04-Device Management
HomeSupportReference GuidesMIB CompanionH3C S9850-G&S6530X Switch Series MIB References-R8307Pxx-6W10004-Device Management
06-HH3C-LSW-DEV-ADM-MIB
06-HH3C-LSW-DEV-ADM-MIB 265.74 KB
About this MIB
Use this MIB to obtain basic device information about chassis, slots, CPUs, and ports.
MIB file name
hh3c-lsw-dev-adm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswDeviceAdmin(18)
Scalar objects
hh3cLswSysIpAddr
Object (OID)
Access
Value range
Implementation
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1)
read-only
IpAddress
Standard MIB values.
IP address of a VLAN interface.
As per the MIB.
hh3cLswSysIpMask
Object (OID)
Access
Value range
Implementation
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2)
read-only
IpAddress
Subnet mask for the system IP address.
As per the MIB.
hh3cLswSysCpuRatio
Object (OID)
Access
Value range
Implementation
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3)
read-only
Integer32
Integer32 (0..100)
Real-time CPU usage on the card in 1-minute intervals.
For distributed devices in IRF mode, this object indicates the real-time CPU usage on the active MPU in the system.
As per the MIB.
hh3cLswSysVersion
Object (OID)
Access
Value range
Implementation
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4)
read-only
DisplayString
OCTET STRING (1..64)
Version of the system.
For distributed devices in IRF mode, this object indicates the version of the active MPU in the system.
As per the MIB.
hh3cLswSysTime
Object (OID)
Access
Value range
Implementation
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5)
read-write
DateAndTime
OCTET STRING (8 | 11)
System time of the device.
For distributed devices in IRF mode, this object indicates the system time of the active MPU in the system.
Supports only the read operation on the non-default MDC.
hh3cLswSysUNMCastDropEnable
Object (OID)
Access
Value range
Implementation
hh3cLswSysUNMCastDropEnable (1.3.6.1.4.1.25506.8.35.18.1.6)
read-write
INTEGER
disable (0),
enable  (1)
Enable or disable the dropping of unknown multicast packets.
As per the MIB.
hh3cLswSysManagementVlan
Object (OID)
Access
Value range
Implementation
hh3cLswSysManagementVlan (1.3.6.1.4.1.25506.8.35.18.1.7)
read-write
INTEGER32
Integer32 (1..4094)
System management VLAN.
As per the MIB.
hh3cLswSysVlanRange
Object (OID)
Access
Value range
Implementation
hh3cLswSysVlanRange (1.3.6.1.4.1.25506.8.35.18.1.8)
read-write
DisplayString
(SIZE(1..10))
System VLAN range. If this VLAN range is specified, you must bind a management IP/mask.
As per the MIB.
hh3cLswSysManagementIpAddr
Object (OID)
Access
Value range
Implementation
hh3cLswSysManagementIpAddr (1.3.6.1.4.1.25506.8.35.18.1.9)
read-write
IpAddress
System IP address.
As per the MIB.
hh3cLswSysManagementIpMask
Object (OID)
Access
Value range
Implementation
hh3cLswSysManagementIpMask (1.3.6.1.4.1.25506.8.35.18.1.10)
read-write
IpAddress
Mask of the system IP address.
As per the MIB.
hh3cMacAddressCountPort
Object (OID)
Access
Value range
Implementation
hh3cMacAddressCountPort (1.3.6.1.4.1.25506.8.35.18.1.11)
read-write
Integer32
Number of MAC addresses supported on the port.
As per the MIB.
hh3cMacAddressCountMachine
Object (OID)
Access
Value range
Implementation
hh3cMacAddressCountMachine (1.3.6.1.4.1.25506.8.35.18.1.12)
read-only
Integer32
Number of MAC addresses supported on the device.
As per the MIB.
hh3cLswSysPhyMemory
Object (OID)
Access
Value range
Implementation
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Physical memory space of the device, in bytes.
For distributed devices, this object indicates the physical memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemory
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14)
read-only
Unsigned32
System memory space, in bytes.
For distributed devices, this object indicates the system memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryUsed
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15)
read-only
Unsigned32
Used system memory, in bytes.
For distributed devices, this object indicates the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryRatio
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used system memory on the device.
