H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
HomeSupportSwitchesH3C S3100 Switch SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
31-System Maintenance and Debugging Command
31-System Maintenance and Debugging Command 164 KB
Chapter 1  Basic System Configuration & Debugging Commands
1.1  Basic System Configuration Commands
1.1.1  clock datetime
clock datetime HH:MM:SS { YYYY/MM/DD | MM/DD/YYYY }
View
Parameter
HH:MM:SS: Current time, where HH ranges from 0 to 23, MM and SS range from 0 to 59.
YYYY/MM/DD or MM/DD/YYYY: Current date, where YYYY is the year ranging from 2000 to 2099, MM is the month ranging from 1 to 12, and DD is the day ranging from 1 to 31.
Use the clock datetime command to set the current date and time of the Ethernet switch.
By default, it is 23:55:00 04/01/2000 when the system starts up.
In an environment that needs to obtain exact absolute time, it is required to use this command to set the current date and time of the Ethernet switch.
Related command: display clock.
Example
# Set the current date and time of the Ethernet switch to 0:0:0 2001/01/01.
<H3C> clock datetime 0:0:0 2001/01/01
1.1.2  clock summer-time
clock summer-time zone-name { one-off | repeating } start-time start-date end-time end-date offset-time
undo clock summer-time
View
Parameter
zone-name: Name of the summer time, a string of 1 to 32 characters.
one-off: Sets the summer time for only one year (the specified year).
repeating: Sets the summer time for every year starting from the specified year.
start-time: Start time of the summer time, in the form of HH:MM:SS.
start-date: Start date of the summer time, in the form of YYYY/MM/DD or MM/DD/YYYY.
end-time: End time of the summer time, in the form of HH:MM:SS.
end-date: end date of the summer time, in the form of YYYY/MM/DD or MM/DD/YYYY.
offset-time: Offset of the summer time relative to the standard time, in the form of HH:MM:SS.
Use the clock summer-time command to set the name, time range and time offset of the summer time.
After the setting, you can use the display clock command to check the results.
Example
# Set the summer time named abc1, which starts from 06:00:00 2005/08/01, ends until 06:00:00 2005/09/01, and is one hour ahead of the standard time.
<H3C> clock summer-time abc1 one-off 06:00:00 08/01/2005 06:00:00 09/01/2005 01:00:00
# Set the summer time named abc2, which starts from 06:00:00 08/01, ends until 06:00:00 09/01, and is one hour ahead of the standard time every year from 2005 on.
<H3C> clock summer-time abc2 repeating 06:00:00 08/01/2005 06:00:00 09/01/2005 01:00:00
1.1.3  clock timezone
clock timezone zone-name { add | minus } HH:MM:SS
undo clock timezone
View
Parameter
zone-name: Name of the time zone, in length of 1 to 32 characters.
add: Sets the time zone to a time before the UTC time.
minus: Sets the time zone to a time behind the UTC time.
HH:MM:SS: Time to be subtracted from the UTC time, in the form of HH:MM:SS.
Use the clock timezone command to set the local time zone.
Use the undo clock timezone command to restore the local time zone to the default UTC (universal time coordinated) time zone.
After the setting, you can use the display clock command to check the results. The log information time and the debug information time adopts the local time that has been adjusted by the time zone and the summer time.
Related command: clock summer-time and display clock.
Example
# Set the local time zone named z5, which is five hours ahead of the UTC time.
<H3C> clock timezone z5 add 05:00:00
1.1.4  language-mode
language-mode { chinese | english }
View
Parameter
chinese: Sets the CLI language environment to Chinese.
English: Sets the CLI language environment to English.
Use the language-mode command to toggle between the language modes (that is, language environments) of the command line interface (CLI) to meet your requirement.
By default, the CLI language mode is english.
Example
# Toggle from the english mode to the chinese mode.
<H3C> language-mode chinese
1.1.5  quit
View
Parameter
None
Use the quit command to return from current view to lower level view, or exit the system if current view is user view.
