- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-OSPF commands
- 04-IS-IS commands
- 05-BGP commands
- 06-Policy-based routing commands
- 07-IPv6 static routing commands
- 08-OSPFv3 commands
- 09-IPv6 policy-based routing commands
- 10-Routing policy commands
- 11-DCN commands
| 03-OSPF commands | 1.08 MB |
display ospf fast-reroute lfa-candidate
display ospf global-statistics
display ospf non-stop-routing status
enable out-of-band-resynchronization
fast-reroute remote-lfa maximum-cost
fast-reroute remote-lfa prefix-list
fast-reroute remote-lfa tunnel ldp
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
lsa-arrival-interval suppress-flapping
lsa-generation-interval suppress-flapping
maxage-lsa route-calculate-delay
ospf fast-reroute remote-lfa disable
ospf peer suppress-flapping hold-down
ospf peer suppress-flapping hold-max-cost
ospf troubleshooting max-number
snmp-agent trap ospf neighbor-state-change extended
OSPF commands
abr-summary
Use abr-summary to configure route summarization on an ABR.
Use undo abr-summary to remove the configuration.
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost-value ]
undo abr-summary ip-address { mask-length | mask }
Route summarization is not configured on an ABR.
OSPF area view
ip-address: Specifies the destination IP address of the summary route in dotted decimal notation.
mask-length: Specifies the mask length in the range of 0 to 32.
mask: Specifies the mask of the IP address, in dotted decimal notation.
advertise | not-advertise: Advertises the summary route or not. By default, the command advertises the summary route.
cost cost-value: Specifies the cost of the summary route, in the range of 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
This command applies only to an ABR to summarize multiple contiguous networks into one network.
To enable ABR to advertise specific routes that have been summarized, use the undo abr-summary command.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 into 36.42.0.0/16.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area
Use area to create an OSPF area and enter OSPF area view.
Use undo area to remove an OSPF area.
In OSPF view:
area area-id
undo area area-id
No OSPF areas exist.
OSPF view
area-id: Specifies an area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format.
# Create Area 0 and enter Area 0 view.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary
Use asbr-summary to configure route summarization on an ASBR.
Use undo asbr-summary to remove the configuration.
asbr-summary ip-address { mask-length | mask } [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ip-address { mask-length | mask }
Route summarization is not configured on an ASBR.
OSPF view
ip-address: Specifies the destination IP address of the summary route.
mask: Specifies the mask in dotted decimal notation.
cost cost-value: Specifies the cost of the summary route, in the range of 1 to 16777214. If you do not specify this option, the largest cost among the summarized routes applies. If the routes in Type-5 LSAs translated from Type-7 LSAs are Type-2 external routes, the largest cost among the summarized routes plus 1 applies.
not-advertise: Disables advertising the summary route. If you do not specify this keyword, the command advertises the route.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. By default, the P-bit of Type-7 LSAs is set to 1. If the ASBR is also an ABR and FULL state neighbors exist in the backbone area, the P-bit of Type-7 LSAs originated by the ASBR is set to 0. This keyword applies to the NSSA ASBR.
tag tag: Specifies a tag for the summary route, in the range of 0 to 4294967295. The default is 1. The tag can be used by a routing policy to control summary route advertisement.
An ASBR can summarize routes in the following LSAs:
· Type-5 LSAs.
· Type-7 LSAs in an NSSA area.
· Type-5 LSAs translated by the ASBR (also an ABR) from Type-7 LSAs in an NSSA area.
If the ASBR (ABR) is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
To enable ASBR to advertise specific routes that have been summarized, use the undo asbr-summary command.
# Summarize redistributed static routes into a single route, and specify a tag value of 2 and a cost of 100 for the summary route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode
Use authentication-mode to specify an authentication mode for an OSPF area.
Use undo authentication-mode to remove the configuration.
For MD5/HMAC-MD5/HMAC-SHA-256 authentication:
authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
undo authentication-mode [ { hmac-md5 | hmac-sha-256 | md5 } key-id ]
For simple authentication:
authentication-mode simple { cipher | plain } string
No authentication is performed for an area.
OSPF area view
hmac-md5: Specifies the HMAC-MD5 authentication mode.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
key-id: Specifies a key by its ID in the range of 0 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
· In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
· In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
· In HMAC-SHA-256 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
To establish or maintain adjacencies, routers in the same area must have the same authentication mode and key.
If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string. As a best practice to minimize the risk of key compromise, use only one key for an area and delete the old key after key replacement.
To replace the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication in an area, you must configure the new key before removing the old key from each router. OSPF uses the key rollover mechanism to ensure that the routers can pass authentication before the replacement is complete across the area. After you configure a new key on a router, the router sends copies of the same packet, each authenticated by a different key, including the new key and the keys in use. This practice continues until the router detects that all its neighbors have the new key.
# Configure OSPF Area 0 to use the MD5 authentication mode, and set the key ID to 15 and the key to abc in plaintext form.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5 15 plain abc
ospf authentication-mode
bandwidth-reference
Use bandwidth-reference to set a reference bandwidth value for link cost calculation.
Use undo bandwidth-reference to restore the default value.
bandwidth-reference value
The reference bandwidth value is 100 Mbps for link cost calculation.
OSPF view
value: Specifies the reference bandwidth value for link cost calculation, in the range of 1 to 4294967 Mbps.
If no cost values are configured for links, OSPF calculates their cost values by using the following formula: Cost = Reference bandwidth value / Expected interface bandwidth. The expected bandwidth of an interface is configured with the bandwidth command (see Interface Command Reference). If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is less than 1, the value of 1 is used.
# Set the reference bandwidth value to 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
ospf cost
database-filter peer
Use database-filter peer to filter LSAs for the specified P2MP neighbor.
Use undo database-filter peer to restore the default.
database-filter peer ip-address { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
undo database-filter peer ip-address
The LSAs for the specified P2MP neighbor are not filtered.
OSPF view
ip-address: Specifies a P2MP neighbor by its IP address.
all: Filters all LSAs except the Grace LSAs.
ase: Filters Type-5 LSAs.
nssa: Filters Type-7 LSAs.
summary: Filters Type-3 LSAs.
acl ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
On an P2MP network, a router might have multiple OSPF neighbors with the P2MP type. Use this command to prevent the router from sending LSAs to the specified neighbor.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
· To deny/permit LSAs with the specified link state ID, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
· To deny/permit LSAs with the specified link state ID and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the link state ID of an LSA and the destination keyword specifies the subnet mask of the LSA. For the mask configuration to take effect, specify a contiguous subnet mask.
If the specified neighbor has already received an LSA, the LSA still exists in the LSDB of the neighbor after you execute the command.
# Filter all LSAs (except the Grace LSAs) for the P2MP neighbor with the IP address 121.20.20.121.
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 all
# Configure advanced ACL 3000 to filter Type-3 LSAs for the P2MP neighbor with the IP address 121.20.20.121.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]rule 10 deny ip source 121.20.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 permit ip
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 summary acl 3000
ospf database-filter
default
Use default to configure default parameters for redistributed routes.
Use undo default to remove the configuration.
default { cost cost-value | tag tag | type type } *
undo default { cost | tag | type } *
The cost is 1, the tag is 1, and the route type is 2.
OSPF view
cost cost-value: Specifies a default cost for redistributed routes, in the range of 0 to 16777214.
tag tag: Specifies a tag for redistributed routes, in the range of 0 to 4294967295.
type type: Specifies a type for redistributed routes: 1 or 2.
# Set the default cost, tag, and type to 10, 100, and 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 tag 100 type 2
import-route
default-cost
Use default-cost to set a cost for the default route advertised to the stub or NSSA area.
Use undo default-cost to restore the default value.
default-cost cost-value
undo default-cost
The cost is 1.
OSPF area view
cost-value: Specifies a cost for the default route advertised to the Stub or NSSA area, in the range of 0 to 16777214.
This command takes effect only on the ABR of a stub area or the ABR or ASBR of an NSSA area.
# Configure Area 1 as a stub area, and set the cost of the default route advertised to the stub area to 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
nssa
stub
default-route-advertise
Use default-route-advertise to redistribute a default route into the OSPF routing domain.
Use undo default-route-advertise to restore the default.
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | type type ] *
default-route-advertise [ summary cost cost-value ]
No default route is redistributed into the OSPF routing domain.
OSPF view
always: Redistributes a default route in a Type-5 LSA into the OSPF routing domain regardless of whether a default route exists in the routing table. If you do not specify this keyword, the router redistributes a default route only when an active default route that does not belong to the current OSPF process exists in the IP routing table.
permit-calculate-other: Enables OSPF to calculate default routes received from other routers. If you do not specify this keyword, OSPF does not calculate default routes from other routers. If the router does not redistribute any default route in a Type-5 LSA into the OSPF routing domain, the router calculates default routes from other routers. It calculates these routes regardless of whether this keyword is specified.
cost cost-value: Specifies a cost for the default route, in the range of 0 to 16777214. If you do not specify this option, the default cost specified by the default-cost command applies.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When the routing policy is matched and one of the following conditions is met, the command redistributes a default route in a Type-5 LSA into the OSPF routing domain:
· A default route exists in the routing table.
· The always keyword is specified.
The routing policy modifies values in the Type-5 LSA.
type type: Specifies a type for the Type-5 LSA: 1 or 2. If you do not specify this option, the default type for the Type-5 LSA specified by the default type command applies.
summary: Advertises the specified default route in a Type-3 LSA. This keyword is available only for VPNs.
This command redistributes a default route in a Type-5 LSA, which cannot be redistributed with the import-route command. If the local routing table has no default route, you must specify the always keyword for the command.
The default-route-advertise summary cost command is applicable only to VPNs. It enables a PE router to redistribute a default external route in a Type-3 LSA to CE routers.
# Redistribute a default route into the OSPF routing domain, regardless of whether the default route exists in the local routing table.
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
default
import-route
description
Use description to configure a description for an OSPF process or area.
No description is configured for an OSPF process or area.
OSPF view
OSPF area view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
The description specified by this command is used to identify an OSPF process or area.
# Describe OSPF process 100 as abc.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Describe OSPF Area 0 as bone area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
discard-route
Use discard-route to configure discard routes for summary networks.
Use undo discard-route to restore the default.
discard-route { external { preference | suppression } | internal { preference | suppression } } *
undo discard-route [ external | internal ] *
A device generates discard routes with preference 255 for summary networks.
OSPF view
external: Specifies discard routes for redistributed summary networks on the ASBR. These discard routes are external discard routes.
preference: Specifies a preference for external discard routes, in the range of 1 to 255.
suppression: Disables the ASBR from generating external discard routes for summary networks.
internal: Specifies discard routes for summary networks on the ABR. These discard routes are internal discard routes.
preference: Specifies a preference for internal discard routes, in the range of 1 to 255.
suppression: Disables the ABR from generating internal discard routes for summary networks.
# Generate external and internal discard routes with preference 100 and 200, respectively.
[Sysname] ospf 100
[Sysname-ospf-100] discard-route external 100 internal 200
display ospf
Use display ospf to display OSPF process information.
display ospf [ process-id ] [ verbose ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
verbose: Displays detailed OSPF process information. If you do not specify this keyword, the command displays brief OSPF process information.