For distributed devices, this object indicates the percentage of the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysTemperature
Object (OID)
Access
Value range
Implementation
hh3cLswSysTemperature (1.3.6.1.4.1.25506.8.35.18.1.17)
read-only
Integer32
System temperature.
For a distributed device, this object indicates the temperature on the primary slot.
As per the MIB.
hh3cLswSysPhyMemRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18)
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19)
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemUsedRev
Object (OID)
Access
Value range
Implementation
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20)
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysSerialNumber
Object (OID)
Access
Value range
Implementation
hh3cLswSysSerialNumber (1.3.6.1.4.1.25506.8.35.18.1.21)
read-only
SnmpAdminString
OCTET STRING (0..32)
Device serial number.
As per the MIB.
hh3cLswSysTotalPower
Object (OID)
Access
Value range
Implementation
hh3cLswSysTotalPower (1.3.6.1.4.1.25506.8.35.18.1.22)
read-only
Unsigned32
Total power in the system, in watts. In IRF mode, the total power is the sum of power on all member devices. Value 0 is invalid.
As per the MIB.
hh3cSysProductName
Object (OID)
Access
Value range
Implementation
hh3cSysProductName(1.3.6.1.4.1.25506.8.35.18.1.23)
read-only
DisplayString
Device model.
For distributed devices in IRF mode, the value for this object is obtained from the active MPU in the system.
As per the MIB.
hh3cSysProductVersion
Object (OID)
Access
Value range
Implementation
hh3cSysProductVersion(1.3.6.1.4.1.25506.8.35.18.1.24)
read-only
DisplayString
Device version.
As per the MIB.
hh3cSysPatchPlatVersion
Object (OID)
Access
Value range
Implementation
hh3cSysPatchPlatVersion(1.3.6.1.4.1.25506.8.35.18.1.25)
read-only
DisplayString
System patch version.
As per the MIB.
Tabular objects
hh3cLswFrameTable
About this table
This table contains chassis-level information about devices.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLswFrameIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFrameIndex (1.3.6.1.4.1.25506.8.35.18.4.2.1.1)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Chassis index.
As per the MIB.
hh3cLswFrameType (1.3.6.1.4.1.25506.8.35.18.4.2.1.2)
read-only
Integer32
Chassis type.
Implementation varies by product.
hh3cLswFrameDesc (1.3.6.1.4.1.25506.8.35.18.4.2.1.3)
read-write
DisplayString
OCTET STRING (0..64)
Description of the chassis.
hh3cLswSlotNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.4)
read-only
Integer32
Number of slots in the current chassis.
As per the MIB.
hh3cLswFrameAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.2.1.5)
read-only
INTEGER
normal(1),
fault(2),
other(3)
Chassis status.
As per the MIB.
hh3cLswFrameSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.6)
read-only
SnmpAdminString
Serial number of the chassis.
As per the MIB.
hh3cLswFrameClassType (1.3.6.1.4.1.25506.8.35.18.4.2.1.9)
read-only
INTEGER
none(1),
lcc(2),
fcc(3)
Cluster type of the chassis.
As per the MIB.
hh3cLswFrameTotalPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.10)
read-only
Unsigned32
Total power in the chassis.
As per the MIB.
hh3cLswFrameNominalPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.11)
read-only
Unsigned32
Chassis power.
As per the MIB.
hh3cLswFramePowerRedundancyType (1.3.6.1.4.1.25506.8.35.18.4.2.1.12)
read-only
DisplayString
(SIZE(0..64))
Power redundancy type.
As per the MIB.
hh3cLswSlotTable
About this table
This table contains card information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSlotIndex (1.3.6.1.4.1.25506.8.35.18.4.3.1.1)
read-only
Integer32
Card index.
As per the MIB.
hh3cLswSlotType (1.3.6.1.4.1.25506.8.35.18.4.3.1.2)
read-only
Integer32
Card type.
hh3cLswSlotDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.3)
read-write
DisplayString
Description of the card.
hh3cLswSlotCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.4)
read-only
Integer32
CPU usage on the card.
As per the MIB.
hh3cLswSlotPcbVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.5)
read-only
DisplayString
Hardware version of the card.
