- 04-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 08-HH3C-LswTRAP-MIB | 752.01 KB |
hh3cDevTrapSlaveSwitchFailReason
hh3cDMAMemoryCriticalThreshold
hh3cCpuUsageSevereNotification
hh3cCpuUsageSevereRecoverNotification
hh3cCpuUsageMinorRecoverNotification
hh3cMemoryUsageEarlyWarningNotification
hh3cMemoryUsageEarlyWarningRecoverNotification
hh3cMemoryUsageMinorNotification
hh3cMemoryUsageMinorRecoverNotification
hh3cMemoryUsageSevereNotification
hh3cMemoryUsageSevereRecoverNotification
hh3cMemoryUsageCriticalNotification
hh3cMemoryUsageCriticalRecoverNotification
hh3cBladeNotInsertedNotCleared
hh3cOutputPowerStatusNotification
HH3C-LswTRAP-MIB
About this MIB
This MIB contains information about notifications for state change of cards and resources on the device.
MIB file name
hh3c-splat-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswTrapMib(12)
Scalar objects
hh3csLswTrapCpuCoreInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapCpuCoreInfo (1.3.6.1.4.1.25506.8.35.12.2.1) |
accessible-for-notify |
SnmpAdminString |
OCTET STRING (0..255) |
CPU core information in CPU notifications. |
As per the MIB. |
hh3csLswTrapProcessCpuInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapProcessCpuInfo (1.3.6.1.4.1.25506.8.35.12.2.2) |
SnmpAdminString |
Process information in CPU notifications. |
As per the MIB. |
hh3csLswTrapProcessMemoryInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapProcessMemoryInfo (1.3.6.1.4.1.25506.8.35.12.2.3) |
SnmpAdminString |
Memory information in CPU notifications. |
As per the MIB. |
hh3csLswTrapSlubInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3csLswTrapSlubInfo (1.3.6.1.4.1.25506.8.35.12.2.4) |
SnmpAdminString |
Slub information in CPU notifications. |
As per the MIB. |
hh3cLswTrapCpuUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswTrapCpuUsage (1.3.6.1.4.1.25506.8.35.12.2.5) |
SnmpAdminString |
CPU usage information in CPU notifications. |
As per the MIB. |
hh3cLswTrapCoreProcessInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswTrapCoreProcessInfo (1.3.6.1.4.1.25506.8.35.12.2.6) |
SnmpAdminString |
Core process information in CPU notifications. |
As per the MIB. |
hh3cLswCoreTrapUsage
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswCoreTrapUsage (1.3.6.1.4.1.25506.8.35.12.2.7) |
Unsigned32 |
Standard MIB values. |
CPU usage in the most recent 30 minutes. |
As per the MIB. |
hh3cBoardAvailablePower
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBoardAvailablePower (1.3.6.1.4.1.25506.8.35.12.2.8) |
Integer32 |
Available power. |
As per the MIB. |
hh3cBoardRequiredPower
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBoardRequiredPower (1.3.6.1.4.1.25506.8.35.12.2.9) |
Integer32 |
Required power. |
As per the MIB. |
hh3cLswAlarmInPortInNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLswAlarmInPortInNum (1.3.6.1.4.1.25506.8.35.12.2.10) |
Unsigned32 |
Number of alarm in ports. |
As per the MIB. |
hh3cHeartbeatTimeoutSeconds
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cHeartbeatTimeoutSeconds (1.3.6.1.4.1.25506.8.35.12.2.19) |
Unsigned32 |
Heartbeat timeout, in seconds. |
As per the MIB. |
hh3cDevTrapSrcChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapSrcChassis(1.3.6.1.4.1.25506.8.35.12.2.20) |
Integer32 |
Source chassis ID. |
As per the MIB. |
hh3cDevTrapSrcSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapSrcSlot(1.3.6.1.4.1.25506.8.35.12.2.21) |
Integer32 |
Source slot ID. |
As per the MIB. |
hh3cDevTrapSrcCpu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapSrcCpu(1.3.6.1.4.1.25506.8.35.12.2.22) |
Integer32 |
Source CPU ID. |
As per the MIB. |
hh3cDevTrapDestChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapDestChassis(1.3.6.1.4.1.25506.8.35.12.2.23) |
Integer32 |
Destination chassis ID. |
As per the MIB. |
hh3cDevTrapDestSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapDestSlot(1.3.6.1.4.1.25506.8.35.12.2.24) |