# Display detailed OSPF process information.
<Sysname> display ospf verbose
OSPF Process 1 with Router ID 192.168.1.2
OSPF Protocol Information
RouterID: 192.168.1.2 Router type: NSSA
Route tag: 0
Ext-community type: Domain ID 0x105, Route Type 0x8000, Router ID 0x8001
Domain ID: 0.0.0.0:23
Opaque capable
Originating router-LSAs with maximum metric
Condition: On startup while BGP is converging, State: Inactive
Advertise stub links with maximum metric in router-LSAs
Advertise summary-LSAs with metric 16711680
Advertise external-LSAs with metric 16711680
ISPF is enabled
SPF-schedule-interval: 50 (in milliseconds)
LSA generation interval: 5
LSA arrival interval: 1000
Route preference: 10
ASE route preference: 150
SPF computation count: 22
RFC 1583 compatible
Fast-reroute: lfa
Fast-reroute: Remote-lfa Disabled
Maximum cost: 4294967295
Node-Protecing Preference: 40
Lowest-cost Preference: 20
SRLG Preference: 10
Fast-reroute: TI-LFA
Microloop-avoidance: Enabled
Microloop-avoidance RIB-update-delay: 20000 ms
Graceful restart interval: 120
SNMP trap rate limit interval: 2 Count: 300
This process is currently bound to MIB
Area count: 1 NSSA area count: 1
Normal areas with up interfaces: 0
NSSA areas with up interfaces: 1
Up interfaces: 1
ExChange/Loading neighbors: 0
Full neighbors:3
Area0 full neighbors: 1
Calculation trigger type: Full
Current calculation type: SPF calculation
Current calculation phase: Calculation area topology
Process reset state: N/A
Current reset type: N/A
Next reset type: N/A
Reset prepare message replied: -/-/-/-
Reset process message replied: -/-/-/-
Reset phase of module:
M-N/A, P-N/A, L-N/A, C-N/A, R-N/A
MPLS segment routing: Disabled
Segment routing adjacency : Disabled
Effective SRGB : 16000 24000
Segment routing local block : 15000 15999
Segment routing tunnel count: 0
Area: 0.0.0.1 (MPLS TE not enabled)
Authentication type: None Area flag: NSSA
SPF scheduled count: 5
Up interfaces: 1
Interface: 192.168.1.2 (GigabitEthernet1/0/12)
Cost: 1 State: DR Type: Broadcast MTU: 1500
Cost source: Default
Priority: 1
Designated router: 192.168.1.2
Backup designated router: 192.168.1.1
Timers: Hello 10 , Dead 40 , Poll 40 , Retransmit 5 , Transmit Delay 1
FRR backup: Enabled
FRR remote-LFA: Enabled
FRR TI-LFA: Enabled
Enabled by network configuration
Peer flapping suppression:
Flapping count: 0
Threshold: 10
Packet size: 1000
Prefix-SID type: Index
Value: 101
Process ID: ospf 1
Prefix-SID validity: Invalid
Interface: 12.1.1.1 (GigabitEthernet1/0/13)
Cost: 65535 State: Down Type: Broadcast MTU: 1500
Cost source: Flapping
Priority: 1
Designated router: 0.0.0.0
Backup designated router: 0.0.0.0
Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit Delay 1
FRR backup: Enabled
FRR TI-LFA: Enabled
FRR remote-lfa: Enabled
Mode: Hold-max-cost
Remaining interval: 488 s
OSPF Process 1 with Router ID 192.168.1.2 |
OSPF process ID and OSPF router ID. |
RouterID |
Router ID. |
Router type |
Router type: · ABR. · ASBR. · NSSA. · Null. |
Route tag |
Tag of redistributed routes. |
Multi-VPN-Instance is not enabled |
The OSPF process does not support multi-VPN-instance. |
Ext-community type |
OSPF extended community attribute type codes: · Domain ID—Domain ID code. · Route Type—Route type code. · Router ID—Router ID code. |
Domain ID |
OSPF domain ID (primary ID). |
Opaque capable |
Opaque LSA advertisement and reception capability is enabled. |
Originating router-LSAs with maximum metric |
The maximum cost value for router LSAs (excluding stub links) is used. |
Condition |
Status of the stub router: · Always. · On startup while BGP is converging. · On startup while BGP is converging for xxx seconds, where xxx is specified by the user. · On startup for xxx seconds, where xxx is specified by the user. |
State |
Whether the stub router is active. |
SPF-schedule-interval |
Interval for SPF calculations. If the SPF calculation interval is fixed, this field also displays in milliseconds enclosed with brackets. |
LSA generation interval |
LSA generation interval. |
LSA arrival interval |
LSA arrival interval. |
Transmit pacing |
LSU packet transmit rate of the interface: · Interval—LSU transmit interval of the interface. · Count—Maximum number of LSU packets sent at each interval. |
Default ASE parameters |
Default ASE parameters: Metric, Tag, and Type. |
Route preference |
Internal route preference. |
ASE route preference |
External route preference. |
SPF computation count |
SPF computation count of the OSPF process. |
RFC1583 compatible |
Compatible with RFC 1583. |
Node-protecting preference |
Priority of the node-protection backup path selection policy. |
Lowest-cost preference |
Priority of the lowest-cost backup path selection policy. |
SRLG preference |
Priority of the shared risk link group (SRLG)-disjoint backup path selection policy. |
Fast-reroute |
FRR type: · lfa—LFA is enabled to calculate backup next hops only for non-ECMP routes. · Remote-lfa Disabled—Remote LFA is not enabled. · Remote-lfa Enabled—Remote LFA is enabled. · TI-LFA—TI-LFA is enabled. |
Maximum-cost |
Maximum cost from the source node of a protected link to a PQ node. |
Microloop-avoidance |
Microloop avoidance status: Disabled or Enabled. |
Microloop-avoidance RIB-update-delay |
Microloop avoidance delay timer in milliseconds. |
SNMP trap rate limit interval |
SNMP notification sending interval. |
Count |
Number of sent SNMP notifications. |
ExChange/Loading neighbors |
Neighbors in ExChange/Loading state. |
Full neighbors |
Neighbors in Full state. |
Area0 full neighbors |
Neighbors in Full state in the backbone area. |
Calculation trigger type |
Route calculation trigger type: · Full—Calculation of all routes is triggered. · Area topology change—Topology change in an area. · Intra router change—Incremental intra-area route change. · ASBR change—Incremental ASBR route change. · 7to5 translator—Type-7-to-Type-5 LSA translator role change. · Full IP prefix—Calculation of all IP prefixes is triggered. · Full intra AS—Calculation of all intra-AS prefixes is triggered. · Inc intra AS—Calculation of incremental intra-AS prefixes is triggered. · Full inter AS—Calculation of all AS-external prefixes is triggered. · Inc inter AS—Calculation of incremental AS-external prefixes is triggered. · N/A—Route calculation is not triggered. |
Current calculation type |
Current route calculation type: · SPF calculation. · Intra router calculation—Intra-area route calculation. · ASBR calculation—Inter-area ASBR route calculation. · Inc intra router—Incremental intra-area route calculation. · Inc ASBR calculation—Incremental inter-area ASBR route calculation. · 7to5 translator—Type-7-to-Type-5 LSA calculation. · Full intra AS—Calculation of all intra-AS prefixes. · Inc intra AS—Calculation of incremental intra-AS prefixes. · Full inter AS—Calculation of all AS-external prefixes. · Inc inter AS—Calculation of incremental AS-external prefixes. · Forward address—Forwarding address calculation. · N/A—Route calculation is not triggered. |
Current calculation phase |
Current route calculation phase: · Calculation area topology—Calculating area topology. · Calculation router—Calculating routes on routers. · Calculation intra AS—Calculating intra-AS routes. · 7to5 translator—Calculating Type-7-to-Type-5 LSAs. · Forward address—Calculating forwarding addresses. · Calculation inter AS—Calculating AS-external routes. · Calculation end—Ending phase of calculation. · N/A—Route calculation is not triggered. |
Process reset state |
Process reset state: · N/A—The process is not reset. · Under reset—The process is in the reset progress. · Under RIB smooth—The process is synchronizing the RIB. |
Current reset type |
Current process reset type: · N/A—The process is not reset. · Normal—Normal reset. · GR quit—Normal reset when GR quits abnormally. · Delete—Delete OSPF process. · VPN delete—Delete VPN. |
Next reset type |
Next process reset type: · N/A—The process is not reset. · Normal—Normal reset. · GR quit—Normal reset when GR quits abnormally. · Delete—Delete OSPF process. · VPN delete—Delete VPN. |
Reset prepare message replied |
Modules that reply reset prepare messages: · P—Neighbor maintenance module. · L—LSDB synchronization module. · C—Route calculation module. · R—Route redistribution module. |
Reset process message replied |
Modules that reply reset process messages: · P—Neighbor maintenance module. · L—LSDB synchronization module. · C—Route calculation module. · R—Route redistribution module. |
Reset phase of module |
Reset phase of each module: · Main control module: ¡ N/A—Not reset. ¡ Delete area. ¡ Delete process. · Neighbor maintenance (P) module: ¡ N/A—Not reset. ¡ Delete neighbor. ¡ Delete interface. ¡ Delete vlink—Delete virtual link. · LSDB synchronization (L) module: ¡ N/A—Not reset. ¡ Stop timer. ¡ Delete ASE—Delete all ASE LSAs. ¡ Delete ASE maps—Delete ASE LSA maps. ¡ Clear process data. ¡ Delete area LSA—Delete LSAs and maps from an area. ¡ Delete area interface—Delete interfaces from an area. ¡ Delete process—Delete process-related resources. ¡ Restart—Restart process-related resources. · Route calculation (C) module: ¡ N/A—Not reset. ¡ Delete topology—Delete area topology. ¡ Delete router—Delete routes of routers. ¡ Delete intra AS—Delete intra-AS routes ¡ Delete inter AS—Delete AS-external routes. ¡ Delete forward address—Delete forwarding address list. ¡ Delete advertise—Delete advertising router list. · Route redistribution (R) module: ¡ N/A—Not reset. ¡ Delete ABR summary—Delete summary routes of the ABR. ¡ Delete ASBR summary—Delete summary routes of the ASBR. ¡ Delete import—Delete redistributed routes. |
MPLS segment routing |
MPLS SR status: Disabled or Enabled. |
Segment routing adjacency |
Adjacency label allocation status: Disabled or Enabled. |
Configured SRGB |
Configured SRGB range. This field is displayed when SRGB is configured. |
Effective SRGB |
SRGB range that takes effect. |
Segment routing global block |
SRGB range. |
Segment routing local block |
SRLB range. |
Area |
Area ID in the IP address format. |
MPLS TE not enabled |
MPLS TE status: · MPLS TE not enabled. · MPLS TE enabled. |
Authentication type |
Authentication type of the area: · None—No authentication. · Simple—Simple authentication. · Cryptographic—MD5, HMAC-MD5, or HMAC-SHA-256 authentication. |
Area flag |
Type of the area: · Normal. · Stub. · StubNoSummary (totally stub area). · NSSA. · NSSANoSummary (totally NSSA area). |
7/5 translator state |
State of the translator that translates Type-7 LSAs to Type-5 LSAs: · Enabled—The translator is specified through commands. · Elected—The translator is designated through election. · Disabled—The device is not a translator. |
7/5 translate stability timer interval |
Stability interval for Type-7 LSA-to-Type-5 LSA translation. |
SPF scheduled Count |
SPF calculation count in the OSPF area. |
Interface in the area. |
Cost |
Interface cost. |
State |
Interface state. |
Type |
Interface network type. |
MTU |
Interface MTU. |
Cost source |
Link cost source of the interface: · Default—Default link cost. · Manual—Manually specified link cost. · IGP_LDP—Link cost advertised by LDP IGP. · LOW—Link cost applied when the link quality of the interface becomes LOW. · Fallback—Link cost applied when the bandwidth of the Layer 3 aggregate interface falls below the threshold. · Flapping—Link cost applied upon neighbor flapping suppression. · BFD—Link cost applied when the BFD session goes down. |
Priority |
Router priority. |
Timers |
OSPF timers: · Hello—Interval for sending hello packets. · Dead—Interval within which the neighbor is down. · Poll—Interval for sending hello packets. · Retransmit—Interval for retransmitting LSAs. |
FRR backup |
Whether Loop Free Alternate (LFA) calculation is enabled on an interface. |
FRR TI-LFA |
Whether TI-LFA calculation is enabled on an interface. |
Peer flapping suppression |
Neighbor flapping suppression information: · Flapping count—Number of flappings that have occurred. · Threshold—Threshold that triggers flapping suppression. · Mode—Flapping suppression mode. Supported modes are Hold-down and Hold-max-cost. · Remaining interval—Remaining time in seconds before the flapping suppression ends. |
Packet size |
The maximum length of OSPF packets that can be sent by an interface. |
Prefix-SID type |
Prefix SID type: · Absolute—Absolute value of the prefix SID. · Index—Index value of the prefix SID. |
Value |
Prefix SID value. |
Prefix-SID validity |
Whether the prefix SID is valid: · Invalid—The prefix SID is invalid. Possible reasons include: ¡ The prefix SID is out of the SRGB range. ¡ The OSPF process ID configured on the loopback interface is different from the OSPF process ID specified during prefix SID configuration. · Valid—The prefix SID is valid. |
display ospf abr-asbr
Use display ospf abr-asbr to display routes to the ABR or ASBR.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays routes to the ABR and ASBR for all OSPF processes.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you use this command on routers in a stub area, the commands displays no ASBR information.
