- H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
- 01-H3C Devices CLI Reference
- 02-Login Management Quick Start Configuration Guide
- 03-Configuration File Management Quick Start Configruation Guide
- 04-Software Upgrade Quick Start Configuration Guide
- 05-Device Management Quick Start Configuration Guide
- 06-NTP Quick Start Configuration Guide
- 07-RBAC Quick Start Configuration Guide
- 08-IRF Quick Start Configuration Guide
- 09-Ethernet Interface Quick Start Configuration Guide
- 10-VLAN Quick Start Configuration Guide
- 11-Port Isolation Quick Start Configuration Guide
- 12-Loop Detection Quick Start Configuration Guide
- 13-QinQ Quick Start Configuration Guide
- 14-MAC Address Table Quick Start Configuration Guide
- 15-Ethernet Link Aggregation Quick Start Configuration Guide
- 16-Spanning Tree Quick Start Configuration Guide
- 17-DHCP Quick Start Configuration Guide
- 18-OSPF Quick Start Configuration Guide
- 19-Static Routing Quick Start Configuration Guide
- 20-Basic RIP Quick Start Configuration Guide
- 21-PBR Quick Start Configuration Guide
- 22-IGMP Snooping Quick Start Configuration Guide
- 23-Packet Filtering Quick Start Configuration Guide
- 24-QoS Quick Start Configuration Guide
- 25-IP Source Guard Quick Start Configuration Guide
- 26-SSH Quick Start Configuration Guide
- 27-Port Security Quick Start Configuration Guide
- 28-VRRP Quick Start Configuration Guide
- 29-PoE Quick Start Configuration Guide
- 30-Mirroring Quick Start Configuration Guide
- 31-Information Center Quick Start Configuration Guide
- 32-SNMP Quick Start Configuration Guide
- 33-Static Route-Based Public and Private Network Intercommunication Configuration Guide
- 34-LAN Networks Quick Start Configuration Guide
- 35-802.1X Quick Start Configuration Guide
- 36-AAA Quick Start Configuration Guide
| 33-Static Route-Based Public and Private Network Intercommunication Configuration Guide | 147.27 KB |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring static route-based public and private network intercommunication
Introduction
As shown in Figure 1, PE 1 is in the public network. The server is directly connected to PE 1. PE 2 is connected to VR 1. VPN 1 accesses the public network through PE 2. Configure
public and private network intercommunication to enable VR 1 to access Server.
Analysis
To enable VR 1 to access Server, configure the following settings in sequence:
1. Create VLANs on PE 1 and VR 1 and the associated VLAN interfaces.
2. Configure a VPN instance on PE 2 and connect VR 1 to PE 2.
3. Configure static routes on Server, PE 1, and VR 1 to ensure public network connectivity.
4. Configure static routes on PE 2 to implement public and private network intercommunication.
Configuring VR 1
# Create VLAN 10 on VR 1, and assign GigabitEthernet 1/0/1 to VLAN 10.
<VR1> system-view
[VR1] vlan 10
[VR1-vlan10] quit
[VR1] interface GigabitEthernet 1/0/1
[VR1-GigabitEthernet1/0/1] port link-type trunk
[VR1-GigabitEthernet1/0/1] port trunk permit vlan 10
[VR1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[VR1-GigabitEthernet1/0/1] quit
# Configure the IP address of VLAN-interface 10 as 10.214.10.2/24.
[VR1] interface Vlan-interface 10
[VR1-Vlan-interface10] ip address 10.214.10.2 24
[VR1-Vlan-interface10] quit
Configuring PE 1
# Create VLAN 30 and VLAN 40 on PE 1, and assign GigabitEthernet 1/0/1 to VLAN 40 and GigabitEthernet 1/0/2 to VLAN 30.
<PE1> system-view
[PE1] vlan 30
[PE1-vlan30] quit
[PE1] vlan 40
[PE1-vlan40] quit
[PE1] interface GigabitEthernet 1/0/1
[PE1-GigabitEthernet1/0/1] port link-type trunk
[PE1-GigabitEthernet1/0/1] port trunk permit vlan 40
[PE1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[PE1] interface GigabitEthernet 1/0/2
[PE1-GigabitEthernet1/0/2] port link-type trunk
[PE1-GigabitEthernet1/0/2] port trunk permit vlan 30
[PE1-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[PE1-GigabitEthernet1/0/2] quit
# Configure the IP addresses of VLAN-interface 30 and VLAN-interface 40 as 172.16.30.2/24 and 10.1.1.1/24, respectively.
[PE1] interface Vlan-interface 30
[PE1-Vlan-interface30] ip address 172.16.30.2 24
[PE1-Vlan-interface30] quit
[PE1] interface Vlan-interface 40
[PE1-Vlan-interface40] ip address 10.1.1.1 24
[PE1-Vlan-interface40] quit
Configuring PE 2
# Create VPN instance named vpn1 on PE 2, configure the RD value for the VPN instance as 10:1, and configure both the import and export route targets as 111:1.
