- 04-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 09-HH3C-POWER-ETH-EXT-MIB | 296.87 KB |
hh3cPOEOutputErrorNotification
hh3cPOEOverVoltageNotification
hh3cPOEModuleShutdownNotification
hh3cPOECurRestrictedNotification
hh3cPOEACSwitchVolABNotification
hh3cPOEACSwitchVolBCNotification
hh3cPOEACSwitchVolCANotification
About this MIB
This MIB is an extension of POWER-ETHERNET-MIB. To implement this MIB, you must first implement relevant parts of POWER-ETHERNET-MIB, such as pethMainPseTable.
This MIB adds some objects which POWER-ETHERNET-MIB does not contain to monitor some specific aspects of entities for better and comprehensive management on devices.
MIB file name
hh3c-power-eth-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPowerEthernetExt(14)
Scalar objects
hh3cPsePowerMaxValue
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPsePowerMaxValue (1.3.6.1.4.1.25506.2.14.5) |
read-write |
INTEGER |
Standard MIB values. |
PSE power management policy. |
As per the MIB. Applicable only to a device in standalone mode or member device 1 in an IRF fabric. |
hh3cPsePolicyMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPsePolicyMode (1.3.6.1.4.1.25506.2.14.9) |
read-write |
INTEGER |
disabled(1), priority(2) |
PSE power management policy mode. |
As per the MIB. |
hh3cPDPolicyMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPDPolicyMode (1.3.6.1.4.1.25506.2.14.10) |
read-write |
INTEGER |
PD power management policy mode. |
As per the MIB. |
hh3cPOEPortName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEPortName (1.3.6.1.4.1.25506.2.14.12) |
accessible-for-notify |
DisplayString |
Name of the PoE port (PI). |
As per the MIB. |
Tabular objects
hh3cPsePortTable
About this table
Use this table to manage PSE ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are pethPsePortGroupIndex and pethPsePortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPsePortFaultDescription (1.3.6.1.4.1.25506.2.14.1.1.2) |
read-write |
DisplayString |
OCTET STRING (0..255) |
Description about the precise PoE hardware state causing the pethPsePortDetectionStatus object to be in the fault state. |
Not supported |
hh3cPsePortPeakPower (1.3.6.1.4.1.25506.2.14.1.1.3) |
read-write |
Integer32 |
Peak power of the PSE port, in milliwatts. |
As per the MIB. You can set the value to 0. Other values are not effective. |
hh3cPsePortAveragePower (1.3.6.1.4.1.25506.2.14.1.1.4) |
read-write |
Integer32 |
Average power of the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortCurrentPower (1.3.6.1.4.1.25506.2.14.1.1.5) |
read-only |
Integer32 |
Current power of the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortPowerLimit (1.3.6.1.4.1.25506.2.14.1.1.6) |
read-write |
Integer32 |
Power limit for the PSE port, in milliwatts. |
As per the MIB. |
hh3cPsePortProfileIndex (1.3.6.1.4.1.25506.2.14.1.1.7) |
read-write |
Integer32 |
Integer32 (0..100) |
Index of the power profile currently associated with this port. |
As per the MIB. |
hh3cMainPseTable
About this table
Use this table to manage PSEs.
