08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
07-HH3C-DHCP4-MIB
07-HH3C-DHCP4-MIB 567.45 KB
HH3C-DHCP4-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1) 1
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2) 1
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3) 1
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4) 2
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5) 2
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6) 2
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7) 2
hh3cDhcpServer2AllocThreshold· 3
(1.3.6.1.4.1.25506.2.122.1.1.8) 3
hh3cDhcpServer2BadNum (1.3.6.1.4.1.25506.2.122.1.2.1) 3
hh3cDhcpServer2BootpRequestNum (1.3.6.1.4.1.25506.2.122.1.2.2) 3
hh3cDhcpServer2DiscoverNum (1.3.6.1.4.1.25506.2.122.1.2.3) 3
hh3cDhcpServer2RequestNum (1.3.6.1.4.1.25506.2.122.1.2.4) 4
hh3cDhcpServer2DeclineNum (1.3.6.1.4.1.25506.2.122.1.2.5) 4
hh3cDhcpServer2ReleaseNum (1.3.6.1.4.1.25506.2.122.1.2.6) 4
hh3cDhcpServer2InformNum·· 4
(1.3.6.1.4.1.25506.2.122.1.2.7) 4
hh3cDhcpServer2BootpReplyNum·· 5
(1.3.6.1.4.1.25506.2.122.1.2.8) 5
hh3cDhcpServer2OfferNum·· 5
(1.3.6.1.4.1.25506.2.122.1.2.9) 5
hh3cDhcpServer2AckNum·· 5
(1.3.6.1.4.1.25506.2.122.1.2.10) 5
hh3cDhcpServer2NakNum·· 5
(1.3.6.1.4.1.25506.2.122.1.2.11) 5
hh3cDhcpServer2TotalPoolUsage· 6
(1.3.6.1.4.1.25506.2.122.1.2.12) 6
hh3cDhcpServer2PoolNumber 6
(1.3.6.1.4.1.25506.2.122.1.2.13) 6
h3cDhcpServer2ConflictNum (1.3.6.1.4.1.25506.2.122.1.2.14) 6
hh3cDhcpServer2AutoBindNum·· 6
(1.3.6.1.4.1.25506.2.122.1.2.15) 6
hh3cDhcpServer2ManualBindNum·· 7
(1.3.6.1.4.1.25506.2.122.1.2.16) 7
hh3cDhcpServer2ExpiredBindNum·· 7
(1.3.6.1.4.1.25506.2.122.1.2.17) 7
hh3cDhcpServer2ReqCnt 7
(1.3.6.1.4.1.25506.2.122.1.2.18) 7
hh3cDhcpServer2ReqSuccCnt 7
(1.3.6.1.4.1.25506.2.122.1.2.19) 7
hh3cDhcpServer2IPTotalNum·· 8
(1.3.6.1.4.1.25506.2.122.1.2.20) 8
hh3cDhcpServer2IPUsedNum·· 8
(1.3.6.1.4.1.25506.2.122.1.2.21) 8
hh3cDhcpServer2IPIdleNum·· 8
(1.3.6.1.4.1.25506.2.122.1.2.22) 8
hh3cDhcpSever2IPExcludeTotalNum·· 8
(1.3.6.1.4.1.25506.2.122.1.2.23) 8
hh3cDhcpServer2OnlineFailReason (1.3.6.1.4.1.25506.2.122.1.2.24) 9
Tabular objects· 9
hh3cDhcpServer2PoolTable· 9
hh3cDhcpServer2IfApplyPoolTable· 12
hh3cDhcpServer2PoolSecNwTable· 12
hh3cDhcpServer2PoolClassTable· 13
hh3cDhcpServer2PoolStaticTable· 14
hh3cDhcpServer2PoolOptionTable· 14
hh3cDhcpServer2PoolForbidTable· 15
hh3cDhcpServer2ClassTable· 16
hh3cDhcpServer2RuleTable· 16
hh3cDhcpServer2ForbidTable· 17
hh3cDhcpServer2FreeTable· 18
hh3cDhcpServer2ConflictTable· 19
hh3cDhcpServer2ExpiredTable· 19
hh3cDhcpServer2IPInUseTable· 20
hh3cDhcpServer2DefOptGrpTable· 21
hh3cDhcpServer2ValidClassTable· 22
hh3cDhcpServer2RuleHwAddrTable· 22
hh3cDhcpServer2OptionGroupTable· 23
hh3cDhcpServer2OptionTable· 24
hh3cDhcpServer2PoolStatTable· 24
hh3cDhcpServer2PoolGpTable· 26
hh3cDhcpServer2PoolGpExtTable· 27
hh3cDhcpServer2PoolGpStatTable· 27
hh3cDhcpRelay2ConfigGroup· 29
hh3cDhcpRelay2StatisticsGroup· 30
hh3cDhcpRelay2IfConfigTable· 31
hh3cDhcpRelay2SrvAddrTable· 33
hh3cDhcpRelay2UserInfoTable· 33
Notifications· 34
hh3cDhcpServer2AddrExhaust 34
hh3cDhcpServer2AddrExhaustRecov· 35
hh3cDhcpServer2IpUsageOverflow· 36
hh3cDhcpServer2AllocOverflow· 37
hh3cDhcpServer2IpUsageOverflowRecov· 38
hh3cDhcpServer2NetUsageOverflow· 39
hh3cDhcpServer2NetUsageOverflowRecov· 40
hh3cDhcpServer2NetExhaust 41
hh3cDhcpServer2GpNetExhaust 41
hh3cDhcpServer2GpNetExhaustRecov· 42
hh3cDhcpSvr2AllocIpFailed· 43
hh3cDhcpSvr2GpAddrExhaus· 44
hh3cDhcpSvr2GpAddrExhaustRecov· 45
hh3cDhcpServer2DevOdapFull 46
hh3cDhcpServer2OdapApplyFail 47
hh3cDhcpServer2OdapReleaseFail 48
hh3cDhcpSvr2GpUsageOverflow· 48
hh3cDhcpSvr2GpUsageOverflowRecov· 50
hh3cDhcpSvr2UserIpConflict 50
HH3C-DHCP4-MIB
About this MIB
Use this MIB to configure DHCP, obtain DHCP address allocation information, and configure alarm settings.