<PE2> system-view
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 10:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
# Create VLAN 10 and VLAN 30 on PE 2, and assign GigabitEthernet 1/0/10 to VLAN 10 and GigabitEthernet 1/0/3 to VLAN 30.
[PE2] vlan 10
[PE2-vlan10] quit
[PE2] vlan 30
[PE2-vlan30] quit
[PE2] interface GigabitEthernet 1/0/10
[PE2-GigabitEthernet1/0/10] port link-type trunk
[PE2-GigabitEthernet1/0/10] port trunk permit vlan 10
[PE2-GigabitEthernet1/0/10] undo port trunk permit vlan 1
[PE2-GigabitEthernet1/0/10] quit
[PE2] interface GigabitEthernet 1/0/3
[PE2-GigabitEthernet1/0/3] port link-type trunk
[PE2-GigabitEthernet1/0/3] port trunk permit vlan 30
[PE2-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[PE2-GigabitEthernet1/0/3] quit
# Associate interface VLAN-interface 10 with VPN instance vpn1, and configure the IP address as 10.214.10.3/24.
[PE2] interface Vlan-interface 10
[PE2-Vlan-interface10] ip binding vpn-instance vpn1
[PE2-Vlan-interface10] ip address 10.214.10.3 24
[PE2-Vlan-interface10] quit
# Configure the IP address of VLAN-interface 30 as 172.16.30.1/24.
[PE2] interface Vlan-interface 30
[PE2-Vlan-interface30] ip address 172.16.30.1 24
[PE2-Vlan-interface30] quit
Configuring static routes on Server, PE 1, and VR 1
# Configure a static route on Server with destination network address 10.214.10.0 and next hop address 10.1.1.1.
<Server> system-view
[Server] ip route-static 10.214.10.0 255.255.255.0 10.1.1.1
# Configure a static route on PE 1 with destination network address 10.214.10.0 and next hop address 172.16.30.1.
<PE1> system-view
[PE1] ip route-static 10.214.10.0 24 172.16.30.1
# Configure a static route on VR 1 with destination network address 10.1.1.0 and next hop address 10.214.10.3.
<VR1> system-view
[VR1] ip route-static 10.1.1.0 24 10.214.10.3
Configuring static routes on PE 2 to implement public and private network intercommunication
# Configure a static route on PE 2 with destination network address 10.214.10.0 and next hop address 10.214.10.2, and bind this route to VPN instance vpn1.
<PE2> system-view
[PE2] ip route-static 10.214.10.0 24 vpn-instance vpn1 10.214.10.2
# Configure a static route on PE 2 with destination network address 10.1.1.0 and next hop address 172.16.30.2, and bind this route to VPN instance vpn1.
[PE2] ip route-static vpn-instance vpn1 10.1.1.0 24 172.16.30.2 public
# Display the routing information of VPN instance vpn1 on PE2.
[PE2] display ip routing-table vpn-instance vpn1
Destinations : 7 Routes : 7
10.214.10.0/24 Direct 0 0 10.214.10.3 Vlan10
10.214.10.3/32 Direct 0 0 127.0.0.1 InLoop0
172.16.30.0/24 Direct 0 0 172.16.30.1 Vlan30
172.16.30.1/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 Static 60 0 172.16.30.2 Vlan30
The output shows that the routing table of VPN 1 contains a static route pointing to the public network.
# Display the routing information on PE2.
[PE1] display ip routing-table
Destinations : 14 Routes : 14
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
100.100.11.1/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
172.16.30.0/24 Direct 0 0 172.16.30.2 Vlan30
172.16.30.0/32 Direct 0 0 172.16.30.2 Vlan30
172.16.30.2/32 Direct 0 0 127.0.0.1 InLoop0
172.16.30.255/32 Direct 0 0 172.16.30.2 Vlan30
10.214.10.0/24 Static 60 1 10.214.10.2 Vlan10
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
The output shows that a static route pointing to the private network have been added to the public network routing table.
# Ping Server on VR 1 to verify the network connectivity.
<VR1>ping 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=3.880 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=0.819 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=0.658 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=1.421 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=0.722 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 0.658/1.500/3.880/1.221 ms
Configuration files
· VR 1:
vlan 10
interface Vlan-interface10
ip address 10.214.10.2 255.255.255.0
port link-mode bridge
· PE 1:
vlan 30
vlan 40
interface Vlan-interface30
ip address 172.16.30.2 255.255.255.0
interface Vlan-interface40
· PE 2:
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
vlan 10
vlan 30
ip address 10.214.10.3 255.255.255.0
ip address 172.16.30.1 255.255.255.0
interface GigabitEthernet1/0/10
ip route-static 10.214.10.0 24 vpn-instance v1 10.214.10.2
ip route-static vpn-instance v1 10.1.1.0 24 172.16.30.2 public
Related documentation
· Static routing configuration in the Layer 3—IP routing configuration guide for the device.
· Static routing commands in the Layer 3—IP routing command reference for the device.
