- H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Confiugration Command
- 07-GVRP Command
- 08-Port Basic Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-DLDP Command
- 12-MAC Address Table Command
- 13-MSTP Command
- 14-Multicast Command
- 15-Routing Protocol Command
- 16-802.1x Command
- 17-AAA-RADIUS-HWTACACS Command
- 18-Centralized MAC Address Authentication Command
- 19-DHCP Command
- 20-ARP Command
- 21-ACL Command
- 22-QoS Command
- 23-Mirroring Command
- 24-Cluster Command
- 25-SNMP and RMON Command
- 26-NTP Command
- 27-SSH Terminal Service Command
- 28-File System Management Command
- 29-FTP and TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Appendix
| 00-1Cover | 329 KB |
H3C S3100-52P Ethernet Switch |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08194N-20070410-C-1.01 Product Version: Release 1500 |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3100-52P Ethernet Switch documentation set includes the following:
Manual |
H3C S3100-52P Ethernet Switch Installation Manual |
It provides information for the system installation and setup. |
H3C S3100-52P Ethernet Switch Operation Manual-Release 1500 |
It is used for assisting the users in device configurations and typical applications. |
Organization
H3C S3100-52P Ethernet Switch Command Manual is organized as follows:
Part |
Contents |
1 CLI |
Introduces the commands used for switching between the command levels and command level setting. |
2 Login |
Introduces the commands used for logging into the Ethernet switch. |
| 3 Configuration File Management |
Introduces the commands used for manipulating the configuration files. |
4 VLAN |
Introduces the commands used for configuring VLANs. |
| 5 IP Address and Performance Confiugration |
Introduces the commands used for configuring IP addresses and IP performance. |
6 Access Management |
Introduces the commands used for access management. |
7 GVRP |
Introduces the GVRP-related commands. |
8 Port Basic Configuration |
Introduces the basic port configuration commands. |
9 Link Aggregation |
Introduces the commands used for link aggregation. |
10 Port Isolation |
Introduces the commands used for port isolation. |
11 DLDP |
Introduces the DLDP-related commands. |
12 MAC Address Table |
Introduces the commands used for MAC address forwarding table management. |
13 MSTP |
Introduces the STP-related commands. |
14 Multicast |
Introduces the commands used for multicast protocol configuration. |
15 Routing Protocol |
Introduces the commands used for routing protocol configuration. |
16 802.1x |
Introduces the 802.1x-related commands. |
17 AAA-RADIUS-HWTACACS |
Introduces the commands used for the configuration of AAA, RADIUS, and HWTACACS. |
18 Centralized MAC Address Authentication |
Introduces the commands used for centralized MAC address authentication. |
19 DHCP |
Introduces the commands used for DHCP-Snooping. |
20 ARP |
Introduces the ARP-related commands. |
21 ACL |
Introduces the ACL-related commands. |
22 QoS |
Introduces the QoS-related commands. |
23 Mirroring |
Introduces the commands used for port mirroring. |
24 Cluster |
Introduces the commands used for cluster management. |
25 SNMP and RMON |
Introduces the commands used for SNMP and RMON configuration. |
26 NTP |
Introduces the NTP-related commands. |
27 SSH Terminal Service |
Introduces the commands used for configuring SSH2.0. |
28 File System Management |
Introduces the commands used for file system management. |
29 FTP and TFTP |
Introduces the FTP /TFTP related commands. |
30 Information Center |
Introduces the commands used for configuring the information center. |
31 System Maintenance and Debugging |
Introduces the commands used for system maintenance and debugging. |
32 VLAN VPN |
Introduces the VLAN VPN-related commands. |
33 HWPing |
Introduces the HWPing-related commands. |
34 DNS |
Introduces the commands used for domain name resolution. |
35 Appendix |
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
A line starting with the # sign is comments. |
II. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