MIB file name
hh3c-dhcp4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4(122)
Scalar objects
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Enabling status of the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to enable the DHCP server to broadcast responses.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to ignore BOOTP requests.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to enable the sending of BOOTP responses in RFC 1048 format.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to enable the DHCP server to handle Option 82.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32(0..10)
Maximum number of attempts that the DHCP server pings an IP address before assigning the IP address to a DHCP client.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32(0..10000)
Ping response timeout time for the DHCP server to ping an IP address.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32(0..100)
IP address allocation success rate threshold. The success rate is the rate of successfully allocated IP addresses to received DHCP requests within a specific time period.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of error packets received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of BOOTP-REQUEST messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-DISCOVER messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-REQUEST messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-DECLINE messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-RELEASE messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-INFORM messages received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of BOOTP-REPLY messages sent by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-OFFER messages sent by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-ACK messages sent by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of DHCP-NAK messages sent by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32(0..100)
DHCP address pool usage.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Standard MIB values.
Number of DHCP address pools.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Total number of conflicting IP addresses on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of dynamic DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of static DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of expired DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of address requests received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of address requests that the DHCP server processed successfully.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Total number of IP addresses in all DHCP address pools on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of assigned IP addresses on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of free IP addresses on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Number of IP addresses excluded from dynamic address allocation on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
Reason for the DHCP server online failure.
As per the MIB.
Tabular objects
About this table
This table records the address pool configuration on a DHCP server.
Support for operations
CreateSupported. When you create a new address pool, this table automatically creates an instance for the pool.
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is h3cDhcpServer2PoolIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolIndex (1.3.6.1.4.1.25506.2.122.2.1.1.1)
Unsigned32
DHCP address pool index.
Implementation varies by product.
hh3cDhcpServer2PoolName (1.3.6.1.4.1.25506.2.122.2.1.1.2)
read-create
OCTET STRING
OCTET STRING (1..63)
DHCP address pool name.
As per the MIB.
hh3cDhcpServer2PoolVpnName (1.3.6.1.4.1.25506.2.122.2.1.1.3)
read-create
OCTET STRING
OCTET STRING (0..31)
VPN to which the DHCP address pool is bound.
As per the MIB.
hh3cDhcpServer2PoolNetwork (1.3.6.1.4.1.25506.2.122.2.1.1.4)
read-create
InetAddressIPv4
OCTET STRING (4)
Primary network address of the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolNetworkMask (1.3.6.1.4.1.25506.2.122.2.1.1.5)
read-create
InetAddressIPv4
OCTET STRING (4)
Mask for the primary network address.
As per the MIB.
hh3cDhcpServer2PoolStartAddr (1.3.6.1.4.1.25506.2.122.2.1.1.6)
read-create
InetAddressIPv4
OCTET STRING (4)
Start IP address of an IP address range in the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolEndAddr (1.3.6.1.4.1.25506.2.122.2.1.1.7)
read-create
InetAddressIPv4
OCTET STRING (4)
End IP address of an IP address range in the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolLeaseDay (1.3.6.1.4.1.25506.2.122.2.1.1.8)
read-create
Integer32
Integer32(0..365)
Lease duration in days.
As per the MIB.
hh3cDhcpServer2PoolLeaseHour (1.3.6.1.4.1.25506.2.122.2.1.1.9)
read-create
Integer32
Integer32 (0..23)
Lease duration in hours.
As per the MIB.
hh3cDhcpServer2PoolLeaseMinute (1.3.6.1.4.1.25506.2.122.2.1.1.10)
read-create
Integer32
Integer32 (0..59)
Lease duration in minutes.
As per the MIB.
hh3cDhcpServer2PoolLeaseSecond (1.3.6.1.4.1.25506.2.122.2.1.1.11)
read-create
Integer32
Integer32 (0..59)
Lease duration in seconds.
As per the MIB.
hh3cDhcpServer2PoolLeaseUnlimit (1.3.6.1.4.1.25506.2.122.2.1.1.12)
read-create
TruthValue
true(1),
false(2)
Whether the lease duration is unlimited.
As per the MIB.
hh3cDhcpServer2PoolLeaseTime (1.3.6.1.4.1.25506.2.122.2.1.1.13)
read-create
TimeTicks
DHCP lease time in TimeTicks
As per the MIB.
hh3cDhcpServer2PoolDomainName (1.3.6.1.4.1.25506.2.122.2.1.1.14)
read-create
OCTET STRING
Domain name assigned to DHCP clients.
As per the MIB.
hh3cDhcpServer2PoolGatewayIP (1.3.6.1.4.1.25506.2.122.2.1.1.15)
read-create
OCTET STRING
OCTET STRING (0..127)
Gateway IP address.
As per the MIB.
hh3cDhcpServer2PoolDNSIP(1.3.6.1.4.1.25506.2.122.2.1.1.16)
read-create
OCTET STRING
DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolPrimaryDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.17)
read-create
InetAddressIPv4
OCTET STRING (4)
Primary DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolSecondDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.18)
read-create
InetAddressIPv4
OCTET STRING (4)
Secondary DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolNetbiosType (1.3.6.1.4.1.25506.2.122.2.1.1.19)
read-create
INTEGER
null(0), bnode(1), pnode(2), mnode(4), hnode(8)
NETBIOS node type.
As per the MIB.
hh3cDhcpServer2PoolNbnsIP(1.3.6.1.4.1.25506.2.122.2.1.1.20)
read-create
OCTET STRING
SIZE(0..127)
NETBIOS server IP address.
As per the MIB.
hh3cDhcpServer2PoolBootFileName (1.3.6.1.4.1.25506.2.122.2.1.1.21)
read-create
OCTET STRING
SIZE(0..63)
Name of a configuration file to be assigned to DHCP clients.
As per the MIB.
hh3cDhcpServer2PoolBimsIP(1.3.6.1.4.1.25506.2.122.2.1.1.22)
read-create
InetAddressIPv4
OCTET STRING (4)
BIMS server IP address.
As per the MIB.
hh3cDhcpServer2PoolBimsPort (1.3.6.1.4.1.25506.2.122.2.1.1.23)
read-create
Unsigned32
Unsigned32(0..65534)
BIMS server port number.
As per the MIB.
hh3cDhcpServer2PoolBimsKeyStr (1.3.6.1.4.1.25506.2.122.2.1.1.24)
read-create
OCTET STRING
OCTET STRING (0..16)
Shared key for the DHCP clients to encrypt packets sent to the BIMS server.
Does not support GET.
hh3cDhcpServer2PoolNextServer (1.3.6.1.4.1.25506.2.122.2.1.1.25)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the next DHCP server.
As per the MIB.
hh3cDhcpServer2PoolTftpDomName (1.3.6.1.4.1.25506.2.122.2.1.1.26)
read-create
OCTET STRING
OCTET STRING (0..63)
TFTP server domain name.
As per the MIB.
hh3cDhcpServer2PoolTftpIP (1.3.6.1.4.1.25506.2.122.2.1.1.27)
read-create
InetAddressIPv4
OCTET STRING (4)
TFTP server IP address.
