08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
15-HH3C-SESSION-MIB
15-HH3C-SESSION-MIB 351.28 KB
HH3C-SESSION-MIB
About this MIB
Use this MIB to configure session modules and obtain session messages.
MIB file name
hh3c-session.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSession(149)
Scalar objects
(hh3cSessionDrvNum) 1.3.6.1.4.1.25506.2.149.1.3.1.1
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Unsigned32
Standard MIB values.
Maximum number of sessions supported by hardware.
As per the MIB.
(hh3cSessionChassis) 1.3.6.1.4.1.25506.2.149.1.3.1.2
Object (OID)
Access
Value range
Implementation
Unsigned32
(0..65534)
Chassis number.
As per the MIB.
(hh3cSessionSlot) 1.3.6.1.4.1.25506.2.149.1.3.1.3
Object (OID)
Access
Value range
Implementation
Unsigned32
(0..65534)
Slot number.
As per the MIB.
(hh3cSessionCpu) 1.3.6.1.4.1.25506.2.149.1.3.1.4
Object (OID)
Access
Value range
Implementation
Unsigned32
(0..7)
CPU number.
As per the MIB.
(hh3cSessionUsage) 1.3.6.1.4.1.25506.2.149.1.3.1.5
Object (OID)
Access
Value range
Implementation
Unsigned32
(0..100)
Usage of hardware session resources.
As per the MIB.
(hh3cSessionThreshold) 1.3.6.1.4.1.25506.2.149.1.3.1.6
Object (OID)
Access
Value range
Implementation
Unsigned32
(60..90)
Resource usage threshold.
As per the MIB.
(hh3cSessionTrapUser) 1.3.6.1.4.1.25506.2.149.1.4.1.6
Object (OID)
Access
Value range
Implementation
OCTET STRING
IOCTET STRING (0..256)
Virtual username that sends the notification.
As per the MIB.
Tabular objects
hh3cSessionStatTable
About this table
Use this table to obtain session statistics.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cSessionStatChassis, hh3cSessionStatSlot, and hh3cSessionStatCPUID.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.149.1.1.1.1)
not-accessible
Unsigned32
0..65534
IRF member ID.
As per the MIB.
hh3cSessionStatSlot
(1.3.6.1.4.1.25506.2.149.1.1.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
(1.3.6.1.4.1.25506.2.149.1.1.1.3)
not-accessible
Unsigned32
0..7
CPU ID.
As per the MIB.
hh3cSessionStatCount
(1.3.6.1.4.1.25506.2.149.1.1.1.4)
read-only
Unsigned32
Total number of sessions.
As per the MIB.
hh3cSessionStatCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.5)
read-only
Unsigned32
Number of sessions created per second.
As per the MIB.
hh3cSessionStatTCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.6)
read-only
Unsigned32
Number of TCP sessions.
As per the MIB.
hh3cSessionStatUDPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.7)
read-only
Unsigned32
Number of UDP sessions.
As per the MIB.
hh3cSessionStatOtherCount
(1.3.6.1.4.1.25506.2.149.1.1.1.8)
read-only
Unsigned32
Number of sessions other than TCP and UDP sessions.
As per the MIB.
hh3cSessionStatTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.9)
read-only
Unsigned32
Number of TCP sessions created per second.
As per the MIB.
hh3cSessionStatUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.10)
read-only
Unsigned32
Number of UDP sessions created per second.
As per the MIB.
hh3cSessionStatOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.11)
read-only
Unsigned32
Number of non-TCP and non-UDP sessions created per second.
As per the MIB.
hh3cSessionStatTCPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.12)
read-only
Counter64
Total number of TCP sessions created till now.
As per the MIB.
hh3cSessionStatUDPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.13)
read-only
Counter64
Total number of UDP sessions created till now.
As per the MIB.
hh3cSessionStatOtherTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.14)
read-only
Counter64
Total number of non-TCP and non-UDP sessions created till now.