# Display brief information about routes to the ABR or ASBR.
<Sysname> display ospf abr-asbr
Routing Table to ABR and ASBR
Topology base (MTID 0)
Type Destination Area Cost Nexthop RtType
Inter 3.3.3.3 0.0.0.0 3124 10.1.1.2 ASBR
Intra 2.2.2.2 0.0.0.0 1562 10.1.1.2 ABR
# Display detailed information about routes to the ABR or ASBR.
<Sysname> display ospf abr-asbr verbose
OSPF Process 10 with Router ID 101.1.1.11
Destination: 1.1.1.1 RtType : ASBR
Area : 0.0.0.1 Type : Intra
Nexthop : 150.0.1.12 BkNexthop : 0.0.0.0
Interface : GE1/0/12 BkInterface: N/A
Cost : 1000
Remote-LFA Info:
PQPrefix: 5.5.5.5 PQAdvID : 5.5.5.5
LsIndex: 2
LabelStack: {2301}
TI-LFA backup info:
PNodePrefix: 5.5.5.5 QNodeAdvID : 5.5.5.5
BkInterface: GE1/0/12 BkNexthop : 1.4.0.4
LsIndex: 5
LabelStack: {16005}
Type |
Type of the route to the ABR or ASBR: · Intra—Intra-area route. · Inter—Inter-area route. |
Topology |
Subtopologies are not supported in the current software version. Topology name. If this field displays base, the topology is the base topology. If this field displays other values, the topology is a subtopology. |
MTID |
Subtopologies are not supported in the current software version. Topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology. |
Destination |
Router ID of an ABR or ASBR. |
Area |
ID of the area of the next hop. |
Cost |
Cost from the router to the ABR or ASBR. |
MALsIndex |
SR microloop avoidance label stack index. |
MALabelStack |
SR microloop avoidance label stack (from top to bottom). |
Nexthop |
Next hop address. |
BkNexthop |
Backup next hop address. |
RtType |
Router type: ABR or ASBR. |
Output interface. |
BkInterface |
Backup output interface. |
Remote-LFA back Info |
Remote LFA backup information. |
PQPrefix |
PQ node prefix. |
PQAdvID |
Router ID of the PQ node. |
TI-LFA backup Info |
TI-LFA backup information. |
PNodePrefix |
P node prefix. |
QNodeAdvID |
Router ID of the Q node. |
LsIndex |
Label stack index. |
LabelStack |
Label stack. |
display ospf abr-summary
Use display ospf abr-summary to display ABR summary route information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ABR summary routes for all OSPF processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays information about ABR summary routes for all OSPF areas.
ip-address: Specifies a summary route by its IP address.
verbose: Displays detailed ABR summary route information. If you do not specify this keyword, the command displays brief ABR summary route information.
If you do not specify an IP address, this command displays information about all summary routes on the ABR.
# Display brief information about summary routes on the ABR.
<Sysname> display ospf abr-summary
ABR Summary Addresses
Area: 0.0.0.1
Total summary address count: 1
Net Mask Status Count Cost
100.0.0.0 255.0.0.0 Advertise 1 (Not Configured)
Topology |
MTID |
Area |
Area to which the summary routes belong. |
Total summary address count |
Total number of summary routes. |
Net |
Address of the summary route. |
Mask |
Mask of the summary route address. |
Status |
Advertisement status of the summary route: Advertise or Non-Advertise. |
Count |
Number of summarized routes. |
Cost |
Cost of the summary route. |
# Display detailed information about summary routes on the ABR.
<Sysname> display ospf abr-summary verbose
Area: 0.0.0.1
Net : 100.0.0.0
Mask : 255.0.0.0
Status : Advertise
Cost : (Not Configured)
Routes count: 1
Destination NetMask Metric
100.1.1.0 255.255.255.0 1000
Topology |
MTID |
Destination |
Destination address of a summarized route. |
NetMask |
Network mask of a summarized route. |
Metric |
Metric of a summarized route. |
display ospf asbr-summary
Use display ospf asbr-summary to display ASBR summary route information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ASBR summary routes for all OSPF processes.
ip-address: Specifies an IP address in dotted decimal notation.
If you do not specify an IP address, this command displays information about all ASBR summary routes.
# Display ASBR summary route information in OSPF process 1.
<Sysname> display ospf 1 asbr-summary
Summary Addresses
Summary Address
Net : 30.1.0.0
Mask : 255.255.0.0
Tag : 20
Status : Advertise
Cost : 10 (Configured)
Route count : 2
Destination Net mask Proto Process Type Metric
30.1.2.0 255.255.255.0 OSPF 2 2 1
30.1.1.0 255.255.255.0 OSPF 2 2 1
Table 5 Command output
Topology |
MTID |
Net |
Mask |
Tag |
Tag of the summary route. |
Status |
Advertisement status of the summary route. |
Cost |
Route count |
Destination |
Net mask |
Proto |
Routing protocol from which the route was redistributed. |
Process |
Process ID of the routing protocol from which the route was redistributed. |
Type |
Type of a summarized route. |
Metric |
display ospf event-log
Use display ospf event-log to display OSPF log information.
display ospf [ process-id ] event-log { lsa-flush | lsa-history [ verbose ] | peer [ neighbor-id ] [ slot slot-number ] | route | spf }
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF log information for all processes.
lsa-flush: Specifies LSA aging log information.
lsa-history: Specifies self-originated and received LSA log information.
verbose: Displays detailed self-originated and received LSA log information. If you do not specify this keyword, the command displays brief self-originated and received LSA log information.
peer: Specifies neighbor state change log information.
neighbor-id: Specifies a neighbor by its router ID. If you do not specify this argument, the command displays state change log information for all neighbors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays neighbor state change log information on the member device where the active process resides.
route: Specifies OSPF route log information.
spf: Specifies route calculation log information.
Route calculation logs show the number of routes newly installed in the IP routing table.
Neighbor logs include information about the following events:
· The OSPF neighbor state goes down.
· The OSPF neighbor state goes backward because the local end receives BadLSReq, SeqNumberMismatch, and 1-Way events.
# Display OSPF LSA aging log information for all processes.
<Sysname> display ospf event-log lsa-flush
LSA Flush Log
Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.1.1
Type: 1 LS ID: 2.2.2.2 AdvRtr: 2.2.2.2 Seq#: 80000001
Date: 2013-09-22 Time: 14:47:33 Flushed MaxAge LSA by the self
Type: 1 LS ID: 1.1.1.1 AdvRtr: 1.1.1.1 Seq#: 80000001
Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.2.2
Table 6 Command output
Date/Time |
Time when the device receives an LSA that has reached the maximum age. |
Received MaxAge LSA from X.X.X.X |
The device received an LSA that has reached the maximum age from X.X.X.X. |
Flushed MaxAge LSA by the self |
The device flushed the LSA that has reached the maximum age. |
Type |
LSA type. |
LS ID |
LSA link state ID. |
AdvRtr |
Advertising router. |
Seq# |
LSA sequence number. |
# Display OSPF LSA log information for process 1.
<Sysname> display ospf event-log lsa-history
LSA Log
Date:2016-06-06 Time:10:47:44:007923 Area 0.0.0.2 LSAs received from interface GE1/0/12 10.5.1.5
Type LinkState ID AdvRtr Age Length Sequence
1 10.1.1.5 10.1.1.5 1 36 80000002
Table 7 Command output
Date/Time |
Time when the device generated or received the LSA, which is accurate to microseconds. |
LSAs received from interface XXX X.X.X.X |
The device received an LSA from interface XXX with IP address X.X.X.X. |
Self-originated or self-aged LSAs |
The LSA is self-originated or self-aged. |
Type |
LSA type. |
LinkState ID |
AdvRtr |
Sequence |
# Display OSPF route log information for process 1.
<Sysname> display ospf event-log route
Route Log
Date: 2013-09-22 Time: 14:47:33:070853 Modified 2.1.1.1/32,
Type:Stub
Interface: GE1/0/13, Nexthop:10.5.1.1, Rely NbrID:0x13000004, Flag:0x01
Table 8 Command output
Date/Time |
Route calculation time, which is accurate to microseconds. |
Added/Deleted/Modified |
The route was newly added, deleted, or modified. |
Type |
Route type, which can be Transit, Stub, Inter, Type1, or Type2. |
Output interface of the route. |
Nexthop |
Next hop of the route. |
Rely NbrID |
Recursive neighbor router ID. If Rely is not displayed, the neighbor router is a non-recursive neighbor. |
Flag |
Route attribute flag. |
# Display OSPF route calculation log information for all processes.
<Sysname> display ospf event-log spf
OSPF Process 1 with Router ID 1.1.1.2
SPF Log
Date Time Duration Intra Inter External Reason
2012-06-27 15:28:26 0.95 1 1 10000 Intra-area LSA
2012-06-27 15:28:23 0.2 0 0 0 Area 0 full neighbor
2012-06-27 15:28:19 0 0 0 0 Intra-area LSA
2012-06-27 15:28:19 0 0 0 0 external LSA
2012-06-27 15:28:19 0.3 0 0 0 Intra-area LSA
2012-06-27 15:28:12 0 1 0 0 Intra-area LSA
2012-06-27 15:28:11 0 0 0 0 Routing policy
2012-06-27 15:28:11 0 0 0 0 Intra-area LSA
Table 9 Command output
Topology |
MTID |
Date/Time |
Time when the route calculation starts. |
Duration |
Duration of the route calculation, in seconds. |
Intra |
Number of intra-area routes newly installed in the IP routing table. |
Inter |
Number of inter-area routes newly installed in the IP routing table. |
External |
Number of external routes newly installed in the IP routing table. |
Reason |
Reasons why the route calculation is performed: · Intra-area LSA—Intra-area LSA changes. · Inter-area LSA—Inter-area LSA changes. · External LSA—External LSA changes. · Configuration—Configuration changes. · Area 0 full neighbor—Number of FULL-state neighbors in Area 0 changes. · Area 0 up interface—Number of interfaces in up state in Area 0 changes. · LSDB overflow state—Overflow status changes. · AS number—AS number changes. · ABR summarization—ABR summarization changes. · GR end—GR ends. · Routing policy—Routing policy changes. · Intra-area tunnel—Intra-area tunnel changes. · Others—Other reasons. |