As per the MIB.
hh3cLswSlotSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.6)
read-only
DisplayString
Software version of the card.
As per the MIB.
hh3cLswSubslotNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.7)
read-only
Integer32
Number of subcards.
As per the MIB.
hh3cLswSlotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.8)
read-only
INTEGER
not-install(1), normal(2), fault(3), forbidden(4)
Administrative status of the card.
As per the MIB.
hh3cLswSlotOperStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.9)
read-write
INTEGER
disable(1), enable(2), reset(3), test(4)
Operation status of the card.
Supports only reset.
hh3cLswSlotPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.10)
read-only
Unsigned32
Physical memory space of the card, in bytes.
The memory is a 32-bit wide memory.
As per the MIB.
hh3cLswSlotMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.11)
read-only
Unsigned32
System memory space of the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.3.1.12)
read-only
Unsigned32
Used system memory on the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.13)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the system used memory on the card, in bytes.
As per the MIB.
hh3cLswSlotTemperature (1.3.6.1.4.1.25506.8.35.18.4.3.1.14)
read-only
Integer32
Temperature of the card.
Not supported
hh3cLswSlotPktBufFree (1.3.6.1.4.1.25506.8.35.18.4.3.1.15)
read-only
Integer32
Number of free packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufInit (1.3.6.1.4.1.25506.8.35.18.4.3.1.16)
read-only
Integer32
Number of packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufMin (1.3.6.1.4.1.25506.8.35.18.4.3.1.17)
read-only
Integer32
Minimum number of packet buffers on the card.
As per the MIB.
hh3cLswSlotPktBufMiss (1.3.6.1.4.1.25506.8.35.18.4.3.1.18)
read-only
Counter64
Counter64 (0..18446744073709551615)
Packet loss counting in packet buffers on the card.
As per the MIB.
hh3cLswSlotRunTime (1.3.6.1.4.1.25506.8.35.18.4.3.1.19)
read-only
DisplayString
Running time of the card.
As per the MIB.
hh3cLswSlotPhyMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.20)
read-only
Counter64
The memory is a 64-bit wide memory.
As per the MIB.
hh3cLswSlotMemRev
 (1.3.6.1.4.1.25506.8.35.18.4.3.1.21)
read-only
Counter64
As per the MIB.
hh3cLswSlotMemUsedRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.22)
read-only
Counter64
As per the MIB.
hh3cLswSlotModelDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.23)
read-only
DisplayString
OCTET STRING (0..255)
Description of the extended module in the slot.
As per the MIB.
hh3cLswSlotPktBufThreshold (1.3.6.1.4.1.25506.8.35.18.4.3.1.24)
read-write
Integer32
Integer32 (1..100)
Packet buffer usage threshold on the card.
As per the MIB.
hh3cLswSlotSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.25)
read-only
SnmpAdminString
Serial number of the card.
As per the MIB.
hh3cSlotCurrentVoltage(1.3.6.1.4.1.25506.8.35.18.4.3.1.27)
read-only
DisplayString
Voltage of the card (V)
As per the MIB.
hh3cSlotCurrent(1.3.6.1.4.1.25506.8.35.18.4.3.1.28)
read-only
DisplayString
Current of the card (A)
As per the MIB.
hh3cLswSubslotTable
About this table
This table contains subcard information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswSubslotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSubslotIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.1)
read-only
Integer32
Subcard index.
As per the MIB.
hh3cLswSubslotType (1.3.6.1.4.1.25506.8.35.18.4.4.1.2)
read-only
Integer32
Subcard type.
hh3cLswSubslotPortNum (1.3.6.1.4.1.25506.8.35.18.4.4.1.3)
read-only
Integer32
Port number of the subcard.
As per the MIB.
hh3cLswSubslotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.4.1.4)
read-only
INTEGER
not-install(1),
normal(2),
fault(3),
forbidden(4)
Status of the subacard.
As per the MIB.
hh3cLswSubslotFirstIfIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.5)
read-only
Integer32
Index of the first physical port on the subcard.
Supports only Ethernet ports.
hh3cLswSubslotSerialNumber(1.3.6.1.4.1.25506.8.35.18.4.4.1.6)
read-only
SnmpAdminString
Serial number of the subcard.
