23-Segment Routing命令参考
03-SRv6 TE Policy命令
本章节下载 03-SRv6 TE Policy命令  (1.26 MB)
03-SRv6 TE Policy命令
  录
1 SRv6 TE Policy
1.1 SRv6 TE Policy配置命令
1.1.1 address-family ipv6 sr-policy
1.1.2 advertise ebgp enable
1.1.3 autoroute enable
1.1.4 autoroute metric
1.1.5 backup hot-standby
1.1.6 bandwidth sample
1.1.7 bandwidth-threshold switch-back
1.1.8 bandwidth-threshold upper
1.1.9 bestroute encap-type
1.1.10 bfd echo
1.1.11 bfd srv6-encapsulation-mode insert
1.1.12 binding-sid (SRv6 TE Policy group view)
1.1.13 binding-sid(SRv6 TE Policy view)
1.1.14 bypass enable
1.1.15 candidate-paths
1.1.16 cmi threshold
1.1.17 color end-point
1.1.18 color match dscp (DSCP forward type view)
1.1.19 color match dscp (SRv6 TE Policy group view)
1.1.20 default-color (Public instance IPv4/IPv6 address family view)
1.1.21 default-color (VPN instance IPv4/IPv6 address family view)
1.1.22 default match (APN ID)
1.1.23 default match(TE Class ID)
1.1.24 delay threshold
1.1.25 description
1.1.26 display bgp mirror remote-sid
1.1.27 display bgp routing-table ipv6 sr-policy
1.1.28 display segment-routing ipv6 te bfd
1.1.29 display segment-routing ipv6 te forwarding
1.1.30 display segment-routing ipv6 te ipr
1.1.31 display segment-routing ipv6 te ipr bandwidth interface
1.1.32 display segment-routing ipv6 te policy
1.1.33 display segment-routing ipv6 te policy ifit
1.1.34 display segment-routing ipv6 te policy last-down-reason
1.1.35 display segment-routing ipv6 te policy statistics
1.1.36 display segment-routing ipv6 te policy status
1.1.37 display segment-routing ipv6 te policy-group
1.1.38 display segment-routing ipv6 te policy-group apn-id-ipv6
1.1.39 display segment-routing ipv6 te policy-group last-down-reason
1.1.40 display segment-routing ipv6 te policy-group statistics
1.1.41 display segment-routing ipv6 te sbfd
1.1.42 display segment-routing ipv6 te segment-list
1.1.43 distribute bgp-ls
1.1.44 drop-upon-invalid enable
1.1.45 drop-upon-mismatch enable
1.1.46 encapsulation-mode
1.1.47 encapsulation-mode encaps include local-end.x
1.1.48 encapsulation-mode insert include local-end.x
1.1.49 end-point
1.1.50 expect-bandwidth
1.1.51 explicit segment-list
1.1.52 fast-reroute mirror delete-delay
1.1.53 fast-reroute mirror enable
1.1.54 forwarding statistics
1.1.55 forward-type (SRv6 TE ODN Policy group view)
1.1.56 forward-type (SRv6 TE Policy group view)
1.1.57 group-color
1.1.58 ifit delay-measure
1.1.59 ifit interval
1.1.60 ifit loss-measure
1.1.61 ifit measure mode
1.1.62 import-route sr-policy
1.1.63 mirror remote-sid delete-delay
1.1.64 index
1.1.65 index apn-id match
1.1.66 index te-class match
1.1.67 intelligent-policy-route
1.1.68 ipr-policy
1.1.69 jitter threshold
1.1.70 local-binding-sid
1.1.71 loss threshold
1.1.72 measure count
1.1.73 on-demand
1.1.74 on-demand-group
1.1.75 policy
1.1.76 policy-group
1.1.77 preference
1.1.78 rate-limit
1.1.79 refresh-period
1.1.80 reset segment-routing ipv6 te forwarding statistics
1.1.81 restrict
1.1.82 reverse-binding-sid
1.1.83 router-id filter
1.1.84 sbfd
1.1.85 schedule-priority
1.1.86 segment-list
1.1.87 service-class
1.1.88 shutdown
1.1.89 sr-policy steering
1.1.90 sr-te frr enable
1.1.91 srv6-policy autoroute enable
1.1.92 srv6-policy backup hot-standby enable
1.1.93 srv6-policy bandwidth sample enable
1.1.94 srv6-policy bandwidth sample interval
1.1.95 srv6-policy bandwidth-threshold lower
1.1.96 srv6-policy bfd echo
1.1.97 srv6-policy color priority
1.1.98 srv6-policy encapsulation-mode
1.1.99 srv6-policy encapsulation-mode encaps include local-end.x
1.1.100 srv6-policy encapsulation-mode insert include local-end.x
1.1.101 srv6-policy forwarding statistics enable
1.1.102 srv6-policy forwarding statistics interval
1.1.103 srv6-policy ifit delay-measure enable
1.1.104 srv6-policy ifit interval
1.1.105 srv6-policy ifit loss-measure enable
1.1.106 srv6-policy ifit measure mode
1.1.107 srv6-policy locator
1.1.108 srv6-policy log enable
1.1.109 srv6-policy sbfd
1.1.110 srv6-policy switch-delay delete-delay
1.1.111 switch-period
1.1.112 traffic-engineering
1.1.113 ttl-mode
1.1.114 validation-check enable
1.1.115 wait-to-restore-period
1 SRv6 TE Policy
address-family ipv6 sr-policy命令用来创建BGP IPv6 SR Policy地址族,并进入相应地址族视图。如果BGP IPv6 SR Policy地址族视图已经存在,则直接进入BGP IPv6 SR Policy地址族。
undo address-family ipv6 sr-policy命令用来删除BGP IPv6 SR Policy地址族,及相应地址族视图下的所有配置。
不存在BGP IPv6 SR Policy地址族。
BGP实例视图
BGP IPv6 SR Policy地址族视图下的配置,只对BGP IPv6 SR Policy地址族的路由和对等体生效。
# 在BGP实例视图下,创建BGP IPv6 SR Policy地址族,并进入BGP IPv6 SR Policy地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6]
advertise ebgp enable命令用来配置将BGP IPv6 SR Policy路由发布给EBGP邻居。
undo advertise ebgp enable命令用来恢复缺省情况。
BGP IPv6 SR Policy路由不发布给EBGP邻居。
缺省情况下,BGP IPv6 SR Policy路由只能在IBGP对等体之间发布。如果需要将BGP IPv6 SR Policy路由发布给EBGP对等体,则需要执行本命令。
# 配置将BGP IPv6 SR Policy路由发布给EBGP邻居。
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] advertise ebgp enable
autoroute enable命令用来开启自动引流功能。
undo autoroute enable命令用来关闭自动引流功能。
autoroute enable [ isis | ospfv3 ]
自动引流功能处于关闭状态。
SRv6 TE Policy视图
isis:开启IPv6 IS-IS的自动引流功能。
ospfv3:开启OSPFv3的自动引流功能。
自动路由发布是指将SRv6 TE Policy隧道发布到IGP(OSPFv3或IS-IS)路由中,让SRv6 TE Policy隧道参与IGP路由的计算,使得流量可以通过SRv6 TE Policy隧道转发。
自动路由发布目前仅支持IGP Shortcut方式,也称为自动路由宣告(AutoRoute Announce),该功能将SRv6 TE Policy隧道当作一条直接连接隧道Ingress节点(头节点)和Egress节点(尾节点)的链路,在隧道的Ingress节点上进行IGP路由计算时考虑该SRv6 TE Policy隧道。
如果不指定isisospfv3参数,则在OSPFv3和IPv6 IS-IS协议的路由计算中都考虑SRv6 TE Policy隧道。
# 开启SRv6 TE Policy的自动引流功能。
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] policy srv6policy
[Sysname-srv6-te-policy-srv6policy] autoroute enable
·     autoroute metric
autoroute metric命令用来配置SRv6 TE Policy隧道的度量值。
undo autoroute metric命令用来恢复缺省情况。
autoroute metric { absolute value | relative value }
SRv6 TE Policy隧道的度量值等于其IGP度量值。
SRv6 TE Policy视图
absolute value:以绝对值的方式指定度量值,即实际度量值为配置的值valuevalue为正整数,取值范围为1~65535。
relative value:以相对值的方式指定度量值,即实际度量值为配置的值value+该隧道的IGP度量值。value可以是正整数、负整数或0,取值范围为-10~10。
开启自动引流功能后,SRv6 TE Policy隧道作为一条链路参与IGP路由的计算。SRv6 TE Policy隧道在路由计算过程中的度量值可以通过本命令来配置。
# 配置SRv6 TE Policy隧道的度量值为绝对值15。
[Sysname-srv6-te-policy-srv6policy] autoroute metric absolute 15
·     autoroute enable
backup hot-standby命令用来配置SRv6 TE Policy的热备份功能。
undo backup hot-standby命令用来恢复缺省情况。
backup hot-standby { disable | enable }
未配置SRv6 TE Policy的热备份功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的热备份功能。
enable:开启SRv6 TE Policy的热备份功能。
开启SRv6 TE Policy的热备份功能后,如果一个SRv6 TE Policy下面存在多条候选路径,则优先级最高的有效路径是主路径,优先级次高的有效路径是备份路径。如果主路径下所有Segment List都发生故障,则将流量切换到备路径转发,以减少对业务的影响。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的热备份功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy 1的热备份功能。
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] backup hot-standby enable
·     srv6-policy backup hot-standby enable
bandwidth sample命令用来配置IPR模板的带宽采样功能。
undo bandwidth sample命令用来恢复缺省情况。
bandwidth sample { disable | enable }
SRv6 TE IPR模板下未配置带宽采样功能,SRv6 TE IPR模板的带宽采样功能的状态以SRv6 TE视图下的配置为准。
SRv6 TE IPR模板视图
enable:开启IPR模板的带宽采样功能。
disable:关闭IPR模板的带宽采样功能。
应用场景
开启IPR模板的带宽采样功能后,SRv6 TE Policy智能策略路由在路径优选时,可以基于带宽使用情况进行SRv6 TE Policy的优选。
IPR算路并选取的最优SRv6 TE Policy的过程中,SRv6 TE Policy不仅需要满足IPR模板中定义的时延、抖动和丢包等网络质量要求,还需要满足对带宽利用率的要求。只有时延、抖动和丢包等网络质量符合IPR模板定义的SLA标准,且带宽利用率不超出bandwidth-threshold upper命令定义的带宽利用率阈值上限的SRv6 TE Policy,能参与最优SRv6 TE Policy计算。
如果未开启IPR模板的带宽采样功能,则智能策略路由在路径优选时仅要求SRv6 TE Policy的时延、抖动和丢包等网络质量符合IPR模板定义的SLA标准。
工作机制
开启IPR模板的带宽采样功能后,设备按照srv6-policy bandwidth sample interval周期来收集各SRv6 TE Policy转发出接口的带宽利用率等信息,并计算IPR模板中各SRv6 TE Policy的预期平均带宽利用率。根据SRv6 TE Policy的预期平均带宽利用率,IPR首次计算和选取最优的SRv6 TE Policy。SRv6 TE Policy的预期平均带宽利用率如果不超过bandwidth-threshold upper命令定义的带宽利用率的阈值上限,则可以作为备选SRv6 TE Policy参与IPR路径优选,并根据srv6-policy color priority命令定义的选路优先级,选取选路优先级最小的SRv6 TE Policy作为最优路径转发业务流量。
其中,SRv6 TE Policy的预期平均带宽利用率指的是使用该SRv6 TE Policy承载新业务之后,该业务的带宽与转发出接口已使用带宽之和占转发出接口总带宽的比例,计算方式如下:
·     如果SRv6 TE Policy的最优候选路径仅存在一个SID列表,并且该SID列表的首个SID仅存在一个出接口时,SRv6 TE Policy的预期平均带宽利用率=(业务期望带宽+该出接口的当前已使用的带宽)/该出接口的总带宽。业务期望带宽选取规则如下,优先使用当前承载该业务的SRv6 TE Policy的实时统计作为业务期望带宽。如果SRv6 TE Policy未承载指定业务或者没有统计到SRv6 TE Policy的流量时,则选择该SRv6 TE Policy视图下expect-bandwidth命令配置的SRv6 TE Policy业务期望带宽。如果SRv6 TE Policy视图下未配置业务期望带宽时,则选择SRv6 TE IPR模板视图下expect-bandwidth命令指定的SRv6 TE IPR模板的业务期望带宽。
·     如果SRv6 TE Policy的最优候选路径存在多个SID列表,或者SID列表的首个SID存在多个等价出接口,SRv6 TE Policy的预期平均带宽利用率计算方式比较复杂,以下列SRv6 TE Policy为例,该SRv6 TE Policy的预期平均带宽利用率计算方法如下:
SRv6 TE Policy A
 Candidate paths(Preference 200)
    Segment List1(weight 10)        interface1    bw1    30%
                                    interface2    bw2    50%
    Segment List2(weight 30)        interface3    bw3    80%
SRv6 TE Policy A的最优候选路径Candidate Path中存在权重为10的SID列表1和权重为30的SID列表2。SID列表1中首个SID存在两个等价出接口interface1和interface2。interface1的接口带宽为bw1,interface2的接口带宽为bw2。SID列表2中首个SID存在一个出接口interface3,interface3的接口带宽为bw3。当前interface1、interface2和interface3的当前已用的带宽利用率分别为30%,50%和80%。
a.     根据等价出接口的当前带宽利用率,取等价出接口的当前带宽利用率的平均值作为SID列表1的带宽利用率,即(30%+50%)/2=40%。
b.     SID列表2的带宽利用率等于出接口interface3当前的带宽利用率80%。
c.     根据不同SID列表的权重和带宽利用率,使用加权平均的方式计算SRv6 TE Policy A的带宽利用率,即(40%*10+80%*30)/(10+30)=70%。
d.     计算SRv6 TE Policy A的预期平均带宽利用率=(业务期望带宽+70%*(bw1+bw2+bw3))/(bw1+bw2+bw3)
注意事项
·     SRv6 TE Policy的最优候选路径中存在多个SID列表或者SID列表的首个SID存在多个等价出接口的场景下,SRv6 TE Policy的预期平均带宽利用率的计算并不能准确反映出各接口的带宽利用率。因此,在使用SRv6 TE Policy的智能策略路由功能,基于带宽使用情况进行SRv6 TE Policy的优选时,请管理员保证规划和创建SRv6 TE Policy的最优候选路径仅存在一个SID列表且该SID列表仅存在单个出接口。
·     SRv6 TE Policy的智能策略路由功能仅首次选取最优的SRv6 TE Policy时使用expect-bandwidth命令指定业务期望带宽来计算预期平均带宽利用率。IPR已选出最优SRv6 TE Policy承载业务后会进行周期性路径优化(即根据SRv6 TE Policy的质量和带宽进行切换和回切)。此时,计算预期平均带宽利用率将使用当前最优SRv6 TE Policy实时统计的业务流量带宽数据作为业务期望带宽来计算各SRv6 TE Policy的预期平均带宽利用率。例如,当前IPR路径优化时,已选取出的最优SRv6 TE Policy A实时的业务流量带宽为100Mbps,IPR计算SRv6 TE Policy B的预期平均带宽利用率=(100Mbps+SRv6 TE Policy B的转发出接口的已使用带宽)/SRv6 TE Policy B的转发出接口的总带宽,根据SRv6 TE Policy B的预期平均带宽利用率确定该SRv6 TE Policy是否符合带宽利用率的要求。
·     在使用SRv6 TE Policy的智能策略路由功能,基于带宽使用情况进行SRv6 TE Policy的优选时,建议管理员创建IPR模板引用的SRv6 TE Policy仅用于承载单一业务,不同业务不复用同一SRv6 TE Policy。例如,TE Class ID1000的业务映射到IPR模板优选的SRv6 TE Policy A(Color为100)中转发,由于IPR根据带宽使用情况进行路径调优时,使用优选的SRv6 TE Policy A实时统计流量来计算各SRv6 TE Policy的预期平均带宽利用率,如果SRv6 TE Policy A不仅仅承载了TE Class ID1000的业务还承载了其他业务,则实时统计流量不准确,预期平均带宽利用率计算也不准确。可以在源节点和尾节点间创建Color值不同的SRv6 TE Policy用于承载其他业务流量。
SRv6 TE视图可以配置srv6-policy bandwidth sample enable命令开启全局带宽采样功能,也可以在SRv6 TE IPR模板视图配置bandwidth sample命令开启带宽采样功能。SRv6 TE视图的配置对所有IPR模板都有效,而SRv6 TE IPR视图的配置只对该IPR模板有效。对于一个IPR模板来说,以SRv6 TE IPR模板视图下的配置为准,只有该SRv6 TE IPR模板视图内未进行配置时,才采用SRv6 TE视图的配置。
请先执行forwarding statistics命令或srv6-policy forwarding statistics enable命令开启IPR模板中所有SRv6 TE Policy的流量转发统计功能,SRv6 TE Policy智能策略路由基于带宽使用情况进行路径调优才能更加准确。
# 配置IPR模板ipr1的带宽采样功能为开启状态。
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] bandwidth sample enable
·     bandwidth-threshold upper
·     expect-bandwidth
·     srv6-policy bandwidth sample enable
bandwidth-threshold switch-back命令用来配置IPR模板的业务回切的带宽利用率阈值。
undo bandwidth-threshold switch-back命令用来恢复缺省情况。
bandwidth-threshold switch-back threshold-value
IPR模板的业务回切带宽利用率阈值为70%。
SRv6 TE IPR模板视图
threshold-value:IPR模板的业务回切的带宽利用率阈值,取值范围为1~100,单位为%。
工作机制
IPR按照refresh-period命令周期性进行路径调优时,如果发现存在至少一个SRv6 TE Policy的选路优先级高于当前承载业务的SRv6 TE Policy,且满足如下条件:
·     该SRv6 TE Policy的预期平均带宽利用率小于等于Min(bandwidth-threshold switch-back命令配置IPR模板的业务回切带宽利用率阈值,srv6-policy bandwidth-threshold lower命令配置带宽阈值下限),Min(a,b)表示a和b之间的较小值;未配置srv6-policy bandwidth-threshold lower命令时,则直接取bandwidth-threshold switch-back命令配置IPR模板的业务回切带宽利用率阈值。
·     该SRv6 TE Policy中数据业务流量的时延、抖动和丢包等质量指标符合的IPR模板中定义的SLA标准;
则设备会等待wait-to-restore-period命令指定的回切时延计时器超时后,将业务流量从当前的SRv6 TE Policy回切到选路优先级更高的SRv6 TE Policy上进行转发。
注意事项
配置本命令时,指定的回切的带宽阈值需要保证不大于bandwidth-threshold upper命令配置的IPR模板的带宽阈值上限。建议配置回切的带宽阈值与IPR模板的带宽阈值上限有较大差异,防止由于接口上带宽变化过大时,业务频繁切换。
# 配置IPR模板ipr1的业务回切的带宽利用率阈值为75%。
[Sysname-srv6-ipr-policy-ipr1] bandwidth-threshold switch-back 75
·     refresh-period
·     srv6-policy bandwidth-threshold lower
·     wait-to-restore-period
bandwidth-threshold upper命令用来配置IPR模板的带宽利用率的阈值上限。
undo bandwidth-threshold upper命令用来恢复缺省情况。
bandwidth-threshold upper upper-value
IPR模板的带宽利用率的阈值上限为90%。
SRv6 TE IPR模板视图
upper-value:IPR模板的带宽利用率的阈值上限,取值范围为1~100,单位为%。
应用场景
SRv6 TE Policy智能策略路由功能可以基于带宽使用情况进行SRv6 TE Policy的优选。
工作机制
·     IPR基于带宽使用情况首次优选SRv6 TE Policy时:要求SRv6 TE Policy的预期平均带宽利用率不超出bandwidth-threshold upper命令定义的带宽利用率阈值上限。SRv6 TE Policy的预期平均带宽利用率=(业务期望带宽+当前接口已占用的带宽)/出接口的总带宽。其中,业务期望带宽优先选择该SRv6 TE Policy视图下expect-bandwidth命令指定的SRv6 TE Policy业务期望带宽,SRv6 TE Policy视图下未配置期望带宽时,则选择SRv6 TE IPR模板视图下expect-bandwidth命令指定的SRv6 TE IPR模板的业务期望带宽。
·     IPR按照refresh-period命令指定的周期进行路径调优时:将计算出最优的SRv6 TE Policy,如果发现当前承载业务的SRv6 TE Policy的带宽利用率超过bandwidth-threshold upper命令指定的带宽利用率阈值上限时,设备会等待switch-period命令指定的切换时延计时器超时后,将业务流量切换到同时满足以下所有条件的SRv6 TE Policy上进行转发:
¡     该SRv6 TE Policy的预期平均带宽利用率不超过bandwidth-threshold upper命令指定的带宽利用率阈值上限;
¡     该SRv6 TE Policy中数据业务流量的时延、抖动和丢包等质量指标符合的IPR模板中定义的SLA标准;
¡     该SRv6 TE Policy的选路优先级最高,即srv6-policy color priority命令中指定的SRv6 TE Policy的选路优先级最小。
假设当前承载业务的SRv6 TE Policy最优候选路径中仅存在一个SID列表,且该SID列表仅存在一个转发出接口,则SRv6 TE Policy带宽利用率=该SRv6 TE Policy的转发出接口的带宽利用率。
注意事项
路径调优时,如果存在满足条件的多个SRv6 TE Policy的选路优先级相同,则业务流量在多个SRv6 TE Policy之间负载分担。
如果IPR模板中不存在同时满足上述条件的SRv6 TE Policy,则根据按照default match命令指定的默认转发策略进行转发业务流量。
# 配置IPR模板ipr1的带宽利用率的阈值上限为85%。
[Sysname-srv6-ipr-policy-ipr1] bandwidth-threshold upper 85
·     bandwidth sample
·     expect-bandwidth
·     refresh-period
·     switch-period
bestroute encap-type命令用来配置根据报文封装进行路由优选。
undo bestroute encap-type命令用来恢复缺省情况。
bestroute encap-type { mpls | srv6 } [ preferred ]
不根据报文封装进行路由优选。
BGP-VPN实例视图
mpls:优选MPLS封装的路由。
srv6:优选SRv6封装的路由。
preferred:提高报文封装在BGP选路规则中的优先级。
本命令的配置在BGP选路规则中的具体优先级顺序,请参见“三层技术-IP路由配置指导”中的“BGP概述”。
多次执行本命令,最后一次执行的命令生效。
# 配置优选SRv6封装的路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] bestroute encap-type srv6
1.1.10  bfd echo
bfd echo命令用来配置SRv6 TE Policy的echo报文方式的BFD检测功能。
undo bfd echo命令用来恢复缺省情况。
bfd echo { disable | enable [ source-ipv6 ipv6-address ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] [ reverse-path reverse-binding-sid ] }
undo bfd echo
未配置SRv6 TE Policy的echo报文方式的BFD检测功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的echo报文方式的BFD检测功能。
enable:开启SRv6 TE Policy的echo报文方式的BFD检测功能。
source-ipv6 ipv6-address:指定BFD会话的源IPv6地址。如果未指定本参数,则以SRv6 TE视图下的配置为准。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的BFD模板为准。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的备份BFD模板为准。
oam-sid sid:为BFD报文添加OAM SID,用于定位目的节点。sid为目的节点的SRv6 SID。如果未指定本参数,则不为BFD报文添加OAM SID。目前OAM SID建议配置为目的节点上的End SID。
encaps:配置BFD报文采用普通封装模式。
insert:配置BFD报文采用插入封装模式。
reverse-path:指定BFD报文的回程路径。如果未指定本参数,则根据IP路径将BFD报文转发回源节点。
reverse-binding-sid:使用反向BSID对应的SID列表作为BFD报文的回程路径。
通过echo报文方式的BFD检测SRv6 TE Policy时,需要为BFD报文封装SRv6 TE Policy的SID列表,封装模式包括:
·     Encaps方式:普通封装模式。在原始报文的基础上封装新的IPv6头和SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
·     Insert方式:插入封装模式。在原始IPv6报文头后插入SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
如果未指定encapsinsert参数,则采用bfd srv6-encapsulation-mode insert命令配置的封装模式。
通过echo报文方式的BFD检测SRv6 TE Policy时,缺省情况下,BFD回程报文均通过IP路径转发,一旦中间设备故障,则回程报文会被丢弃,导致BFD会话down,从而错误地认为所有SRv6 TE Policy的SID列表故障。为了解决上述问题,可以使BFD回程报文按照SRv6 TE Policy的指定SID列表转发,实现去程和回程路径一致的功能,或者叫BFD的来回路径一致功能。该功能的实现方式为:配置reverse-path reverse-binding-sid参数后,源节点将在BFD报文的插入SRH头,并在SRH中SL=1的位置封装反向BSID信息,该反向BSID可以通过explicit segment-listreverse-binding-sid命令来指定。尾节点收到BFD报文后,获取反向BSID信息。如果反向BSID和尾节点某个SRv6 TE Policy的本地BSID相同(该本地BSID可以通过local-binding-sid命令指定),则向BFD报文中插入新的SRH,沿本地BSID所属SRv6 TE Policy的SID列表转发。
指定reverse-path reverse-binding-sid参数后,BFD报文仅支持采用Insert方式,配置的encaps参数不生效。
通过echo报文方式的BFD检测SRv6 TE Policy,为BFD报文封装SRv6 TE Policy的SID列表时,不受SRv6 TE视图和SRv6 TE Policy视图下SRv6 TE Policy的封装模式命令的控制。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的echo报文方式的BFD检测功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
目前,支持通过BFD echo报文和SBFD两种方式检测SRv6 TE Policy。在同一SRv6 TE Policy下同时配置以上两种检测方式时,SBFD检测生效。
# 开启SRv6 TE Policy 1的echo报文方式的BFD检测功能,并指定BFD会话的源IPv6地址为11::11。
[Sysname-srv6-te-policy-1] bfd echo enable source-ipv6 11::11
·     bfd srv6-encapsulation-mode insert
·     explicit segment-list
·     display segment-routing ipv6 te bfd
·     srv6-policy bfd echo
bfd srv6-encapsulation-mode insert命令用来配置使用BFD或SBFD对SRv6转发路径进行故障检测时,BFD或SBFD报文的封装模式为Insert模式。
undo bfd srv6-encapsulation-mode insert命令用来恢复缺省情况。