As per the MIB.
hh3cDhcpServer2PoolVoiceAsIP (1.3.6.1.4.1.25506.2.122.2.1.1.28)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the backup network calling processor.
As per the MIB.
hh3cDhcpServer2PoolVoiceFailIP (1.3.6.1.4.1.25506.2.122.2.1.1.29)
read-create
InetAddressIPv4
OCTET STRING (4)
Failover IP address.
As per the MIB.
hh3cDhcpServer2PoolVoiceFailStr (1.3.6.1.4.1.25506.2.122.2.1.1.30)
read-create
OCTET STRING
OCTET STRING (0..39)
Failover dialer string.
As per the MIB.
hh3cDhcpServer2PoolVoiceNCPIP (1.3.6.1.4.1.25506.2.122.2.1.1.31)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the primary network calling processor.
As per the MIB.
hh3cDhcpServer2PoolVoiceVlanId (1.3.6.1.4.1.25506.2.122.2.1.1.32)
read-create
Unsigned32
Unsigned32(2..4094|65535)
Voice VLAN ID.
As per the MIB.
hh3cDhcpServer2PoolVoiceVlanEnbl (1.3.6.1.4.1.25506.2.122.2.1.1.33)
read-create
TruthValue
true(1),
false(2)
Enabling status of the voice VLAN.
As per the MIB.
hh3cDhcpServer2PoolRowStatus (1.3.6.1.4.1.25506.2.122.2.1.1.34)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
hh3cDhcpServer2PoolVerifyClass(1.3.6.1.4.1.25506.2.122.2.1.1.35)
read-create
TruthValue
true(1),
false(2)
Enabling status of the user class whitelist.
As per the MIB.
hh3cDhcpServer2PoolThreshold
(1.3.6.1.4.1.25506.2.122.2.1.1.36)
read-create
Unsigned32
Unsigned32(0..100)
IP address usage threshold for the address pool.
As per the MIB.
About this table
This table records the address pool bound to an interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2IfApplyPoolName (1.3.6.1.4.1.25506.2.122.2.2.1.1)
read-write
OCTET STRING
Name of the address pool bound to an interface.
As per the MIB.
About this table
This table records the secondary network configuration in the DHCP address pool.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex, h3cDhcpServer2PoolSecNw, and h3cDhcpServer2PoolSecNwMask.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolSecNw(1.3.6.1.4.1.25506.2.122.2.3.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Secondary network IP address.
As per the MIB.
hh3cDhcpServer2PoolSecNwMask (1.3.6.1.4.1.25506.2.122.2.3.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Mask of the secondary network IP address.
As per the MIB.
hh3cDhcpServer2PoolSecNwGwIP (1.3.6.1.4.1.25506.2.122.2.3.1.3)
read-create
OCTET STRING
Gateway IP address for the secondary network.
As per the MIB.
hh3cDhcpServer2PoolSecNwStatus (1.3.6.1.4.1.25506.2.122.2.3.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records address ranges for DHCP user classes in a DHCP address pool on a DHCP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolClassName (1.3.6.1.4.1.25506.2.122.2.4.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2PoolClassStart (1.3.6.1.4.1.25506.2.122.2.4.1.2)
read-create
InetAddressIPv4
OCTET STRING (4)
Start IP address of an address range for a DHCP user class.
As per the MIB.
hh3cDhcpServer2PoolClassEnd
(1.3.6.1.4.1.25506.2.122.2.4.1.3)
read-create
InetAddressIPv4
OCTET STRING (4)
End IP address of an address range for a DHCP user class.
As per the MIB.
hh3cDhcpServer2PoolClassStatus (1.3.6.1.4.1.25506.2.122.2.4.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records static bindings in a DHCP address pool.
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolStaticIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolStaticIP (1.3.6.1.4.1.25506.2.122.2.5.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
IP address in a static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticMask (1.3.6.1.4.1.25506.2.122.2.5.1.2)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address mask in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticCID (1.3.6.1.4.1.25506.2.122.2.5.1.3)
read-create
OCTET STRING
OCTET STRING (0|4..254)
Client identifier in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticHAddr
(1.3.6.1.4.1.25506.2.122.2.5.1.4)
read-create
OCTET STRING
OCTET STRING (0|4..39)
Hardware address in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticHType
(1.3.6.1.4.1.25506.2.122.2.5.1.5)
read-create
INTEGER
default(1), ethernet(2), tokenRing(3)
Hardware address type.
As per the MIB.
hh3cDhcpServer2PoolStaticStatus (1.3.6.1.4.1.25506.2.122.2.5.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records user-defined options in the DHCP address pool.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolOptCode.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolOptCode (1.3.6.1.4.1.25506.2.122.2.6.1.1)
not-accessible
Integer32
Integer32(2..254), excluding 50..54, 56, 58, 59, 61, 82.
Option code.
As per the MIB.
hh3cDhcpServer2PoolOptType (1.3.6.1.4.1.25506.2.122.2.6.1.2)
read-create
INTEGER
ascii(1), hex(2), ip(3)
Option type.
As per the MIB.
hh3cDhcpServer2PoolOptAscii (1.3.6.1.4.1.25506.2.122.2.6.1.3)
read-create
OCTET STRING
OCTET STRING (0..255)
ASCII string as the option content.
As per the MIB.
hh3cDhcpServer2PoolOptHexStr (1.3.6.1.4.1.25506.2.122.2.6.1.4)
read-create
OCTET STRING
OCTET STRING (0..510)
Hexadecimal number as the option content.
The string length cannot exceed 256.
hh3cDhcpServer2PoolOptIPStr (1.3.6.1.4.1.25506.2.122.2.6.1.5)
read-create
OCTET STRING
IP address as the option content.
As per the MIB.
hh3cDhcpServer2PoolOptRowStatus (1.3.6.1.4.1.25506.2.122.2.6.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records excluded IP addresses in a DHCP address pool.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolForbidIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolForbidIP (1.3.6.1.4.1.25506.2.122.2.7.1.1)
not-accessible
InetAddressIPv4
IP address excluded from dynamic allocation.
As per the MIB.
hh3cDhcpServer2PoolForbidStatus (1.3.6.1.4.1.25506.2.122.2.7.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP user class information.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is h3cDhcpServer2ClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ClassName (1.3.6.1.4.1.25506.2.122.2.8.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2ClassRowStatus (1.3.6.1.4.1.25506.2.122.2.8.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP user class match rules.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleNumber.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2RuleNumber
(1.3.6.1.4.1.25506.2.122.2.9.1.1)
not-accessible
Integer32
Integer32(1..16)
Rule ID.