As per the MIB.
hh3cLswPortTable
About this table
This table contains port information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table does not have indexes.
Object (OID)
Access
Value range
Implementation
hh3cLswPortLoopbackIsSupport (1.3.6.1.4.1.25506.8.35.18.4.6.1.1)
read-only
INTEGER
neither(1),
both(2),
internalOnly(3),
externalOnly(4)
Loopback types supported on the current port.
As per the MIB.
hh3cLswPortLoopbackOperate (1.3.6.1.4.1.25506.8.35.18.4.6.1.2)
read-write
INTEGER
stopRemoteOrLocalLoopBack(0),
internalLoopback(1),
externalLoopback(2),
remoteLoopback(3),
localLoopback(4)
Loopback operation types on the port. The read operation is not supported.
As per the MIB.
hh3cLswPortLoopbackResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.3)
read-only
INTEGER
testing (0),
testok (1),
testfailed (2)
The loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed.
As per the MIB.
hh3cLswPortLoopbackAutoStopSupport (1.3.6.1.4.1.25506.8.35.18.4.6.1.4)
read-only
INTEGER
support(1),
notSupport(2)
Whether the port supports the NEED-MMANUL-NOLOOP mode.
As per the MIB.
hh3cLswPortLoopbackRemoteResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.5)
read-write
INTEGER
loopbackTestInit(0),
loopbackTesting(1),
loopbackTestSuccessed (2),
loopbackTestFailed (3),
loopbackTestTestAndFailed (4)
The remote loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed.
As per the MIB.
hh3cLswPortLoopbackLocalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.6)
read-write
INTEGER
loopbackTesting(1),
The local loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed.
As per the MIB.
hh3cLswPortLoopbackInternalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.7)
read-write
INTEGER
loopbackTesting(1),
The internal loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed.
As per the MIB.
hh3cLswPortLoopbackExternalResult (1.3.6.1.4.1.25506.8.35.18.4.6.1.8)
read-write
INTEGER
loopbackTesting(1),
The external loopback test result of the port used to identify whether the test is successful. The query value on the node will be meaningful only after the test is performed.
As per the MIB.
hh3cLswPortLoopbackTable
About this table
This table contains information about loopback tests of a port.
Create
Edit/Modify
Delete
Read
No
No
No
Yes
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswPortIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.1)
read-only
Integer32
Port index.
As per the MIB.
hh3cLswPortType (1.3.6.1.4.1.25506.8.35.18.4.5.1.2)
read-only
Integer32
Port type.
hh3cLswPortIfIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.3)
read-only
Integer32
Index of the interface attached to the port.
As per the MIB.
Hh3cLswPortIsPlugged (1.3.6.1.4.1.25506.8.35.18.4.5.1.4)
read-only
INTEGER
unplugged(0),
plugged(1)
Connection status of the port.
As per the MIB.
hh3cLswFabricTable
About this table
This table contains fabric module channel information.
This table does not support the read operation only on the default MDC.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswFabricChannelIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFabricChannelIndex (1.3.6.1.4.1.25506.8.35.18.4.7.1.1)
not-accessible
Integer32
Channel index.
As per the MIB.
hh3cLswFabricUtilIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.2)
read-only
Integer32
Integer32 (0..100)
Ingress utilization of the channel.
As per the MIB.
hh3cLswFabricUtilOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.3)
read-only
Integer32
Integer32 (0..100)
Egress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakIn (1.3.6.1.4.1.25506.8.35.18.4.7.1.4)
read-only
Integer32
Integer32 (0..100)
Peak ingress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakInTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.5)
read-only
DateAndTime
Time at which peak ingress utilization of the channel is present.
As per the MIB.
hh3cLswFabricPeakOut (1.3.6.1.4.1.25506.8.35.18.4.7.1.6)
read-only
Integer32
Integer32 (0..100)
Peak egress utilization of the channel.
As per the MIB.
hh3cLswFabricPeakOutTime (1.3.6.1.4.1.25506.8.35.18.4.7.1.7)
read-only
DateAndTime
Time at which peak egress utilization of the channel is present.
