- H3C S3100-52P Ethernet Switch Command Manual-Release 1500(V1.01)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Confiugration Command
- 07-GVRP Command
- 08-Port Basic Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-DLDP Command
- 12-MAC Address Table Command
- 13-MSTP Command
- 14-Multicast Command
- 15-Routing Protocol Command
- 16-802.1x Command
- 17-AAA-RADIUS-HWTACACS Command
- 18-Centralized MAC Address Authentication Command
- 19-DHCP Command
- 20-ARP Command
- 21-ACL Command
- 22-QoS Command
- 23-Mirroring Command
- 24-Cluster Command
- 25-SNMP and RMON Command
- 26-NTP Command
- 27-SSH Terminal Service Command
- 28-File System Management Command
- 29-FTP and TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Appendix
| 19-DHCP Command | 62 KB |
Table of Contents
Chapter 1 DHCP Snooping Configuration Commands
1.1 DHCP Snooping Configuration Commands
1.1.4 display dhcp-snooping trust
Chapter 2 DHCP/BOOTP Client Configuration
2.1 DHCP Client Configuration Commands
2.2 BOOTP Client Configuration Commands
1.1.1 dhcp-snooping
dhcp-snooping
undo dhcp-snooping
View
Parameter
None
Use the dhcp-snooping command to enable the DHCP snooping function.
Use the undo dhcp-snooping command to disable the DHCP snooping function.
By default, the DHCP snooping function is disabled.
Related command: display dhcp-snooping.
Example
# Enter system view.
<H3C> system-view
# Enable the DHCP snooping function.
[H3C] dhcp-snooping
1.1.2 dhcp-snooping trust
dhcp-snooping trust
undo dhcp-snooping trust
View
Ethernet port view
Parameter
None
Use the dhcp-snooping trust command to set an Ethernet port to a trusted port.
Use the undo dhcp-snooping trust command to restore an Ethernet port to an untrusted port.
DHCP snooping security allow you to set a port to a trusted port or an untrusted port, so that DHCP clients can obtain IP addresses from only valid DHCP servers.
l Trusted ports can be used to connect DHCP servers or ports of other switches. Untrusted ports can be used to connect DHCP clients or networks.
l Trusted ports forward any received DHCP packets to ensure that DHCP clients can obtain IP addresses from valid DHCP servers. Untrusted ports discard the DHCP-ACK and DHCP-OFFER responses received from DHCP servers.
By default, all the ports of a switch are untrusted ports.
Related command: display dhcp-snooping trust.
Example
<H3C> system-view
# Set the Ethernet1/0/1 port to a trusted port.
[H3C-Ethernet1/0/1] dhcp-snooping trust
1.1.3 display dhcp-snooping
display dhcp-snooping [ unit unit-id ]
View
Parameter
unit unit-id: Displays the DHCP-snooping information on other devices in fabric when the switch is in fabric. unit-id indicates the number of the device whose DHCP-snooping information needs to be viewed.
Use the display dhcp-snooping command to display the user IP-MAC address mapping entries recorded by the DHCP snooping function.
Related command: dhcp-snooping.
Example
# Display the user IP-MAC address mapping entries recorded by the DHCP snooping function.
DHCP-Snooping is enabled.
The client binding table for all untrusted ports.
Type : D--Dynamic , S--Static
Unit ID : 1
Type IP Address MAC Address Lease VLAN Interface
--- 0 dhcp-snooping item(s) of unit 1 found ---
View
Parameter
None
Use the display dhcp-snooping trust command to display the (enabled/disabled) state of the DHCP snooping function and the trusted ports.
Related command: dhcp-snooping trust.
Example
# Display the state of the DHCP snooping function and the trusted ports.
<H3C> display dhcp-snooping trust
DHCP-Snooping trust become effective.
Interface Trusted
Ethernet1/0/10 Trusted
The above display information indicates that the DHCP snooping function is enabled, and the Ethernet1/0/10 port is a trusted port.
2.1.1 debugging dhcp client
debugging dhcp client { all | error | event | packet }
undo debugging dhcp client { all | error | event | packet }
View
Parameter
all: Enables all types of debugging for dynamic host configuration protocol (DHCP) or bootstrap protocol (BOOTP) client.
error: Enables debugging for DHCP/BOOTP client error messages (including the information about unidentified packets).
event: Enables debugging for DHCP/BOOTP client events (including address allocation and data update).
packet: Enables debugging for packets received/transmitted by a DHCP/BOOTP client.
Use the debugging dhcp client command to enable a specified type of debugging for the DHCP/BOOTP client.