# Display OSPF neighbor log information for OSPF process 1.
<Sysname> display ospf 1 event-log peer
Neighbors Log
Date Time Local Address Remote Address Router ID Reason
2012-12-31 12:35:45 197.168.1.1 197.168.1.2 2.2.2.2 IntPhyChange
2012-12-31 12:35:19 197.168.1.1 197.168.1.2 2.2.2.2 ConfNssaArea
2012-12-31 12:34:59 197.168.1.1 197.168.1.2 2.2.2.2 SilentInt
Table 10 Command output
Date/Time |
Time when the neighbor state changes. |
Local Address |
Local address of the neighbor relationship. |
Remote Address |
Peer address of the neighbor relationship. |
Router ID |
Neighbor router ID. |
Reason |
Reasons for neighbor state changes: · ResetConnect—The connection is lost due to insufficient memory. · IntChange—The interface parameter has changed. · VlinkChange—The virtual link parameter has changed. · ResetOspf—The OSPF process is reset. · UndoOspf—The OSPF process is deleted. · UndoArea—The OSPF area is deleted. · UndoNetwork—The interface is disabled. · SilentInt—The interface is configured as a silent interface. · IntLogChange—The logical attribute of the interface has changed. · IntPhyChange—The physical attribute of the interface has changed. · IntVliChange—The virtual link attribute of the interface has changed. · VlinkDown—The virtual link goes down. · DeadExpired—The dead timer expires. · ConfStubArea—The interface is configured with stub area parameters. · ConfNssaArea—The interface is configured with NSSA area parameters. · AuthChange—The authentication type has changed. · OpaqueChange—The Opaque capability has changed. · Retrans—Excessive retransmissions. · LLSChange—The LLS capability has changed. · OOBChange—The OOB capability has changed. · GRChange—The GR capability has changed. · BFDDown—The interface is shut down by BFD. · BadLSReq—The interface receives BadLSReq events. · SeqMismatch—The interface receives SeqNumberMismatch events. · 1-Way—The interface receives 1-Way events. |
reset ospf event-log
display ospf event-log hello
Use display ospf event-log hello to display OSPF log information about received or sent hello packets.
display ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } [ neighbor-id ] [ slot slot-number ]
received: Specifies log information for received hello packets.
sent: Specifies log information for sent hello packets.
abnormal: Specifies log information for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies log information for received hello packets that were dropped.
failed: Specifies log information for hello packets that failed to be sent.
neighbor-address: Specifies a neighbor by its IP address. If you do not specify this argument, the command displays received or sent hello packet log information for all neighbors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays received or sent hello packet log information on the member device where the active process resides.
# Display log information for sent hello packets.
<Sysname> display ospf event-log hello sent
OSPF Process 1 with Router ID 5.5.5.5
Hello Log
Interface: GE1/0/12
Neighbor address: 10.1.1.2, NbrID: 1.0.0.2
First 4 hello packets sent:
2019-09-05 20:10:10:121, failed, errno: 132
2019-09-05 20:10:20:121, succeeded
2019-09-05 20:10:30:121, succeeded
2019-09-05 20:10:40:121, succeeded
Last 4 hello packets sent before Full->Down at 2019-09-06 14:52:10:121
2019-09-06 14:51:40:021, succeeded
2019-09-06 14:51:50:021, succeeded
2019-09-06 14:52:00:021, failed, errno: 132
2019-09-06 14:52:10:010, failed, errno: 132
Interface: GE1/0/12
Last 4 hello packets sent before Full->Init at 2019-09-06 11:16:20:171
2019-09-06 11:15:20:121, succeeded
2019-09-06 11:15:30:121, succeeded
2019-09-06 11:15:40:121, succeeded
2019-09-06 11:15:50:121, succeeded
Table 11 Command output
Interface that sends the hello packets. |
Neighbor address |
IP address of the neighbor. |
NbrID |
Router ID of the neighbor. |
First 4 hello packets sent |
Time and result (succeeded or failed) for sending the first four hello packets. For a packet failed to be sent, an error code is displayed in the errno field. |
Last 4 hello packets sent before Full->Down at 2018-01-06 14:52:10:121 |
Time and result (succeeded or failed) for sending the last four hello packets before neighbor state change. For a packet failed to be sent, an error code is displayed in the errno field. |
# Display log information for hello packets that failed to be sent.
<Sysname> display ospf event-log hello sent failed
Hello Log
Date: 2019-09-06 Time: 14:51:20:121 Interface: GE1/0/12
Destination address: 224.0.0.5, sent failed, errno: 132
Date: 2019-09-06 Time: 11:20:20:116 Interface: GE1/0/13
Destination address: 10.1.1.2, sent failed, errno: 132
Table 12 Command output
Date |
Date for the hello packet sending failure, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day. |
Time |
Time for the hello packet sending failure, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds. |
Interface that sends the hello packet. |
Destination address |
Destination IP address of the hello packet. |
errno |
Error code for the hello packet sending failure. |
# Display log information for abnormal hello packets sent.
<Sysname> display ospf event-log hello sent abnormal
Hello Log
Date: 2019-09-06 Time: 11:21:12:121 Interface: GE1/0/13
Destination address: 224.0.0.5, last one sent: 2019-09-06 11:20:51:916
Date: 2019-09-06 Time: 11:56:21:312 Interface: GE1/0/13
Destination address: 10.1.1.2, last one sent: 2019-09-06 11:56:02:691
Table 13 Command output
Date |
Date for sending the abnormal hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day. |
Time |
Time for sending the abnormal hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds. |
Interface that sends the abnormal hello packet. |
Destination IP address of the abnormal hello packet. |
last one sent |
Time for sending the last hello packet before sending the abnormal hello packet. |
# Display log information for received hello packets.
<Sysname> display ospf event-log hello received
Hello Log
Interface: GE1/0/12
First 4 hello packets received:
2019-09-05 20:11:10:121
2019-09-05 20:11:20:121
2019-09-05 20:11:30:121
2019-09-05 20:11:40:121
Last 4 hello packets received before Exchange->Down at 2019-09-06 14:52:10:121
2019-09-06 14:51:10:121
2019-09-06 14:51:20:121
2019-09-06 14:51:30:121
2019-09-06 14:51:40:121
Interface: GE1/0/12
Neighbor address: 10.1.1.1, NbrID: 1.0.0.1
2019-09-06 19:11:15:121
2019-09-06 19:11:25:121
2019-09-06 19:11:35:121
2019-09-06 19:11:45:121
Last 4 hello packets received before Full->Init at 2019-09-06 21:16:20:171
2019-09-06 21:15:45:121
2019-09-06 21:15:55:121
2019-09-06 21:16:05:121
2019-09-06 21:16:15:121
Table 14 Command output
Interface that receives the hello packets. |
Neighbor address |
NbrID |
First 4 hello packets received |
Time for receiving the first four hello packets. |
Last 4 hello packets received before Full->Init at 2019-09-06 21:16:20:171 |
Time for receiving the last four hello packets before neighbor state change, in the format of YYYY-MM-DD hh:mm:ss:xxx. YYYY represents the year, MM represents the month, and DD represents the day. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds. |
# Display log information for received hello packets that were dropped.
<Sysname> display ospf event-log hello received dropped
Hello Log
Date: 2019-09-06 Time: 14:51:22:791 Interface: GE1/0/12
Source address: 10.1.1.1, NbrID: 1.0.0.1, area: 0.0.0.1
Drop reason: Hello-time mismatch
Source address: 10.1.1.2, NbrID: 1.0.0.2, area: 0.0.0.1
Drop reason: NP-bit mismatch
Table 15 Command output
Date |
Date for dropping the received hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day. |
Time |
Time for dropping the received hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds. |
Interface that receives the hello packet. |
Source address |
Source IP address of the received hello packet. |
NbrID |
area |
Area to which the neighbor interface belongs. |
Drop reason |
Reason for dropping the hello packet: · Area under reset—The area is in the reset progress. · Router ID conflict—Route ID conflict. · Area mismatch—Area ID mismatch. · Unknown virtual link—The hello packet is from an unknown virtual link. · Authentication failure—Authentication check failure. · Peer address check failure—Neighbor address check failure. · Not DR or BDR—The destination IP address of the hello packet is 224.0.0.6, but the interface is not a DR or BDR. · Unknown unicast peer—The hello packet is from an unknown unicast neighbor. · Option mismatch—Option mismatch. · Netmask mismatch—Subnet mask mismatch. · Address mismatch—Address range mismatch. · Hello-time mismatch—Hello timer mismatch. · Dead-time mismatch—Dead timer mismatch. · Peer change—The source IP address or router ID has changed. |
# Display log information for abnormal hello packets received.
<Sysname> display ospf event-log hello received abnormal
Hello Log
Date: 2019-09-06 Time: 10:12:22:121 Interface: GE1/0/12
Last one received: 2019-09-06 10:12:04:212
Last one received: 2019-09-06 14:51:05:113
Table 16 Command output
Date&Tme |
Date for receiving the abnormal hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day. |
Time |
Time for receiving the abnormal hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds. |
Interface that receives the abnormal hello packet. |
Source address |
Source IP address of the received abnormal hello packet. |
NbrID |
area |
Last one received |
Time for receiving the last hello packet before receiving the abnormal hello packet. |
reset ospf event-log hello
Use display ospf fast-reroute lfa-candidate to display OSPF FRR backup next hop information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays FRR backup next hop information for all processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays FRR backup next hop information for all OSPF areas.
# Display OSPF FRR backup next hop information.
<Sysname> display ospf 1 area 0 fast-reroute lfa-candidate
LFA Candidate List
Area: 0.0.0.0
Candidate nexthop count: 2
NextHop IntIP Interface
10.0.1.1 10.0.1.2 GE1/0/13
10.0.11.1 10.0.11.2 GE1/0/14
Table 17 Command output
Topology |
MTID |
Area |
Area to which the backup next hops belong. |
Candidate nexthop count |
Number of backup next hops. |
NextHop |
IntIP |
IP address of the output interface. |
Output interface. |
Use display ospf global-statistics to display global OSPF statistics.
display ospf global-statistics [ public | vpn-instance vpn-instance-name ]
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify the public keyword or the vpn-instance vpn-instance-name option, this command displays global OSPF statistics for the public network and all VPN instances.