As per the MIB.
hh3cLswExtendModelTable
About this table
This table contains extended module information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLswExtendModelIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswExtendModelIndex (1.3.6.1.4.1.25506.8.35.18.4.9.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Extended module index.
As per the MIB.
hh3cLswExtendModelDesc (1.3.6.1.4.1.25506.8.35.18.4.9.1.2)
read-only
DisplayString
Description of the Extended module.
As per the MIB.
hh3cLswCpuTable
About this table
This table contains CPU information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswCpuIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCpuIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.1)
not-accessible
PhysicalIndex
Integer32 (0..2147483647)
CPU index.
As per the MIB.
hh3cLswCpuEntityIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.2)
read-only
Integer32
Index of the CPU entity.
As per the MIB.
hh3cLswCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.3)
read-only
Unsigned32
Unsigned32 (0..100)
Real-time CPU usage on the host.
As per the MIB.
hh3cLswCpuSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.10.1.4)
read-only
DisplayString
CPU software version.
As per the MIB.
hh3cLswCpuAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.5)
read-only
INTEGER
notInstall(1),
normal(2),
fault(3),
forbidden(4)
CPU status.
As per the MIB.
hh3cLswCpuOperStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.6)
read-write
INTEGER
disable(1),
enable(2),
reset(3),
test(4)
Operation status of the CPU.
Supports reset only on the active CPU.
Supports the read operation only on the non-default MDC.
hh3cLswCpuPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.7)
read-only
Counter64
Physical memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.8)
read-only
Counter64
System memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.9)
read-only
Counter64
Used memory on the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.10)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used memory on the node.
As per the MIB.
hh3cLswCpuUsageMinorThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.11)
read-write
Unsigned32
Unsigned32 (1..99)
Minor CPU usage alarm threshold.
hh3cLswCpuUsageSevereThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.12)
read-write
Unsigned32
Unsigned32 (2..100)
Major CPU usage alarm threshold.
hh3cLswCpuUsageRecoverThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.13)
read-write
Unsigned32
Unsigned32 (0..98)
CPU usage recovery threshold.
hh3cLswCpuMemoryFree (1.3.6.1.4.1.25506.8.35.18.4.10.1.14)
read-only
CounterBasedGauge64
Free memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryFreeRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.15)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the free memory.
As per the MIB.
hh3cLswCpuMemoryHighTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.16)
read-only
CounterBasedGauge64
Total high memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryHighFree  (1.3.6.1.4.1.25506.8.35.18.4.10.1.17)
read-only
CounterBasedGauge64
Free high memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryLowTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.18)
read-only
CounterBasedGauge64
Total low memory size, in bytes.
As per the MIB.
hh3cLswCpuMemoryLowFree   (1.3.6.1.4.1.25506.8.35.18.4.10.1.19)
read-only
CounterBasedGauge64
Free low memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocTotal (1.3.6.1.4.1.25506.8.35.18.4.10.1.20)
read-only
CounterBasedGauge64
Total vmalloc memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.21)
read-only
CounterBasedGauge64
Used vmalloc memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryVmallocChunk (1.3.6.1.4.1.25506.8.35.18.4.10.1.22)
read-only
CounterBasedGauge64
Number of chunks for the vmalloc memory.
As per the MIB.
hh3cLswCpuMemoryCommitLimit (1.3.6.1.4.1.25506.8.35.18.4.10.1.23)
read-only
CounterBasedGauge64
Memory size that can be allocated to the system, in bytes.
As per the MIB.
hh3cLswCpuMemoryCommittedAs (1.3.6.1.4.1.25506.8.35.18.4.10.1.24)
read-only
CounterBasedGauge64
Committed_As memory, in bytes.
As per the MIB.
hh3cLswCpuMemoryThresholdUnit  (1.3.6.1.4.1.25506.8.35.18.4.10.1.25)
read-write
INTEGER
inMB(1),
inPercentage(2)
Unit of memory thresholds.
As per the MIB.
hh3cLswCpuMemorySecureThreshold  (1.3.6.1.4.1.25506.8.35.18.4.10.1.26)
read-write
Unsigned32
Sufficient-memory threshold for the memory.
