04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
07-HH3C-MAC-INFORMATION-MIB
07-HH3C-MAC-INFORMATION-MIB 216.20 KB
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACInformation(87)
Scalar objects
hh3cMACInformationEnabled
Object (OID)
Access
Value range
Implementation
hh3cMACInformationEnabled (1.3.6.1.4.1.25506.2.87.1.1.1)
read-write
INTEGER
enabled(1)
disabled(2)
Status of the MAC Information feature.
As per the MIB.
hh3cMACInformationcSendInterval
Object (OID)
Access
Value range
Implementation
hh3cMACInformationcSendInterval(1.3.6.1.4.1.25506.2.87.1.1.2)
read-write
Integer32
Integer32 (1..20000)
MAC change notification interval.
As per the MIB.
hh3cMACInformationLearntMACNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationLearntMACNum(1.3.6.1.4.1.25506.2.87.1.1.3)
read-only
Counter32
Standard MIB values.
Total number of the MAC addresses learned since MAC information is enabled.
As per the MIB.
hh3cMACInformationRemovedMACNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationRemovedMACNum (1.3.6.1.4.1.25506.2.87.1.1.4)
read-only
Counter32
Total number of the MAC addresses deleted or aged since MAC information is enabled.
As per the MIB.
hh3cMACInformationTrapSendNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationTrapSendNum (1.3.6.1.4.1.25506.2.87.1.1.5)
read-only
Counter32
Number of sent SNMP notifications.
As per the MIB.
hh3cMACInformationSyslogSendNum
Object (OID)
Access
Value range
Implementation
hh3cMACInformationSyslogSendNum (1.3.6.1.4.1.25506.2.87.1.1.6)
read-only
Counter32
Number of sent syslog messages.
As per the MIB.
hh3cMACInformationCacheLen
Object (OID)
Access
Value range
Implementation
hh3cMACInformationCacheLen (1.3.6.1.4.1.25506.2.87.1.1.7)
read-write
Integer32
Integer32 (0..1000)
MAC Information queue length.
As per the MIB.
hh3cMACInfomationWorkMode
Object (OID)
Access
Value range
Implementation
hh3cMACInfomationWorkMode (1.3.6.1.4.1.25506.2.87.1.1.8)
read-write
Hh3cMACInfoWorkMode
trap(1)
syslog(2)
MAC Information mode
As per the MIB.
hh3cMACInfoTrapIndex
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapIndex(1.3.6.1.4.1.25506.2.87.1.3.2.1)
accessible-for-notify
Integer32
Integer32 (1..2147483647)
Notification index.
As per the MIB.
hh3cMACInfoTrapCount
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapCount (1.3.6.1.4.1.25506.2.87.1.3.2.2)
Integer32
Notification count.
As per the MIB.
hh3cMACInfoTrapMsg
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsg(1.3.6.1.4.1.25506.2.87.1.3.2.2)
OCTET STRING
OCTET STRING  (1..254)
Notification contents.
As per the MIB.
hh3cMACInfoTrapVerExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapVerExt (1.3.6.1.4.1.25506.2.87.1.4.2.1)
Integer32
SNMP version.
As per the MIB.
hh3cMACInfoTrapIndexExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapIndexExt (1.3.6.1.4.1.25506.2.87.1.4.2.2)
Integer32
Notification index.
As per the MIB.
hh3cMACInfoTrapCountExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapCountExt (1.3.6.1.4.1.25506.2.87.1.4.2.3)
Integer32
Notification count.
As per the MIB.
hh3cMACInfoTrapMsgExt
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgExt (1.3.6.1.4.1.25506.2.87.1.4.2.4)
OCTET STRING
As per the MIB.
hh3cMACInfoTrapMsgMovedAddress
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.87.1.4.2.5)
OCTET STRING
MAC address.
As per the MIB.
hh3cMACInfoTrapMsgMovedVlan
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedVlan (1.3.6.1.4.1.25506.2.87.1.4.2.6)
Unsigned32
Unsigned32 (1..4094)
VLAN ID.
