- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-VLANTERM-MIB
- 12-HH3C-LswMSTP-MIB
- 13-HH3C-LswVLAN-MIB
- 14-IEEE8021-CFM-MIB
- 15-IEEE8021-CFM-V2-MIB
- 16-IEEE8023-LAG-MIB
- 17-LLDP-EXT-MED-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-MIB
- 24-LLDP-V2-MIB
- 25-MAU-MIB
| 13-HH3C-LswVLAN-MIB | 101.50 KB |
HH3C-LswVLAN-MIB
About this MIB
Use this MIB to configure basic VLAN settings and obtain basic VLAN information.
MIB file name
hh3c-splat-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswVlan(2)
Tabular objects
hh3cdot1qVlanMIBTable
About this table
Use this table to manage and monitor VLANs, create and delete VLANs, and configure and obtain the proprietary VLAN data.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cdot1qVlanIndex, which specifies a VLAN ID. Use this table to create and delete VLANs, configure VLAN attributes, and obtain VLAN data.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qVlanIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.1) |
read-only |
Hh3cVlanIndex |
Integer32 (0..2147483647) |
VLAN index. |
As per the MIB. |
hh3cdot1qVlanName (1.3.6.1.4.1.25506.8.35.2.1.1.1.2) |
read-write |
SnmpAdminString |
OCTET STRING (0..80) |
VLAN name. |
If the VLAN name input starts or ends with spaces, the spaces will be automatically trimmed. The string cannot contain only spaces. If you enter an empty string, the default VLAN description is used. |
hh3cdot1qVlanType (1.3.6.1.4.1.25506.8.35.2.1.1.1.4) |
read-write |
Integer |
superVlan(1) common-vlan(2) sub-vlan(3) isolate-user-vlan(4) secondary-vlan(5) primaryVlan(6) |
VLAN type. |
Not supported |
hh3cdot1qVlanMacFilter (1.3.6.1.4.1.25506.8.35.2.1.1.1.5) |
read-only |
TruthValue |
true(1), false(2) |
MAC VLAN filtering |
Not supported. The default false(2) is displayed. |
hh3cdot1qVlanMcastUnknownProtos (1.3.6.1.4.1.25506.8.35.2.1.1.1.6) |
read-only |
TruthValue |
true(1), false(2) |
Whether to broadcast packets. |
hh3cExistInterface (1.3.6.1.4.1.25506.8.35.2.1.1.1.7) |
read-only |
TruthValue |
true(1), false(2) |
Whether the VLAN has a VLAN interface. |
As per the MIB. |
hh3cVlanInterfaceIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.8) |
read-only |
Integer |
Integer (1..4094) |
Index of the VLAN interface. |
As per the MIB. |
hh3cdot1qVlanMacLearn (1.3.6.1.4.1.25506.8.35.2.1.1.1.9) |
read-only |
TruthValue |
true(1), false(2) |
Whether MAC address learning is supported. |
hh3cdot1qVlanStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.10) |
read-only |
Integer |
other(1), static(2), dynamic(3) |
VLAN state. |
As per the MIB. |
hh3cdot1qVlanCreationTime (1.3.6.1.4.1.25506.8.35.2.1.1.1.11) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Time when the VLAN was created. |
As per the MIB. |
hh3cdot1qVlanPriority (1.3.6.1.4.1.25506.8.35.2.1.1.1.12) |
read-write |
Integer |
Integer
VLAN priority. |
Implementation varies by product. |
hh3cdot1qVlanRowStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.13) |
read-create |
Row-Status |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
VLAN row state. |
Only the following operations are supported:
hh3cdot1qVlanBroadcastSuppression (1.3.6.1.4.1.25506.8.35.2.1.1.1.14) |
read-write |
Integer |
Integer(0..100) |
VLAN broadcast suppression. |
The object can only be read. |
hh3cdot1qVlanPortIndexs (1.3.6.1.4.1.25506.8.35.2.1.1.1.19) |
read-write |
OCTET STRING |
OCTET STRING (0..65535) |
Port index list. |
As per the MIB. |
hh3cVlanInterfaceTable
About this table
