- 04-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PROTOCOL-VLAN-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-SUBNET-VLAN-MIB
- 12-HH3C-VMAP-MIB
- 13-HH3C-VOICE-VLAN-MIB
- 14-HH3C-LswMSTP-MIB
- 15-HH3C-LswVLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-MED-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-Q-BRIDGE-MIB
- 28-RBRIDGE-MIB
| 16-IEEE8021-CFM-MIB | 150.90 KB |
IEEE8021-CFM-MIB
About this MIB
Connectivity Fault Management (CFM) is the name of the feature defined in IEEE 802.1ag for end-to-end Operations, Administration and Maintenance (OAM) for Ethernet. In the Comware platform, the feature is called Connectivity Fault Detection (CFD).
CFD is an end-to-end per-VLAN link layer OAM mechanism. CFD is used for link connectivity detection, fault verification, and fault location.
This MIB defines how to implement CFD. Use this MIB to configure CFD on managed devices.
MIB file name
ieee8021-cfm.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbered-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021CfmMib(8)
Scalar objects
dot1agCfmMdTableNextIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1agCfmMdTableNextIndex (1.3.111.2.802.1.1.8.1.5.1) |
read-only |
Dot1afCfmIndexIntegerNextFree |
Unsigned32 (1..4294967295) |
Value to be used as a new index in the MD table. |
As per the MIB. |
Tabular objects
dot1agCfmMdTable
About this table
Use this table to obtain the MD information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
· The dot1agCfmMdIndex index must be configured. The index is provided by the dot1agCfmMdTableNextIndex object. · The dot1agCfmMdMdLevel object must be configured. · The dot1agCfmMdFormat object is optional. If it is not configured, the default value is charString(4). · The dot1agCfmMdName object is optional. When the dot1agCfmMdFormat object is set to none(1), the MIB will automatically ignore the input value no matter whether the dot1agCfmMdName object is configured. When the dot1agCfmMdFormat object is set to any other value, you must configure the dot1agCfmMdName object, and the MIB will read the input value. · The dot1agCfmMdMhfCreation object is optional. If it is not configured, the default value is defMHFnone(1), and only the value is available. · The dot1agCfmMdMhfIdPermission object is optional. If it is not configured, the default value is sendIdNone(1), and only the value is available. |
Not supported |
Supported |
Supported |
Columns
The table index is dot1agCfmMdIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1agCfmMdIndex (1.3.111.2.802.1.1.8.1.5.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..4294967295) |
MD table index. |
As per the MIB. |
dot1agCfmMdFormat (1.3.111.2.802.1.1.8.1.5.2.1.2) |
read-create |
Dot1agCfmMaintDomainNameType |
INTEGER { none (1) dnsLikeName(2) macAddressAndUint (3) charString (4) } |
MD name type. |
As per the MIB. |
dot1agCfmMdName (1.3.111.2.802.1.1.8.1.5.2.1.3) |
read-create |
Dot1agCfmMaintDomainName |
OCTET STRING(1..43) |
MD name. |
The MD name must be unique. After an MD is created, its name cannot be modified. When the format is set to macAddressAndUint(3), you must enter eight bytes, where the first fix bytes specify the MAC address and the last two bytes specify the subnumber. |
dot1agCfmMdMdLevel (1.3.111.2.802.1.1.8.1.5.2.1.4) |
read-create |
Dot1agCfmMDLevel |
Integer32 (0..7) |
MD level. |
Eight MD levels are available, 0 to 7. The MD level cannot be modified after an MD is created. |
dot1agCfmMdMhfCreation (1.3.111.2.802.1.1.8.1.5.2.1.5) |
read-create |
Dot1agCfmMhfCreation |
INTEGER { defMHFnone(1), defMHFdefault(2), defMHFexplicit(3) } |
Enumerated value indicating whether the management entity can create MHFs (MIP Half Function) for this MD. |
This object is insignificant. This object cannot be modified after an MD is created. The default is defMHFnone(1), and only the value is supported. |
dot1agCfmMdMhfIdPermission (1.3.111.2.802.1.1.8.1.5.2.1.6) |
read-create |
Dot1agCfmIdPermission |
INTEGER { sendIdNone(1), sendIdChassis(2), sendIdManage(3), sendIdChassisManage(4) } |
Enumerated value indicating what, if anything, is to be included in the Sender ID TLV (21.5.3) transmitted by MPs configured in this MD. |
The default value is sendIdNone(1), and only the value is available. |
dot1agCfmMdMaNextIndex (1.3.111.2.802.1.1.8.1.5.2.1.7) |
read-only |
Dot1afCfmIndexIntegerNextFree, |
Index of the next MA to be created. |
As per the MIB. |
dot1agCfmMdRowStatus (1.3.111.2.802.1.1.8.1.5.2.1.8) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Available values are active(1), createAndGo(4), and destroy(6). |
dot1agCfmMaNetTable
About this table
Use this table to obtain the MA network information.
