- H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
- 01-H3C Devices CLI Reference
- 02-Login Management Quick Start Configuration Guide
- 03-Configuration File Management Quick Start Configruation Guide
- 04-Software Upgrade Quick Start Configuration Guide
- 05-Device Management Quick Start Configuration Guide
- 06-NTP Quick Start Configuration Guide
- 07-RBAC Quick Start Configuration Guide
- 08-IRF Quick Start Configuration Guide
- 09-Ethernet Interface Quick Start Configuration Guide
- 10-VLAN Quick Start Configuration Guide
- 11-Port Isolation Quick Start Configuration Guide
- 12-Loop Detection Quick Start Configuration Guide
- 13-QinQ Quick Start Configuration Guide
- 14-MAC Address Table Quick Start Configuration Guide
- 15-Ethernet Link Aggregation Quick Start Configuration Guide
- 16-Spanning Tree Quick Start Configuration Guide
- 17-DHCP Quick Start Configuration Guide
- 18-OSPF Quick Start Configuration Guide
- 19-Static Routing Quick Start Configuration Guide
- 20-Basic RIP Quick Start Configuration Guide
- 21-PBR Quick Start Configuration Guide
- 22-IGMP Snooping Quick Start Configuration Guide
- 23-Packet Filtering Quick Start Configuration Guide
- 24-QoS Quick Start Configuration Guide
- 25-IP Source Guard Quick Start Configuration Guide
- 26-SSH Quick Start Configuration Guide
- 27-Port Security Quick Start Configuration Guide
- 28-VRRP Quick Start Configuration Guide
- 29-PoE Quick Start Configuration Guide
- 30-Mirroring Quick Start Configuration Guide
- 31-Information Center Quick Start Configuration Guide
- 32-SNMP Quick Start Configuration Guide
- 33-Static Route-Based Public and Private Network Intercommunication Configuration Guide
- 34-LAN Networks Quick Start Configuration Guide
- 35-802.1X Quick Start Configuration Guide
- 36-AAA Quick Start Configuration Guide
| 29-PoE Quick Start Configuration Guide | 69.93 KB |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring PoE
Introduction
The following information uses an example to describe the basis procedure to configure PoE.
The system reserves and supplies power to a PSE only after you enable PoE for that PSE.
You can enable PoE for a PSE if the PSE will not result in PoE power overload. If the PSE will result in PoE power overload, you can enable PoE for the PSE only when the PSE priority policy is enabled on the PSE.
You cannot execute the apply poe-profile or apply poe-profile interface command repeatedly to modify a PoE profile. To modify a PoE profile applied on a PI, first remove the PoE profile from the PI.
Enabling PoE for a single PI
# Enter system view.
< Device> system-view
# Enable PoE on GigabitEthernet 1/0/1.
[Device] interface GigabitEthernet 1/0/1
[Device-GigabitEthernet1/0/1] poe enable
# Save the configuration.
[Device] save force
Enabling PoE for PIs in bulk
# Create a PoE profile named abc, and specify its index number as 1.
[Device] poe-profile abc 1
# Enable PoE.
[Device-poe-profile-abc-1] poe enable
[Device-poe-profile-abc-1] return
# Apply PoE profile abc with an index number of 1 to PIs.
[Device] apply poe-profile abc index 1 interface gigabitethernet 1/0/1 to gigabitethernet 1/0/6
[Device] save force
# Verify that the device is supplying power correctly to the PIs, and the PIs are operating correctly.
Configuration files
· Enabling PoE for a single PI.
poe enable
· Enabling PoE for PIs in bulk.
poe-profile abc 1
poe enable
apply poe-profile index 1
save force
Related documentation
· PoE configuration in the network management and monitoring configuration guide for the device.
· PoE commands in the network management and monitoring command reference for the device.