As per the MIB.
hh3cSessionStatDNSCount
(1.3.6.1.4.1.25506.2.149.1.1.1.15)
read-only
Unsigned32
Total number of DNS sessions created till now.
As per the MIB.
hh3cSessionStatFTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.16)
read-only
Unsigned32
Total number of FTP sessions created till now.
As per the MIB.
hh3cSessionStatGTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.17)
read-only
Unsigned32
Total number of GTP sessions created till now.
As per the MIB.
hh3cSessionStatH323Count
(1.3.6.1.4.1.25506.2.149.1.1.1.18)
read-only
Unsigned32
Total number of H323 sessions created till now.
As per the MIB.
hh3cSessionStatHTTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.19)
read-only
Unsigned32
Total number of HTTP sessions created till now.
As per the MIB.
hh3cSessionStatILSCount
(1.3.6.1.4.1.25506.2.149.1.1.1.20)
read-only
Unsigned32
Total number of ILS sessions created till now.
As per the MIB.
hh3cSessionStatMGCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.21)
read-only
Unsigned32
Total number of MGCP sessions created till now.
As per the MIB.
hh3cSessionStatNBTCount
(1.3.6.1.4.1.25506.2.149.1.1.1.22)
read-only
Unsigned32
Total number of NBT sessions created till now.
As per the MIB.
hh3cSessionStatPPTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.23)
read-only
Unsigned32
Total number of PPTP sessions created till now.
As per the MIB.
hh3cSessionStatRSHCount
(1.3.6.1.4.1.25506.2.149.1.1.1.24)
read-only
Unsigned32
Total number of RSH sessions created till now
As per the MIB.
hh3cSessionStatRTSPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.25)
read-only
Unsigned32
Total number of RTSP sessions created till now.
As per the MIB.
hh3cSessionStatSCCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.26)
read-only
Unsigned32
Total number of SCCP sessions created till now.
As per the MIB.
hh3cSessionStatSIPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.27)
read-only
Unsigned32
Total number of SIP sessions created till now.
As per the MIB.
hh3cSessionStatSMTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.28)
read-only
Unsigned32
Total number of SMTP sessions created till now.
As per the MIB.
hh3cSessionStatSQLNETCount
(1.3.6.1.4.1.25506.2.149.1.1.1.29)
read-only
Unsigned32
Total number of SQLNET sessions created till now.
As per the MIB.
hh3cSessionStatSSHCount
(1.3.6.1.4.1.25506.2.149.1.1.1.30)
read-only
Unsigned32
Total number of SSH sessions created till now.
As per the MIB.
hh3cSessionStatTELNETCount
(1.3.6.1.4.1.25506.2.149.1.1.1.31)
read-only
Unsigned32
Total number of TELNET sessions created till now.
As per the MIB.
hh3cSessionStatTFTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.32)
read-only
Unsigned32
Total number of TFTP sessions created till now.
As per the MIB.
hh3cSessionStatXDMCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.33)
read-only
Unsigned32
Total number of XDMCP sessions created till now.
As per the MIB.
hh3cSessionEntTable
About this table
Use this table to obtain statistics about sessions by entity.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cSessionEntIndex.
Object (OID)
Access
Value range
Implementation
hh3cSessionEntCount
(1.3.6.1.4.1.25506.2.149.1.2.1.2)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.3)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.4)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.5)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCount
(1.3.6.1.4.1.25506.2.149.1.2.1.6)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.7)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.8)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.9)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.10)
read-only
Counter64
As per the MIB.
hh3cSessionEntUDPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.11)
read-only
Counter64
As per the MIB.
hh3cSessionEntOtherTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.12)
read-only
Counter64
As per the MIB.
hh3cSessionAllStatTable
About this table
Use this table to obtain session statistics of all modules on the device.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cSessionAllIndex.
