- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-VLANTERM-MIB
- 12-HH3C-LswMSTP-MIB
- 13-HH3C-LswVLAN-MIB
- 14-IEEE8021-CFM-MIB
- 15-IEEE8021-CFM-V2-MIB
- 16-IEEE8023-LAG-MIB
- 17-LLDP-EXT-MED-MIB
- 18-LLDP-EXT-DOT3-V2-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-MIB
- 24-LLDP-V2-MIB
- 25-MAU-MIB
| 24-LLDP-V2-MIB | 115.24 KB |
LLDP-V2-MIB
About this MIB
This MIB is compliant with IEEE 802.1AB-2009. It defines MIB objects for the following LLDP information:
● LLDP configuration.
● LLDP statistics.
● LLDP local system information.
● LLDP neighbor system information.
● 802.1 extension.
● DCBX extension.
● 802.3 extension.
MIB file name
lldp-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13)
Tabular objects
lldpV2PortConfigTable
About this table
Use this table to configure LLDP on a port.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2PortConfigAdminStatus (1.3.111.2.802.1.1.13.1.1.8.1.3) |
read-write |
INTEGER |
txOnly(1) rxOnly(2) txAndRx(3) disabled(4) |
LLDP operating mode. |
Default: Disabled for the following agents: The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 Ethernet interface. The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 or Layer 3 aggregate interface. The nearest non-TPMR bridge agent on a Layer 3 Ethernet interface. |
lldpV2PortConfigNotificationEnable (1.3.111.2.802.1.1.13.1.1.8.1.4) |
read-write |
TruthValue |
Standard MIB values. |
Trapping status. |
As per the MIB. |
lldpV2PortConfigTLVsTxEnable (1.3.111.2.802.1.1.13.1.1.8.1.5) |
read-write |
BITS |
BITS { portDesc(0), sysName(1), sysDesc(2), sysCap(3) } |
Optional TLVs that the port can send. |
Default: 0xf0 for the following agents: The nearest bridge agent and nearest customer bridge agent on a Layer 2 or Layer 3 Ethernet interface. The nearest customer bridge agent on a Layer 2 aggregate interface. The default is 0x40 for the nearest customer bridge agent on a Layer 3 aggregate interface or S-channel interface. |
lldpV2DestAddressTable
About this table
Use this table to obtain the destination MAC address of LLDP frames.
Edit/Modify:Not supported
Read:Supported
Columns
The table index is lldpV2AddressTableIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2DestMacAddress (1.3.111.2.802.1.1.13.1.1.9.1.2) |
read-only |
MacAddress |
Destination MAC address. |
As per the MIB. |
lldpV2ManAddrConfigTxPortsTable
About this table
Use this table to configure a management address for agents on interfaces.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are lldpV2ManAddrConfigIfIndex, lldpV2ManAddrConfigDestAddressIndex, lldpV2ManAddrConfigLocManAddrSubtype, lldpV2ManAddrConfigLocManAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2ManAddrConfigTxEnable (1.3.111.2.802.1.1.13.1.1.10.1.5) |
read-create |
TruthValue |
Whether the management address TLV is enabled. |
Default: Disabled for the following agents: The nearest bridge agent and nearest customer bridge agent on a Layer 2 or Layer 3 Ethernet interface. The nearest customer bridge agent on a Layer 2 or Layer 3 aggregate interface. |
lldpV2ManAddrConfigRowStatus (1.3.111.2.802.1.1.13.1.1.10.1.6) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
lldpV2StatsTxPortTable
About this table
Use this table to obtain outgoing LLDP packet statistics about agents.
Read:Supported
Columns
The table indexes are lldpV2StatsTxIfIndex and lldpV2StatsTxDestMACAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsTxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.6.1.3) |
read-only |
Counter32 |
Total outgoing frame count. |
As per the MIB. |
lldpV2StatsTxLLDPDULengthErrors (1.3.111.2.802.1.1.13.1.2.6.1.4) |
read-only |
Counter32 |
Frame length error count. |
As per the MIB. |
lldpV2StatsRxPortTable
About this table
Use this table to obtain incoming LLDP packet statistics about agents.