As per the MIB.
hh3cDhcpServer2RuleOptCode (1.3.6.1.4.1.25506.2.122.2.9.1.2)
read-create
Integer32
Integer32(1..254)
Option code.
As per the MIB.
hh3cDhcpServer2RuleOptHexStr (1.3.6.1.4.1.25506.2.122.2.9.1.3)
read-create
OCTET STRING
Content to match specific options in packets.
The length of the content cannot exceed 256.
hh3cDhcpServer2RuleOptMask (1.3.6.1.4.1.25506.2.122.2.9.1.4)
read-create
OCTET STRING
Hexadecimal mask for the match operation.
If it is bound to hh3cDhcpServer2RuleOptHexStr, the entire command length cannot exceed 512.
hh3cDhcpServer2RuleOptOffset (1.3.6.1.4.1.25506.2.122.2.9.1.5)
read-create
Integer32
Integer32(0..254)
Offset in bytes after which the match operation starts
As per the MIB.
hh3cDhcpServer2RuleOptLength (1.3.6.1.4.1.25506.2.122.2.9.1.6)
read-create
Integer32
Integer32(0..255)
Length of the option content to be matched.
As per the MIB.
hh3cDhcpServer2RuleRowStatus (1.3.6.1.4.1.25506.2.122.2.9.1.7)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records excluded IP address ranges.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2ForbidVpnName, h3cDhcpServer2ForbidStart, and h3cDhcpServer2ForbidEnd.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ForbidVpnName (1.3.6.1.4.1.25506.2.122.2.10.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..31)
Name of the VPN to which the excluded IP address belongs.
As per the MIB.
hh3cDhcpServer2ForbidStart (1.3.6.1.4.1.25506.2.122.2.10.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Start IP address of the excluded IP address range.
As per the MIB.
hh3cDhcpServer2ForbidEnd (1.3.6.1.4.1.25506.2.122.2.10.1.3)
not-accessible
InetAddressIPv4
OCTET STRING (4)
End IP address of the excluded IP address range.
As per the MIB.
hh3cDhcpServer2ForbidRowStatus (1.3.6.1.4.1.25506.2.122.2.10.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records free IP address ranges on a DHCP server.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2FreeStart.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2FreeStart (1.3.6.1.4.1.25506.2.122.2.11.1.1)
not-accessible
InetAddressIPv4
Start IP address of a free IP address range.
As per the MIB.
hh3cDhcpServer2FreeEnd (1.3.6.1.4.1.25506.2.122.2.11.1.2)
read-only
InetAddressIPv4
End IP address of a free IP address range.
As per the MIB.
About this table
This table records conflicting IP addresses on a DHCP server.
CreateNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ConflictIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ConflictIP (1.3.6.1.4.1.25506.2.122.2.12.1.1)
not-accessible
InetAddressIPv4
Conflicting IP address.
As per the MIB.
hh3cDhcpServer2ConflictType (1.3.6.1.4.1.25506.2.122.2.12.1.2)
read-only
INTEGER
detectByServer(1), detectByClient(2)
Conflict type.
As per the MIB.
hh3cDhcpServer2ConflictTime (1.3.6.1.4.1.25506.2.122.2.12.1.3)
read-only
OCTET STRING
OCTET STRING (1..19)
Time when the conflict was detected.
As per the MIB.
hh3cDhcpServer2ConflictRowStatus
(1.3.6.1.4.1.25506.2.122.2.12.1.4)
read-create
RowStatus
destroy
Row status.
As per the MIB.
About this table
This table records lease expiration information on a DHCP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ExpiredIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ExpiredIP (1.3.6.1.4.1.25506.2.122.2.13.1.1)
not-accessible
InetAddressIPv4
Expired IP address.
As per the MIB.
hh3cDhcpServer2ExpiredClientId (1.3.6.1.4.1.25506.2.122.2.13.1.2)
read-only
OCTET STRING
OCTET STRING (4..254)
ID of the DHCP client of the expired IP address.
As per the MIB.
hh3cDhcpServer2ExpiredTime (1.3.6.1.4.1.25506.2.122.2.13.1.3)
read-only
OCTET STRING
OCTET STRING (1..19), a time string in the format of MM/DD/YYYY hh:mm:ss.
Time when the lease expired.
As per the MIB.
hh3cDhcpServer2ExpiredRowStatus (1.3.6.1.4.1.25506.2.122.2.13.1.4)
read-create
RowStatus
destroy
Row status.
As per the MIB.
About this table
This table records binding information about IP addresses in use on a DHCP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2IPInUseIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2IPInUseIP (1.3.6.1.4.1.25506.2.122.2.14.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
IP address in use.
As per the MIB.
hh3cDhcpServer2IPInUseClientId (1.3.6.1.4.1.25506.2.122.2.14.1.2)
read-only
OCTET STRING
Client ID of the IP address.
As per the MIB.
hh3cDhcpServer2IPInUseHardAddr
(1.3.6.1.4.1.25506.2.122.2.14.1.3)
read-only
OCTET STRING
Hardware address of the DHCP client.
As per the MIB.
hh3cDhcpServer2IPInUseHardType
(1.3.6.1.4.1.25506.2.122.2.14.1.4)
read-only
INTEGER
As per the MIB.
hh3cDhcpServer2IPInUseVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.5)
read-only
Unsigned32
Unsigned32(1..4094 | 65535)
VLAN where the DHCP client resides.
As per the MIB.
hh3cDhcpServer2IPInUseEndLease (1.3.6.1.4.1.25506.2.122.2.14.1.6)
read-only
OCTET STRING
Lease expiration time.
As per the MIB.
hh3cDhcpServer2IPInUseType (1.3.6.1.4.1.25506.2.122.2.14.1.7)
read-only
INTEGER
staticUnallocated(1), staticOffered(2), staticCommitted(3), autoOffered(4),
autoCommitted(5)
Binding type.
As per the MIB.
hh3cDhcpServer2IPInUseIfIndex (1.3.6.1.4.1.25506.2.122.2.14.1.8)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Index of the interface that connects to the DHCP client.
As per the MIB.
hh3cDhcpServer2IPInUseRowStatus (1.3.6.1.4.1.25506.2.122.2.14.1.9)
read-create
RowStatus
destroy
Row status.
As per the MIB.
hh3cDhcpServer2IPInUseSecondVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.10)
read-only
Unsigned32
Inner VLAN (customer VLAN) tag contained in the DHCP request.
As per the MIB.
About this table
This table defines option information associated with the DHCP user class.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2DefOptGrpClass.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2DefOptGrpClass (1.3.6.1.4.1.25506.2.122.2.15.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2DefOptGrpId (1.3.6.1.4.1.25506.2.122.2.15.1.2)
read-create
Integer32
Integer32(1..32768)
Option group ID.