# Display global OSPF statistics.
<Sysname> display ospf global-statistics
OSPF global statistics
Instance count : 1
Process count : 1
Interface information
Down : 0
Up : 1
Neighbor information
Down : 0
Init : 0
Attempt : 0
2-Way : 0
ExStart : 0
Exchange : 0
Loading : 0
Full : 1
Packets sent : 26
Packets received : 27
LSA count : 6
Route count : 2
Table 18 Command output
Instance count |
This field displays the number of VPN instances and public network that are configured with OSPF. · If OSPF is configured only for the public network, the value is fixed at 1. · If OSPF is configured only for VPN instances, the value equals the number of the VPN instances. · If OSPF is configured for both the public network and VPN instances, the value equals the number of VPN instances plus 1. |
Process count |
Number of OSPF processes. |
Interface information |
Statistics about interface status. |
Down |
Number of interfaces in Down status. |
Up |
Number of interfaces in Up status. |
Neighbor information |
Statistics about neighbor status. |
Down |
Number of neighbor routers in Down status. |
Attempt |
Number of neighbor routers in Up status. |
Init |
Number of neighbor routers in Init status. |
2-Way |
Number of neighbor routers in 2-Way status. |
ExStart |
Number of neighbor routers in ExStart status. |
Exchange |
Number of neighbor routers in Exchange status. |
Loading |
Number of neighbor routers in Loading status. |
Full |
Number of neighbor routers in Full status. |
Packets sent |
Number of OSPF packets sent. |
Packets received |
Number of OSPF packets received. |
LSA count |
Total number of LSAs in the LSDB. |
Route count |
Total number of OSPF routes. |
display ospf graceful-restart
Use display ospf graceful-restart to display GR information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays GR information for all processes.
verbose: Displays detailed GR information. If you do not specify this keyword, the command displays brief GR information.
# Display detailed GR information.
<Sysname> display ospf graceful-restart verbose
Graceful Restart information
Graceful Restart capability : Enable(IETF)
Graceful Restart support : Planned and unplanned,Partial
Helper capability : Enable(IETF)
Helper support : Planned and unplanned(IETF),Strict LSA check
Current GR state : Normal
Graceful Restart period : 40 seconds
Number of neighbors under Helper: 0
Number of restarting neighbors : 0
Last exit reason:
Restarter : None
Helper : None
Area: 0.0.0.0
Authentication type: None Area flag: Normal
Area up Interface count: 2
Interface: 40.4.0.1 (GigabitEthernet1/0/13)
Restarter state: Normal State: P-2-P Type: PTP
Last exit reason:
Restarter : None
Helper : None
Neighbor count of this interface: 1
Neighbor IP address GR state Last Helper exit reason
3.3.3.3 40.4.0.3 Normal None
Virtual-link Neighbor-ID -> 4.4.4.4, Neighbor-State: Full
Interface: 20.2.0.1 (Vlink)
Transit Area: 0.0.0.1
Last exit reason:
Restarter : None
Helper : None
4.4.4.4 20.2.0.4 Normal Reset neighbor
Table 19 Command output
OSPF Process 1 with Router ID 1.1.1.1 Graceful Restart information |
GR information for OSPF process 1 with router ID 1.1.1.1. |
Graceful Restart capability |
Whether GR is enabled: · Enable(IETF)—IETF GR is enabled. · Enable(Nonstandard)—Non-IETF GR is enabled. · Disable—GR is disabled. |
Graceful Restart support |
GR modes that the process supports (displayed only when GR is enabled): · Planned and unplanned—Supports both planned and unplanned GR. · Planned only—Supports only planned GR. · Partial—Supports partial GR. · Global—Supports global GR. |
Helper capability |
Helper capability that the process supports: · Enable(IETF)—Supports IETF GR helper capability. · Enable(Nonstandard)—Supports non-IETF GR helper capability. · Enable(IETF and nonstandard)—Supports both IETF GR helper capability and non-IETF GR helper capability. · Disable—Does not support GR helper capability. |
Helper support |
This field is available only when the helper capability is enabled. Policies that the helper supports: · Strict lsa check—The helper supports strict LSA checking. · Planned and unplanned—The helper supports planned and unplanned GR. · Planned only—The helper supports only planned GR. |
Current GR state |
GR state: · Normal—GR is not in progress or has completed. · Under GR—GR is in process. · Under Helper—The process is acting as GR helper. |
Last exit reason |
Last exit reason: · Restarter—Reason that the restarter exited most recently. · Helper—Reason that the helper exited most recently. |
Area |
Area ID in IP address format. |
Area flag |
Area up Interface count |
Number of up interfaces in the area. |
Restarter state |
Restarter state on the interface. |
State |
Interface state. |
Type |
Neighbor count of this interface |
Neighbors of an interface. |
Neighbor |
IP address |
Neighbor IP address. |
GR state |
Neighbor GR state: · Normal—GR is not in progress or has completed. · Under GR—GR is in process. · Under Helper—The process is acting as GR helper. |
Last Helper exit reason |
Virtual-link Neighbor-ID |
Router ID of the virtual link's neighbor. |
Neighbor-State |
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, and Full. |
Output interface of the virtual link. |
display ospf hostname-table
Use display ospf hostname-table to display the router ID-to-host name mapping table.
display ospf [ process-id ] hostname-table
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify an OSPF process, this command displays the router ID-to-host name mapping tables for all OSPF processes.
# Display the router ID-to-host name mapping tables for all OSPF processes.
<RouterA> display ospf hostname-table
OSPF Process 1 with Router ID 192.168.56.21
Hostname Table Information
Area: 0.0.0.1
Router ID Hostname
192.168.56.21 RouterA
display ospf interface
Use display ospf interface to display OSPF interface information.
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF interface information for all OSPF processes.
verbose: Displays detailed OSPF information for all interfaces.
If you do not specify the interface-type interface-number argument or the verbose keyword, this command displays brief information for all interfaces.
# Display brief OSPF information for all interfaces.
<Sysname> display ospf interface
OSPF Process 1 with Router ID 192.168.1.1
Interfaces
Area: 0.0.0.0
IP Address Type State Cost Pri DR BDR
192.168.1.1 PTP P-2-P 1562 1 0.0.0.0 0.0.0.0
Area: 0.0.0.1
172.16.0.1 Broadcast DR 1 1 172.16.0.1 0.0.0.0
Table 20 Command output
Area |
Area ID of the interface. |
IP Address |
Interface IP address (regardless of whether TE is enabled or not). |
Type |
Interface network type: · PTP (P2P). · PTMP (P2MP). · Broadcast. |
State |
Interface state: · Down—No protocol traffic can be sent or received on the interface. · Loopback—The interface is in loopback state and it cannot forward traffic. · Waiting—The interface starts sending and receiving Hello packets. The router is trying to determine the identity of the (Backup) designated router for the network. · P-2-P—The interface will send Hello packets at the hello interval, and try to establish an adjacency with the neighbor. · DR—The router is the designated router on the network. · BDR—The router is the backup designated router on the network. · DROther—The router is a DR Other router on the attached network. |
Cost |
Interface cost. |
Pri |
Router priority. |
DR |
DR on the interface's network segment. |
BDR |
BDR on the interface's network segment. |
# Display detailed OSPF information for all interfaces.
<Sysname> display ospf interface verbose
Interfaces
Area: 0.0.0.0
Interface: 172.16.0.1 (GigabitEthernet1/0/12)
Priority: 1
Designated router: 172.16.0.1
FRR backup: Enabled
FRR TI-LFA: Enabled
Primary path detection mode: BFD ctrl
Enabled by interface configuration (including secondary IP addresses)
Flapping count: 0
Threshold: 10
BFD: echo
Cryptographic authentication: Enabled, inherited
The last key is 3.
The rollover is in progress, 2 neighbor(s) left.
LDP state: No-LDP
LDP sync state: Achieved
Link quality: GOOD, cost adjusted at low quality: 50
Packet size: 1000
Value: 876, Explicit-null, N-flag-clear
Process ID: ospf 1
Static adjacency SID:
Nexthop Adjacency-SID Type Result
100.100.100.100 15555 Absolute Succeeded
8.8.8.8 1000 Index Conflicting
MTID Cost Disabled Topology name
0 1 No base
Priority: 1
FRR backup: Enabled
FRR TI-LFA: Enabled
Mode: Hold-max-cost
Remaining interval: 420 s
0 65535 No base
Table 21 Command output
Information about the interface, such as the IP address. |
Cost source |
Timers |
OSPF timers (in seconds): Hello, Dead, Poll, and Retransmit. |
Transmit Delay |
LSA transmission delay on the interface, in seconds. |
FRR backup |
Whether LFA calculation is enabled on an interface. |
FRR remote-LFA |
Whether remote LFA calculation is enabled on an interface. |
FRR TI-LFA |
Primary path detection mode |
Primary link detection mode: · BFD ctrl—BFD control packet mode. · BFD echo—BFD echo packet mode. |
Enabled by interface configuration (including secondary IP addresses) |
OSPF is enabled on the interface (including secondary IP addresses). |
BFD |
BFD session mode enabled on the interface: · ctrl—BFD control packet mode. · echo—BFD echo packet mode. |
Cryptographic authentication: Enabled, inherited |
Cryptographic authentication mode (MD5, HMAC-MD5, or HMAC-SHA-256) is used by the interface. If the interface uses the simple authentication mode, this field displays Simple authentication: Enabled. The inherited attribute indicates that the interface uses the authentication mode specified for the area to which the interface belongs. |
The last key |
Most recent MD5, HMAC-MD5, or HMAC-SHA-256 authentication key ID. |
The rollover is in progress, 2 neighbor(s) left |
Key rollover for MD5, HMAC-MD5, or HMAC-SHA-256 authentication is in progress, and two neighbors have not completed the key rollover. |
LDP state |
LDP state: · Init—Initialization state. LDP has not been delivered. · No-LDP—LDP is not configured. · Not ready—LDP sessions have not been established. · Ready—LDP sessions have been established. |
LDP sync state |
LDP IGP synchronization state: · Init—Initialization state. · Achieved—LDP has been synchronized. · Max cost—OSPF advertises the maximum cost in LSAs. |
Link quality |
Link quality: · GOOD—The bit error ratio is below the upper threshold or drops below the lower threshold. · LOW—The bit error ratio exceeds the upper threshold. This field is displayed only when the interface is configured with the ospf link-quality adjust-cost command. |
cost adjusted at low quality |
Interface cost adjustment parameters: · xx—Value added to the interface cost. When the link quality is LOW, the interface cost is xx plus the original interface cost. · Maximum—Sets the maximum interface cost when the link quality is LOW. This field is displayed only when the interface is configured with the ospf link-quality adjust-cost command. |
Packet size |
Prefix-SID type |
Nexthop |
Next hop address. This field displays 0.0.0.0 for a P2P network. |
Type |
Adjacency SID type: · Absolute—Absolute value of the adjacency SID. · Index—Index value of the adjacency SID. |
Result |
Adjacency SID application result: · Succeeded—Applied for adjacency SID successfully. · Conflicting—Adjacency SID conflict occurred. · Init—Adjacency SID application is in progress or adjacency SID assignment is not enabled. |
Value |
Prefix SID value and flag information: · Explicit-null—The upstream neighbor uses an explicit null flag to replace the prefix SID. · N-flag-clear—The prefix SID is the SID to a group of SR nodes. |
MTID |
Cost |
Cost of the interface route in the topology. |
Disabled |
Whether OSPF is disabled from advertising the topology for the interface: Yes or No. |
Topology name |
display ospf interface hello
Use display ospf interface hello to display information about hello packets sent by OSPF interfaces.
display ospf [ process-id ] interface [ interface-type interface-number ] hello
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays hello packet information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information about the hello packets sent by all OSPF interfaces.
This command displays information for only the hello packets sent in multicast.