This table is not supported on non-default MDCs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is pethPsePortGroupIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMainPsePowerLimit (1.3.6.1.4.1.25506.2.14.2.1.1) |
read-write |
Integer32 |
Power limit for the PSE, in watts. |
As per the MIB. |
hh3cMainPseAveragePower (1.3.6.1.4.1.25506.2.14.2.1.2) |
read-write |
Integer32 |
Average power of the PSE, in watts. |
As per the MIB. |
hh3cMainPsePeakPower (1.3.6.1.4.1.25506.2.14.2.1.3) |
read-write |
Integer32 |
Peak power of the PSE, in watts. |
As per the MIB. |
hh3cMainGuaranteedPowerRemaining (1.3.6.1.4.1.25506.2.14.2.1.4) |
read-only |
Integer32 |
Remaining guaranteed power of the PSE, in watts. |
As per the MIB. |
hh3cMainPsePriorityMode (1.3.6.1.4.1.25506.2.14.2.1.5) |
read-write |
INTEGER |
disconnection(0), non-disconnection(1) |
Describes or controls the priority mode on slot which must be enabled firstly. When a new card is inserted, and the power is overloaded, a value of disconnection(0) means that power will not be supplied to the low priority slot. A value of non-disconnection(1) means that power is supplied to the slot when a new card is inserted, and the power is overloaded. |
Not supported. |
hh3cMainPseLegacy (1.3.6.1.4.1.25506.2.14.2.1.6) |
read-write |
INTEGER |
enable(0), disable(1) |
Standard or nonstandard PD detection mode. |
As per the MIB. |
hh3cMainPsePowerPriority (1.3.6.1.4.1.25506.2.14.2.1.7) |
read-write |
INTEGER |
critical(1), high(2), low(3) |
Priority of the PSE. |
As per the MIB. |
hh3cPseProfilesTable
About this table
Use this table to manage power profiles.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cPseProfileIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPseProfileIndex (1.3.6.1.4.1.25506.2.14.7.1.1) |
not-accessible |
Integer32 |
Integer32 (1..100) |
Profile index. |
As per the MIB. |
hh3cPseProfileName (1.3.6.1.4.1.25506.2.14.7.1.2) |
read-create |
DisplayString |
OCTET STRING (1..15) |
Profile name. |
As per the MIB. |
hh3cPseProfilePowerMode (1.3.6.1.4.1.25506.2.14.7.1.3) |
read-create |
INTEGER |
powerDisabled(1), powerEnabled(2) |
Power mode. |
As per the MIB. |
hh3cPseProfilePowerLimit (1.3.6.1.4.1.25506.2.14.7.1.4) |
read-create |
Integer32 |
Power limit, in milliwatts. |
As per the MIB. |
hh3cPseProfilePriority (1.3.6.1.4.1.25506.2.14.7.1.5) |
read-create |
INTEGER |
Port priority. |
As per the MIB. |
hh3cPseProfilePairs (1.3.6.1.4.1.25506.2.14.7.1.6) |
read-create |
INTEGER |
signal(1), spare(2) |
Pairs in use. |
As per the MIB. |
hh3cPseProfileApplyNum (1.3.6.1.4.1.25506.2.14.7.1.7) |
read-only |
Integer32 |
Number of this profile being applied. |
As per the MIB. |
hh3cPseProfileRowStatus (1.3.6.1.4.1.25506.2.14.7.1.8) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active, createAndGo, and destory. This row cannot be deleted when the value of the hh3cPseProfileApplyNum is 0. |
hh3cPOEModuleInfoTable
About this table
This table contains information about the PoE power supplies.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOEModuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEModuleIndex (1.3.6.1.4.1.25506.2.14.8.2.7.1.1) |
Integer32 |
Integer32 (1..2147483647) |
PoE power supply index. |
As per the MIB. |
hh3cPOEModuleID (1.3.6.1.4.1.25506.2.14.8.2.7.1.2) |
read-only |
Integer32 |
PoE power supply ID. |
As per the MIB. |
hh3cPOEModuleInfoPower (1.3.6.1.4.1.25506.2.14.8.2.7.1.3) |
read-only |
Integer32 |
Power of the PoE power supply. |
As per the MIB. |
hh3cPOEModuleHardVerInfo (1.3.6.1.4.1.25506.2.14.8.2.7.1.4) |
read-only |
STRING |
(SIZE (1..127)) |
Hardware version information of the PoE power supply. |
As per the MIB. |
hh3cPOEDCOutStateTable
About this table
This table contains the DC power output states of a PoE power supply.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOEDCOutStateIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEDCOutStateIndex (1.3.6.1.4.1.25506.2.14.8.3.2.1.1) |
Integer32 |
DC output power state index. |
As per the MIB. |