使用BFD或SBFD对SRv6转发路径进行故障检测时,BFD或SBFD报文的封装模式为Encap模式。
使用BFD或SBFD对SRv6 TE Policy进行故障检测时,不同封装模式下的封装内容不同,具体如下:
·     Insert模式下,在IPv6基本头和BFD/SBFD报文之间插入SRH,该SRH中包含SRv6 TE Policy的SID列表。如果SID列表长度为0,则不插入SRH。
·     Encap模式下,在原始报文基础上添加新的IPv6基本头和SRH,添加的SRH中包含SRv6 TE Policy的SID列表。如果SID列表长度为0,则不添加SRH。
当BFD或SBFD会话已建立,再执行本命令切换BFD或SBFD报文的封装模式时,切换后的封装方式不会立即生效,请先执行bfd echosbfd命令指定disable关键字关闭SRv6 TE Policy的BFD或SBFD检测功能,再执行bfd echosbfd命令开启SRv6 TE Policy的BFD或SBFD检测功能。
# 配置使用BFD/SBFD对SRv6转发路径进行故障检测时,BFD/SBFD报文的封装模式为Insert模式。
[Sysname] bfd srv6-encapsulation-mode insert
·     bfd echo
·     sbfd
binding-sid命令用来配置SRv6 TE Policy组的BSID。
undo binding-sid命令用来删除SRv6 TE Policy组的BSID。
binding-sid ipv6 ipv6-address
undo binding-sid
SRv6 TE Policy组不存在BSID。
SRv6 TE Policy组视图
ipv6 ipv6-address:指定BSID为IPv6地址。ipv6-address为IPv6地址。
BSID(Binding SID,绑定SID)是指入节点的SID。通过BSID可以将流量引入该SRv6 TE Policy组。
SRv6 TE Policy组的BSID目前仅支持通过本命令手工配置。
本命令配置的BSID必须在SRv6 TE视图下引用的Locator的静态段范围内。否则,BSID对应的SRv6 TE Policy组不能用于报文转发。
# 配置SRv6 TE Policy组的BSID为1000::1。
[Sysname-srv6-te] policy-group 1
[Sysname-srv6-te-policy-group-1] binding-sid ipv6 1000::1
binding-sid命令用来配置BSID。
undo binding-sid命令用来删除BSID。
undo binding-sid
不存在BSID。
SRv6 TE Policy视图
ipv6 ipv6-address:配置BSID为IPv6地址。ipv6-address为IPv6地址。
BSID(Binding SID,绑定SID)是指入节点的SID。通过BSID、Color和Endpoint可以唯一标识一个SRv6 TE Policy。
BSID获取方式如下:
·     手工配置:通过本命令手工配置BSID。
·     动态获取:SRv6 TE Policy下仅配置Color和Endpoint时,SRv6 TE Policy会自动申请一个BSID。
手工配置优先生效。
本命令配置的BSID必须在SRv6 TE视图下引用的Locator的静态段范围内。否则,BSID对应的SRv6 TE Policy不能用于报文转发。
# 为名称为srv6policy的SRv6 TE Policy配置BSID为1000::1。
[Sysname-segment-routing-ipv6] traffic engineering
[Sysname-srv6-te-policy-srv6policy] binding-sid ipv6 1000::1
bypass enable命令用来开启SRv6 TE Policy的备份路径功能。
undo bypass enable命令用来关闭SRv6 TE Policy的备份路径功能。
bypass enable
undo bypass enable
SRv6 TE Policy的备份路径功能处于关闭状态。
SRv6 TE Policy视图
当本节点作为SRv6 TE Policy的源节点时,如果SID列表中的第一个SID不可达,则源节点会将SRv6 TE Policy置为down状态,既无法通过该SRv6 TE Policy转发报文,也无法触发SRv6 TE FRR。
开启SRv6 TE Policy的备份路径功能,可以解决上述问题。开启本功能后,如果SRv6 TE Policy的SID列表中的第一个SID不可达,则设备生成一条目的地址为SID列表中第一个SID、出接口为NULL0的路由,保证该SRv6 TE Policy处于up状态,以触发SRv6 TE FRR。
# 开启SRv6 TE Policy的备份路径功能。
[Sysname-srv6–te] policy 1
[Sysname-srv6–te-policy-1] bypass enable
·     sr-te frr enable
candidate-paths命令用来创建SRv6 TE Policy候选路径,并进入SRv6 TE Policy候选路径视图。如果SRv6 TE Policy候选路径已经存在,则直接进入SRv6 TE Policy候选路径视图。
undo candidate-paths命令用来删除SRv6 TE Policy候选路径,及SRv6 TE Policy候选路径视图下的所有配置。
candidate-paths
不存在SRv6 TE Policy候选路径。
SRv6 TE Policy视图
# 创建SRv6 TE Policy候选路径,并进入SRv6 TE Policy候选路径视图。
[Sysname-srv6-te-policy-srv6policy] candidate-paths
[Sysname-srv6-te-policy-srv6policy-path]
cmi threshold命令用来配置IPR模板的CMI(Composite Measure Indicator,综合度量指标)标准。
undo cmi threshold命令用来恢复缺省情况。
cmi threshold threshold-value
undo cmi threshold
IPR模板的CMI标准为9000。
SRv6 TE IPR模板视图
threshold-value:IPR模板的CMI标准,取值范围为0~9000。
CMI(Composite Measure Indicator,综合度量指标)是衡量业务质量的综合指标。业务的CMI=时延(毫秒)+抖动(毫秒)+丢包率(‰)。因此,CMI值设置得越小表明链路质量要求越高。
只有SRv6 TE Policy的iFIT丢包率、时延和抖动测量功能检测到SRv6 TE Policy的iFIT丢包率、时延和抖动数值求和后不超过本命令设置的CMI标准,则该SRv6 TE Policy才能作为备选的转发路径,参与最优SRv6 TE Policy选路过程。
# 配置IPR模板ipr1的CMI标准为300。
[Sysname-srv6-ipr-policy-ipr1] cmi threshold 300
color end-point命令用来配置SRv6 TE Policy的Color属性和目的节点地址。
undo color命令用来删除SRv6 TE Policy的Color属性和目的节点地址
color color-value end-point ipv6 ipv6-address
undo color
未配置SRv6 TE Policy的Color属性和目的节点地址。
SRv6 TE Policy视图
color-value:SRv6 TE Policy的Color属性,取值范围为0~4294967295。
ipv6-address:SRv6 TE Policy目的节点的IPv6地址。
Color为转发路径的Color属性,用于在相同的源和目的节点之间区分不同的SRv6 TE Policy;Endpoint为SRv6 TE Policy目的节点的IPv6地址。通过BSID、Color和Endpoint可以唯一标识一个SRv6 TE Policy。
不同SRv6 TE Policy不能配置相同的Color和目的节点地址。
# 配置SRv6 TE Policy的Color属性为20、目的节点的IPv6地址为1000::1。
[Sysname-srv6-te-policy-srv6policy] color 20 end-point ipv6 1000::1
color match dscp命令用来配置SRv6 TE Policy组的ODN模板中Color和DSCP的映射关系。
undo color match dscp命令用来删除SRv6 TE Policy组的ODN模板中Color和DSCP的映射关系。
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 }
color color-value match dscp { ipv4 | ipv6 } default
undo color color-value match dscp { ipv4 | ipv6 } default
未配置SRv6 TE Policy组的ODN模板中Color和DSCP映射关系。
DSCP转发类型视图
color-value:指定SRv6 TE Policy的Color值,取值范围为0~4294967295。
ipv4:将IPv4报文引流到指定的SRv6 TE Policy。
ipv6:将IPv6报文引流到指定的SRv6 TE Policy。
dscp-value-list:DSCP列表,表示方式为dscp-value-list = { dscp-value1 [ to dscp-value2 ] } &<1-32>。其中,dscp-value表示DSCP值,取值范围为0~63。&<1-32>表示前面的参数最多可以输入32次。dscp-value2的值要大于等于dscp-value1的值。
default:配置缺省的Color和DSCP的映射关系,即未匹配DSCP值的报文均通过指定的SRv6 TE Policy转发。通过本参数来指定某个Color对应的SRv6 TE Policy作为指定地址族报文的缺省SRv6 TE Policy。
功能简介
通过ODN模板创建的SRv6 TE Policy组中通常存在多个Endpoint相同但Color不同的SRv6 TE Policy隧道,当流量被引入到SRv6 TE Policy组转发后,通过本命令,可以配置指定DSCP和SRv6 TE Policy的Color的映射关系,形成DSCP->Color->SRv6 TE Policy的关联关系,从而将携带指定DSCP值的报文通过对应的SRv6 TE Policy转发。
工作机制
流量引入SRv6 TE Policy组后,根据报文携带的DSCP值以及color match dscp命令和drop-upon-mismatch enable命令的配置情况,按如下顺序依次查找匹配关系,若查找到和报文匹配的转发策略,且该转发策略有效,则使用该转发策略来转发报文,若未查找到和报文匹配的转发策略或该转发策略无效,则继续下一步查找:
(1)     查找color match dscp命令为本地址族指定的DSCP和转发策略的映射关系,根据匹配的SRv6 TE Policy转发流量。
(2)     查找color match dscp default命令为本地址族指定的缺省SRv6 TE Policy,根据缺省的SRv6 TE Policy转发流量。
(3)     查找color match dscp default命令为另一地址族指定的缺省SRv6 TE Policy,根据缺省的SRv6 TE Policy转发流量。
(4)     根据drop-upon-mismatch enable命令的配置情况,确定流量处理方式:
¡     如果配置了drop-upon-mismatch enable命令,则直接丢弃报文。
¡     如果未配置drop-upon-mismatch enable命令,但SRv6 TE Policy组内配置了本地址族DSCP和Color的映射关系,则查找DSCP值最小的映射关系,最小DSCP对应的SRv6 TE Policy有效,采用该映射关系中指定的SRv6 TE Policy转发报文。如果不存在本地址族DSCP和Color的映射关系,则查找另一地址族下配置的Color和DSCP映射关系,且最小DSCP对应的SRv6 TE Policy有效,则采用该SRv6 TE Policy转发。
注意事项
一个SRv6 TE Policy组内,可以分别为IPv4和IPv6地址族指定不同的DSCP引流规则,但是对于同一个地址族的报文,每个DSCP只能关联一个SRv6 TE Policy。
一个SRv6 TE Policy组内,一个地址族只能有一个缺省SRv6 TE Policy。
# 配置SRv6 TE Policy组的ODN模板中Color和DSCP映射关系:将DSCP值为30的IPv4报文引流到Color 20对应的SRv6 TE Policy上。
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] forward-type dscp
[Sysname-srv6-te-odn-group-1-dscp] color 20 match dscp ipv4 30
·     drop-upon-mismatch enable
color match dscp命令用来配置SRv6 TE Policy组的Color和DSCP映射关系。
undo color match dscp命令用来删除SRv6 TE Policy组的Color和DSCP映射关系。
undo color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 } [ default ]
未配置SRv6 TE Policy组的Color和DSCP映射关系,即不能通过该SRv6 TE Policy组转发流量。
SRv6 TE Policy组视图
color-value:指定SRv6 TE Policy组的Color值,取值范围为0~4294967295。
ipv4:将IPv4报文引流到指定的SRv6 TE Policy的DSCP值。
ipv6:将IPv6报文引流到指定的SRv6 TE Policy的DSCP值。
default:配置缺省的Color和DSCP映射关系,即未匹配DSCP值的报文均通过的指定SRv6 TE Policy转发。
功能简介
工作机制
流量引入SRv6 TE Policy组后,根据报文携带的DSCP值以及color match dscp命令、和drop-upon-mismatch enable命令的配置情况,按如下顺序依次查找匹配关系,若查找到和报文匹配的转发策略,且该转发策略有效,则使用该转发策略来转发报文,若未查找到和报文匹配的转发策略或该转发策略无效,则继续下一步查找:
注意事项
IPv4和IPv6地址族可以分别指定Color与DSCP的映射关系,但是对于同一个地址族的报文,每个DSCP值仅支持关联一个Color值。
只有SRv6 TE Policy有效时,才能将其Color值与DSCP关联。
# 配置SRv6 TE Policy组的Color和DSCP映射关系:将DSCP值为30的IPv4报文引流到Color 20对应的SRv6 TE Policy上。
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] color 20 match dscp ipv4 30
default-color命令用来配置公网业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值。
undo default-color命令用来恢复缺省情况。
default-color color-value
undo default-color
未配置缺省Color值。
公网实例IPv4地址族视图
公网实例IPv6地址族视图
color-value:缺省Color值,取值范围为0~4294967295。
本地PE从远端PE接收到公网实例的路由后,如果该路由未携带Color扩展团体属性,且没有通过路由策略为路由添加Color属性,则将该路由迭代到SRv6 TE Policy隧道时,会使用本命令配置的缺省Color值来查找匹配的SRv6 TE Policy,以实现SRv6 TE Policy引流。
本命令只对从远端PE学习到的公网实例路由生效。
本命令配置的Color值仅在SRv6 TE Policy隧道引流时生效,路由向外发布时不生效。
# 在公网实例IPv4地址族视图下,配置公网业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值为100。
[Sysname] ip public-instance
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4] default-color 100
default-color命令用来配置L3VPN业务迭代SRv6 TE Policy隧道时使用指定的缺省Color值。
default-color color-value [ evpn ]
undo default-color [ evpn ]
未配置缺省Color值。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
evpn:表示EVPN L3VPN路由迭代SRv6 TE Policy隧道时使用指定的缺省Color值。不指定该参数时表示MPLS L3VPN路由迭代SRv6 TE Policy隧道时都使用指定缺省Color值。
本地PE从远端PE接收到VPNv4、VPNv6或EVPN IP prefix路由后,如果该路由未携带Color扩展团体属性,且没有通过路由策略为路由添加Color属性,则将该路由迭代到SRv6 TE Policy隧道时,会使用本命令配置的缺省Color值来查找匹配的SRv6 TE Policy,以实现SRv6 TE Policy引流。
本命令只对从远端PE学习到的VPN路由生效。
# 在VPN实例vpn1的IPv4址族视图下,配置EVPN L3VPN业务迭代SRv6 TE Policy隧道时使用的缺省Color值为100。
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1] default-color 100 evpn
default match命令用来配置根据APN ID转发的缺省转发策略。
undo default match命令用来删除根据APN ID转发的缺省转发策略。
default match best-effort
default match srv6-policy color color-value
undo default match { best-effort | srv6-policy }
未配置根据APN ID转发的缺省转发策略。
SRv6 TE Policy组视图
APN ID转发类型视图
best-effort:指定SRv6 BE方式作为缺省转发策略。
srv6-policy color color-value:将指定Color的SRv6 TE Policy作为缺省转发策略,其中color-value表示SRv6 TE Policy的Color属性,取值范围为0~4294967295。
配置准备
只有配置了SRv6 TE Policy组的转发类型为APN ID,即SRv6 TE Policy组视图或SRv6 TE ODN Policy组视图下执行forward-type apn-id命令后,本功能才生效。
应用场景
当业务流量被引入到SRv6 TE Policy组中转发时,设备可以根据IPv6报文的APN ID标识,将流量引入到指定Color对应的SRv6 TE Policy中转发,或者采用SRv6 BE方式转发报文。default match命令指定的缺省转发策略可以用于如下场景:
·     当不同类型的业务流量通过同一个SRv6 TE Policy或者通过SRv6 BE方式转发就能满足业务的服务质量需求时,可以配置本功能来设置缺省的转发策略,通过缺省的转发策略转发APN ID标识的业务流量。
·     当设备收到的报文未携带APN ID、报文的APN ID未匹配index apn-id match命令指定的任何映射关系或者报文的APN ID匹配的SRv6 TE Policy/SRv6 BE无效时,也可以通过缺省的转发策略转发APN ID标识的业务流量。
工作机制
通过SRv6 BE方式转发报文时,设备将为报文封装新的IPv6报文头,其中新IPv6报文头中的目的地址为SRv6 TE Policy Group尾节点上为公网或私网分配的VPN SID,封装后的报文查找IPv6路由表转发。
当设备收到的报文未携带APN ID、报文的APN ID未匹配任何映射关系或者报文的APN ID匹配的SRv6 TE Policy/SRv6 BE无效时,依次按照如下优选顺序选择报文转发方式:
(1)     如果已执行default match命令配置了通过缺省的SRv6 TE Policy转发报文,且该SRv6 TE Policy有效,则优先采用该SRv6 TE Policy转发报文。
(2)     如果已执行default match命令配置了通过SRv6 BE转发报文,且SRv6 BE有效,则采用SRv6 BE方式转发报文。
(3)     未配置default match命令,或者default match命令配置的转发策略无效时,根据drop-upon-mismatch enable命令的配置情况,流量处理方式为:
¡     如果配置了drop-upon-mismatch enable命令,则流量将被直接丢弃。
¡     如果未配置drop-upon-mismatch enable命令,但通过本命令配置了APN ID和SRv6 TE Policy或SRv6 BE的映射关系,则查找其中SRv6 TE Policy或SRv6 BE有效且APN ID最小的映射关系,采用该映射关系中指定的SRv6 TE Policy或SRv6 BE转发报文。
注意事项
一个SRv6 TE Policy组内,只能指定一个SRv6 TE Policy作为缺省转发策略。
可以同时指定SRv6 TE Policy和SRv6 BE方式作为缺省转发策略,但优先使用SRv6 TE Policy转发报文。
# 在手工创建的SRv6 TE Policy组中,将Color 20对应的SRv6 TE Policy作为根据APN ID转发的缺省转发策略。
[Sysname-srv6-te-policy-group-10] forward-type apn-id
[Sysname-srv6-te-policy-group-10] default match srv6-policy color 20
# 在ODN模板创建的SRv6 TE Policy组中,将Color 20对应的SRv6 TE Policy作为根据APN ID转发的缺省转发策略。
[Sysname-srv6-te-odn-group-1] forward-type apn-id
[Sysname-srv6-te-odn-group-1-apn-id] default match srv6-policy color 20
·     index apn-id match
·     forward-type (SRv6 TE Policy group view)
·     forward-type (SRv6 TE ODN Policy group view)
default match命令用来配置基于TE Class ID转发的默认转发策略。
undo default match命令用来删除基于TE Class ID转发的默认转发策略。
undo default match best-effort
default match { ipr-policy ipr-name | srv6-policy color color-value }
undo default match { ipr-policy ipr-name | srv6-policy color color-value }
未配置基于TE Class ID转发的默认转发策略。
SRv6 TE Policy组视图
TE Class转发类型视图
best-effort:表示TE Class ID标识的流量默认转发方式为SRv6 BE方式,即为原始报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
ipr-policy ipr-name:表示TE Class ID标识的流量默认转发方式为IPR方式,其中ipr-name表示IPR模板的名称,为1~31个字符的字符串,区分大小写。
srv6-policy color color-value:表示TE Class ID标识的流量默认转发方式为通过指定Color值对应的SRv6 TE Policy转发,其中color-value表示SRv6 TE Policy的Color属性,取值范围为0~4294967295。
请先执行forward-type te-class命令配置SRv6 TE Policy组的转发类型为根据TE Class ID转发流量,本功能才能生效。
配置本功能后,当业务流量被引入到SRv6 TE Policy组中转发时,如果未设置流量的TE Class ID、流量的TE Class ID未关联到index te-class match命令中指定的转发策略或者TE Class ID关联到的转发策略无效时,则设备将这类流量按照默认转发策略转发。最多可以同时存在两个默认转发策略,但IPR方式转发和SRv6 TE Policy转发不可以同时存在。流量按照默认转发策略转发时,按如下优先顺序选取转发策略:
(1)     如果配置了默认转发方式为通过指定Color值对应的SRv6 TE Policy转发或者配置了默认转发方式为IPR方式,且用于转发的SRv6 TE Policy有效,则设备将流量引入到该SRv6 TE Policy中转发。
(2)     如果配置了默认转发方式为SRv6 BE方式,且SRv6 BE有效,则设备为报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
¡     如果未配置drop-upon-mismatch enable命令,但通过本命令配置了多个TE Class ID和IPR模板、SRv6 TE Policy或SRv6 BE的映射关系,则查找其中转发路径有效且索引值最小的映射关系,采用该映射关系中的SRv6 TE Policy或SRv6 BE转发报文。
# 配置基于TE Class ID转发的默认转发策略为:通过Color属性为8的SRv6 TE Policy转发流量。
[Sysname-srv6-te-policy-group-1] forward-type te-class
[Sysname-srv6-te-policy-group-1] default match srv6-policy color 8
delay threshold命令用来配置IPR模板的时延标准。
undo delay threshold命令用来恢复缺省情况。
delay threshold time-value
IPR模板的时延标准为5000毫秒。
SRv6 TE IPR模板视图
time-value:IPR模板的时延标准,取值范围为0~5000,单位为毫秒。
只有SRv6 TE Policy的iFIT时延和抖动测量功能检测到SRv6 TE Policy的时延不超过本命令设置的时延标准,则该SRv6 TE Policy才能作为备选的转发路径,参与最优SRv6 TE Policy选路过程。
如果SRv6 TE Policy的最优候选路径下存在多条带权重的有效Segment List,智能策略路由计算SRv6 TE Policy的时延是否符合标准时,则设备将该SRv6 TE Policy的最优候选路径下的所有有效Segment List的iFIT时延加权值作为该SRv6 TE Policy的时延。
# 配置IPR模板ipr1的时延阈值为50毫秒。
[Sysname-srv6-ipr-policy-ipr1] delay threshold 50
1.1.25  description
description命令用来配置SRv6 TE Policy组ODN模板的描述信息。
undo description命令用来恢复缺省情况。
未配置SRv6 TE Policy组ODN模板的描述信息。
text:SRv6 TE Policy组ODN模板的描述信息,为1~242个字符的字符串,区分大小写。
为了方便记忆和管理,可以配置SRv6 TE Policy组ODN模板的描述信息。
# 配置SRv6 TE Policy组ODN模板的描述信息。
[Sysname-srv6-te-odn-group-1] description abc
display bgp mirror remote-sid命令用来显示通过Mirror SID保护的远端SRv6 SID。
display bgp [ instance instance-name ] mirror remote-sid [ end-dt4 | end-dt46 | end-dt6 ] [ sid ]
end-dt4:End.DT4类型的远端SRv6 SID。
end-dt46:End.DT46类型的远端SRv6 SID。
end-dt6:End.DT6类型的远端SRv6 SID。
sid:显示指定的远端SRv6 SID信息。
通过本命令可以显示MPLS L3VPN over SRv6和EVPN L3VPN over SRv6组网中通过Mirror SID保护的远端SRv6 SID。
如果未指定任何参数,则显示所有通过Mirror SID保护的远端SRv6 SID的信息。
# 显示L3VPN over SRv6网络中所有通过Mirror SID保护的远端SRv6 SID的信息。
<Sysname> display bgp mirror remote-sid
Remote SID: 3001::1:0:0
Remote SID type: End.DT4
Mirror locator: 3001::1/64
VPN instance name: vrf1
Remote SID: 3001::1:0:1
Remote SID type: End.DT6
VPN instance name: vrf2
Remote SID: 1111:2222:3333:4444::1
Mirror locator: 1111:2222:3333:4444:5555:6666:7777:8888/64
表1-1 display bgp mirror remote-sid命令简要显示信息描述表
Remote SID
远端SRv6 SID
Remote SID type
远端SRv6 SID的类型:
·     End.DT4
·     End.DT6
·     End.DT46
Mirror locator
远端SRv6 SID所属的Locator的IPv6前缀和前缀长度
VPN instance name
与远端SRv6 SID关联的VPN实例名称
Remaining retention time
远端SRv6 SID与VPN实例映射表的剩余的延迟删除时间,单位为秒
display bgp routing-table ipv6 sr-policy命令用来显示BGP IPv6 SR Policy路由信息。
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ peer ipv6-address { advertised-routes | received-routes } ] [ sr-policy-prefix [ advertise-info ]
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ peer ipv6-address { advertised-routes | received-routes } ] [ statistics | color color-value | end-point ipv6 ipv6-address ] *
display bgp [ instance instance-name ] routing-table ipv6 sr-policy  color color-value end-point ipv6 ipv6-address
sr-policy-prefix:显示指定BGP IPv6 SR Policy路由的详细信息。sr-policy-prefix组成格式为sr-policy-route/route-length,为1~512个字符的字符串,不区分大小写。其中,sr-policy-route表示BGP IPv6 SR Policy路由信息,route-length表示路由信息的长度。
color color-value:显示指定Color属性的BGP IPv6 SR Policy路由的详细信息。color-value表示Color属性值,取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的地址的BGP IPv6 SR Policy路由的详细信息。ipv6-address表示目的节点的IPv6地址。
advertise-info:显示BGP IPv6 SR Policy路由的通告信息。
peer ipv6-address:显示向指定的对等体发布或者从指定的对等体收到的BGP IPv6 SR Policy路由信息。ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示路由的统计信息。
如果没有指定任何参数,则显示所有BGP IPv6 SR Policy路由的简要信息。
# 显示所有BGP IPv6 SR Policy路由的简要信息。
<Sysname> display bgp routing-table ipv6 sr-policy
 Total number of routes: 1
 Status codes: * - valid, > - best, d - dampened, h - history
               a – additional-path
>i Network : [46][46][8::8]/192
   NextHop : 1::2                                  LocPrf    : 100
   PrefVal : 0                                     MED       : 0
   Path/Ogn: i
表1-2 display bgp routing-table ipv6 sr-policy命令简要显示信息描述表
路由总数
BGP local router ID
本地的路由器ID
Status codes
路由状态代码:
·     * – valid:合法路由
·     > – best:普通优选路由
·     d - dampened:震荡抑制路由
·     h – history:历史路由
·     s – suppressed:聚合抑制路由
·     S – stale:过期路由
·     i – internal:内部路由
·     e – external:外部路由
·     a – additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? – incomplete:表示路由的来源无法确定
Network
BGP IPv6 SR Policy路由,由以下三部分组成:
·     SRv6 TE Policy候选路径的优先级
·     SRv6 TE Policy的Color属性值
·     目的节点IPv6地址
NextHop
下一跳IP地址
LocPrf
本地优先级
PrefVal
路由首选值
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性,其中:
·     AS_PATH属性记录了此路由经过的所有AS,可以避免路由环路的出现
·     ORIGIN属性标记了此BGP路由如何生成的
# 显示BGP IPv6 SR Policy路由[46][46][8::8]/192的详细信息。
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192
BGP local router ID: 5.5.5.1
Local AS number: 100
Paths: 1 available, 1 best
 BGP routing table information of [46][46][8::8]/192
 Imported route.
