| Title | Size | Downloads |
| 15-Command Index-book.rar | 6.29 MB |
| book | 6.29 MB |
1 Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
abr-summary (OSPFv3 area view)
address-family ipv4 (VPN instance view)
address-family ipv6 (public instance view)
address-family ipv6 (VPN instance view)
address-family l2vpn evpn (BGP instance view)
advertise-between-vrf clear-reflect-attributes
archive configuration interval
archive configuration location
arp ip-unnumbered learning enable
arp resolving-route probe-count
arp resolving-route probe-interval
attack-defense local apply policy
attack-defense signature log non-aggregate
bestroute origin-as-validation
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bgp apply-policy on-startup duration
bgp update-delay on-startup prefix-list
bgp update-delay wait-other-protocol
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
crc-error bit-error-ratio algorithm-parameter
default-cost (OSPFv3 area view)
default-route-advertise (OSPFv3 view)
description (cross-connect group view)
description (VPN instance view)
destination-group (subscription view)
destination-group (telemetry view)
dhcp authorized-ip-conflict ignore
dhcp conflict-ip-address offline
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
dhcp relay forward reply by-option82
dhcp relay information circuit-id
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay master-server switch-delay
dhcp relay server-address algorithm
dhcp server allocated-ip threshold
dhcp server bootp reply-rfc-1048
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server multi-ip per-mac enable
dhcp server policy-first enable
dhcp server relay information enable
dhcp server reply-exclude-option60
dhcp server request-ip-address check
display | { begin | exclude | include }
display arp source-mac configuration
display arp source-mac statistics
display arp source-suppression
display arp valid-check statistics
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense scan victim ip
display attack-defense scan victim ipv6
display attack-defense statistics local
display bgp dampening parameter
display bgp egress-engineering ipv4
display bgp l2vpn auto-discovery
display bgp l2vpn evpn inlabel
display bgp non-stop-routing status
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 mvpn
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp segment-routing label-range
display cfd dm two-way history
display cpu-usage configuration
display current-configuration diff
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp server statistics
display dhcp-access packet statistics
display dhcp-access user-table
display diagnostic-information
display diagnostic-logfile summary
display evpn route xconnect-group
display hardware-failure-detection
display igmp attack-suppression source-mac configuration
display igmp attack-suppression source-mac entry
display igmp proxy routing-table
display interface register-tunnel
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ipv6 dhcp client statistics
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast rpf-info
display ipv6 nd suppression xconnect-group
display ipv6 neighbors entry-limit
display ipv6 neighbors vpn-instance
display ipv6 pim claimed-route
display ipv6 pim routing-table
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 router-renumber statistics
display ipv6 route-static routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display isis event-log graceful-restart
display isis event-log non-stop-routing
display isis global-statistics
display isis graceful-restart status
display isis mpls te advertisement
display isis non-stop-routing status
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing prefix-sid-map
display kernel deadloop configuration
display kernel starvation configuration
display l2vpn forwarding evpn split-horizon
display l2vpn pw state-machine
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display mac-address aging-time
display mld proxy routing-table
display mpls ldp troubleshooting
display mpls static-sr-mpls prefix
display mpls te binding-sid ref-list
display mpls te bit-error-detection tunnel-interface
display mpls te link-management bandwidth-allocation
display mpls te link-management srlg
display mpls te pce stateful neighbor
display mpls te pce statistics
display mpls te segment-routing tunnel path
display mpls te tunnel-interface
display msdp non-stop-routing status
display multicast fast-forwarding cache
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast-vpn c-multicast routing-table
display multicast-vpn default-group
display multicast-vpn inclusive-tunnel
display multicast-vpn ipv6 default-group
display multicast-vpn selective-tunnel
display nqa twamp-light client
display nqa twamp-light client statistics
display nqa twamp-light client test-session reaction counters
display nqa twamp-light responder
display ntp-service ipv6 sessions
display ospf fast-reroute lfa-candidate
display ospf global-statistics
display ospf non-stop-routing status
display ospf segment-routing adjacency
display ospf segment-routing global-block
display ospf segment-routing prefix-sid-map
display ospfv3 global-statistics
display ospfv3 graceful-restart
display ospfv3 non-stop-routing
display packet-filter statistics
display packet-filter statistics sum
display password-control blacklist
display performance-management statistics
display performance-management task