As per the MIB.
hh3cMACInfoTrapMsgMovedFromIf
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedFromIf (1.3.6.1.4.1.25506.2.87.1.4.2.7)
Unsigned32
Unsigned32(1..2147483647)
Source port for the MAC address move.
As per the MIB.
hh3cMACInfoTrapMsgMovedToIf
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedToIf (1.3.6.1.4.1.25506.2.87.1.4.2.8)
Unsigned32
Destination port for the MAC address move.
As per the MIB.
hh3cMACInfoTrapMsgMovedCount
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedCount (1.3.6.1.4.1.25506.2.87.1.4.2.9)
Counter32
MAC address move count.
As per the MIB.
hh3cMACInfoTrapMsgMovedVsi
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedVsi (1.3.6.1.4.1.25506.2.87.1.4.2.10)
OCTET STRING
OCTET STRING (1..31)
A MAC address moves on a VSI.
As per the MIB.
hh3cMACInfoTrapMsgMovedFmIfName
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedFmIfName (1.3.6.1.4.1.25506.2.87.1.4.2.11)
OCTET STRING
OCTET STRING (0..255)
Source interface name for the MAC address move or interface + service instance or link identifier.
As per the MIB.
hh3cMACInfoTrapMsgMovedToIfName
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgMovedToIfName (1.3.6.1.4.1.25506.2.87.1.4.2.12)
OCTET STRING
Destination interface name for the MAC address move or interface + service instance or link identifier.
As per the MIB.
hh3cMACInfoTrapMsgChassis
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgChassis (1.3.6.1.4.1.25506.2.87.1.4.2.13)
Unsigned32
Chassis ID.
As per the MIB.
hh3cMACInfoTrapMsgSlot
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgSlot (1.3.6.1.4.1.25506.2.87.1.4.2.14)
Unsigned32
Slot ID.
As per the MIB.
hh3cMACInfoTrapMsgBlockIfName
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgBlockIfName (1.3.6.1.4.1.25506.2.87.1.4.2.15)
OCTET STRING
Interface name.
As per the MIB.
hh3cMACInfoTrapMsgBlockTime
Object (OID)
Access
Value range
Implementation
hh3cMACInfoTrapMsgBlockTime (1.3.6.1.4.1.25506.2.87.1.4.2.16)
Unsigned32
Unsigned32(30..86400)
Suppression interval (seconds).
As per the MIB.
Tabular objects
hh3cMACInfomationIfTable
About this table
Use this table to configure MAC Information on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cMACLearntEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.1)
read-write
INTEGER
enabled(1)
disabled(2)
MAC learning event reporting.
As per the MIB.
hh3cMACRemovedEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.2)
read-write
INTEGER
enabled(1)
disabled(2)
MAC aging or deletion event reporting.
As per the MIB.
Notifications
This table contains notifications output by HH3C-MAC-INFORMATION-MIB.
hh3cMACInformationChangedTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.87.1.3.0.1
MAC changes.
Informational
Warning
ON
Notification triggers
This notification is generated when MAC addresses change.
System impact
Status control
This notification cannot be disabled.
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.3.2.1 (hh3cMACInfoTrapIndex)
Notification index.
N/A
Unsigned32
Unsigned32 (1..2147483647)
1.3.6.1.4.1.25506.2.87.1.3.2.2 (hh3cMACInfoTrapCount)
Notification count.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.3.2.3 (hh3cMACInfoTrapMsg)
N/A
OCTET STRING
Recommended action
No action is required.
hh3cMACInformationChangedTrapExt
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.1
MAC changes.
Informational
Warning
N/A
ON
System impact
Status control
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt)
SNMP version.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt)
Notification index.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt)
Notification count.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt)
N/A
OCTET STRING
Recommended action
hh3cMACInformationMovedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.2
A MAC address moves.
Error
Minor
1.3.6.1.4.1.25506.2.87.1.4.0.3 (hh3cMACInformationMovedRsmTrap)
OFF
This notification is generated when a MAC address moves.
