- 04-Device Management
- 01-ENTITY-MIB
- 02-HH3C-COMMON-SYSTEM-MIB
- 03-HH3C-ENTITY-EXT-MIB
- 04-HH3C-ENTRELATION-MIB
- 05-HH3C-INFOCENTER-MIB
- 06-HH3C-LSW-DEV-ADM-MIB
- 07-HH3C-LswDEVM-MIB
- 08-HH3C-LswTRAP-MIB
- 09-HH3C-POWER-ETH-EXT-MIB
- 10-HH3C-RES-MON-MIB
- 11-HH3C-TRANSCEIVER-INFO-MIB
- 12-HH3C-TRAP-MIB
- 13-POWER-ETHERNET-MIB
- 14-SYSLOG-MSG-MIB
| 07-HH3C-LswDEVM-MIB | 85.18 KB |
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Scalar objects
hh3cdot1qTpFdbLearnStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qTpFdbLearnStatus (1.3.6.1.4.1.25506.8.35.9.1.10) |
read-write |
INTEGER |
enabled(1), |
Enablement status of MAC address learning. |
Implementation varies by product. |
hh3cDevMFirstTrapTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMFirstTrapTime (1.3.6.1.4.1.25506.8.35.9.1.13) |
accessible-for-notify |
TimeTicks |
Standard MIB values. |
Time when the first trap is sent. |
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cDevMFanNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1) |
read-only |
Integer32 |
Fan index. |
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2) |
read-only |
INTEGER |
active(1), |
Fan status. |
hh3cDevMFanPosFrame (1.3.6.1.4.1.25506.8.35.9.1.1.1.3) |
read-only |
Integer32 |
ID of the chassis where the fan resides. |
Not supported |
hh3cDevMFanPosSlot (1.3.6.1.4.1.25506.8.35.9.1.1.1.4) |
read-only |
Integer32 |
Slot number of the fan. |
hh3cDevMFanPosIndex (1.3.6.1.4.1.25506.8.35.9.1.1.1.5) |
read-only |
Integer32 |
Fan number. |
hh3cDevMFanMaxSpeed (1.3.6.1.4.1.25506.8.35.9.1.1.1.6) |
read-only |
Integer32 |
Maximum fan speed. |
Not supported |
hh3cDevMFanCurrentSpeed (1.3.6.1.4.1.25506.8.35.9.1.1.1.7) |
read-only |
Integer32 |
Current fan speed. |
Not supported |
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cDevMPowerNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1) |
read-only |
Integer32 |
Power supply index. |
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2) |
read-only |
INTEGER |
active(1), |
Power supply status. |
hh3cDevMPowerEntIndex (1.3.6.1.4.1.25506.8.35.9.1.2.1.3) |
read-only |
Integer32 |
Power module entity index. |
hh3cDevMPowerSupplyType (1.3.6.1.4.1.25506.8.35.9.1.2.1.9) |
read-only |
Integer32 |
AC(1), DC (2), HVDC(3) |
Power supply type. |
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1) |
not-accessible |
INTEGER |
temperature(1), |
Type of the environment elements. |
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2) |
read-only |
INTEGER |
normal(1), upper(2), lower(3) |
Status of the environment where the card resides. |
Not supported. |
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3) |
read-only |
Integer32 |
Environment data for the card. |
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4) |
read-write |
Integer32 |
Upper limit for the environment requirements. |
Not supported. |
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5) |
read-write |
Integer32 |
Lower limit for the environment requirements. |
Not supported. |
hh3cMemTable
About this table
This table contains memory information.
Create |
Edit/Modify |
Delete |
Read |
No |
No |
No |
Yes |
Columns
The table index is hh3cMemModuleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMemModuleIndex (1.3.6.1.4.1.25506.8.8.2.1.1.1) |
not-accessible |
Integer32 |
Table index. |
As per the MIB. |
hh3cMemSize (1.3.6.1.4.1.25506.8.8.2.1.1.2) |
read-only |
Gauge32 |
Total size of memory modules on the hosted object. |
As per the MIB. |
hh3cMemFree (1.3.6.1.4.1.25506.8.8.2.1.1.3) |
read-only |
Gauge32 |
Free memory size. |
As per the MIB. |
hh3cMemRawSliceUsed (1.3.6.1.4.1.25506.8.8.2.1.1.4) |
read-only |
Gauge32 |
Size of the raw memory that has been used. |
As per the MIB. |
hh3cMemLgFree (1.3.6.1.4.1.25506.8.8.2.1.1.5) |
read-only |
Gauge32 |
Maximum available size of a contiguous region in memory, in bytes. |
As per the MIB. |
hh3cMemFail (1.3.6.1.4.1.25506.8.8.2.1.1.6) |
read-only |
Gauge32 |
Number of memory allocation failures. |
As per the MIB. |
hh3cMemFailNoMem (1.3.6.1.4.1.25506.8.8.2.1.1.7) |
read-only |
Gauge32 |
Low memory limit for the card. |
As per the MIB. |
hh3cBufTable
About this table
This table contains buffer information.
Create |
Edit/Modify |
Delete |
Read |
No |
No |
No |
Yes |
Columns
The table indexes are hh3cBufModuleIndex and hh3cBufSize.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cBufModuleIndex (1.3.6.1.4.1.25506.8.8.2.2.1.1) |
not-accessible |
Integer32 |
Table index. |
As per the MIB. |
hh3cBufSize (1.3.6.1.4.1.25506.8.8.2.2.1.2) |
read-only |
Gauge32 |
Buffer size. |
As per the MIB. |
hh3cBufCurrentTotal (1.3.6.1.4.1.25506.8.8.2.2.1.3) |
read-only |
Gauge32 |
Total number of buffers. |
As per the MIB. |
hh3cBufCurrentUsed (1.3.6.1.4.1.25506.8.8.2.2.1.4) |
read-only |
Gauge32 |
Number of buffers in use/ |
As per the MIB. |