 Original nexthop: ::
 Output interface: p1
 Route age       : 19h45m02s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, localpref 100, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel encapsulation info:
    Type: 15 (SR policy)
     Policy name: p1
     Binding SID: 2::6
     Preference: 100
     Path: 1
      Weight: 1
      SIDs: {2::2}
表1-3 display bgp routing-table ipv6 sr-policy命令详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
BGP IPv6 SR Policy路由[46][46][8::8]/192的路由表项信息
Imported route
引入的路由
From
发布该路由的BGP对等体的IP地址
Rely Nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
Output interface
出接口
Route age
路由最后一次更新到目前持续的时间
OutLabel
路由的出标签值
RxPathID
接收到的路由的Add-Path ID值
TxPathID
发送的路由的Add-Path ID值
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     delay:表示该路由优选时将被延迟(仅在显示路由详细信息时显示本字段)
·     not preferred for reason:路由未被优选的原因,reason的具体内容请参见表1-4
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的QoS本地ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
隧道封装信息
隧道封装类型,目前取值只能为15,表示SR-TE policy
Policy name
SRv6-TE policy名称
Preference
候选路径优先级
Binding SID
SRv6 TE Policy的绑定SID
Path
候选路径的编号
Weight
权重
Local Path Segment
(暂不支持)SID列表所携带本地Path Segment SID,可以用于SBFD检测SRv6 TE Policy时保证来回路径一致
Reverse Path Segment
(暂不支持)SID列表所携带反向Path Segment SID,可以用于SBFD检测SRv6 TE Policy时保证来回路径一致
SIDs
SID列表
当SID为G-SID时,显示格式为{sid-value, coc32, prefix-length}。其中,sid-value为SID值;prefix-length为公共前缀长度
表1-4 路由未被优选的原因
原因
preferred-value
优选首选值最大的路由
local-preference
优选本地优先级最高的路由
as-path
优选AS路径最短的路由
origin
依次选择ORIGIN类型为IGP、EGP、Incomplete的路由
med
优选MED值最低的路由
remote-route
依次选择从EBGP、联盟EBGP、联盟IBGP、IBGP学来的路由
igp-cost
优选IGP Metric值最小的路由
relydepth
优选迭代深度值小的路由
rfc5004
rfc5004规则:如果当前的最优路由为EBGP路由,则BGP路由器收到来自不同的EBGP邻居的路由后,不会改变最优路由
router-id
优选Router ID最小的路由器发布的路由。如果路由包含RR属性,那么在路由选择过程中,就用ORIGINATOR_ID来替代Router ID
cluster-list
优选CLUSTER_LIST长度最短的路由
peer-address
优选IP地址最小的对等体发布的路由
received
优选最先学习到的路由
# 显示BGP IPv6 SR Policy路由[46][46][8::8]/192的通告信息。
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192 advertise-info
 BGP local router ID: 2.2.2.2
 Local AS number: 1
 Paths:   1 best
 BGP routing table information of [46][46][8::8]/192(TxPathID:0):
 Advertised to peers (2 in total):
    1::1
    3::3
表1-5 display bgp routing-table ipv6 sr-policy advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0)
BGP IPv6 SR Policy路由[46][46][8::8]的通告信息,TxPathID表示发送的路由的Add-Path ID值
该路由已经向哪些对等体发送,以及对等体的数目
# 显示向对等体2::2发布的BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 advertised-routes statistics
 Advertised routes total: 2
# 显示从对等体2::2收到的BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 received-routes statistics
 Received routes total: 1
表1-6 display bgp routing-table ipv6 sr-policy peer statistics命令显示信息描述表
向指定对等体发布的路由总数
从指定对等体收到的路由总数
# 显示BGP IPv6 SR Policy路由的统计信息。
<Sysname> display bgp routing-table ipv6 sr-policy statistics
 Total number of routes: 3
表1-7 display bgp routing-table ipv6 sr-policy statistics命令显示信息描述表
路由总数
display segment-routing ipv6 te bfd命令用来显示SRv6 TE Policy的BFD信息。
display segment-routing ipv6 te bfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down:显示状态为down的SRv6 TE Policy的BFD信息。
policy:显示指定SRv6 TE Policy的BFD信息。
color color-value:指定Color属性,取值范围为0~4294967295。
end-point ipv6 ipv6-address:指定目的节点,ipv6-address表示目的节点的IPv6地址。
name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
up:显示状态为up的SRv6 TE Policy的BFD信息。
如果未指定downpolicyup参数,则显示所有SRv6 TE Policy的BFD信息。
# 显示所有SRv6 TE Policy的BFD信息。
<Sysname> display segment-routing ipv6 te policy bfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Up
   Nid: 2149580801
   BFD type: ECHO
   Source IPv6: 1::1
   State: Up
   Timer: 37
   VPN index: 1
   Template name: abc
表1-8 display segment-routing ipv6 te policy bfd命令显示信息描述表
Color
Endpoint
SRv6 TE Policy的目的节点的IPv6地址
Policy name
SRv6 TE Policy的名称
BFD会话状态:
·     Up
·     Down
·     Delete
Nid
SID列表的转发表项索引
BFD type
BFD类型,目前仅支持BFD echo
Source IPv6
BFD会话的源IPv6地址
Timer
BFD会话定时器,单位为秒
VPN index
VPN实例索引
Template name
Echo方式BFD的模板名
display segment-routing ipv6 te forwarding命令用来显示SRv6 TE的转发信息。
display segment-routing ipv6 te forwarding [ policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } ] [ verbose ]
policy:显示指定SRv6 TE Policy的转发信息。如果未指定本参数,则显示所有SRv6 TE Policy的转发信息。
name policy-name:显示指定名称的SRv6 TE Policy的转发信息。policy-name为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
color color-value:显示指定Color属性的SRv6 TE Policy的转发信息。color-value表示Color属性值,取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的节点的SRv6 TE Policy的转发信息。ipv6-address表示目的节点的IPv6地址。
verbose:显示SRv6 TE Policy的详细转发信息。如果未指定本参数,则显示SRv6 TE Policy的简要转发信息。
# 显示所有SRv6 TE Policy的简要转发信息。
<Sysname> display segment-routing ipv6 te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
 Binding SID: 8000::1
 Forwarding index: 2150629377
 Main path:
   Seglist ID: 1
     Seglist forwarding index: 2149580801
     Weight: 1
     Outgoing forwarding index: 2148532225
       Interface: GE1/0/1
       Nexthop: FE80::6CCE:CBFF:FE91:206
 Backup path:
   Seglist ID: 2
     Seglist forwarding index: 2149580802
       Weight: 1
       Outgoing forwarding index: 2148532226
         Interface: GE1/0/2
         Nexthop: FE80::6CCE:CBFF:FE91:207
# 显示所有SRv6 TE Policy的详细转发信息。
<Sysname> display segment-routing ipv6 te forwarding verbose
 Inbound statistics:
   Total octets: 525
   Total packets: 1
   Erroneous packets: 0
   Dropped packets: 0
 Outbound statistics:
   Total octets: 750
   Total packets: 1
   Dropped packets: 0
 Main path:
   Seglist ID: 1
     Weight: 1
       Total octets: 750
       Total packets: 1
       Dropped packets: 0
       Interface: GE1/0/1
         Path ID: 1
         SID list: {44::44, 45::45}
         Total octets: 750
         Total packets: 1
         Dropped packets: 0
 Backup path:
   Seglist ID: 2
     Weight: 1
         Interface: GE1/0/2
           Path ID: 2
           SID list: {44::44, 45::47}
表1-9 display segment-routing ipv6 te forwarding命令显示信息描述表
SRv6 TE转发表项总数
Policy name/ID
SRv6 TE Policy的名称/ID
Binding SID
入节点的SID
Forwarding index
SRv6 TE Policy的转发表项索引
Inbound statistics
入方向流量统计信息,记录了指定BSID收到的总流量
Total octets
转发的字节总数
Total packets
转发的总报文数
Erroneous packets
错误报文个数
Dropped packets
丢弃报文个数
Outbound statistics
出方向流量统计信息
octets
字节数
packets
报文数
errors
错误包数
dropped packets
丢弃包数
Main path
流量转发的主路径
Backup path
流量转发的备份路径
Seglist ID
SID列表ID
SID列表的转发表项索引
Weight
SID列表的权重
SID列表中首地址的下一跳转发表项索引
出接口简称
Nexthop
下一跳IPv6地址
Path ID
SRv6 TE Policy为SID列表分配的ID
SID list
SID列表
SID
节点的SID,即IPv6地址
Common prefix length
表示下一个SID的公共前缀长度,如果下一个SID为非压缩的SID,则公共前缀长度取值为0
G-SID length
表示下一个G-SID长度,如果下一个SID为非压缩的SID,则该SID长度取值为128
display segment-routing ipv6 te ipr命令用来显示IPR模板的信息。
display segment-routing ipv6 te ipr [ name ipr-name ] [ end-point ipv6 ipv6-address ]
name ipr-name:显示指定IPR模板的信息,ipr-name表示IPR模板的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有IPR模板的信息。
end-point ipv6 ipv6-address:显示指定Endpoint的SRv6 TE Policy组的引用的IPR模板的信息。
# 显示名称为ipr1的IPR模板的信息。
<Sysname> display segment-routing ipv6 te ipr name ipr1
IPR policy name: ipr1
Delay threshold      : 1000          Jitter threshold     : 1000
Packet loss threshold: 300           CMI threshold        : 5000
Bandwidth sample     : Enabled       Bandwidth upper      : 80
Bandwidth lower      : 70            Bandwidth switchback : 70
Expect bandwidth     : 1000          Schedule priority    : 10
Switch period        : 6             WTR period           : 6
Color                : 1             Priority             : 1
Color                : 2             Priority             : 2
Color                : 3             Priority             : 1
Color                : 4             Priority             : 2
Instance:
  Group ID       : 1                 Endpoint : 1::1
  Selected color : 2 3 4
  Group ID       : 2                 Endpoint : 2::2
表1-10 display segment-routing ipv6 te ipr命令显示信息描述表
IPR Policy Name
IPR模板名称
Delay threshold
IPR模板的时延标准,单位为毫秒
Jitter threshold
IPR模板的抖动标准,单位为毫秒
IPR模板的丢包率标准,单位为‰
CMI threshold
IPR模板业务的CMI(Composite Measure Indicator,综合度量指标)标准
Switch period
IPR模板中不同SRv6 TE Policy之间的切换时延,单位为秒
WTR period
IPR模板中的回切时延,单位为秒
Bandwidth sample
带宽采样功能开关
·     Enabled:表示开启带宽采样功能
·     Disabled:表示关闭带宽采样功能
Bandwidth upper
IPR模板的带宽利用率的阈值上限,单位为%
Bandwidth lower
带宽阈值下限,单位为%
IPR模板的业务回切带宽利用率阈值,单位为%
Expect bandwidth
期望带宽值,单位为kbps,-代表该IPR模板未配置期望带宽
Schedule priority
IPR模板的切换调度优先级,-代表该IPR模板未配置切换调度优先级
Color
IPR模板中配置的SRv6 TE Policy的Color属性
Priority
IPR模板中配置的SRv6 TE Policy的Color属性对应的选路优先级
Instance
IPR模板被SRv6 TE Policy组引用的实例信息
Group ID
引用该IPR模板的SRv6 TE Policy组
Endpoint
SRv6 TE Policy组的目的节点地址
Selected color
根据IPR模板计算出被优选的SRv6 TE Policy的Color属性
·     ipr-policy
display segment-routing ipv6 te ipr bandwidth interface命令用来显示SRv6 TE Policy转发出接口的带宽使用信息。
display segment-routing ipv6 te ipr bandwidth interface [ interface-type interface-number ] [ verbose ]
interface-type interface-number:显示指定SRv6 TE Policy转发出接口的信息。如果未指定本参数,将显示所有SRv6 TE Policy转发出接口的信息。
verbose:显示SRv6 TE Policy转发出接口带宽使用的详细信息。如果未指定本参数,将显示SRv6 TE Policy转发出接口带宽使用的简要信息。
# 显示所有SRv6 TE Policy转发出接口的带宽使用的简要信息。
<Sysname> display segment-routing ipv6 te ipr bandwidth interface
Configured sample period(s)    : 16
Actual sample period (s)       : 20
Total interface number         : 1
Interface                      : GigabitEthernet1/0/1
Maximum bandwidth(bytes/sec)   : 125000000
Remaining bandwidth(bytes/sec) : 24908259
Used bandwidth(bytes/sec)      : 91741
# 显示所有SRv6 TE Policy转发出接口的带宽使用的详细信息。
<Sysname> display segment-routing ipv6 te ipr bandwidth interface verbose
Total interface number         : 2
 RefPolicy:
  Color: 1                           Endpoint: 3::3
  ProtoOrigin: CLI                   Discriminator: 100
  Instance ID: 0                     Priginator: 0, ::
  Segment list ID: 1
   Nexthop: FE80::4463:9BFF:FE17:216
   Nexthop: FE80::4463:9BFF:FE17:220
  Segment list ID: 2
  Color: 2                           Endpoint: 3::3
  Segment list ID: 1
Interface                      : GigabitEthernet 1/0/2
Remaining bandwidth(bytes/sec) : 2124908259
 RefPolicy:
  Instance ID: 0                     Originator: 0, ::
  Segment list ID: 1
表1-11 display segment-routing ipv6 te ipr bandwidth interface命令显示信息描述表
配置的SRv6 TE Policy转发出接口带宽利用率采样周期
实际生效的SRv6 TE Policy转发出接口带宽利用率采样周期
SRv6 TE Policy转发出接口的总数量
隧道接口或物理出接口的总带宽,单位为字节/秒
隧道接口或物理出接口的剩余带宽,单位为字节/秒
隧道接口或物理出接口的已使用带宽,单位为字节/秒
RefPolicy
目前以该接口为转发出接口的SRv6 TE Policy
Color
Endpoint
ProtoOrigin
获取SRv6 TE Policy的协议
·     PCEP:通过PCEP协议获取
·     BGP:通过BGP协议获取
·     CLI:本地配置
Discriminator
SRv6 TE Policy的标识符
Instance ID
BGP实例ID,0表示未从BGP对等体获取SRv6 TE Policy信息
Originator:  ASN, Peer-address
从BGP获取到SRv6 TE Policy的信息,其中:
·     ASN:自制系统号。0表示未从BGP获取到SRv6 TE Policy
·     Peer-address:BGP节点地址。手工配置SRv6 TE Policy时,Peer address为0.0.0.0;从BGP对等体获取SRv6 TE Policy信息时,Peer address为BGP对等体的Router ID
Segment list ID
SRv6 TE Policy最优候选路径中的SID列表ID
Nexthop
SID列表的下一跳地址
display segment-routing ipv6 te policy命令用来显示SRv6 TE Policy信息。
display segment-routing ipv6 te policy [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
name policy-name:显示指定SRv6 TE Policy的信息。policy-name为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
down:显示状态为down的SRv6 TE Policy信息。
up:显示状态为up的SRv6 TE Policy信息。
color color-value:显示指定Color属性的SRv6 TE Policy信息。color-value取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的节点的SRv6 TE Policy信息。ipv6-address表示目的节点的IPv6地址。
如果未指定任何参数,则显示所有SRv6 TE Policy的信息。
# 显示所有SRv6 TE Policy的信息。
Name/ID: p1/0
 Color: 10
 Endpoint: 1000::1
 Name from BGP:
 BSID:
  Mode: Dynamic              Type: Type_2              Request state: Succeeded
  Current BSID: 8000::1      Explicit BSID: -          Dynamic BSID: 8000::1
 Reference counts: 3
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Not configured
 Up time: 2020-03-09 16:09:40
 Down time: 2020-03-09 16:09:13
 Hot backup: Not configured
 Statistics: Not configured
  Statistics by service class: Not configured
 Path verification: Not configured
 Drop-upon-invalid: Disabled
 BFD trigger path-down: Disabled
 SBFD: Enabled
  Encapsulation mode: -
  Remote: 1000
  SBFD template name: abc
  SBFD backup-template name: -
  OAM SID: -
  Reverse path type: None
 BFD Echo: Not configured
  Source IPv6 address: 1::1
  Echo BFD template name: -
  Echo BFD backup template name: -
  OAM SID: -
  Reverse path type: Reverse BSID
 Association ID: 0
 Service-class: -
 Rate-limit: -
 Flapping suppression Remaining interval: -
 Expect bandwidth(kbps): 20000
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1          BGP paths: 0          PCEP paths: 0
 Candidate paths:
  Preference : 20
   CpathName:
   CPathPolicyName:
   Instance ID: 0          ASN: 0          Node address: 0.0.0.0
   Peer address:  ::
   Optimal: Y              Flags: V/A
   Explicit SID list:
    ID: 1                     Name: Sl1
    Weight: 1                 Forwarding index: 2149580801
    State: Up                 State(SBFD): -
    Verification State: -
    Path MTU: 1500            Path MTU Reserved: 72
    SID list flags: None
    Local BSID: -
    Reverse BSID: 100:1:2:3::10
    Local Path Segment: -
    Reverse Path Segment: -
表1-12 display segment-routing ipv6 te policy命令显示信息描述表
Name/ID
Color
Endpoint
SRv6 TE Policy的目的节点的IPv6地址,none表示未配置
Name from BGP
通过BGP获取到的SRv6 TE Policy的名称,未获取到时显示为空
BSID
入节点的SID
Mode
BSID的模式:
·     Explicit:手工指定的
·     Dynamic:动态获取的
·     None:未配置
BSID的类型:
·     None:未配置
·     Type_2:IPv6地址
Request state
BSID申请的状态:
·     Conflicted:BSID冲突
·     Failed:申请失败
·     Succeeded:申请成功
Current BSID
当前的BSID
Explicit BSID
静态的BSID
Dynamic BSID
动态的BSID
Reference counts
SRv6 TE Policy被引用的次数
Flags
SRv6 TE Policy的标志位:
·     A:激活SRv6 TE Policy
·     C:优选SRv6 TE Policy
·     N:正在进行SRv6 TE Policy优选
·     BA:正在申请BSID
·     BS:优选BSID
·     D:删除SRv6 TE Policy
·     CF:和已有BSID冲突
·     NC:手工配置的SRv6 TE Policy
·     NB:通过BGP路由获取到的SRv6 TE Policy
Status
SRv6 TE Policy的状态,取决于SRv6 TE Policy的候选路径中是否存在的状态为UP的SID列表,如果有,则SRv6 TE Policy中的状态为状态为UP,否则,状态为DOWN:
·     Up
·     Down
AdminStatus
SRv6 TE Policy的管理状态,即是否通过shutdown命令关闭SRv6 TE Policy:
·     Configured:已配置
·     Not configured:未配置
Up time
SRv6 TE Policy变为Up状态的时间
Down time
SRv6 TE Policy变为Down状态的时间
Hot backup
SRv6 TE Policy的热备份功能的配置状态:
·     Enabled:热备份功能处于开启状态
·     Disabled:热备份功能处于关闭状态
·     Not configured:未配置热备份功能
Statistics
SRv6 TE Policy的流量转发统计功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
基于隧道转发类的SRv6 TE Policy流量转发统计功能的配置状态:
·     Enabled:开启
Path verification
SRv6 TE Policy路径连通性检查功能的配置状态:
·     Disabled:关闭
·     Enabled:开启,表示校验Segment List中所有SID的有效性
·     Specified SIDs:仅校验Segment List中指定SID的有效性
Drop-upon-invalid
SRv6 TE Policy失效时丢弃流量功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
SRv6 TE Policy的BFD down触发Policy down功能的配置状态:
·     Disabled:关闭
·     Enabled:开启
SBFD
SRv6 TE Policy的SBFD功能的配置状态:
·     Enabled:SBFD功能处于开启状态
·     Disabled:SBFD功能处于关闭状态
·     Not configured:未配置SBFD功能
Encapsulation mode
BFD和SBFD报文封装模式:
·     Encaps:普通封装模式
·     Insert:插入封装模式
·     -:未配置BFD封装模式
Remote
SBFD会话的远端标识符
SBFD template name
SBFD的模板名
备份SID列表的SBFD模板名
OAM SID
为SBFD报文或Echo BFD报文添加OAM SID
Reverse path type
SBFD回程路径类型:
·     Reverse BSID:使用反向BSID对应的SID列表作为SBFD报文的回程路径
·     None:未配置SBFD回程路径,根据IP路径将SBFD报文转发回源节点
BFD Echo
SRv6 TE Policy的echo方式的BFD功能的配置状态:
·     Enable:echo方式的BFD功能处于开启状态
·     Disabled:echo方式的BFD功能处于关闭状态
·     Not configured:未配置echo方式的BFD功能
Source IPv6 address
Echo方式BFD会话的源IPv6地址
Echo template name
Echo方式BFD的模板名
Echo backup-template name
Echo方式备份SID列表的BFD模板名
Reverse path type
Echo方式BFD回程路径类型:
·     Reverse BSID:使用反向BSID对应的SID列表作为BFD报文的回程路径
·     None:未配置Echo方式BFD回程路径
Forwarding index
Association ID
SRv6 TE Policy的候选路径所属组ID,通过组ID来标识一个SRv6 TE Policy
Service-class
SRv6 TE Policy的转发类,采用缺省值时显示为“-”
Rate-limit
SRv6 TE Policy的限速值,未配置时显示为“-”
Encapsulation mode
SRv6 TE Policy的封装方式:
·     Encaps:普通封装模式
·     Encaps Reduced:普通封装的简化模式
·     Encaps include local End.X:普通封装包含本地End.X SID模式
·     Insert:插入封装模式
·     Insert Reduced:插入封装的简化模式
·     Insert include local End.X:插入封装包含本地End.X SID模式
·     -:未配置SRv6 TE Policy的封装方式
SRv6 TE Policy震荡抑制判定的剩余时间
SRv6 TE Policy的预期带宽值,单位为kbps,-表示未配置SRv6 TE Policy的业务期望带宽
候选路径配置状态:
·     Configured:已配置
SRv6 TE Policy候选路径来源统计
CLI paths
手工配置的候选路径数量
BGP paths
通过BGP SRv6 Policy路由获取的候选路径数量
PCEP paths
(暂不支持)通过PCEP(Path Computation Element Protocol,路径计算单元通信协议)获取的候选路径数量
Candidate paths
SRv6 TE Policy候选路径信息
Preference
CPathName
通过BGP路由获取的候选路径名称,未获取时显示为空
CPathPolicyName
继承自SRv6 TE Policy的候选路径名称,未获取时显示为空
ProtoOrigin
获取SRv6 TE Policy的协议:
·     PCEP:通过PCEP协议获取
·     BGP:通过BGP协议获取
·     CLI:本地配置
·     Unknown:来源未知
Discriminator
SRv6 TE Policy的标识符
Instance ID
ASN
自治系统号,0表示未从BGP对等体获取SRv6 TE Policy信息
Node address
BGP节点地址
从BGP对等体获取SRv6 TE Policy信息时,Node address为BGP对等体的Router ID;通过其他方式获取SRv6 TE Policy信息时,Node address为0.0.0.0
Peer address
BGP对等体地址
手工配置SRv6 TE Policy时,Peer address为::;从BGP对等体获取SRv6 TE Policy信息时,Peer address为BGP对等体的地址
Optimal
是否为最优路径:
·     Y:表示是最优路径
·     N:表示不是最优路径
Flags
SRv6 TE Policy候选路径标志位:
·     V:有效的候选路径
·     A:激活的候选路径
·     NONE:无候选路径
Explicit SID list
SRv6 TE Policy候选路径下的显式SID列表
ID
SID列表索引
Name
SID列表名称
Weight
SID列表在该候选路径中的权重值
Forwarding index
SID列表的转发表项索引
SID列表状态,取决于SID列表的首跳,如果SID列表的首跳可达则SID列表状态为UP,否则,SID列表状态为DOWN:
·     UP:SID列表处于UP状态
·     DOWN:SID列表处于DOWN状态
State(type)
SID列表的SBFD或Echo BFD会话状态:
·     Up:会话处于UP状态
·     Down:会话处于DOWN状态
·     Path Inactive:候选路径中无可用的SID列表
·     Unknown:SBFD或Echo BFD检测无结果
·     -:SBFD或Echo BFD未配置
Verification state
SID列表的故障感知校验结果:
·     Down:校验未通过
·     Up:校验通过
-:未配置故障感知功能
Path MTU
Path MTU值
Path MTU Reserved
Path MTU预留值
SID list flags
SRv6 TE Policy SID列表的标志位:
·     O:SID列表中的SID数量超过设备最大标签栈深度
·     None:无状态
Local BSID
本地BSID
如果未通过explicit segment-list命令指定local-binding-sid参数,则显示为-
Reverse BSID
反向BSID
如果未通过explicit segment-list命令指定reverse-binding-sid参数,则显示为-
Local Path Segment
(暂不支持)本地Path Segment
(暂不支持)反向Path Segment
display segment-routing ipv6 te policy ifit命令用来显示SRv6 TE Policy的iFIT检测信息。
display segment-routing ipv6 te policy ifit [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
