08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
23-TCP-MIB
23-TCP-MIB 134.78 KB
TCP-MIB
About this MIB
This MIB is defined by RFC 4022. Use this MIB to obtain the TCP protocol parameters, TCP connection information, and TCP packet statistics.
MIB file name
rfc4022-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).tcp(6)
Scalar objects
tcpRtoAlgorithm (1.3.6.1.2.1.6.1)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
other(1),
constant(2),
rsre(3),
vanj(4)
Algorithm used to determine the timeout value for retransmitting unacknowledged octets.
As per the MIB.
tcpRtoMin (1.3.6.1.2.1.6.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (0..2147483647)
Minimum value, in milliseconds, for the TCP retransmission timeout.
As per the MIB.
tcpRtoMax (1.3.6.1.2.1.6.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Maximum value, in milliseconds, for the TCP retransmission timeout.
As per the MIB.
tcpMaxConn (1.3.6.1.2.1.6.4)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (-1 | 0..2147483647)
Maximum number of TCP connections that are supported.
In the maximum number is a dynamic value, this object take the "value–1".
As per the MIB.
tcpActiveOpens (1.3.6.1.2.1.6.5)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Standard MIB values.
Number of times that TCP connections have made a direct transition to the SYN-SENT state from the CLOSED state.
As per the MIB.
tcpPassiveOpens (1.3.6.1.2.1.6.6)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of times that TCP connections have made a direct transition to the SYN-RCVD state from the LISTEN state.
As per the MIB.
tcpAttemptFails (1.3.6.1.2.1.6.7)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Sum of the following number of times that TCP connections have made a direct transition:
Number of transitions to the CLOSED state from either the SYN-SENT state or the SYN-RCVD state.
Number of transitions to the LISTEN state from the SYN-RCVD state.
As per the MIB.
tcpEstabResets (1.3.6.1.2.1.6.8)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of times that TCP connections have made a direct transition to the CLOSED state from either the ESTABLISHED state or the CLOSE-WAIT state.
As per the MIB.
tcpCurrEstab (1.3.6.1.2.1.6.9)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Number of TCP connections for which the current state is either ESTABLISHED or CLOSE-WAIT.
As per the MIB.
tcpInSegs (1.3.6.1.2.1.6.10)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of segments received, including those received in error, and the segments received on established connections.
As per the MIB.
tcpOutSegs (1.3.6.1.2.1.6.11)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent segments, including those on current connections. The segments containing only retransmitted octets are not included.
As per the MIB.
tcpRetransSegs (1.3.6.1.2.1.6.12)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of segments retransmitted, that is, the number of transmitted TCP segments containing one or more previously transmitted octets.
As per the MIB.
tcpInErrs (1.3.6.1.2.1.6.14)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of segments received in error (for example, bad TCP checksums).
As per the MIB.
tcpOutRsts (1.3.6.1.2.1.6.15)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of sent TCP segments containing the RST flag.
As per the MIB.
tcpHCInSegs (1.3.6.1.2.1.6.17)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
64-bit equivalent of tcpInSegs.
Not supported
tcpHCOutSegs (1.3.6.1.2.1.6.18)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
64-bit equivalent of tcpOutSegs.
Not supported
Tabular objects
tcpConnTable
About this table
Use this table to obtain detailed IPv4 TCP connection information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are tcpConnLocalAddress, tcpConnLocalPort, tcpConnRemAddress, and tcpConnRemPort.
Object (OID)
Access
Value range
Implementation
tcpConnState (1.3.6.1.2.1.6.13.1.1)
read-write
INTEGER
closed(1),
listen(2),
synSent(3),
synReceived(4),
established(5),
finWait1(6),
finWait2(7),
closeWait(8),
lastAck(9),
closing(10),
timeWait(11),
deleteTCB(12)
TCP connection state.
The only value that a management station can set is deleteTCB(12).
If a management station tries to set the object to a value other than deleteTCB(12), the agent will return an error response.
If the object value is set to deleteTCB(12), TCB will be deleted and the corresponding TCP connection will be terminated.
Read only.
tcpConnLocalAddress (1.3.6.1.2.1.6.13.1.2)
read-only
IpAddress
Local IP address for the TCP connection. The value 0.0.0.0 indicates that the connection in the listen state can accept connections for any interface.
As per the MIB.
tcpConnLocalPort (1.3.6.1.2.1.6.13.1.3)
read-only
Integer32
Integer32 (0..65535)
Local port number of the TCP connection.
As per the MIB.
tcpConnRemAddress (1.3.6.1.2.1.6.13.1.4)
read-only
IpAddress
Remote IP address of the TCP connection.
As per the MIB.
tcpConnRemPort (1.3.6.1.2.1.6.13.1.5)
read-only
Integer32
Remote port number of the TCP connection.
As per the MIB.
tcpConnectionTable
About this table
Use this table to obtain TCP connection information. Different from tcpConnTable, information about the connections in the LISTEN state is stored in tcpListenTable.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are tcpConnectionLocalAddressType, tcpConnectionLocalAddress, tcpConnectionLocalPort, tcpConnectionRemAddressType, tcpConnectionRemAddress, and tcpConnectionRemPort.
Object (OID)
Access
Value range
Implementation
tcpConnectionLocalAddressType (1.3.6.1.2.1.6.19.1.1)
not-accessible
InetAddressType
Address type of tcpConnectionLocalAddress.
Only supports ipv4(1) and ipv6 (2).
tcpConnectionLocalAddress (1.3.6.1.2.1.6.19.1.2)
not-accessible
InetAddress
Local IP address of the TCP connection.
As per the MIB.
tcpConnectionLocalPort (1.3.6.1.2.1.6.19.1.3)
not-accessible
InetPortNumber
As per the MIB.
tcpConnectionRemAddressType (1.3.6.1.2.1.6.19.1.4)
not-accessible
InetAddressType
Address type of tcpConnectionRemAddress.
Supports only ipv4(1) and ipv6 (2).
tcpConnectionRemAddress (1.3.6.1.2.1.6.19.1.5)
not-accessible
InetAddress
As per the MIB.
tcpConnectionRemPort (1.3.6.1.2.1.6.19.1.6)
not-accessible
InetPortNumber
As per the MIB.
tcpConnectionState (1.3.6.1.2.1.6.19.1.7)
read-write
INTEGER
closed(1),
listen(2),
synSent(3),
synReceived(4),
established(5),
finWait1(6),
finWait2(7),
closeWait(8),
lastAck(9),
closing(10),
timeWait(11),
deleteTCB(12)
Read only.
tcpConnectionProcess (1.3.6.1.2.1.6.19.1.8)
read-only
Unsigned32
System's process ID for the process associated with this connection. The value is 0 if no such process exists.
As per the MIB.
tcpListenerTable
About this table
Use this table to obtain the TCP listener information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are tcpListenerLocalAddressType, tcpListenerLocalAddress, and tcpListenerLocalPort.
Object (OID)
Access
Value range
Implementation
tcpListenerLocalAddressType (1.3.6.1.2.1.6.20.1.1)
not-accessible
InetAddressType
Address type of tcpListenerLocalAddress.
The value unknown(0) indicates that the listener accepts connection initiations to all local IP addresses.
tcpListenerLocalAddress (1.3.6.1.2.1.6.20.1.2)
not-accessible
InetAddress
As per the MIB.
tcpListenerLocalPort (1.3.6.1.2.1.6.20.1.3)
not-accessible
InetPortNumber
As per the MIB.
tcpListenerProcess (1.3.6.1.2.1.6.20.1.4)
read-only
Unsigned32
As per the MIB.
