- H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
- 01-H3C Devices CLI Reference
- 02-Login Management Quick Start Configuration Guide
- 03-Configuration File Management Quick Start Configruation Guide
- 04-Software Upgrade Quick Start Configuration Guide
- 05-Device Management Quick Start Configuration Guide
- 06-NTP Quick Start Configuration Guide
- 07-RBAC Quick Start Configuration Guide
- 08-IRF Quick Start Configuration Guide
- 09-Ethernet Interface Quick Start Configuration Guide
- 10-VLAN Quick Start Configuration Guide
- 11-Port Isolation Quick Start Configuration Guide
- 12-Loop Detection Quick Start Configuration Guide
- 13-QinQ Quick Start Configuration Guide
- 14-MAC Address Table Quick Start Configuration Guide
- 15-Ethernet Link Aggregation Quick Start Configuration Guide
- 16-Spanning Tree Quick Start Configuration Guide
- 17-DHCP Quick Start Configuration Guide
- 18-OSPF Quick Start Configuration Guide
- 19-Static Routing Quick Start Configuration Guide
- 20-Basic RIP Quick Start Configuration Guide
- 21-PBR Quick Start Configuration Guide
- 22-IGMP Snooping Quick Start Configuration Guide
- 23-Packet Filtering Quick Start Configuration Guide
- 24-QoS Quick Start Configuration Guide
- 25-IP Source Guard Quick Start Configuration Guide
- 26-SSH Quick Start Configuration Guide
- 27-Port Security Quick Start Configuration Guide
- 28-VRRP Quick Start Configuration Guide
- 29-PoE Quick Start Configuration Guide
- 30-Mirroring Quick Start Configuration Guide
- 31-Information Center Quick Start Configuration Guide
- 32-SNMP Quick Start Configuration Guide
- 33-Static Route-Based Public and Private Network Intercommunication Configuration Guide
- 34-LAN Networks Quick Start Configuration Guide
- 35-802.1X Quick Start Configuration Guide
- 36-AAA Quick Start Configuration Guide
| 15-Ethernet Link Aggregation Quick Start Configuration Guide | 141.55 KB |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring Layer 2 link aggregation
Enabling local-first load sharing for link aggregation
Introduction
The following information uses an example to describe the basic procedure for configuring Layer 2 link aggregation.
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
· VLAN 10 on Device A can communicate with VLAN 10 on Device B.
· VLAN 20 on Device A can communicate with VLAN 20 on Device B.
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
· When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a. Use the display this command in interface view to check the following attribute configurations of the port:
- Port isolation.
- QinQ.
- VLAN.
- VLAN mapping.
b. If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c. Assign the port to the aggregation group.
· In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, use dynamic aggregation.
· You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Configuring Device A
# Enter system view, create VLAN 10, and then assign port GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA-vlan20] port gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create static or dynamic Layer 2 aggregate interface Bridge-aggregation 1.
· Create static Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
· Create dynamic Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] undo shutdown
# Assign ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring GigabitEthernet1/0/1 done.
Configuring GigabitEthernet1/0/2 done.
Configuring GigabitEthernet1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
Configuring Device B
Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
· Display link aggregation configuration when the static aggregation mode is used.
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key
GE1/0/1(R) S 32768 1
GE1/0/2 S 32768 1
GE1/0/3 S 32768 1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
· Display link aggregation configuration when the dynamic aggregation mode is used.
Creation Mode: Manual
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/1 S 32768 1 1 {ACDEF}
GE1/0/2 S 32768 2 1 {ACDEF}
GE1/0/3 S 32768 3 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/1(R) 32768 1 1 0x8000, a4e5-c316-0100 {ACDEF}
GE1/0/2 32768 2 1 0x8000, a4e5-c316-0100 {ACDEF}
GE1/0/3 32768 3 1 0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same aggregation state through exchanging LACPDUs.