Object (OID)
Access
Value range
Implementation
hh3cSessionAllIndex
(1.3.6.1.4.1.25506.2.149.2.1.1.1)
not-accessible
Unsigned32
0..2147483647
Device index
As per the MIB.
hh3cSessionAllStatCount
(1.3.6.1.4.1.25506.2.149.2.1.1.2)
read-only
Unsigned32
Total number of sessions created by all modules on the device.
As per the MIB.
hh3cSessionAllStatCreateRate
(1.3.6.1.4.1.25506.2.149.2.1.1.3)
read-only
Unsigned32
Number of sessions created by all modules on the device per second.
As per the MIB.
Notifications
hh3cSessionDrvMaxTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.149.1.3.0.1
Hardware session resource exhaustion.
Error
Major
1.3.6.1.4.1.25506.2.149.1.3.0.2 (hh3cSessionDrvRecoveryTrap)
OFF
Notification triggers
This notification is generated when the number of sessions reaches the limit.
System impact
Sessions created by the CGN device cannot be forwarded by hardware. If too many sessions are created, the CPU usage might increase obviously.
Status control
ON
CLI: Use the snmp-agent trap enable session resource command.
OFF
CLI: Use the undo snmp-agent trap enable session resource command.
Object
OID (object name)
Index
Value range
 (hh3cSessionDrvNum)
No
Unsigned32
Chassis number.
Yes
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
Yes
Unsigned32
(0..65534)
1.3.6.1.4.1.25506.2.149.1.3.1.4 (hh3cSessionCpu)
CPU number.
Yes
Unsigned32
(0..7)
Recommended action
To resolve this issue:
1.Execute the display session table { ipv4 | ipv6 } command to verify whether the number of sessions on the device has reached the upper limit.
  - If the number of sessions has reached the upper limit, expand the device storage capacity to store more sessions. Check whether the alarm is removed. If the issue persists, go to step 2.
  - If the number of session does not reach the upper limit, go to step 2.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Number of sessions drops below the limit.
Recovery
Major
N/A (N/A)
OFF
This notification is generated if the number of sessions drops below the limit supported by hardware.
System impact
No impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
No action is required.
hh3cSessionThdMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.3.0.3
High hardware session resource usage.
Error
Major
1.3.6.1.4.1.25506.2.149.1.3.0.4 (hh3cSessionThdRecoveryTrap)
OFF
This notification is generated if the hardware session resource usage exceeds the alarm threshold.
System impact
No impact is generated on services upon the triggering of the notification. With the session creation continuing, if the number of sessions reaches the upper limit, the newly created sessions cannot be forwarded by hardware and too many sessions might increase the CPU usage obviously.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (hh3cSessionUsage)
Hardware session resource usage.
N/A
Unsigned32
(0..100)
Alarm threshold.
N/A
Unsigned32
(60..90)
1.3.6.1.4.1.25506.2.149.1.3.1.2 (hh3cSessionChassis)
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
1.Execute the display session table { ipv4 | ipv6 } command to verify whether the hardware session resource usage exceeds the alarm threshold.
  - If the hardware session resource usage exceeds the alarm threshold, go to step 2.
  - If the hardware session resource usage does not exceed the alarm threshold, go to step 3.
2.Execute the session alarm usage threshold command to increase the alarm threshold or expand the device storage capacity, and then check whether the alarm is removed. If the issue persists, go to step 3.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The hardware session resource usage drops below 87.5% of the alarm threshold.
Recovery
Major
N/A (N/A)
OFF
This notification is generated if the hardware session resource usage drops below 87.5% of the alarm threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (hh3cSessionUsage)
N/A
Unsigned32
(0..100)
Alarm threshold.
N/A
Unsigned32
(60..90)
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
hh3cSessUsageAbruptAlarmTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.1
The session table usage change reaches the alarm threshold.
Informational
Warning
N/A (N/A)
OFF
If alarms are enabled for abrupt session table usage changes, the system collects the session table usage at an interval of 10 seconds. This notification is generated when the system detects abrupt increase or drop in the session table usage and the session table usage change reaches the corresponding alarm threshold.