# Display information about hello packets sent by all OSPF interfaces.
<Sysname> display ospf interface hello
Interfaces
Area: 0.0.0.0
2019-09-05 11:05:10:121, succeeded
2019-09-05 11:05:20:121, succeeded
2019-09-05 11:05:30:121, succeeded
2019-09-05 11:05:40:121, succeeded
Last 4 hello packets sent:
2019-09-06 11:15:10:121, succeeded
Table 22 Command output
Area |
Area to which the interface belongs. |
IP address of the interface. |
Time and result (succeeded or failed) for sending the first four hello packets. |
Last 4 hello packets sent |
Time and result (succeeded or failed) for sending the last four hello packets when the command is executed. |
display ospf lsdb
Use display ospf lsdb to display OSPF LSDB information.
display ospf [ process-id ] lsdb [ brief | originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb opaque-as [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb opaque-as [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb ase [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb ase [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDB information for all OSPF processes.
age: Displays LSAs whose ages are in the specified range. If you do not specify this keyword, the command displays all LSAs in the LSDB.
max-value max-age-value: Specifies the maximum age of LSAs, in the range of 0 to 3600 seconds. The default value is 3600.
min-value min-age-value: Specifies the minimum age of LSAs, in the range of 0 to 3600 seconds. The default value is 0. The min-age-value cannot be greater than the max-age-value.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays LSDB information for all OSPF areas.
brief: Displays brief LSDB information.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
network: Displays Type-2 LSA (Network LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
router: Displays Type-1 LSA (Router LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
link-state-id: Specifies a link state ID in the IP address format.
originate-router advertising-router-id: Specifies an advertising router by its ID.
self-originate: Displays information about self-originated LSAs.
hostname host-name: Displays LSAs advertised by the router with the specified host name. If you do not specify this option, the command displays all LSAs in the OSPF LSDB.
resolve-hostname: Displays host names in OSPF LSDB information. If you do not specify this keyword, the OSPF LSDB information does not include host names.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
OSPF Process 1 with Router ID 192.168.0.1
Link State Database
Area: 0.0.0.0
Type LinkState ID AdvRouter Age Len Sequence Metric
Router 192.168.0.2 192.168.0.2 474 36 80000004 0
Router 192.168.0.1 192.168.0.1 21 36 80000009 0
Network 192.168.0.1 192.168.0.1 321 32 80000003 0
Sum-Net 192.168.1.0 192.168.0.1 321 28 80000002 1
Sum-Net 192.168.2.0 192.168.0.2 474 28 80000002 1
Area: 0.0.0.1
Router 192.168.0.1 192.168.0.1 21 36 80000005 0
Sum-Net 192.168.2.0 192.168.0.1 321 28 80000002 2
Sum-Net 192.168.0.0 192.168.0.1 321 28 80000002 1
Type 9 Opaque (Link-Local Scope) Database
Flags: * -Vlink interface LSA
Type LinkState ID AdvRouter Age Len Sequence Interfaces
*Opq-Link 3.0.0.0 7.2.2.1 8 14 80000001 10.1.1.2
*Opq-Link 3.0.0.0 7.2.2.2 8 14 80000001 20.1.1.2
# Display OSPF LSDB information, including the host names of the advertising routers.
<Sysname> display ospf lsdb resolve-hostname
Link State Database
Area: 0.0.0.0
Router 1.1.1.1 1.1.1.1 1419 36 80000004 0
Router 2.2.2.2 RouterB 1420 36 80000004 0
Network 192.168.12.2 RouterB 1420 32 80000001 0
Sum-Net 192.168.13.0 1.1.1.1 1456 28 80000001 1
Area: 0.0.0.1
Router 3.3.3.3 3.3.3.3 1416 36 80000003 0
Router 1.1.1.1 1.1.1.1 1415 36 80000003 0
Network 192.168.13.2 3.3.3.3 1416 32 80000001 0
Sum-Net 192.168.12.0 1.1.1.1 1456 28 80000001 1
Type 10 Opaque (Area-Local Scope) Database
Type LinkState ID AdvRouter Age Len Sequence Area
Opq-Area 4.0.0.0 RouterB 470 32 80000001 0.0.0.0
Table 23 Command output
Area |
LSDB information for the area. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
Advertising router or its host name. |
Age |
Age of the LSA. |
Len |
Length of the LSA. |
Sequence |
Sequence number of the LSA. |
Metric |
Cost of the LSA. |
*Opq-Link |
Opaque LSA generated by a virtual link. |
Opq-Area |
Received Type-10 LSA. |
# Display Type-2 LSA (Network LSA) information in the LSDB.
<Sysname> display ospf 1 lsdb network
Link State Database
Area: 0.0.0.0
Type : Network
LS ID : 192.168.0.2
Adv Rtr : 192.168.2.1
LS age : 922
Len : 32
Options : E
Seq# : 80000003
Checksum : 0x8d1b
Net mask : 255.255.255.0
Attached router 192.168.1.1
Attached router 192.168.2.1
Area: 0.0.0.1
Type : Network
LS ID : 192.168.1.2
Adv Rtr : 192.168.1.2
LS age : 782
Len : 32
Options : NP
Seq# : 80000003
Checksum : 0x2a77
Attached router 192.168.1.2
# Display Type-2 LSA (Network LSA) information in the LSDB, including the host names of the advertising routers.
<Sysname> display ospf 1 lsdb network resolve-hostname
Link State Database
Area: 0.0.0.0
Type : Network
LS ID : 192.168.12.2
Adv Rtr : 2.2.2.2
Hostname : RouterB
LS age : 1552
Len : 32
Options : O E
Seq# : 80000001
Checksum : 0xbdd0
Attached router 1.1.1.1
Attached router 2.2.2.2
Area: 0.0.0.1
Type : Network
LS ID : 192.168.13.2
Adv Rtr : 3.3.3.3
LS age : 1548
Len : 32
Options : O E
Seq# : 80000001
Checksum : 0xc6be
Attached router 3.3.3.3
Table 24 Command output
Type |
LSA type. |
LS ID |
DR IP address. |
Adv Rtr |
Router that advertised the LSA. |
Hostname |
Host name of the advertising router. |
LS age |
LSA age time. |
Len |
LSA length. |
Options |
LSA options: · O—Opaque LSA advertisement capability. · E—AS External LSA reception capability. · EA—External extended LSA reception capability. · DC—On-demand link support. · N—NSSA external LSA support. · P—Capability of an NSSA ABR to translate Type-7 LSAs into Type-5 LSAs. |
Seq# |
Checksum |
LSA checksum. |
Net mask |
Network mask. |
Attached router |
ID of the router that established adjacency with the DR, and ID of the DR itself. |
# Display Type-10 LSA (opaque LSA) information in the LSDB for OSPF process 1.
<Sysname> display ospf 1 lsdb opaque-area
Link State Database
Area: 0.0.0.0
Type : Opq-Area
LS ID : 4.0.0.0
Adv Rtr : 1.1.1.1
LS age : 1311
Len : 52
Options : O E
Seq# : 8000015c
Checksum : 0x4323
Opaque type: 4(Router information)
Opaque ID: 0
Router information TLV:
Length : 4
Capabilities:
All Capability Bits: 0x60000000
Graceful restart helper capable
Stub router capable
Segment routing algorithm TLV:
Length : 1
Algorithm: 0
Segment routing range TLV:
Length: 12
Range : 1001
SID sub-TLV:
Length: 3
Label : 16000
Type : Opq-Area
LS ID : 1.0.0.2
Adv Rtr : 1.1.1.1
LS age : 1239
Len : 192
Options : O E
Seq# : 80000001
Checksum : 0x9412
Opaque type: 1(Traffic Engineering)
Opaque ID: 2
Link Type : Broadcast
Link ID : 12.1.1.2
Local Interface Address : 12.1.1.1
TE Metric : 1
Maximum Bandwidth : 0 bytes/sec
Maximum Reservable BW : 0 bytes/sec
Administrative Group : 0x0
IGP Metric : 1
Number of SRLGs : 3
SRLG [1]:10
SRLG [2]:20
SRLG [3]:30
Unreserved Bandwidth for each TE Class:
TE class 0 = 0 bytes/sec
TE class 1 = 0 bytes/sec
TE class 2 = 0 bytes/sec
TE class 3 = 0 bytes/sec
TE class 4 = 0 bytes/sec
TE class 5 = 0 bytes/sec
TE class 6 = 0 bytes/sec
TE class 7 = 0 bytes/sec
Bandwidth Constraint Model: Prestandard DS-TE RDM
Bandwidth Constraints:
BC [ 0] = 0 bytes/sec
BC [ 1] = 0 bytes/sec
Type : Opq-Area
LS ID : 7.0.0.0
Adv Rtr : 1.1.1.1
LS age : 1311
Len : 44
Options : O E
Seq# : 8000012f
Checksum : 0xabcf
Opaque type: 7(Extended prefix)
Opaque ID: 0
Extended prefix TLV:
Length : 20
Route type: 1
AF : 0
Flags : N
Prefix : 23.1.1.1/32
SID sub-TLV:
Length : 8
Flags : NP/-/E/-/-
MTID : 0
Algorithm : 0
SID index : 101
# Display Type-11 LSA (opaque LSA) information in the LSDB for OSPF process 1.
<Sysname> display ospf 1 lsdb opaque-as
Link State Database
Type : Opq-AS
LS ID : 7.0.0.1
Adv Rtr : 3.3.3.3
LS Age : 78
Len : 44
Options : O E
Seq# : 80000001
Checksum : 0xc164
Opaque Type: 7(Extended prefix)
Opaque ID: 1
Length : 20
Route type: 5
AF : 0
Flags : -
Prefix : 5.5.5.5/32
SID sub-TLV:
Length : 8
Flags : NP/-/-/-/-
MTID : 0
Algorithm : 0
SID index : 50
Table 25 Command output
Type |
LSA type: · Opq-Area—Type-10 LSA, which is flooded within an area. · Opq-AS—Type-11 LSA, which is flooded within an AS. |
LS ID |
IP address of the DR. |
Adv Rtr |
Hostname |
Host name of the router that advertised the LSA. |
LS age |
LSA aging time. |
Len |
LSA length. |
Options |
LSA options: · O—Opaque LSA advertisement capability. · E—AS External LSA reception capability. · EA—External extended LSA reception and forwarding capability. · DC—On-demand link support. · N—NSSA external LSA support. · P—Capability of an NSSA ABR to translate Type-7 LSAs into Type-5 LSAs. |
Seq# |
Checksum |
LSA checksum. |
Opaque type |
Opaque type: · 1(Traffic Engineering)—Opaque LSAs used for MPLS TE. · 4(Router information)—Opaque LSAs used for route capability advertisement. · 7(Extended prefix)—Opaque LSAs used for SID or MPLS label advertisement. |
Opaque ID |
Opaque ID. |
Link Type |
Link type: · Point to Point. · Point to Multi Point. · Broadcast. |
Link ID |
Link ID. |
Local Interface Address |
Primary IP address of the local interface. |
TE Metric |
TE metric. |
Maximum Bandwidth |
Maximum bandwidth of the link. |
Maximum Reservable BW |
Maximum bandwidth that can be reserved for the link. |
Administrative Group |
Administrative group attribute of the link. |
IGP Metric |
IGP metric. |
Number of SRLGs. The n argument in SRLG [n] represents the sequence number of the SRLG. For example, SRLG [1] represents the first SRLG. |
Unreserved Bandwidth for each TE Class |
Available bandwidth reserved for each TE class. |
Bandwidth Constraint Model |
Bandwidth constraint model: · Prestandard DS-TE RDM. · IETF DS-TE RDM. · IETF DS-TE MAM. |
Bandwidth Constraints |
Bandwidth constraint value. The Prestandard model supports 2 BCs, and the IETF models support a maximum of 4 BCs. |
MPLS TE Router ID |
Local LSR ID. |
Router information TLV |
Route capability TLV information. |
Length |
TLV length in bytes. |
Capabilities |
Route capabilities. |
All capability bits |
All capability bits, indicating the features that the device supports. |
Traffic Engineering enabled area |
The OSPF area is enabled with MPLS TE. |
Algorithm |
Prefix related algorithm. |
Range |
Label range. |
SID sub-TLV |
Prefix SID sub-TLV. |
Label |
Minimum label value. |
Route type |
Route type: · 1—Intra-area route. · 3—Inter-area route. · 5—Autonnmous System (AS) external route. · 7—Not-So-Stubby Area (NSSA) external route. |
AF |
Address family information. |
Flags |
Prefix SID flag: · A—Attach flag (A-Flag). Inter-area prefix generated by the ABR. · N—Node flag (N-Flag). The prefix SID is the SID to an SR node. |
Prefix |
Prefix information. |
SID sub-TLV |
Prefix SID sub-TLV length. |
Flags |
Flag carried in the prefix SID sub-TLV: · NP—No-PHP flag. The penultimate node cannot pop the prefix SID. · E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets. · V—Value/Index flag. The value of the prefix SID is an absolute value. |
MTID |
Subtopologies are not supported in the current software version. Multi-topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology. |
Algorithm |
SID index |
Index value of the prefix SID |
display ospf nexthop
Use display ospf nexthop to display OSPF next hop information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays next hop information for all OSPF processes.