如果未指定任何参数,则显示所有SRv6 TE Policy的iFIT检测信息。
# 显示所有SRv6 TE Policy的iFIT检测信息。
<Sysname> display segment-routing ipv6 te policy ifit
SRv6 TE policy name/ID: p1/0
Color: 10
End-point          : 1000::1
Status             : Up                     AdminStatus        : Up
Up time            : 2020-03-09 16:09:40
Down time          : 2020-03-09 16:09:13
IFIT loss measure  : Enabled                IFIT delay measure : Enabled
IFIT interval(s)  : 10                      IFIT measure mode  : e2e
Measurement values :
  One-Way Delay(ms)           : 10
  One-Way Jitter(ms)          : 100
  One-Way Loss(per-thousand)  : 123
CLI paths: 1          BGP paths: 0          PCEP paths: 0          ODN paths: 0
Candidate paths:
Preference : 20
 CpathName     :
 ProtoOrigin   : CLI                Discriminator     : 30
 Instance ID   : 0                  Node address      : 0.0.0.0
 Originator    : 0, ::
 Explicit SID list:
 ID: 1                      Name: Sl1
 Global segment list ID: 1
 State: Up                  State(-): -
 Latest measurement values:
  One-Way Loss(per-thousand)  : 122
表1-13 display segment-routing ipv6 te policy ifit命令显示信息描述表
Name/ID
Color
Endpoint
Status
SRv6 TE Policy的状态:
·     Up:激活状态
·     Down:未激活状态,非BFD/SBFD会话联动导致SRv6 TE Policy状态为Down
·     Down (BFD down):BFD/SBFD会话检测到SRv6 TE Policy中当前选中候选路径的所有SID列表对应的转发路径不通,则联动SRv6 TE Policy状态为Down(原因为所有SID列表对应的转发路径上首个下一跳可达,但转发路径上后续路径不通)
AdminStatus
·     Down:已配置shutdown命令关闭SRv6 TE Policy
·     Up:未配置shutdown命令关闭SRv6 TE Policy
Up time
Down time
IFIT loss measure
SRv6 TE Policy的iFIT丢包率测量功能状态,取值包括:
·     Enabled
·     Disabled
IFIT delay measure
SRv6 TE Policy的iFIT时延测量功能状态,取值包括:
·     Enabled
·     Disabled
IFIT interval(s)
SRv6 TE Policy的iFIT检测周期,单位为秒
IFIT measure mode
SRv6 TE Policy的iFIT测量模式,取值包括:
·     e2e
·     trace
Measurement values
SRv6 TE Policy的iFIT检测值
One-Way Delay(ms)
SRv6 TE Policy最优候选路径下所有Segment List的单程iFIT时延加权值,单位为毫秒
One-Way Jitter(ms)
SRv6 TE Policy最优候选路径下所有Segment List的单程iFIT抖动加权值,单位为毫秒。
SRv6 TE Policy最优候选路径下所有Segment List的单程iFIT丢包率加权值,单位为‰
候选路径配置状态:
·     Configured:已配置
CLI paths
手工配置的候选路径数量
BGP paths
PCEP paths
ODN paths
通过ODN创建的SRv6 TE Policy的候选路径数量
Candidate paths
Preference
CPathName
ProtoOrigin
·     PCEP:通过PCEP协议获取(暂不支持)
·     BGP:通过BGP协议获取
·     CLI:本地配置
·     Unknown:来源未知
Discriminator
SRv6 TE Policy的标识符
Instance ID
Node address
BGP节点地址
从BGP获取到的SRv6 TE Policy,其中:
·     ASN:自治系统号。0表示未从BGP获取到SRv6 TE Policy
·     Peer-address:BGP节点地址。手工配置SRv6 TE Policy时,Peer address为::;从BGP对等体获取SRv6 TE Policy信息时,Peer address为BGP对等体的Router ID
Explicit SID list
ID
SID列表索引,创建SID列表时系统自动为该SID列表分配一个索引值,不同SRv6 TE Policy引用同一个SID列表时,本索引值不变
Name
SID列表名称
Weight
SID列表在该候选路径中的权重值
全局唯一的SID列表索引,当SRv6 TE Policy引用SID列表时,系统将自动为该SID列表分配一个全局唯一的索引,iFIT流和本索引值一一对应
Forwarding index
SID列表的转发表项索引
SID列表状态:
·     UP:SID列表处于UP状态
·     Down(BFD down):SID列表对应的转发路径上首个下一跳可达,但BFD探测发现转发路径上后续路径不通
State(type)
·     Up:会话处于UP状态
·     Down:会话处于DOWN状态
Type指BFD会话类型,取值包括:
·     SBFD:配置了SBFD会话
·     Echo BFD:配置了echo方式的BFD会话
最近5次Segment List的iFIT检测结果,如果iFIT检测的次数不满5次,则显示所有iFIT检测结果,如果iFIT无法正常测量数据则不显示该字段
One-Way Delay(ms)
Segment list最近5次的单程iFIT时延,单位为毫秒
One-Way Jitter(ms)
Segment list最近5次的单程iFIT抖动,单位为毫秒
Segment list最近5次的单程iFIT丢包率,单位为‰
·     ifit delay-measure
·     ifit interval
·     ifit loss-measure
·     srv6-policy ifit delay-measure enable
·     srv6-policy ifit interval
·     srv6-policy ifit loss-measure enable
display segment-routing ipv6 te policy last-down-reason命令用来显示SRv6 TE Policy最近一次down的原因。
display segment-routing ipv6 te policy last-down-reason [ binding-sid bsid | color color-value endpoint ipv6 ipv6-address | policy-name policy-name ]
binding-sid bsid:指定BSID。bsid为IPv6地址。
color color-value endpoint ipv6 ipv6-address:指定Color属性和目的节点地址。color-value表示Color属性值,取值范围为0~4294967295。ipv6-address表示目的节点的IPv6地址。
policy-name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
如果不指定任何参数,则显示所有SRv6 TE Policy最近一次down的原因。
# 显示名称为abc的SRv6 TE Policy最近一次down的原因。
<Sysname> display segment-routing ipv6 te policy last-down-reason policy-name abc
Name/ID: p1/1
  Color: 10
  Endpoint: 4::4
  BSID: 5000::2
  Up time: 2020-06-23 15:42:14
  Down time: 2020-06-23 15:41:15
  Down reason: Candidate path invalid segment list
  Candidate paths:
    Preference : 10
      CPathName:
      Explicit SID list:
        ID: 1                     Name: s1
        Down reason: No SRv6 SID Out
表1-14 display segment-routing ipv6 te policy last-down-reason命令显示信息描述表
Name/ID
Color
SRv6 TE Policy的Color属性,0表示未配置
Endpoint
SRv6 TE Policy的目的节点地址,None表示未配置
BSID
入节点的SID
Up time
SRv6 TE Policy UP的时间
Down time
SRv6 TE Policy DOWN的时间
Down reason
SRv6 TE Policy DOWN的原因
·     Admin down:表示该SRv6 TE Policy已经通过shutdown命令被关闭,即管理状态为关闭
·     No Endpoint:目的地址不存在
·     No candidate path:候选路径不存在
·     No valid candidate path:候选路径下未指定Segment list
·     Candidate path invalid segment list:候选路径下所有SID列表处于Down状态
·     Policy unconfigured:SRv6 TE Policy正在被删除
·     Internal error:内部错误
Candidate paths
Preference
候选路径的优先级
CPathName
候选路径的名称,未从BGP获取到时显示为空
Explicit SID List
SRv6 TE Policy候选路径下的SID列表
ID
SID列表索引
Name
SID列表名称
Up time
SID列表UP的时间
Down time
SID列表DOWN的时间
Down reason
SID列表DOWN的原因
·     No SID list:SID列表不存在
·     No SRv6 SID Out:SID列表中首个SID无对应出接口
display segment-routing ipv6 te policy statistics命令用来显示SRv6 TE Policy的统计信息。
# 显示SRv6 TE Policy的统计信息。
<Sysname> display segment-routing ipv6 te policy statistics
         IPv6 TE Policy Database Statistics
Total policies: 1 (1 up 0 down)
    Configured: 1 (1 up 0 down)
    From BGP: 0 (Added 0 deleted 0   0 up 0 down)
Total candidate paths: 1
    Configured: 1
    From BGP: 0 (Added 0 deleted 0)
Total SID lists: 1 (1 up 0 down)
    From BGP: 0 (0 up 0 down)
表1-15 display segment-routing ipv6 te policy statistics命令显示信息描述表
SRv6 TE Policy的统计信息
Total policies
SRv6 TE Policy总个数:
·     up:处于up状态的SRv6 TE Policy的个数
·     down:处于down状态的SRv6 TE Policy的个数
Configured
手工配置的个数:
From BGP
通过BGP路由学习的个数
·     Added:BGP添加个数
·     deleted:BGP删除个数
display segment-routing ipv6 te policy status命令用来显示SRv6 TE Policy的状态。
display segment-routing ipv6 te policy status [ policy-name policy-name ]
policy-name policy-name:指定SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。如果未指定本参数,则显示所有SRv6 TE Policy的状态。
当上一个检查项状态为Failed时,其他检查项显示为“-”,表示不检查。
# 显示所有SRv6 TE Policy的状态。
<Sysname> display segment-routing ipv6 te policy status
Name/ID: p1/0
Status: Up
  Check admin status                  : Passed
  Check for endpoint & color          : Passed
  Check for segment list              : Passed
  Check valid candidate paths         : Passed
  Check for BSIDs                     : Passed
表1-16 display segment-routing ipv6 te policy status命令显示信息描述表
Name/ID
Status
SRv6 TE Policy的状态:
·     Up
·     Down
Check admin status
检查SRv6 TE Policy下是否配置了shutdown
·     Passed:检查结果为通过,即未配置
·     Failed:检查结果为失败,即已配置
检查SRv6 TE Policy下是否存在目的地址和Color:
·     Passed:检查结果为通过,即存在
·     Failed:检查结果为失败,即不存在
Check for segment lists
检查SRv6 TE Policy的候选路径下是否存在有效的SID列表:
检查SRv6 TE Policy是否存在UP状态的候选路径:
Check for BSIDs
检查SRv6 TE Policy下是否存在Binding SID:
display segment-routing ipv6 te policy-group命令用来显示SRv6 TE Policy组的信息。
display segment-routing ipv6 te policy-group [ odn ] [ group-id | { color color-value | end-point ipv6 ipv6-address } * ] [ verbose ]
odn:显示由ODN动态创建的SRv6 TE Policy组的信息。如果未指定本参数,则显示包括ODN动态创建和手工静态创建的所有SRv6 TE Policy组的信息。
group-id:显示指定SRv6 TE Policy组的信息。group-id为SRv6 TE Policy组ID,取值范围为1~4294967295。如果未指定本参数,则显示所有SRv6 TE Policy组的信息。
color color-value:显示指定Color属性的SRv6 TE Policy组信息。color-value取值范围为0~4294967295。
end-point ipv6 ipv6-address:显示指定目的节点的SRv6 TE Policy组信息。ipv6-address表示目的节点的IPv6地址。
verbose:显示SRv6 TE Policy组的详细信息。如果未指定本参数,则显示SRv6 TE Policy组的简要信息。
# 显示所有SRv6 TE Policy组的简要信息。
<Sysname> display segment-routing ipv6 te policy-group
Total number of policy groups: 1
GroupID      GroupState    UPMappings     TotalMappings
10           Up            26             26
# 显示所有SRv6 TE Policy组的详细信息。
<Sysname> display segment-routing ipv6 te policy-group verbose
Total number of policy groups: 2
GroupID: 10                         GroupState: Down
GroupNID: 0                         Referenced: 1
Flags:  None                        Group type: Static TE Class
Group color: -
StateChangeTime: 2024-05-27 10:30:14
Endpoint: None
BSID:
  Explicit BSID: -                       Request state: -
Drop upon mismatch: Enabled
UP/Total Mappings: 0/3
  Default Match Type: None
    Default SRv6 TE Policy Color: -
    Default IPR Policy  : -
  Index: 10               TE Class: 10
    Match Type          : IPR Policy
    IPR Policy          : ipr1
  Index: 20               TE Class: 20
    Match Type          : SRv6 TE Policy
    SRv6 TE Policy Color: 20
    IPR Policy          : -
  Index: 30               TE Class: 30
    Match Type          : SRv6 BE
    IPR Policy          : -
GroupID: 20                     GroupState: Up
GroupNID: 2151677953            Referenced: 1
Flags: A                        Group type: Static DSCP
Group color: -
Endpoint: 4::4
BSID:
Best-effort NID: 0
Drop upon mismatch: Disabled
UP/Total Mappings: 0/0
IPv4 Best-effort: Not configured  IPv6 Best-effort: Not configured
GroupID: 40                          GroupState: Up
Flags: A                             Group type: Dynamic APN-ID
Group color: 100
StateChangeTime: 2022-10-18 09:57:43
Endpoint: 444::444
UP/Total Mappings: 26/26
  Index     APN-ID/APN-INSTANCE       Color/Best-effort
  10        test1                     100
  15        test2                     200
  20        test3                     best-effort
表1-17 display segment-routing ipv6 te policy-group命令显示信息描述表
SRv6 TE Policy组的总个数
GroupID
SRv6 TE Policy组ID
GroupState
SRv6 TE Policy组状态:
·     Down
·     Up
UPMappings
SRv6 TE Policy组中映射关系生效数量的总和
TotalMappings
SRv6 TE Policy组中所有映射关系数量的总和
GroupNID
SRv6 TE Policy组的转发表项索引
Referenced
SRv6 TE Policy组被引用的次数
Flags
SRv6 TE Policy组的标志位:
·     A:分配SRv6 TE Policy组的转发表项索引
·     F:下发SRv6 TE Policy组的转发表项
·     W:等待分配SRv6 TE Policy组的转发表项索引
·     D:删除SRv6 TE Policy组
·     None:SRv6 TE Policy组处于初始状态或者稳定状态
Group type
SRv6 TE Policy组的类型,取值包括:
·     Static DSCP:静态创建的基于DSCP引流的SRv6 TE Policy组
·     Static APN-ID:静态创建的基于APN-ID引流的SRv6 TE Policy组
·     Static TE Class:静态创建的基于TE Class ID转发的SRv6 TE Policy组
·     Dynamic:动态创建的SRv6 TE Polic组,但未配置转发类型
·     Dynamic APN-ID:动态创建的基于APN-ID引流的SRv6 TE Policy组
·     Dynamic DSCP:动态创建的基于DSCP引流的SRv6 TE Policy组
·     Dynamic TE Class:动态创建的基于TE Class ID转发的SRv6 TE Policy组
Group color
StateChangeTime
SRv6 TE Policy组状态变化的时间
Endpoint
SRv6 TE Policy组的目的节点地址,None表示未配置
BSID
SRv6 TE Policy组申请的Binding SID信息:
·     Explicit BSID:系统分配的Binding SID值
·     Request state:SRv6 TE Policy组申请的Binding SID状态,取值包括
¡     Succeeded:申请成功
¡     Failed:申请失败
Best-effort NID
按SRv6 BE方式转发流量的转发索引
Drop upon mismatch
SRv6 TE Policy组不匹配引流策略时丢弃流量的功能状态:
·     Disabled:关闭
·     Enabled:开启
UP/Total Mappings
·     当SRv6 TE Policy组基于DSCP转发时:SRv6 TE Policy组中有效的Color和DSCP映射关系数量和配置的Color和DSCP映射关系总数量
·     当SRv6 TE Policy组基于TE Class转发时:SRv6 TE Policy组中TE Class的映射关系生效数量和配置的TE Class的映射关系总数
·     当SRv6 TE Policy组基于APN ID转发时:SRv6 TE Policy组中APN ID的映射关系生效数量和配置的APN ID的映射关系总数
Color
Color值
报文类型:
·     IPv4
·     IPv6
DSCP
DSCP优先级
Index
APN ID和转发策略映射关系的索引
APN-ID/APN-INSTANCE
APN ID实例名称
Color/Best-effort
APN ID对应的转发策略
·     取值为数值时,该值为SRv6 TE Policy的Color值,表示具有指定APN ID的流量通过该SRv6 TE Policy转发
·     取值为best-effort时,表示具有指定APN ID的流量通过SRv6 BE方式转发
Default MatchType
基于TE Class ID转发的默认转发策略,取值包括:
·     IPR Policy:表示默认转发策略为IPR模板
·     SRv6 TE Policy:表示默认转发策略为通过SRv6 TE Policy转发
·     SRv6 BE:表示默认转发策略为通过SRv6 BE方式转发
默认转发策略为SRv6 TE Policy时,该SRv6 TE Policy的Color值,如果默认的转发策略未配置成通过SRv6 TE Policy转发,则显示为“-”
Default IPR Policy
默认转发策略为IPR模板时,该IPR模板的名称,如果默认转发策略不是IPR模板则显示为“-”
Color
IPR模板中优选的SRv6 TE Policy的Color值,如果TE Class ID未和IPR模板建立映射关系则不显示该字段
Priority
IPR模板中优选的SRv6 TE Policy的优先级的值,如果TE Class ID未和IPR模板建立映射关系则不显示该字段
Index
TE Class ID标识的流量和转发策略的映射关系的索引
TE Class
流量的TE Class ID标识
Match Type
TE Class ID与SRv6 TE Policy、IPR模板或BE转发策略间的映射关系,取值包括:
·     IPR Policy:表示TE Class ID标识的流量通过IPR模板定义的策略转发,当流量使用该IPR模板的转发策略生效时,将显示active,否则,不显示active
·     SRv6 TE Policy:表示TE Class ID标识的流量通过SRv6 TE Policy转发
SRv6 BE:表示TE Class ID标识的流量通过SRv6 BE方式转发
TE Class ID和SRv6 TE Policy映射时,该SRv6 TE Policy的Color值
IPR Policy
TE Class ID和IPR模板映射时,该IPR模板的名称
1.1.38  display segment-routing ipv6 te policy-group apn-id-ipv6
display segment-routing ipv6 te policy-group apn-id-ipv6 instance命令用来显示SRv6 TE Policy模块的APN ID实例信息。
display segment-routing ipv6 te policy-group apn-id-ipv6 instance [ name inatnce-name ]
name instance-name:指定APN ID实例名称。其中instance-name为APN ID实例名称,1~31个字符的字符串,区分大小写。
创建了APN ID实例后,SRv6 TE Policy功能模块也可以获取到APN ID实例的详细信息,并基于APN ID实例进行SRv6 TE Policy引流。通过本命了可以查看APN6功能模块和SRv6 TE Policy功能模块是否正常交互APN ID实例信息。关于APN ID实例的详细信息,请参见“业务感知型网络配置指导”中的“APN6”。
# 显示SRv6 TE Policy模块的APN ID实例信息。
<Sysname> display segment-routing ipv6 te policy-group apn-id-ipv6 instance
Instance name  : inst1
Instacne ID    : 1          APN ID length      : 64
App Group Len  : 32         App Group Mask Len : 10
Usr Group Len  : 32         Usr Group Mask Len : 8
APN ID         : 0x4b400000 0xc9000000
APN mask       : 0xffc00000 0xff000000
表1-18 display segment-routing ipv6 te policy-group apn-id-ipv6 instance命令输出信息描述
Instance name
APN ID实例名称
Instance ID
系统自动为APN ID实例分配的索引
APN ID length
APN ID的总长度,包含APP-Group-ID、User-Group-ID和预留字段
AppGroupLen
APN ID中APP-Group-ID字段的总长度
AppGroupMaskLen
APN ID中APP-Group-ID字段的掩码长度
UsrGroupLen
APN ID中User-Group-ID字段的总长度
UsrGroupMaskLen
APN ID中User-Group-ID字段的掩码长度
APN ID
APN ID中APP-Group-ID字段和User-Group-ID字段的十六进制值,其中,前面显示的字段为APP-Group-ID的值,后面显示的字段为User-Group-ID的值
APN mask
APN ID中APP-Group-ID字段和User-Group-ID字段的掩码,其中,前面显示的字段为APP-Group-ID的掩码,后面显示的字段为User-Group-ID的掩码,例如APP-Group-ID的值为0x02000000,掩码为0xff000000,则表示APP-Group-ID字段中仅最高8位被赋值为2
1.1.39  display segment-routing ipv6 te policy-group last-down-reason
display segment-routing ipv6 te policy-group last-down-reason命令用来显示SRv6 TE Policy组最近一次down的原因。
display segment-routing ipv6 te policy-group last-down-reason [ group-id | endpoint ipv6-address color color-value ]
group-id:显示指定SRv6 TE Policy组最近一次down的原因。group-id为SRv6 TE Policy组ID,取值范围为1~4294967295。如果未指定本参数,则显示所有SRv6 TE Policy组最近一次down的原因。
endpoint ipv6-address color color-value:指定Color属性和目的节点地址。color-value表示Color属性值,取值范围为0~4294967295。ipv6-address表示目的节点的IPv6地址。
# 显示SRv6 TE Policy组1最近一次down的原因。
<Sysname> display segment-routing ipv6 te policy-group last-down-reason 10
Group ID   : 10                        Group type : Static DSCP
Group color: 100                       Endpoint   : 4::4
Group NID  : 2151677956
Create time: 2021-03-18 09:57:43
Up time    : -
Down time  : 2021-03-18 09:57:43
Down reason: No active SRv6-TE Policies
  Color: 20                     Address family: IPv4
    Up time    : 2021-03-18 01:52:20.785
    Down time  : 2021-03-18 09:59:23
    Down reason: No endpoint
表1-19 display segment-routing ipv6 te policy-group last-down-reason命令显示信息描述表
Group ID
SRv6 TE Policy组的ID
Group type
SRv6 TE Polic组的类型:
·     Static DSCP:静态创建的基于DSCP引流的SRv6 TE Polic组
Group color
Endpoint
Group NID
Create time
SRv6 TE Policy组创建的时间
Up time
SRv6 TE Policy组UP的时间
Down time
SRv6 TE Policy组DOWN的时间
Down reason
SRv6 TE Policy组DOWN的原因:
·     No endpoint:没有配置SRv6 TE Policy组的目的节点地址
·     No color-DSCP mappings:没有配置Color和DSCP映射关系
·     No active SRv6-TE policies:SRv6 TE Policy组中不存在有效的SRv6 TE Policy
·     No color-TE Class mappings:没有配置Color和TE Class ID映射关系
·     No color-apn-id mappings:没有配置Color和APN ID的映射关系
·     Forwarding down:没有转发表项
Color
与DSCP/TE Class进行映射的Color值
Address family type
地址族:
·     IPv4
·     IPv6
Up time
Color和DSCP/TE Class映射关系生效的时间
Down time
Color和DSCP/TE Class映射关系失效的时间
Down reason
Color和DSCP/TE Class映射关系失效的原因:
·     No endpoint:没有配置SRv6 TE Policy的目的节点地址
·     The SRv6-TE policy is used by another group:Color对应的SRv6 TE Policy已经被其他SRv6 TE Policy组使用
·     SRv6-TE policy does't exist:SRv6 TE Policy不存在
·     SRv6-TE policy down:Color对应的SRv6 TE Policy处于down状态
·     No selected by intelligent route policy:智能策略路由未选中SRv6 TE Policy
·     APNID conflict:APNID冲突,即不同APNID实例对应的APNID相同
1.1.40  display segment-routing ipv6 te policy-group statistics
display segment-routing ipv6 te policy-group statistics命令用来显示SRv6 TE Policy组的统计信息。
# 显示SRv6 TE Policy组的统计信息。
<Sysname> display segment-routing ipv6 te policy-group statistics
Statistics type                 Total                Up
Dynamic DSCP groups             0                    0
Static DSCP groups              1                    0
Color-DSCP mappings             0                    0
SRv6-BE-DSCP mappings           0                    0
Static Dot1p groups             0                    0
Color-Dot1p mappings            0                    0
Dynamic service-class groups    0                    0
Static service-class groups     0                    0
Color-service-class mappings    0                    0
SRv6-BE-service-class mappings  0                    0
Dynamic apn-id groups           0                    0
Static apn-id groups            0                    0
Color-apn-id mappings           0                    0
SRv6-BE-apn-id mappings         0                    0
Dynamic TE Class groups         0                    0
Static TE Class groups          0                    0
Color-TE Class mappings         0                    0
IPR-TE Class mappings           0                    0
SRv6-BE-TE Class mappings       0                    0
表1-20 display segment-routing ipv6 te policy-group statistics命令显示信息描述表
Statistics type
统计对象:
·     Dynamic DSCP groups:动态创建的基于DSCP引流SRv6 TE Policy组
·     Static DSCP groups:静态创建的基于DSCP引流的SRv6 TE Policy组
·     Color-DSCP mappings:所有SRv6 TE Policy组中的Color和DSCP映射关系
·     SRv6-BE-DSCP mappings:所有SRv6 TE Policy组中DSCP和SRv6 BE方式的映射关系
·     Static Dot1p groups:静态创建的基于Dot1p引流的SRv6 TE Policy组
·     Color-Dot1p mappings:SRv6 TE Policy组中配置的Color和Dot1p映射关系
·     Dynamic service-class groups:动态创建基于service-class引流的SRv6 TE Policy组