Use the undo debugging dhcp client command to disable debugging output.
By default, debugging for DHCP/BOOTP client is disabled.
As debugging occupies system resources, disable debugging if it is not needed.
Example
# Enable debugging for DHCP/BOOTP client events.
<H3C> debugging dhcp client event
2.1.2 debugging dhcp irf xha
undo debugging dhcp irf xha
View
Parameter
None
Use the debugging dhcp irf xha command to enable the hot backup debugging for the DHCP/BOOTP client.
Use the undo debugging dhcp irf xha command to disable the hot backup debugging for the DHCP/BOOTP client.
The hot backup debugging for the DHCP/BOOTP client is disabled by default.
Example
# Enable the hot backup debugging for the DHCP/BOOTP client.
<H3C> debugging dhcp irf xha
2.1.3 display dhcp client
display dhcp client [ verbose ]
View
Parameter
verbose: Displays the detailed address allocation information.
Use the display dhcp client command to display the information about the address allocation of DHCP clients.
Example
# Display the information about the address allocation of DHCP clients.
<H3C> display dhcp client verbose
DHCP client statistic information:
Vlan-interface1:
Current machine state: BOUND
Allocated IP: 169.254.0.2 255.255.0.0
Allocated lease: 86400 seconds, T1: 43200 seconds, T2: 75600 seconds
Lease from 2002.09.20 01:05:03 to 2002.09.21 01:05:03
Server IP: 169.254.0.1
Transaction ID = 0x3d8a7431
Default router: 2.2.2.2
Next timeout will happen after 0 days 11 hours 56 minutes 1 seconds.
The output information above shows that:
l The IP address 169.254.0.2/16 is allocated to VLAN interface1.
l The current state of the client state machine is BOUND.
l The lease period of the address is 86,400 seconds.
l The value of the renewal timer and rebinding timer is 43,200 seconds and 75,600 seconds.
l The lease period dates from 2002.09.20 01:05:03 to 2002.09.21 01:05:03.
l The IP address of the DHCP server is 169.254.0.1.
l The IP address of the gateway is 2.2.2.2.
l Next timeout will happen after 11 hours 56 minutes 1 second.
Table 2-1 Description on the fields of the display dhcp client command
Vlan-interface1 |
VLAN interface operating as a DHCP client to obtain an IP address dynamically |
Current machine state |
The state of the client state machine |
Allocated IP |
IP address allocated to the DHCP client |
lease |
Lease period |
T1 |
Renewal timer setting |
T2 |
Rebinding timer setting |
Lease from….to…. |
The starting and end time of the lease period |
Server IP |
IP address of the DHCP server selected |
Transaction ID |
Transaction ID |
Default router |
Gateway address |
2.1.4 ip address dhcp-alloc
undo ip address dhcp-alloc
View
VLAN interface view
Parameter
None
Use the ip address dhcp-alloc command to configure a VLAN interface to obtain an IP address through DHCP.
Use the undo ip address dhcp-alloc command to cancel the configuration.
By default, a VLAN interface does not use DHCP to obtain an IP address.
Example
# Configure the management VLAN interface to obtain an IP address through DHCP. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C] interface Vlan-interface 1
[H3C-Vlan-interface1] ip address dhcp-alloc
2.2.1 display bootp client
display bootp client [ interface Vlan-interface vlan-id ]
View
Parameter
vlan-id: ID of the management VLAN interface.
Use the display bootp client command to display BOOTP client-related information, including the MAC address of the BOOTP client and the IP address obtained.
Example
# Display the BOOTP client-related information.
<H3C> display bootp client interface Vlan-interface 1
Vlan-interface1:
Mac Address 00e0-fc0a-c3ef
Table 2-2 Description on the fields of the display bootp client command
Vlan-interface1 |
Management VLAN interface 1 is configured to obtain an IP address through BOOTP. |
Allocated IP |
IP address allocated to the VLAN interface |
Transaction ID |
Value of the XID field in BOOTP packets |
Mac Address |
MAC address of the BOOTP client |
2.2.2 ip address bootp-alloc
undo ip address bootp-alloc
View
VLAN interface view
Parameter
None
Use the ip address bootp-alloc command to configure a VLAN interface to obtain an IP address through BOOTP.
Use the undo ip address bootp-alloc command to cancel the configuration.
By default, a VLAN interface does not use BOOTP to obtain an IP address.
Related command: display bootp client.
Example
# Configure the management VLAN interface to obtain an IP address through BOOTP. (Assume that VLAN 1 is the management VLAN.)
<H3C> system-view
[H3C-Vlan-interface1] ip address bootp-alloc
