08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
10-HH3C-IP-ADDRESS-MIB
10-HH3C-IP-ADDRESS-MIB 107.05 KB
HH3C-IP-ADDRESS-MIB
About this MIB
Use this MIB to obtain and configure IPv4 addresses.
MIB file name
hh3c-ip-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpAddrMIB(67)
Scalar objects
hh3cIpAddrNotifyIfIndex (1.3.6.1.4.1.25506.2.67.2.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
Integer32 (1..2147483647)
Interface index.
As per the MIB.
hh3cIpAddrOldIpAddress (1.3.6.1.4.1.25506.2.67.2.1.2)
Object (OID)
Access
Value range
Implementation
InetAddress
OCTET STRING (0..255)
Old IP address.
As per the MIB.
hh3cIpAddrNewIpAddress (1.3.6.1.4.1.25506.2.67.2.1.3)
Object (OID)
Access
Value range
Implementation
InetAddress
New IP address.
As per the MIB.
hh3cIpAddrFirstTrapTime (1.3.6.1.4.1.25506.2.67.2.1.4)
Object (OID)
Access
Value range
Implementation
TimeTicks
TimeTicks (04294967295)
Time when the first SNMP notification was sent.
As per the MIB.
Tabular objects
hh3cIpAddrSetTable
About this table
Use this table to configure IPv4 addresses.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cIpAddrSetIfIndex, hh3cIpAddrSetAddrType, and hh3cIpAddrSetAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpAddrSetIfIndex (1.3.6.1.4.1.25506.2.67.1.1.1.1.1)
not-accessible
Integer32
Interface index.
As per the MIB.
hh3cIpAddrSetAddrType (1.3.6.1.4.1.25506.2.67.1.1.1.1.2)
not-accessible
InetAddressType
ipv4(1)
IP address version.
Only support ipv4(1)
hh3cIpAddrSetAddr (1.3.6.1.4.1.25506.2.67.1.1.1.1.3)
not-accessible
InetAddress
IP address.
As per the MIB.
hh3cIpAddrSetMask (1.3.6.1.4.1.25506.2.67.1.1.1.1.4)
read-create
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpAddrSetSourceType (1.3.6.1.4.1.25506.2.67.1.1.1.1.5)
read-create
INTEGER
assignedIp(1)
Source type of the IPv4 address.
As per the MIB.
hh3cIpAddrSetCatalog (1.3.6.1.4.1.25506.2.67.1.1.1.1.6)
read-create
INTEGER
primary(1),
sub(2)
Type of the IPv4 address.
As per the MIB.
hh3cIpAddrSetRowStatus (1.3.6.1.4.1.25506.2.67.1.1.1.1.7)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status of the IPv4 address.
Support active(1), createAndGo(4), and destroy(6) The value active(1) is read only.
hh3cIpAddrReadTable
About this table
Use this table to obtain IPv4 addresses.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cIpAddrReadIfIndex, hh3cIpAddrReadAddrType, hh3cIpAddrReadAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpAddrReadIfIndex (1.3.6.1.4.1.25506.2.67.1.1.2.1.1)
not-accessible
Integer32
Interface index.
As per the MIB.
hh3cIpAddrReadAddrType (1.3.6.1.4.1.25506.2.67.1.1.2.1.2)
not-accessible
InetAddressType
ipv4(1)
IP address version.
Only support ipv4(1).
hh3cIpAddrReadAddr (1.3.6.1.4.1.25506.2.67.1.1.2.1.3)
not-accessible
InetAddress
IP address.
As per the MIB.
hh3cIpAddrReadMask (1.3.6.1.4.1.25506.2.67.1.1.2.1.4)
read-only
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpAddrReadSourceType (1.3.6.1.4.1.25506.2.67.1.1.2.1.5)
read-only
INTEGER
assignedIp(1), cluster(2), dhcp(3), bootp(4), negotiate(5), unnumbered(6), vrrp(7),cellar(8),mad(9)
As per the MIB.
hh3cIpAddrReadCatalog (1.3.6.1.4.1.25506.2.67.1.1.2.1.6)
read-only
INTEGER
primary(1), sub(2), cluster(3), vrrp(4),backup(5)
As per the MIB.
hh3cIpv4AddrTable
About this table
Use this table to configure the primary IPv4 address of an interface.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cIpv4AddrAddr
(1.3.6.1.4.1.25506.2.67.1.1.3.1.1)
read-create
IpAddress
OCTET STRING (4)
IP address.
If the interface has no primary or secondary IP address, the value is 0.0.0.0.
hh3cIpv4AddrMask
(1.3.6.1.4.1.25506.2.67.1.1.3.1.2)
read-create
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpv4AddrRowStatus
(1.3.6.1.4.1.25506.2.67.1.1.3.1.3)
read-create
RowStatus
active(1) ,
notInService(2) ,
createAndGo(4) ,
destroy(6)
Row status of the address configuration.
Support active(1), notInService(2), createAndGo(4), and destroy(6).
If the interface has primary or secondary IP address, the value is active(1).
If the interface has no primary or secondary IP address, the value is notInService(2).
Notifications
hh3cIpAddressChangeNotify
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.67.2.2.0.1
Address change.
Informational
Warning
ON
Notification triggers
This notification is generated when no FIB entry deployment failure occurs within 60 minutes.
System impact
OID
Event
Severity
Default status
Address change.
Informational
Warning
ON
This notification is generated when the IP address of an interface changes.
System impact
The IP address of an interface changes, which might cause service interruption.
Status control
The SNMP notification for IP address change cannot be disabled.
Object
OID (object name)
Index
Value range
Interface index.
N/A
Integer32
Previous IP address.
N/A
InetAddress
New IP address.
N/A
InetAddress
N/A
TimeTicks
Recommended action
Use the display ip interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief ] command to view the interface IP address and verify that the IP address change is as expected. If the IP address is changed unexpectedly, correct the error in time to avoid service interruption.
