08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
12-HH3C-IPV6-ADDRESS-MIB
12-HH3C-IPV6-ADDRESS-MIB 97.47 KB
About this MIB
Use this MIB to obtain and configure IPv6 addresses.
MIB file name
hh3c-ipv6-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpv6AddrMIB(71)
Scalar objects
hh3cIpv6AddrSetProEnableIfName
(1.3.6.1.4.1.25506.2.71.1.2.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING (0..255)
Interface name.
As per the MIB.
hh3cIpv6AddrSetProEnableChassis
(1.3.6.1.4.1.25506.2.71.1.2.1.2)
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32(0..65535)
Chassis number.
As per the MIB.
hh3cIpv6AddrSetProEnableSlot (1.3.6.1.4.1.25506.2.71.1.2.1.3)
Object (OID)
Access
Value range
Implementation
Unsigned32
Slot number.
As per the MIB.
Tabular objects
hh3cIpv6AddrSetTable
About this table
This table configures an IPv6 addresses.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cIpv6AddrSetIfIndex, hh3cIpv6AddrSetAddrType, and hh3cIpv6AddrSetAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpv6AddrSetIfIndex (1.3.6.1.4.1.25506.2.71.1.1.1.1.1)
not-accessible
Integer32
Integer32 (1..2147483)
Interface index.
As per the MIB.
hh3cIpv6AddrSetAddrType (1.3.6.1.4.1.25506.2.71.1.1.1.1.2)
not-accessible
InetAddressType
ipv6(2)
IP address version.
As per the MIB.
hh3cIpv6AddrSetAddr (1.3.6.1.4.1.25506.2.71.1.1.1.1.3)
not-accessible
InetAddress
IP address.
As per the MIB.
hh3cIpv6AddrSetPfxLength (1.3.6.1.4.1.25506.2.71.1.1.1.1.4)
read-create
Integer32
Integer32 (1..128)
IPv6 address subnet prefix length.
As per the MIB.
hh3cIpv6AddrSetSourceType (1.3.6.1.4.1.25506.2.71.1.1.1.1.5)
read-create
INTEGER
assignedIp(1)
assignedEUI64Ip(2)
assignedLinklocalIp(3)
Source type of the IPv6 address.
As per the MIB.
hh3cIpv6AddrSetRowStatus (1.3.6.1.4.1.25506.2.71.1.1.1.1.6)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Create a new row or delete an existing row.
As per the MIB.
hh3cIpv6AddrReadTable
About this table
This table displays IPv6 addresses.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cIpv6AddrReadIfIndex, hh3cIpv6AddrReadAddrType, and hh3cIpv6AddrReadAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpv6AddrReadIfIndex (1.3.6.1.4.1.25506.2.71.1.1.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Interface index.
As per the MIB.
hh3cIpv6AddrReadAddrType (1.3.6.1.4.1.25506.2.71.1.1.2.1.2)
not-accessible
InetAddressType
ipv6(2)
IP address version.
As per the MIB.
hh3cIpv6AddrReadAddr (1.3.6.1.4.1.25506.2.71.1.1.2.1.3)
not-accessible
InetAddress
IPv6 address.
As per the MIB.
hh3cIpv6AddrReadPfxLength (1.3.6.1.4.1.25506.2.71.1.1.2.1.4)
read-only
Integer32
Integer32 (1..128)
IPv6 address prefix length.
As per the MIB.
hh3cIpv6AddrReadSourceType (1.3.6.1.4.1.25506.2.71.1.1.2.1.5)
read-only
INTEGER
assignedIp(1)
assignedEUI64Ip(2),
assignedAutoIp(3)
autoIp(4)
dhcpv6(5)
negotiate(6)
cluster(7)
As per the MIB.
hh3cIpv6AddrReadCatalog (1.3.6.1.4.1.25506.2.71.1.1.2.1.6)
read-only
INTEGER
nodelocal(1)
linklocal(2)
sitelocal(3)
orglocal(4)
global(5)
Type of the IPv6 address.
As per the MIB.
Notifications
hh3cIpv6AddrSetProEnableFailed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.71.1.2.0.1
IPv6 enabling failed.
Informational
Major
N/A (N/A)
ON
Notification triggers
This notification is generated when IPv6 fails to be enabled on an interface due to insufficient system resources.
System impact
IPv6 services are unavailable on the interface.
Status control
ON
CLI: snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
OFF
CLI: undo snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.71.1.2.1.1 (hh3cIpv6AddrSetProEnableIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.71.1.2.1.2 (hh3cIpv6AddrSetProEnableChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.71.1.2.1.3 (hh3cIpv6AddrSetProEnableSlot)
Slot number.
N/A
Unsigned32
Recommended action
To resolve the issue:
1.Use the display ipv6 interface command to view IPv6 information on all interfaces.
2.Based on network planning and service deployment, examine whether IPv6 is not required on some interfaces enabled with IPv6.
  - If such interfaces do not exist, proceed to step 3.
  - If such interfaces exist, use the undo ipv6 address command to delete all IPv6 addresses of the interfaces. Then, try to configure an IPv6 address for the target interface for which the notification is generated.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