The following lists the three levels of views available (from lower level to higher level):
l           User view
l           System view
l           VLAN view, Ethernet port view, and so on
Related command: return and system-view.
Example
# Return from system view to user view.
<H3C> system-view
[H3C] quit
<H3C>
1.1.6  return
return
View
System view and higher level views
Parameter
None
Use the return command to return from current view to user view. The composite key <Ctrl+Z> has the same effect with the return command.
Related command: quit.
Example
# Return from interface view to user view.
<H3C> system-view
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] return
<H3C>
1.1.7  sysname
sysname sysname
undo sysname
View
Parameter
sysname: System name of the Ethernet switch. It is a character string in length of 1 to 30 characters. By default, it is H3C.
Use the sysname command to set the system name of the Ethernet switch. Changing the system name will affect the CLI prompt. For example, if the system name of the switch is H3C, the prompt for user view is <H3C>.
Use the undo sysname command to restore the default system view of the Ethernet switch.
Example
# Set the system name of the Ethernet switch to H3CLANSwitch.
<H3C> system-view
[H3C] sysname H3CLANSwitch
[H3CLANSwitch]
1.1.8  system-view
View
Parameter
None
Use the system-view command to enter system view from user view.
Related command: quit and return.
Example
# Enter system view from user view.
<H3C> system-view
[H3C]
1.2  System Status/Information Display Commands
1.2.1  display clock
display clock
View
Parameter
None
Use the display clock command to display the current date and time of the system, so that you can adjust them if they are wrong.
The maximum date and time that can be displayed by this command is 23:59:59 9999/12/31.
Related command: clock datetime.
Example
# Display the current date and time of the system.
<H3C> display clock
18:36:31 beijing Sat 2002/02/02
Time Zone : beijing add 01:00:00
Summer-Time : bj one-off 01:00:00 2003/01/01 01:00:00 2003/08/08 01:00:00
Table 1-1 Description on the fields of the display clock command
Current date and time of the system
Time Zone
Configured time zone information
Summer-Time
Configured summer time information
1.2.2  display debugging
display debugging [ unit unit-id ] [ interface interface-type interface-number ] [ module-name ]
View
Parameter
unit-id: Unit ID of a switch.
interface-type: Interface type.
interface-number: Interface number.
module-name: Functional module name.
Use the display debugging command to display enabled debugging on a specified device. Executing this command without any parameter will display all enabled debugging.
Related command: debugging.
Example
# Display enabled debugging on unit 1.
<H3C> display debugging unit 1
IP packet debugging is on
IP icmp debugging is on
1.2.3  display users
display users [ all ]
View
Parameter
all: Displays the information about all user terminal interfaces.
Use the display users command to display the status and configuration information about user terminal interfaces.
Example
# Display the status and configuration information about user terminal interfaces.
<H3C> display users
        UI    Delay     Type   Ipaddress       Username        Userlevel
  0   AUX 0   00:00:17                                             3
  8   VTY 0   01:37:55  TEL    192.168.0.200                       3
+ 9   VTY 1   00:00:00  TEL    192.168.0.3                         3
  12  VTY 4   00:00:00  TEL    192.168.0.115                       3
 +   : Current operation user.
 F   : Current operation user work in async mode.
Table 1-2 Description on the output user terminal interface information
Item
UI
User interface
Delay
Delay time when no interaction occurs between user and device
User login type
Ipaddress
IP address used when login using telnet program
Username
User name
User level
User level
1.2.4  display version
display version
View
Parameter
None
Use the display version command to display the information (such as the version information) about the switch system.
Specifically, you can use this command to check the software version and issue time, the basic hardware configuration, and some other information about the switch.
Example
# Display the version of the system.
<H3C> display version
H3C Comware Platform Software.
Comware software, Version 3.10, Release 1500
Copyright(c) 2004-2007 Hangzhou H3C Technologies. Co., Ltd. All rights reserved.