·     Static service-class groups:静态创建的基于service-class引流的SRv6 TE Policy组
·     Color-service-class mappings:SRv6 TE Policy组中配置的Color和service-class映射关系
·     SRv6-BE-service-class mappings:所有SRv6 TE Policy组中service-class和SRv6 BE方式的映射关系
·     Dynamic apn-id groups:动态创建基于APN ID引流的SRv6 TE Policy组
·     Static apn-id groups:静态创建的基于APN ID引流的SRv6 TE Policy组
·     Color-apn-id mappings:SRv6 TE Policy组中配置的Color和APN ID映射关系
·     SRv6-BE-apn-id mappings:所有SRv6 TE Policy组中APN ID和SRv6 BE方式的映射关系
·     Dynamic TE Class groups:动态创建的基于TE Class引流的SRv6 TE Policy组
·     Static TE Class groups:静态创建的基于TE Class引流的SRv6 TE Policy组
·     Color-TE Class mappings:所有SRv6 TE Policy组中的Color和TE Class映射关系
·     IPR-TE Class mappings:所有IPR模板和TE Class映射关系
·     SRv6-BE-TE Class mappings:所有SRv6 TE Policy组中TE Class和SRv6 BE方式的映射关系
Total
总数量
UP
生效的数量
1.1.41  display segment-routing ipv6 te sbfd
display segment-routing ipv6 te sbfd命令用来显示SRv6 TE Policy的SBFD信息。
display segment-routing ipv6 te sbfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down:显示状态为down的SRv6 TE Policy的SBFD信息。
policy:显示指定SRv6 TE Policy的SBFD信息。
up:显示状态为up的SRv6 TE Policy的SBFD信息。
如果未指定downpolicyup参数,则显示所有SRv6 TE Policy的SBFD信息。
# 显示所有SRv6 TE Policy的SBFD信息。
<Sysname> display segment-routing ipv6 te policy sbfd
 Color: 10
 Endpoint: 4::4
 Policy name: p1
 State: Down
   Nid: 2149580801
   BFD type: SBFD
   Remote Discr: 100
   State: Down
   Timer: 30
   VPN index: 0
   Template name: abc
   Reverse BSID: -
   Local Path Segment:-
   Flush add time: 2022-12-22 17:01:48
表1-21 display segment-routing ipv6 te policy sbfd命令显示信息描述表
Color
Endpoint
Policy name
SRv6 TE Policy的名称
SBFD会话状态:
·     Up
·     Down
·     Delete
Nid
SID列表的转发表项索引
BFD type
BFD类型,目前仅支持SBFD
Remote Discr
远端标识符
Timer
SBFD会话定时器,单位为秒
VPN index
VPN实例索引
Template name
SBFD的模板名
Reverse path type
SBFD报文的回程路径类型:
·     (暂不支持)Reverse Path Segment:使用反向Path Segment对应的SID列表作为SBFD报文的回程路径
·     None:未配置SBFD报文的回程路径,根据IP路径将SBFD报文转发回源节点
Reverse BSID
SBFD会话的反向BSID
Local Path Segment
SBFD会话的本地Path Segment
Flush add time
SRv6 TE Policy最近一次将路径信息传递给SBFD的时间,SBFD基于路径信息建立检测会话,如果未创建SBFD会话时,则显示为“-”
1.1.42  display segment-routing ipv6 te segment-list
display segment-routing ipv6 te segment-list命令用来显示SRv6-TE的SID列表信息。
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
name segment-list-name:显示指定名称的SID列表信息。segment-list-name表示SID列表名称,为1~128个字符的字符串,区分大小写。
id id-value:显示指定ID的SID列表信息。id-value为SID列表的ID,取值范围为1~4294967295。
如果未指定nameid参数,则显示SRv6-TE的所有SID列表信息。
SID列表的ID可以通过display segment-routing ipv6 te policy命令查看。
# 显示SRv6-TE的所有SID列表信息。
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 2
Name/ID: A/1
 Origin: CLI
 Status: Up
 Nodes: 1
  Index            : 10                           SID: 101::1
  Type             : Type_2                     Flags: None
  Coc Type         : -           Common prefix length: 0
  Function length  : 0                    Args length: 0
  Endpoint Behavior: -
  Index            : 2                            SID: 101::2
  Type             : Type_13                    Flags: None
  Coc Type         : COC32       Common prefix length: 72
  Function length  : 64                   Args length: 0
  Endpoint Behavior: End with COC
表1-22 display segment-routing ipv6 te segment-list命令显示信息描述表
Total Segment lists
SID列表个数
Name/ID
SID列表名称/ID
Origin
SID列表的配置来源:
·     CLI:手工配置
·     BGP:BGP配置下发
·     PCE:PCE配置下发(暂不支持)
·     -:无有效来源
Status
SID列表的状态:
·     Down:SID列表处于down状态
·     Up:SID列表处于up状态
Nodes
SID列表中节点数量
Index
节点索引值
SID
节点的SID,即IPv6地址
节点的SID类型:
·     None:未配置
·     Type 2:IPv6地址
·     Type 13:压缩的IPv6地址
Flags
节点的标志位,当前未定义,显示为None
Coc Type
SID的压缩类型,目前仅支持COC32,表示32位压缩
SID未压缩时,显示为“-”
G-SID的公共前缀长度
Function length
SID的Function长度
Args length
指定SRv6 SID预留段长度
Endpoint Behavior
SRv6 Endpoint节点的转发行为,取值包括:
·     -:无效节点行为
·     End (no PSP, no USP)
·     End with PSP
·     End with USP
·     End with PSP&USP
·     End.X (no PSP, no USP)
·     End.X with PSP
·     End.X with USP
·     End.X with PSP&USP
·     End.T (no PSP, no USP)
·     End.T with PSP
·     End.T with USP
·     End.T with PSP&USP
·     End with USD
·     End with PSP&USD
·     End with USP&USD
·     End with PSP&USP&USD
·     End.X with USD
·     End.X with PSP&USD
·     End.X with USP&USD
·     End.X with PSP&USP&USD
·     End.T with USD
·     End.T with PSP&USD
·     End.T with USP&USD
·     End.T with PSP&USP&USD
·     End with COC
·     End with PSP&COC
·     End with PSP&USP&COC
·     End.X with COC
·     End.X with PSP&COC
·     End.X with PSP&USP&COC
·     End.T with COC
·     End.T with PSP&COC
·     End.T with PSP&USP&COC
·     End with PSP&USD&COC
·     End with PSP&USP&USD&COC
·     End.X with PSP&USD&COC
·     End.X with PSP&USP&USD&COC
·     End.T with PSP&USD&COC
·     End.T with PSP&USP&USD&COC
1.1.43  distribute bgp-ls
distribute bgp-ls命令用来配置设备允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
undo distribute bgp-ls命令用来恢复缺省情况。
distribute bgp-ls
不允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
SRv6 TE视图
配置本命令后,设备会将SRv6 TE Policy的候选路径信息上报给BGP-LS,通过BGP-LS路由对外发布,以满足需要知道SRv6 TE Policy路径信息的应用的需求。
# 配置设备允许将SRv6 TE Policy的候选路径信息上报BGP-LS。
[Sysname] segment-routing-ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] distribute bgp-ls
1.1.44  drop-upon-invalid enable
drop-upon-invalid enable命令用来开启SRv6 TE Policy在Policy失效时丢弃流量的功能。
undo drop-upon-invalid enable命令用来关闭SRv6 TE Policy在Policy失效时丢弃流量的功能。
SRv6 TE Policy在Policy失效时丢弃流量功能处于关闭状态。
SRv6 TE Policy视图
如果希望限定流量仅通过SRv6 TE Policy隧道转发,可以开启本功能。
缺省情况下,转发报文的SRv6 TE Policy的所有候选路径都失效时,设备会通过传统IPv6转发方式转发报文,即根据目的IPv6地址查找IPv6路由表转发报文。
当配置drop-upon-invalid enable命令后,如果用于转发报文的SRv6 TE Policy的所有候选路径都失效,设备会丢弃该报文,不会通过传统IPv6转发方式转发报文。
display segment-routing ipv6 te policy命令中Request state字段显示为Falied(即BSID申请失败)、Conflicted(BSID冲突)或者Forwarding index字段显示为0(即SRv6 TE Policy无效)时,drop-upon-invalid enable命令不生效。
# 配置SRv6 TE Policy a1在失效时丢弃流量。
[Sysname] segment-routing ipv6
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] drop-upon-invalid enable
1.1.45  drop-upon-mismatch enable
drop-upon-mismatch enable命令用来开启SRv6 TE Policy组不匹配引流策略时丢弃流量的功能。
undo drop-upon-mismatch enable命令用来关闭SRv6 TE Policy组不匹配引流策略时丢弃流量的功能。
SRv6 TE Policy组未匹配引流策略时丢弃流量功能处于关闭状态。
SRv6 TE Policy组视图
流量引入到SRv6 TE Policy组中转发时,如果用户仅希望通过DSCP/Dot1p/service-class匹配的SRv6 TE Policy或SRv6 BE方式转发流量,或者采用缺省的SRv6 TE Policy/SRv6 BE转发流量,则可以开启本功能,使得流量匹配不到有效的SRv6 TE Policy和SRv6 BE路径时,丢弃该流量。
# 开启SRv6 TE Policy组10不匹配引流策略时丢弃流量的功能。
[Sysname-srv6-te-policy-group-10] drop-upon-mismatch enable
# 开启SRv6 TE ODN Policy组不匹配引流策略时丢弃流量的功能。
[Sysname-srv6-te-odn-group-1] drop-upon-mismatch enable
·     color match dscp (SRv6 TE Policy group view)
1.1.46  encapsulation-mode
encapsulation-mode命令用来配置SRv6 TE Policy的封装模式。
undo encapsulation-mode命令用来恢复缺省情况。
encapsulation-mode encaps reduced [ disable ]
undo encapsulation-mode encaps reduced
undo encapsulation-mode insert
encapsulation-mode insert reduced [ disable ]
undo encapsulation-mode insert reduced
未配置SRv6 TE Policy的封装模式,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
encaps reduced:配置封装模式为普通封装的简化模式。
insert:配置封装模式为插入封装模式。
insert reduced:配置封装模式为插入封装的简化模式。
disable:不采用配置的SRv6 TE Policy的封装模式。如果未指定本参数,则采用配置的SRv6 TE Policy的封装模式。
报文通过SRv6 TE Policy转发时,需要为报文封装SRv6 TE Policy的SID列表,封装模式包括:
·     Encaps方式:普通封装模式。在原始报文的基础上封装新的IPv6头和SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     新IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个IPv6地址,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
¡     SRH包含SRv6 TE Policy的SID列表中所有SID信息。
·     Encaps.Red方式:普通封装的简化模式。在原始报文的基础上封装新的IPv6头和SRH,且SRv6 TE Policy的SID列表中的第一个SID不封装在SRH中,其他SID封装到SRH中,以便减少SRH的长度。
¡     新IPv6头的目的IPv6地址为SRv6 TE Policy的SID列表中的第一个SID,源IPv6地址为encapsulation source-address命令指定的IPv6地址。
¡     SRH包含SRv6 TE Policy的SID列表中除第一个SID外所有SID信息。
·     Insert方式:插入封装模式。在原始IPv6报文头后插入SRH,且SRv6 TE Policy的SID列表中的所有SID均封装在SRH中。
¡     IPv6头的目的IPv6地址改为SRv6 TE Policy的SID列表中的第一个IPv6地址,原始IPv6报文头的源IPv6地址不变。
·     Insert.Red方式:插入封装的简化模式。在原始IPv6报文头后插入SRH,且SRv6 TE Policy的SID列表中的第一个SID不封装在SRH中,其他SID封装到SRH中,以便减少SRH的长度。
¡     IPv6头的目的IPv6地址改为SRv6 TE Policy的SID列表中的第一个SID,原始IPv6报文头的源IPv6地址不变。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的封装模式。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
普通封装模式与插入封装模式互斥:配置普通封装模式后,系统会自动删除已配置的插入封装模式;配置插入封装模式后,系统会自动删除已配置的普通封装模式。
配置insertinsert reduced模式后,如果设备收到IPv4报文,则设备将按照Encaps方式封装报文。
配置本功能并指定封装模式为普通封装的简化模式,同时,在SRv6 TE Policy视图下又配置了encapsulation-mode encaps include local-end.x命令,则encapsulation-mode encaps include local-end.x命令生效。
配置本功能并指定封装模式为插入封装的简化模式,同时,在SRv6 TE Policy视图下又配置了encapsulation-mode insert include local-end.x命令,则encapsulation-mode insert include local-end.x命令生效。
# 配置SRv6 TE Policy 1采用Encaps.Red封装模式。
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] encapsulation-mode encaps reduced
·     encapsulation source-address(Segment Routing命令参考/SRv6 VPN)
·     srv6-policy encapsulation-mode
1.1.47  encapsulation-mode encaps include local-end.x
encapsulation-mode encaps include local-end.x命令用来配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID。
undo encapsulation-mode encaps include local-end.x命令用来恢复缺省情况。
encapsulation-mode encaps include local-end.x [ disable ]
未配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:配置通过SRv6 TE Policy转发报文时封装的SRH中不包含本地End.X SID。如果未指定本参数,则通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
引流到SRv6 TE Policy时,缺省情况下,如果头节点的SRv6 SID是End.X SID,则不会将该SID封装到SRH中。配置本命令后,封装SRH时可以添加本地的End.X SID。
在SRH中添加本地的End.X SID后,可以通过报文中的SRH获取完整的路径信息,即获取到SRv6转发路径上所有SRv6节点的信息。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置通过SRv6 TE Policy转发报文时封装的SRH中是否包含本地End.X SID。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
多次配置encapsulation-mode encaps include local-end.x命令和encapsulation-mode insert include local-end.x命令,最后一次的配置生效。
配置了本功能的同时,在SRv6 TE Policy视图下配置encapsulation-mode命令指定SRv6 TE Policy的封装模式为普通封装的简化模式时,本功能优先生效。
# 配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
[Sysname-srv6-te-policy-1] encapsulation-mode encaps include local-end.x
·     srv6-policy encapsulation-mode encaps include local-end.x
1.1.48  encapsulation-mode insert include local-end.x
encapsulation-mode insert include local-end.x命令用来配置SRv6 TE Policy转发报文时插入的SRH中是否包含本地End.X SID。
undo encapsulation-mode insert include local-end.x命令用来恢复缺省情况。
encapsulation-mode insert include local-end.x [ disable ]
未配置通过SRv6 TE Policy转发报文时插入的SRH中是否包含本地End.X SID,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:配置通过SRv6 TE Policy转发报文时插入的SRH中不包含本地End.X SID。如果未指定本参数,则通过SRv6 TE Policy转发报文时插入的SRH中包含本地End.X SID。
引流到SRv6 TE Policy时,缺省情况下,如果头节点的SRv6 SID是End.X SID,则不会将该SID封装到SRH中。配置本命令后,插入SRH时可以添加本地的End.X SID。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的封装模式为包含本地End.X SID模式。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
配置了本功能的同时,在SRv6 TE Policy视图下配置encapsulation-mode命令指定SRv6 TE Policy的封装模式为插入封装的简化模式时,本功能优先生效。
# 配置通过SRv6 TE Policy转发报文时插入的SRH中包含本地End.X SID。
[Sysname-srv6-te-policy-1] encapsulation-mode insert include local-end.x
1.1.49  end-point
end-point命令用来配置SRv6 TE Policy组的目的节点地址。
undo end-point命令用来恢复缺省情况。
undo end-point ipv6
未配置SRv6 TE Policy组的目的节点地址。
SRv6 TE Policy组视图
ipv6 ipv6-address:指定SRv6 TE Policy组的目的节点地址。
SRv6 TE Policy组中所有SRv6 TE Policy的目的节点地址必须与该SRv6 TE Policy组的目的节点地址相同。
多次执行本命令,最后一次执行的命令生效。
# 配置SRv6 TE Policy组的目的节点地址为100::2。
[Sysname-srv6-te-policy-group-10] end-point ipv6 100::2
1.1.50  expect-bandwidth
expect-bandwidth命令用来配置SRv6 TE Policy或SRv6 TE IPR模板的业务期望带宽。
undo expect-bandwidth命令用来恢复缺省情况。
expect-bandwidth bandwidth-value
SRv6 TE Policy或SRv6 TE IPR模板承载业务的期望带宽为0kbps。
SRv6 TE Policy视图
SRv6 TE IPR模板视图
bandwidth-value:指定期望带宽,取值范围为1~400000000,单位为kbps。
应用场景
SRv6 TE Policy的智能策略路由功能根据带宽使用情况进行路径优选时,可以配置业务期望带宽作为首次选取合适的SRv6 TE Policy的触发值,避免业务首次选取SRv6 TE Policy转发后,该SRv6 TE Policy的转发出接口带宽利用率超限而造成拥塞丢包。另外,如果未统计到SRv6 TE Policy的流量数据时,也需要使用期望带宽来计算SRv6 TE Policy的预期平均带宽利用率。
expect-bandwidth命令配置的期望带宽表示该业务预估占用带宽的经验值,而非业务实际使用的带宽值。
工作机制
SRv6 TE Policy的智能策略路由功能根据带宽使用情况进行路径优选时,将计算SRv6 TE Policy预期平均带宽利用率。SRv6 TE Policy的预期平均带宽利用率=(业务期望带宽+当前接口已占用的带宽)/出接口的总带宽。其中,业务期望带宽选取规则如下,优先使用当前承载该业务的SRv6 TE Policy的实时统计作为业务期望带宽。如果SRv6 TE Policy未承载指定业务或者没有统计到SRv6 TE Policy的流量时,则选择该SRv6 TE Policy视图下expect-bandwidth命令配置的SRv6 TE Policy业务期望带宽。如果SRv6 TE Policy视图下未配置业务期望带宽时,则选择SRv6 TE IPR模板视图下expect-bandwidth命令指定的SRv6 TE IPR模板的业务期望带宽。
推荐配置
配置本功能时管理员需要根据业务实际情况和经验来预估SRv6 TE Policy或SRv6 TE IPR模板中将要承载的业务所需的带宽。例如,预估视频会议业务的期望带宽为200Mbps,视频会议业务通过IPR模板转发。IPR模板中存在高优先的SRv6 TE Policy A和低优先SRv6 TE Policy B,SRv6 TE Policy A和SRv6 TE Policy B的出接口分别为千兆接口A和千兆接口B。接口A和接口B当前已使用了800Mbps和300Mbps带宽,此时,如果未配置expect-bandwidth命令,期望带宽为0kbps,IPR模板的带宽利用率的阈值上限为90%,SRv6 TE Policy A和SRv6 TE Policy B均能满足带宽利用率要求。因此,IPR将优选高优先的SRv6 TE Policy A作为优选路径来转发视频会议业务流量,但实际上视频会议业务流量与接口A的带宽之和不仅超出IPR模板的带宽利用率的阈值上限,而且达到接口带宽上限。所以,管理员需要设置业务期望带宽来避免上述问题。
注意事项
请先执行forwarding statistics命令或srv6-policy forwarding statistics enable命令开启IPR模板中所有SRv6 TE Policy的流量转发统计功能,SRv6 TE Policy智能策略路由基于带宽使用情况进行路径调优才能更加准确。
# 配置SRv6 TE Policy 1的业务期望带宽为30000kbps。
[Sysname-srv6-te-policy-1] expect-bandwidth 30000
# 配置SRv6 TE IPR模板ipr1的业务期望带宽为30000kbps。
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] expect-bandwidth 30000
·     bandwidth sample
·     expect-bandwidth
·     srv6-policy bandwidth sample enable
1.1.51  explicit segment-list
explicit segment-list命令用来为指定优先级的SRv6 TE Policy候选路径配置SID列表。
undo explicit segment-list命令用来删除SRv6 TE Policy候选路径的SID列表或恢复SID列表的缺省权重值。
explicit segment-list segment-list-name [ local-binding-sid ipv6 ipv6-address ipv6-address | reverse-binding-sid ipv6 ipv6-addres | weight weight-value ] *
undo explicit segment-list segment-list-name [ local-binding-sid | reverse-binding-sid | weight ] *
指定优先级的SRv6 TE Policy候选路径下不存在SID列表。
SRv6 Policy Path Preference视图
segment-list-name:SID列表名称,为1~128个字符的字符串,区分大小写。
local-binding-sid ipv6 ipv6-address:指定用于BFD检测的本地BSID。如果未指定本参数,则使用SID列表下配置的本地BSID。
·     通过本参数配置的BSID值不能和SID列表下local-binding-sid命令配置的BSID值相同。
·     同时配置本参数和在SID列表下配置local-binding-sid命令,则本参数优先生效。
reverse-binding-sid ipv6 ipv6-address:指定用于BFD检测的反向BSID。如果未指定本参数,则使用SID列表下配置的反向BSID。
·     通过本参数配置的BSID值不能和SID列表下reverse-binding-sid命令配置的BSID值相同。
·     同时配置本参数和在SID列表下配置reverse-binding-sid命令,则本参数优先生效。
weight weight-value:SID列表的权重值,取值范围为1~4294967295,缺省值为1。
工作机制
当通过指定SRv6 TE Policy转发流量时,会选取优先级最高的有效候选路径下配置的SID列表作为该流量的转发路径。
同一SRv6 TE Policy Path Preference视图下可以配置多个SID列表。多个SID列表均可以转发流量,实现负载分担。通过为SID列表指定不同的权重,可以按照比例对流量进行转发。例如,创建SID列表a、b、c,配置其权重分别为x、y、z,此时SID列表a转发流量的比例为x/(x+y+z)。
对于同一SID列表,多次指定其权重值,最后一次指定的权重值生效。
# 为SRv6 TE Policy中优先级为20的候选路径配置SID列表为abc,其权重为20。
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 20
[Sysname-srv6-te-policy-a1-path-pref-20] explicit segment-list abc weight 20
·     segment-list
1.1.52  fast-reroute mirror delete-delay
fast-reroute mirror delete-delay命令用来配置Mirror FRR的延迟删除时间。
undo fast-reroute mirror delete-delay命令用来恢复缺省情况。
fast-reroute mirror delete-delay delete-delay-time
Mirror FRR延迟删除时间为60秒。
IS-IS IPv6单播地址族视图
OSPFv3视图
delete-delay-time:延迟删除时间,取值范围为1~21845,单位为秒。
在尾节点保护场景中,切换到Mirror FRR路径后,流量沿着Mirror FRR路径转发。当中间节点完成路由收敛后,会删除Mirror FRR路径。如果此时头节点未完成路径切换,仍将流量转发给中间节点,由于中间节点上不存在Mirror FRR路径,流量会被丢弃。
为了避免上述情况,可以在中间节点上配置Mirror FRR的延迟删除时间,延迟删除Mirror FRR路由,使流量沿着Mirror FRR路径转发,避免丢包。
# 在IS-SI进程1下配置Mirror FRR的延迟删除时间为100秒。
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute mirror delete-delay 100
# 在OSPFv3进程1下配置Mirror FRR的延迟删除时间为100秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror delete-delay 100
·     fast-reroute mirror enable
1.1.53  fast-reroute mirror enable
fast-reroute mirror enable命令用来开启尾节点保护功能。
undo fast-reroute mirror enable命令用来关闭尾节点保护功能。
尾节点保护功能处于关闭状态。
IS-IS IPv6单播地址族视图
OSPFv3视图
工作机制
在某个SRv6节点上开启尾节点保护功能后,该节点可以根据收到的IS-ISv6路由或OSPFv3路由中携带的End.M SID,计算到达尾节点的备份路径信息,即Mirror FRR路径信息。当尾节点故障后,中间节点可以根据End.M SID,将流量转发到对尾节点进行保护的节点处理,避免流量丢失。
注意事项
在尾节点上游的中间节点上开启尾节点保护功能的同时,还需要在对应视图下开启TI-LFA FRR功能,设备才能计算出备份路径。
# 开启IS-IS尾节点保护功能。
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute mirror enable
# 开启OSPFv3尾节点保护功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute mirror enable
1.1.54  forwarding statistics
forwarding statistics命令用来配置SRv6 TE Policy的流量转发统计功能。
undo forwarding statistics命令用来恢复缺省情况。
forwarding statistics { disable | [ service-class ] enable }
未配置SRv6 TE Policy的流量转发统计功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的流量转发统计功能。
enable:开启SRv6 TE Policy的流量转发统计功能。
service-class:开启基于隧道转发类的SRv6 TE Policy流量统计功能,即不仅对SRv6 TE Policy隧道转发的总流量进行统计,还会对隧道转发的每个隧道转发类的流量分别进行统计。如果不指定本参数,则只对SRv6 TE Policy隧道转发的总流量进行统计。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的流量转发统计功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy 1的流量转发统计功能。
[Sysname-srv6-te-policy-1] forwarding statistics enable
·     display segment-routing ipv6 te forwarding
·     reset segment-routing ipv6 te forwarding statistics
·     srv6-policy forwarding statistic enable
·     srv6-policy forwarding statistic interval
1.1.55  forward-type (SRv6 TE ODN Policy group view)
forward-type命令用来创建转发类型,并进入对应的转发类型视图。如果指定的转发类型已经存在,则直接进入该转发类型视图。
undo forward-type命令用来恢复缺省情况。
forward-type { apn-id | dscp | te-class }
undo forward-type { apn-id | dscp | te-class }
不存在转发类型,由ODN自动创建的SRv6 TE Policy组无法引流。
SRv6 TE ODN Policy组视图
apn-id:配置SRv6 TE Policy组的转发类型为APN ID,即基于APN ID引流。
dscp:配置SRv6 TE Policy组的转发类型为DSCP,即根据DSCP引流。
te-class:配置SRv6 TE Policy组的转发类型为TE Class,即基于流量的TE Class ID转发。
通过本命令可以指定由ODN自动创建的SRv6 TE Policy组的引流方式。目前由ODN自动创建的SRv6 TE Policy组支持基于APN ID、TE Class ID和DSCP引流。
当转发类型为DSCP时,引流过程为:
(1)     根据报文的DSCP值与color match dscp命令配置的映射关系进行匹配;
(2)     如果匹配到color match dscp命令中某个Color属性,且该Color属性对应的SRv6 TE Policy有效,则采用这个SRv6 TE Policy转发流量。
当转发类型为TE Class ID,引流过程为:
(1)     SRv6 TE Policy组的头节点根据报文携带的本地TE Class ID查找与其关联的Color属性、IPR模板名称或者SRv6 BE转发策略。
(2)     如果TE Class ID关联到某个Color属性,则设备将流量引入到Color属性对应的SRv6 TE Policy中转发;如果TE Class ID关联到某个IPR模板,则设备按照该IPR模板中定义的SRv6 TE Policy选路策略将流量引入最优的SRv6 TE Policy中转发;如果TE Class ID关联SRv6 BE转发策略,则流量通过SRv6 BE方式转发,设备为流量报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
(3)     如果流量的TE Class ID未关联任何转发策略,则按照default match命令指定的默认转发策略进行转发。
当转发类型为APN ID时,引流过程为:
(1)     将流量的APN ID标识,与index apn-id match命令配置的映射关系进行匹配。