# Display OSPF next hop information.
<Sysname> display ospf nexthop
Neighbor Nexthop Information
NbrID Nexthop Interface RefCount Status
192.168.12.1 0.0.0.0 GE1/0/13 4 Valid
192.168.12.2 192.168.12.2 GE1/0/13 3 Valid
192.168.12.1 0.0.0.0 Loop100 1 Valid
Table 26 Command output
NbrID |
Nexthop |
Next hop address. |
Output interface. |
RefCount |
Reference count (routes that use the next hop). |
Status |
Next hop status: · Valid. · Invalid. |
display ospf non-stop-routing status
Use display ospf non-stop-routing status to display OSPF NSR information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF NSR information for all OSPF processes.
# Display OSPF NSR information.
<Sysname> display ospf non-stop-routing status
OSPF Process 1 with Router ID 192.168.33.12
Non Stop Routing information
Non Stop Routing capability : Enabled
Upgrade phase : Normal
Table 27 Command output
Non Stop Routing capability |
NSR status: enabled or disabled. |
Upgrade phase |
Upgrade phase: · Prepare—Upgrade preparation phase. · Restore Smooth—Upgrade phase. · Preroute—Route pre-calculation phase. · Calculating—Route calculation phase. · Redisting—Route redistribution phase. · Original and age—LSA generation and aging phase. · Normal—Normal status. |
display ospf peer
Use display ospf peer to display information about OSPF neighbors.
display ospf [ process-id ] peer [ hello | verbose ] [ interface-type interface-number ] [ [ neighbor-id ] [ resolve-hostname ] | hostname host-name ]
process-id: Specifies an OSPF process by ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF neighbor information for all OSPF processes.
hello: Displays information about the hello packets sent to and received from neighbor routers. In scenarios where hello packets are sent in multicast, the command displays information for only the hello packets received from neighbor routers.
verbose: Displays detailed neighbor information. If you do not specify this keyword, the command displays brief OSPF neighbor information.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays neighbor information for all interfaces.
neighbor-id: Specifies a neighbor router ID. If you do not specify this argument, the command displays information for all neighbors.
resolve-hostname: Resolves the host names of the neighbor routers. If you do not specify this keyword, the command cannot resolve the host names of the neighbor routers.
hostname host-name: Specifies a neighbor router by its host name, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the command displays information for all neighbors.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
Neighbors
Area 0.0.0.0 interface 1.1.1.1(GigabitEthernet1/0/12)'s neighbors
Router ID: 1.1.1.2 Address: 1.1.1.2 GR state: Normal
State: Full Mode: Nbr is master Priority: 1
DR: 1.1.1.2 BDR: 1.1.1.1 MTU: 0
Dead timer due in 33 sec
Neighbor is up for 02:03:35
Authentication sequence: [ 0 ]
BFD status: Disabled
Adjacency SID: 24253
Last Neighbor Down Event:
Router ID: 22.22.22.22
Local Address: 11.11.11.11
Remote Address: 22.22.22.22
Time: Apr 9 03:18:19 2014
Reason: Ospf_ifachange
# Display detailed OSPF neighbor information and resolve the host names of the neighbor routers.
<Sysname> display ospf peer verbose resolve-hostname
Area 0.0.0.1 interface 1.1.1.2(GigabitEthernet1/0/12)'s neighbors
Router ID: 3.3.3.3 Address: 13.1.1.2 GR state: Normal
Hostname: RouterA
State: Full Mode: Nbr is slave Priority: 1
DR: 13.1.1.2 BDR: 13.1.1.1 MTU: 0
Options is 0x42 (-|O|-|-|-|-|E|-)
Dead timer due in 31 sec
Neighbor is up for 00:04:42
Neighbor state change count: 5
Router ID: 3.3.3.3
Local Address: 13.1.1.1
Remote Address: 13.1.1.2
Time: Jun 15 16:13:29 2016
Reason: Reset ospf command was performed
Table 28 Command output
Area areaID interface IPAddress(InterfaceName)'s neighbors |
Neighbor information for the interface in the specified area: · areaID—Area to which the neighbor belongs. · IPAddress—Interface IP address. · InterfaceName—Interface name. |
Router ID |
Address |
Neighbor router address. |
GR state |
GR state: · Normal. · Restarter. · Complete. · Helper. |
Hostname |
Host name of the neighbor router. |
State |
Neighbor state: · Down—Initial state of a neighbor conversation. · Init—The router has received a Hello packet from the neighbor. However, the router has not established bidirectional communication with the neighbor. The router did not appear in the neighbor's hello packet. · 2-Way—Communication between the two routers is bidirectional. The local router appears in the neighbor's Hello packet. · Exstart—The goal of this state is to decide which router is the master, and to decide upon the initial Database Description (DD) sequence number. · Exchange—The router is sending DD packets to the neighbor, describing its entire link-state database. · Loading—The router sends LSRs packets to the neighbor, requesting more recent LSAs. · Full—The neighboring routers are fully adjacent. |
Mode |
Neighbor mode for LSDB synchronization. |
Priority |
Neighboring router priority. |
DR |
BDR |
MTU |
Interface MTU. |
Options |
Dead timer due in 33 sec |
This dead timer will expire in 33 seconds. |
Neighbor is up for 02:03:35 |
The neighbor has been up for 02:03:35. |
Authentication sequence |
Authentication sequence number. |
Neighbor state change count |
Count of neighbor state changes. |
BFD status |
BFD status: · Disabled. · Enabled (Control mode). · Enabled (Echo mode). |
Adjacency SID |
SID advertised by the adjacency path. |
Last Neighbor Down Event |
The most recent neighbor down event. |
Time |
Time when the neighbor went down. |
Reason |
Reason for the neighbor down event. |
Cost |
Cost of the route to the neighbor. |
# Display brief OSPF neighbor information.
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time State Interface
1.1.1.2 1.1.1.2 1 40 Full/DR GE1/0/12
Sham link: 11.11.11.11 -> 22.22.22.22
22.22.22.22 22.22.22.22 1 36 Full
# Display brief OSPF neighbor information and resolve the host names of the neighbor routers.
<Sysname> display ospf peer resolve-hostname
Area: 0.0.0.0
RouterA 1.1.1.2 1 34 Full/DR GE1/0/12
Table 29 Command output
Area |
Neighbor area. |
Router ID |
ID or host name of the neighbor router. |
Address |
Neighbor interface address. |
Pri |
Dead-Time |
Dead interval remained. |
Interface connected to the neighbor. |
State |
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading, or Full. |
# Display information about the hello packets sent to and received from neighbor routers.
<Sysname> display ospf peer hello
Neighbors
2019-09-06 09:12:10:121
2019-09-06 09:12:20:121
2019-09-06 09:12:30:121
2019-09-06 09:12:40:121
Last 4 hello packets received:
2019-09-06 09:12:12:121, failed, errno:132
2019-09-06 09:12:22:121, succeeded
2019-09-06 09:12:32:121, succeeded
2019-09-06 09:12:42:121, succeeded
2019-09-06 11:15:12:121, succeeded
2019-09-06 11:15:22:121, succeeded
2019-09-06 11:15:32:121, failed, errno:132
2019-09-06 11:15:42:121, failed, errno:132
Table 30 Command output
Router ID |
Address |
IP address of the neighbor interface. |
Time for receiving the first four hello packets from neighbors. |
Last 4 hello packets received |
Time for receiving the last four hello packets from neighbors. |
Time and result (succeeded or failed) for sending the first four hello packets to neighbors. For a packet failed to be sent, an error code is displayed in the errno field. This field is not displayed in scenarios where hello packets are sent in multicast. |
Time and result (succeeded or failed) for sending the last four hello packets to neighbors when the command is executed. For a packet failed to be sent, an error code is displayed in the errno field. This field is not displayed in scenarios where hello packets are sent in multicast. |
display ospf peer statistics
Use display ospf peer statistics to display OSPF neighbor statistics.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF neighbor statistics for all OSPF processes.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
OSPF Process 1 with Router ID 10.3.1.1
Neighbor Statistics
Area ID Down Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.0 0 0 0 0 0 0 0 1 1
0.0.0.2 0 0 0 0 0 0 0 1 1
Total 0 0 0 0 0 0 0 2 2
Sham links' neighbors (Total: 1):
Down: 0, Init: 0, 2-Way: 0, ExStart: 0, Exchange: 0, Loading: 0, Full: 1
Table 31 Command output
Area ID |
The state statistics for all the routers in the area to which the router belongs is displayed. |
Down |
Number of neighboring routers in Down state in the same area. |
Attempt |
Number of neighboring routers in Attempt state in the same area. |
Init |
Number of neighboring routers in Init state in the same area. |
2-Way |
Number of neighboring routers in 2-Way state in the same area. |
ExStart |
Number of neighboring routers in ExStart state in the same area. |
Exchange |
Number of neighboring routers in Exchange state in the same area. |
Loading |
Number of neighboring routers in Loading state in the same area. |
Full |
Number of neighboring routers in Full state in the same area. |
Total |
Total number of neighbors in the same state: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, or Full. |
Sham links' neighbors |
Statistics about sham links' neighbors. |
display ospf request-queue
Use display ospf request-queue to display OSPF request queue information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF request queue information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays the OSPF request queue information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify this argument, the command displays the OSPF request queue information for all OSPF neighbors.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
OSPF Process 100 with Router ID 192.168.1.59
Link State Request List
The Router's Neighbor is Router ID 2.2.2.2 Address 10.1.1.2
Interface 10.1.1.1 Area 0.0.0.0
Request list:
Type LinkState ID AdvRouter Sequence Age
Router 2.2.2.2 1.1.1.1 80000004 1
Network 192.168.0.1 1.1.1.1 80000003 1
Sum-Net 192.168.1.0 1.1.1.1 80000002 2
Table 32 Command output
The Router's Neighbor is Router ID |
Address |
Neighbor interface IP address. |
Local interface IP address. |
Area |
Area ID. |
Request list |
Request list information. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
Sequence |
Age |
LSA age. |
display ospf retrans-queue
Use display ospf retrans-queue to display retransmission queue information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays retransmission queue information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays retransmission queue information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify this argument, the command displays retransmission queue information for all neighbors.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
Link State Retransmission List
Retransmit list:
Router 2.2.2.2 2.2.2.2 80000004 1
Network 12.18.0.1 2.2.2.2 80000003 1
Sum-Net 12.18.1.0 2.2.2.2 80000002 2
Table 33 Command output
Address |
Interface address of the router. |
Area |
Area ID. |
Retransmit list |
Retransmission list. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
Sequence |
Age |
LSA age. |
display ospf routing
Use display ospf routing to display OSPF routing information.
display ospf [ process-id ] routing [ ip-address { mask-length | mask } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the routing information for all OSPF processes.
ip-address: Specifies a destination IP address.
mask-length: Specifies mask length in the range of 0 to 32.
mask: Specifies the mask in dotted decimal notation.
interface interface-type interface-number: Displays routes passing the specified output interface. If you do not specify this option, the command displays OSPF routing information for all interfaces.
nexthop nexthop-address: Displays routes passing the specified next hop. If you do not specify this option, the command displays all OSPF routing information.
verbose: Displays detailed OSPF routing information. If you do not specify this keyword, the command displays brief OSPF routing information.