Create |
Edit/Modify |
Delete |
Read |
· The dot1agCfmMdIndex must be configured. The index is provided by dot1agCfmMdIndex in the dot1agCfmMdTable object. · The dot1agCfmMaIndex and dot1agCfmMaNetName indexes are required. When configuring the dot1agCfmMaIndex index, the index is provided by the dot1agCfmMdMaNextIndex in the dot1agCfmMdTable table. When you use the dot1agCfmMaNetName object to configure a name, the name can contain only digits, letters, and underscores (_). · The dot1agCfmMaNetFormat object must be configured. · The dot1agCfmMaNetCcmInterval object is optional. If it is not configured, the default value is interval1s (4). |
Only the dot1agCfmMaNetCcmInterval object value can be modified. The values of the other objects cannot be modified. To modify them, first delete this row, and then create a new one.
Supported |
Supported |
Columns
The table indexes are dot1agCfmMdIndex and dot1agCfmMaIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1agCfmMaIndex (1.3.111.2.802.1.1.8.1.6.1.1.1) |
not-accessible |
Unsigned32 |
MA index. |
This object cannot be modified after being created. |
dot1agCfmMaNetFormat (1.3.111.2.802.1.1.8.1.6.1.1.2) |
read-create |
Dot1agCfmMaintAssocNameType |
INTEGER { primaryVid (1), charString (2), unsignedInt16 (3), iccFormat (32) } |
MA name format. |
dot1agCfmMaNetName (1.3.111.2.802.1.1.8.1.6.1.1.3) |
read-create |
Dot1agCfmMaintAssocName |
OCTET STRING (1..45) |
MA name. |
This object cannot be modified after being created. The total length of the MA name and its MD name cannot exceed 44 bytes. |
dot1agCfmMaNetCcmInterval (1.3.111.2.802.1.1.8.1.6.1.1.4) |
read-create |
Dot1agCfmCcmInterval |
INTEGER { intervalInvalid (0), interval300Hz (1), interval10ms (2), interval100ms (3), interval1s (4), interval10s (5), interval1min (6), interval10min (7) } |
CCM transmission interval. |
As per the MIB. |
dot1agCfmMaNetRowStatus (1.3.111.2.802.1.1.8.1.6.1.1.5) |
read-create |
RowStatus |
Row status. |
dot1agCfmMaMepListTable
About this table
Create |
Edit/Modify |
Delete |
Read |
· The dot1agCfmMdIndex must be configured. The index is provided by the dot1agCfmMdIndex in the dot1agCfmMdTable object. · The dot1agCfmMaIndex must be configured. The index is provided by the dot1agCfmMaIndex in the dot1agCfmMaNetTable object. · The dot1agCfmMaMepListIdentifier object must be configured. |
Not supported |
Supported |
Supported |
Columns
The table indexes are dot1agCfmMdIndex, dot1agCfmMaIndex, and dot1agCfmMaMepListIdentifier.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1agCfmMaMepListIdentifier (1.3.111.2.802.1.1.8.1.6.3.1.1) |
not-accessible |
Dot1agCfmMepId |
Unsigned32 (1..8191) |
MEP ID. |
dot1agCfmMaMepListRowStatus (1.3.111.2.802.1.1.8.1.6.3.1.2) |
read-create |
RowStatus |
Row status. |
dot1agCfmMepTable
About this table
Use this table to obtain the MEP information.