Use this table to configure and obtain VLAN interface information.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cdot1qVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVlanInterfaceID (1.3.6.1.4.1.25506.8.35.2.1.2.1.1) |
read-only |
Integer |
Standard MIB values. |
Index. |
As per the MIB. |
hh3cdot1qVlanID (1.3.6.1.4.1.25506.8.35.2.1.2.1.2) |
read-only |
Hh3cVlanIndex |
VLAN ID |
As per the MIB. |
hh3cdot1qVlanIpAddress (1.3.6.1.4.1.25506.8.35.2.1.2.1.3) |
read-write |
IpAddress |
IP address. |
As per the MIB. |
hh3cdot1qVlanIpAddressMask (1.3.6.1.4.1.25506.8.35.2.1.2.1.4) |
read-write |
IpAddress |
IP address and its mask. |
As per the MIB. |
hh3cVlanInterfaceAdminStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.5) |
read-write |
Integer |
up(1), down(2) |
VLAN interface state. |
As per the MIB. |
hh3cVlanInterfaceFrameType (1.3.6.1.4.1.25506.8.35.2.1.2.1.6) |
read-only |
Integer |
ethernet-ii(1), ethernet-snap(2), ethernet-8022(3), ethernet-8023(4) |
Frame type. |
As per the MIB. |
hh3cInterfaceRowStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.7) |
read-create |
RowStatus |
active(1),
Interface row state. |
Available values are active(1), createAndgo(4), and destroy(6).
If an object fails to be configured, this operation fails. As a best practice, use the hh3cInterfaceRowStatus (createAndGo(4)) to create a VLAN interface and configure other attribute objects separately.
hh3cVlanInterfaceIpMethod (1.3.6.1.4.1.25506.8.35.2.1.2.1.8) |
read-write |
Integer |
assigned-ip(1), dhcp-ip(2), bootp-ip(3) |
VLAN interface IP address assignment method. |
hh3cVlanInterfaceIfIndex (1.3.6.1.4.1.25506.8.35.2.1.2.1.9) |
read-only |
Integer |
As per the MIB. |
hh3cVlanInterfaceAddrTable
About this table
Use this table to configure and obtain VLAN interface IP addresses.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cVlanInterfaceIpIfIndex and hh3cVlanInterfaceIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVlanInterfaceIpIfIndex (1.3.6.1.4.1.25506.8.35.2.1.5.1.1) |
read-only |
Integer |
As per the MIB. |
hh3cVlanInterfaceIpAddr (1.3.6.1.4.1.25506.8.35.2.1.5.1.2) |
read-only |
IpAddress |
OCTET STRING (4) |
VLAN interface IP address. |
As per the MIB. |
hh3cVlanInterfaceIpMask (1.3.6.1.4.1.25506.8.35.2.1.5.1.3) |
read-create |
IpAddress |
OCTET STRING (4) |
VLAN Interface IP address mask. |
As per the MIB. |
hh3cVlanInterfaceIpType (1.3.6.1.4.1.25506.8.35.2.1.5.1.4) |
read-create |
Integer |
primary(1), sub(2), cluster(3), vrrp(4) |
VLAN interface IP type. |
As per the MIB. Available values are primary(1) and sub(2). |
hh3cVlanInterfaceIpRowStatus (1.3.6.1.4.1.25506.8.35.2.1.5.1.5) |
read-create |
RowStatus |
Interface IP address row state. |
Available values are active(1), createAndGo(4), and destroy(6). |
hh3cifSuperVlanMappingTable
About this table
Use this table to configure the super VLAN feature and configure and obtain the super VLAN-to-sub VLAN mappings.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cifSuperVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifSuperVlanID (1.3.6.1.4.1.25506.8.35.2.1.7.1.1) |
read-only |
Hh3cVlanIndex |
Super VLAN index. |
Not supported |
hh3cifSubVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.7.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Low bit in the sub VLAN bitmap. |
Not supported |
hh3cifSubVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.7.1.3) |
read-write |
OCTET STRING |
High bit in the sub VLAN bitmap. |
Not supported |
