- H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Confiugration Command
- 07-GVRP Command
- 08-Port Basic Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-DLDP Command
- 12-MAC Address Table Command
- 13-MSTP Command
- 14-Multicast Command
- 15-Routing Protocol Command
- 16-802.1x Command
- 17-AAA-RADIUS-HWTACACS Command
- 18-Centralized MAC Address Authentication Command
- 19-DHCP Command
- 20-ARP Command
- 21-ACL Command
- 22-QoS Command
- 23-Mirroring Command
- 24-Cluster Command
- 25-SNMP and RMON Command
- 26-NTP Command
- 27-SSH Terminal Service Command
- 28-File System Management Command
- 29-FTP and TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Appendix
| 03-Configuration File Management Command | 86 KB |
Table of Contents
Chapter 1 Configuration File Management Commands.
1.1 File Attribute Configuration Commands
1.1.1 display current-configuration
1.1.2 display saved-configuration
1.1.5 reset saved-configuration
1.1.7 startup saved-configuration
File path and file name can be represented in one of the following ways:
l Universal resource locator (URL) starting with “unit [No.]>flash:/” ( [No.] represents the unit ID of the switch). This method is used to specify a file on a specified unit. For example, if the unit ID of the switch is 1, the URL of the file named text.txt in the root directory of the switch is unit1>flash:/text.txt;
l URL starting with “flash:/”. This method can be used to specify the files saved in the flash of the current unit;
l Inputting the path name or file name directly. This method can be used to specify the path to go to or a file in the current work directory.
display current-configuration [ configuration [ configuration-type ] | interface [ interface-type ] [ interface-number ] | vlan [ vlan-id ] ] [ by-linenum ] [ | { begin | include | exclude } regular-expression ]
View
Parameter
configuration: Displays the specified configuration.
l configuration-type: Configuration type, It depends on the specific configuration, which can be one of the following: acl-adv, acl-basic, acl-ethernetframe, acl-user, hwping, isp, radius-template, system, and user-interface.
interface: Displays port configuration.
interface-type: Port/interface type, which can be one of the following: Aux, Ethernet, GigabitEthernet, Loopback, NULL and VLAN-interface.
interface-number: Port/interface number.
vlan: Displays VLAN configuration.
vlan-id: VLAN ID.
by-linenum: Displays line numbers.
|: Uses a regular expression to filter the configuration of the device to be displayed.
begin: Displays the configuration starting with the string specified by the regular-expression argument.
include: Displays the configuration including the string specified by the regular-expression argument.
exclude: Displays the configuration not including the string specified by the regular-expression argument.
regular-expression: A regular expression.
Table 1-1 Special characters used in a regular expression
Character |
Meaning |
Matches the strings starting with the sub-expressions following “^” |
^user matches configuration files starting with “user”. |
Matches the strings starting with the sub-expressions before “$” |
user$ matches the configuration ending with “user” |
_ |
Underline, which can represent the following characters: (^|$|[,{}]), space, starting character, and ending character. |
If the first character of a regular expression is not “_”, the number of the underline characters in a regular expression is only limited by the length of a command line. If the first character of a regular expression is “_”, there can be up to four other successive underline characters following it. If the underline characters are not successive, only the first underline character group is matched. The subsequent underline groups are ignored. |
Left parenthesis, push-in-stack signal |
You are not recommended to use this character in a regular expression. |
Period. A wildcard, it can represent any single character, including spaces. |
Asterisk. It means that the preceding sub-expression can be matched for zero or multiple times. |
zo* matches “z” and “zoo”. |
Plus sign. It means that the preceding sub-expression can be matched for one or multiple times. |
zo+ matches "zo" and “zoo”, but not "z". |
Use the display current-configuration command to display the current configuration of a switch.
Parameters that are the same as the default are not displayed.
As the display current-configuration command can be used to view the currently valid parameters, you can use this command to verify a group of configurations. The configured parameter whose corresponding function does not take effect is not displayed.
Related command: save, reset saved-configuration, and display saved-configuration.