display process memory heap address
display process memory heap size
display ptp foreign-masters-record
display public-key local public
display qos forwarding-profile
display qos policy control-plane
display qos policy control-plane pre-defined
display qos queue sp interface
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos scheduler-policy diagnosis interface
display qos scheduler-policy interface
display route-static routing-table
display security-logfile summary
display segment-routing label-block
display segment-routing mapping-server prefix-sid-map
display snmp-agent local-engineid
display snmp-agent trapbuffer drop
display snmp-agent trapbuffer send
display s-trunk member role-change
display s-trunk packet-statistics
domain-authentication send-only
enable out-of-band-resynchronization
evpn frr local (cross-connect group EVPN instance view)
evpn frr local (VSI EVPN instance view)
evpn local-service-id remote-service-id
evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag
evpn multihoming timer df-delay
evpn multihoming vpws-frr local
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
filter-policy export (OSPFv3 view)
filter-policy import (OSPFv3 view)
forwarding-group (forwarding group match criterion view)
forwarding-group profile (scheduler-policy match criterion view)
ftp server acl-deny-log enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp-learning enable
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
http-flood detect non-specific
icmp-flood detect non-specific
icmpv6-flood detect non-specific
igmp host-tracking { disable | enable }
igmp last-member-query-interval
igmp other-querier-present-interval
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center syslog trap buffersize
info-center trace-logfile quota
ip address te-tunnel unnumbered
ip policy-based-route-log enable
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip route-static recursive-lookup tunnel
ip vpn-instance (BGP instance view)
ipv6 dhcp client stateless enable
ipv6 dhcp relay client-information record
ipv6 dhcp session-mismatch action
ipv6 extension-header drop enable
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server suppress
ipv6 nd ra hop-limit unspecified
ipv6 nd route-direct advertise
ipv6 nd suppression push interval
ipv6 neighbors max-learning-num
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim state-refresh-capable
ipv6 pim triggered-hello-delay
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 policy-based-route-log enable
ipv6 route-static default-preference
ipv6 route-static fast-reroute auto
ipv6 route-static primary-path-detect bfd echo
ipv6 route-static vpn-instance
isis fast-reroute lfa-backup exclude
isis fast-reroute remote-lfa disable
isis fast-reroute ti-lfa disable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 primary-path-detect bfd
labeled-route ignore-no-tunnel
lacp default-selected-port disable
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
link-aggregation bfd-compatible enable
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation reversion delay
link-aggregation secondary-down
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-aggregation selected-port minimum percentage
link-management periodic-flooding timer
link-quality crc-error bit-error-ratio
lldp ignore-pvid-inconsistency
lldp management-address-format string
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer notification-interval
load-splitting (IPv6 MRIB view)
local-server log change-password-prompt
longest-match (IPv6 MRIB view)
lsa-arrival-interval suppress-flapping
lsa-generation-interval suppress-flapping
maxage-lsa route-calculate-delay
maximum load-balancing (OSPFv3 view)
memory-threshold usage resend-interval
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mld host-tracking { disable | enable }
mld last-listener-query-interval
mld other-querier-present-timeout
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor resend cpu-usage core-interval
monitor resend memory-threshold
mpls bfd backup detect-multiplier
mpls bfd backup min-receive-interval
mpls bfd backup min-transmit-interval
mpls bfd min-transmit-interval
mpls bfd trigger tunnel-down enable
mpls ldp sync (OSPF view/OSPF area view)
mpls periodic-tracert (for LSP)
mpls te auto-tunnel backup disable
mpls te bandwidth change thresholds
mpls te bit-error-detection threshold
mpls te enable (interface view)
mpls te enable (OSPF area view)
mpls te fast-reroute bypass-tunnel
mpls te max-reservable-bandwidth
mpls te passive-delegate report-only
mpls te path-selection adjacency-sid
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
mpls te tunnel-attribute prefer
mpls tunnel-bfd (for TE tunnel)
mpls tunnel-bfd detect-multiplier
mpls tunnel-bfd min-receive-interval
mpls tunnel-bfd min-transmit-interval
multicast rpf-proxy-vector compatible
netconf capability specific-namespace
network-clock source frequency
nexthop recursive-lookup delay
nexthop recursive-lookup restrain clear-interval
nexthop recursive-lookup restrain disable
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service reliable authentication-keyid
ntp-service time-offset-threshold
origin dhcp subnet mask-length
ospf fast-reroute remote-lfa disable
ospf fast-reroute ti-lfa disable
ospf peer suppress-flapping hold-down
ospf peer suppress-flapping hold-max-cost
ospf troubleshooting max-number
ospfv3 fast-reroute lfa-backup exclude