As per the MIB.
hh3cDhcpServer2DefOptGrpStatus(1.3.6.1.4.1.25506.2.122.2.15.1.3)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines user class whitelist.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ValidClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ValidClassName (1.3.6.1.4.1.25506.2.122.2.16.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2ValidClassStatus (1.3.6.1.4.1.25506.2.122.2.16.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines the user class hardware address match rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleHwAddrNumber.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2RuleHwAddrNumber (1.3.6.1.4.1.25506.2.122.2.17.1.1)
not-accessible
Integer32
Integer32 (1..16)
Rule ID.
As per the MIB.
hh3cDhcpServer2RuleHwAddress (1.3.6.1.4.1.25506.2.122.2.17.1.2)
read-create
OCTET STRING
OCTET STRING (4..39)
Hardware address.
As per the MIB.
hh3cDhcpServer2RuleHwAddrMask (1.3.6.1.4.1.25506.2.122.2.17.1.3)
read-create
OCTET STRING
Hardware address mask.
As per the MIB.
hh3cDhcpServer2RuleHwAddrType (1.3.6.1.4.1.25506.2.122.2.17.1.4)
read-create
Integer32
1, representing the Ethernet
As per the MIB.
hh3cDhcpServer2RuleHwAddrStatus (1.3.6.1.4.1.25506.2.122.2.17.1.5)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines a DHCP option group for a DHCP user class.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is h3cDhcpServer2OptionGroupId.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2OptionGroupId (1.3.6.1.4.1.25506.2.122.2.18.1.1)
not-accessible
Integer32
Integer32(1..32768)
Option group ID.
As per the MIB.
hh3cDhcpServer2OptionGroupStatus (1.3.6.1.4.1.25506.2.122.2.18.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines user option information in a DHCP option group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpServer2OptionGroupId and h3cDhcpServer2OptionCode.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2OptionCode (1.3.6.1.4.1.25506.2.122.2.19.1.1)
not-accessible
Integer32
Integer32(2..254),excluding 50..54, 56, 58, 59, 61, 82
Option code.
As per the MIB.
hh3cDhcpServer2OptionType (1.3.6.1.4.1.25506.2.122.2.19.1.2)
read-create
INTEGER
Option type.
As per the MIB.
hh3cDhcpServer2OptionAscii (1.3.6.1.4.1.25506.2.122.2.19.1.3)
read-create
OCTET STRING
OCTET STRING(0..255)
The value read from this object is 0 if ascii(1) is specified as the option type but no ASCII string is specified.
hh3cDhcpServer2OptionHexStr (1.3.6.1.4.1.25506.2.122.2.19.1.4)
read-create
OCTET STRING
OCTET STRING(0|2..510)
The value read from this object is 0 if hex(2) is specified as the option type but no hexadecimal string is specified.
hh3cDhcpServer2OptionIPStr (1.3.6.1.4.1.25506.2.122.2.19.1.5)
read-create
OCTET STRING
OCTET STRING(0..127)
As per the MIB.
hh3cDhcpServer2OptionRowStatus (1.3.6.1.4.1.25506.2.122.2.19.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP address pool statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolUsage
(1.3.6.1.4.1.25506.2.122.2.20.1.1)
read-only
Unsigned32
Unsigned32(0..100)
IP address usage of the address pool.
As per the MIB.
hh3cDhcpServer2PoolReqCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.2)
read-only
Counter64
Number of address requests received by the address pool.
As per the MIB.
hh3cDhcpServer2PoolReqSuccCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.3)
read-only
Counter64
Number of successfully processed received requests in the address pool.
As per the MIB.
hh3cDhcpServer2PoolDiscoverCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.4)
read-only
Counter64
Number of DHCP-DISCOVER messages received by the address pool.
As per the MIB.
hh3cDhcpServer2PoolOfferCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.5)
read-only
Counter64
Number of DHCP-OFFER messages sent by the address pool.
As per the MIB.
hh3cDhcpServer2PoolAckCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.6)
read-only
Counter64
Number of DHCP-ACK messages sent by the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPTotalNum
(1.3.6.1.4.1.25506.2.122.2.20.1.7)
read-only
Unsigned32
Total number of addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPUsedNum
(1.3.6.1.4.1.25506.2.122.2.20.1.8)
read-only
Unsigned32
Number of assigned IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPIdleNum
(1.3.6.1.4.1.25506.2.122.2.20.1.9)
read-only
Unsigned32
Number of free IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPExcludeNum
(1.3.6.1.4.1.25506.2.122.2.20.1.10)
read-only
Unsigned32
Number of excluded IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolConflictNum
(1.3.6.1.4.1.25506.2.122.2.20.1.11)
read-only
Unsigned32
Number of conflicting IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolAutoBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.12)
read-only
Unsigned32
Number of dynamic IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolManualBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.13)
read-only
Unsigned32
Number of static IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolExpiredBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.14)
read-only
Unsigned32
Number of expired IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolNameInfo
(1.3.6.1.4.1.25506.2.122.2.20.1.15)
read-create
OCTET STRING
As per the MIB.
hh3cDhcpServer2PoolReserveIpNum
(1.3.6.1.4.1.25506.2.122.2.20.1.16)
read-only
Unsigned32
Number of reserved IP addresses in the pool.
As per the MIB.
About this table
This table defines DHCP pool group information.
CreateSupported.
It must be bound to h3cDhcpServer2PoolGroupName when you create an entry.
Edit/ModifyNot editable after you create hh3cDhcp6Server2PoolGroupName.
DeleteNot supported
ReadNot supported
Columns
The table index is hh3cDhcpServer2PoolGpName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolGpName (1.3.6.1.4.1.25506.2.122.2.21.1.1)
read-only
OCTET STRING
DHCP pool group name.
hh3cDhcpServer2PoolGpVpnName (1.3.6.1.4.1.25506.2.122.2.21.1.2)
read-create
OCTET STRING
VPN instance to which the DHCP pool group is applied.
As per the MIB.
hh3cDhcpServer2PoolGpIncUndo (1.3.6.1.4.1.25506.2.122.2.21.1.3)
read-write
TruthValue
Deleting all pools from the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpRowSta (1.3.6.1.4.1.25506.2.122.2.21.1.4)
read-create
RowStatus
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines DHCP pool information for a DHCP pool group.
CreateSupported.
It must be bound to hh3cDhcpServer2PoolGroupName when you create an entry.
The pool must have been created.
Edit/ModifyNot supported.
DeleteNot supported
ReadNot supported
Columns
The table indexes are hh3cDhcpServer2PoolIndex and hh3cDhcpServer2PoolGpName.
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
DHCP pool name.