Integer32 |
Destination slot ID. |
As per the MIB. |
hh3cDevTrapDestCpu
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapDestCpu(1.3.6.1.4.1.25506.8.35.12.2.25) |
Integer32 |
Destination CPU ID. |
As per the MIB. |
hh3cDevTrapRebootReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapRebootReason(1.3.6.1.4.1.25506.8.35.12.2.26) |
SnmpAdminString |
OCTET STRING(0..255) |
Reason for card or member device reboot failure |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapSlaveSwitchFailReason(1.3.6.1.4.1.25506.8.35.12.2.27) |
INTEGER |
other(0) systemRestarting(1) standbyAbsent(2) standbyNoReady(3) |
Reason for active/standby or master/subordinate switchover failure. |
As per the MIB. |
hh3cDevTrapFanFailureErrcode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapFanFailureErrcode(1.3.6.1.4.1.25506.8.35.12.2.28) |
INTEGER |
remove(0) failed(1) |
Reason for the fan tray failure. |
As per the MIB. |
hh3cDMAMemoryTotal
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryTotal(1.3.6.1.4.1.25506.8.35.12.2.11) |
Counter64 |
Total DMA memory space. |
As per the MIB. |
hh3cDMAMemoryUsed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryUsed(1.3.6.1.4.1.25506.8.35.12.2.12) |
Counter64 |
Used DMA memory space. |
As per the MIB. |
hh3cDMAMemoryFree
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryFree(1.3.6.1.4.1.25506.8.35.12.2.13) |
Counter64 |
Free DMA memory space. |
As per the MIB. |
hh3cDMAMemoryCurrentState
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryCurrentState(1.3.6.1.4.1.25506.8.35.12.2.17) |
INTEGER |
normal(1), critical(2) |
Current DMA memory usage status. |
As per the MIB. |
hh3cDMAMemoryFreeRatio
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryFreeRatio(1.3.6.1.4.1.25506.8.35.12.2.14) |
Unsigned32 |
Unsigned32(0..100) |
Free DMA memory ratio. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryCriticalThreshold(1.3.6.1.4.1.25506.8.35.12.2.15) |
Unsigned32 |
DMA memory usage alarm athreshold. |
As per the MIB. |
hh3cDMAMemoryRecoverThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDMAMemoryRecoverThreshold(1.3.6.1.4.1.25506.8.35.12.2.16) |
Unsigned32 |
DMA memory usage alarm clearance threshold. |
As per the MIB. |
hh3cDevTrapSliceIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevTrapSliceIndex(1.3.6.1.4.1.25506.8.35.12.2.29) |
Unsigned32 |
Slice index. |
As per the MIB. |
Notifications
This section contains the HH3C-LswTRAP-MIB notifications.
hh3cpowerfailure
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.1 |
Failure of a power supply |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.2(hh3cPowerNormal) |
ON |
Notification triggers
This notification is generated when a power supply fails or a new power supply is inserted into the device.
System impact
A power supply failure might affect power supply to the device.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.9.1.2.1.1 (hh3cDevMPowerNum) |
Power supply ID. |
hh3cDevMPowerNum |
Integer32 |
1.3.6.1.4.1.25506.8.35.9.1.13 (hh3cDevMFirstTrapTime) |
Timestamp of the notification. |
N/A |
TimeTicks |
Recommended action
To resolve the issue:
1. Verify that the power supply is installed correctly.
2. If the issue persists, contact H3C Support.
hh3cPowerNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.2 |
Recovery of a power supply from a fault |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a power supply recovers from an abnormal state.
System impact
No negative impact on the system
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Power supply ID. |
hh3cDevMPowerNum |
Integer32 |
N/A |
TimeTicks |
Recommended action
hh3cPowerRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.5 |
Removal of a power supply |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.23 (hh3cPowerInserted) |
ON |
This notification is generated when a power supply is removed from the device.