hh3cPOEDCOutDCVolAlarm (1.3.6.1.4.1.25506.2.14.8.3.2.1.2) |
read-only |
DCAlarmState |
normal (1), underLimit (2), aboveLimit (3), fuseBroken (4), switchOff (5), otherError (6)." |
DC output power state alarm. |
As per the MIB. |
hh3cPOEDCOutInfoTable
About this table
This table contains the DC output information of a PoE power supply.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOEDCOutInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEDCOutInfoIndex (1.3.6.1.4.1.25506.2.14.8.4.2.1.1) |
Integer32 |
DC output information index of a PoE power supply. |
As per the MIB. |
hh3cPOEDCOutVol (1.3.6.1.4.1.25506.2.14.8.4.2.1.2) |
read-only |
OCTET STRING |
(SIZE (1..10)) |
DC output voltage. |
As per the MIB. |
hh3cPOEDCOutInfoLoadCur (1.3.6.1.4.1.25506.2.14.8.4.2.1.3) |
read-only |
OCTET STRING |
(SIZE (1..10)) |
Total load current. |
As per the MIB. |
hh3cPOEACSwitchStateTable
About this table
This table contains the AC switch state of a PoE power supply.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOEACSwitchStateIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEACSwitchStateIndex (1.3.6.1.4.1.25506.2.14.8.5.2.1.1) |
Integer32 |
AC switch state index. |
As per the MIB. |
hh3cPOEACSwitchState (1.3.6.1.4.1.25506.2.14.8.5.2.1.2) |
read-only |
SwitchState |
on (1), off (2), highVoltInput (3), lowVoltInput (4)" |
AC switch state. |
As per the MIB. |
hh3cPOESwitchStateVolExTable
About this table
This table contains the all alarm status of the VOL status.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOESwitchStateVolExIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOESwitchStateVolExIndex (1.3.6.1.4.1.25506.2.14.8.6.5.1.1) |
Integer32 |
Index of the VOL status. |
As per the MIB. |
hh3cPOESwitchStateInVolAB (1.3.6.1.4.1.25506.2.14.8.6.5.1.2) |
read-only |
ACAlarmState |
normal (1), underLimit (2), aboveLimit (3), lackPhrase (4), fuseBroken (5), switchOff (6), otherError (7)." |
VOL AB alarm in the VOL status. |
As per the MIB. |
hh3cPOESwitchStateInVolBC (1.3.6.1.4.1.25506.2.14.8.6.5.1.3) |
read-only |
ACAlarmState |
VOL BC alarm in the VOL status. |
As per the MIB. |
hh3cPOESwitchStateInVolCA (1.3.6.1.4.1.25506.2.14.8.6.5.1.4) |
read-only |
ACAlarmState |
VOL CA alarm in the VOL status. |
As per the MIB. |
hh3cPOEAlarmStateInfoTable
About this table
This table contains all alarm states of PoE power supplies.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cPOEAlarmModuleInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPOEAlarmModuleInfoIndex (1.3.6.1.4.1.25506.2.14.8.7.2.1.1) |
Integer32 |
Alarm information index. |
As per the MIB. |
hh3cPOEModuleDisconnect (1.3.6.1.4.1.25506.2.14.8.7.2.1.2) |
read-only |
ModuleAlarmState |
normal (1), alarm (2). |
PoE power supply disconnection alarm state. |
As per the MIB. |
hh3cPOEModuleInputError (1.3.6.1.4.1.25506.2.14.8.7.2.1.3) |
read-only |
ModuleAlarmState |
Input error alarm state. |
As per the MIB. |
hh3cPOEModuleOutputError (1.3.6.1.4.1.25506.2.14.8.7.2.1.4) |
read-only |
ModuleAlarmState |
Output error alarm state. |
As per the MIB. |
hh3cPOEModuleOverVoltage (1.3.6.1.4.1.25506.2.14.8.7.2.1.5) |
read-only |
ModuleAlarmState |
Overvoltage alarm state. |
As per the MIB. |
hh3cPOEModuleOverTemp (1.3.6.1.4.1.25506.2.14.8.7.2.1.6) |
read-only |
ModuleAlarmState |
Overtemperature alarm. |
As per the MIB. |
hh3cPOEModuleFanError (1.3.6.1.4.1.25506.2.14.8.7.2.1.7) |
read-only |
ModuleAlarmState |
Fan error alarm state. |
As per the MIB. |
hh3cPOEModuleShutdown (1.3.6.1.4.1.25506.2.14.8.7.2.1.8) |
read-only |
ModuleAlarmState |
PoE power supply shut down alarm state. |
As per the MIB. |
hh3cPOEModuleCurRestricted (1.3.6.1.4.1.25506.2.14.8.7.2.1.9) |
read-only |
ModuleAlarmState |
PoE power supply current limited alarm state. |
As per the MIB. |
Notifications
This section contains the HH3C-POWER-ETH-EXT-MIB notifications.
hh3cpsePDChangeNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.14.6.1 |
PD connection status changed |
Informational |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when a PD is connected or disconnected.