(2)     如果匹配到index apn-id match命令配置的SRv6 TE Policy或者SRv6 BE转发策略,且该SRv6 TE Policy或者SRv6 BE有效,则采用这个SRv6 TE Policy或者SRv6 BE转发流量。
(3)     如果未正常匹配,则根据具体情况,按照index apn-id match命令的使用指导转发报文。
在SRv6 TE Policy组的头节点上,管理员可以利用QoS策略中的remark te-class命令,为符合匹配规则的流量标记TE Class ID值。利用QoS策略中的remark apn-id ipv6 instance命令,可以为符合匹配规则的流量标记APN ID值。
# 创建转发类型DSCP,并进入DSCP转发类型视图。
[Sysname-srv6-te] on-demand-group color 1
[Sysname-srv6-te-odn-group-1] forward-type dscp
[Sysname-srv6-te-odn-group-1-dscp]
# 配置SRv6 TE Policy组的转发类型为TE Class,并进入TE Class转发类型视图。
[Sysname-srv6-te-odn-group-1] forward-type te-class
[Sysname-srv6-te-odn-group-1-te-class]
·     color match dscp (DSCP forward type view)
·     default match(APN ID)
·     default match(TE Class ID)
·     index apn-id match
·     remark apn-id ipv6 instance(QoS和ACL命令参考/QoS)
·     remark te-class(QoS和ACL命令参考/QoS)
1.1.56  forward-type (SRv6 TE Policy group view)
forward-type命令用来配置SRv6 TE Policy组的转发类型。
forward-type { apn-id | te-class }
undo forward-type { apn-id | te-class }
SRv6 TE Policy组基于DSCP引流。
SRv6 TE Policy组视图
通过本命令可以指定静态手工创建的SRv6 TE Policy组的引流方式。目前静态手工创建的SRv6 TE Policy组支持基于DSCP、TE Class ID和APN ID引流。
在SRv6 TE Policy组的头节点上,管理员可以利用QoS策略中的remark te-class命令,为符合匹配规则的流量标记TE Class ID值。TE Class ID仅作为本地标识。利用QoS策略中的remark apn-id ipv6 instance命令,可以为符合匹配规则的流量标记APN ID值。
当转发类型为DSCP时,引流过程为:
当转发类型为TE Class ID时,引流过程为:
# 配置SRv6 TE Policy组的转发类型为APN ID。
[Sysname-srv6-te] policy-group 1
[Sysname-srv6-te-policy-group-1] forward-type apn-id
1.1.57  group-color
group-color命令用来配置SRv6 TE Policy组的Color值。
undo group-color命令用来恢复缺省情况。
group-color color-value
undo group-color
未配置SRv6 TE Policy组的Color值。
SRv6 TE Policy组视图
color-value:Color值,取值范围为0~4294967295。
通过本命令指定SRv6 TE Policy组的Color值后,可以通过Color引流方式将流量引入指定SRv6 TE Policy组。
SRv6 TE Policy组的Color值和SRv6 TE Policy组中SRv6 TE Policy的Color值可以相同,也可以不同,二者互不影响。
# 配置SRv6 TE Policy组的Color值为1。
[Sysname-srv6-te-policy-group-1] group-color 1
1.1.58  ifit delay-measure
ifit delay-measure命令用来配置SRv6 TE Policy的iFIT时延和抖动测量功能。
undo ifit delay-measure命令用来恢复缺省情况。
ifit delay-measure { disable | enable }
未配置SRv6 TE Policy的iFIT时延和抖动测量功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:表示关闭SRv6 TE Policy的iFIT时延和抖动测量功能。
enable:表示开启SRv6 TE Policy的iFIT时延和抖动测量功能。
配置准备
为了使本功能生效,请先配置以下功能:
·     在SRv6 TE Policy的头节点开启iFIT功能,配置iFIT设备的标识,并设置iFIT的工作模式为分析器,执行service-type srv6-segment-list命令。
·     在SRv6 TE Policy的尾节点或者中间节点上开启iFIT功能,并设置iFIT的工作模式为收集器,执行service-type srv6-segment-list命令。
应用场景
iFIT(In-situ Flow Information Telemetry,随流检测)是一种随流OAM检测技术,通过直接在业务报文中封装携带了测量周期、丢包标记和时延标记等信息的iFIT选项字段,来测量网络中业务的真实丢包率、时延和抖动。关于iFIT的详细介绍,请参考“网络监控和管理配置指导”中的“iFIT”。
当业务流量被引入到SRv6 TE Policy组中转发,且SRv6 TE Policy组的转发类型为基于流量的TE Class ID转发时,设备可以将指定TE Class ID值的业务流量按照IPR模板中定义的SRv6 TE Policy选路策略进行转发。
开启SRv6 TE Policy的iFIT时延和抖动测量功能后,设备将通过iFIT测量SRv6 TE Policy的时延和抖动,并将该时延和抖动与IPR模板中定义的时延和抖动标准进行比较,iFIT测量SRv6 TE Policy的时延和抖动将作为SRv6 TE Policy优选的条件,如果不符合该时延和抖动标准的SRv6 TE Policy不能作为流量转发路径。
工作机制
在SRv6 TE Policy的头节点配置本功能后,SRv6 TE Policy的头节点和尾节点将测量通过SRv6 TE Policy转发流量的端到端时延和抖动。测量过程为:
(1)     头节点自动创建iFIT实例,并分配FlowID。
(2)     头节点作为数据发送端,当报文通过SRv6 TE Policy转发时,头节点为原始报文封装携带iFIT选项字段的DOH报文头和SRH报文头,并记录SRv6 TE Policy的iFIT检测周期内从该SRv6 TE Policy发送报文的时间戳。
(3)     尾节点作为数据接收端,解析报文中iFIT选项字段的信息,得到SRv6 TE Policy的iFIT检测周期等信息,记录本SRv6 TE Policy的iFIT检测周期内从SRv6 TE Policy接收到报文的时间戳;
(4)     头节点上配置encapsulation source-address命令为为通过SRv6 TE Policy转发的报文指定源地址,尾节点则通过接收到报文的源地址与头节点建立UDP会话,并将记录的报文时间戳按照SRv6 TE Policy的iFIT检测周期返回给头节点,由头节点分析和计算通过SRv6 TE Policy转发报文的时延和抖动。
注意事项
只有存在通过SRv6 TE Policy转发的数据业务流量时,iFIT才能测量该SRv6 TE Policy的时延和抖动。
如果同时配置本命令和SRv6 TE视图下的srv6-policy ifit delay-measure enable命令,则本命令优先生效。
如果尾节点不是H3C设备,请在倒数第二跳(即转发路径上的H3C设备)上开启iFIT功能,并设置iFIT的工作模式为收集器,该设备将作为数据接收端记录时间戳,建立UDP会话并将时间戳反馈给头节点,完成尾节点的功能。
如果存在多个节点都向头节点反馈数据,则头节点的处理方式为:
·     如果尾节点和其他多个节点都向头节点反馈数据,则头节点优先选择SRv6 TE Policy尾节点反馈的数据计算时延和抖动。
·     如果存在多个非尾节点都向头节点反馈数据,则头节点优先选择SRv6 TE Policy中最靠近尾节点的节点反馈的数据计算时延和抖动。
为保证iFIT检测正常生效,要求所有参与iFIT测量的设备时间已经同步,否则iFIT计算结果将不准确。NTP(Network Time Protocol,网络时间协议)和PTP(Precision Time Protocol,精确时间协议)都可用于实现设备间的时间同步。
# 开启SRv6 TE Policy 1的iFIT时延测量功能。
[Sysname-srv6-te-policy-1]ifit delay-measure enable
·     ifit enable(网络管理和监控命令参考/iFIT)
·     ifit interval
·     service-type srv6-segment-list(网络管理和监控命令参考/iFIT)
·     work-mode analyzer(网络管理和监控命令参考/iFIT)
·     work-mode collector(网络管理和监控命令参考/iFIT)
1.1.59  ifit interval
ifit interval命令用来配置SRv6 TE Policy的iFIT检测周期。
undo ifit interval命令用来恢复缺省情况。
ifit interval time-value
undo ifit interval
未配置SRv6 TE Policy的iFIT检测周期,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
time-value:SRv6 TE Policy的iFIT检测周期,取值范围为10、30、60、300,单位为秒。
本功能仅需在SRv6 TE Policy的头节点上配置。
开启本功能后,SRv6 TE Policy的头节点会将本命令配置的检测周期添加到iFIT报文中,按照该检测周期来统计通过SRv6 TE Policy转发报文的计数和时间戳,并且以该检测周期计算SRv6 TE Policy的时延、抖动和丢包率。
SRv6 TE Policy的尾节点从iFIT报文中获取检测周期,按该检测周期来统计通过SRv6 TE Policy转发报文的计数和时间戳,并且以检测周期向SRv6 TE Policy的头节点反馈计数和时间戳等信息。
如果同时配置本命令和SRv6 TE视图下的srv6-policy ifit interval命令,则本命令优先生效。
# 配置SRv6 TE Policy 1的iFIT检测周期为60秒。
[Sysname-srv6-te-policy-1] ifit interval 60
·     ifit loss-measure
1.1.60  ifit loss-measure
ifit loss-measure命令用来配置SRv6 TE Policy的iFIT丢包率测量功能。
undo ifit loss-measure命令用来恢复缺省情况。
ifit loss-measure { disable | enable }
未配置SRv6 TE Policy的iFIT丢包率测量功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:表示关闭SRv6 TE Policy的iFIT丢包率测量功能。
enable:表示开启SRv6 TE Policy的iFIT丢包率测量功能。
配置准备
为了使本功能生效,请先配置以下功能:
应用场景
开启SRv6 TE Policy的iFIT丢包率测量功能后,设备将通过iFIT测量SRv6 TE Policy的丢包率,并将该丢包率与IPR模板中定义的丢包率标准进行比较,iFIT测量SRv6 TE Policy的丢包率作为SRv6 TE Policy优选的条件,如果不符合该丢包率标准的SRv6 TE Policy不能作为流量转发路径。
工作机制
在SRv6 TE Policy的头节点配置本功能后,SRv6 TE Policy的头节点和尾节点将测量通过SRv6 TE Policy转发流量的端到端丢包率。测量过程为:
(2)     头节点作为数据发送端,当报文通过SRv6 TE Policy转发时,头节点为原始报文封装携带iFIT选项字段的DOH报文头和SRH报文头,并统计SRv6 TE Policy的iFIT检测周期内通过该SRv6 TE Policy转发的报文个数。
(3)     尾节点作为数据接收端,解析报文中iFIT选项字段的信息,得到SRv6 TE Policy的iFIT检测周期等信息,统计SRv6 TE Policy的iFIT检测周期内从SRv6 TE Policy接收到的报文个数。
(4)     头节点上配置encapsulation source-address命令为通过SRv6 TE Policy转发的报文指定源地址,尾节点通过接收到报文的源地址与头节点建立UDP会话,并将统计到的报文计数通过UDP会话按照SRv6 TE Policy的iFIT检测周期返回给头节点,由头节点分析和计算通过SRv6 TE Policy转发报文的丢包率。
注意事项
只有存在通过SRv6 TE Policy转发的数据业务流量时,iFIT才能测量该SRv6 TE Policy的丢包率。如果同时配置了本命令和SRv6 TE视图下的srv6-policy ifit loss-measure enable命令,则本命令优先生效。
如果尾节点不是H3C设备,请在倒数第二跳(即转发路径上的H3C设备)上开启iFIT功能,并设置iFIT的工作模式为收集器,将该设备作为数据接收端来统计数据、与头节点建立UDP会话并将统计数据反馈给头节点,完成尾节点的功能。
如果多个节点都向头节点反馈数据,则头节点的处理方式为:
·     如果尾节点和其他多个节点都向头节点反馈数据,则头节点优先选择SRv6 TE Policy尾节点反馈的数据计算丢包率。
·     如果多个非尾节点都向头节点反馈数据,则头节点优先选择SRv6 TE Policy中最靠近尾节点的节点反馈的数据计算丢包率。
为保证iFIT检测正常生效,要求所有参与iFIT测量的设备时间同步,否则iFIT计算结果将不准确。NTP(Network Time Protocol,网络时间协议)和PTP(Precision Time Protocol,精确时间协议)都可用于实现设备间的时间同步。
# 开启SRv6 TE Policy aaa的iFIT丢包率测量功能。
[Sysname-srv6-te] policy aaa
[Sysname-srv6-te-policy-aaa] ifit loss-measure enable
·     ifit interval
1.1.61  ifit measure mode
ifit measure mode命令用来配置SRv6 TE Policy的iFIT测量模式。
undo ifit measure mode命令用来恢复缺省情况。
ifit measure mode { e2e | trace }
未配置SRv6 TE Policy的iFIT测量模式,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
e2e:指定全局SRv6 TE Policy的iFIT测量模式为端到端模式。在该模式下,只有SRv6 TE Policy的尾节点会将iFIT测量结果反馈给SRv6 TE Policy的头节点用于计算SRv6 TE Policy的网络质量。
trace:指定全局SRv6 TE Policy的iFIT测量模式为逐跳模式。在该模式下,目标流途经的设备上,只要开启了iFIT功能,并且检测到了iFIT报文,就会将iFIT测量结果反馈给SRv6 TE Policy的头节点用于计算SRv6 TE Policy的网络质量。
配置准备
为了使本功能生效,请先配置以下功能:
推荐配置
·     当SRv6 TE Policy的尾节点非H3C设备时,必须配置SRv6 TE Policy的iFIT测量模式为逐跳模式,此时在倒数第二跳(即转发路径上的H3C设备)上开启iFIT功能,设置iFIT的工作模式为收集器,将该设备作为数据接收端来统计数据、与头节点建立UDP会话并将统计数据反馈给头节点,完成尾节点的功能。逐跳模式通常仅用于SRv6 TE Policy的尾节点非H3C设备的场景。
·     当SRv6 TE Policy的头节点和尾节点均为H3C设备时,建议配置SRv6 TE Policy的iFIT测量模式为端到端模式,此时由尾节点将iFIT测量结果反馈给SRv6 TE Policy的头节点用于计算SRv6 TE Policy的网络质量。其他目标流量途径的中间节点即使开启了iFIT功能且检测到了iFIT报文也不会将iFIT测量结果反馈给SRv6 TE Policy的头节点,降低设备处理的复杂度。
工作机制
配置SRv6 TE Policy的iFIT测量模式之后,SRv6 TE Policy的头节点为报文封装的iFIT选项字段中将携带iFIT测量模式的信息,报文在转发过程中将iFIT测量模式通知给途经的设备。
当SRv6 TE Policy的iFIT测量模式为端到端模式,则仅开启iFIT功能,并检测到了iFIT报文的尾节点将测量数据通过UDP会话反馈给头节点,其他途径节点将不反馈测量信息。
当SRv6 TE Policy的iFIT测量模式为逐跳模式,则所有开启iFIT功能,并检测到了iFIT报文的目标流途径节点都将测量数据通过UDP会话反馈给头节点,由头节点决策选取测量数据信息。如果存在多个非尾节点都向头节点反馈数据,则头节点优先选择SRv6 TE Policy中最靠近尾节点的节点反馈的数据计算网络质量。
注意事项
如果同时配置本命令和SRv6 TE视图下的srv6-policy ifit measure mode命令,则本命令优先生效。
# 配置SRv6 TE Policy的iFIT测量模式为逐跳模式。
[Sysname-srv6-te-policy-1] ifit measure mode trace
·     srv6-policy ifit measure mode
1.1.62  import-route sr-policy
import-route sr-policy命令用来将BGP IPv6 SR Policy路由引入到BGP路由表中,以便通过BGP发布引入的路由。
undo import-route sr-policy命令用来恢复缺省情况。
BGP不会引入BGP IPv6 SR Policy路由。
BGP IPv6 SR Policy地址族视图
配置本命令后,设备将本地的BGP IPv6 SR Policy路由引入到BGP路由表中,并将该路由发布给IBGP对等体,以便对等体根据SRv6 TE Policy转发流量。
# 在BGP IPv6 SR Policy地址族视图下,引入BGP IPv6 SR Policy路由。
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] import-route sr-policy
1.1.63  mirror remote-sid delete-delay
mirror remote-sid delete-delay命令用来配置远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间。
undo mirror remote-sid delete-delay命令用来恢复缺省情况。
mirror remote-sid delete-delay delete-delay-time
远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间为60秒。
SRv6视图
在尾节点保护场景中,当尾节点故障时,保护节点与尾节点之间邻居中断,会导致保护节点从尾节点收到的BGP路由删除,进而导致远端SRv6 SID与VPN实例/交叉连接/VSI映射表被删除,造成丢包。为了避免上述情况,可以在对尾节点进行保护的节点上延迟删除远端SRv6 SID与VPN实例/交叉连接/VSI映射表,在头节点感知到尾节点故障计算出新的转发路径前,保证流量通过保护节点转发,避免丢包。
# 配置远端SRv6 SID与VPN实例/交叉连接/VSI映射表的延迟删除时间为100秒。
[Sysname-segment-routing-ipv6] mirror remote-sid delete-delay 100
1.1.64  index
index命令用来在SID列表中添加节点。
undo index命令用来删除SID列表中指定节点。
index index-number ipv6 ipv6-address
index index-number coc32 ipv6 ipv6-address common-prefix-length
undo index index-number
SID列表中不存在任何节点。
SID列表视图
index-number:SID列表的节点索引值,取值范围为1~65535。
ipv6 ipv6-address:SID列表中指定节点对应的IPv6地址。
coc32:添加COC标识,表示当前节点的下一节点为32bits G-SID。
common-prefix-length:下一个G-SID的公共前缀长度,取值范围为1~94。
在SID列表中添加G-SID时,本命令common-prefix-length参数配置值必须与下一节点所属的Locator段中的公共前缀长度一致。
在SID列表中添加G-SID时,需要保证:
·     G-SID的前一节点对应的SRv6 SID必须是End(COC32) SID或End.X(COC32) SID。
·     SID列表最后一个节点对应的SRv6 SID不能携带COC标识。
# 在SID列表abc中添加节点,其节点索引为1,IPv6地址为1000::1。
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc] index 1 ipv6 1000::1
# 在SID列表text中添加节点,其中:
·     节点索引为10,IPv6地址为100::1,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为20,IPv6地址为200::1:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为30,IPv6地址为200::2:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为40,IPv6地址为200::3:0:0,下一节点为32bits G-SID,G-SID的公共前缀长度为64。
·     节点索引为50,IPv6地址为200::4:0:0。
·     节点索引为60,IPv6地址为300::3。
[Sysname-srv6-te] segment-list text
[Sysname-srv6-te-sl-abc] index 10 coc32 ipv6 100::1 64
[Sysname-srv6-te-sl-abc] index 20 coc32 ipv6 200::1:0:0 64
[Sysname-srv6-te-sl-abc] index 30 coc32 ipv6 200::2:0:0 64
[Sysname-srv6-te-sl-abc] index 40 coc32 ipv6 200::3:0:0:0 64
[Sysname-srv6-te-sl-abc] index 50 ipv6 200::4:0:0
[Sysname-srv6-te-sl-abc] index 60 ipv6 300::3
·     locator(Segment Routing命令参考/SRv6)
1.1.65  index apn-id match
index apn-id match命令用来配置指定APN ID和转发策略的映射关系。
undo index命令用来删除APN ID和转发策略的映射关系。
index index-value apn-id instance instance-name match { best-effort | srv6-policy color color-value }
undo index index-value
未配置APN ID和转发策略的映射关系。
SRv6 TE Policy组视图
APN ID转发类型视图
index-value:表示APN ID标识的流量和转发策略的映射关系的索引,取值范围为1~4294967294。
instance instance-name:指定APN ID实例。其中instance-name为APN ID实例名称,为1~31个字符的字符串,区分大小写。
best-effort:表示APN ID标识的流量通过SRv6 BE方式转发。
srv6-policy color color-value:表示APN ID标识的流量通过指定Color的SRv6 TE Policy转发,其中color-value表示SRv6 TE Policy的Color属性,取值范围为0~4294967295。
配置准备
只有先配置了SRv6 TE Policy组的转发类型为APN ID,即SRv6 TE Policy组视图或SRv6 TE ODN Policy组视图下执行forward-type apn-id命令后,本功能才生效。
应用场景
当业务流量被引入到SRv6 TE Policy组中转发时,配置本功能后,设备可以根据IPv6报文的APN ID标识,将流量引入到指定Color对应的SRv6 TE Policy中转发,或者采用SRv6 BE方式转发报文。
工作机制
通过SRv6 BE方式转发报文时,设备将为报文封装新的IPv6报文头,其中新IPv6报文头中的目的地址为SRv6 TE Policy Group尾节点上为公网或私网分配的VPN SID,封装后的报文查找IPv6路由表转发。
当流量引入SRv6 TE Policy组后,设备收到的报文未携带APN ID、报文的APN ID未匹配任何映射关系或者报文的APN ID匹配的SRv6 TE Policy/SRv6 BE无效时,依次按照如下优选顺序选择报文转发方式:
(1)     如果已执行default match命令配置了通过缺省的SRv6 TE Policy转发报文,且该SRv6 TE Policy有效,则优先采用该SRv6 TE Policy转发报文。
(2)     如果已执行default match命令配置了通过SRv6 BE转发报文,且SRv6 BE有效,则采用SRv6 BE方式转发报文。
(3)     未配置default match命令,或者default match命令配置的转发策略无效时,根据drop-upon-mismatch enable命令的配置情况,流量处理方式为:
¡     如果配置了drop-upon-mismatch enable命令,则流量将被直接丢弃。
¡     如果未配置drop-upon-mismatch enable命令,但通过本命令配置了APN ID和SRv6 TE Policy或SRv6 BE的映射关系,则查找其中SRv6 TE Policy或SRv6 BE有效且索引值最小的映射关系,采用该映射关系中指定的SRv6 TE Policy或SRv6 BE转发报文。
注意事项
只有SRv6 TE Policy有效时,才能建立APN ID与SRv6 TE Policy的映射关系,流量才可以通过该SRv6 TE Policy转发。
只有SRv6 BE转发方式有效,即设备IPv6路由表中存在目的为SRv6 TE Policy Group尾节点上为公网或私网分配的VPN SID的路由时,才能建立APN ID与SRv6 BE的映射关系,流量才可以通过SRv6 BE转发。
一个SRv6 TE Policy组内,同一个APN ID仅能关联一个Color对应的SRv6 TE Policy或者仅能关联SRv6 BE转发方式。
多次执行本命令,配置同一个APN ID和不同转发策略的映射关系,最后一次执行的命令生效。
多次执行本命令,在一个SRv6 TE Policy组内,配置多个APN ID实例和转发策略的映射关系时,如果多个APN ID实例名称对应的APN ID值相同,则按照index-value从小到大的顺序,选择index-value最小的映射关系对应的路径转发报文。
多次执行本命令,配置相同index-value,最后一次执行的命令生效。
# 配置APN ID和Color的映射关系:将APN ID实例为aa的报文引流到SRv6 TE Policy组中Color 20对应的SRv6 TE Policy中转发。
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] forward-type apn-id
[Sysname-srv6-te-policy-group-10] index 10 apn-id instance aa match srv6-policy color 20
# 配置APN ID和Color的映射关系:将APN ID实例为aa的报文引流到ODN方式创建的SRv6 TE Policy组中Color 20对应的SRv6 TE Policy转发。
[Sysname-srv6-te-odn-group-1] forward-type apn-id
[Sysname-srv6-te-odn-group-1-apn-id] index 10 apn-id instance aa match srv6-policy color 20
·     default match
·     drop-upon-mismatch enable
·     forward-type (SRv6 TE Policy group view)
·     forward-type (SRv6 TE ODN Policy group view)
1.1.66  index te-class match
index te-class match命令用来配置指定TE Class ID和SRv6 TE Policy、IPR模板或SRv6 BE转发策略间的映射关系。
undo index te-class match命令删除指定TE Class ID和SRv6 TE Policy、IPR模板或SRv6 BE转发策略间的映射关系。
index index-value te-class te-class-id match { best-effort | ipr-policy ipr-name | srv6-policy color color-value }
未配置TE Class ID和SRv6 TE Policy、IPR模板或SRv6 BE转发策略间的映射关系。
SRv6 TE Policy组视图
TE Class转发类型视图
index-value:表示TE Class ID标识的流量和转发策略的映射关系的索引,取值范围为0~4294967294。
te-class-id:TE Class ID值,取值范围为1~65535。
best-effort:表示TE Class ID标识的流量通过SRv6 BE方式转发,原始报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
ipr-policy ipr-name:表示TE Class ID标识的流量通过IPR方式转发,其中ipr-name表示IPR模板的名称,为1~31个字符的字符串,区分大小写。
srv6-policy color color-value:表示TE Class ID标识的流量通过指定Color值对应的SRv6 TE Policy转发,其中color-value为SRv6 TE Policy的Color属性,取值范围为0~4294967295。
配置准备
请先执行forward-type te-class命令配置SRv6 TE Policy组的转发类型为根据TE Class ID转发流量,本功能才能生效。
应用场景
配置本功能后,当业务流量被引入到SRv6 TE Policy组中转发时,设备可以将TE Class ID值标识的业务流量按照指定的转发策略进行转发。
工作机制
本功能支持将TE Class ID标识的流量按照以下方式转发:
·     如果流量的TE Class ID关联到某个Color属性,则设备将流量引入到Color属性对应的SRv6 TE Policy中转发。
·     如果流量的TE Class ID关联到某个IPR模板,则设备按照该IPR模板中定义的SRv6 TE Policy选路策略将流量引入到最优的SRv6 TE Policy中转发。
·     如果流量的TE Class ID关联到SRv6 BE转发策略,则流量通过SRv6 BE方式转发,即设备为流量报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
·     如果流量的TE Class ID未关联任何转发策略,则按照default match命令指定的默认转发策略进行转发。
流量引入SRv6 TE Policy组后,流量按照默认转发策略转发时,按如下优先顺序选取转发策略:
(1)     如果配置了默认转发方式为通过指定Color值对应的SRv6 TE Policy转发或者配置了默认转发方式为IPR方式,且用于转发的SRv6 TE Policy有效,则设备将流量引入到该SRv6 TE Policy中转发。
(2)     如果配置了默认转发方式为SRv6 BE方式,且SRv6 BE有效,则设备为报文封装新的IPv6头,之后通过查找IPv6路由表转发报文。
¡     如果未配置drop-upon-mismatch enable命令,但通过本命令配置了多个TE Class ID和IPR模板、SRv6 TE Policy或SRv6 BE的映射关系,则查找其中转发路径有效且索引值最小的映射关系,采用该映射关系中的SRv6 TE Policy或SRv6 BE转发报文。
注意事项
同一个TE Class ID只能对应一个索引值。
多次配置同一个index-value,最后一次配置的命令生效。
同一个TE Class ID标识的流量只能关联一个转发策略,例如,TE Class ID 10标识的流量与名称为ipr1的IPR模板建立映射关系,则该流量无法同时再与其他IPR模板、SRv6 TE Policy或者SRv6 BE转发方式建立映射关系。多次配置同一个TE Class ID和不同的转发策略的映射关系,最后一次配置的命令生效。
建议为不同Group ID标识的SRv6 TE Policy组配置不同的Endpoint。否则,具有相同Endpoint的一组SRv6 TE Policy将同时属于不同SRv6 TE Policy组。
# 将TE Class ID为100的流量映射到名称为ipr1的IPR模板转发。
[Sysname-srv6-te-policy-group-1] forward-type te-class
[Sysname-srv6-te-policy-group-1] index 10 te-class 100 match ipr-policy ipr1
·     default match (TE Class ID)
1.1.67  intelligent-policy-route
intelligent-policy-route命令用来开启智能策略路由功能,并进入SRv6 TE IPR视图。
undo intelligent-policy-route命令用来关闭智能策略路由功能并删除SRv6 TE IPR视图中的所有配置。
智能策略路由功能处于关闭状态。
SRv6 TE视图
IPR(intelligent Policy Route,智能策略路由)是一种根据SRv6 TE Policy的iFIT检测参数,从SRv6 TE Policy组中动态选取最优SRv6 TE Policy的选路策略。
通过在智能策略路由中定义不同的IPR模板,可以设置不同的网络质量标准、SRv6 TE Policy的优先顺序和切换策略。不同的IPR模板用于满足不同业务对网络质量的需求。
IPR需要与SRv6 TE Policy的iFIT丢包率、时延和抖动测量功能配合,才能实现SRv6 TE Policy的动态优选功能。
# 开启智能策略路由功能,并进入SRv6 TE IPR视图。
[Sysname-srv6-te-ipr]
1.1.68  ipr-policy
ipr-policy命令用来配置IPR模板,并进入对应的SRv6 TE IPR模板视图。如果指定的IPR模板已经存在,则直接进入该SRv6 TE IPR模板视图。
undo ipr-policy命令用来删除IPR模板及IPR模板中的配置。
ipr-policy ipr-name
undo ipr-policy
不存在IPR模板。
SRv6 TE IPR视图
ipr-name:IPR模板的名称,为1~31个字符的字符串,区分大小写。
应用场景
当业务流量被引入到SRv6 TE Policy组中转发,且SRv6 TE Policy组的转发类型为基于流量的TE Class ID转发时,管理员可以执行index te-class match命令将指定TE Class ID标识的业务流量和IPR模板建立映射关系,此时,SRv6 TE Policy组将引用IPR模板并将该流量按照IPR模板中定义的SRv6 TE Policy选路策略进行转发。
工作机制
SRv6 TE IPR视图下可以创建多个IPR模板,每个IPR模板代表一种基于SLA(Service Level Agreement,服务水平协议)的SRv6 TE Policy选路策略。IPR模板中可以定义如下内容:
·     不同的SLA(Service Level Agreement,服务水平协议)标准,包括业务流量的时延标准、丢包标准、抖动标准和综合度量指标CMI(Composite Measure Indicator)标准。
·     SRv6 TE Policy的Color值和选路优先级的映射关系。
·     SRv6 TE Policy的切换时间和回切时间。
IPR模板需要和SRv6 TE Policy的iFIT丢包率、时延和抖动测量功能配合实现智能路由优选,IPR模板和SRv6 TE Policy的iFIT测量功能配合工作机制为:
(1)     iFIT检测网络质量:管理员在SRv6 TE Policy组的头节点开启SRv6 TE Policy的iFIT丢包率、时延和抖动测量功能。iFIT功能可以检测SRv6 TE Policy组中不同SRv6 TE Policy的链路质量,并按照SRv6 TE Policy的iFIT检测周期将SLA检测参数传递给SRv6 TE Policy头节点的智能策略路由,由智能策略路由进行算路和优选。
(2)     计算备选路径:SRv6 TE Policy头节点按照refresh-period命令设置的最优路径计算周期来计算最优的SRv6 TE Policy。如果SRv6 TE Policy头节点计算最优路径时,发现最近一次iFIT功能计算得到的时延、丢包率、抖动和CMI任一指标不满足IPR模板中设置的标准,则表示该SRv6 TE Policy不符合SLA标准,该SRv6 TE Policy不能作为备选路径用于业务转发;如果SRv6 TE Policy的iFIT功能未能检测到某个SRv6 TE Policy的时延、丢包率、抖动和CMI参数,但该SRv6 TE Policy有效,则该SRv6 TE Policy仍作为备选路径用于业务转发。
(3)     备选路径选路:SRv6 TE Policy组的头节点根据IPR模板中定义的SRv6 TE Policy的优先顺序,选取优先级最高的SRv6 TE Policy作为最优转发路径,并将业务流量引入到该SRv6 TE Policy中转发。当存在优先级相同的SRv6 TE Policy时,流量可以在这些SRv6 TE Policy之间负载分担。
注意事项
如果需要删除已被引用的IPR模板,请先删除IPR模板和指定TE Class ID值的映射关系,再删除该IPR模板。
# 配置名称为ipr1的IPR模板,并进入该SRv6 TE IPR模板视图。
[Sysname-srv6-te-ipr] ipr-policy ipr1
·     index te-class match