System impact
Power supply to the system might be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Power supply ID. |
hh3cDevMPowerNum |
Integer32 |
Recommended action
1. Verify that a power supply is removed from the device.
¡ If the power supply is removed from the device, no action is required.
¡ If the power supply is not removed from the device, verify that the power supply is installed correctly.
hh3cfanfailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.6 |
Failure of a fan tray |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.7(hh3cFanNormal) |
ON |
This notification is generated when a fan tray fails.
System impact
Heat dissipation might be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.9.1.1.1.1 (hh3cDevMFanNum) |
Fan tray ID. |
hh3cDevMFanNum |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.28 (hh3cDevTrapFanFailureErrcode) |
N/A |
INTEGER |
Recommended action
1. Verify that the fan tray is installed correctly.
hh3cFanNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.7 |
Recovery of a fan tray from a fault. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a fan tray recovers from a fault.
System impact
No negative impact on the system.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Fan tray ID. |
hh3cDevMFanNum |
Integer32 |
Recommended action
hh3cBoardRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.8 |
Removal of a card |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.9(hh3cBoardInserted) |
ON |
This notification is generated when a card is removed from the device.
System impact
Service processing capabilities of the system will degrade.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.18.4.2.1.1 (hh3cLswFrameIndex) |
Chassis ID. |
hh3cLswFrameIndex hh3cLswSlotIndex |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cLswSlotIndex) |
Slot ID. |
Integer32 |
Recommended action
1. Verify that the card is removed from the device.
¡ If the card is removed from the device, no action is required.
¡ If the card is not removed from the device, verify that the card is installed correctly.
hh3cBoardInserted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.9 |
Insertion of a card |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a card is inserted into the device.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
Recommended action
hh3cBoardFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.10 |
Failure or startup of a card |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.11(hh3cBoardNormal) |
ON |
This notification is generated when a card is starting up or a fault occurs on the card.
System impact
A card failure can cause degradation of system processing capabilities.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Member ID of the device |
Integer32 |
Slot ID |
Integer32 |
Recommended action
1. Verify that the card is installed correctly.
2. If the issue persists after 24 hours, contact H3C Support.
hh3cBoardNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.11 |
Initialization completion of a card |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a card completes initialization.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
Recommended action
hh3cSubcardRemove
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.12 |
Removal of a subcard |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.13(hh3cSubcardInsert) |
ON |
This notification is generated when a subcard is removed from the device.
System impact
System processing capabilities will degrade.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
hh3cLswFrameIndex hh3cLswSlotIndex hh3cLswSubslotIndex |
Integer32 |
Slot ID |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.4.1.1 (hh3cLswSubslotIndex) |
Subslot ID |
Integer32 |
Recommended action
1. Verify that the subcard is removed from the device.
¡ If the subcard is removed from the device, no action is required.
¡ If the subcard is not removed from the device, verify that the subcard is installed correctly.
hh3cSubcardInsert
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.13 |
Insertion of a subcard |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a subcard is inserted into the device.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
Subslot ID. |
Integer32 |
Recommended action
No action is required.
hh3cPowerInserted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.23 |
Insertion of a power supply |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a power supply is inserted into the device.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Power supply ID. |
hh3cDevMPowerNum |
Integer32 |
Recommended action
hh3cCpuRemoved
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.25 |
Removal of a non-default CPU |
Error |
Minor |
N/A |
ON |
This notification is generated when a non-default CPU subcard is removed from the device.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
hh3cLswFrameIndex hh3cLswSlotIndex hh3cLswCpuIndex |
Integer32 |
Slot ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.1 (hh3cLswCpuIndex) |
CPU ID. |
Integer32 |
Recommended action
1. Verify that the non-default CPU is removed from the device.
¡ If the non-default CPU is removed from the device, no action is required.
¡ If the non-default CPU is not removed from the device, verify that the non-default CPU is installed correctly.
hh3cCpuFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.26 |
Failure or startup of a non-default CPU |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.27(hh3cCpuNormal) |
ON |
This notification is generated when a non-default CPU is starting up or a fault occurs on it.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Recommended action
1. Verify that the non-default CPU is installed correctly.
hh3cCpuNormal
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.27 |
Initialization completion of a non-default CPU |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a non-default CPU completes initialization.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Recommended action
hh3cPowerIncompatible
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.28 |
Incompatibility of a power supply with the device |
Error |
Major |
ON |
This notification is generated when a power supply is not compatible with the device.
