- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-VLANTERM-MIB
- 12-HH3C-LswMSTP-MIB
- 13-HH3C-LswVLAN-MIB
- 14-IEEE8021-CFM-MIB
- 15-IEEE8021-CFM-V2-MIB
- 16-IEEE8023-LAG-MIB
- 17-LLDP-EXT-MED-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-MIB
- 24-LLDP-V2-MIB
- 25-MAU-MIB
| 25-MAU-MIB | 103.45 KB |
MAU-MIB
About this MIB
This MIB is defined in RFC 3636 and contains interface media attachment unit (MAU) information.
The document might not be updated in time. For the latest detailed informatin, see the offical document at https://www.iana.org/assignments/ianamau-mib/ianamau-mib.
MIB file name
rfc3636-mau.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).snmpDot3MauMgt(26)
Tabular objects
ifMauTable
About this table
Use this table to obtain the interface MAU state.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are ifMauIfIndex and ifMauIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauIfIndex (1.3.6.1.2.1.26.2.1.1.1) |
read-only |
InterfaceIndex |
Standard MIB values. |
Index of the interface in this entry. |
As per the MIB. |
ifMauIndex (1.3.6.1.2.1.26.2.1.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Interface MAU index. |
As per the MIB. |
ifMauType (1.3.6.1.2.1.26.2.1.1.3) |
read-only |
AutonomousType |
Interface MAU operation type. The value (1) indicates autonegotiation. The value (2) indicates autonegotiation is not enabled or applied on an interface. |
As per the MIB. |
ifMauStatus (1.3.6.1.2.1.26.2.1.1.4) |
read-write |
INTEGER |
other(1), unknown(2), operational(3), standby(4), shutdown(5), reset(6) |
Current state of the interface MAU. |
The object can only be read. |
ifMauMediaAvailable (1.3.6.1.2.1.26.2.1.1.5) |
read-only |
INTEGER |
other(1), unknown(2), available(3), notAvailable(4), remoteFault(5), invalidSignal(6), remoteJabber(7), remoteLinkLoss(8), remoteTest(9), offline(10), autoNegError(11), pmdLinkFault(12), wisFrameLoss(13), wisSignalLoss(14), pcsLinkFault(15), excessiveBER(16), dxsLinkFault(17), pxsLinkFault(18) |
Current availability state of the interface MAU. |
As per the MIB. |
ifMauDefaultType (1.3.6.1.2.1.26.2.1.1.11) |
read-write |
AutonomousType |
Default interface MAU type. |
ifMauAutoNegSupported (1.3.6.1.2.1.26.2.1.1.12) |
read-only |
TruthValue |
true(1), false(2) |
Whether an interface MAU supports autonegotiation. |
As per the MIB. |
ifMauTypeListBits (1.3.6.1.2.1.26.2.1.1.13) |
read-only |
BITS |
bOther(0), bAUI(1), b10base5(2), bFoirl(3), b10base2(4), b10baseT(5), b10baseFP(6), b10baseFB(7), b10baseFL(8), b10broad36(9), b10baseTHD(10), b10baseTFD(11), b10baseFLHD(12), b10baseFLFD(13), b100baseT4(14), b100baseTXHD(15), b100baseTXFD(16), b100baseFXHD(17), b100baseFXFD(18), b100baseT2HD(19), b100baseT2FD(20), b1000baseXHD(21), b1000baseXFD(22), b1000baseLXHD(23), b1000baseLXFD(24), b1000baseSXHD(25), b1000baseSXFD(26), b1000baseCXHD(27), b1000baseCXFD(28), b1000baseTHD(29), b1000baseTFD(30), b10GbaseX(31), b10GbaseLX4(32), b10GbaseR(33), b10GbaseER(34), b10GbaseLR(35), b10GbaseSR(36), b10GbaseW(37), b10GbaseEW(38), b10GbaseLW(39), b10GbaseSW(40), -- new since RFC 3636 b10GbaseCX4(41), b2BaseTL(42), b10PassTS(43), b100BaseBX10D(44), b100BaseBX10U(45), b100BaseLX10(46), b1000BaseBX10D(47), b1000BaseBX10U(48), b1000BaseLX10(49), b1000BasePX10D(50), b1000BasePX10U(51), b1000BasePX20D(52), b1000BasePX20U(53), b10GbaseT(54), b10GbaseLRM(55), b1000baseKX(56), b10GbaseKX4(57), b10GbaseKR(58), b10G1GbasePRXD1(59), b10G1GbasePRXD2(60), b10G1GbasePRXD3(61), b10G1GbasePRXU1(62), b10G1GbasePRXU2(63), b10G1GbasePRXU3(64), b10GbasePRD1(65), b10GbasePRD2(66), b10GbasePRD3(67), b10GbasePRU1(68), b10GbasePRU3(69), b40GbaseKR4(70), b40GbaseCR4(71), b40GbaseSR4(72), b40GbaseFR(73), b40GbaseLR4(74), b100GbaseCR10(75), b100GbaseSR10(76), b100GbaseLR4(77), b100GbaseER4(78