Example
# Display the currently valid configuration parameters of the Ethernet switch.
<H3C> display current-configuration
sysname H3C
gvrp
MAC-authentication
queue-scheduler strict-priority
vlan 1
interface Vlan-interface1
ip address 192.168.0.39 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1
priority 7
webcache address 1.1.1.1 mac 0000-0000-0001 vlan 1
traffic-limit inbound ip-group 3001 rule 1 640 exceed remark-dscp 4
traffic-priority inbound ip-group 2000 rule 0 dscp ef
line-rate inbound 128
interface Ethernet1/0/2
voice vlan enable
interface Ethernet1/0/3
port link-type hybrid
port hybrid vlan 1 3 untagged
voice vlan enable
port hybrid protocol-vlan vlan 3 1
port hybrid protocol-vlan vlan 3 2
interface Ethernet1/0/4
mirroring-group 1 monitor-port
interface Ethernet1/0/5
port link-type trunk
port trunk permit vlan 1 25
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
interface Ethernet1/0/9
voice vlan enable
interface Ethernet1/0/10
port hybrid vlan 1 3 to 4 untagged
port hybrid protocol-vlan vlan 4 0
lacp enable
interface Ethernet1/0/11
interface Ethernet1/0/12
interface Ethernet1/0/13
interface Ethernet1/0/14
interface Ethernet1/0/15
interface Ethernet1/0/16
interface Ethernet1/0/17
interface Ethernet1/0/18
interface Ethernet1/0/19
interface Ethernet1/0/20
port access vlan 2
interface Ethernet1/0/21
interface Ethernet1/0/22
interface Ethernet1/0/23
interface Ethernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface NULL0
user-interface aux 0 4
idle-timeout 0 0
user-interface aux 5 7
user-interface vty 0 4
authentication-mode none
user privilege level 3
set authentication password simple 1
return
# Display the lines that include the stings matching “10*” in the configuration information. (The character “*” means that the character 0 in the string before it can appear multiple times or does not appear.)
<H3C> display current-configuration | include 10*
vlan 1
interface Aux1/0/0
route-policy song permit node 1
# Display the configuration information starting with the string “user”.
<H3C> display current-configuration | include ^user
user-interface aux 0 7
display saved-configuration [ unit unit-id ] [ by-linenum ]
View
Parameter
unit unit-id: Specifies the unit ID of a switch.
Use the display saved-configuration command to display the content of the primary configuration file in the Flash of a switch.
Related command: save, reset saved-configuration, and display current-configuration.
Example
# Display the content of the primary configuration file in the Flash.
<H3C> display saved-configuration
sysname H3C
gvrp
MAC-authentication
vlan 1
#LOCCFG. MUST NOT DELETE
interface Aux1/0/0
priority 7
voice vlan enable
voice vlan enable
voice vlan enable
lacp enable
#TOPOLOGYCFG. MUST NOT DELETE
interface NULL0
idle-timeout 0 0
return
The configurations are listed in this order: global configuration, port configuration, and user interface configuration.
1.1.3 display startup
display startup [ unit unit-id ]
View
Parameter
Use the display startup command to display the startup configuration of a switch, including the name of the current startup configuration file, the names of the primary startup configuration file and secondary startup configuration file to be used when the switch starts the next time, and so on.
Related command: startup saved-configuration.
Example
# Display the startup configuration of unit 1.
<H3C> display startup unit 1
MainBoard:
Current Startup saved-configuration file: NULL
Next main startup saved-configuration file: flash:/123.cfg
Next backup startup saved-configuration file: flash:/back.cfg
Bootrom-access enable state: enabled
1.1.4 display this
display this [ by-linenum ]
View
Parameter
Use the display this command to display the current configuration performed in the current view. To verify the configuration performed in a view, you can use this command to display the parameters that are valid in the current view.
Parameters that are the same as the default are not displayed. And parameters corresponding to the functions that do not take effect are not displayed either.
When you execute this command in different interface views, the configurations performed in the corresponding interfaces are displayed. When you execute this command in different protocol views, the configurations performed in the corresponding protocol views are displayed. And when you execute this command in different protocol sub-views, the configurations performed in the corresponding protocol sub-views are displayed.
Related command: save, reset saved-configuration, display saved-configuration, and display current-configuration.
Example
# Display the configuration parameters that take effect in AUX 0 interface view.
[H3C-ui-aux0] display this
idle-timeout 0 0
set authentication password simple 123
idle-timeout 0 0
user-interface vty 1 4
idle-timeout 0 0
return
View
Parameter
backup: Specifies the secondary configuration file.
main: Specifies the primary configuration file.
Use the reset saved-configuration command to remove a specified configuration file from the Flash.
If you execute this command with neither the backup nor the main keyword specified, the primary configuration file is removed.
The reset saved-configuration command is usually used when:
l The configuration files in the Flash are not compatible with the system software. (This may occur after you upgrade the software of the switch.)
l The network where the switch operates changes. In this case, the existing configuration files may conflict with the new network. You can remove the existing configuration files and configure the switch again.
Caution:
l Execute the reset saved-configuration command with caution or with the presence of the technicians.
l Upon powered on, a switch performs initialization using the default parameters if the Flash contains no configuration file.
l An error occurs when you execute this command if the configuration file to be removed does not exist.
Related command: save.
Example
# Remove the primary configuration file to be used in the next startup.
<H3C> reset saved-configuration main
The saved configuration will be erased.
Are you sure?[Y/N]y
Configuration in flash memory is being cleared.
Please wait ...
Unit1 reset saved-configuration successfully.
1.1.6 save
save [ cfgfile | [ safely ] [ backup | main ] ]
View
Parameter
cfgfile: Path name or file name of a configuration file in the Flash, a string comprising 5 to 56 characters.
safely: Saves the current configuration in the safe mode. Although the saving process in the safe mode is slow, the configuration can be saved to the Flash even if the device restarts or is powered off when the saving operation is being processed.
backup: Saves the configuration to the secondary configuration file.
main: Saves the configuration to the primary configuration file.
Use the save command to save the current configuration to a configuration file in the Flash.
If you execute this command with neither the backup nor the main keyword specified, the current configuration is saved in the primary configuration file.
The safely keyword determines the way to save the current configuration, as described in the following.
l If you execute this command with the safely keyword not specified, the system saves the current configuration in the fast mode. In this mode, the configuration gets lost if the device restarts or is powered off when the saving operation is being processed.
l If you execute this command with the safely keyword specified, the system saves the current configuration in the safe mode. Although this mode takes more time than the fast mode, the configuration can be saved to the Flash even if the device restarts or is powered off when the saving operation is being processed.
The fast mode is recommended under the circumstances where the power systems are reliable, while the safe mode is recommended when power system is unreliable or you are performing a remote maintenance operation.
& Note:
l If you execute the save command with the cfgfile argument not specified, the current configuration is saved in the configuration file with which the device latest starts. If the device starts using the default configuration, the current configuration is saved in the default configuration file.
l To make a switch to adopt the current configuration when it starts the next time, save the current configuration using the save command before restarting the switch.
l The displayed format of the configuration file is the same as the format in which it is saved.
Example
# Save the current configuration to the primary configuration file.
<H3C> save main
The configuration will be written to the device.
Are you sure?[Y/N]y
Please input the file name(*.cfg)(To leave the existing filename
unchanged press the enter key):123.cfg
Now saving current configuration to the device.
Saving configuration. Please wait...
Unit1 save configuration flash:/123.cfg successfully
%Apr 2 02:58:01:682 2000 H3C CFM/3/CFM_LOG:- 1 -Unit1 save configuration successfully.
# Save the current configuration to 234.cfg in unit 1.
<H3C> save unit1>flash:/234.cfg
The current configuration will be saved to unit1>flash:/234.cfg [Y/N]:y
Unit1 save configuration unit1>flash:/234.cfg successfully
<H3C>
%Apr 2 04:07:21:805 2000 5500-EI CFM/3/CFM_LOG:- 1 -Unit1 save configuration successfully.
undo startup saved-configuration [ unit unit-id ]
View
Parameter
cfgfile: Path name or file name of a configuration file in the Flash, a string comprising 5 to 56 characters. Note that the current configuration file is saved in the root directory of the Flash, with the extension being .cfg.
backup: Specifies the configuration file to be the secondary configuration file.
main: Specifies the configuration file to be the primary configuration file.
Use the startup saved-configuration command to specify a configuration file to be the primary configuration file or the secondary configuration file.
Use the undo startup saved-configuration command to specify a switch to start without loading the configuration file.
If you execute the startup saved-configuration command with neither the backup nor the main keyword specified, the configuration file identified by the cfgfile argument is specified as the primary configuration file.
Caution:
To make a switch to start without loading the configuration file, do not execute the save command after executing the undo startup saved-configuration command.
Related command: display startup.
Example
# Configure the file named congfig.cfg to be the main configuration file for the switch to start the next time.
<H3C> startup saved-configuration congfig.cfg main
Please wait......Done!