System impact
The power supply cannot supply power to the device.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Power supply ID. |
hh3cDevMPowerNum |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.29 |
Severe CPU usage alarm |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.30(hh3cCpuUsageSevereRecoverNotification) |
ON |
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageSevereThreshold. This notification is sent at intervals of 60 seconds until the alarm is cleared.
System impact
The system service processing capabilities will be degraded.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.3 (hh3cLswCpuRatio) |
CPU usage. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.11 (hh3cLswCpuUsageMinorThreshold) |
Minor CPU usage threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.12 (hh3cLswCpuUsageSevereThreshold) |
Severe CPU usage threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.13 (hh3cLswCpuUsageRecoverThreshold) |
CPU usage recovery threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.12.2.1 (hh3csLswTrapCpuCoreInfo) |
CPU core usage (top1). |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top1) |
CPU core usage (top2). |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top2) |
CPU core usage (top3). |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top3) |
CPU core usage (top4). |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top4) |
CPU core usage (top5). |
SnmpAdminString |
Standard MIB values. (hh3cLswCpuCoreUsage-top5) |
1.3.6.1.4.1.25506.8.35.12.2.2 (hh3csLswTrapProcessCpuInfo) |
Process usage (top1). |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top1) |
Process usage (top2). |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top2) |
Process usage (top3). |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio-top3) |
Process usage (top4). |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top4) |
Process usage (top5). |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessCpuRatio -top5) |
Recommended action
If the alarm remains over 10 minutes, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.30 |
Clearance of a severe CPU usage alarm |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageSevereThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
CPU usage. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
Recommended action
hh3cCpuUsageMinorNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.31 |
Minor CPU usage alarm |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.1.32(hh3cCpuUsageMinorRecoverNotification) |
ON |
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageMinorThreshold. This notification is sent at intervals of 300 seconds until the alarm is cleared.
System impact
No impact on the system at present. Observer whether the CPU usage continues to increase.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
CPU usage. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
CPU core usage (top5) |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
Recommended action
Potential risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.32 |
Minor CPU usage alarm clearance |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageMinorThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
CPU usage. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.33 |
Memory usage early warning alarm |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.1.34(hh3cMemoryUsageEarlyWarningRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageEarlyWarningThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared or a higher severity alarm is generated.
System impact
No negative impact on the system. Observe whether the amount of free memory continues to decrease.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.8 (hh3cLswCpuMemory) |
Total memory size. |
CounterBasedGauge64 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.14 (hh3cLswCpuMemoryFree) |
Free memory size. |
1.3.6.1.4.1.25506.8.35.18.4.10.1.15 (hh3cLswCpuMemoryFreeRatio) |
Free memory ratio. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.16 (hh3cLswCpuMemoryHighTotal) |
Total high memory size |
1.3.6.1.4.1.25506.8.35.18.4.10.1.17 (hh3cLswCpuMemoryHighFree) |
Free high memory size. |
1.3.6.1.4.1.25506.8.35.18.4.10.1.18 (hh3cLswCpuMemoryLowTotal) |
Total low memory size. |
1.3.6.1.4.1.25506.8.35.18.4.10.1.19 (hh3cLswCpuMemoryLowFree) |
Free low memory size. |
1.3.6.1.4.1.25506.8.35.18.4.10.1.26 (hh3cLswCpuMemorySecureThreshold) |
Sufficient memory threshold. |
Unsigned32 |
1 to 100, in percentage |
1.3.6.1.4.1.25506.8.35.18.4.10.1.27 (hh3cLswCpuMemoryEarlyWarningThreshold) |
Early-warning memory threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.28 (hh3cLswCpuMemoryNormalThreshold) |
Normal state memory threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.29 (hh3cLswCpuMemoryMinorThreshold) |
Minor memory threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.30 (hh3cLswCpuMemorySevereThreshold) |
Severe memory threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.31 (hh3cLswCpuMemoryCriticalThreshold) |
Critical memory threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.10.1.32 (hh3cLswCpuMemoryCurrentState) |
Current memory state. |
INTEGER |
secure(1), earlywarning(2), normal(3), minor(4), severe(5), critical(6) |
