 |
An edge port receives BPDUs. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an edge port receives BPDUs and becomes a non-edge port.
System impact
The network topology might change.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
Port number. |
INTEGER |
1..65535 |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name. |
ifIndex |
OCTET STRING |
OCTET STRING(0..255) |
Instance ID. |
INTEGER |
0..4094 |
Recommended action
1. Verify that the peer network attached to the edge port has changed and identify whether the received BPDUs are malicious attack packets.
hh3cMstiTcGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.11 |
The number of TC-BPDUs received by the device exceeds the upper threshold. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the number of TC-BPDUs received by the device exceeds the upper threshold within a TC-BPDU protection period.
System impact
The excessive TC-BPDUs do not immediately cause MAC and ARP entry deletion. The network topology does not change immediately.
Status control
ON
CLI: Use the stp tc-protection command.
OFF
CLI: Use the undo stp tc-protection command.
Objects
OID |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Recommended action
1. Identify whether the network topology is flapping.
2. Identify whether malicious attacks exist.
hh3cMstiProTcGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.12 |
Informational |
Warning |
N/A |
ON |
System impact
Status control
ON
OFF
Objects
OID |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
1.3.6.1.4.1.25506.8.35.14.22.1 (hh3cMstiTcGuardVal) |
Upper threshold |
N/A |
Integer32 |
Recommended action
hh3cPortMstiLoopbackGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.13 |
Loopback guard. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when an interface receives a BPDU sent by itself.
System impact
Network loops might create a broadcast storm.
Status control
ON
CLI: Use the stp loopback-protection command.
MIB: Set hh3cdot1sMstiPortLoopbackGuard to true(1).
OFF
CLI: Use the undo stp loopback-protection command.
MIB: Set hh3cdot1sMstiPortLoopbackGuard to false(2).
Objects
OID |
Index nodes |
Type |
Value range |
Instance ID. |
INTEGER |
0..4094 |
Interface name. |
ifIndex |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
1. Identify whether an attacker uses forged BPDUs to attack the network.
¡ If yes, proceed to step 3.
¡ If no, proceed to step 2.
2. Identify whether physical loops exist in the network. If yes, remove the physical loops. If the issue persists, proceed to step 3.
3. Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPortPvstLoopbackGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
Loopback guard. |
Informational |
Warning |
N/A |
OFF |
System impact
Status control
ON
OFF
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.14.22.6 (hh3cMstiVlanID) |
VLAN ID. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
hh3cPortPvstRootGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.15 |
Root guard. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when an interface enabled with root guard receives a configuration BPDU with a higher priority or the priority of a switch changes.
System impact
The interface that receives a configuration BPDU with a higher priority transitions to the listening state and no longer forwards user packets. If the port receives no BPDUs with a higher priority within twice the forwarding delay, it reverts to its original state.
Status control
ON
OFF
CLI: Use the undo stp root-protection command.
Objects
OID |
Index nodes |
Type |
Value range |
VLAN ID. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
1. Execute the display stp command on other devices to identify whether the root bridge and port calculation results are as planned.
¡ If yes, proceed to step 2.
¡ If no, proceed to step 3.
2. Execute the undo stp root-protection command on the interface enabled with root guard to disable root guard. If the issue persists, proceed to step 4.
3. Reconfigure the priority of each device so that the device enabled with root guard can become the root bridge. If the issue persists, proceed to step 4.
4. Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPortPvstLoopGuarded
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.16 |
Loop guard is triggered. |
Informational |
Warning |
N/A |
OFF |
This notification is generated if the peer device of an interface enabled with loop guard is not enabled with the spanning tree feature or an interface enabled with loop guard experiences a link fault. Both cases might cause the interface enabled with loop guard to fail to receive BPDUs.
System impact
The interface stays in the discarding state until it receives BPDUs.
Status control
ON
OFF
CLI: Use the undo stp loop-protection command.
Objects
OID |
Index nodes |
Type |
Value range |
VLAN ID. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
1. Execute the display stp command on the peer device to identify whether the spanning tree feature is enabled.
¡ If no, use the stp global enable and stp enable commands to enable the spanning tree feature globally and on the interface, respectively. If the local end still cannot receive BPDUs, proceed to step 2.
2. Identify whether the link between the local device and peer device is faulty.
¡ If yes, remove the link fault. If the link fault cannot be located or removed, proceed to step 3.
hh3cPortPvstPvidInconsistent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.17 |
PVID inconsistency. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when an interface receives a BPDU with a different PVID.