System impact
If attacks cause abrupt increase or drop in the session table usage, the device load might become too heavy and normal services might not be forwarded correctly.
Status control
ON
CLI: session alarm usage-abrupt enable
OFF
CLI: undo session alarm usage-abrupt enable
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.149.1.4.1.1 (hh3cSessionUsageAbruptVar)
Session table usage change rate.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.149.1.4.1.4 (hh3cSessionLastStat)
Last collection statistics.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.149.1.4.1.5 (hh3cSessionCurrentStat)
Current collection statistics.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.149.1.4.1.6 (hh3cSessionTrapChassis)
Chassis number.
1.3.6.1.4.1.25506.2.149.1.4.1.6 (hh3cSessionTrapChassis), 1.3.6.1.4.1.25506.2.149.1.4.1.7 (hh3cSessionTrapSlot), 1.3.6.1.4.1.25506.2.149.1.4.1.8 (hh3cSessionTrapCpu), 1.3.6.1.4.1.25506.2.149.1.4.1.9 (hh3cSessionTrapFlag)
Unsigned32
(0..65534)
Slot number.
Unsigned32
(0..65534)
CPU number.
Unsigned32
(0..7)
Abrupt change flag.
Unsigned32
Recommended action
1.If abrupt increase is detected in the session table usage, execute the display session table { ipv4 | ipv6 } command to verify whether sessions of abnormal services exist.
  - If no abnormal service session exists, the new sessions are normal service sessions and no action is required.
  - If abnormal service sessions exist, configure a protection policy to prevent the device from attacks as a best practice.
2.If abrupt drop is detected in the session table usage, verify whether the current service connections are interrupted.
  - If no current service connection is interrupted, no action is required.
  - If a current service connection is interrupted, verify whether the device link is disconnected. If the issue persists, go to step 3.
hh3cSessRateAbruptAlarmTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.2
The session creation rate change reaches the alarm threshold.
Informational
Warning
N/A (N/A)
OFF
If alarms are enabled for abrupt session creation rate changes, the system collects the session creation rate at an interval of 10 seconds. This notification is generated when the system detects abrupt increase or drop in the session creation rate and the session creation rate change reaches the corresponding alarm threshold.
System impact
If attacks cause abrupt increase or drop in the session creation rate, the device load might become too heavy and normal services might not be forwarded correctly.
Status control
ON
CLI: session alarm rate-abrupt enable
OFF
CLI: undo session alarm rate-abrupt enable
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.149.1.4.1.2 (hh3cSessionRateAbruptVar)
Session creation rate change rate.
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
Chassis number.
Unsigned32
(0..65534)
Slot number.
Unsigned32
(0..65534)
CPU number.
Unsigned32
(0..7)
Abrupt change flag.
Unsigned32
Recommended action
1.If abrupt increase is detected in the session creation rate, execute the display session table { ipv4 | ipv6 } command to verify whether sessions of abnormal services exist.
2.If abrupt drop is detected in the session creation rate, verify whether the current service connections are interrupted.
hh3cSessTryRateAbruptAlarmTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.3
The session creation attempt rate change reaches the alarm threshold.
Informational
Warning
N/A (N/A)
OFF
If alarms are enabled for abrupt session attempt rate changes, the system collects the session creation attempt rate at an interval of 10 seconds. This notification is generated when the system detects abrupt increase or drop in the session creation attempt rate and the session creation attempt rate reaches the corresponding alarm threshold.
System impact
If attacks cause abrupt increase or drop in the session creation attempt rate, the device load might become too heavy and normal services might not be forwarded correctly.
Status control
ON
CLI: session alarm try-rate-abrupt enable
OFF
CLI: undo session alarm try-rate-abrupt enable
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.149.1.4.1.3 (hh3cSessionTryRateAbruptVar)
Session creation attempt rate change rate.
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
Chassis number.
Unsigned32
(0..65534)
Slot number.
