06-Layer 2 - LAN Switching
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
12-HH3C-LswMSTP-MIB
12-HH3C-LswMSTP-MIB 296.54 KB
HH3C-LswMSTP-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cdot1sStpStatus (1.3.6.1.4.1.25506.8.35.14.1) 1
hh3cdot1sStpForceVersion (1.3.6.1.4.1.25506.8.35.14.2) 1
hh3cdot1sStpDiameter (1.3.6.1.4.1.25506.8.35.14.3) 1
hh3cdot1sMstBridgeMaxHops (1.3.6.1.4.1.25506.8.35.14.4) 2
hh3cdot1sMstMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.5) 2
hh3cdot1sMstMasterPathCost (1.3.6.1.4.1.25506.8.35.14.6) 2
hh3cdot1sMstBpduGuard (1.3.6.1.4.1.25506.8.35.14.7) 2
hh3cdot1sMstAdminFormatSelector (1.3.6.1.4.1.25506.8.35.14.8) 3
hh3cdot1sMstAdminRegionName (1.3.6.1.4.1.25506.8.35.14.9) 3
hh3cdot1sMstAdminRevisionLevel (1.3.6.1.4.1.25506.8.35.14.10) 3
hh3cdot1sMstOperFormatSelector (1.3.6.1.4.1.25506.8.35.14.11) 3
hh3cdot1sMstOperRegionName (1.3.6.1.4.1.25506.8.35.14.12) 3
hh3cdot1sMstOperRevisionLevel (1.3.6.1.4.1.25506.8.35.14.13) 4
hh3cdot1sMstOperConfigDigest (1.3.6.1.4.1.25506.8.35.14.14) 4
hh3cdot1sMstRegionConfActive (1.3.6.1.4.1.25506.8.35.14.15) 4
hh3cdot1sMstDefaultVlanAllo (1.3.6.1.4.1.25506.8.35.14.16) 4
hh3cdot1sMstDefaultRegionName (1.3.6.1.4.1.25506.8.35.14.17) 4
hh3cdot1sStpPathCostStandard (1.3.6.1.4.1.25506.8.35.14.21) 5
hh3cMstiTcGuardVal (1.3.6.1.4.1.25506.8.35.14.22.1) 5
hh3cPvstPvid (1.3.6.1.4.1.25506.8.35.14.22.2) 5
hh3cPvstPvidInPdu (1.3.6.1.4.1.25506.8.35.14.22.3) 5
hh3cMstiLpuStgNum (1.3.6.1.4.1.25506.8.35.14.22.4) 5
hh3cMstiMpuStgNum (1.3.6.1.4.1.25506.8.35.14.22.5) 6
hh3cMstiVlanID (1.3.6.1.4.1.25506.8.35.14.22.6) 6
hh3cMstiBridgeIDInPdu (1.3.6.1.4.1.25506.8.35.14.22.7) 6
hh3cMstiPortPriorityInPdu (1.3.6.1.4.1.25506.8.35.14.22.8) 6
hh3cMstiPortNumInPdu (1.3.6.1.4.1.25506.8.35.14.22.9) 6
Tabular objects· 7
hh3cdot1sVIDAllocationTable· 7
hh3cdot1sInstanceTable· 7
hh3cdot1sPortTable· 8
Notifications· 12
hh3cPortMstiStateForwarding· 12
hh3cPortMstiStateDiscarding· 13
hh3cBridgeLostRootPrimary· 14
hh3cPortMstiRootGuarded· 15
hh3cPortMstiBpduGuarded· 16
hh3cPortMstiLoopGuarded· 16
hh3cMstiNewRoot 17
hh3cMstiTopologyChange· 18
hh3cPortMstiLostEdge· 19
hh3cMstiTcGuarded· 20
hh3cMstiProTcGuarded· 21
hh3cPortPvstPvidInconsistent 22
hh3cPortPvstPortTypeInconsistent 23
HH3C-LswMSTP-MIB
About this MIB
Spanning tree protocols eliminate loops by selectively blocking ports to prune the loop structure into a loop-free tree structure.
This MIB defines private MIB objects for MSTP.
MIB file name
hh3c-splat-mstp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei(2011).products(2).lanSw(23).lswCommon(1).hwdotlsMstp(14)
Scalar objects
Object (OID)
Access
Value range
Implementation
read-write
EnabledStatus
enabled(1)
disabled(2)
MSTP status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
stp(0)
rstp(2)
mstp(3)
Spanning tree mode.
Same as MIB definition. The value for PVST is 2.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
2..7
Network diameter.
This object is related to the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects defined in IEEE 802.1d. Modification to the hh3cdot1sStpDiameter object will change the values of those objects.
Modification to any of the dot1dStpHelloTime, dot1dStpMaxAge, and dot1dStpForwardDelay objects will invalidate the value of the hh3cdot1sStpDiameter object.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
1..40
Maximum hops of an MST region.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
BridgeId
OCTET STRING (8)
Root bridge in an MSTP region.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
Standard MIB values.
Cost of the path to the root bridge.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
EnabledStatus
enabled(1)
disabled(2)
BPDU guard.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
0.
Bridge selection factor.
This object is configurable, and you can set it only to 0.
Object (OID)
Access
Value range
Implementation
read-write
OCTET STRING
SIZE (1..32)
MST region name.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
0..65535
MSTP revision level.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
Effective selection factor of an MSTP region.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
SIZE (0..32)
Effective MST region name.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
0..65535
Effective MSTP revision level.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
SIZE (0..16)
Effective configuration digest of an MST region.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enable(1)
disable(2)
Activate MST region configuration.
Default: Enabled.
If you set the value to disable, MST region configuration is read-only and does not take effect.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enable(1)
unused(65535)
Default VLAN-to-instance mappings in an MST region.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enable(1)
unused(65535)
Default MST region name.
As per the MIB.
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
legacy(0)
dot1d-1998(1)
dot1t(2)
Standard for calculating the default path costs.
legacy—Private standard.
dot1d-1998—IEEE 802.1d-1998.
dot1t—IEEE 802.1t.
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
Integer32 (1..255)
TC threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..4094)
PVID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..4094)
PVID carried in packets.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..4094)
STG count of the LPU.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..4094)
STG count of the MPU.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..4094)
VLAN ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
BridgeId
OCTET STRING (8)
Bridge ID carried in low-priority BPDUs.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32  (1..65535)
Port priority carried in low-priority BPDUs.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Port ID carried in low-priority BPDUs.
As per the MIB.
Tabular objects
About this table
Use this table to configure MSTP VLAN settings.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cdot1sMstVID.
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstVID (1.3.6.1.4.1.25506.8.35.14.18.1.1)
read-only
INTEGER
1..4094
VLAN ID
As per the MIB.
hh3cdot1sAdminMstID (1.3.6.1.4.1.25506.8.35.14.18.1.2)
read-write
INTEGER
0..4094
Configured MST region mapping.
As per the MIB.
hh3cdot1sOperMstID (1.3.6.1.4.1.25506.8.35.14.18.1.3)
read-only
INTEGER
0..4094
Effective MST region mapping.
As per the MIB.
About this table
Use this table to configure MST region settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cdot1sInstanceID.
Object (OID)
Access
Value range
Implementation
hh3cdot1sInstanceID (1.3.6.1.4.1.25506.8.35.14.19.1.1)
read-only
INTEGER
0..4094
Instance ID.
As per the MIB.
hh3cdot1sMstiBridgeID (1.3.6.1.4.1.25506.8.35.14.19.1.2)
read-only
BridgeId
OCTET STRING (8)
Bridge ID.
As per the MIB.
hh3cdot1sMstiBridgePriority (1.3.6.1.4.1.25506.8.35.14.19.1.3)
read-write
INTEGER
0..61440
Bridge priority.
As per the MIB.
hh3cdot1sMstiDesignedRoot (1.3.6.1.4.1.25506.8.35.14.19.1.4)
read-only
BridgeId
OCTET STRING (8)
Root bridge.
As per the MIB.
hh3cdot1sMstiRootPathCost (1.3.6.1.4.1.25506.8.35.14.19.1.5)
read-only
INTEGER
Path cost from the MSTI to the root bridge.
As per the MIB.
hh3cdot1sMstiRootPort (1.3.6.1.4.1.25506.8.35.14.19.1.6)
read-only
INTEGER
Root port.
As per the MIB.
hh3cdot1sMstiRootType (1.3.6.1.4.1.25506.8.35.14.19.1.7)
read-write
INTEGER
normal(0)
secondary(1)
primary(2)
Root bridge type.
As per the MIB.
hh3cdot1sMstiRemainingHops (1.3.6.1.4.1.25506.8.35.14.19.1.8)
read-only
INTEGER
Remaining hops.
As per the MIB.
hh3cdot1sMstiAdminMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.9)
read-only
OCTET STRING
SIZE (0..256)
Lower part of the VLAN ID list mapped to the instance.
As per the MIB.
hh3cdot1sMstiAdminMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.10)
read-only
OCTET STRING
SIZE (0..256)
Higher part of the VLAN ID list mapped to the instance.
As per the MIB.
hh3cdot1sMstiOperMappedVlanListLow (1.3.6.1.4.1.25506.8.35.14.19.1.11)
read-only
OCTET STRING
SIZE (0..256)
Lower part of the effective VLAN ID list.
As per the MIB.
hh3cdot1sMstiOperMappedVlanListHigh (1.3.6.1.4.1.25506.8.35.14.19.1.12)
read-only
OCTET STRING
SIZE (0..256)
Higher part of the effective VLAN ID list.
As per the MIB.
hh3cdot1sPortTable
About this table
Use this table to configure MSTP on ports.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cdot1sInstanceID and hh3cdot1sMstiPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cdot1sMstiPortIndex (1.3.6.1.4.1.25506.8.35.14.20.1.1)
read-only
INTEGER
(0..65535)
Port index.
As per the MIB.
hh3cdot1sMstiState (1.3.6.1.4.1.25506.8.35.14.20.1.2)
read-only
INTEGER
disabled(1)
discarding(2)
learning(4)
forwarding(5)
Port status.
Does not support disabled.
hh3cdot1sMstiPortPriority (1.3.6.1.4.1.25506.8.35.14.20.1.3)
read-write
INTEGER
0..240
Port priority.
As per the MIB.
hh3cdot1sMstiPathCost (1.3.6.1.4.1.25506.8.35.14.20.1.4)
read-write
INTEGER
1..200000000
Port path cost.
As per the MIB.
hh3cdot1sMstiDesignatedRoot (1.3.6.1.4.1.25506.8.35.14.20.1.5)
read-only
BridgeId
OCTET STRING (8)
Root bridge.
As per the MIB.
hh3cdot1sMstiDesignatedCost (1.3.6.1.4.1.25506.8.35.14.20.1.6)
read-only
INTEGER
Path cost of the designated port.
As per the MIB.
hh3cdot1sMstiDesignatedBridge (1.3.6.1.4.1.25506.8.35.14.20.1.7)
read-only
BridgeId
OCTET STRING (8)
Designated bridge.
As per the MIB.
hh3cdot1sMstiDesignatedPort (1.3.6.1.4.1.25506.8.35.14.20.1.8)
read-only
OCTET STRING
SIZE (2)
Designated port.
As per the MIB.
hh3cdot1sMstiMasterBridgeID (1.3.6.1.4.1.25506.8.35.14.20.1.9)
read-only
BridgeId
OCTET STRING (8)
Master bridge.
As per the MIB.
hh3cdot1sMstiMasterPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.10)
read-only
INTEGER
Path cost to the master bridge.
As per the MIB.
hh3cdot1sMstiStpPortEdgeport (1.3.6.1.4.1.25506.8.35.14.20.1.11)
read-write
EnabledStatus
enabled(1)
disabled(2)
Whether the port is an edge port.
As per the MIB.
hh3cdot1sMstiStpPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.12)
read-write
INTEGER
forceTrue(1)
forceFalse(2)
auto(3)
Whether to set the port link type to point-to-point.
As per the MIB.
hh3cdot1sMstiStpMcheck (1.3.6.1.4.1.25506.8.35.14.20.1.13)
read-write
INTEGER
enable(1)
unused(65535)
Perform mCheck.
As per the MIB.
hh3cdot1sMstiStpTransLimit (1.3.6.1.4.1.25506.8.35.14.20.1.14)
read-write
INTEGER
1..255
BPDU transmission rate.
Default: 10.
hh3cdot1sMstiStpRXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.15)
read-only
Counter32
Incoming BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXStpBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.16)
read-only
Counter32
Outgoing BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.17)
read-only
Counter32
Incoming TCN BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXTCNBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.18)
read-only
Counter32
Outgoing TCN BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.19)
read-only
Counter32
Incoming RSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXRSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.20)
read-only
Counter32
Outgoing RSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpRXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.21)
read-only
Counter32
Incoming MSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpTXMSTPBPDU (1.3.6.1.4.1.25506.8.35.14.20.1.22)
read-only
Counter32
Outgoing MSTP BPDU count.
As per the MIB.
hh3cdot1sMstiStpClearStatistics (1.3.6.1.4.1.25506.8.35.14.20.1.23)
read-write
INTEGER
clear(1)
unused(65535)
Clear packet statistics.
As per the MIB.
hh3cdot1sMstiStpDefaultPortCost (1.3.6.1.4.1.25506.8.35.14.20.1.24)
read-write
INTEGER
enable(1)
unused(65535)
Default port path cost.
As per the MIB.
hh3cdot1sMstiStpStatus (1.3.6.1.4.1.25506.8.35.14.20.1.25)
read-write
EnabledStatus
enabled(1)
disabled(2)
Spanning tree feature status.
As per the MIB.
hh3cdot1sMstiPortRootGuard (1.3.6.1.4.1.25506.8.35.14.20.1.26)
read-write
EnabledStatus
enabled(1)
disabled(2)
Root guard status.
As per the MIB.
hh3cdot1sMstiPortLoopGuard (1.3.6.1.4.1.25506.8.35.14.20.1.27)
read-write
EnabledStatus
enabled(1)
disabled(2)
Loop guard status.
As per the MIB.
hh3cdot1sMstiStpPortSendingBPDUType (1.3.6.1.4.1.25506.8.35.14.20.1.28)
read-only
INTEGER
stp(1)
rstp(2)
mstp(3)
BPDU type.
As per the MIB.
hh3cdot1sMstiStpOperPortPointToPoint (1.3.6.1.4.1.25506.8.35.14.20.1.29)
read-only
TruthValue
true(1)
false(2)
Whether the port link type is point-to-point.
As per the MIB.
hh3cdot1sMstiStpPortAdminBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.30)
read-write
Hh3cdot1sFormatStatus
legacy(1)
dot1s(2)
auto(3)
Set the mode used by the port to recognize and send MSTP BPDUs.
legacy—The port receives and sends only compatible-format MSTP BPDUs.
dot1s—The port receives and sends only standard-format (802.1s-compliant) MSTP BPDUs.
auto—The port recognizes the MSTP BPDU format automatically and determines the format of MSTP BPDUs to send accordingly.
This mode takes effect only on the CIST.
hh3cdot1sMstiStpPortOperBPDUFmt (1.3.6.1.4.1.25506.8.35.14.20.1.31)
read-only
legacy(1)
dot1s(2)
auto(3)
Read the mode used by the port to send MSTP BPDUs.
legacy—The port sends only compatible-format MSTP BPDUs.
dot1s—The port sends only standard-format (802.1s-compliant) MSTP BPDUs.
hh3cdot1sMstiStpPortRoleRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.32)
read-write
EnabledStatus
enabled(1)
disabled(2)
Port role restriction status.
As per the MIB.
hh3cdot1sMstiStpPortTcRestriction(1.3.6.1.4.1.25506.8.35.14.20.1.33)
read-write
EnabledStatus
enabled(1)
disabled(2)
TC-BPDU transmission restriction status.
As per the MIB.
hh3cdot1sMstiStpPortDisputed(1.3.6.1.4.1.25506.8.35.14.20.1.34)
read-only
TruthValue
true(1)
false(2)
Dispute guard status.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.14.0.1
A port transits to the forwarding state.
Informational
Warning
OFF
Notification triggers
This notification might be generated when a port transits to the forwarding state in the following situations:
The network topology changes after a new link is added.
The network topology changes after a port comes up or goes down.
System impact
The network topology changes.
Status control
ON
CLI: Use the stp port-log command.
OFF
CLI: Use the undo stp port-log command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.14.19.1.1 (hh3cdot1sInstanceID)
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.20.1.1 (hh3cdot1sMstiPortIndex)
Port index.
hh3cdot1sInstanceID
INTEGER
1..65535
Recommended action
To resolve this issue:
1.Check for link failures after the network topology becomes stable.
2.Identify whether the spanning tree feature is enabled on a new physical link.
3.Identify whether a spanning tree-enabled port in the network topology has come up or gone down.
4.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.2
A port transits to the discarding state.
Informational
Warning
OFF
This notification might be generated when a port transits to the discarding state in the following situations:
The network topology is recalculated after a new link is added.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Port index.
hh3cdot1sInstanceID
INTEGER
1..65535
Recommended action
1.Identify whether a new physical link is added in the spanning tree network after the network topology becomes stable.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.3
The device loses its root bridge role after another device is elected as root bridge.
Informational
Warning
ON
This notification might be generated when the device loses its root bridge role after another device is elected as root bridge in the following situations:
A new link is added to the network topology.
The priority of a device changes in the network topology.
System impact
The network topology might not be presented as expected.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Recommended action
1.Identify whether a new physical link is added in the spanning tree network.
2.Identify whether a priority change operation has been performed and verify that the operation is correct.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.4
A root guard-enabled port receives a configuration BPDU with a higher priority.
Informational
Warning
OFF
This notification might be generated when the following events occur:
A root guard-enabled port receives a configuration BPDU with a priority higher than the current bridge.
The priority of a device in the network topology changes.
System impact
Status control
ON
CLI: Use the stp root-protection command.
MIB: Set hh3cdot1sMstiPortRootGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortRootGuard to false(2).
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Port index.
hh3cdot1sInstanceID
INTEGER
1..65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.5
A BPDU guard-enabled edge port receives configuration BPDUs.
Informational
Warning
OFF
This notification is generated when a BPDU guard-enabled edge port receives configuration BPDUs.
System impact
The user network connected to the port is interrupted.
Status control
ON
CLI: Use the stp bpdu-protection command.
MIB: Set hh3cdot1sMstBpduGuard to true(1).
OFF
MIB: Set hh3cdot1sMstBpduGuard to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.17.2.15.1.1 (dot1dStpPort)
Port index.
dot1dStpPort
INTEGER
1..65535
Recommended action
Verify that the downstream device is an endpoint device.
Check for possible attacks from other devices.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.6
An alternate port or root port does not receive a BPDU upon BPDU reception timeout.
Informational
Warning
OFF
This notification might be generated when an alternate port or root port does not receive a BPDU upon BPDU reception timeout in the following situations:
The peer port does not send a BPDU to the local end before the BPDU reception time expires. The spanning tree feature might be disabled on the peer port.
The link connected to the peer end is congested. Verify that traffic can be forwarded correctly.
System impact
The alternate port or root port cannot forward service traffic.
Status control
ON
CLI: Use the stp loop-protection command.
MIB: Set hh3cdot1sMstiPortLoopGuard to true(1).
OFF
MIB: Set hh3cdot1sMstiPortLoopGuard to false(2).
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Port index.
hh3cdot1sInstanceID
INTEGER
1..65535
Recommended action
Verify that the spanning tree status of the upstream device is correct.
hh3cMstiNewRoot
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.7
A new root bridge is elected.
Informational
Warning
OFF
This notification might be generated when a new root bridge is elected in the following situations:
The current bridge joins a new network topology.
The priority of the current bridge increases.
The original root bridge fails.
The priority of the original root bridge decreases.
System impact
The network topology changes. Service traffic loss might occur.
Status control
ON
CLI: Use the snmp trap enable stp new-root command.
OFF
CLI: Use the undo snmp trap enable stp new-root command.
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.19.1.4 (hh3cdot1sMstiDesignedRoot)
Root bridge information.
hh3cdot1sInstanceID
BridgeId
hh3cdot1sInstanceID
BridgeId
Recommended action
Verify that the bridge priority configuration on devices is correct.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.9
The network topology changes after the spanning tree state of ports changes.
Informational
Warning
ON
This notification might be generated when the spanning tree state changes of ports cause network topology changes in the following situations:
The network topology changes after the priority of a device changes.
Network topology change causes discarding port change after the cost value or priority of a port is changed.
System impact
Status control
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Recommended action
2.Identify whether a spanning tree-enabled port has come up or gone down in the network topology.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.10
An edge port receives BPDUs.
Informational
Warning
ON
This notification is generated when an edge port receives BPDUs and becomes a non-edge port.
System impact
The network topology might change.
Status control
Object
OID (object name)
Index
Value range
Port number.
INTEGER
1..65535
1.3.6.1.2.1.2.2.1.2
 (ifDescr)
Interface name.
ifIndex
OCTET STRING
OCTET STRING(0..255)
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Recommended action
1.Verify that the peer network attached to the edge port has changed and identify whether the received BPDUs are malicious attack packets.
hh3cMstiTcGuarded
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.11
The number of TC-BPDUs received by the device exceeds the upper threshold.
Informational
Warning
ON
This notification is generated when the number of TC-BPDUs received by the device exceeds the upper threshold within a TC-BPDU protection period.
System impact
The excessive TC-BPDUs do not immediately cause MAC and ARP entry deletion. The network topology does not change immediately.
Status control
ON
CLI: Use the stp tc-protection command.
OFF
CLI: Use the undo stp tc-protection command.
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
Recommended action
1.Identify whether the network topology is flapping.
2.Identify whether malicious attacks exist.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.12
Informational
Warning
ON
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Instance ID.
hh3cdot1sInstanceID
INTEGER
0..4094
1.3.6.1.4.1.25506.8.35.14.22.1 (hh3cMstiTcGuardVal)
Upper threshold
N/A
Integer32
Integer32  (1..255)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.17
PVID inconsistency.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an interface receives a BPDU with a different PVID.
System impact
PVST calculation errors might occur.
Status control
ON
CLI: Use the stp ignore-pvid-inconsistency command.
OFF
CLI: Use the undo stp ignore-pvid-inconsistency command.
Object
OID (object name)
Index
Value range
 (hh3cPvstPvid)
PVID.
N/A
Integer32
Integer32  (1..4094)
 (hh3cPvstPvidInPdu)
PVID in packets.
N/A
Integer32
Integer32  (1..4094)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface name.
ifIndex
OCTET STRING
OCTET STRING (0..255)
Recommended action
1.Identify whether different PVIDs are required on two connected ports:
  - If yes, use the stp ignore-pvid-inconsistency command to disable inconsistent PVID protection.
  - If no, modify the different PVIDs to be the same.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.14.0.18
Port type inconsistency.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an access port receives a PVST BPDU from a trunk or hybrid port.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cMstiVlanID)
VLAN ID.
N/A
Integer32
Integer32  (1..4094)
Interface name.
ifIndex
OCTET STRING
Recommended action
1.Identify whether the port types of the two ends are the same:
  - If yes, proceed to step 2.
  - If no, modify the port types to be the same. If the issue persists, proceed to step 2.
2.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