Read:Supported
Columns
The table indexes are lldpV2StatsRxDestIfIndex and lldpV2StatsRxDestMACAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRxPortFramesDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.3) |
read-only |
Counter32 |
Discarded incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortFramesErrors(1.3.111.2.802.1.1.13.1.2.7.1.4) |
read-only |
Counter32 |
Error incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.7.1.5) |
read-only |
Counter32 |
Total incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortTLVsDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.6) |
read-only |
Counter32 |
Discarded incoming TLV count. |
As per the MIB. |
lldpV2StatsRxPortTLVsUnrecognizedTotal (1.3.111.2.802.1.1.13.1.2.7.1.7) |
read-only |
Counter32 |
Unrecognized incoming TLV count. |
As per the MIB. |
lldpV2StatsRxPortAgeoutsTotal (1.3.111.2.802.1.1.13.1.2.7.1.8) |
read-only |
ZeroBasedCounter32 |
Neighbor ageout count. |
As per the MIB. |
lldpV2LocPortTable
About this table
Use this table to obtain LLDP information about local ports.
Read:Supported
Columns
The table index is lldpV2LocPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocPortIdSubtype (1.3.111.2.802.1.1.13.1.3.7.1.2) |
read-only |
LldpV2PortIdSubtype |
Port ID subtype. |
As per the MIB. |
lldpV2LocPortId (1.3.111.2.802.1.1.13.1.3.7.1.3) |
read-only |
LldpV2PortId |
Port ID. |
As per the MIB. |
lldpV2LocPortDesc (1.3.111.2.802.1.1.13.1.3.7.1.4) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Port description. |
As per the MIB. |
lldpV2LocManAddrTable
About this table
Use this table to obtain local management address information.
Read:Supported
Columns
The table indexes are lldpV2LocManAddrSubtype and lldpV2LocManAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocManAddr (1.3.111.2.802.1.1.13.1.3.8.1.2) |
not-accessible |
LldpV2ManAddress |
Management address. |
The subtypes of the management address TLV are IPv4 and IPv6. |
lldpV2LocManAddrLen (1.3.111.2.802.1.1.13.1.3.8.1.3) |
read-only |
Unsigned32 |
Management address length. |
As per the MIB. |
lldpV2LocManAddrIfSubtype (1.3.111.2.802.1.1.13.1.3.8.1.4) |
read-only |
LldpV2ManAddrIfSubtype |
The enumeration value that identifies the port numbering method used for defining the port number associated with the local system. |
As per the MIB. |
lldpV2LocManAddrIfId (1.3.111.2.802.1.1.13.1.3.8.1.5) |
read-only |
Unsigned32 |
Interface index. |
As per the MIB. |
lldpV2LocManAddrOID (1.3.111.2.802.1.1.13.1.3.8.1.6) |
read-only |
OBJECT IDENTIFIER |
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the local system agent. |
Not supported |
Notifications
lldpV2RemTablesChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.111.2.802.1.1.13.0.0.1 |
LLDP polling is triggered. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the value of the lldpV2StatsRemTableLastChangeTime object changes. The network management system can use this notification to trigger LLDP polling to facilitate maintaining remote system entries.
You can set the notification transmission interval by configuring the lldpV2NotificationInterval object.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to false(2).
Object
OID (object name) |
Index |
Type |
Value range |
lldpV2StatsRemTablesInserts (1.3.111.2.802.1.1.13.1.2.2) |
Neighbor creation. |
N/A |
lldpV2StatsRemTablesDeletes (1.3.111.2.802.1.1.13.1.2.3) |
Neighbor deletion. |
N/A |
lldpV2StatsRemTablesDrops (1.3.111.2.802.1.1.13.1.2.4) |
Neighbor discard. |
N/A |
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5) |
Neighbor ageout. |
N/A |
Recommended action
1.Verify that the topology changes are as expected.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