1.3.6.1.4.1.25506.8.35.12.2.3 (hh3csLswTrapProcessMemoryInfo) |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top1) |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top2) |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top3) |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top4) |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswProcessMemoryUsed-top5) |
1.3.6.1.4.1.25506.8.35.12.2.4 (hh3csLswTrapSlubInfo) |
Slub information (top 1). |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top1) |
Slub information (top 2). |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top2) |
Slub information (top 3). |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top3) |
Slub information (top 4). |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top4) |
Slub information (top 5). |
N/A |
SnmpAdminString |
Standard MIB values. (hh3cLswSlubInfoUsed-top5) |
Recommended action
Potential risks might exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.34 |
Memory usage early warning alarm clearance |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSecureThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Total high memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.35 |
Minor memory usage alarm |
Error |
Minor |
1.3.6.1.4.1.25506.8.35.12.1.36(hh3cMemoryUsageMinorRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cLswCpuMemoryMinorThreshold. The notification is sent at intervals of 12 hours until the alarm condition is cleared or a higher severity alarm is generated.
System impact
No negative impact on the system at present.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Sufficient memory threshold |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
The issue needs to be reviewed to determine whether action is necessary.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.36 |
Minor memory usage notification clearance |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cLswCpuMemoryNormalThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Slub information (top 4) |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.37 |
Severe memory usage alarm |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.1.38(hh3cMemoryUsageSevereRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageSevereThreshold. This notification is sent at intervals of 3 hours until the alarm is cleared or a higher severity alarm is generated.
System impact
Some services are affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
The issue has significant impact on services. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.38 |
Severe memory usage alarm clearance |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageMinorThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.39 |
Critical memory usage alarm |
Error |
Critical |
1.3.6.1.4.1.25506.8.35.12.1.40(hh3cMemoryUsageCriticalRecoverNotification) |
ON |
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageCriticalThreshold. This notification is sent at intervals of 1 hour until the alarm is cleared.
System impact
The amount of free memory is severely insufficient. System communication will be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
The issue puts the system assets and services at risk. Immediate action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.40 |
Critical memory usage alarm clearance |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSevereThreshold.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
Free memory size. |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
INTEGER |
1.3.6.1.4.1.25506.8.35.18.4.10.1.33 (hh3cLswCpuMemoryUsageThreshold) |
Memory usage threshold. |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
Recommended action
hh3cCoreUsageNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.1 |
CPU core usage alarm |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.10(hh3cCoreUsageSevereRecoveryNotification) |
ON |
This notification is generated when the CPU core usage exceeds the hh3cLswCoreThreshold.
System impact
Degradation of the service processing capabilities by the CPU core.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
hh3cLswFrameIndex hh3cLswSlotIndex hh3cLswCpuIndex hh3cLswCoreIndex |
Integer32 |
Slot ID. |
Integer32 |
CPU ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.1 (hh3cLswCoreIndex) |
CPU core ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.7 (hh3cLswCoreTrapUsage) |
CPU core usage in the most recent 30 minutes. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.5 (hh3cLswCoreThreshold) |
CPU core usage threshold. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.12.2.5 (hh3cLswTrapCpuUsage) |
CPU usage during the most recent 5 seconds, 1 minute, 5 minutes. |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.8.35.12.2.6 (hh3cLswTrapCoreProcessInfo) |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
N/A |
SnmpAdminString |
1.3.6.1.4.1.25506.8.35.18.4.15.1.7 (hh3cLswCoreMinorThreshold) |
Minor CPU core usage threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.8.35.18.4.15.1.8 (hh3cLswCoreRecoveryThreshold) |
CPU core normal state threshold. |
Unsigned32 |
Recommended action
If the issue persists after 10 minutes, contact H3C Support.
hh3cBoardPowerNotEnough
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.2 |
Power insufficiency for a card |
Error |
Major |
N/A |
ON |
This notification is generated when the power provided for a card is not enough.