H3C S3100-52P uptime is 0 week, 0 day, 15 hours, 20 minutes
H3C S3100-52P with 1 MIPS Processor
64M     bytes DRAM
8196K   bytes Flash Memory
Config Register points to FLASH
Hardware Version is REV.C
CPLD Version is CPLD 001
Bootrom Version is 101
[Subslot 0] 48 FE Hardware Version is REV.C
[Subslot 1] 4 GE  Hardware Version is REV.C
1.3  System Debugging Commands
1.3.1  debugging
debugging module-name [ debugging-option ]
undo debugging { all | module-name [ debugging-option ] }
View
Parameter
module-name: Module name.
debugging-option: Debugging option.
all: Used to disable all debugging.
Use the debugging command to enable system debugging.
Use the undo debugging command to disable system debugging.
By default, all debugging is disabled for the system.
Enabling debugging will generate a great deal of debugging information and thus will affect the efficiency of the system. Therefore, it is recommended not to enable debugging for multiple functional modules at the same time. The undo debugging all command brings great convenience for you to disable all debugging at a time instead of disabling them one by one.
Related command: display debugging.
Example
# Enable IP packet debugging.
<H3C> debugging ip packet
IP packet debugging switch is on.
The above command output indicates that the IP packet debugging is enabled.
1.3.2  display diagnostic-information
View
Parameter
None
Use the display diagnostic-information command to display system diagnostic information, or save system diagnostic information to a file suffixed with diag in the Flash memory.
Example
# Save system diagnostic information to the file default.diag.
<H3C> display diagnostic-information
This operation may take a few minutes, continue?[Y/N]y
 Diagnostic-information is saved to Flash or displayed(Y=save N=display)?[Y/N]y
 Please input the file name(*.diag)[flash:/default.diag]:
% Output information to file: flash:/default.diag.
Please wait......
# Display the current diagnostic information of the system.
 Diagnostic-information is saved to Flash or displayed(Y=save N=display)?[Y/N]n
-------------------- display version --------------------
<Omitted>
1.3.3  terminal debugging
terminal debugging
undo terminal debugging
View
Parameter
None
Use the terminal debugging command to enable terminal display for debugging information.
Use the undo terminal debugging command to disable terminal display for debugging information.
By default, terminal display for debugging information is disabled.
Example
# Enable terminal display for debugging information.
<H3C> terminal debugging
Chapter 2  Network Connectivity Test Commands
2.1.1  ping
ping [ -a ip-address ] [-c count ] [ -d ] [ -f ] [ -h ttl ] [ -i interface-type interface-number [ ip ] [ -n ] [ - p pattern ] [ -q ] [ -s packetsize ] [ -t timeout ] [ -tos tos ] [ -v ] host
View
Parameter
-a ip-address: Sets the source IP address to send the ICMP ECHO-REQUEST packets.
-c count: Specifies how many times the ICMP ECHO-REQUEST packet will be sent. The count argument is the times, which ranges from 1 to 4,294,967,295 and defaults to 5.
-d: Sets the socket to DEBUGGING mode. By default, it is non-DEBUGGING mode.
-f: Specifies to discard a packet directly instead of fragmenting it if its length is greater than the MTU (maximum transmission unit) of the interface.
-h ttl: Sets the TTL (time to live) value of the ICMP ECHO-REQUEST packets in the range of 1 to 255. By default, the TTL value is 255.
-i: Selects the port to send the packets.
ip: Selects the IP ICMP packet.
-n: Specifies to regard the host argument as an IP address without performing domain name resolution. By default, the host argument is first regarded as an IP address; if it is not an IP address, domain name resolution is performed.
-p pattern: Specifies the padding byte pattern of the ICMP ECHO-REQUEST packets. The pattern argument is a byte in hexadecimal. For example, -p ff fills a packet with only ff. By default, the system fills a packet with 0x01, 0x02, and so on, until 0x09; then it repeats this procedure from 0x01 again.
-q: Specifies to display only the statistics and not to display the details. By default, all the information including the details and statistics will be displayed.
-s packetize: Specifies the size (in bytes) of each ICMP ECHO-REQUEST packet (excluding the IP and ICMP headers). The packetize argument ranges from 20 to 32,000 and defaults to 56 bytes.