System impact
No negative impact on the system.
Status control
ON
MIB: Set pethNotificationControlEnable to true(1).
OFF
MIB: Set pethNotificationControlEnable to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.105.1.1.1.6 (pethPsePortDetectionStatus) |
PD detection status of the PSE port. |
pethPsePortGroupIndex pethPsePortIndex |
INTEGER |
disabled(1), searching(2), deliveringPower(3), fault(4), test(5), otherFault(6) |
Recommended action
Check the PD connection and make sure the PD is connected correctly.
No action is required if the PD is disconnected or connected on purpose.
hh3cPOEDisconnectNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.2 |
PoE power supply disconnected. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a PoE power supply is disconnected.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.7.2.1.1 (hh3cPOEAlarmModuleInfoIndex) |
PoE power supply alarm information index. |
hh3cPOEAlarmModuleInfoIndex |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.2 (hh3cPOEModuleDisconnect) |
Disconnection alarm state of the PoE power supply. |
ModuleAlarmState |
normal (1), alarm (2) |
Recommended action
Check the power supply. Locate and resolve the issues.
hh3cPOEInputErrorNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.3 |
PoE power supply input error. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an input error occurs on a PoE power supply.
System impact
The PoE power supply cannot be used.
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.3 (hh3cPOEModuleInputError) |
Input error alarm of the PoE power supply. |
ModuleAlarmState |
Recommended action
Contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.4 |
PoE power supply output error. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an output error occurs on a PoE power supply.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.4 (hh3cPOEModuleOutputError) |
Output error alarm of the PoE power supply. |
ModuleAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.5 |
PoE power supply overvoltage. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an overvoltage occurs on a PoE power supply
System impact
The voltage of the PoE power supply is too high.
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.5 (hh3cPOEModuleOverVoltage) |
Overvoltage alarm of the PoE power supply. |
ModuleAlarmState |
Recommended action
hh3cPOEOverTempNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.6 |
PoE power supply overtemperature |
Informational |
Warning |
N/A |
ON |
This notification is generated when an overtemperature occurs on a PoE power supply.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.5 (hh3cPOEModuleOverTemp) |
Overtemperature alarm of the PoE power supply. |
ModuleAlarmState |
normal (1), alarm (2)." |
Recommended action
hh3cPOEFanErrorNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.7 |
PoE power supply fan error. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a fan error occurs on a PoE power supply.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.7 (hh3cPOEModuleFanError) |
Fan error alarm of the PoE power supply. |
ModuleAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.8 |
PoE power supply shut down. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a PoE power supply is shut down.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.8 (hh3cPOEModuleShutdown) |
PoE power supply shutdown alarm. |
ModuleAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.9 |
The current of the PoE power supply was limited. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the current of a PoE power supply is limited.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.9 (hh3cPOEModuleCurRestricted) |
PoE power supply current limited alarm. |
ModuleAlarmState |
Recommended action
hh3cPOEACSwitchNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.10 |
AC input switch alarm |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input switch alarm occurs on a PoE power supply.