As per the MIB.
hh3cLswCpuMemoryEarlyWarningThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.27)
read-write
Unsigned32
Early-warning threshold for the memory.
As per the MIB.
hh3cLswCpuMemoryNormalThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.28)
read-write
Unsigned32
Normal state threshold for the memory.
As per the MIB.
 hh3cLswCpuMemoryMinorThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.29)
read-write
Unsigned32
Minor memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemorySevereThreshold (1.3.6.1.4.1.25506.8.35.18.4.10.1.30)
read-write
Unsigned32
Major memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemoryCriticalThreshold  (1.3.6.1.4.1.25506.8.35.18.4.10.1.31)
read-write
Unsigned32
Critical memory alarm threshold.
As per the MIB.
 hh3cLswCpuMemoryCurrentState (1.3.6.1.4.1.25506.8.35.18.4.10.1.32)
read-only
INTEGER
secure(1),
earlywarning(2),
normal(3),
minor(4),
severe(5),
critical(6)
Current memory status.
As per the MIB.
hh3cLswPowerTable
About this table
This table contains power supply information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswPowerIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswPowerIndex (1.3.6.1.4.1.25506.8.35.18.4.11.1.1)
read-only
Integer32
Power supply index.
As per the MIB.
hh3cLswPowerSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.11.1.2)
read-only
SnmpAdminString
Serial number of the power supply.
As per the MIB.
hh3cLswFanTable
About this table
This table contains fan information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswFanIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFanIndex (1.3.6.1.4.1.25506.8.35.18.4.12.1.1)
read-only
Integer32
Fan index.
As per the MIB.
hh3cLswFanSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.12.1.2)
read-only
SnmpAdminString
Serial number of the fan.
As per the MIB.
hh3cLswTransceiverTable
About this table
This table contains transceiver module information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswTransceiverIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswTransceiverIndex (1.3.6.1.4.1.25506.8.35.18.4.13.1.1)
read-only
Integer32
Transceiver module index.
As per the MIB.
hh3cLswTransceiverSerialNumber (1.3.6.1.4.1.25506.8.35.18.4.13.1.2)
read-only
SnmpAdminString
Serial number of the transceiver module.
As per the MIB.
hh3cLswCoreTable
About this table
This table contains CPU core information.
Support for this table varies by product.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswCpuIndex, and hh3cLswCoreIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCoreIndex  (1.3.6.1.4.1.25506.8.35.18.4.15.1.1)
read-only
Integer32
CPU core index.
As per the MIB.
hh3cLswCoreUsageInLast5Sec (1.3.6.1.4.1.25506.8.35.18.4.15.1.2)
read-only
Unsigned32
CPU core usage in the most recent 5-second interval.
As per the MIB.
hh3cLswCoreUsageInLast1Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.3)
read-only
Unsigned32
CPU core usage in the most recent 1-minute interval.
As per the MIB.
hh3cLswCoreUsageInLast5Min (1.3.6.1.4.1.25506.8.35.18.4.15.1.4)
read-only
Unsigned32
CPU core usage in the most recent 5-minute interval.
As per the MIB.
hh3cLswCoreThreshold (1.3.6.1.4.1.25506.8.35.18.4.15.1.5)
read-write
Unsigned32
CPU core alarm threshold.
As per the MIB.
hh3cLswCoreState (1.3.6.1.4.1.25506.8.35.18.4.15.1.6)
read-only
INTEGER
normal(1),
warning(2)
CPU core status.
hh3cLswOutputPowerTable
About this table
This table contains power port status information.
Create
Edit/Modify
Delete
Read
No
No
No
Yes
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswOutputPowerPortID.
Object (OID)
Access
Value range
Implementation
hh3cLswOutputPowerPortID (1.3.6.1.4.1.25506.8.35.18.4.16.1.1)
read-only
Integer32
Integer32(1.. 2147483647)
Power port index.
As per the MIB.
hh3cLswOutputPowerStatus (1.3.6.1.4.1.25506.8.35.18.4.16.1.2)
read-only
INTEGER
disable(1),
normal(2)
open(3),
overvol(4)
undervol(5),
overcur(6)
overpower(7),
Power port status.
As per the MIB.