), b1000baseT1(79), b1000basePX30D(80), b1000basePX30U(81), b1000basePX40D(82), b1000basePX40U(83), b10G1GbasePRXD4(84), b10G1GbasePRXU4(85), b10GbasePRD4(86), b10GbasePRU4(87), b25GbaseCR(88), b25GbaseCRS(89), b25GbaseKR(90), b25GbaseKRS(91), b25GbaseR(92), b25GbaseSR(93), b25GbaseT(94), b40GbaseER4(95), b40GbaseR(96), b40GbaseT(97), b100GbaseCR4(98), b100GbaseKR4(99), b100GbaseKP4(100), b100GbaseR(101), b100GbaseSR4(102), b2p5GbaseT(103), b5GbaseT(104), b100baseT1(105), b1000baseRHA(106), b1000baseRHB(107), b1000baseRHC(108), b2p5GbaseKX(109), b2p5GbaseX(110), b5GbaseKR(111), b5GbaseR(112), b10GpassXR(113), b25GbaseLR(114), b25GbaseER(115), b50GbaseR(116), b50GbaseCR(117), b50GbaseKR(118), b50GbaseSR(119), b50GbaseFR(120), b50GbaseLR(121), b50GbaseER(122), b100GbaseCR2(123), b100GbaseKR2(124), b100GbaseSR2(125), b100GbaseDR(126), b200GbaseR(127), b200GbaseDR4(128), b200GbaseFR4(129), b200GbaseLR4(130), b200GbaseCR4(131), b200GbaseKR4(132), b200GbaseSR4(133), b200GbaseER4(134), b400GbaseR(135), b400GbaseSR16(136), b400GbaseDR4(137), b400GbaseFR8(138), b400GbaseLR8(139), b400GbaseER8(140), b10baseT1L(141), b10baseT1SHD(142), b10baseT1SMD(143), b10baseT1SFD(144), |
Set of possible IEEE 802.3 types that the MAU could be. |
As per the MIB. |
ifJackTable
About this table
Use this table to obtain the external jack information of an interface MAU.
Read:Supported
Columns
The table indexes are ifMauIfIndex, ifMauIndex, and ifJackIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifJackIndex (1.3.6.1.2.1.26.2.2.1.1) |
not-accessible |
Integer32 |
Index of the external jack of an interface MAU. |
As per the MIB. |
ifJackType (1.3.6.1.2.1.26.2.2.1.2) |
read-only |
JackType |
Type of the external jack of an interface MAU. |
As per the MIB. |
ifMauAutoNegTable
About this table
Use this table to obtain the autonegotiation information of an interface MAU.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauAutoNegAdminStatus (1.3.6.1.2.1.26.5.1.1.1) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Autonegotiation enabling state of an interface MAU. |
ifMauAutoNegConfig (1.3.6.1.2.1.26.5.1.1.4) |
read-only |
INTEGER |
other(1), configuring(2), complete(3), disabled(4), parallelDetectFail(5) |
Current autonegotiation state of an interface MAU. |
As per the MIB. |
ifMauAutoNegCapabilityBits (1.3.6.1.2.1.26.5.1.1.9) |
read-only |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bfdxPause(8), bfdxAPause(9), bfdxSPause(10), bfdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15), b10GbaseT(16), b1000baseKX(17), b10GbaseKX4(18), b10GbaseKR(19), b40GbaseKR4(20), b40GbaseCR4(21), b100GbaseCR10(22), b1000baseT1(23), b25GbaseRS(24), b25GbaseR(25), bRSFEC25Greq(26), bBaseFEC25Greq(27), b25GbaseT(28), b40GbaseT(29), b100GbaseCR4(30), b100GbaseKR4(31), b100GbaseKP4(32), bForceMS(33), b2p5GbaseT(34), b5GBaseT(35), b2p5GbaseKX(36), b5GbaseKR(37), b50GbaseR(38), b100GbaseR2(39), b200GbaseR4(40), b10baseT1L(41), b10baseT1S(42), |
Set of capabilities of the local autonegotiation entity. |
As per the MIB. |
ifMauAutoNegCapAdvertisedBits (1.3.6.1.2.1.26.5.1.1.10) |
read-write |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bFdxPause(8), bFdxAPause(9), bFdxSPause(10), bFdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15), b10GbaseT(16), b1000baseKX(17), b10GbaseKX4(18), b10GbaseKR(19), b40GbaseKR4(20), b40GbaseCR4(21), b100GbaseCR10(22), b1000baseT1(23), b25GbaseRS(24), b25GbaseR(25), bRSFEC25Greq(26), bBaseFEC25Greq(27), b25GbaseT(28), b40GbaseT(29), b100GbaseCR4(30), b100GbaseKR4(31), b100GbaseKP4(32), bForceMS(33), b2p5GbaseT(34), b5GBaseT(35), b2p5GbaseKX(36), b5GbaseKR(37), b50GbaseR(38), b100GbaseR2(39), b200GbaseR4(40), b10baseT1L(41), b10baseT1S(42), |
Set of capabilities advertised by the local autonegotiation entity. |
