04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
13-HH3C-VOICE-VLAN-MIB
13-HH3C-VOICE-VLAN-MIB 58.83 KB
HH3C-VOICE-VLAN-MIB
About this MIB
Use this MIB to configure voice VLAN. You can assign interfaces connecting to voice devices to a voice VLAN. Then, the system automatically modifies the QoS parameters for the voice packets to improve the priority of voice packets and ensure voice quality. Implementation varies by product.
MIB file name
hh3c-voice-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVoiceVlan(9)
Scalar objects
hh3cVoiceVlanAgingTime
Object (OID)
Access
Value range
Implementation
hh3cVoiceVlanAgingTime (1.3.6.1.4.1.25506.2.9.4)
read-write
Integer32
Integer32 (0|5..43200)
Voice VLAN aging time.
As per the MIB.
hh3cVoiceVlanSecurityState
Object (OID)
Access
Value range
Implementation
hh3cVoiceVlanSecurityState (1.3.6.1.4.1.25506.2.9.6)
read-write
INTEGER
security (1),
normal (2)
Voice VLAN security mode state.
As per the MIB.
Tabular objects
hh3cvoiceVlanOuiTable
About this table
Use this table to configure the OUI addresses that can be recognized by the voice VLAN.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cVoiceVlanOuiAddress. When you use the hh3cVoiceVlanOuiRowStatus to create a row, you must specify the hh3cVoiceVlanOuiMask object and can leave the hh3cVoiceVlanOuiDescription object empty.
Object (OID)
Access
Value range
Implementation
hh3cVoiceVlanOuiAddress (1.3.6.1.4.1.25506.2.9.1.1.1)
read-only
MacAddress
OCTET STRING (6)
OUI address of the voice VLAN.
As per the MIB.
hh3cVoiceVlanOuiMask (1.3.6.1.4.1.25506.2.9.1.1.2)
read-write
MacAddress
OCTET STRING (6)
Mask for the OUI address of the voice VLAN.
This object cannot be specified separately.
hh3cVoiceVlanOuiDescription (1.3.6.1.4.1.25506.2.9.1.1.3)
read-write
OCTET STRING
OCTET STRING  (0..30)
Description on the OUI address of the voice VLAN.
The first letter of the description cannot be a space.
hh3cVoiceVlanOuiRowStatus (1.3.6.1.4.1.25506.2.9.1.1.4)
read-create
RowStatus
Standard MIB values.
Row state of the OUI address of the voice VLAN.
As per the MIB.
hh3cvoiceVlanPortTable
About this table
Use this table to configure the voice VLAN features, for example, configure the voice VLAN operating mode, configure an interface to trust the priority of packets in a voice VLAN, and modify the CoS and DSCP values for packets in a voice VLAN.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cVoiceVlanPortifIndex.
Object (OID)
Access
Value range
Implementation
hh3cVoiceVlanPortifIndex (1.3.6.1.4.1.25506.2.9.7.1.1)
not-accessible
Integer32
Integer32(1..2147483647)
Index of a port in a voice VLAN.
As per the MIB.
hh3cVoiceVlanPortMode (1.3.6.1.4.1.25506.2.9.7.1.2)
read-write
INTEGER
auto (1),
manual (2)
Voice VLAN assignment mode of a port.
As per the MIB.
hh3cVoiceVlanPortLegacy
(1.3.6.1.4.1.25506.2.9.7.1.3)
read-write
TruthValue
Voice VLAN configuration legacy status on a port.
Not supported
hh3cVoiceVlanPortQosTrust
(1.3.6.1.4.1.25506.2.9.7.1.4)
read-write
TruthValue
QoS settings on a port in a voice VLAN.
Not supported
