- 04-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 05-HH3C-INFOCENTER-MIB | 160.28 KB |
hh3cICLogbufferCurrentMessages
hh3cICLogbufferOverwrittenMessages
hh3cICLogbufferDroppedMessages
HH3C-INFOCENTER-MIB
About this MIB
Use this MIB to configure information center settings, including enabling the information center or configuring log buffers and log hosts. You can access this MIB to obtain information about log entries in the log buffer.
MIB file name
hh3c-infocenter.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInfoCenter(119)
Scalar objects
hh3cICMaxLogbufferSize
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Maximum number of log entries that can be buffered. |
As per the MIB. |
hh3cICLogbufferSize
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2) |
read-write |
Unsigned32 |
Current buffer size. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3) |
read-only |
Unsigned32 |
Number of messages stored in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4) |
read-only |
Counter32 |
Number of overwritten messages in the log buffer. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5) |
read-only |
Counter32 |
Number of dropped messages in the log buffer. |
As per the MIB. |
hh3cICMaxLoghost
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1) |
read-only |
Unsigned32 |
Maximum number of log hosts supported by the information center. |
As per the MIB. |
hh3cICLoghostSourceInterface
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2) |
read-write |
InterfaceIndexOrZero |
Source interface through which log messages are sent to log hosts. |
As per the MIB. |
hh3cICLoghostTimestampType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3) |
read-write |
ICTimeStampType |
date(0), boot(1), iso(2), dateWithoutYear(3), none(4), isoWithTimezone(5), dataWithMilliseconds(6), isoWithMilliseconds(7), isoWithMillisecondsAndTimezone(8) |
Timestamp format for logs sent to log hosts. |
Does not support boot(1). |
hh3cICLogGlobalState
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable the information center globally. |
As per the MIB. |
hh3cICLogTimestampType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2) |
read-write |
ICTimeStampType |
date(0), |
Timestamp format for log messages. |
Supports only boot, date, and none. |
hh3cICLogType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogType (1.3.6.1.4.1.25506.2.119.5.4.1) |
accessible-for-notify |
INTEGER |
logfile(1), diagfile(2), secfile(3), tracefile(4) |
Log type. |
As per the MIB. |
hh3cICFailReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICFailReason (1.3.6.1.4.1.25506.2.119.5.4.2) |
DisplayString |
Reason for write failure. |
As per the MIB. |
hh3cICLogFileName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogFileName (1.3.6.1.4.1.25506.2.119.5.4.3) |
DisplayString |
Name of the deleted log file. |
As per the MIB. |
Tabular objects
hh3cICLogbufferContTable
About this table
This table contains log buffer information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cICLogbufferContIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogbufferContIndex (1.3.6.1.4.1.25506.2.119.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Table index. |
As per the MIB. |
hh3cICLogbufferContDescription (1.3.6.1.4.1.25506.2.119.1.2.1.2) |
read-only |
DisplayString |
OCTET STRING (0..1600) |
Content of the log buffer. |
As per the MIB. |
hh3cICLoghostTable
About this table
This table specifies a log host and configures output parameters, including IP address of the log host, VPN instance, logging facility, port number of the log host, and log output destination. You can also access this table to obtain log host-related information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cICLoghostIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLoghostIndex (1.3.6.1.4.1.25506.2.119.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..64) |
Table index. |
As per the MIB. |
hh3cICLoghostIpaddressType (1.3.6.1.4.1.25506.2.119.2.2.1.2) |
read-create |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Address type for the log host. |
As per the MIB. |
hh3cICLoghostIpaddress (1.3.6.1.4.1.25506.2.119.2.2.1.3) |
read-create |
InetAddress |
OCTET STRING (0..255) |
IP address of the log host. |
As per the MIB. |
hh3cICLoghostVPNName (1.3.6.1.4.1.25506.2.119.2.2.1.4) |
read-create |
DisplayString |
Name of the VPN instance to which the log host belongs. |
As per the MIB. |
hh3cICLoghostFacility (1.3.6.1.4.1.25506.2.119.2.2.1.5) |
read-create |
ICFacilityType |
kernel(0), userLevel(1), mailSystem(2), systemDaemons(3), securityAuthorization(4), internallyMessages(5), linePrinter(6), networkNews(7), uucp(8), clockDaemon(9), securityAuthorization2(10), ftpDaemon(11), ntp(12), logAudit(13), logAlert(14), clockDaemon2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23) |
Logging facility for marking different logging sources, and querying and filtering log messages. |
