04-Device Management
HomeSupportReference GuidesMIB CompanionH3C S9850-G&S6530X Switch Series MIB References-R8307Pxx-6W10004-Device Management
13-POWER-ETHERNET-MIB
13-POWER-ETHERNET-MIB 96.51 KB
POWER-ETHERNET-MIB
About this MIB
Use this MIB to query for and manage Power Source Equipment (PSE) working.
MIB file name
rfc3621-power-ethernet.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).powerEthernetMIB(105)
Tabular objects
pethPsePortTable
About this table
Use this table to obtain and control the power characteristics of power Ethernet ports on a PSE.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID)
Access
Value range
Implementation
pethPsePortGroupIndex (1.3.6.1.2.1.105.1.1.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
PSE port group index.
As per the MIB.
pethPsePortIndex (1.3.6.1.2.1.105.1.1.1.2)
not-accessible
Integer32
PSE port index.
As per the MIB.
pethPsePortAdminEnable (1.3.6.1.2.1.105.1.1.1.3)
read-write
TruthValue
true(1),
false(2)
Whether the port can provide the PSE functions.
As per the MIB.
pethPsePortPowerPairsControlAbility (1.3.6.1.2.1.105.1.1.1.4)
read-only
TruthValue
true(1),
false(2)
Capability of controlling the power pairs functionality to switch pins for sourcing power.
As per the MIB.
pethPsePortPowerPairs (1.3.6.1.2.1.105.1.1.1.5)
read-write
INTEGER
signal(1),
spare(2)
Pairs in use.
As per the MIB.
If the value of pethPsePortPowerPairsControl is true, this object is writable. A value of signal(1) means that the signal pairs (1, 2, 3, 6) only are in use. A value of spare(2) means that the spare pairs (4, 5, 7, 8) only are in use.
pethPsePortDetectionStatus (1.3.6.1.2.1.105.1.1.1.6)
read-only
INTEGER
disabled(1),
searching(2),
deliveringPower(3),
fault(4),
test(5),
otherFault(6)
Operational status of the port PD detection.
As per the MIB.
pethPsePortPowerPriority (1.3.6.1.2.1.105.1.1.1.7)
read-write
INTEGER
critical(1),
high(2),
low(3)
PSE port power priority.
As per the MIB.
pethPsePortMPSAbsentCounter (1.3.6.1.2.1.105.1.1.1.8)
read-only
Counter32
Standard MIB values
This counter is incremented when the PSE state diagram transitions directly from the POWER_ON state to the IDLE state due to tmpdo_timer_done being asserted.
As per the MIB.
pethPsePortType (1.3.6.1.2.1.105.1.1.1.9)
read-write
SnmpAdminString
OCTET STRING (0..255)
Type of powered device connected to the port.
As per the MIB.
A zero-length octet string is not supported.
pethPsePortPowerClassifications (1.3.6.1.2.1.105.1.1.1.10)
read-only
INTEGER
class0(1),
class1(2),
class2(3),
class3(4),
class4(5)
Class of the powered device by its power consumption.
As per the MIB.
This object takes effect only when the PD is being powered.
pethPsePortInvalidSignatureCounter (1.3.6.1.2.1.105.1.1.1.11)
read-only
Counter32
Standard MIB values
This counter is incremented when the PSE state diagram enters the SIGNATURE_INVALID state.
As per the MIB.
pethPsePortPowerDeniedCounter (1.3.6.1.2.1.105.1.1.1.12)
read-only
Counter32
Standard MIB values
This counter is incremented when the PSE state diagram enters the POWER_DENIED state.
As per the MIB.
pethPsePortOverLoadCounter (1.3.6.1.2.1.105.1.1.1.13)
read-only
Counter32
Standard MIB values
This counter is incremented when the PSE state diagram enters the ERROR_DELAY_OVER state.
As per the MIB.
pethPsePortShortCounter (1.3.6.1.2.1.105.1.1.1.14)
read-only
Counter32
Standard MIB values
This counter is incremented when the PSE state diagram enters the ERROR_DELAY_SHORT state.
As per the MIB.
pethMainPseTable
About this table
Use this table to obtain and control attributes of the main power source on a PSE device.
This table is not supported on non-default MDCs.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is pethMainPseGroupIndex.
Object (OID)
Access
Value range
Implementation
pethMainPseGroupIndex (1.3.6.1.2.1.105.1.3.1.1.1)
not-accessible
Integer32
Index of the group to which a power Ethernet PSE is connected.
As per the MIB.
pethMainPsePower (1.3.6.1.2.1.105.1.3.1.1.2)
read-only
Gauge32
Gauge32 (1..65535)
Nominal power of the PSE, in watts.
As per the MIB.
pethMainPseOperStatus (1.3.6.1.2.1.105.1.3.1.1.3)
read-only
INTEGER
on(1),
off(2),
faulty(3)
Operational status of the main PSE.
As per the MIB.
pethMainPseConsumptionPower (1.3.6.1.2.1.105.1.3.1.1.4)
read-only
Gauge32
Standard MIB values
PSE power usage in watts.
As per the MIB.
pethMainPseUsageThreshold (1.3.6.1.2.1.105.1.3.1.1.5)
read-write
Integer32
Integer32 (1..99)
PSE power usage threshold.
As per the MIB.
pethNotificationControlTable
About this table
Use this table to control and obtain PSE notifications.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is pethNotificationControlGroupIndex.
Object (OID)
Access
Value range
Implementation
pethNotificationControlGroupIndex (1.3.6.1.2.1.105.1.4.1.1.1)
not-accessible
Integer32
Standard MIB values
Index of the notification control group.
As per the MIB.
pethNotificationControlEnable (1.3.6.1.2.1.105.1.4.1.1.2)
read-write
INTEGER
true(1),
false(2)
Whether or not to enable notifications.
As per the MIB.
Notifications
This section contains the POWER-ETHERNET-MIB notifications.
pethPsePortOnOffNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.105.0.1
PSE power port status changed
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the status of a PSE power port changes except changing to searching state. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
System impact
No negative impact on the system.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus)
PD detection status of a PSE port
pethPsePortIndex
INTEGER
disabled(1)
searching(2)
deliveringPower(3)
fault(4)
test(5)
otherFault(6)
Recommended action
No action is required.
pethMainPowerUsageOnNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.105.0.2
PSE power usage threshold reached
Error
Minor
1.3.6.1.2.1.105.0.3(pethMainPowerUsageOffNotification)
ON
This notification is generated when the PSE power usage reaches the threshold. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
System impact
A large number of PDs might affect PoE power output of the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.105.1.3.1.1.4 (pethMainPseConsumptionPower)
PSE power usage
Gauge32
0..4294967295
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Reduce the number of PDs.
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.105.0.3
PSE power usage dropped below the threshold
Recovery
Minor
N/A
ON
This notification is generated when the PSE power usage falls below the threshold. A minimum of 500 milliseconds must elapse between notifications sent by the same object instance.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
PSE power consumption
Gauge32
0..4294967295
Recommended action