-t timeout: Sets the timeout time (in ms) waiting for an ICMP ECHO-REPLY packet after an ICMP ECHO-REQUEST packet is sent. The timeout argument ranges from 0 to 65535 and defaults to 2,000 ms.
-tos tos: Sets the ToS value of the ICMP ECHO-REQUEST packets in the range of 0 to 255. By default, this value is 0.
-v: Specifies to display other ICMP packets received (that is, non-ECHO-REPLY packets) as well as the ECHO-REPLY packets. By default, except for the ECHO-REPLY packets, other ICMP packets are not displayed.
host: Domain name or IP address of the destination host.
Use the ping command to check the IP network connectivity and the reachability of a host.
The executing procedure of the ping command is as follows: First, the source host sends an ICMP ECHO-REQUEST packet to the destination host. If the connection to the destination network is normal, the destination host receives this packet and responds with an ICMP ECHO-REPLY packet.
You can use the ping command to check the network connectivity and the quality of a network line. This command can output the following information:
l           Response status of the destination to each ICMP ECHO-REQUEST packet. If no response packet is received within the timeout time, including the number of bytes, packet sequence number, TTL and response time of the response packet. If no response packet is received within the timeout time, the message "Request time out" is displayed instead.
l           Final statistics, including the numbers of sent packets and received response packets, the irresponsive packet percentage, and the minimum, average and maximum values of response time.
You can set a relatively long timeout time waiting for response packet if the network transmission is slow.
Related command: tracert.
Example
# Check the reachability of the host with IP address 202.38.160.244.
<H3C> ping 202.38.160.244
ping 202.38.160.244 : 56 data bytes
Reply from 202.38.160.244 : bytes=56 sequence=1 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=2 ttl=255 time = 2ms
Reply from 202.38.160.244 : bytes=56 sequence=3 ttl=255 time = 1ms
Reply from 202.38.160.244 : bytes=56 sequence=4 ttl=255 time = 3ms
Reply from 202.38.160.244 : bytes=56 sequence=5 ttl=255 time = 2ms
--202.38.160.244 ping statistics--
5 packet transmitted
5 packet received
0% packet loss
round-trip min/avg/max = 1/2/3 ms
2.1.2  tracert
tracert [ -a source-ip ] [ -f first-ttl ] [ -m max-ttl ] [ -p port ] [ -q num-packet ] [ -w timeout ] string
View
Parameter
-a source-ip: Sets the source IP address used by this command.
-f first-ttl: Sets the initial TTL of the packets to be sent, so that this command displays the addresses of only those gateways on the path whose hop counts are not smaller than the hop count specified by the first-ttl argument. For example, if the first-ttl argument is three, the command displays the addresses of the gateways from the third hop The first-ttl argument ranges from 1 to 255 and defaults to 1.
-m max-ttl: Sets the maximum TTL value of the packets to be sent. After the command sends a packet with the maximum TTL, it will not send any more packets. With this argument, this command displays the addresses of only those gateways from the source destination to the hop count specified by the argument. For example, if the max-ttl argument is 5, the command displays the addresses of the gateways from the source to the fifth count. The max-ttl argument ranges from 1 to 255 and defaults to 30.
-p port: Sets the destination port of the packets to be sent. The port argument ranges from 0 to 65535 and defaults to 33434. Generally, you need not change the argument.
-q num-packet: Sets the number of packets to be sent every time. The nqueries argument ranges from 0 to 65,535 and defaults to 3.
-w timeout: Sets the timeout time to wait for ICMP error packets. The timeout argument ranges from 0 to 65,535 and defaults to 5,000 (in milliseconds).
string: IP address of the destination host, or host name of the remote system with 1 to 20 characters.
Use the tracert command to trace the gateways the test packets passes through during its journey from the source to the destination. This command is mainly used to check the network connectivity. It can help you locate the trouble spot of the network.