As per the MIB.
hh3cDhcpServer2PoolGpExtRowSta (1.3.6.1.4.1.25506.2.122.2.22.1.2)
read-create
RowStatus
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP pool group statistics.
CreateNot supported.
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolGpPoolNum
(1.3.6.1.4.1.25506.2.122.2.23.1.1)
read-only
Unsigned32
Number of IP pools in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpBndDomNum
(1.3.6.1.4.1.25506.2.122.2.23.1.2)
read-only
Counter64
Number of domains specified for the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpUsage (1.3.6.1.4.1.25506.2.122.2.23.1.3)
read-only
Counter64
IP address usage of the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpIPTotalNum (1.3.6.1.4.1.25506.2.122.2.23.1.4)
read-only
Counter64
Total number of IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpIPUsedNum (1.3.6.1.4.1.25506.2.122.2.23.1.5)
read-only
Counter64
Number of allocated IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpIPIdleNum (1.3.6.1.4.1.25506.2.122.2.23.1.6)
read-only
Counter64
Number of free IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpIPExcNum (1.3.6.1.4.1.25506.2.122.2.23.1.7)
read-only
Unsigned32
Number of excluded IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpConfNum (1.3.6.1.4.1.25506.2.122.2.23.1.8)
read-only
Unsigned32
Number of conflicting IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpAutoBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.9)
read-only
Unsigned32
Number of dynamically allocated IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpManuBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.10)
read-only
Unsigned32
Number of statically allocated IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpExpiBndNum (1.3.6.1.4.1.25506.2.122.2.23.1.11)
read-only
Counter64
Number of expired IP addresses in the DHCP pool group.
As per the MIB.
hh3cDhcpServer2PoolGpReserveIpNum
(1.3.6.1.4.1.25506.2.122.2.23.1.12)
read-only
Counter64
Number of reserved IP addresses in the DHCP pool group.
As per the MIB.
About this table
This table configures global DHCP relay agent settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2UserInfoRecord
(1.3.6.1.4.1.25506.2.122.3.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of recording client information in relay entries.
As per the MIB.
hh3cDhcpRelay2UserInfoRefresh
(1.3.6.1.4.1.25506.2.122.3.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of refreshing relay entries.
As per the MIB.
hh3cDhcpRelay2UserInfoFlushTime (1.3.6.1.4.1.25506.2.122.3.1.3)
read-write
Unsigned32
Unsigned32(0..120)
Interval at which the DHCP relay agent refreshes relay entries.
As per the MIB.
hh3cDhcpRelay2ReleaseAddr
(1.3.6.1.4.1.25506.2.122.3.1.4)
read-write
OCTET STRING
OCTET STRING (0..47)
IP address release request sent to the server.
The set operation enables the relay agent to send a release request for the specified IP address to the DHCP server.
When you perform a get operation on this object, a value of 0 is returned.
About this table
This table records the global statistics on a DHCP relay agent.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2RxClientNum (1.3.6.1.4.1.25506.2.122.3.2.1)
read-only
Counter64
Number of received packets that are sent by the DHCP clients.
As per the MIB.
hh3cDhcpRelay2TxClientNum (1.3.6.1.4.1.25506.2.122.3.2.2)
read-only
Counter64
Number of packets sent to the DHCP clients.
As per the MIB.
hh3cDhcpRelay2RxServerNum (1.3.6.1.4.1.25506.2.122.3.2.3)
read-only
Counter64
Number of received packets sent by DHCP servers.
As per the MIB.
hh3cDhcpRelay2TxServerNum (1.3.6.1.4.1.25506.2.122.3.2.4)
read-only
Counter64
Number of packets sent to the DHCP servers.
As per the MIB.
hh3cDhcpRelay2BadNum
(1.3.6.1.4.1.25506.2.122.3.2.5)
read-only
Counter64
Number of error packets processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2BootpRequestNum
(1.3.6.1.4.1.25506.2.122.3.2.6)
read-only
Counter64
Number of BOOTP requests processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2DiscoverNum (1.3.6.1.4.1.25506.2.122.3.2.7)
read-only
Counter64
Number of DHCP-DISCOVER messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2RequestNum (1.3.6.1.4.1.25506.2.122.3.2.8)
read-only
Counter64
Number of DHCP-REQUEST messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2DeclineNum (1.3.6.1.4.1.25506.2.122.3.2.9)
read-only
Counter64
Number of DHCP-DECLINE messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2ReleaseNum (1.3.6.1.4.1.25506.2.122.3.2.10)
read-only
Counter64
Number of DHCP-RELEASE messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2InformNum (1.3.6.1.4.1.25506.2.122.3.2.11)
read-only
Counter64
Number of DHCP-INFORM messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2BootpReplyNum
(1.3.6.1.4.1.25506.2.122.3.2.12)
read-only
Counter64
Number of BOOTP replies processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2OfferNum (1.3.6.1.4.1.25506.2.122.3.2.13)
read-only
Counter64
Number of DHCP-OFFER messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2AckNum (1.3.6.1.4.1.25506.2.122.3.2.14)
read-only
Counter64
Number of DHCP-ACK messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2NakNum (1.3.6.1.4.1.25506.2.122.3.2.15)
read-only
Counter64
Number of DHCP-NAK messages processed by the DHCP relay agent.
As per the MIB.
About this table
This table records the DHCP relay agent configuration on an interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2IfSelectRelay (1.3.6.1.4.1.25506.2.122.4.1.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2IfCheckMac
(1.3.6.1.4.1.25506.2.122.4.1.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of MAC address check.
As per the MIB.
hh3cDhcpRelay2IfOpt82Enable
(1.3.6.1.4.1.25506.2.122.4.1.1.3)
read-write
TruthValue
true(1),
false(2)
Enabling status of support for option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82Strategy
(1.3.6.1.4.1.25506.2.122.4.1.1.4)
read-write
INTEGER
drop(1), keep(2), replace(3)
Strategy for handling DHCP requests that contain Option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDMode
(1.3.6.1.4.1.25506.2.122.4.1.1.5)
read-write
INTEGER
normal(1),
verbose(2),
userDefine(3)
Mode of the circuit ID sub-option in option 82.
The return value is normal(1) if the system reads an unsupported mode.
hh3cDhcpRelay2IfOpt82CIDNodeType
(1.3.6.1.4.1.25506.2.122.4.1.1.6)
read-write
INTEGER
invalid(1),
mac(2),
sysname(3),
userDefine(4)
Access node identifier for the circuit ID sub-option in verbose mode.