Create |
Edit/Modify |
Delete |
Read |
· The dot1agCfmMdIndex must be configured. The index is provided by the dot1agCfmMdIndex in the dot1agCfmMdTable object. · The dot1agCfmMaIndex must be configured. The index is provided by the dot1dot1agCfmMaIndex in the dot1agCfmMaNetTable object. · Indexes dot1agCfmMepIdentifier and dot1agCfmMepIfIndex and non-index dot1agCfmMepDirection must be configured. |
The dot1agCfmMepActive and dot1agCfmMepCciEnabled object values can be modified. The values of the other objects cannot be modified. To modify them, first delete this row, and then create a new one. |
Supported |
Supported |
Columns
The table indexes are dot1agCfmMdIndex, dot1agCfmMaIndex, and dot1agCfmMepIdentifier.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1agCfmMepIdentifier (1.3.111.2.802.1.1.8.1.7.1.1.1) |
not-accessible |
Dot1agCfmMepId |
MEP ID. |
dot1agCfmMepIfIndex (1.3.111.2.802.1.1.8.1.7.1.1.2) |
read-create |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Interface index of an MEP. |
As per the MIB. |
dot1agCfmMepDirection (1.3.111.2.802.1.1.8.1.7.1.1.3) |
read-create |
Dot1agCfmMpDirection |
INTEGER { down (1), up (2) } |
MEP direction. |
dot1agCfmMepPrimaryVid (1.3.111.2.802.1.1.8.1.7.1.1.4) |
read-create |
Unsigned32 |
Unsigned32(0..16777215) |
VLAN of the MEP. |
The value 0 indicates that either the primary VID is that of the MEP's MA, or that the MEP's MA is associated with no VID. |
dot1agCfmMepActive (1.3.111.2.802.1.1.8.1.7.1.1.5) |
read-create |
TruthValue |
true(1), false(2) |
Enabling state of the MEP. |
The value must be true (1), and cannot be modified once the MEP is created. |
dot1agCfmMepFngState (1.3.111.2.802.1.1.8.1.7.1.1.6) |
read-only |
Dot1agCfmFngState |
INTEGER { fngReset (1), fngDefect (2), fngReportDefect (3), fngDefectReported(4), fngDefectClearing(5) } |
FNG state machine state of the MEP. |
As per the MIB. |
dot1agCfmMepCciEnabled (1.3.111.2.802.1.1.8.1.7.1.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable the MEP to send CCM packets. |
As per the MIB. |
dot1agCfmMepCcmLtmPriority (1.3.111.2.802.1.1.8.1.7.1.1.8) |
read-create |
Unsigned32 |
Unsigned32(0..7) |
Priority of CCM packets sent by the MEP. |
Not supported |
dot1agCfmMepMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.9) |
read-only |
MacAddress |
OCTET STRING(6) |
MEP MAC address. |
Not supported |
dot1agCfmMepLowPrDef (1.3.111.2.802.1.1.8.1.7.1.1.10) |
read-create |
Dot1agCfmLowestAlarmPri |
INTEGER { allDef (1), macRemErrXcon(2), remErrXcon (3), errXcon (4), xcon (5), noXcon (6) } |
Lowest priority defect that is allowed to generate fault alarms. |
Not supported |
dot1agCfmMepFngAlarmTime (1.3.111.2.802.1.1.8.1.7.1.1.11) |
read-create |
TimeInterval |
250..1000 |
The time that defects must be present before a fault alarm is issued. |
Not supported |
dot1agCfmMepFngResetTime (1.3.111.2.802.1.1.8.1.7.1.1.12) |
read-create |
TimeInterval |
250..1000 |
The time that defects must be absent before resetting a fault alarm. |
Not supported |
dot1agCfmMepHighestPrDefect (1.3.111.2.802.1.1.8.1.7.1.1.13) |
read-only |
Dot1agCfmHighestDefectPri |
INTEGER { none (0), defRDICCM (1), defMACstatus (2), defRemoteCCM (3), defErrorCCM (4), defXconCCM (5) } |
Highest-priority fault of the MEP. |
In the current software version, only fault types defRemoteCCM(3), defErrorCCM(4), and defXconCCM (5) are supported. |
dot1agCfmMepDefects (1.3.111.2.802.1.1.8.1.7.1.1.14) |
read-only |
Dot1agCfmMepDefects |
BITS { bDefRDICCM(0), bDefMACstatus(1), bDefRemoteCCM(2), bDefErrorCCM(3), bDefXconCCM(4) } |
MEP fault state. |
Not supported |
dot1agCfmMepErrorCcmLastFailure (1.3.111.2.802.1.1.8.1.7.1.1.15) |
read-only |