System impact
The card cannot operate correctly.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.8 (hh3cBoardAvailablePower) |
Available power. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.9 (hh3cBoardRequiredPower) |
Required power. |
N/A |
Integer32 |
Recommended action
Replace the power supplies with high-power ones.
hh3cAlarmInPortIn
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.3 |
Electrical level state received on an alarm input port inconsistent with that configured for the port. |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.4(hh3cAlarmInPortRecover) |
ON |
This notification is generated when the electrical level state received on an alarm input port is inconsistent with that configured for the port.
System impact
Alarm signal identification will be affected.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.10 (hh3cLswAlarmInPortInNum) |
Alarm input port number. |
N/A |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.4 |
Electrical level state received on an alarm input port become consistent with that configured for the port |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the electrical level state received on an alarm input port becomes consistent with that configured for the port.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
hh3cLswFrameIndex |
Integer32 |
Slot ID. |
hh3cLswSlotIndex |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.9 (hh3cLswAlarmInPortInNum) |
N/A |
Integer32 |
Recommended action
hh3cLoadFinished
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.20 |
A card finished loading of the image file. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a card finishes loading of the image file.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.18.4.2.1.1(hh3cLswFrameIndex) |
Chassis ID. |
Integer |
Slot ID. |
Integer |
Recommended action
hh3cBootImageUpdated
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.24 |
Startup software images updated. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the startup software images are updated.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
Recommended action
hh3cRequestLoading
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.1.18 |
Image loading request received. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the loading service end receives an image loading request.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
Recommended action
hh3cBoardHeartbeatTimeout
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.46 |
Heartbeat between the MPU and a card timed out. |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.47(hh3cBoardHeartbeatResume) |
ON |
This notification is generated when the heartbeat between the MPU and a card times out.
System impact
A communication exception might occur between the MPU and other cards.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
CPU ID. |
Integer |
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cHeartbeatTimeoutSeconds) |
N/A |
Integer |
Recommended action
Check the connection between the MPU and the card.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.47 |
Heartbeat between the MPU and a card resumed. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the heartbeat between the MPU and a card resumes.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
CPU ID. |
Integer |
Recommended action
hh3cCommunicateError
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.48 |
LIPC communication timed out. |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.3.0.49(hh3cCommunicateResume) |
ON |
This notification is generated when communication between LIPC nodes times out.
System impact
A LIPC communication exception might occur.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.12.2.20(hh3cDevTrapSrcChassis) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.21(hh3cDevTrapSrcSlot) |
Source slot ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.22(hh3cDevTrapSrcCpu) |
Source CPU ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.23(hh3cDevTrapDestChassis) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.24(hh3cDevTrapDestSlot) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.25(hh3cDevTrapDestCpu) |
N/A |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.49 |
LIPC communication recovered. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when LIPC communication recovers after a timeout.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
Integer32 |
Source slot ID. |
N/A |
Integer32 |
Source CPU ID. |
N/A |
Integer32 |
N/A |
Integer32 |
N/A |
Integer32 |
N/A |
Integer32 |
Recommended action
hh3cBoardRebooted
Objects
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.50 |
A card or member device failed to reboot. |
Informational |
Major |
N/A |
ON |
This notification is generated when a card or member device fails to reboot.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.12.2.26(hh3cDevTrapRebootReason) |
Reason for reboot failure of the card or member device. |
N/A |
SnmpAdminString |
Standard MIB values |
N/A |
Integer32 |
Source slot ID. |
N/A |
Integer32 |
Source CPU ID. |
N/A |
Integer32 |
Recommended action
Identify whether the reboot is an unexpected reboot.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.51 |
An active/standby or master/subordinate switchover failed. |
Informational |
Major |
N/A |
ON |
This notification is generated when an active/standby or master/subordinate switchover fails. The following are the possible causes:
· No standby/subordinate exists.
· Startup of the standby/subordinate has not finished.
· The system is restarting.
· Other reasons.