If no access node identifier is specified, the value read from this object is invalid(1).
hh3cDhcpRelay2IfOpt82CIDNodeStr
(1.3.6.1.4.1.25506.2.122.4.1.1.7)
read-write
OCTET STRING
OCTET STRING (0..50)
User-defined string as the access node identifier for the circuit ID sub-option in verbose mode.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDStr
(1.3.6.1.4.1.25506.2.122.4.1.1.8)
read-write
OCTET STRING
OCTET STRING (0|3..63)
User-defined string as the access node identifier for the circuit ID sub-option in userDefine mode.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDFormat
(1.3.6.1.4.1.25506.2.122.4.1.1.9)
read-write
INTEGER
hex(1),
ascii(2),
undefine(3)
Padding format of the circuit ID sub-option in option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82RIDMode
(1.3.6.1.4.1.25506.2.122.4.1.1.10)
read-write
INTEGER
normal(1),
sysname(2),
userDefine(3)
Mode of the remote ID sub-option in option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82RIDStr
(1.3.6.1.4.1.25506.2.122.4.1.1.11)
read-write
OCTET STRING
User-defined string as the access node identifier for the remote ID sub-option in userDefine mode.
If the mode of the remote ID sub-option is sysname(2), the value read from this object is 0.
hh3cDhcpRelay2IfOpt82RIDFormat
(1.3.6.1.4.1.25506.2.122.4.1.1.12)
read-write
INTEGER
hex(1),
ascii(2)
Padding format of the remote ID sub-option in normal mode.
As per the MIB.
About this table
This table obtains the IP address of a DHCP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex and h3cDhcpRelay2SrvAddrIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2SrvAddrIP
(1.3.6.1.4.1.25506.2.122.4.2.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
DHCP server IP address.
As per the MIB.
hh3cDhcpRelay2SrvAddrRowStatus (1.3.6.1.4.1.25506.2.122.4.2.1.2)
read-create
RowStatus
Active,
createAndGo,
destroy
Row status.
As per the MIB.
About this table
Use this table to delete DHCP relay entries.
CreateNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cDhcpRelay2UserInfoVpnIndex and h3cDhcpRelay2UserInfoIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2UserInfoVpnIndex
(1.3.6.1.4.1.25506.2.122.4.3.1.1)
not-accessible
Unsigned32
Unsigned32 (0 . 65534), 0 represents the public network.
VPN to which the IP address of the relay entry belongs.
As per the MIB.
hh3cDhcpRelay2UserInfoIpAddr (1.3.6.1.4.1.25506.2.122.4.3.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (0.255)
Client IP address in the relay entry.
As per the MIB.
hh3cDhcpRelay2UserInfoMacAddr (1.3.6.1.4.1.25506.2.122.4.3.1.3)
read-only
MacAddress
OCTET STRING (6)
Client MAC address in the relay entry.
As per the MIB.
hh3cDhcpRelay2UserInfoIfIndex (1.3.6.1.4.1.25506.2.122.4.3.1.4)
read-only
Index of the Layer 3 interface that connects to the DHCP client.
As per the MIB.
hh3cDhcpRelay2UserInfoRowStatus (1.3.6.1.4.1.25506.2.122.4.3.1.5)
read-create
RowStatus
destroy
Row status.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.122.5.0.1
Exhaustion of addresses in a DHCP address pool.
Error
Major
1.3.6.1.4.1.25506.2.122.5.0.2 (hh3cDhcpServer2AddrExhaustRecov)
ON
Notification triggers
This notification is generated when all addresses in a DHCP address pool are assigned.
System impact
New DHCP users cannot obtain IP addresses from the DHCP server.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server address-exhaust command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server address-exhaust command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.122.2.1.1.1 (hh3cDhcpServer2PoolIndex)
Unsigned32
Recommended action
To resolve this issue:
1.Use one of the following methods to increase address resources:
  - Add the current address pool and other address pools to an address pool group.
  - Add secondary network segments for dynamic address allocation in the current address pool.
If the issue persists, proceed to step 2.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
A DHCP address pool has recovered from address exhaustion.
Recovery
Major
N/A (N/A)
ON
This notification is generated when a DHCP address pool has recovered from address exhaustion.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.3
The address usage of an address pool has exceeded the threshold.
Error
Warning
1.3.6.1.4.1.25506.2.122.5.0.5 (hh3cDhcpServer2IpUsageOverflowRecov)
ON
This notification is generated when the address usage of an address pool has exceeded the threshold. The address usage of an address pool is read every 5 minutes.
System impact
If the DHCP server continues to assign IP addresses from the address pool to clients, the address pool might run out of addresses. As a result, new DHCP users cannot obtain IP addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-in-use command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-in-use command.
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
1.Use the display ip pool command in any view to check whether the address usage threshold specified in the current address pool is appropriate.
  - If the address usage threshold is too low, increase the threshold.
  - If the address usage threshold is appropriate, proceed to step 2.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool.
  - If the assignable addresses are insufficient, use one of the following methods to increase address resources:
  - If the assignable addresses are sufficient, keep observing the address usage of the current address pool. When the address pool has a high address usage, increase address resources timely to ensure that new DHCP users can obtain addresses.
3.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.4
DHCP address allocation success rate is below the specified threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the DHCP address allocation success rate is below the specified threshold during the past five minutes.
System impact
If this issue occurs due to address exhaustion, new DHCP users cannot obtain addresses from the DHCP server and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server allocated-ip command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server allocated-ip command.
Object
OID (object name)
Index
Value range
Recommended action
1.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool:
  - If the address pool has both assigned addresses and assignable addresses, proceed to step 2.
  - If the address pool does not have any assignable addresses, use one of the following methods to increase address resources:
If the issue persists, proceed to step 3.
2.Verify that all DHCP settings are configured correctly. If the issue persists, proceed to step 3.
3.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The address usage of an address pool has dropped below the specified threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the address usage of an address pool has dropped below the specified threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.6
Subnet usage of an address pool has reached or exceeded the threshold.
Error
Warning
1.3.6.1.4.1.25506.2.122.5.0.7 (hh3cDhcpServer2NetUsageOverflowRecov)
ON
This notification is generated when the subnet usage of an address pool has reached or exceeded the threshold.
System impact
If the DHCP server continues to assign subnets from the address pool to clients, the address pool might run out of address resources. As a result, new DHCP users cannot obtain addresses and thus cannot come online.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
1.Use the display ip pool command in any view to check whether the subnet usage threshold specified for the current address pool is appropriate:
  - If the subnet usage threshold is too low, increase the threshold.
  - If the subnet usage threshold is appropriate, proceed to step 2.
2.Use the display dhcp server statistics command in any view to view the subnet usage of the current address pool and the number of assignable subnets in the current address pool:
  - If the assignable subnets are insufficient, use one of the following methods to increase subnet resources:
Add secondary network segments for dynamic subnet allocation in the current address pool.