Unsigned32
(0..65534)
CPU number.
Unsigned32
(0..7)
Abrupt change flag.
Unsigned32
Recommended action
1.If abrupt increase is detected in the session creation attempt rate, execute the display session statistics command to verify whether the session creation rate is far lower than the session creation attempt rate.
  - If the session creation rate is far lower than the session creation attempt rate, use the session fast-drop enable command to enable deny sessions. If the issue persists, go to step 4.
  - If the session creation rate is little lower than the session creation attempt rate, go to step 2.
2.Execute the display session table { ipv4 | ipv6 } command to verify whether sessions of abnormal services exist.
  - If abnormal service sessions exist, configure protection policy to prevent the device from attacks as a best practice.
3.If abrupt drop is detected in the session creation attempt rate, verify whether the current service connections are interrupted.
4.Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cSessSpecMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.4
The number of sessions reaches the upper limit.
Informational
Critical
N/A (N/A)
OFF
This notification is generated when the number of sessions on the device reaches the upper limit.
System impact
The device cannot create new sessions and the new service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionChassis), 1.3.6.1.4.1.25506.2.149.1.3.1.3
(hh3cSessionSlot), 1.3.6.1.4.1.25506.2.149.1.3.1.4
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.Configure IRF or add switching fabric modules to expand the device capacity to store more sessions. Verify whether the alarm is removed.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cSessSpecOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.5
The session table usage exceeds the configured threshold.
Informational
Minor
N/A (N/A)
OFF
This notification is generated when the session table usage reaches the configured threshold.
System impact
The number of concurrent sessions on the device is too great. If the device continues creating sessions and the number of sessions reaches the upper limit, the device stops creating sessions and the new service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.If the configured threshold is too low, execute the session usage threshold threshold-value command to increase the alarm threshold. If the threshold is reasonable, execute the display session table { ipv4 | ipv6 } command to verify whether sessions of abnormal services exist.
  - If no abnormal service session exists, the new sessions are normal service sessions. Go to step 2.
2.Configure IRF or add switching fabric modules to expand the device capacity to support more sessions. Verify whether the alarm is removed. If the issue persists, go to step 3.
hh3cSessSpecBelowTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.6
Session table usage drops below the configured threshold.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the session table usage drops below the configured threshold.
System impact
N/A
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
hh3cSessAlgSpecMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.7
The number of relation entries reaches the upper limit.
Informational
Critical
N/A (N/A)
OFF
This notification is generated when the number of relation entries reaches the upper limit.
System impact
The device cannot create new relation entries and the new relation entry traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.Configure IRF or add switching fabric modules to expand the device capacity to store more relation entries. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessAlgSpecOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.8
The session relation table usage exceeds the configured threshold.
Informational
Minor
N/A (N/A)
OFF
This notification is generated when the session relation table usage exceeds the configured threshold.
System impact
The number of concurrent relation entries on the device is too great. If the device continues creating relation entries and the number of relation entries reaches the upper limit, the device stops creating relation entries and the new service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.If the configured threshold is low, execute the session usage threshold threshold-value command to increase the threshold. If the threshold is reasonable, execute the display session table { ipv4 | ipv6 } command to verify whether sessions of abnormal services exist.
2.Configure IRF or add switching fabric modules to expand the device capacity to store more sessions. Verify whether the alarm is removed. If the issue persists, go to step 3.
hh3cSessAlgSpecBelowTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.9
The session relation table usage drops below the configured threshold.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the session relation table usage drops below the configured threshold.
System impact
N/A
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
hh3cSessDenySpecMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.10
The number of deny sessions reaches the upper limit.
Informational
Critical
N/A (N/A)
OFF
This notification is generated when the number of deny sessions reaches the upper limit.
System impact
The device cannot create new deny sessions to fast drop packets. Packet drop is performed by service modules, which might degrade the device performance and affect other services.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.Execute the session fast-drop resource-ratio command to increase the ratio of deny sessions to all sessions. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessDenySpecOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.11
The deny session table usage exceeds the configured threshold.