1.1.69  jitter threshold
jitter threshold命令用来配置IPR模板的抖动标准。
undo jitter threshold命令用来恢复缺省情况。
jitter threshold time-value
IPR模板的抖动标准为3000毫秒。
SRv6 TE IPR模板视图
time-value:IPR模板的抖动标准,取值范围为0~3000,单位为毫秒。
只有SRv6 TE Policy的iFIT时延和抖动测量功能检测到SRv6 TE Policy的抖动不超过本命令设置的抖动标准,则该SRv6 TE Policy才能作为备选的转发路径,参与最优SRv6 TE Policy选路过程。
如果SRv6 TE Policy的最优候选路径下存在多条带权重的有效Segment List,智能策略路由计算SRv6 TE Policy的抖动是否符合标准时,则设备将该SRv6 TE Policy的最优候选路径下的所有有效Segment List的iFIT抖动加权值作为该SRv6 TE Policy的抖动。
# 配置IPR模板ipr1的抖动标准为20毫秒。
[Sysname-srv6-ipr-policy-ipr1] jitter threshold 20
1.1.70  local-binding-sid
local-binding-sid命令用来配置本地BSID。
undo local-binding-sid命令用来恢复缺省情况。
不存在本地BSID。
SID列表视图
ipv6 ipv6-address:本地BSID对应的IPv6地址。ipv6-address为IPv6地址。
通过BFD echo或SBFD方式检测SRv6 TE Policy连通性时,缺省情况下,BFD或SBFD回程报文通过IP路径转发。如果中间设备故障,则回程报文会被丢弃,导致BFD或SBFD会话down,从而错误地认为SID列表故障。
为了解决上述问题,可以使BFD或SBFD回程报文按照SRv6 TE Policy的指定SID列表转发,以确保连通性。具体实现机制为:
(1)     在源节点的SID列表视图下配置反向BSID,在尾节点的SID列表视图下配置本地BSID,二者取值相同。
(2)     源节点发送BFD报文或SBFD时:
¡     对于BFD报文,SRH中除了封装SID列表外,还会将该SID列表的反向BSID封装到SL=1的位置。
¡     对于SBFD报文,源节点将为SBFD报文封装Aux Path TLV(备用路径TLV),该TLV中包含反向BSID。
(3)     尾节点收到该BFD或SBFD报文,查找反向BSID,如果报文中反向BSID与尾节点配置的本地BSID相同,则为BFD或SBFD回程报文封装SRH,沿着本地BSID所在的SID列表转发。
本命令指定的BSID不能和SRv6 TE Policy的BSID相同,否则会导致SID列表无效,无法转发报文。
本命令配置的BSID必须在SRv6 TE视图下引用的Locator的静态段范围内。否则,BSID对应的SID列表不能用于报文转发。
# 在SID列表s1中配置本地BSID为1::1。
[Sysname-segment-routing] traffic-engineering
[Sysname-srv6-te] segment-list s1
[Sysname-srv6-te-sl-s1] local-binding-sid ipv6 1::1
·     reverse-binding-sid
1.1.71  loss threshold
loss threshold命令用来配置IPR模板的丢包率标准。
undo loss threshold命令用来恢复缺省情况。
loss threshold threshold-value
undo loss threshold
IPR模板的丢包率标准为1000‰。
SRv6 TE IPR模板视图
threshold-value:IPR模板的丢包率标准,取值范围为0~1000,单位为‰。
只有SRv6 TE Policy的iFIT丢包率测量功能检测到SRv6 TE Policy的丢包率不超过本命令设置的丢包率标准,则该SRv6 TE Policy才能作为备选的转发路径,参与最优SRv6 TE Policy选路过程。
如果SRv6 TE Policy的最优候选路径下存在多条带权重的有效Segment List,智能策略路由计算SRv6 TE Policy的丢包率是否符合标准时,则设备将该SRv6 TE Policy的最优候选路径下的所有有效Segment List的iFIT丢包率加权值作为该SRv6 TE Policy的丢包率。
# 配置IPR模板ipr1的丢包率标准为千分之5。
[Sysname-srv6-ipr-policy-ipr1] loss threshold 5
1.1.72  measure count
measure count命令用来配置智能策略路由的数据计算模式。
undo measure count命令用来恢复缺省情况。
measure count { one-way | two-way-average }
undo measure count
智能策略路由的数据计算模式为单程模式。
SRv6 TE IPR视图
one-way:指定智能策略路由的数据计算模式为单程模式。
two-way-average:指定智能策略路由的数据计算模式为双程模式。
通过echo BFD或SBFD检测功能可以探测SRv6 TE Policy转发路径的状态。利用SRv6 TE Policy的echo BFD或SBFD协议报文,SRv6 TE Policy的iFIT测量功能可以得到从SRv6 TE Policy头节点到尾节点、以及从SRv6 TE Policy尾节点返回头节点的网络质量参数。
根据SRv6 TE Policy的iFIT测量功能衡量SRv6 TE Policy的网络质量时,智能策略路由支持以下数据计算模式:
·     单程模式:智能策略路由仅使用从SRv6 TE Policy头节点到尾节点过程中采集到的单程iFIT检测参数作为衡量网络质量数据。
·     双程模式:智能策略路由使用从SRv6 TE Policy头节点到尾节点以及从尾节点返回头节点过程中采集到的双程iFIT检测参数的均值作为衡量网络质量数据。
需要注意的是指定智能策略路由的数据计算模式为双程模式时,iFIT无法准确测量SRv6 TE Policy隧道的丢包率,因此丢包率的数据仍采用单程模式的测量结果。
# 配置智能策略路由的数据计算模式为双程模式。
[Sysname-srv6-te-ipr] measure count two-way-average
1.1.73  on-demand
on-demand 命令用来创建SRv6 TE Policy的ODN(On-Demand Next-Hop,按需下一跳)模板,并进入SRv6 TE ODN视图。如果指定的ODN模板已经存在,则直接进入该SRv6 TE ODN视图。
undo on-demand命令用来删除指定的ODN模板及SRv6 TE ODN视图下的所有配置。
on-demand color color-value
undo on-demand color color-value
不存在SRv6 TE Policy的ODN模板。
SRv6 TE视图
color color-value:指定ODN模板的Color值,取值范围为0~4294967295。
配置ODN模板后,当设备收到BGP路由时,如果该BGP路由携带的Color扩展团体属性与ODN模板的Color值相同,则以该BGP路由的下一跳地址作为SRv6 TE Policy的目的节点地址,以ODN模板的Color值作为SRv6 TE Policy的Color属性,生成一个SRv6 TE Policy。同时,ODN会为该SRv6 TE Policy自动生成两条候选路径:
·     Preference为200的候选路径,该候选路径下的SID列表需要用户手工指定。
·     Preference为100的候选路径,该候选路径下的SID列表需要由PCE计算。
由ODN功能创建的SRv6 TE Policy下还可以手工创建候选路径。
# 创建SRv6 TE Policy的ODN模板,配置ODN模板的Color值为1,并进入SRv6 TE ODN视图。
[Sysname-srv6-te] on-demand color 1
[Sysname-srv6-te-odn-1]
1.1.74  on-demand-group
on-demand-group命令用来创建SRv6 TE Policy组的ODN模板,并进入SRv6 TE ODN Policy组视图。如果指定的ODN模板已经存在,则直接进入该SRv6 TE ODN Policy组视图。
undo on-demand-group命令用来删除指定的ODN模板及SRv6 TE ODN Policy组视图下的所有配置。
on-demand-group color color-value
undo on-demand-group color color-value
不存在SRv6 TE Policy组的ODN模板。
SRv6 TE视图
配置SRv6 TE Policy组的ODN模板后,当设备收到BGP路由时,如果该BGP路由携带的Color扩展团体属性与ODN模板的Color值相同,则以该BGP路由的下一跳地址作为SRv6 TE Policy组的目的节点地址,以ODN模板的Color值作为SRv6 TE Policy组的Color属性,生成一个SRv6 TE Policy组。设备将在未分配的组ID中,选择最小的组ID分配给该SRv6 TE Policy组。
自动创建SRv6 TE Policy组后,在ODN模板下需要配置Color和DSCP的映射关系,以便实现基于DSCP引流。
# 创建SRv6 TE Policy组的ODN模板,配置ODN模板的Color值为1,并进入SRv6 TE ODN Policy组视图。
1.1.75  policy
policy命令用来创建SRv6 TE Policy,并进入SRv6 TE Policy视图。如果SRv6 TE Policy已经存在,则直接进入SRv6 TE Policy视图。
undo policy命令用来删除指定SRv6 TE Policy,及该SRv6 TE Policy视图下的所有配置
policy policy-name
undo policy policy-name
不存在SRv6 TE Policy。
SRv6 TE视图
policy-name:SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
# 创建名称为srv6policy的SRv6 TE Policy,并进入SRv6 TE Policy视图。
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1]
1.1.76  policy-group
policy-group命令用来创建SRv6 TE Policy组,并进入SRv6 TE Policy组视图。如果SRv6 TE Policy组已经存在,则直接进入SRv6 TE Policy组视图。
undo policy-group命令用来删除指定SRv6 TE Policy组,及该SRv6 TE Policy组视图下的所有配置。
policy-group group-id
undo policy-group group-id
不存在SRv6 TE Policy组。
SRv6 TE视图
group-id:SRv6 TE Policy组ID,取值范围为1~4294967295。
将SRv6 TE Policy加入到SRv6 TE Policy组后,可以实现根据报文的DSCP(Differentiated Services Code Point,区分服务编码点)分组引流。
# 创建SRv6 TE Policy组1,并进入SRv6 TE Policy组视图。
1.1.77  preference
preference命令用来配置SRv6 TE Policy候选路径的优先级,并进入SRv6 TE Policy Path Preference视图。如果SRv6 TE Policy候选路径的优先级已经存在,则直接进入SRv6 TE Policy Path Preference视图。
undo preference命令用来删除SRv6 TE Policy候选路径的优先级,及SRv6 TE Policy Path Preference视图下的所有配置。
preference preference-value
undo preference preference-value
未配置SRv6 TE Policy候选路径的优先级。
SRv6 TE Policy候选路径视图
preferenc-value:SRv6 TE Policy候选路径的优先级,取值范围为1~65535。数值越大,优先级越高。
# 配置SRv6 TE Policy候选路径的优先级为20,并进入该SRv6 TE Policy Path Preference视图。
1.1.78  rate-limit
rate-limit命令用来配置SRv6 TE Policy的限速值。
undo rate-limit命令用来恢复缺省情况。
rate-limit kbps
undo rate-limit
不对SRv6 TE Policy的流量速率进行限制。
SRv6 TE Policy视图
kbps:限速值,取值范围为1~4294967295,单位为kbps。
配置本命令后,通过SRv6 TE Policy转发的报文速率超过限速值时,超过速率限制的报文会被丢弃。
# 配置SRv6 TE Policy aaa的限速值为15000kbps。
[Sysname-srv6-te-policy-aaa] rate-limit 15000
1.1.79  refresh-period
refresh-period命令用来配置IPR计算最优路径的周期。
undo refresh-period命令用来恢复缺省情况。
refresh-period time-value
undo refresh-period
IPR计算最优路径的周期为60秒。
SRv6 TE IPR视图
time-value:指定IPR计算最优路径的周期,取值范围为2~60,单位为秒。
当用户执行index te-class match命令配置指定TE Class ID和IPR模板的映射关系时,SRv6 TE Policy组的头节点开始按本命令设置的周期计算最优的SRv6 TE Policy,并将流量通过该最优SRv6 TE Policy转发。
周期性计算最优路径可以保证业务始终通过满足SLA标准且优先级最高的SRv6 TE Policy转发。用户可以按需设置IPR计算最优路径的周期,最优路径计算周期越短,系统开销越大。
# 配置IPR计算最优路径的周期为20秒。
[Sysname-srv6-te-ipr] refresh-period 20
1.1.80  reset segment-routing ipv6 te forwarding statistics
reset segment-routing ipv6 te forwarding statistics命令用来清除SRv6 TE Policy流量转发统计信息。
reset segment-routing ipv6 te forwarding statistics [ binding-sid binding-sid | color color-value end-point endpoint-ipv6 | name name-value ]
binding-sid binding-sid:清除指定BSID的SRv6 TE Policy的流量转发统计信息。binding-sid为SRv6 TE Policy的BSID值。
color color-value end-point endpoint-ipv6:清除指定Color属性和目的节点的SRv6 TE Policy的流量转发统计信息。color-value为Color值,取值范围为0~4294967295。endpoint-ipv6为目的节点的IPv6地址。
name name-value:清除指定SRv6 TE Policy的流量转发统计信息。name-value为SRv6 TE Policy名称,为1~59个字符的字符串,区分大小写。
配置本命令后将清除所有SRv6 TE Policy流量转发统计信息。
如果未指定任何参数,则清除所有SRv6 TE Policy的流量转发统计信息。
# 清除SRv6 TE Policy流量转发统计信息。
<Sysname> reset segment-routing ipv6 te forwarding statistics
·     forwarding statistics
·     srv6-policy forwarding statistics enable
·     srv6-policy forwarding statistics interval
1.1.81  restrict
restrict命令用来配置ODN生成SRv6 TE Policy的触发策略。
undo restrict命令用来恢复缺省情况。
restrict prefix-list-name
undo restrict
携带的Color扩展团体属性与ODN模板的Color值相同的BGP路由均会触发ODN功能生成SRv6 TE Policy。
SRv6 TE ODN视图
prefix-list-name:IPv6地址前缀列表名,为1~63个字符的字符串,区分大小写。
根据ODN模板生成SRv6 TE Policy时,可以利用IPv6地址前缀列表对BGP路由进行过滤。通过IPv6地址前缀列表过滤的BGP路由可以触发生成SRv6 TE Policy,被IPv6地址前缀列表拒绝的BGP路由不能触发建立SRv6 TE Policy。
# 配置允许1000::/96网段的BGP路由触发ODN功能生成SRv6 TE Policy。
[Sysname] ipv6 prefix-list policy permit 1000:: 96
[Sysname-srv6-te-odn-1] restrict policy
·     ipv6 prefix-list(三层技术-IP路由命令参考/路由策略)
1.1.82  reverse-binding-sid
reverse-binding-sid命令用来配置反向BSID。
undo reverse-binding-sid命令用来恢复缺省情况。
不存反向BSID。
SID列表视图
ipv6 ipv6-address:反向BSID对应的IPv6地址。ipv6-address为IPv6地址。
通过BFD echo或SBFD方式检测SRv6 TE Policy连通性时,缺省情况下,BFD或SBFD的回程报文通过IP路径转发。如果中间设备故障,则回程报文会被丢弃,导致BFD或SBFD会话down,从而错误地认为SID列表故障。
(2)     源节点发送BFD或SBFD报文时:
# 在SID列表s1中配置反向BSID为1::1。
[Sysname-srv6-te-sl-s1] reverse-binding-sid ipv6 1::1
·     local-binding-sid
1.1.83  router-id filter
router-id filter命令用来开启Router ID过滤功能。
undo router-id filter命令用来关闭Router ID过滤功能。
router-id filter [ bgp-rib-only ]
Router ID过滤功能处于关闭状态。
bgp-rib-only:当设备收到BGP IPv6 SR Policy路由,且该路由携带的Route Target属性中不包含本地设备的Router ID时,仅接收该路由,不生成对应的SRv6 TE Policy。
当网络中存在大量的BGP IPv6 SR Policy路由,而设备仅希望处理部分路由时,可以通过本命令过滤接收到的BGP IPv6 SR Policy路由。
开启Router ID过滤功能后,设备将检查接收到的BGP IPv6 SR Policy路由中携带的Route Target属性。如果该属性中包含本地设备的Router ID,则接收该路由,并生成对应的SRv6 TE Policy;否则:
·     执行本命令时,如果未指定bgp-rib-only参数,则丢弃该路由。
·     执行本命令时,如果指定bgp-rib-only参数,则仅接收该路由,不生成对应的SRv6 TE Policy。
当控制器需要通过多台中间设备将BGP IPv6 SR Policy路由发布到源节点时,控制器与源节点之间的中间设备仅需要转发BGP IPv6 SR Policy路由,不需要生成SRv6 TE Policy,以节省中间设备的资源。这种情况下,可以在中间设备上配置router-id filter bgp-rib-only命令,当中间设备收到BGP IPv6 SR Policy路由后,即使该路由携带的Route Target属性中不包含本地设备的Router ID,也不会丢弃该路由,仍对该路由进行转发。同时,也不会在中间设备上生成SRv6 TE Policy,避免影响报文转发。
为了正确使用Router ID过滤功能,需要通过路由策略等方式为BGP IPv6 SR Policy路由合理添加Route Target属性。否则,可能会导致错误地学习或丢弃BGP IPv6 SR Policy路由。
# 开启Router ID过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] router-id filter
1.1.84  sbfd
sbfd命令用来配置SRv6 TE Policy的SBFD功能。
undo sbfd命令用来恢复缺省情况。
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] [ encaps | insert ] }
undo sbfd
未配置SRv6 TE Policy的SBFD功能,以SRv6 TE视图下的配置为准。
SRv6 TE Policy视图
disable:关闭SRv6 TE Policy的SBFD功能。
enable:开启SRv6 TE Policy的SBFD功能。
remote remote-id:指定SBFD会话的远端标识符,取值范围为1~4294967295。如果未指定本参数,则以SRv6 TE视图下的配置为准。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的BFD模板为准。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则以SRv6 TE视图下配置的备份BFD模板为准。
oam-sid sid:为SBFD报文添加OAM SID,用于定位目的节点。sid为目的节点的SRv6 SID。如果未指定本参数,则不为SBFD报文添加OAM SID。目前OAM SID建议配置为目的节点上的End SID。
encaps:配置SBFD报文采用普通封装模式。
insert:配置SBFD报文采用插入封装模式。
‌【使用指导】
通过SBFD检测SRv6 TE Policy时,需要为SBFD报文封装SRv6 TE Policy的SID列表,封装模式包括:
如果未指定encapsinsert参数,则采用bfd srv6-encapsulation-mode insert命令配置的封装模式。
通过SBFD检测SRv6 TE Policy,为SBFD报文封装SRv6 TE Policy的SID列表时,不受SRv6 TE视图和SRv6 TE Policy视图下SRv6 TE Policy的封装模式命令的控制。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的SBFD功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
本命令指定的远端标识符必须与Reflector端sbfd local-discriminator命令指定的标识符一致,否则Reflector端不会发送应答报文给Initiator端。
目前,支持通过BFD echo报文和SBFD两种方式检测SRv6 TE Policy。在同一SRv6 TE Policy下同时配置以上两种检测方式时,SBFD检测生效。
# 开启SRv6 TE Policy 1的SBFD功能。
[Sysname-srv6-te-policy-1] sbfd enable
·     bfd srv6-encapsulation-mode insert
·     display segment-routing ipv6 te sbfd
·     explicit segment-list
·     sbfd local-discriminator(可靠性命令参考/BFD)
·     srv6-policy sbfd
1.1.85  schedule-priority
schedule-priority命令用来配置IPR模板的切换调度优先级。
undo schedule-priority命令用来恢复缺省情况。
schedule-priority priority-value
IPR模板的切换调度优先级为0。
SRv6 TE IPR模板视图
priority-value:IPR模板的切换调度优先级,取值范围为1~65535,取值越大,IPR切换调度优先级越高。
工作机制
当不同的业务流量通过不同的IPR模板中多个SRv6 TE Policy转发时,可能存在多个SRv6 TE Policy共用同一出接口转发的情况。如果该接口的带宽使用率大于bandwidth-threshold upper命令指定的带宽利用率阈值上限,则需要按照refresh-period命令定义的IPR计算最优路径的周期,逐个对切换调度优先级最低的IPR模板进行流量调优,即将该IPR模板所承载的业务流量切换到其他SRv6 TE Policy转发,避免使用同一出接口转发。
例如,在源节点上TE Class ID 100标识的流量通过IPR模板A中的最优路径SRv6 TE Policy 1转发,TE Class ID 200标识的流量通过IPR模板B中的最优路径SRv6 TE Policy 2转发,TE Class ID 300标识的流量通过IPR模板C中的最优路径SRv6 TE Policy 3转发,其中,SRv6 TE Policy 1、SRv6 TE Policy 2和SRv6 TE Policy 3的出接口均为Interface X。此时,Interface X上的实际带宽利用率超出了bandwidth-threshold upper命令指定的带宽利用率阈值上限,则比较IPR模板A、IPR模板B以及IPR模板C的切换调度优先级,优先将切换调度优先级最低的IPR模板中承载的流量进行切换,直到Interface X上的实际带宽利用率小于等于bandwidth-threshold upper命令指定的带宽利用率阈值上限。
注意事项
如果多个IPR模板的切换调度优先级相同,则所有相同优先级的IPR模板中承载的流量都会进行切换。请尽量为不同IPR模板的配置不同的切换调度优先级。
# 配置IPR模板的切换调度优先级为30000。
[Sysname-srv6-ipr-policy-ipr1] schedule-priority 30000
1.1.86  segment-list
segment-list命令用来创建SID列表,并进入SID列表视图。如果SID列表已经存在,则直接进入SID列表视图。
undo segment-list命令用来删除指定的SID列表,及该SID列表视图下的所有配置。
undo segment-list segment-list-name
不存在SID列表。
SRv6 TE视图
segment-list-name:SID列表名称,取值范围为1~128个字符的字符串,区分大小写。
# 创建名称为abc的SID列表,并进入SID列表视图。
1.1.87  service-class
service-class命令用来配置SRv6 TE Policy的转发类。
undo service-class命令用来恢复缺省情况。
service-class service-class-value
undo service-class
未配置SRv6 TE Policy的转发类。
SRv6 TE Policy视图
service-class-value:SRv6 TE Policy转发类的值,本参数的取值范围为0~127。SRv6 TE Policy转发类的取值越小,隧道转发的优先级越低,没有配置转发类的隧道优先级最低。
配置本功能后:
·     设备会优先选择与流量的转发类值相同的SRv6 TE Policy转发该流量。
·     如果存在多条与流量的转发类值相同的SRv6 TE Policy,只有一条流且为逐流转发则随机选择一条SRv6 TE Policy转发流量;有一条流但是为逐包转发或有多条流,则流量在相同转发类的SRv6 TE Policy间进行负载分担。通过ip load-sharing mode区分流和负载分担方式。
·     如果没有与流量的转发类值相同的SRv6 TE Policy,则选择转发类值最小的SRv6 TE Policy转发流量。
流行为视图下可以通过remark service-class命令配置重新标记报文的隧道转发类的值。
# 配置SRv6 TE Policy 1的转发类值为5。
[Sysname-srv6-te-policy-1] service-class 5
·     ip load-sharing mode(三层技术-IP业务命令参考/负载分担)
·     remark service-class(ACL和QoS命令参考/QoS命令)
1.1.88  shutdown
shutdown命令用来关闭SRv6 TE Policy。
undo shutdown命令用来开启SRv6 TE Policy。
shutdown
SRv6 TE Policy处于开启状态。
SRv6 TE Policy视图
通过本命令控制SRv6 TE Policy的开启和关闭状态,从而控制该SRv6 TE Policy是否可以转发流量。
当设备存在多个SRv6 TE Policy时,可以配置本命令,关闭一些不需要的SRv6 TE Policy,避免影响流量转发。
# 关闭SRv6 TE Policy 1。
[Sysname-srv6-te-policy-1] shutdown
1.1.89  sr-policy steering
sr-policy steering命令用来配置SRv6 TE Policy的引流方式。
undo sr-policy steering命令用来恢复缺省情况。
sr-policy steering { disable | policy-based }
基于Color将数据报文引流到SRv6 TE Policy。
BGP实例视图
disable:不使用基于Color引流。
policy-based:基于隧道策略将数据报文引流到SRv6 TE Policy。指定本参数后,按照基于隧道绑定策略进行引流->基于Color引流->基于隧道负载分担策略进行引流的优先级顺序引流方式。
可以通过如下方式将数据报文引流到SRv6 TE Policy:
·     基于Color引流:查找是否存在Color和Endpoint地址与BGP路由的Color扩展团体属性和下一跳地址完全相同的SRv6-TE policy。若存在,则将该BGP路由迭代到SRv6 TE Policy。当设备收到匹配该BGP路由的报文时,会通过SRv6 TE Policy转发该报文。
·     基于隧道策略引流:IP L3VPN over SRv6、EVPN L3VPN over SRv6组网中,通过部署隧道策略,将SRv6 TE Policy作为公网隧道来转发私网报文。隧道策略的详细介绍请参见“MPLS配置指导”中的“隧道策略”。
在L2VPN组网环境中,本命令不生效。
# 配置基于隧道策略将数据报文引流到SRv6 TE Policy。
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
1.1.90  sr-te frr enable
sr-te frr enable命令用来开启SRv6 TE FRR功能。
undo sr-te frr enable命令用来关闭SRv6 TE FRR功能。
sr-te frr enable
SRv6 TE FRR功能处于关闭状态。
SRv6视图
开启SRv6 TE FRR功能后,当SRv6 TE Policy的中间节点发生故障时,故障节点的上游节点可以代替故障节点完成报文转发,这个上游节点称之为代理转发(Proxy Forwarding)节点。
在节点开启SRv6 TE FRR功能后,当报文中存在SRH,且SRH中SL>1时,在如下任一场景下,该节点将作为代理转发节点转发报文:
·     查询IPv6 FIB表,没有找到对应的转发表项。
·     报文的下一跳是报文目的地址,该目的地址对应的出接口状态为DOWN;
·     查询Local SID表匹配SRv6 SID为End.X SID,且End.X SID对应的出接口状态为DOWN。
·     从路由表中查到的路由为NULL0路由。
代理转发节点代替故障节点进行报文转发时,需要进行以下操作:
·     代理转发节点将报文中SRH的SL减1;
·     将下层要处理的SID更新到外层IPv6报文头,使其作为报文的目的地址;
·     根据目的地址查表转发。
代理转发节点通过执行以上操作使报文绕过故障节点,实现中间节点故障的保护。这种保护技术也称为SRv6 TE FRR。
组网环境复杂时,中间节点并不固定,所以,为了提供整网可靠性,建议在所有节点上开启SRv6 TE FRR功能。
# 开启SRv6 TE FRR功能。
[Sysname-segment-routing-ipv6] sr-te frr enable
·     bfd echo
1.1.91  srv6-policy autoroute enable
srv6-policy autoroute enable命令用来开启SRv6 TE Policy的自动引流功能。
undo srv6-policy autoroute enable命令用来关闭SRv6 TE Policy的自动引流功能。
srv6-policy autoroute enable [ level-1 | level-2 ]
SRv6 TE Policy的自动引流功能处于关闭状态。
ISIS IPv6地址族视图
level-1:开启Level-1的SRv6 TE Policy的自动引流功能。
level-2:开启Level-2的SRv6 TE Policy的自动引流功能。
配置本功能后可以将SRv6 TE Policy隧道发布到IGP(IS-IS)路由中,让SRv6 TE Policy参与IGP路由的计算,使得流量可以通过SRv6 TE Policy转发。
如果不指定level-1level-2参数,则开启所有Level的SRv6 TE Policy的自动引流功能。
配置本命令前,需要在SRv6 TE Policy视图下配置autoroute enable命令,允许SRv6 TE Policy隧道参与路由计算。
# 开启IS-IS进程1的SRv6 TE Policy自动引流功能。
[Sysname] isis 1
[Sysname-isis-1-ipv6] srv6-policy autoroute enable
·     autoroute enable
1.1.92  srv6-policy backup hot-standby enable
srv6-policy backup hot-standby enable命令用来全局开启SRv6 TE Policy的热备份功能。
undo srv6-policy backup hot-standby enable命令用来全局关闭SRv6 TE Policy的热备份功能。
SRv6 TE Policy的热备份功能处于关闭状态。
SRv6 TE视图
开启SRv6 TE Policy的热备份功能后,如果一个SRv6 TE Policy下面存在多条候选路径,则优先级最高的有效路径是主路径,优先级次高的有效路径是备份路径。如果主路径下所有Segment List都发生故障,则将流量切换到备路径转发,以减少对业务的影响。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的热备份功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
# 开启SRv6 TE Policy的热备份功能。
[Sysname-srv6-te] srv6-policy backup hot-standby enable
·     backup hot-standby
1.1.93  srv6-policy bandwidth sample enable
srv6-policy bandwidth sample enable命令用来开启全局带宽采样功能。
undo srv6-policy bandwidth sample enable命令用来关闭全局带宽采样功能。
全局带宽采样功能处于关闭状态。
SRv6 TE视图
应用场景
开启IPR模板的带宽采样功能后,SRv6 TE Policy智能策略路由在路径优选时,可以基于带宽使用情况进行SRv6 TE Policy的优选。
IPR算路并选取的最优SRv6 TE Policy的过程中,SRv6 TE Policy不仅需要满足IPR模板中定义的时延、抖动和丢包等网络质量要求,还需要满足对带宽利用率的要求。只有时延、抖动和丢包等网络质量符合IPR模板定义的SLA标准,且带宽利用率不超出bandwidth-threshold upper命令定义的带宽利用率阈值上限的SRv6 TE Policy,能参与最优SRv6 TE Policy计算。
如果未开启IPR模板的带宽采样功能,则智能策略路由在路径优选时仅要求SRv6 TE Policy的时延、抖动和丢包等网络质量符合IPR模板定义的SLA标准。
工作机制
开启IPR模板的带宽采样功能后,设备按照srv6-policy bandwidth sample interval周期来收集各SRv6 TE Policy转发出接口的带宽利用率等信息,并计算IPR模板中各SRv6 TE Policy的预期平均带宽利用率。根据SRv6 TE Policy的预期平均带宽利用率,IPR首次计算和选取最优的SRv6 TE Policy。SRv6 TE Policy的预期平均带宽利用率如果不超过bandwidth-threshold upper命令定义的带宽利用率的阈值上限,则可以作为备选SRv6 TE Policy参与IPR路径优选,并根据srv6-policy color priority命令定义的选路优先级,选取选路优先级最小的SRv6 TE Policy作为最优路径转发业务流量。
其中,SRv6 TE Policy的预期平均带宽利用率指的是使用该SRv6 TE Policy承载新业务之后,该业务的带宽与转发出接口已使用带宽之和占转发出接口总带宽的比例,计算方式如下:
·     如果SRv6 TE Policy的最优候选路径仅存在一个SID列表,并且该SID列表的首个SID仅存在一个出接口时,SRv6 TE Policy的预期平均带宽利用率=(业务期望带宽+该出接口的当前已使用的带宽)/该出接口的总带宽。业务期望带宽选取规则如下,优先使用当前承载该业务的SRv6 TE Policy的实时统计作为业务期望带宽。如果SRv6 TE Policy未承载指定业务或者没有统计到SRv6 TE Policy的流量时,则选择该SRv6 TE Policy视图下expect-bandwidth命令配置的SRv6 TE Policy业务期望带宽。如果SRv6 TE Policy视图下未配置业务期望带宽时,则选择SRv6 TE IPR模板视图下expect-bandwidth命令指定的SRv6 TE IPR模板的业务期望带宽。
·     如果SRv6 TE Policy的最优候选路径存在多个SID列表,或者SID列表的首个SID存在多个等价出接口,SRv6 TE Policy的预期平均带宽利用率计算方式比较复杂,以下列SRv6 TE Policy为例,该SRv6 TE Policy的预期平均带宽利用率计算方法如下:
SRv6 TE Policy A
 Candidate paths(Preference 200)
    Segment List1(weight 10)        interface1    bw1    30%
                                    interface2    bw2    50%
    Segment List2(weight 30)        interface3    bw3    80%