ospfv3 primary-path-detect bfd
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
packet-capture local interface
packet-capture remote interface
packet-filter default hardware-count
password (device management user view)
password-control { aging | composition | history | length } enable
password-control alert-before-expire
password-control change-password first-login enable
password-control change-password weak-password enable
password-control expired-user-login
password-control login idle-time
password-control login-attempt
password-control super composition
password-control update-interval
pce capability segment-routing
peer advertise additional-paths best
peer advertise encap-type mpls
peer advertise origin-as-validation
peer advertise-policy exist-policy
peer advertise-policy non-exist-policy
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer capability-advertise conventional
peer capability-advertise orf non-standard
peer capability-advertise orf prefix-list
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer default-route-advertise (BGP VPNv4 address family view)
peer default-route-advertise (BGP VPNv6 address family view)
peer graceful-restart timer restart extra
peer next-hop-invariable (BGP VPNv4 address family view)
peer next-hop-invariable (BGP VPNv6 address family view)
peer nexthop-recursive-policy disable
peer upe (BGP VPNv4 address family view)
peer upe (BGP VPNv6 address family view)
peer upe route-policy (BGP VPNv4 address family view)
peer upe route-policy (BGP VPNv6 address family view)
port ifmonitor crc-error bit-error-ratio
protocol nexthop recursive-lookup
ptp alarm-threshold { time-lock | time-unlock } *
ptp alarm-threshold clock-source-class
ptp alarm-threshold time-offset
ptp alarm-threshold time-offset-sum pk-pk
pw-class (auto-discovery cross-connect group view)
pw-class (auto-discovery VSI view)
qos apply policy(interface view, control plane view)
qos wfq { byte-count | weight }
qos wrr { byte-count | weight }
reaction checked-element two-way-delay
reaction checked-element two-way-jitter
reaction checked-element two-way-loss
register-policy (IPv6 PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
reset arp source-mac statistics
reset arp valid-check statistics
reset attack-defense policy flood
reset attack-defense statistics local
reset bgp bmp server statistics
reset counters interface inloopback
reset counters interface loopback
reset counters interface tunnel
reset crc-error bit-error-ratio status interface
reset dhcp relay client-information
reset dhcp-access packet statistics
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay statistics
reset ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 nd suppression xconnect-group
reset ipv6 policy-based-route statistics
reset ipv6 router-renumber statistics
reset ipv6 routing-table statistics protocol
reset isis event-log graceful-restart
reset isis event-log non-stop-routing
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset netconf service statistics
reset netconf session statistics
reset nqa twamp-light statistics
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset qos policy control-plane
reset s-trunk packet-statistics
route-replicate (public instance IPv4 address family view)
route-replicate (public instance IPv6 address family view)
route-replicate (VPN instance IPv4 address family view)
route-replicate (VPN instance IPv6 address family view)
router-id (BGP-VPN instance view)
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rsvp authentication window-size
rsvp reduction retransmit increment
rsvp reduction retransmit interval
save current-configuration interval
segment-routing adjacency enable
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
select-seq load-balance-number
sensor-group (subscription view)
service-type (local user view)
shutdown (cross-connect group view)
signature { large-icmp | large-icmpv6 } max-length
snmp-agent { inform | trap } source
snmp-agent packet response dscp
snmp-agent trap enable dhcp server
snmp-agent trap if-mib link extended
snmp-agent trap isis adjacency-state-change extended
snmp-agent trap ospf neighbor-state-change extended
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3 user-role
sntp reliable authentication-keyid
source-lifetime (IPv6 PIM view)
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
start (frame loss/latency/throughput operation view)
start (TWAMP Light sender view)
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
stop (frame loss/latency/throughput operation view)
stop (TWAMP Light sender view)
syn-ack-flood detect non-specific
telnet server acl-deny-log enable
test-session (Twamp Light client view)
test-session (Twamp Light responder view)
timer join-prune (IPv6 PIM view)
timer lsp-flood suppress-flapping
timer lsp-generation suppress-flapping
timer purge-zero-lsp route-calculate-delay
timer route-calculate suppress-flapping
track list threshold percentage
tunnel-policy (auto-discovery cross-connect view)
tunnel-policy (auto-discovery VSI view)
unicast-route recursive-lookup tunnel
update-first route-policy (BGP VPNv4 address family view)
update-first route-policy (BGP VPNv6 address family view)
vlan-termination broadcast enable
vlan-type dot1q vid second-dot1q
vpn-instance (IP pool group view)
vrrp ipv6 state-transition-delay
vrrp ipv6 vrid ignore-interface-down
vrrp ipv6 vrid source-interface
vrrp ipv6 vrid timer advertise