Informational
Minor
N/A (N/A)
OFF
This notification is generated when the deny session table usage exceeds the configured threshold.
System impact
The number of deny session entries on the device is too great. If the device continues creating deny sessions and the number of deny session entries reaches the upper limit, the device stops creating deny sessions. In this case, packet drop is performed by service modules, which might degrade the device performance and affect other services.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
1.Execute the session fast-drop-usage threshold command to increase the alarm threshold or the session fast-drop resource-ratio command to increase the ratio of deny sessions to all sessions. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessDenySpecBelowTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.12
The deny session table usage drops below the configured threshold.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when the deny session table usage drops below the configured threshold.
System impact
N/A
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Recommended action
hh3cSessCapabilityMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.13
The number of concurrent sessions reaches the configured threshold on the context or vSystem.
Informational
Major
N/A (N/A)
OFF
This notification is generated when the number of sessions reaches the configured threshold on the context or vSystem.
System impact
The context or vSystem can no longer create new sessions and the new service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
1.3.6.1.4.1.25506.2.149.1.4.1.6 (hh3cSessionTrapUser)
N/A
OCTET STRING
Recommended action
1.Execute the capability session maximum command to set the maximum number of concurrent sessions for the context or vSystem. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessCapabilityOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.14
The session table usage exceeds the configured threshold on a context or vSystem.
Informational
Minor
N/A (N/A)
OFF
This notification is generated when the session table usage exceeds the configured threshold on a context or vSystem.
System impact
The number of concurrent sessions on the context or vSystem is too great. If the context or vSystem continues creating sessions and the number of session reaches the upper limit, the context or vSystem stops creating new sessions and the new service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
Virtual username that send the alarm.
N/A
OCTET STRING
Recommended action
1.If the configured threshold is too low, execute the capability session maximum threshold command to increase the threshold, or the capability session maximum command to set the maximum number of concurrent sessions for the context or vSystem. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessCapabilityBelowTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.15
The session table usage drops below the configured threshold on the context or vSystem.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the session table usage drops below the configured threshold on the context or vSystem.
System impact
N/A
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
OCTET STRING
Recommended action
hh3cSessCapabilityRateMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.16
The session creation rate reaches the upper limit on the context or vSystem.
Informational
Critical
N/A (N/A)
OFF
This notification is generated when the session creation rate reaches the upper limit on the context or vSystem.
System impact
The context or vSystem cannot establish new sessions when the limit is reached and part of service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
N/A
OCTET STRING
Recommended action
1.Execute the capability session rate command to set a higher limit of the session creation rate for a context or vSystem. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessCapabilityRateOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.17
The session creation rate usage exceeds the configured threshold on the context or vSystem.
Informational
Minor
N/A (N/A)
OFF
This notification is generated when the session creation rate usage exceeds the configured threshold on the context or vSystem.
System impact
The current session creation rate of the context or vSystem is too high. If the context or vSystem continues creating sessions and the number of sessions reaches the upper limit, new sessions cannot be created and part of service traffic cannot be forwarded.
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
N/A
OCTET STRING
Recommended action
1.If the configured threshold is too low, execute the capability session rate threshold command to change the threshold, or execute the capability session rate command to configure a higher session creation rate limit. Verify whether the alarm is removed. If the issue persists, go to step 2.
hh3cSessCapabilityRateBelowTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.4.0.18
The session creation rate usage drops below the configured threshold on the context or vSystem.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the session creation rate usage drops below the configured threshold on the context or vSystem.
System impact
N/A
Status control
N/A
Object
OID (object name)
Index
Value range
Chassis number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
(hh3cSessionCpu)
Unsigned32
(0..65534)
 (hh3cSessionCpu)
CPU number.
(hh3cSessionCpu)
Unsigned32
(0..7)
N/A
OCTET STRING
Recommended action