OCTET STRING |
OCTET STRING (1..1522) |
Last-received CCM packet that triggered a DefError CCM fault. |
Not supported |
dot1agCfmMepXconCcmLastFailure (1.3.111.2.802.1.1.8.1.7.1.1.16) |
read-only |
OCTET STRING |
Last-received CCM packet that triggered a DefXcon CCM fault. |
Not supported |
dot1agCfmMepCcmSequenceErrors (1.3.111.2.802.1.1.8.1.7.1.1.17) |
read-only |
Counter32 |
Standard MIB values. |
Total number of out-of-sequence CCM packets received. |
Not supported |
dot1agCfmMepCciSentCcms (1.3.111.2.802.1.1.8.1.7.1.1.18) |
read-only |
Counter32 |
Total number of CCM packets sent. |
Not supported |
dot1agCfmMepNextLbmTransId (1.3.111.2.802.1.1.8.1.7.1.1.19) |
read-only |
Unsigned32 |
Next sequence number. |
Not supported |
dot1agCfmMepLbrIn (1.3.111.2.802.1.1.8.1.7.1.1.20) |
read-only |
Counter32 |
Total number of LBR packets received. |
Not supported |
dot1agCfmMepLbrInOutOfOrder (1.3.111.2.802.1.1.8.1.7.1.1.21) |
read-only |
Counter32 |
Total number of out-of-sequence LBR packets received. |
Not supported |
dot1agCfmMepLbrBadMsdu (1.3.111.2.802.1.1.8.1.7.1.1.22) |
read-only |
Counter32 |
Total number of bad LBR packets. |
Not supported |
dot1agCfmMepLtmNextSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.23) |
read-only |
Unsigned32 |
Next sequence number of the LT packet. |
Not supported |
dot1agCfmMepUnexpLtrIn (1.3.111.2.802.1.1.8.1.7.1.1.24) |
read-only |
Counter32 |
Total number of LTR packets |
Not supported |
dot1agCfmMepLbrOut (1.3.111.2.802.1.1.8.1.7.1.1.25) |
read-only |
Counter32 |
Total number of LBR packets sent. |
Not supported |
dot1agCfmMepTransmitLbmStatus (1.3.111.2.802.1.1.8.1.7.1.1.26) |
read-create |
TruthValue |
true(1), false(2) |
Whether to forward LBM packets. |
Not supported |
dot1agCfmMepTransmitLbmDestMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.27) |
read-create |
MacAddress |
OCTET STRING(6) |
Destination MAC address of LBM packets. |
Not supported |
dot1agCfmMepTransmitLbmDestMepId (1.3.111.2.802.1.1.8.1.7.1.1.28) |
read-create |
Dot1agCfmMepIdOrZero |
MEP ID. |
Not supported |
dot1agCfmMepTransmitLbmDestIsMepId (1.3.111.2.802.1.1.8.1.7.1.1.29) |
read-create |
TruthValue |
true(1), false(2) |
Whether the LBM packets are transmitted by using the MEP ID or destination MAC address. |
Not supported |
dot1agCfmMepTransmitLbmMessages (1.3.111.2.802.1.1.8.1.7.1.1.30) |
read-create |
Integer32 |
Integer32(1..1024) |
Total number of LBM packets sent. |
Not supported |
dot1agCfmMepTransmitLbmDataTlv (1.3.111.2.802.1.1.8.1.7.1.1.31) |
read-create |
OCTET STRING |
OCTET STRING (0..1500) |
Data in TLVs. |
Not supported |
dot1agCfmMepTransmitLbmVlanPriority (1.3.111.2.802.1.1.8.1.7.1.1.32) |
read-create |
Integer32 |
OCTET STRING (0..7) |
Priority. |
Not supported |
dot1agCfmMepTransmitLbmVlanDropEnable (1.3.111.2.802.1.1.8.1.7.1.1.33) |
read-create |
TruthValue |
true(1), false(2) |
Whether to enable dropping packets. |
Not supported |
dot1agCfmMepTransmitLbmResultOK (1.3.111.2.802.1.1.8.1.7.1.1.34) |
read-only |
TruthValue |
true(1), false(2) |
Whether to send LBM packets. |
Not supported |
dot1agCfmMepTransmitLbmSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.35) |
read-only |
Unsigned32 |
ID of the first LBM packet sent. |
Not supported |
dot1agCfmMepTransmitLtmStatus (1.3.111.2.802.1.1.8.1.7.1.1.36) |
read-create |
TruthValue |
true(1), false(2) |
Whether to send the next LTM packet. |
Not supported |
dot1agCfmMepTransmitLtmFlags (1.3.111.2.802.1.1.8.1.7.1.1.37) |
read-create |
BITS |
useFDBonly (0) |
Flag field in LTM packets. |
Not supported |
dot1agCfmMepTransmitLtmTargetMacAddress (1.3.111.2.802.1.1.8.1.7.1.1.38) |
read-create |
MacAddress |
OCTET STRING(6) |