The executing procedure of the tracert command is as follows: First, the source sends a packet with the TTL of 1, and the first hop device returns an ICMP error message indicating that it cannot forward this packet because of TTL timeout. Then, the source resends a packet with the TTL of 2, and the second hop device also returns an ICMP TTL timeout message. This procedure goes on and on until a packet gets to the destination or the maximum TTL is reached. During the procedure, the system records the source address of each ICMP TTL timeout message in order to offer the path that the packets pass through to the destination.
If you find that the network is in trouble by using the ping command, you can use the tracert command to find where the trouble is in the network.
The tracert command can output the IP addresses of all the gateways the packets pass through to the destination. It output the string "***" if a gateway times out.
Example
# Trace the gateways the packets pass through during its journey to the destination with IP address 18.26.0.115.
<H3C> tracert 18.26.0.115
tracert to allspice.lcs.mit.edu (18.26.0.115), 30 hops max
1 helios.ee.lbl.gov (128.3.112.1) 0 ms 0 ms 0 ms
2 lilac-dmc.Berkeley.EDU (128.32.216.1) 19 ms 19 ms 19 ms
3 lilac-dmc.Berkeley.EDU (128.32.216.1) 39 ms 19 ms 19 ms
4 ccngw-ner-cc.Berkeley.EDU (128.32.136.23) 19 ms 39 ms 39 ms
5 ccn-nerif22.Berkeley.EDU (128.32.168.22) 20 ms 39 ms 39 ms
6 128.32.197.4 (128.32.197.4) 59 ms 119 ms 39 ms
7 131.119.2.5 (131.119.2.5) 59 ms 59 ms 39 ms
8 129.140.70.13 (129.140.70.13) 80 ms 79 ms 99 ms
9 129.140.71.6 (129.140.71.6) 139 ms 139 ms 159 ms
10 129.140.81.7 (129.140.81.7) 199 ms 180 ms 300 ms
11 129.140.72.17 (129.140.72.17) 300 ms 239 ms 239 ms
12 * * *
13 128.121.54.72 (128.121.54.72) 259 ms 499 ms 279 ms
14 * * *
15 * * *
16 * * *
17 * * *
18 ALLSPICE.LCS.MIT.EDU (18.26.0.115) 339 ms 279 ms 279 ms
Chapter 3  Device Management Commands
3.1  Device Management Commands
3.1.1  boot boot-loader
boot boot-loader [ backup-attribute ] { file-url | device-name }
View
Parameter
backup-attribute: Sets the specified file to a backup file.
file-url: Path + name of an host software file in the Flash memory.
device-name: File name, in the form of unit[NO.]>flash:, which is used to save the specified file to the Flash memory of a specified switch.
Use the boot boot-loader command to specify the host software that will be adopted when the switch reboots next time.
You can use this command to specify a .bin file in the Flash memory as the host software to be adopted at reboot.
Example
# Specify the host software that will be adopted when the current switch reboots next time.
<H3C> boot boot-loader s3100-52P.bin
The specified file will be booted next time on unit 1!
3.1.2  boot bootrom
boot bootrom { file-url | device-name }
View
Parameter
file-ulr: Path + name of a BootROM file (that is, a .btm file) in the Flash memory.
device-name: File name, beginning with a device name in the form of unit[NO.]>flash, used to save the specified file to the Flash memory of a specified switch.
Use the boot bootrom command to update the BootROM.
Example
# Update the BootROM of the switch using the file named S3100-52P.btm.
<H3C> boot bootrom S3100-52P.btm
3.1.3  display boot-loader
display boot-loader
View
Parameter
None
Use the display boot-loader command to display the host software (.bin file) that will be adopted when the switch reboots.
Example
# Display the host software that will be adopted when the switch reboots.
<H3C>display boot-loader
Unit 1:
   The current boot app is: s3100-52p.bin
   The main boot app is:    s3100-52p.bin
   The backup boot app is:  s3100-52p.bin
Table 3-1 Description on the fields of the display boot-loader command
Current boot file of the system
Main boot file of the system (default boot file)
Backup boot file of the system
3.1.4  display cpu
display cpu [ unit unit-id ]
View
Parameter
Use the display cpu command to display the CPU usage of a specified switch.