System impact
Active/standby or master/subordinate switchover failure.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.12.2.27(hh3cDevTrapSlaveSwitchFailReason) |
N/A |
INTEGER |
Recommended action
Take actions according to the reason displayed by the system:
· An active/standby or master/subordinate switchover cannot be performed.
· Wait for the standby/subordinate to finish startup.
· Contact H3C Support.
hh3cAllBoardHeartbeatTimeout
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.52 |
The active MPU or master device was disconnected from all cards or member devices. |
Error |
Major |
1.3.6.1.4.1.25506.8.35.12.3.0.53(hh3cAllBoardHeartbeatResume) |
ON |
This notification is generated when the active MPU or master device is disconnected from all cards or member devices.
System impact
MPU exception.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.8.35.12.2.19(hh3cHeartbeatTimeoutSeconds) |
Heartbeat timeout value. |
N |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.53 |
Recovery |
Warning |
N/A |
ON |
This notification is generated when heartbeat between the MPU and a card times out.
System impact
Status control
Objects
None.
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.54 |
After a security engine was removed, no security engine was inserted for a long time and information for the absent security engine was not cleared. |
Error |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.55(hh3cBladeInsertedCleared) |
ON |
This notification is generated if a security engine is removed, no security engine is inserted for a long time, and information for the absent security engine was not cleared.
System impact
Degradation of service processing capabilities of the system.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID |
Integer |
Slot ID |
Integer |
CPU ID |
Integer |
Recommended action
Execute the reset blade-controller-team command to clear information for an absent security engine in a security engine group or insert a security engine.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.55 |
A security engine was inserted or information for an absent security engine has been cleared. |
Recovery |
Warning |
N/A |
ON |
This notification is generated if a security engine was inserted or information for an absent security engine has been cleared.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
CPU ID. |
Integer |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.45 |
Power interface exception |
Error |
Warning |
N/A |
ON |
This notification is generated if a power interface exception is detected.
System impact
Power supply will be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
hh3cLswFrameIndex hh3cLswSlotIndex hh3cLswOutputPowerPortID |
Integer32 |
Slot ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.18.4.16.1.1 (hh3cLswOutputPowerPortID) |
Power interface ID. |
Integer32 |
Integer32(1..2147483647) |
1.3.6.1.4.1.25506.8.35.18.4.16.1.2 (hh3cLswOutputPowerStatus) |
Power interface state. |
INTEGER |
INTEGER(1-7) |
Recommended action
If the issue cannot be resolved, contact H3C Support.
hh3cDevTrapSliceStarting
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.56 |
A slice module started to power on. |
Informational |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.57 |
ON |
This notification is generated when the following events occur after slice energy saving is enabled.
· A hidden command is executed to power on a slice module.
· A service triggers power on of a slice module.
System impact
The slice module cannot provide services when this notification is triggered.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
1.3.6.1.4.1.25506.8.35.12.2.29(hh3cDevTrapSliceIndex) |
Slice module ID. |
N/A |
Integer32 |
Recommended actions
hh3cDevTrapSliceOnline
Basic information
OID |
Event |
Type |
Severity |
Default status |
A slice module completed power on. |
Informational |
Warning |
1.3.6.1.4.1.25506.8.35.12.3.0.58 |
ON |
This notification is generated when a slice module completes power on after slice energy saving is enabled.
System impact
The slice module that has completed power on can process services.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
Slice module ID. |
N/A |
Integer32 |
Recommended actions
hh3cDevTrapSliceOffline
Basic information
OID |
Event |
Type |
Severity |
Default status |
A slice module powered off. |
Informational |
Warning |
ON |
This notification is generated when the following event occur after slice energy saving is enabled.
· A hidden command is executed to power off a slice module.
· A service triggers power off of a slice module.
System impact
A slice module that has powered off cannot provide forwarding.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer32 |
Slot ID. |
Integer32 |
Slice module ID. |
N/A |
Integer32 |
Recommended actions
hh3cBoardReceiveWrongPackets
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.35.12.3.0.59 |
A card received error packets. |
Error |
Warning |
N/A |
ON |
This notification is generated when a card receives error packets.
System impact
Service anomaly might occur, or the card might reboot.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis ID. |
Integer |
Slot ID. |
Integer |
CPU ID. |
Integer |
Recommended actions
