08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
11-HH3C-IPFW-MIB
11-HH3C-IPFW-MIB 130.99 KB
HH3C-IPFW-MIB
About this MIB
Use this MIB to obtain IP forwarding information and configure IP forwarding.
MIB file name
hh3c-ipfw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpfw(211)
Scalar objects
hh3cIpfwIfIndex (1.3.6.1.4.1.25506.2.211.2.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
InterfaceIndex
Integer32 (1..2147483647)
Index of the interface from which packets are received.
As per the MIB.
hh3cIpfwPeerAddress (1.3.6.1.4.1.25506.2.211.2.1.2)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING  (0..255)
Destination IP address of received packets.
As per the MIB.
hh3cIpfwInterfaceName (1.3.6.1.4.1.25506.2.211.2.1.3)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the interface from which packets are received.
As per the MIB.
hh3cIpfwChassis (1.3.6.1.4.1.25506.2.211.2.1.4)
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32(0..2147483647)
Chassis number.
As per the MIB.
hh3cIpfwSlot (1.3.6.1.4.1.25506.2.211.2.1.5)
Object (OID)
Access
Value range
Implementation
Unsigned32
Slot number.
As per the MIB.
hh3cIpfwVsysID (1.3.6.1.4.1.25506.2.211.2.1.6)
Object (OID)
Access
Value range
Implementation
Unsigned32
vSystem ID.
As per the MIB.
hh3cIpfwIPv4FragBufSrcAddress (1.3.6.1.4.1.25506.2.211.2.1.7)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Source IPv4 address of the packet that triggered the alarm notification.
As per the MIB.
hh3cIpfwIPv4FragBufDstAddress (1.3.6.1.4.1.25506.2.211.2.1.8)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Destination IPv4 address of the packet that triggered the alarm notification.
As per the MIB.
hh3cIpfwIPv6FragBufSrcAddress (1.3.6.1.4.1.25506.2.211.2.1.9)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Source IPv6 address of the packet that triggered the alarm notification.
As per the MIB.
hh3cIpfwIPv6FragBufDstAddress (1.3.6.1.4.1.25506.2.211.2.1.10)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Destination IPv6 address of the packet that triggered the alarm notification.
As per the MIB.
hh3cIpfwMbufAllocFailedNum (1.3.6.1.4.1.25506.2.211.2.1.11)
Object (OID)
Access
Value range
Implementation
Unsigned32
Standard MIB values.
Number of MBUF allocation failures.
As per the MIB.
Notifications
hh3cIpfwPktNumExcAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.211.2.0.1
Disordered packets detected.
Error
Warning
1.3.6.1.4.1.25506.2.211.2.0.2 (hh3cIpfwPktNumExcAlarmResume)
ON
Notification triggers
This notification is generated when the length of the buffered packet queue exceeds the alarm threshold because the device receives a large number of fragments that require reassembly.
System impact
The device received too many fragments, some of which are disordered, and the device cannot complete fragment reassembly in time. This might cause packet loss and affect service operation.
Status control
ON
CLI: Use the snmp-agent trap enable ip-forwarding command.
OFF
CLI: Use the undo snmp-agent trap enable ip-forwarding command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.211.2.1.1 (hh3cIpfwIfIndex)
Index of the interface from which the packets are received.
N/A
InterfaceIndex
1.3.6.1.4.1.25506.2.211.2.1.2 (hh3cIpfwPeerAddress)
IP address of the interface from which the packets are received.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.211.2.1.3 (hh3cIpfwInterfaceName)
Name of the interface from which the packets are received.
N/A
OCTET STRING
Recommended action
Use the IP address and interface information in the alarm message to identify the fragment source and verify if the fragments are valid. If the fragments are invalid, enable anti-attack measures against the source as a best practice to avoid effect on service operation.
Basic information
OID
Event
Severity
Default status
Disordered packet alarm removal
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the threshold exceeding alarm (buffered packet queue length threshold) is removed.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
InterfaceIndex
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
No action is required.
hh3cIpfwIPv4VfrExcAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.211.2.0.3
IPv4 VFR buffer limit violation.
Error
Warning
1.3.6.1.4.1.25506.2.211.2.0.4 (hh3cIpfwIPv4VfrExcAlarmResume)
ON
This notification is generated when one of the following items exceeds the limit:
Quantity of the fragments buffered by IPv4 VFR.
Quantity of entries in the IPv4 fragment fast forwarding table.
System impact
Service interruption will occur because the device discards the fragments that IPv4 VFR cannot reassemble.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.211.2.1.4 (hh3cIpfwChassis)
Chassis number.
N/A
Unsigned32
Integer32 (0..2147483647)
1.3.6.1.4.1.25506.2.211.2.1.5 (hh3cIpfwSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.211.2.1.6 (hh3cIpfwVsysID)
vSystem ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.211.2.1.7 (hh3cIpfwIPv4FragBufSrcAddress)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.211.2.1.8 (hh3cIpfwIPv4FragBufDstAddress)
N/A
OCTET STRING
Recommended action
To resolve this issue:
1.Identify whether the number of IPv4 fragments in the current system is correct by capturing packets from the system.
2.Repeat the display system internal ip packet-drop statistics command in probe view, and observe the values of the following fields in the command output:
  - Fragments in queue for virtual reassembly reach the limit
  - Virtual fragment reassembly failed
3.Collect the results of the steps above, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Recovery from IPv4 VFR buffer limit violation.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the device recovers from a condition of IPv4 VFR buffer limit violation.
System impact
No negative impact on the system.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
vSystem ID.
N/A
Unsigned32
Recommended action
No action is required. Please contact H3C Support.
hh3cIpfwIPv6VfrExcAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.211.2.0.5
IPv6 VFR buffer limit violation.
Error
Warning
1.3.6.1.4.1.25506.2.211.2.0.6 (hh3cIpfwIPv6VfrExcAlarmResume)
ON
Quantity of the fragments buffered by IPv6 VFR.
Quantity of entries in the IPv6 fragment fast forwarding table.
System impact
Service interruption will occur because the device discards the fragments that IPv6 VFR cannot reassemble.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.211.2.1.6 (hh3cIpfwVsys)
vSystem ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.211.2.1.9 (hh3cIpfwIPv6FragBufSrcAddress)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.211.2.1.10 (hh3cIpfwIPv6FragBufDstAddress)
N/A
OCTET STRING
Recommended action
1.Identify whether the number of IPv6 fragments in the current system is correct by capturing packets from the system.
2.Repeat the display system internal ipv6 packet-drop statistics command in probe view, and observe the values of the following fields in the command output:
Basic information
OID
Event
Severity
Default status
Recovery from IPv6 VFR buffer limit violation.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the device recovers from a condition of IPv6 VFR buffer limit violation.
System impact
Status control
ON
CLI: N/A
OFF
CLI: N/A
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
vSystem ID.
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.211.2.0.7
Error
Warning
N/A (N/A)
ON
This notification is generated due to memory insufficiency.
System impact
Packet failure occurs, interrupting services.
Status control
ON
CLI: snmp-agent trap enable ip-forwarding
OFF
CLI: undo snmp-agent trap enable ip-forwarding
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.211.2.1.11 (hh3cIpfwMbufAllocFailedNum)
N/A
Unsigned32
As per the MIB.
Recommended action
1.Check the device for memory insufficiency.
2.Stop unused services and downsize services with high memory usage.