Supports only local0(0), local1(1), local2(2), local3(3), local4(4), local5(5), local6(6), and local7(7). |
hh3cICLoghostOperateRowStatus (1.3.6.1.4.1.25506.2.119.2.2.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cICLoghostIpaddressPort (1.3.6.1.4.1.25506.2.119.2.2.1.7) |
read-create |
Unsigned32 |
Unsigned32 (1..65535) |
Port number of the log host. |
As per the MIB. |
hh3cICLoghostTAddress (1.3.6.1.4.1.25506.2.119.2.2.1.8) |
read-create |
TAddress |
OCTET STRING (1..255) |
Supports only IPv4 addresses. |
hh3cICDirectionTable
About this table
This table contains information about syslog output directions and specifies the enablement status of output directions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cICDirectionIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICDirectionIndex (1.3.6.1.4.1.25506.2.119.3.1.1.1) |
not-accessible |
Unsigned32 |
Table index. |
As per the MIB. |
hh3cICDirectionName (1.3.6.1.4.1.25506.2.119.3.1.1.2) |
read-only |
DisplayString |
OCTET STRING (1..30) |
Name of a log output destination. |
As per the MIB. |
hh3cICDirectionState (1.3.6.1.4.1.25506.2.119.3.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Status of the log output destination. |
Specifies whether to enable log output to the log buffer, log file, security log file, or diagnostic log file. Log output to other destinations than the above destinations are all enabled. |
hh3cICModuleTable
About this table
This table contains available source modules.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICModuleName (1.3.6.1.4.1.25506.2.119.4.1.1.1) |
read-only |
DisplayString |
OCTET STRING (1..8) |
Name of a source module. |
As per the MIB. |
hh3cICLogTable
About this table
This table specifies the log level of log messages generated by a specific module to a specific output destination, and contains the log buffer information.
Create |
Edit/Modify |
Delete |
Read |
The module name in a row cannot contain lowercase letters and cannot be default |
A row with the source module named default cannot be deleted |
Supported |
Supported |
Columns
The table indexes are hh3cICDirectionIndex and hh3cICModuleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cICLogLevel (1.3.6.1.4.1.25506.2.119.5.2.1.1) |
read-create |
ICMessageLevelType |
emergency(0), |
Severity level of a log message. |
As per the MIB. |
hh3cICLogRowStatus (1.3.6.1.4.1.25506.2.119.5.2.1.2) |
read-create |
RowStatus |
active(1), |
Row status. |
As per the MIB. |
Notifications
The following information describes the notifications included in the HH3C-INFOCENTER-MIB module.
hh3cICLogWriteFail
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.119.5.3.0.1 |
Failed to write logs to the log file. |
Error |
Major |
N/A |
ON |
Notification triggers
This notification is generated when the device fails to write logs from the log file buffer to the log file.
System impact
New logs will not be saved to the log file.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.119.5.4.1 (hh3cICLogType) |
Log type. |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.119.5.4.2 (hh3cICFailReason) |
N/A |
DisplayString |
Recommended action
Take the corresponding action according to the failure reason indicated in the trap message:
1. Use the dir command in user view to check the free storage space. If the free storage space on the device is not sufficient, delete unused files by using the delete /unreserved command to free storage space.
2. If the storage medium becomes read-only due to some faults, back up the files in the storage medium, and then use the fixdisk command to repair the storage medium.
3. If log file overwrite-protection is enabled, the device stops saving new logs when no log file space is available. In this case, use the undo info-center logfile overwrite-protection command to disable log file overwrite-protection, so the device can overwrite old logs to save new logs.
4. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cICLogFileAging
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.119.5.3.0.2 |
Deleted the oldest compressed log file. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the device deletes the oldest compressed log file in the case that all the log files are full. This notification is available for devices that support multiple log files.
System impact
The logs in the deleted compressed log file are lost.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
(1.3.6.1.4.1.25506.2.119.5.4.3) hh3cICLogFileName |
N/A |
DisplayString |
Recommended action
1. Back up the log files regularly to avoid loss of important logs.
2. Use the display logfile summary command to view the maximum log file size displayed in the Log file size quota field. Change the maximum log file size to a bigger value if needed. To set the maximum log file size, use the info-center logfile size-quota command.