Example
# Display the CPU usage of this switch.
<H3C> display cpu
Unit 1
Board 0 CPU busy status:
    12% in last 5 seconds
    12% in last 1 minute
    12% in last 5 minutes
Table 3-2 Description on the fields of the display cpu command
CPU busy status
Indicates that the following lines describe the CPU occupancies in different time periods.
The CPU usage in the last five seconds is 12%.
The CPU usage in the last one minute is 12%.
The CPU usage in the last five minutes is 12%.
3.1.5  display device
display device [ manuinfo [ unit unit-id ] | unit unit-id ]
View
Parameter
manuinfo: Displays the manufacture information of the specified switch.
Use the display device command to display the information, such as the module type and operating status, about each board (main board and sub board) of a specified switch.
You can use this command to display the following information about each board: slot number, sub slot number, number of ports, versions of PCB, FPGA, CPLD and BootROM software, address learning mode, interface board type, and so on.
Example
# Display board information of this switch.
<H3C> display device
Unit 1
SlotNo SubSNo PortNum PCBVer FPGAVer CPLDVer BootRomVer AddrLM Type       State
0      0      48      REV.C  NULL    001     101        IVL    MAIN       Normal
0      1      4       REV.C  NULL    001     NULL       IVL    4 GE       Normal
3.1.6  display fan
display fan [ unit unit-id [ fan-id ] ]
View
Parameter
fan-id: ID number of a fan.
Use the display fan command to view the working state of the built-in fans.
Example
# Display the working state of the fans.
<H3C> display fan
Unit 1
 Fan  1 State: Normal
The above information indicates that fan work normally.
3.1.7  display memory
display memory [ unit unit-id ]
View
Parameter
Use the display memory command to display the memory usage of a specified switch.
Example
# Display the memory usage of this switch.
<H3C> display memory
Unit 1
System Available Memory(bytes): 36191232
System Used Memory(bytes): 13143716
Used Rate: 36%
Table 3-3 Description on the fields of the display memory command
Available memory size of the system, in unit of bytes
Used memory size of the system, in unit of bytes
Used Rate
Percentage of the used memory
3.1.8  display power
display power [ unit unit-id [ power-id ] ]
View
Parameter
power-id: Power ID.
Use the display power command to view the working state of the power supply of the switch.
Example
# Display the working state of the power supply.
<H3C> display power
Unit 1
  power    1
  State    : Normal
  Type     : AC
The above information indicates that the type of the power is AC, and the power supplies normally.
3.1.9  display schedule reboot
View
Parameter
None
Use the display schedule reboot command to display information about scheduled reboot.
Related command: reboot, schedule reboot at.
Example
# Display the information about scheduled reboot.
<H3C> display schedule reboot
System will reboot at 16:00:00 2002/11/1 (in 2 hours and 5 minutes).
3.1.10  reboot
reboot [ unit unit-id ]
View
Parameter
Use the reboot command to restart a specified Ethernet switch.
&  Note:
When rebooting, the system checks whether there is any configuration change. If there is, it prompts you to indicate whether or not to proceed. This prevents you from losing your original configuration due to oblivion after system reboot.
Example
# Directly restart this switch without saving the current configuration.
<H3C> reboot
Start to check configuration with next startup configuration file,
 please wait......
 This command will reboot the device. Current configuration may be lost in next
startup if you continue.   Continue? [Y/N] y
 This will reboot device. Continue? [Y/N] y
<H3C>
%Apr  1 23:57:58:685 2000 H3C DEV/5/DEV_LOG:- 1 -
Switch is rebooting...
Starting......
3.1.11  schedule reboot at
schedule reboot at hh:mm [ mm/dd/yyyy | yyyy/mm/dd ]
undo schedule reboot
View
Parameter
hh:mm: Reboot time, where hh (hour) ranges from 0 to 23, and mm (minute) ranges from 0 to 59.
mm/dd/yyyy or yyyy/mm/dd: Reboot date, where yyyy (year) ranges from 2,000 to 2,099, mm (month) ranges from 1 to 12, and the range of dd (day) depends on the specific month. You cannot set the date later than 30 days than the system current date.