Configuration files
· Device A:
vlan 10
interface GigabitEthernet1/0/4
port link-mode bridge
port access vlan 10
vlan 20
interface GigabitEthernet1/0/5
port access vlan 20
¡ In the static aggregation mode:
interface Bridge-Aggregation1
¡ In the dynamic aggregation mode:
· Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Related documentation
· Ethernet link aggregation configuration in the Layer 2—LAN switching configuration guide for the device.
· Ethernet link aggregation commands in the Layer 2—LAN switching command reference for the device.
Introduction
The following information uses an example to describe the basic procedure for enabling local-first load sharing for link aggregation.
As shown in Figure 2:
· Device A and Device B form an IRF fabric and are aggregated across member devices via the GigabitEthernet1/0/3 and GigabitEthernet 2/0/3.
· Due to the aggregated load sharing feature, traffic from VLAN 2 and VLAN 3 is forwarded to Device C via GigabitEthernet 1/0/3 and GigabitEthernet 2/0/3, resulting in low traffic forwarding efficiency. If the bandwidth is satisfied, we want the traffic of VLAN 2 to be forwarded through GigabitEthernet 1/0/3 and the traffic of VLAN 3 to be forwarded through GigabitEthernet 2/0/3 in order to improve the traffic forwarding efficiency.
This feature is available only in IRF mode.
As a best practice, configure this feature only when the bandwidth of a single IRF device is sufficient to carry the traffic forwarding requirements. This can improve forwarding efficiency and alleviate the problem of high bandwidth carrying pressure on the IRF fabric.
For more information about IRF setup, see IRF Quick Start Configuration Guide or the Configuration Guide and Command Reference of the product.
# Enter system view, and create Layer 2 aggregate interface Bridge-Aggregation 1.
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 2/0/3 to Layer 2 aggregate interface Bridge-Aggregation 1.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 1
[DeviceA] interface gigabitethernet 2/0/3
[DeviceA-GigabitEthernet2/0/3] port link-aggregation group 1
[DeviceA-GigabitEthernet2/0/3] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port, and assign the port to all VLANs.
[DeviceA-Bridge-Aggregation1]port link-type trunk
[DeviceA-Bridge-Aggregation1]port trunk permit vlan all
[DeviceA-Bridge-Aggregation1]quit
# Enable local-first load sharing on the aggregate interface.
[DeviceA] link-aggregation load-sharing mode local-first
# Create VLAN 2 and VLAN 3.
[DeviceA] vlan 2 to 3
# Configure GigabitEthernet 1/0/4 as a trunk port, and assign the port to VLAN 2.
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4]port link-type trunk
[DeviceA-GigabitEthernet1/0/4]undo port trunk permit vlan 1
[DeviceA-GigabitEthernet1/0/4]port trunk permit vlan 2
[DeviceA-GigabitEthernet1/0/4]quit
# Configure GigabitEthernet 2/0/4 as a trunk port, and assign the port to VLAN 3.
[DeviceA] interface gigabitethernet 2/0/4
[DeviceA-GigabitEthernet2/0/4]port link-type trunk
[DeviceA-GigabitEthernet2/0/4]undo port trunk permit vlan 1
[DeviceA-GigabitEthernet2/0/4]port trunk permit vlan 3
[DeviceA-GigabitEthernet2/0/4]quit
Configuring Device C
<DeviceC> system-view
[DeviceC] interface bridge-aggregation 1
[DeviceC-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to Layer 2 aggregate interface Bridge-Aggregation 1.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceC-if-range] port link-aggregation group 1
[DeviceC-if-range] quit
[DeviceC-Bridge-Aggregation1]port link-type trunk
[DeviceC-Bridge-Aggregation1]port trunk permit vlan all
[DeviceC-Bridge-Aggregation1]quit
# Use display link-aggregation verbose to display detailed information about the aggregation groups.
GE1/0/3 S 32768 1
GE2/0/3 S 32768 1
The output shows that all member ports in the static aggregation group are in the Selected state. The traffic of VLAN 2 is forwarded only through GigabitEthernet 1/0/3.
Configuration files
· Device A:
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
· Device B:
· Device C:
