- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-VLANTERM-MIB
- 12-HH3C-LswMSTP-MIB
- 13-HH3C-LswVLAN-MIB
- 14-IEEE8021-CFM-MIB
- 15-IEEE8021-CFM-V2-MIB
- 16-IEEE8023-LAG-MIB
- 17-LLDP-EXT-MED-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-MIB
- 24-LLDP-V2-MIB
- 25-MAU-MIB
| 23-LLDP-MIB | 189.00 KB |
lldpMessageTxInterval (1.0.8802.1.1.2.1.1.1)
lldpMessageTxHoldMultiplier (1.0.8802.1.1.2.1.1.2)
lldpReinitDelay (1.0.8802.1.1.2.1.1.3)
lldpTxDelay (1.0.8802.1.1.2.1.1.4)
lldpNotificationInterval (1.0.8802.1.1.2.1.1.5)
lldpStatsRemTablesLastChangeTime (1.0.8802.1.1.2.1.2.1)
lldpStatsRemTablesInserts (1.0.8802.1.1.2.1.2.2)
lldpStatsRemTablesDeletes (1.0.8802.1.1.2.1.2.3)
lldpStatsRemTablesDrops (1.0.8802.1.1.2.1.2.4)
lldpStatsRemTablesAgeouts (1.0.8802.1.1.2.1.2.5)
lldpLocChassisIdSubtype (1.0.8802.1.1.2.1.3.1)
lldpLocChassisId (1.0.8802.1.1.2.1.3.2)
lldpLocSysName (1.0.8802.1.1.2.1.3.3)
lldpLocSysDesc (1.0.8802.1.1.2.1.3.4)
lldpLocSysCapSupported (1.0.8802.1.1.2.1.3.5)
lldpLocSysCapEnabled (1.0.8802.1.1.2.1.3.6)
LLDP-MIB
About this MIB
Use this MIB to configure the following LLDP information:
● LLDP configuration.
● LLDP statistics.
● LLDP local system information.
● LLDP neighbor system information.
MIB file name
lldp.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpMessageTxInterval (1.0.8802.1.1.2.1.1.1) |
read-write |
Integer32 |
Integer32 (5..32768) |
LLDP frame transmission interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpMessageTxHoldMultiplier (1.0.8802.1.1.2.1.1.2) |
read-write |
Integer32 |
Integer32 (2..10) |
TTL multiplier. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpReinitDelay (1.0.8802.1.1.2.1.1.3) |
read-write |
Integer32 |
Integer32 (1..10) |
LLDP reinitialization delay. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpTxDelay (1.0.8802.1.1.2.1.1.4) |
read-write |
Integer32 |
Integer32 (1..8192) |
LLDP frame transmission delay. |
The value is fixed at 2, which indicates that this delay is not supported. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpNotificationInterval (1.0.8802.1.1.2.1.1.5) |
read-write |
Integer32 |
Integer32 (5..3600) |
Trap transmission interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRemTablesLastChangeTime (1.0.8802.1.1.2.1.2.1) |
read-only |
TimeStamp |
Standard MIB values. |
Time when LLDP information about a neighboring device was last updated. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRemTablesInserts (1.0.8802.1.1.2.1.2.2) |
read-only |
ZeroBasedCounter32 |
Number of neighbors added by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRemTablesDeletes (1.0.8802.1.1.2.1.2.3) |
read-only |
Number of neighbors deleted by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRemTablesDrops (1.0.8802.1.1.2.1.2.4) |
read-only |
Number of neighbors discarded by LLDP. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRemTablesAgeouts (1.0.8802.1.1.2.1.2.5) |
read-only |
Neighbor ageout count. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocChassisIdSubtype (1.0.8802.1.1.2.1.3.1) |
read-only |
LldpChassisIdSubtype |
Local chassis ID subtype. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocChassisId (1.0.8802.1.1.2.1.3.2) |
read-only |
LldpChassisId |
Local chassis ID. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocSysName (1.0.8802.1.1.2.1.3.3) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Local system name. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocSysDesc (1.0.8802.1.1.2.1.3.4) |
read-only |
SnmpAdminString |
Local system description. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocSysCapSupported (1.0.8802.1.1.2.1.3.5) |
read-only |
LldpSystemCapabilitiesMap |
Capabilities supported by the local system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocSysCapEnabled (1.0.8802.1.1.2.1.3.6) |
read-only |
Capabilities enabled on the local system. |
As per the MIB. |
Tabular objects
lldpPortConfigTable
About this table
Use this table to configure LLDP on a port.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is lldpPortConfigPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpPortConfigPortNum (1.0.8802.1.1.2.1.1.6.1.1) |
not-accessible |
LldpPortNumber |
Port number. |
As per the MIB. |
lldpPortConfigAdminStatus (1.0.8802.1.1.2.1.1.6.1.2) |
read-write |
INTEGER |
txOnly(1) rxOnly(2) txAndRx(3) disabled(4) |
LLDP operating mode. |
As per the MIB. |
lldpPortConfigNotificationEnable (1.0.8802.1.1.2.1.1.6.1.3) |
read-write |
TruthValue |
Trapping status. |
As per the MIB. |
lldpPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.1.6.1.4) |
read-write |
BITS |
BITS { portDesc(0) sysName(1) sysDesc(2) sysCap(3) } |
Optional TLVs that the port can send. |
Default: All bits are set to 1, which indicates that all basic optional TLVs are enabled. |
lldpConfigManAddrTable
About this table
Use this table to configure management addresses.
Read:Supported
Columns
The table indexes are lldpLocManAddrSubtype and lldpLocManAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpConfigManAddrPortsTxEnable (1.0.8802.1.1.2.1.1.7.1.1) |
read-write |
LldpPortList |
Ports that can send management addresses. |
Each bit set in this list represents a port. By default, all bits are set to 1, which indicates that all ports can send management addresses. |
lldpStatsTxPortTable
About this table
Use this table to obtain outgoing LLDP packet statistics about ports.
Edit/Modify:Not supported
Read:Supported
Columns
The table index is lldpStatsTxPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsTxPortNum (1.0.8802.1.1.2.1.2.6.1.1) |
not-accessible |
LldpPortNumber |
Port number. |
As per the MIB. |
lldpStatsTxPortFramesTotal (1.0.8802.1.1.2.1.2.6.1.2) |
read-only |
Counter32 |
Total outgoing frame count. |
As per the MIB. |
lldpStatsRxPortTable
About this table
Use this table to obtain incoming LLDP packet statistics about ports.
Read:Supported
Columns
The table index is lldpStatsRxPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpStatsRxPortNum (1.0.8802.1.1.2.1.2.7.1.1) |
not-accessible |
LldpPortNumber |
Port number. |
As per the MIB. |
lldpStatsRxPortFramesDiscardedTotal (1.0.8802.1.1.2.1.2.7.1.2) |
read-only |
Counter32 |
Discarded incoming frame count. |
As per the MIB. |
lldpStatsRxPortFramesErrors (1.0.8802.1.1.2.1.2.7.1.3) |
read-only |
Counter32 |
Error incoming frame count. |
As per the MIB. |
lldpStatsRxPortFramesTotal (1.0.8802.1.1.2.1.2.7.1.4) |
read-only |
Counter32 |
Total incoming frame count. |
As per the MIB. |
lldpStatsRxPortTLVsDiscardedTotal (1.0.8802.1.1.2.1.2.7.1.5) |
read-only |
Counter32 |
Discarded incoming TLV count. |
As per the MIB. |
lldpStatsRxPortTLVsUnrecognizedTotal (1.0.8802.1.1.2.1.2.7.1.6) |
read-only |
Counter32 |
Unrecognized incoming TLV count. |
As per the MIB. |
lldpStatsRxPortAgeoutsTotal (1.0.8802.1.1.2.1.2.7.1.7) |
read-only |
As per the MIB. |
lldpLocPortTable
About this table
Use this table to obtain LLDP information about local ports.
Read:Supported
Columns
The table index is lldpLocPortNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocPortNum (1.0.8802.1.1.2.1.3.7.1.1) |
not-accessible |
LldpPortNumber |
Port number. |
As per the MIB. |
lldpLocPortIdSubtype (1.0.8802.1.1.2.1.3.7.1.2) |
read-only |
LldpPortIdSubtype |
Port ID subtype. |
As per the MIB. |
lldpLocPortId (1.0.8802.1.1.2.1.3.7.1.3) |
read-only |
LldpPortId |
Port ID. |
If the port has a MED neighbor, the port ID is the MAC address of the port. If the port does not have a MED neighbor, the port ID is the name of the port. |
lldpLocPortDesc (1.0.8802.1.1.2.1.3.7.1.4) |
read-only |
SnmpAdminString |
Port description. |
As per the MIB. |
lldpLocManAddrTable
About this table
Use this table to obtain local management address information.
Read:Supported
Columns
The table indexes are lldpLocManAddrSubtype, lldpLocManAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpLocManAddrSubtype (1.0.8802.1.1.2.1.3.8.1.1) |
not-accessible |
AddressFamilyNumbers |
Management address subtype. |
As per the MIB. |
lldpLocManAddr (1.0.8802.1.1.2.1.3.8.1.2) |
not-accessible |
LldpManAddress |
Management address. |
As per the MIB. |
lldpLocManAddrLen (1.0.8802.1.1.2.1.3.8.1.3) |
read-only |
Integer32 |
Management address length. |
As per the MIB. |
lldpLocManAddrIfSubtype (1.0.8802.1.1.2.1.3.8.1.4) |
read-only |
LldpManAddrIfSubtype |
The enumeration value that identifies the port numbering method used for defining the port number associated with the local system. |
The subtype is IfIndex. |
lldpLocManAddrIfId (1.0.8802.1.1.2.1.3.8.1.5) |
read-only |
Integer32 |
Index of the port associated with the management address. |
If no port is associated with the management address, the value of this object is 0. |
lldpLocManAddrOID (1.0.8802.1.1.2.1.3.8.1.6) |
read-only |
OBJECT IDENTIFIER |
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the local system agent. |
Not supported. |
lldpRemTable
About this table
Use this table to obtain neighbor configuration and related local indexes.
Read:Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpRemTimeMark (1.0.8802.1.1.2.1.4.1.1.1) |
not-accessible |
TimeFilter |
Time mark for a neighbor. |
The time mark is the time when this object is created or the remote system is updated. You can use the time mark to search for remote system records. |
lldpRemLocalPortNum (1.0.8802.1.1.2.1.4.1.1.2) |
not-accessible |
LldpPortNumber |
Local port receiving the neighbor information. |
As per the MIB. |
lldpRemIndex (1.0.8802.1.1.2.1.4.1.1.3) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Neighbor index. |
As per the MIB. |
lldpRemChassisIdSubtype (1.0.8802.1.1.2.1.4.1.1.4) |
read-only |
Neighbor chassis ID subtype. |
As per the MIB. |
lldpRemChassisId (1.0.8802.1.1.2.1.4.1.1.5) |
read-only |
LldpChassisId |
Neighbor chassis ID. |
As per the MIB. |
lldpRemPortIdSubtype (1.0.8802.1.1.2.1.4.1.1.6) |
read-only |
LldpPortIdSubtype |
Neighbor port ID subtype. |
As per the MIB. |
lldpRemPortId (1.0.8802.1.1.2.1.4.1.1.7) |
read-only |
LldpPortId |
Neighbor port ID. |
As per the MIB. |
lldpRemPortDesc (1.0.8802.1.1.2.1.4.1.1.8) |
read-only |
SnmpAdminString |
Neighbor port description. |
As per the MIB. |
lldpRemSysName (1.0.8802.1.1.2.1.4.1.1.9) |
read-only |
SnmpAdminString |
Neighbor system name. |
As per the MIB. |
lldpRemSysDesc (1.0.8802.1.1.2.1.4.1.1.10) |
read-only |
SnmpAdminString |
Neighbor system description. |
As per the MIB. |
lldpRemSysCapSupported (1.0.8802.1.1.2.1.4.1.1.11) |
read-only |
Capabilities supported by the neighbor system. |
As per the MIB. |
lldpRemSysCapEnabled (1.0.8802.1.1.2.1.4.1.1.12) |
read-only |
Capabilities enabled on the neighbor system. |
As per the MIB. |
lldpRemManAddrTable
About this table
Use this table to obtain neighbor management address information.
Read:Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemManAddrSubtype, and lldpRemManAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpRemManAddrSubtype (1.0.8802.1.1.2.1.4.2.1.1) |
not-accessible |
As per the MIB. |
lldpRemManAddr (1.0.8802.1.1.2.1.4.2.1.2) |
not-accessible |
LldpManAddress |
As per the MIB. |
lldpRemManAddrIfSubtype (1.0.8802.1.1.2.1.4.2.1.3) |
read-only |
The enumeration value that identifies the port numbering method used for defining the port number associated with the remote system. |
As per the MIB. |
lldpRemManAddrIfId (1.0.8802.1.1.2.1.4.2.1.4) |
read-only |
Integer32 |
As per the MIB. |
lldpRemManAddrOID (1.0.8802.1.1.2.1.4.2.1.5) |
read-only |
OBJECT IDENTIFIER |
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the remote system agent. |
Not supported |
lldpRemUnknownTLVTable
About this table
Use this table to display the unrecognized TLVs received from neighbors.
Read:Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpRemunknownTLVType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpRemUnknownTLVType (1.0.8802.1.1.2.1.4.3.1.1) |
not-accessible |
Integer32 |
Integer32 (9..126) |
TLV type. |
As per the MIB. |
lldpRemUnknownTLVInfo (1.0.8802.1.1.2.1.4.3.1.2) |
read-only |
OCTET STRING |
OCTET STRING (0..511) |
TLV string. |
As per the MIB. |
lldpRemOrgDefInfoTable
About this table
Use this table to display the neighbor organizationally defined information not recognized by the local system.
Read:Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemOrgDefInfoOUI, lldpRemOrgDefInfoSubtype, and lldpRemOrgDefInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpRemOrgDefInfoOUI (1.0.8802.1.1.2.1.4.4.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (3) |
Organizationally Unique Identifier (OUI). |
As per the MIB. |
lldpRemOrgDefInfoSubtype (1.0.8802.1.1.2.1.4.4.1.2) |
not-accessible |
Integer32 |
Integer32 (1..255) |
Subtype of the organizationally defined information. |
As per the MIB. |
lldpRemOrgDefInfoIndex (1.0.8802.1.1.2.1.4.4.1.3) |
not-accessible |
Integer32 |
Index of the organizationally defined information. |
As per the MIB. |
lldpRemOrgDefInfo (1.0.8802.1.1.2.1.4.4.1.4) |
read-only |
OCTET STRING |
OCTET STRING (0..507) |
Organizationally defined information. |
As per the MIB. |
Notifications
lldpRemTablesChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.0.8802.1.1.2.0.0.1 |
LLDP polling is triggered. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the value of the lldpStatsRemTableLastChangeTime object changes. The network management system can use this notification to trigger LLDP polling to facilitate maintaining remote system entries.
You can set the notification transmission interval by configuring the lldpNotificationInterval object.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpPortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpPortConfigNotificationEnable object to false(2).
Object
OID (object name) |
Index |
Type |
Value range |
1.0.8802.1.1.2.1.2.2 (lldpStatsRemTablesInserts) |
Neighbor creation. |
N/A |
1.0.8802.1.1.2.1.2.3 (lldpStatsRemTablesDeletes) |
Neighbor deletion. |
N/A |
1.0.8802.1.1.2.1.2.4 (lldpStatsRemTablesDrops) |
Neighbor discard. |
N/A |
1.0.8802.1.1.2.1.2.5 (lldpStatsRemTablesAgeouts) |
Neighbor ageout. |
N/A |
Recommended action
1.Verify that the topology changes are as expected.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