Destination MAC address. |
Not supported |
dot1agCfmMepTransmitLtmTargetMepId (1.3.111.2.802.1.1.8.1.7.1.1.39) |
read-create |
Whether the sent packets carry the destination MAC address. |
Not supported |
dot1agCfmMepTransmitLtmTargetIsMepId (1.3.111.2.802.1.1.8.1.7.1.1.40) |
read-create |
TruthValue |
true(1), false(2) |
Whether the LTM packets use the MEP ID. |
Not supported |
dot1agCfmMepTransmitLtmTtl (1.3.111.2.802.1.1.8.1.7.1.1.41) |
read-create |
Unsigned32 |
Unsigned32(0..255) |
TTL |
Not supported |
dot1agCfmMepTransmitLtmResult (1.3.111.2.802.1.1.8.1.7.1.1.42) |
read-only |
TruthValue |
true(1), false(2) |
Whether to send LTM packets. |
Not supported |
dot1agCfmMepTransmitLtmSeqNumber (1.3.111.2.802.1.1.8.1.7.1.1.43) |
read-only |
Unsigned32 |
LTM transaction identifier of the LTM sent. |
Not supported |
dot1agCfmMepTransmitLtmEgressIdentifier (1.3.111.2.802.1.1.8.1.7.1.1.44) |
read-create |
OCTET STRING |
OCTET STRING(8) |
ID of the egress of the LTM packets. |
Not supported |
dot1agCfmMepRowStatus (1.3.111.2.802.1.1.8.1.7.1.1.45) |
read-create |
RowStatus |
Row status. |
dot1agCfmMepPbbTeCanReportPbbTePresence (1.3.111.2.802.1.1.8.1.7.1.1.46) |
read-create |
TruthValue |
true(1), false(2) |
Whether the PBB-TE reporting capability is supported. |
Not supported |
dot1agCfmMepPbbTeTrafficMismatchDefect (1.3.111.2.802.1.1.8.1.7.1.1.47) |
read-only |
TruthValue |
true(1), false(2) |
Whether traffic mismatch errors have been detected. |
Not supported |
dot1agCfmMepPbbTransmitLbmLtmReverseVid (1.3.111.2.802.1.1.8.1.7.1.1.48) |
read-create |
IEEE8021VlanIndex |
Unsigned32 (1..4094|4096..4294967295)
PBB VID carried in LTM packets. |
Not supported |
dot1agCfmMepPbbTeMismatchAlarm (1.3.111.2.802.1.1.8.1.7.1.1.49) |
read-create |
TruthValue |
true(1), false(2) |
Whether PBB-TE errors or PBB-TE alarms are detected. |
Not supported |
dot1agCfmMepPbbTeLocalMismatchDefect (1.3.111.2.802.1.1.8.1.7.1.1.50) |
read-only |
TruthValue |
true(1), false(2) |
Whether local PBB-TE errors have been detected. |
Not supported |
dot1agCfmMepPbbTeLocalMismatchSinceReset (1.3.111.2.802.1.1.8.1.7.1.1.51) |
read-only |
TruthValue |
true(1), false(2) |
Whether the local PBB-TE errors start from the reset state. |
Not supported |
Notifications
dot1agCfmFaultAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.111.2.802.1.1.8.0.1 |
A MEP error occurs. |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is sent when the MEP continuously fails.
Possible causes might include the following:
· The CFD entities at the two ends have inconsistent MDs or MAs.
· The CFD entities at the two ends have inconsistent CCM intervals.
· The MEP ID in CCMs is not in the MEP ID on the local end.
· No CCM is received upon expiration of the specified timer.
System impact
Continuity check cannot be performed. Service traffic switchover or interruption might occur.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.111.2.802.1.1.8.1.5.2.1.1 (dot1agCfmMdIndex) |
MD index. |
dot1agCfmMdIndex |
Integer32 |
1.. 4294967295 |
1.3.111.2.802.1.1.8.1.6.1.1.1 (dot1agCfmMaIndex) |
MA index. |
dot1agCfmMaIndex |
Integer32 |
1.. 4294967295 |
1.3.111.2.802.1.1.8.1.7.1.1.1 (dot1agCfmMepIdentifier) |
MEP ID and ultimate index in the MEP list |
dot1agCfmMdIndex dot1agCfmMaIndex dot1agCfmMepIdentifier |
Integer32 |
1.. 8191 |
1.3.111.2.802.1.1.8.1.7.1.1.13 (dot1agCfmMepHighestPrDefect) |
Detected faulty MEP. |
none (0) defRemoteCCM (3) defErrorCCM (4) defXconCCM (5) |
Recommended action
To resolve this issue:
1. Identify whether the CFD configuration is correct.
2. Identify whether the port and link states are normal.
3. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