SRv6 TE Policy A的最优候选路径Candidate Path中存在权重为10的SID列表1和权重为30的SID列表2。SID列表1中首个SID存在两个等价出接口interface1和interface2。interface1的接口带宽为bw1,interface2的接口带宽为bw2。SID列表2中首个SID存在一个出接口interface3,interface3的接口带宽为bw3。当前interface1、interface2和interface3的当前已用的带宽利用率分别为30%,50%和80%。
a.     根据等价出接口的当前带宽利用率,取等价出接口的当前带宽利用率的平均值作为SID列表1的带宽利用率,即(30%+50%)/2=40%。
b.     SID列表2的带宽利用率等于出接口interface3当前的带宽利用率80%。
c.     根据不同SID列表的权重和带宽利用率,使用加权平均的方式计算SRv6 TE Policy A的带宽利用率,即(40%*10+80%*30)/(10+30)=70%。
d.     计算SRv6 TE Policy A的预期平均带宽利用率=(业务期望带宽+70%*(bw1+bw2+bw3))/(bw1+bw2+bw3)
注意事项
·     SRv6 TE Policy的最优候选路径中存在多个SID列表或者SID列表的首个SID存在多个等价出接口的场景下,SRv6 TE Policy的预期平均带宽利用率的计算并不能准确反映出各接口的带宽利用率。因此,在使用SRv6 TE Policy的智能策略路由功能,基于带宽使用情况进行SRv6 TE Policy的优选时,请管理员保证规划和创建SRv6 TE Policy的最优候选路径仅存在一个SID列表和单个出接口。
·     SRv6 TE Policy的智能策略路由功能仅首次选取最优的SRv6 TE Policy时使用expect-bandwidth命令指定业务期望带宽来计算预期平均带宽利用率。IPR已选出最优SRv6 TE Policy承载业务后会进行周期性路径优化(即根据SRv6 TE Policy的质量和带宽进行切换和回切),此时,计算预期平均带宽利用率将使用当前最优SRv6 TE Policy实时统计的业务流量带宽数据作为业务期望带宽来计算各SRv6 TE Policy的预期平均带宽利用率。例如,当前IPR路径优化时,已选取出的最优SRv6 TE Policy A实时的业务流量带宽为100Mbps,IPR计算SRv6 TE Policy B的预期平均带宽利用率=(100Mbps+SRv6 TE Policy B的转发出接口的已使用带宽)/SRv6 TE Policy B的转发出接口的总带宽,根据SRv6 TE Policy B的预期平均带宽利用率确定该SRv6 TE Policy是否符合带宽利用率的要求。
·     在使用SRv6 TE Policy的智能策略路由功能,基于带宽使用情况进行SRv6 TE Policy的优选时,建议管理员创建IPR模板引用的SRv6 TE Policy仅用于承载单一业务,不同业务不复用同一SRv6 TE Policy。例如,TE Class ID1000的业务映射到IPR模板优选的SRv6 TE Policy A(Color为100)中转发,由于IPR根据带宽使用情况进行路径调优时,使用优选的SRv6 TE Policy A实时统计流量来计算各SRv6 TE Policy的预期平均带宽利用率,如果SRv6 TE Policy A不仅仅承载了TE Class ID1000的业务还承载了其他非相关业务,则实时统计流量不准确,预期平均带宽利用率计算也不准确。可以创建Color值不同的SRv6 TE Policy用于承载其他业务流量。
可以在SRv6 TE视图配置srv6-policy bandwidth sample enable命令开启全局带宽采样功能,也可以在SRv6 TE IPR模板视图配置bandwidth sample命令开启带宽采样功能。SRv6 TE视图的配置对所有IPR模板都有效,而SRv6 TE IPR视图的配置只对该IPR模板有效。对于一个IPR模板来说,以SRv6 TE IPR模板视图下的配置为准,只有该SRv6 TE IPR模板视图内未进行配置时,才采用SRv6 TE视图的配置。
[Sysname-srv6-te] srv6-policy bandwidth sample enable
·     bandwidth-threshold upper
·     expect-bandwidth
·     bandwidth sample
1.1.94  srv6-policy bandwidth sample interval
srv6-policy bandwidth sample interval命令用来配置SRv6 TE Policy转发出接口的带宽利用率采样周期。
undo srv6-policy bandwidth sample interval命令用来恢复缺省情况。
srv6-policy bandwidth sample interval time-value
SRv6 TE Policy转发出接口的带宽利用率采样周期为30秒。
SRv6 TE视图
time-value:SRv6 TE Policy转发出接口的带宽利用率采样周期,取值范围是1~1800,单位为秒。
工作机制
执行bandwidth sample命令开启IPR模板的带宽采样功能或者执行srv6-policy bandwidth sample enable之后,可以通过本命令调整和设置SRv6 TE Policy转发出接口的带宽利用率的采集周期。
本命令对所有的IPR模板生效。
注意事项
配置的SRv6 TE Policy转发出接口的带宽利用率采样周期time-value与实际生效值之间存在一定差异:
·     当配置的time-value参数范围在1~10之间,采用周期实际生效值只能为1、2、5、10。
·     当配置的time-value参数范围在10~60之间,采用周期实际生效值=10+5n,其中n为小于等于10的整数。
·     当配置的time-value参数范围在60~180之间,采用周期实际生效值=60+10n,其中n为小于等于12的整数。
·     当配置的time-value参数范围在180~300之间,采用周期实际生效值=180+30n,其中n为小于等于4的整数。
·     当配置的time-value参数范围在300~900之间,采用周期实际生效值=300+60n,其中n为小于等于10的整数。
·     当配置的time-value参数范围在900~1800之间,采用周期实际生效值=900+300n,其中n为小于等于3的整数。
配置的参数值介于两个实际生效值之间时,则实际生效值等于两者中较大的实际生效值。例如,配置值为3,则实际生效值为5,配置值为22,则实际生效值为25。
# 配置SRv6 TE Policy转发出接口的带宽利用率采样周期为100秒。
[Sysname-srv6-te] srv6-policy bandwidth sample interval 100
·     bandwidth sample
1.1.95  srv6-policy bandwidth-threshold lower
srv6-policy bandwidth-threshold lower命令用来配置带宽阈值下限。
undo srv6-policy bandwidth-threshold lower命令用来恢复缺省情况。
srv6-policy bandwidth-threshold lower lower-value
未配置带宽阈值下限。
SRv6 TE视图
lower-value:带宽阈值下限,取值范围为1~100,单位为%。
工作机制
IPR按照refresh-period命令周期性进行路径调优时,如果发现存在至少一个SRv6 TE Policy的选路优先级高于当前承载业务的SRv6 TE Policy,且满足如下条件:
·     该SRv6 TE Policy的预期平均带宽利用率小于等于Min(bandwidth-threshold switch-back命令配置IPR模板的业务回切带宽利用率阈值,srv6-policy bandwidth-threshold lower命令配置带宽阈值下限),Min(a,b)表示a和b之间的较小值;未配置srv6-policy bandwidth-threshold lower命令时,则直接取bandwidth-threshold switch-back命令配置IPR模板的业务回切带宽利用率阈值。
·     该SRv6 TE Policy中数据业务流量的时延、抖动和丢包等质量指标符合的IPR模板中定义的SLA标准;
则设备会等待wait-to-restore-period命令指定的回切时延计时器超时后,将业务流量从当前的SRv6 TE Policy回切到选路优先级更高的SRv6 TE Policy上进行转发。
注意事项
本命令配置的带宽阈值下限对所有IPR模板均有效,而bandwidth-threshold switch-back命令仅对某个IPR模板有效。
配置本命令时,指定的带宽阈值下限需要保证不大于bandwidth-threshold upper命令配置的IPR模板的带宽阈值上限。建议配置回切带宽阈值与IPR模板的带宽阈值上限有较大差异,防止接口带宽变化过大时,业务频繁切换。
# 配置带宽阈值下限为30%。
[Sysname-srv6-te] srv6-policy bandwidth-threshold lower 30
·     refresh-period
·     bandwidth-threshold switch-back
·     wait-to-restore-period
1.1.96  srv6-policy bfd echo
srv6-policy bfd echo命令用来全局开启SRv6 TE Policy的echo报文方式的BFD检测功能。
undo srv6-policy bfd echo命令用来全局关闭SRv6 TE Policy的echo报文方式的BFD检测功能。
srv6-policy bfd echo source-ipv6 ipv6-address [ template template-name ] [ backup-template backup-template-name ] [ reverse-path reverse-binding-sid ]
SRv6 TE Policy的echo报文方式的BFD检测功能处于关闭状态。
SRv6 TE视图
source-ipv6 ipv6-address:指定BFD会话的源IPv6地址。
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用系统视图下配置的多跳BFD会话参数。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则BFD会话使用系统视图下配置的多跳BFD会话参数。
reverse-path:指定BFD报文的回程路径。如果未指定本参数,则根据IP路径将BFD报文转发回源节点。
reverse-binding-sid:使用反向BSID对应的SID列表作为BFD报文的回程路径。
SRv6 TE视图和SRv6 TE Policy视图下均可以配置SRv6 TE Policy的echo报文方式的BFD功能。SRv6 TE视图的配置对所有SRv6 TE Policy都有效,而SRv6 TE Policy视图的配置只对当前SRv6 TE Policy有效。对于一个SRv6 TE Policy来说,优先采用该SRv6 TE Policy内的配置,只有该SRv6 TE Policy内未进行配置时,才采用SRv6 TE视图的配置。
通过echo报文方式的BFD检测SRv6 TE Policy时,缺省情况下,BFD回程报文均通过IP路径转发,一旦中间设备故障,则回程报文会被丢弃,导致BFD会话down,从而错误地认为所有SRv6 TE Policy的SID列表故障。为了解决上述问题,可以使BFD回程报文按照SRv6 TE Policy的指定SID列表转发,实现去程和回程路径一致的功能,或者叫BFD的来回路径一致功能。该功能的实现方式为:配置reverse-path reverse-binding-sid参数后,源节点将在BFD报文的插入SRH头,并在SRH中SL=1的位置封装反向BSID信息,该反向BSID可以通过explicit segment-listreverse-binding-sid命令来指定。尾节点收到BFD报文后,获取反向BSID信息。如果反向BSID和尾节点某个SRv6 TE Policy的本地BSID相同(该本地BSID可以通过local-binding-sid命令指定),则向BFD报文中插入新的SRH,沿本地BSID所属SRv6 TE Policy的SID列表转发。
# 全局开启SRv6 TE Policy的echo报文方式的BFD检测功能,并指定BFD会话的源IPv6地址为11::11。
[Sysname-srv6-te] srv6-policy bfd echo source-ipv6 11::11
·     bfd echo
·     display segment-routing ipv6 te bfd
1.1.97  srv6-policy color priority
srv6-policy color priority命令用来配置IPR模板中不同SRv6 TE Policy的Color属性和选路优先级的映射关系。
undo srv6-policy color命令用来删除IPR模板中不同SRv6 TE Policy的Color属性和选路优先级的映射关系。
srv6-policy color color-value priority priority-value
undo srv6-policy color color-value
未配置IPR模板中不同SRv6 TE Policy的Color属性和选路优先级的映射关系。
SRv6 TE IPR模板视图
color-value:SRv6 TE Policy的Color属性,取值范围为0~4294967295。
priority-value:IPR模板中不同SRv6 TE Policy的选路优先级,取值范围为1~8,数值越小优先级越高。
工作原理
SRv6 TE Policy组中存在多个不同的SRv6 TE Policy,不同的SRv6 TE Policy通过Color属性来区分。通过本命令可以建立SRv6 TE Policy的Color和选路优先级的映射关系,从而为不同SRv6 TE Policy设置选路优先级,如果参与路径优选的SRv6 TE Policy的网络质量符合IPR模板中设置的SLA标准,则优先级数值最小的SRv6 TE Policy将被选择为最优转发路径。
如果因iFIT检测SRv6 TE Policy的网络质量失败,或者因SRv6 TE Policy中不存在任何流量等原因导致SRv6 TE Policy组的源节点未获取到某些SRv6 TE Policy的网络质量,但这些SRv6 TE Policy有效,即SRv6 TE Policy状态正常,可以用于报文转发,则这些SRv6 TE Policy仍可能被选择为最优转发路径。
注意事项
如果不同Color属性映射到相同的优先级,且该优先级关联的SRv6 TE Policy均满足IPR模板中定义的SLA标准,则流量会在不同Color属性标识的SRv6 TE Policy之间进行负载分担。
同一个IPR模板中最多可以指定8个Color属性,即一个IPR模板中最多只能存在8个不同的SRv6 TE Policy。
# 配置IPR模板ipr1中SRv6 TE Policy的Color属性1和优先级1映射。
[Sysname-srv6-ipr-policy-ipr1] srv6-policy color 1 priority 1
1.1.98  srv6-policy encapsulation-mode
srv6-policy encapsulation-mode命令用来全局配置SRv6 TE Policy的封装模式。
undo srv6-policy encapsulation-mode命令用来恢复缺省情况。
srv6-policy encapsulation-mode encaps reduced
undo srv6-policy encapsulation-mode encaps reduced
srv6-policy encapsulation-mode insert
undo srv6-policy encapsulation-mode insert
srv6-policy encapsulation-mode insert reduced
undo srv6-policy encapsulation-mode insert reduced
SRv6 TE Policy的封装模式为普通封装模式。
SRv6 TE视图
配置本功能并指定封装模式为普通封装的简化模式,同时,在SRv6 TE视图下又配置了srv6-policy encapsulation-mode encaps include local-end.x命令,则srv6-policy encapsulation-mode encaps include local-end.x命令生效。
配置本功能并指定封装模式为插入封装的简化模式,同时,在SRv6 TE视图下又配置了srv6-policy encapsulation-mode insert include local-end.x命令,则srv6-policy encapsulation-mode insert include local-end.x命令生效。
# 全局配置SRv6 TE Policy的封装模式为Encaps.Red模式。
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps reduced
·     encapsulation-mode
1.1.99  srv6-policy encapsulation-mode encaps include local-end.x
srv6-policy encapsulation-mode encaps include local-end.x命令用来全局配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
undo srv6-policy encapsulation-mode encaps include local-end.x命令用来恢缺省情况。
SRv6 TE视图
多次配置srv6-policy encapsulation-mode encaps include local-end.x命令和srv6-policy encapsulation-mode insert include local-end.x命令,最后一次的配置生效。
配置了本功能的同时,在SRv6 TE视图下配置srv6-policy encapsulation-mode命令指定SRv6 TE Policy的封装模式为普通封装的简化模式时,本功能优先生效。
# 全局配置通过SRv6 TE Policy转发报文时封装的SRH中包含本地End.X SID。
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] srv6-policy encapsulation-mode encaps include local-end.x
·     encapsulation-mode encaps include local-end.x
1.1.100  srv6-policy encapsulation-mode insert include local-end.x
srv6-policy encapsulation-mode insert include local-end.x命令用来全局配置通过SRv6 TE Policy转发报文时插入的SRH中包含本地End.X SID。
undo srv6-policy encapsulation-mode insert include local-end.x命令用来恢复缺省情况。
SRv6 TE视图
配置了本功能的同时,在SRv6 TE视图下配置srv6-policy encapsulation-mode命令指定SRv6 TE Policy的封装模式为插入封装的简化模式时,本功能优先生效。
# 全局配置通过SRv6 TE Policy转发报文时插入的SRH中包含本地End.X SID。
[Sysname] segment-routing ipv6
[Sysname-srv6-te] srv6-policy encapsulation-mode insert include local-end.x
·     encapsulation-mode insert include local-end.x
1.1.101  srv6-policy forwarding statistics enable
srv6-policy forwarding statistics enable命令用来全局开启SRv6 TE Policy的流量转发统计功能。
undo srv6-policy forwarding statistics enable命令用来全局关闭SRv6 TE Policy的流量转发统计功能。
srv6-policy forwarding statistics [ service-class ] enable
SRv6 TE Policy的流量转发统计功能处于关闭状态。
SRv6 TE视图
# 开启SRv6 TE Policy的流量转发统计功能。
[Sysname-srv6-te] srv6-policy forwarding statistics enable
1.1.102  srv6-policy forwarding statistics interval
srv6-policy forwarding statistics interval命令用来全局配置SRv6 TE Policy流量转发统计信息收集的时间间隔。
undo srv6-policy forwarding statistics interval命令用来恢复缺省情况。
srv6-policy forwarding statistics interval interval
SRv6 TE Policy流量转发统计信息收集的时间间隔为30秒。
SRv6 TE视图
interval:SRv6 TE Policy流量转发统计信息收集的时间间隔,取值范围为5~65535,单位为秒。
本命令对所有SRv6 TE Policy生效。
# 配置SRv6 TE Policy流量转发统计信息收集的时间间隔为90秒。
[Sysname-srv6-te] srv6-policy forwarding statistics interval 90
1.1.103  srv6-policy ifit delay-measure enable
srv6-policy ifit delay-measure enable命令用来全局开启SRv6 TE Policy的iFIT时延和抖动测量功能。
undo srv6-policy ifit delay-measure enable命令用来恢复缺省情况。
全局SRv6 TE Policy的iFIT时延和抖动测量功能处于关闭状态。
SRv6 TE视图
配置准备
为了使本功能生效,请先配置以下功能:
应用场景
工作机制
注意事项
如果同时配置本命令和SRv6 TE Policy视图下的ifit delay-measure命令,则SRv6 TE Policy视图下的ifit delay-measure命令优先生效。
# 全局开启SRv6 TE Policy的iFIT时延和抖动测量功能。
[Sysname-srv6-te] srv6-policy ifit delay-measure enable
·     ifit delay-measure enable
·     ifit interval
·     srv6-policy ifit interval
1.1.104  srv6-policy ifit interval
srv6-policy ifit interval命令用来全局配置SRv6 TE Policy的iFIT检测周期。
undo srv6-policy ifit interval命令用来恢复缺省情况。
srv6-policy ifit interval time-value
全局SRv6 TE Policy的iFIT检测周期为30秒。
SRv6 TE视图
如果同时配置本命令和SRv6 TE Policy视图下的ifit interval命令,则SRv6 TE Policy视图下的ifit interval命令优先生效。
# 全局配置SRv6 TE Policy的iFIT检测周期为60秒。
[Sysname-srv6-te] srv6-policy ifit interval 60
·     ifit interval
·     ifit loss-measure
·     srv6-policy ifit delay-measure enable
·     srv6-policy ifit loss-measure enable
1.1.105  srv6-policy ifit loss-measure enable
srv6-policy ifit loss-measure enable命令用来全局开启SRv6 TE Policy的iFIT丢包率测量功能。
undo srv6-policy ifit loss-measure enable命令用来恢复缺省情况。
全局SRv6 TE Policy的iFIT丢包率测量功能处于关闭状态。
SRv6 TE视图
配置准备
为了使本功能生效,请先配置以下功能:
应用场景
工作机制
注意事项
只有存在通过SRv6 TE Policy转发的数据业务流量时,iFIT才能测量该SRv6 TE Policy的丢包率。如果同时配置了本命令和SRv6 TE Policy视图下的ifit loss-measure命令,则SRv6 TE Policy视图下的命令优先生效。
# 全局开启SRv6 TE Policy的iFIT丢包率测量功能。
[Sysname-srv6-te] srv6-policy ifit loss-measure enable
·     ifit interval
·     ifit loss-measure enable
1.1.106  srv6-policy ifit measure mode
srv6-policy ifit measure mode命令用来全局配置SRv6 TE Policy的iFIT测量模式。
undo srv6-policy ifit measure mode命令用来恢复缺省情况。
srv6-policy ifit measure mode { e2e | trace }
SRv6 TE Policy的iFIT的测量模式为端到端模式。
SRv6 TE视图
配置准备
为了使本功能生效,请先配置以下功能:
推荐配置
工作机制
注意事项
如果同时配置本命令和SRv6 TE Policy视图下的ifit measure mode命令,则SRv6 TE Policy视图下的ifit measure mode命令优先生效。
# 全局配置SRv6 TE Policy的iFIT测量模式为逐跳模式。
[Sysname-srv6-te] srv6-policy ifit measure mode trace
·     ifit measure mode
1.1.107  srv6-policy locator
srv6-policy locator命令用来引用Locator段。
undo srv6-policy locator命令用来取消引用Locator段。
srv6-policy locator locator-name
未引用Locator段。
SRv6 TE视图
locator-name:Locator段名称,为1~31个字符的字符串,区分大小写。
在SRv6 TE视图下引用Locator段用来限定BSID的范围。只有在Locator段范围内的BSID才能生效。
不能通过重复执行srv6-policy locator命令修改引用的Locator段。如需修改引用的Locator段,请先通过undo srv6-policy locator命令删除已引用的Locator段,再执行srv6-policy locator命令引用新的Locator段。
# 在SRv6 TE视图下引用Locator段test1。
[Sysname-srv6-te] srv6-policy locator test1
1.1.108  srv6-policy log enable
srv6-policy log enable命令用来开启SRv6 TE Policy的日志功能。
undo srv6-policy log enable命令用来关闭SRv6 TE Policy的日志功能。
SRv6 TE Policy的日志功能处于关闭状态。
SRv6 TE视图
开启SRv6 TE Policy的日志功能后,设备将记录SRv6 TE Policy的状态变化和资源使用情况,以便管理员对SRv6 TE Policy运行情况进行审计。设备生成的SRv6 TE Policy日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启SRv6 TE Policy的日志功能。
[Sysname-srv6-te] srv6-policy log enable
1.1.109  srv6-policy sbfd
srv6-policy sbfd命令用来全局开启SRv6 TE Policy的SBFD功能并配置相关参数。
undo srv6-policy sbfd命令用来全局关闭SRv6 TE Policy的SBFD功能。
srv6-policy sbfd remote remote-id [ template template-name ] [ backup-template backup-template-name ]
SRv6 TE Policy的SBFD功能处于关闭状态。
SRv6 TE视图
template template-name:指定引用的BFD模板。template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则SBFD会话使用系统视图下配置的多跳BFD会话参数。
backup-template backup-template-name:指定备份SID列表引用的BFD模板。backup-template-name为BFD会话参数模板的名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则SBFD会话使用系统视图下配置的多跳BFD会话参数。
# 全局开启SRv6 TE Policy的SBFD功能,并指定SBFD会话的远端标识符为1000001。
[Sysname-srv6-te] srv6-policy sbfd remote 1000001
·     sbfd
1.1.110  srv6-policy switch-delay delete-delay
srv6-policy switch-delay delete-delay命令用来配置SRv6 TE Policy中转发路径的切换延迟时间和删除延迟时间。
undo srv6-policy switch-delay命令用来恢复缺省情况。
srv6-policy switch-delay switch-delay-time delete-delay delete-delay-time
SRv6 TE Policy中转发路径的切换延迟时间为5000毫秒,删除延迟时间为20000毫秒。
SRv6 TE视图
switch-delay-time:SRv6 TE Policy中转发路径的切换延迟时间,取值范围为0~600000,单位为毫秒。
delete-delay-time:SRv6 TE Policy中转发路径的删除延迟时间,取值范围为0~600000,单位为毫秒。
在SRv6 TE Policy的转发路径更新过程中,设备在删除老的转发路径之前先把新的转发路径建立起来,建立新的转发路径期间流量先保持按照老的转发路径转发,切换延迟时间超时后再按照新的转发路径转发流量,并在删除延迟时间超时后将旧转发路径删除,防止转发路径切换导致流量不通。
# 配置SRv6 TE Policy中转发路径的切换延迟时间为8000毫秒,删除延迟时间为15000毫秒。
[Sysname-srv6-te] srv6-policy switch-delay 8000 delete-delay 15000
1.1.111  switch-period
switch-period命令用来配置IPR模板中SRv6 TE Policy之间的切换时延。
undo switch-period命令用来恢复缺省情况。
switch-period time-value
undo switch-period
IPR模板中SRv6 TE Policy之间的切换时延为6秒。
SRv6 TE IPR模板视图
time-value:表示IPR模板中SRv6 TE Policy之间的切换时延,取值范围为1~7200,单位为秒。
当SRv6 TE Policy组的头节点计算出最优SRv6 TE Policy和业务当前使用的SRv6 TE Policy不同,且最优SRv6 TE Policy的选路优先级比当前业务使用的SRv6 TE Policy的选路优先级低,则表示SRv6 TE Policy的iFIT功能检测到业务当前使用的SRv6 TE Policy的丢包率、时延或抖动不满足IPR模板中的SLA标准,业务流量需要切换到较低优先级的SRv6 TE Policy中转发。此时,设备将启动切换时延计时器,切换时延由本命令配置。在切换时延计时器超时前,如果该SRv6 TE Policy的某次iFIT探测结果满足SLA阈值标准,则切换时延计时器清零;如果该SRv6 TE Policy的iFIT探测结果始终不满足SLA阈值标准,则在切换时延计时结束后,将业务流量切换到IPR计算得到的最优SRv6 TE Policy中转发。
用户需要根据业务的特点来合理设置切换时延。例如,语音业务对实时性要求较高,SRv6 TE Policy的网络质量劣化后需要及时切换转发路径来保证语音业务的实时性,此时,可以设置较短切换时延,以实现业务的快速切换。
# 配置IPR模板ipr1中SRv6 TE Policy之间的切换时延为3秒。
[Sysname-srv6-ipr-policy-ipr1] switch-period 3
1.1.112  traffic-engineering
traffic-engineering命令用来创建SRv6 TE,并进入SRv6 TE视图。如果SRv6 TE已经存在,则直接进入SRv6 TE视图。
undo traffic-engineering命令用来删除SRv6 TE,及SRv6 TE视图下的所有配置。
traffic-engineering
不存在SRv6 TE。
SRv6视图
# 创建SRv6 TE,并进入SRv6 TE视图。
[Sysname-srv6-te]
1.1.113  ttl-mode
ttl-mode命令用来配置SRv6 TE Policy对TTL的处理模式。
undo ttl-mode命令用来恢复缺省情况。
ttl-mode { pipe | uniform }
undo ttl-mode
SRv6 TE Policy对TTL的处理模式为Pipe模式。
SRv6视图
pipe:TTL的处理模式为Pipe模式。
uniform:TTL的处理模式为Uniform模式。
使用SRv6 TE Policy作为公网隧道的场景下,SRv6 TE Policy对TTL的处理有两种模式:
·     Uniform模式:入节点为IP报文添加新的IPv6头时,将原IP报文中的TTL值复制到新IPv6头的IPv6 Hop Limit字段。使用SRv6 TE Policy转发报文时,对新IPv6头的Hop Limit值逐跳减一。设备解封装报文时,将新IPv6头的Hop Limit值复制回IP报文。使用这种方式时,公网中的节点对用户网络的报文可见。报文沿着SRv6 TE Policy传输的过程中,TTL逐跳递减,Tracert的结果将反映报文实际经过的路径。
·     Pipe模式:入节点为IP报文添加新的IPv6头时,不会将原IP报文中的TTL值复制到新IPv6头的IPv6 Hop Limit字段,新IPv6头的Hop Limit取值为255。使用SRv6 TE Policy转发报文时,对新IPv6头的Hop Limit值逐跳减一。设备解封装报文时,不修改IPv6 Hop Limit的值。使用这种方式时,公网中的节点对用户网络的报文不可见。Tracert的结果不包括公网中的每一跳,从而隐藏公网的结构。
# 配置SRv6 TE Policy 1对TTL的处理模式为Uniform模式。
[Sysname-segment-routing-ipv6] ttl-mode uniform
1.1.114  validation-check enable
validation-check enable命令用来开启BGP IPv6 SR Policy路由有效性检查功能。
undo validation-check enable命令用来关闭BGP IPv6 SR Policy路由有效性检查功能。
BGP IPv6 SR Policy路由有效性检查功能处于关闭状态,即设备不会检查对等体/对等体组接收到的BGP IPv6 SR Policy路由的有效性。
开启本功能后,设备会对BGP IPv6 SR Policy路由进行检查。如果BGP IPv6 SR Policy路由中既没有IPv4地址格式的RT扩展团体属性,又没有NO_ADVERTISE团体属性,则该路由无效,不会被优选。
在控制器与RR(Router Reflector,路由反射器)建立BGP邻居关系,RR再与多个不同SRv6 TE Policy的源节点建立BGP邻居关系的组网场景中,可以在RR上配置本功能,RR将检查控制器下发的多条BGP IPv6 SR Policy路由是否携带IPv4地址格式的RT属性或者NO_ADVERTISE团体属性,如果携带上述属性之一,则RR接收这些路由,并将不带NO_ADVERTISE的路由反射给多个不同SRv6 TE Policy的源节点。在不同SRv6 TE Policy的源节点可以配置router-id filter命令来开启Router ID过滤功能,源节点将本地的Router ID与BGP IPv6 SR Policy路由RT属性中的IPv4地址进行对比。如果相同,则接收该路由,否则,丢弃该路由。
# 开启BGP IPv6 SR Policy路由有效性检查功能。
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] validation-check enable
1.1.115  wait-to-restore-period
wait-to-restore-period命令用来配置IPR模板的回切时延。
undo wait-to-restore-period命令用来恢复缺省情况。
wait-to-restore-period time-value
IPR模板的回切时延为6秒。
SRv6 TE IPR模板视图
time-value:表示IPR模板的回切时延,取值范围为1~259200,单位为秒。
当SRv6 TE Policy组的头节点计算出最优SRv6 TE Policy和业务当前使用的SRv6 TE Policy不同,且最优SRv6 TE Policy的选路优先级比当前业务使用的SRv6 TE Policy的选路优先级高,则表示SRv6 TE Policy的iFIT功能检测到高优先级的SRv6 TE Policy的丢包率、时延或抖动恢复正常,业务流量需要切换回高优先级的SRv6 TE Policy中转发。此时,设备将启动回切时延计时器,回切时延由本命令配置。在回切时延计时器超时前,如果高优先级的SRv6 TE Policy的某次iFIT探测结果不满足SLA阈值标准,则回切时延计时器清零;如果该高优先级的SRv6 TE Policy的iFIT探测结果始终满足SLA阈值标准,则在回切时延计时器结束后,将业务流量切换到IPR计算得到的最优SRv6 TE Policy中转发。
如果不设置回切时延,直接将业务流量切换到高优先级的SRv6 TE Policy中转发,则可能因高优先级的SRv6 TE Policy转发链路的质量不稳定导致业务回切之后流量丢包或抖动。
# 配置IPR模板ipr1的回切时延为30秒。
[Sysname-srv6-te] intelligent-policy-route
[Sysname-srv6-ipr] ipr-policy ipr1
[Sysname-srv6-ipr-policy-ipr1] wait-to-restore-period 30
