- H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Confiugration Command
- 07-GVRP Command
- 08-Port Basic Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-DLDP Command
- 12-MAC Address Table Command
- 13-MSTP Command
- 14-Multicast Command
- 15-Routing Protocol Command
- 16-802.1x Command
- 17-AAA-RADIUS-HWTACACS Command
- 18-Centralized MAC Address Authentication Command
- 19-DHCP Command
- 20-ARP Command
- 21-ACL Command
- 22-QoS Command
- 23-Mirroring Command
- 24-Cluster Command
- 25-SNMP and RMON Command
- 26-NTP Command
- 27-SSH Terminal Service Command
- 28-File System Management Command
- 29-FTP and TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Appendix
| 32-VLAN VPN Command | 55 KB |
Chapter 1 VLAN-VPN Configuration Commands
1.1 VLAN-VPN Configuration Commands
1.1.3 vlan-vpn inner-cos-trust
Chapter 2 BPDU Tunnel Configuration Commands
2.1 BPDU TUNNEL Configuration Commands
1.1.1 display port vlan-vpn
View
Parameter
None
Use the display port vlan-vpn command to display the information about VLAN VPN configuration of the current system, including current TPID value, VLAN-VPN ports, and whether or not the inner VLAN tag priority replication function is enabled.
Example
# Display the VLAN-VPN configuration of the current system.
<H3C> display port vlan-vpn
Ethernet1/0/1
VLAN-VPN TPID: 8100
Ethernet1/0/2
VLAN-VPN status: enabled
VLAN-VPN VLAN: 1
VLAN-VPN inner-cos-trust status: disable
VLAN-VPN TPID: 8100
Ethernet1/0/3
VLAN-VPN TPID: 8100
Ethernet1/0/4
VLAN-VPN TPID: 8100
(Omitted)
1.1.2 vlan-vpn enable
vlan-vpn enable
undo vlan-vpn
View
Ethernet port view
Parameter
None
Use the vlan-vpn enable command to enable the VLAN-VPN function for a port.
Use the undo vlan-vpn command to disable the VLAN-VPN function for a port.
By default, the VLAN-VPN function is disabled.
With the VLAN VPN function enabled, a received packet is tagged with the default VLAN tag of the receiving port no matter whether or not the packet already carries a VLAN tag. If the packet already carries a VLAN tag, the packet becomes a dual-tagged packet. Otherwise, the packet becomes a packet carrying the default VLAN tag of the port.
Caution:
l The VLAN-VPN function is unavailable if the port has any of the protocols among GARP VLAN registration protocol (GVRP), spanning tree protocol (STP), neighbor topology discovery protocol (NTDP), 802.1x, and centralized MAC address authentication function enabled.
l After you enable the VLAN-VPN function for a port, you cannot change the attribute of the port to trunk or hybrid, or enable GVRP, STP, NTDP, 802.1x, and centralized MAC address authentication function for the port.
Example
# Enable the VLAN-VPN function for Ethernet1/0/1 port.
<H3C> system-view
[H3C]interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] vlan-vpn enable
vlan-vpn inner-cos-trust enable
undo vlan-vpn inner-cos-trust
View
Parameter
None
Use the vlan-vpn inner-cos-trust enable command to enable the inner tag priority replication function.
Use the undo vlan-vpn inner-cos-trust command to disable the inner tag priority replication function.
By default, the inner tag priority replication function is disabled.
Example
# Enable the inner tag priority replication function for the Ethernet 1/0/2 port.
<H3C> system-view
[H3C] interface Ethernet 1/0/2
[H3C-Ethernet1/0/2] vlan-vpn inner-cos-trust enable
1.1.4 vlan-vpn tpid
vlan-vpn tpid value
undo vlan-vpn tpid
View
Ethernet port view
Parameter
value: User-defined TPID value (in hexadecimal format), in the range 1 to 0xFFFF.
Use the vlan-vpn tpid command to set a TPID value for a port.
Use the undo vlan-vpn tpid command to restore the default TPID value.
The default TPID value is 0x8100.
The position of the TPID field in an Ethernet packet is the same as the position of the protocol type field in a packet without VLAN Tag. Thus, to avoid confusion happening when the switch forwards or receives a packet, do not configure the protocol type values listed in Table 1-1 as the TPID value.
Table 1-1 Common Ethernet frame protocol type values
Protocol type |
Value |
ARP |
0x0806 |
IP |
0x0800 |
MPLS |
0x8847/0x8848 |
IPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
802.1x |
0x888E |
Example
# Set the TPID value to 0x12 for Ethernet1/0/2 port.
<H3C> system-view
[H3C-Ethernet1/0/2] vlan-vpn tpid 12
2.1.1 bpdu-tunnel
bpdu-tunnel { lacp | ndp | cdp | vtp }
undo bpdu-tunnel { lacp | ndp | cdp | vtp | all }
View
Ethernet port view
Parameter
lacp: Enables/Disables BPDU Tunnel function for LACP (link aggregation control protocol) packets.
ndp: Enables/Disables BPDU Tunnel function for NDP (neighbor discovery protocol) packets.
cdp: Enables/Disables BPDU Tunnel function for CDP (Cisco discovery protocol) packets.
vtp: Enables/Disables BPDU Tunnel function for VTP (virtual terminal protocol) packets.
all: Disables the BPDU Tunnel function for the packets of all the above-mentioned protocols.
Use the bpdu-tunnel command to enable the BPDU Tunnel function for the packets of a specific protocol. You can enable the function for the packets of these protocols: LACP, NDP, CDP, and VTP.
Use the undo bpdu-tunnel command to disable the BPDU Tunnel function for the packets of a specified protocol or all the above-mentioned protocols.
Caution:
l If you enable the BPDU Tunnel function for packets of a protocol on a port, don’t enable the protocol on port. For example, with the bpdu-tunnel lacp command executed, do not execute the lacp enable command on the same port.
l To ensure BPDU packets travel across a tunnel properly, specify the same keyword for the bpdu-tunnel command when executing the command on the both sides of the tunnel.
Example
# Enable the BPDU Tunnel function for LACP packets.
<H3C> system-view
[H3C-Ethernet1/0/1] bpdu-tunnel lacp
2.1.2 bpdu-tunnel uplink
bpdu-tunnel uplink [ interface interface-list ]
View
System view, Ethernet port view
Parameter
interface interface-list: Specifies lists of Ethernet ports. To specify multiple Ethernet ports, you need to provide the interface-list argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> means that you can specify up to ten port indexes/port index lists at one time. This argument is unavailable in Ethernet port view.
Use the bpdu-tunnel uplink command to configure an Ethernet port or multiple Ethernet ports as uplink BPDU Tunnel ports. A device listens to its uplink BPDU Tunnel ports and picks out the Layer 2 protocol packets that reach the ports.
Example
# Configure Ethernet1/0/1 through Ethernet1/0/5 ports as uplink BPDU Tunnel ports.
<H3C> system-view
[H3C] bpdu-tunnel uplink Ethernet 1/0/1 to Ethernet 1/0/5