System impact
The MAC address move might cause transient interruption of traffic.
Status control
ON
CLI: Use the snmp-agent trap enable mac-address [ mac-move ] command.
OFF
CLI: Use the undo snmp-agent trap enable mac-address [ mac-move ] command.
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.5.0 (hh3cMACInfoTrapMsgMovedAddress)
MAC address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.6.0 (hh3cMACInfoTrapMsgMovedVlan)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.7.0 (hh3cMACInfoTrapMsgMovedFromIf)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.8.0 (hh3cMACInfoTrapMsgMovedToIf)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.9.0 (hh3cMACInfoTrapMsgMovedCount)
N/A
Counter32
1.3.6.1.4.1.25506.2.87.1.4.2.13.0 (hh3cMACInfoTrapMsgChassis)
Chassis ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.14.0 (hh3cMACInfoTrapMsgSlot)
Slot ID.
N/A
Unsigned32
Recommended action
To resolve this issue:
1.     Execute the display mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on interfaces.
¡     If physical Layer 2 loops exist, remove these loops. If MAC address moves occur frequently after you remove the loops, perform step 2.
¡     If no Layer 2 loop exists, perform step 2.
2.     Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
MAC address moves stop.
Recovery
Minor
N/A
ON
This notification is generated when MAC address moves stop in a VLAN within a specific time period.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.6 (hh3cMACInfoTrapMsgMovedVlan)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.13 (hh3cMACInfoTrapMsgChassis)
Chassis ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.14 (hh3cMACInfoTrapMsgSlot)
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACInfoVsiMovedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.4
Error
Minor
1.3.6.1.4.1.25506.2.87.1.4.0.5 (hh3cMACInfoVsiMovedRsmTrap)
ON
This notification is generated when a MAC address moves on a VSI.
System impact
Status control
ON
OFF
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.5 (hh3cMACInfoTrapMsgMovedAddress)
MAC address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.10 (hh3cMACInfoTrapMsgMovedVsi)
VSI name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.11 (hh3cMACInfoTrapMsgMovedFmIfName)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.12 (hh3cMACInfoTrapMsgMovedToIfName)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.9 (hh3cMACInfoTrapMsgMovedCount)
N/A
Counter32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
1.     Execute the display l2vpn mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on the VSI.
Basic information
OID
Event
Severity
Default status
MAC address moves stop on a VSI.
Recovery
Minor
N/A
ON
This notification is generated when MAC address moves stop on a VSI within a specific time period.
System impact
Status control
ON
OFF
Objects
OID (Object name)
Index nodes
Value range
VSI name.
N/A
OCTET STRING
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACInfoMovedIfBlockTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.6
MAC address move suppression is triggered on an interface due to frequent MAC address moves.
Error
Critical
1.3.6.1.4.1.25506.2.87.1.4.0.7 (hh3cMACInfoMovedIfResumeTrap)
ON
This notification is generated when MAC address move suppression is triggered on an interface due to frequent MAC address moves, and this interface will be shut down for a suppression interval.
System impact
MAC address move suppression might cause service interruption on the shutdown interface.
Status control
ON
OFF
Objects
OID (Object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.15 (hh3cMACInfoTrapMsgBlockIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.16 (hh3cMACInfoTrapMsgBlockTime)
N/A
Unsigned32
MAC address.
N/A
OCTET STRING
VLAN ID.
N/A
Unsigned32
Recommended action
1.     Check whether physical Layer 2 loops exist in the VLAN.
Basic information
OID
Event
Severity
Default status
An interface recovers from MAC address move suppression.
Recovery
Minor
N/A
ON
This notification is generated when an interface goes up after a suppression interval elapses.
System impact
Services interrupted due to MAC address move suppression are restored.
Status control
ON
OFF
Objects
OID (Object name)
Index nodes
Value range
Interface name.
N/A
OCTET STRING
N/A
Unsigned32
VLAN ID.
N/A
Unsigned32
Recommended action