Use the schedule reboot at command to schedule a reboot on the current switch and set the reboot date and time.
Use the undo schedule reboot command to cancel the scheduled reboot.
By default, no scheduled reboot is set on the switch.
&  Note:
There is at most one minute defer for scheduled reboot, that is, the switch will reboot within one minute after reaching the specified reboot date and time.
After you execute the schedule reboot at command with a future date specified, the switch will reboot at the specified time with at most one minute delay.
After you execute the schedule reboot at command without specifying a date, the switch will:
l           Reboot at the specified time on the current day if the specified time is later than the current time.
l           Reboot at the specified time on the next day if the specified time is earlier than the current time.
After you execute the command, the system will prompt you to confirm. Enter "Y" or "y" for your setting to take effect, and your setting will overwrite the old one (if available).
If you adjust the system time by the clock command after executing the schedule reboot at command, the schedule reboot at command will be invalid and the scheduled reboot will not happen.
Related command: reboot, display schedule reboot.
Example
# Suppose the current time is 05:06, schedule a reboot so that the switch reboots at 22:00 on the current day.
<H3C> schedule reboot at 22:00
Reboot system at 22:00 2000/04/02(in 16 hours and 53 minutes)
confirm?[Y/N]:y
<H3C>
3.1.12  schedule reboot delay
schedule reboot delay { hh:mm | mm }
View
Parameter
hh:mm: Reboot waiting delay, where hh ranges from 0 to 720, and mm ranges from 0 to 59.
mm: Reboot waiting delay, ranging from 0 to 43,200 minutes.
Use the schedule reboot delay command to schedule a reboot on the switch, and set the reboot waiting delay.
&  Note:
There is at most one minute defer for scheduled reboot, that is, the switch will reboot within one minute after waiting for the specified delay.
You can set the reboot waiting delay in two formats: the hours:minutes format and the absolute minutes format, and both must be less than or equal to 30 × 24 × 60 (that is, 30 days).
After you execute the command, the system will prompt you to confirm. Enter "Y" or "y" for your setting to take effect. Your setting will overwrite the old one (if available).
If you adjust the system time by the clock command after executing the schedule reboot delay command, the schedule reboot delay command will be invalid and the scheduled reboot will not happen.
Related command: reboot, schedule reboot at, undo schedule reboot, and display schedule reboot.
Example
# Suppose the current time is 05:02, schedule a reboot so that the switch reboots after 70 minutes.
<H3C> schedule reboot delay 70
Reboot system at 06:12 2000/04/02(in 1 hours and 10 minutes)
confirm?[Y/N]:y
<H3C>
3.1.13  schedule reboot regularity
schedule reboot regularity at hh:mm period
undo schedule reboot regularity
View
Parameter
hh:mm: Reboot time of the switch, in the hours:minutes format, where hh ranges from 0 to 24, and mm ranges from 0 to 59.
period: Reboot period of the switch, in the format period = { daily | { monday | tuesday | wednesday | thursday | friday | saturday | sunday }* }. daily indicates the reboot period is one day, that is, the switch reboots at a specified time each day. { monday | tuesday | wednesday | thursday | friday | saturday | sunday }* indicates the day when the switch reboots.
Use the schedule reboot regularity command to enable the periodical reboot function of the switch and set the reboot time.
Use the undo schedule reboot regularity command to cancel the configured reboot period.
By default, the reboot period of the switch is not configured.
&  Note:
If you adjust the system time by the clock command after executing the schedule reboot regularity command, the schedule reboot regularity command will be invalid.
Example
# Schedule a reboot so that the switch reboots at 10:00 every Thursday.
<H3C> system-view
[H3C] schedule reboot regularity at 10:00 thursday
Schedule reboot regularity, are you sure?[Y/N]:y
[H3C]