  - If the assignable addresses are sufficient, keep observing the subnet usage of the current address pool. When the address pool has a high subnet usage, increase subnet resources timely to ensure that new DHCP users can obtain addresses.
Basic information
OID
Event
Severity
Default status
Subnet usage of an address pool has dropped below the threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the subnet usage of an address pool has dropped below the threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.8
Subnets in an address pool have been exhausted.
Error
Major
1.3.6.1.4.1.25506.2.122.5.0.9 (hh3cDhcpServer2NetExhaustRecov)
ON
This notification is generated when an address pool has recovered from subnet resource exhaustion.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.10
Subnets in an address pool group have been exhausted.
Error
Major
1.3.6.1.4.1.25506.2.122.5.0.11 (hh3cDhcpServer2GpNetExhaustRecov)
ON
This notification is generated when an address pool group has run out of subnet resources.
System impact
New DHCP users might fail to obtain addresses and thus cannot come online.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.122.2.21.1.1 (hh3cDhcpServer2PoolGpName)
Name of the DHCP address pool group.
OCTET STRING
Recommended action
1.Use one of the following methods to increase subnet resources for the address pool group:
  - Add new address pools to the address pool group.
  - Add secondary network segments for address pools in the address pool group.
Basic information
OID
Event
Severity
Default status
An address pool group has recovered from subnet resource exhaustion.
Recovery
Major
N/A (N/A)
ON
This notification is generated when an address pool group has recovered from subnet resource exhaustion.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.12
The DHCP server fails to allocate an IP address in the ISP domain.
Informational
Warning
N/A (N/A)
ON
This notification is generated in one of the following scenarios:
The DHCP relay agent is disconnected from the DHCP server.
The DHCP server does not have assignable addresses.
System impact
The DHCP relay agent cannot obtain IP addresses from the DHCP server. As a result, users attached to the DHCP relay agent cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-alloc-failed command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-alloc-failed command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.122.1.2.24 (hh3cDhcpServer2OnlineFailReason)
Reason for the address allocation failure on the DHCP server.
N/A
OCTET STRING
Recommended action
1.Verify that the link between the DHCP relay agent and the DHCP server is in good condition and they can reach each other.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool and the number of assignable addresses in the current address pool:
  - If the address pool has both assigned addresses and assignable addresses, proceed to step 3.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.14
An address pool group has no assignable IP addresses.
Error
Warning
1.3.6.1.4.1.25506.2.122.5.0.15 (hh3cDhcpSvr2GpAddrExhaustRecov)
ON
This notification is generated when an address pool group has run out of IP addresses.
System impact
New DHCP users cannot obtain addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server pool-group-exhaust command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server pool-group-exhaust command.
Object
OID (object name)
Index
Value range
Name of the address pool group.
The value range varies by product type.
Recommended action
1.Use one of the following methods to increase address resources for the address pool group:
Basic information
OID
Event
Severity
Default status
An address pool group recovers from the address resource exhaustion condition.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when an address pool group has recovered from the address resource exhaustion condition.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server group-used-exhaustion command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server group-used-exhaustion command.
Object
OID (object name)
Index
Value range
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.16
All ODAP address pools have run out of subnet resources.
Informational
Warning
N/A (N/A)
ON
This notification is generated when all ODAP address pools have run out of subnet resources.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server odap-subnet-alarm command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server odap-subnet-alarm command.
Object
OID (object name)
Index
Value range
Recommended action
1.Use the display dhcp dynamic-alloc address command in any view to view the address usage of each subnet. If the address usage of each subnet is not high, use the subnet utilization mark command to increase the low utilization mark. When the address usage of each subnet in an ODAP client address pool is lower than the low utilization mark, the address pool releases idle subnets.
2.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.17
An ODAP address pool fails to request subnet resources.
Informational
Warning
N/A (N/A)
ON
This notification is generated when one of the following conditions exists:
The ODAP server does not respond to the subnet request.
The ODAP server is configured incorrectly.
The ODAP server has run out of subnet resources.
System impact
Users cannot come online.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Reason why the ODAP address pool failed to request subnet resources.
N/A
OCTET STRING
Recommended action
1.Use the display dhcp dynamic-alloc address command in any view to view the address usage of each subnet. If the address usage of each subnet is high, use the subnet utilization mark command to adjust the low utilization mark. When the address usage of each subnet in an ODAP client address pool is lower than the low utilization mark, the address pool releases idle subnets.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.18
An ODAP address pool fails to release subnets.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the ODAP server is disconnected from an ODAP client.
System impact
This issue might disable the ODAP server from reclaiming subnets from the ODAP client and the ODAP server might run out of subnet resources.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Reason why the ODAP address pool failed to release subnet resources.
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.19
The IP address usage of an address pool group has reached or exceeded the threshold.
Error
Warning
1.3.6.1.4.1.25506.2.122.5.0.20 (hh3cDhcpSvr2GpUsageOverflowRecov)
ON
This notification is generated when the IP address usage of an address pool group has reached or exceeded the threshold.
System impact
If the DHCP server continues to assign IP addresses from the address pool group to clients, the address pool group might run out of addresses. As a result, new DHCP users cannot obtain IP addresses and thus cannot come online.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server pool-group-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server pool-group-threshold command.
Object
OID (object name)
Index
Value range
Recommended action
1.Use the display ip pool-group command in any view to check whether the address usage threshold specified in the current address pool group is appropriate.
2.Use the display dhcp server statistics command in any view to view the address usage of the current address pool group and the number of assignable addresses in the current address pool group.
  - If the assignable addresses are insufficient, use one of the following methods to increase address resources for the address pool group:
  - If the assignable addresses are sufficient, keep observing the address usage of the current address pool group. When the address pool group has a high address usage, increase address resources timely to ensure that new DHCP users can obtain addresses.
Basic information
OID
Event
Severity
Default status
The IP address usage of an address pool group has dropped below the threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the IP address usage of an address pool group has dropped below the threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.21
The DHCP server assigns a conflicting address to a client.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the DHCP server assigns a conflicting address to a client.
System impact
If excessive conflicting addresses exist, the DHCP server might run out of address pool resources.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-conflict command.
Object
OID (object name)
Index
Value range
Index of the address pool.
Unsigned32
Conflicting IP address assigned to the DHCP client.
N/A
InetAddressIPv4
Recommended action
1.Use the display dhcp server conflict command in any view to identify whether the IP address conflicts are excessive. If too many IP address conflicts exist, identify whether they are real.
  - If those IP address conflicts do exist, replan the network.
  - If some IP address conflicts are not real, proceed to step 2.