System impact
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.5.2.1.1 (hh3cPOEACSwitchStateIndex) |
hh3cPOEACSwitchStateIndex |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.5.2.1.2 (hh3cPOEACSwitchState) |
AC input switch alarm of the PoE power supply. |
SwitchState |
on (1), off (2), highVoltInput (3), lowVoltInput (4) |
Recommended action
hh3cPOEACInCurANotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.11 |
AC input current A alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input current A alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.6.2 (hh3cPOEInCurAState) |
Current A state alarm in the input of the PoE power supply. |
hh3cPOEInCurStateModuleNum |
ACAlarmState |
normal (1), underLimit (2), aboveLimit (3), lackPhrase (4), fuseBroken (5), switchOff (6), otherError (7). |
Recommended action
hh3cPOEACInCurBNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.12 |
AC input current B alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input current B alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.6.3 (hh3cPOEInCurBState) |
Current B state alarm in the input of the PoE power supply. |
ACAlarmState |
Recommended action
hh3cPOEACInCurCNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.13 |
AC input current C state alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the AC input current C state alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.6.4 (hh3cPOEInCurCState) |
AC input current C alarm state of a PoE power supply. |
ACAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.14 |
AC input voltage AB state alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input voltage AB state alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.6.5.1.1 (hh3cPOESwitchStateVolExIndex) |
VOL status index. |
hh3cPOESwitchStateVolExIndex |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.6.5.1.2 (hh3cPOESwitchStateInVolAB) |
VOL AB alarm state in the VOL status. |
ACAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.15 |
AC input voltage BC state alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input voltage BC state alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VOL status index. |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.6.5.1.3 (hh3cPOESwitchStateInVolBC) |
VOL BC alarm state in the VOL status. |
ACAlarmState |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.16 |
AC input voltage CA state alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when an AC input voltage CA state alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
VOL status index. |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.6.5.1.3 (hh3cPOESwitchStateInVolCA) |
VOL CA alarm state in the VOL status. |
ACAlarmState |
Recommended action
hh3cPOEDCOutVolNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.17 |
DC output alarm. |
Informational |
Warning |
N/A |
ON |
This notification is generated when a DC output alarm occurs on a PoE power supply.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.3.2.1.1 (hh3cPOEDCOutStateIndex) |
hh3cPOEDCOutStateIndex |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.3.2.1.2 (hh3cPOEDCOutDCVolAlarm) |
DC output power alarm of the PoE power supply. |
DCAlarmState |
normal (1), underLimit (2), aboveLimit (3), fuseBroken (4), switchOff (5), otherError (6). |
Recommended action
hh3cPOEShutdownNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.18 |
Informational |
Warning |
N/A |
ON |
System impact
Status control
None.
Recommended action
None.
hh3cPOETrackNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.19 |
PD connected to a PoE port unreachable. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the PD connected to a PI cannot be reached.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.1.1.1.8 (hh3cPsePortTrackAction) |
Action taken when the state of the track entry associated with the PoE port changes from positive to negative. |
INTEGER |
none(0), alarm(1), alarmRebootPD(2) |
Recommended action
hh3cPOEPdClassInvalid
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.20 |
A PD of invalid class was detected. |
Informational |
Major |
N/A |
ON |
This notification is generated when a PD of invalid class is detected.
System impact
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
(1.3.6.1.4.1.25506.2.14.12) hh3cPOEPortName |
PI name. |
N/A |
DisplayString |
Recommended action
To resolve this issue, verify that the PD complies with the PoE standard.
hh3cPOEPdClassOvercurrent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.21 |
A PD of overcurrent class was detected |
Informational |
Major |
N/A |
ON |
This notification is generated when a PD of overcurrent class is detected.
System impact
Power supply to PDs might be affected.
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PI name. |
N/A |
DisplayString |
Recommended action
Disconnect the PD.
hh3cPOEPdPowerOvercurrent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.6.22 |
PD overcurrent occurred. |
Informational |
Major |
N/A |
ON |
This notification is generated when PD overcurrent occurs on a port.
System impact
Status control
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PI name. |
N/A |
DisplayString |
Recommended action
Disconnect the PD.
hh3cPsePDDisableNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.14.11.0.1 |
Power supply to a PD terminated. |
Informational |
Warning |
N/A |
ON |
This notification is generated when power supply to a PD is terminated.
System impact
N/A
Status control
None.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.14.8.7.2.1.1 (hh3cPsePortGroupIndex) |
PSE port group index. |
hh3cPseNotificationObjects |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.3 (hh3cPsePortIndex) |
PSE port index. |
Integer32 |
1.3.6.1.4.1.25506.2.14.8.7.2.1.3 (hh3cPsePortDisableInfo) |
Reason that caused failure of the PSE port to supply power. |
Hh3cPDDisableState |
unknown(0), overInrush(1), lessMPSCurrent(2), peakPower(3), overVoltage(4), underVoltage(5), overTemperature(6), shortCircuit(7). |
Recommended action