System impact
PVST calculation errors might occur.
Status control
ON
CLI: Use the stp ignore-pvid-inconsistency command.
OFF
CLI: Use the undo stp ignore-pvid-inconsistency command.
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.14.22.2 (hh3cPvstPvid) |
PVID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.14.22.3 (hh3cPvstPvidInPdu) |
PVID in packets. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
1. Identify whether different PVIDs are required on two connected ports:
¡ If yes, use the stp ignore-pvid-inconsistency command to disable inconsistent PVID protection.
¡ If no, modify the different PVIDs to be the same.
hh3cPortPvstPortTypeInconsistent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.18 |
Port type inconsistency. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when an access port receives a PVST BPDU from a trunk or hybrid port.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
VLAN ID. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
1. Identify whether the port types of the two ends are the same:
¡ If no, modify the port types to be the same. If the issue persists, proceed to step 2.
2. Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPortPvstLostEdge
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.19 |
An edge port receives a BPDU. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an edge port receives a BPDU.
System impact
Network topology changes might occur.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
VLAN ID. |
N/A |
Integer32 |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
1. Identify whether the interface should be planned as an edge port:
2. Identify whether BPDUs are from an attacker:
¡ If yes, proceed to step 4.
3. Use the undo stp edged-port command to configure the interface as a non-edge port.
hh3cMstiStgNumInconsistent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.20 |
The number of STGs on an interface card is smaller than the number of STGs on the MPU. |
Informational |
Warning |
N/A |
OFF |
This notification is generated when the number of STGs on an interface card is smaller than the number of STGs on the MPU.
System impact
The spanning tree protocol cannot run correctly.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.14.22.4 (hh3cMstiLpuStgNum) |
Number of STGs on an interface card. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.14.22.5 (hh3cMstiMpuStgNum) |
Number of STGs on the MPU. |
N/A |
Integer32 |
Recommended action
Modify the number of STGs on the interface card to be greater than the number of STGs on the MPU.
hh3cPortMstiDispute
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.21 |
Dispute guard is triggered. |
Informational |
Warning |
N/A |
OFF |
This notification is generated if an upstream port receives inferior BPDUs from a downstream designated port in forwarding or learning state.
System impact
The upstream port is blocked.
Status control
ON
CLI: Use the stp dispute-protection command.
OFF
CLI: Use the undo stp dispute-protection command.
Objects
OID |
Index nodes |
Type |
Value range |
Spanning tree instance ID. |
N/A |
INTEGER |
Interface name. |
ifIndex |
OCTET STRING |
1.3.6.1.4.1.25506.8.35.14.22.7 (hh3cMstiBridgeIDInPdu) |
Designated bridge ID carried in inferior BPDUs. |
N/A |
BridgeId |
OCTET STRING (8) |
1.3.6.1.4.1.25506.8.35.14.22.8 (hh3cMstiPortPriorityInPdu) |
Designated port priority carried in inferior BPDUs. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.14.22.9 (hh3cMstiPortNumInPdu) |
Designated port ID carried in inferior BPDUs. |
N/A |
Integer32 |
Recommended action
· Execute the display stp abnormal-port command to identify information about blocked ports. Identify whether unidirectional link failures exist. if the PVIDs of the two ends are the same, shut down and bring up the interface or replace cables.
· Troubleshoot the link between the local and peer device according to the designated bridge ID and designated port ID.
If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cPortMstiDisputeClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.22 |
A port exited the distribute guard state. |
Informational |
Warning |
N/A |
OFF |
This notification is generated if an upstream port receives normal-priority BPDUs or the undo stp dispute-protection command is executed to disable dispute guard.
System impact
The port returns to the normal forwarding state.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
N/A |
INTEGER |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
No action is required.
hh3cPortPvstDispute
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.23 |
Informational |
Warning |
N/A |
OFF |
System impact
Status control
ON
OFF
Objects
OID |
Index nodes |
Type |
Value range |
N/A |
INTEGER |
Interface name. |
ifIndex |
OCTET STRING |
N/A |
BridgeId |
OCTET STRING (8) |
N/A |
Integer32 |
N/A |
Integer32 |
Recommended action
hh3cPortPvstDisputeClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.14.0.24 |
Informational |
Warning |
N/A |
OFF |
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
VLAN ID. |
N/A |
INTEGER |
Interface name. |
ifIndex |
OCTET STRING |
Recommended action