# Display OSPF routing information.
<Sysname> display ospf routing
OSPF Process 1 with Router ID 192.168.1.2
Routing Table
Topology base (MTID 0)
Routing for network
Destination Cost Type NextHop AdvRouter Area
192.168.1.0/24 1562 Stub 192.168.1.2 192.168.1.2 0.0.0.0
172.16.0.0/16 1563 Inter 192.168.1.1 192.168.1.1 0.0.0.0
Total nets: 2
Intra area: 1 Inter area: 1 ASE: 0 NSSA: 0
Table 34 Command output
Topology |
Subtopologies are not supported in the current software version. Topology name. If this field displays base, the topology is the base topology. If this field displays other values, the topology is a subtopology. |
MTID |
Subtopologies are not supported in the current software version. Topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology. |
Destination |
Destination network. |
Cost |
Cost to destination. |
Type |
Route type: transit, stub, inter, Type-1, and Type-2. |
NextHop |
Next hop address. |
AdvRouter |
Area |
Area ID. |
Total nets |
Total networks. |
Intra area |
Total intra-area routes. |
Inter area |
Total inter-area routes. |
ASE |
Total ASE routes. |
NSSA |
Total NSSA routes. |
# Display detailed OSPF routing information.
<Sysname> display ospf routing verbose
OSPF Process 2 with Router ID 192.168.1.112
Routing Table
Routing for network
Destination: 192.168.1.0/24
Priority: Low Type: Stub
AdvRouter: 192.168.1.2 Area: 0.0.0.0
SubProtoID: 0x1 Preference: 10
NextHop: 192.168.1.2 BkNextHop: N/A
IfType: Broadcast BkIfType: N/A
Interface: GE1/0/13 BkInterface: N/A
NibID: 0x1300000c Status: Normal
Cost: 1562
InLabel: 4294967295 Tunnel type: -
OutLabel: 4294967295 OutLabel flag: -
BkOutLabel: 4294967295 BkOutLabel flag: -
LabelSrc: N/A Delay flag: -
Remote-LFA backup Info:
PQPrefix: 44.44.44.44 PQAdvID: 44.44.44.44
LsIndex: 1
LabelStack: {2303}
TI-LFA backup info:
BkInterface: GE1/0/12 BkNextHop: 12.1.1.2
BkIfType: Broadcast
PNodePrefix: 3.3.3.3 QNodeAdvID: 2.2.2.2
LsIndex: 2
LabelStack: {19030, 2431}
Destination: 172.16.0.0/16
Priority: Low Type: Inter
AdvRouter: 192.168.1.1 Area: 0.0.0.0
NextHop: 192.168.1.1 BkNextHop: N/A
Interface: GE1/0/14 BkInterface: N/A
Cost: 1563
Destination: 4.4.4.4/32
Priority: Medium Type: Stub
NibID: 0x13000008 Status: Normal
Cost: 1
LabelSrc: N/A Delay Flag: -
Priority: Medium Type: Stub ECMP-backup
NextHop: 192.168.2.2 BkNextHop: N/A
NibID: 0x1300000a Status: Normal
Cost: 1
Total nets: 4
Intra area: 4 Inter area: 0 ASE: 0 NSSA: 0
Table 35 Command output
Topology |
MTID |
Priority |
Prefix priority: critical, high, medium, and low. |
Type |
Route type: transit, stub, inter, Type-1, and Type-2. Ecmp-backup indicates that the route is a backup route for ECMP routes. |
AdvRouter |
Advertising router. |
Area |
Area ID. |
SubProtoID |
Sub protocol ID. |
Preference |
OSPF route preference. |
NextHop |
Primary next hop IP address. |
BkNextHop |
Backup next hop IP address. |
IfType |
Type of the network to which the primary next hop belongs. |
BkIfType |
Type of the network to which the backup next hop belongs. |
Output interface. |
BkInterface |
Backup output interface. |
NibID |
Next hop ID. |
Status |
Route status: · Local—The route is on the local end and is not sent to the route management module. · Invalid—The next hop is invalid. · Stale—The next hop is stale. · Normal—The route is available. · Delete—The route is deleted. · Host-Adv—The route is a host route. · Rely—The route is a recursive route. |
Cost |
InLabel |
Incoming label. |
Tunnel type |
This field is not supported in the current software version. Tunnel type. Only SR tunnels are supported in the current software version. |
OutLabel |
Outgoing label. |
OutLabel flag |
Outgoing label flag: · E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets. · I—Implicit null flag. The upstream neighbor must replace the SID with an implicit null flag before forwarding the packets. This flag is not supported in the current software version. · N—Normal flag. · P—SR label preferred flag. |
BkOutLabel |
Backup outgoing label. |
BkOutLabel flag |
Backup outgoing label flag: · E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets. · I—Implicit null flag. The upstream neighbor must replace the SID with an implicit null flag before forwarding the packets. · N—Normal flag. · P—SR label preferred flag. |
LabelSrc |
Label source: · SR—Assigned by an SR node. · SRMS—Assigned by the Segment Routing Mapping Server (SRMS). |
DelayFlag |
Microloop avoidance delay flag: · D—Microloop avoidance is configured. Route convergence is delayed. · N/A—Microloop avoidance is not configured or the microloop avoidance delay timer has expired. Route convergence is in progress. |
MALsIndex |
SR microloop avoidance label stack index. |
MALabelStack |
SR microloop avoidance label stack (from top to bottom). |
Remote-LFA back Info |
Remote LFA backup information. |
PQPrefix |
PQ node prefix. |
PQAdvID |
Router ID of the PQ node. |
LsIndex |
Label stack index. |
LabelStack |
Label stack. |
TI-LFA backup info |
TI-LFA backup information. |
PNodePrefix |
P node prefix. |
QNodeAdvID |
Router ID of the Q node. |
display ospf spf-tree
Use display ospf spf-tree to display SPF tree information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command displays SPF tree information for all OSPF processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify an area, this command displays SPF tree information for all OSPF areas.
verbose: Displays detailed SPF tree information. If you do not specify this keyword, the command displays brief SPF tree information.
# Display brief SPF tree information for Area 0 in OSPF process 1.
<Sysname> display ospf 1 area 0 spf-tree
OSPF Process 1 with Router ID 100.0.0.4
Flags: S-Node is on SPF tree R-Node is directly reachable
I-Node or Link is init D-Node or Link is to be deleted
P-Neighbor is parent A-Node is in candidate list
C-Neighbor is child T-Node is tunnel destination
H-Nexthop changed N-Link is a new path
V-Link is involved G-Link is in change list
Area: 0.0.0.0 Shortest Path Tree
SpfNode Type Flag SpfLink Type Cost Flag
>192.168.119.130 Network S R
-->114.114.114.111 NET2RT 0 C
-->100.0.0.4 NET2RT 0 P
>114.114.114.111 Router S
-->192.168.119.130 RT2NET 65535 P
>100.0.0.4 Router S
-->192.168.119.130 RT2NET 10 C
Table 36 Command output
Topology |
MTID |
SpfNode |
SPF node, represented by a router ID when the node type is Router, or the IP address of the DR when the node type is Network. Node flag: · I—The node is in initialization state. · A—The node is on the candidate list. · S—The node is on the SPF tree. · R—The node is directly connected to the root node. · D—The node is to be deleted. · T—The node is the tunnel destination. |
SpfLink |
SPF link, representing the peer node. Link type: · RT2RT—Router to router. · NET2RT—Network to router. · RT2NET—Router to network. Link flag: · I—The link is in initialization state. · P—The peer is the parent node. · C—The peer is the child node. · D—The link is to be deleted. · H—The next hop is changed. · V—When the peer node is deleted or added, the peer node is not on the SPF tree or is deleted. · N—The link is newly added, and both end nodes are on the SPF tree. · G—The link is on the area change list. |
# Display detailed SPF tree information for Area 0 in OSPF process 1.
<Sysname> display ospf 1 area 0 spf-tree verbose
>LsId(192.168.119.130)
AdvId : 100.0.0.4 NodeType : Network
Mask : 255.255.255.0 SPFLinkCnt : 2
Distance : 10
VlinkData: 0.0.0.0 ParentLinkCnt: 1 NodeFlag: S R
NextHop : 1
192.168.119.130 Interface: GE1/0/13 Flag: -
BkNextHop: 1
0.0.0.0 Interface: GE1/0/13 Flag: -
Remote-LFA:
RLFAAdvId : 11.11.11.11 RLFAInterface: GE1/0/14
RLFANexthop : 1.1.1.1
PQNode AdvID : 44.44.44.44 PQNode prefix: 44.44.44.44
Protect : Link
Label stack : {2303}
TI-LFA:
TiLfaAdvId : 4.4.4.4 TiLfaInterface: GE1/0/13
TiLfaNexthop : 14.1.1.4
PNode AdvID : 3.3.3.3 QNode AdvID: 2.2.2.2
PNode prefix : 3.3.3.3 PNode SidIndex: 30
Protect : Link
Label stack : {19030, 2431}
-->LinkId(114.114.114.111)
AdvId : 100.0.0.4 LinkType : NET2RT
LsId : 192.168.119.130 LinkCost : 0 NextHopCnt: 1
LinkData: 0.0.0.0 LinkNewCost: 0 LinkFlag : C
-->LinkId(100.0.0.4)
LinkData: 0.0.0.0 LinkNewCost: 0 LinkFlag : P
Table 37 Command output
Topology |
MTID |
LsId |
Link state ID. |
AdvId |
ID of the advertising router. |
NodeType |
Node type: · Network—Network node. · Router—Router node. |
Mask |
Network mask. Its value is 0 for a router node. |
SPFLinkCnt |
Number of SPF links. |
Distance |
Cost to the root node. |
VlinkData |
Destination address of virtual link packets. |
ParentLinkCnt |
Number of parent links. |
NodeFlag |
NextHop |
Next hop. |
Output interface. |
MADuration |
SR microloop avoidance duration in milliseconds. |
MALStack |
BkNextHop |
Backup next hop. |
Flag |
This field is not supported in the current software version. Next hop type. SR indicates SR tunnel. This field displays a hyphen (-) for other next hop types. |
Remote-LFA |
RLFAAdvId |
Router ID of the remote LFA backup next hop. |
RLFAaInterface |
Output interface of the remote LFA backup next hop. |
RLFaNexthop |
Remote LFA backup next hop information. |
PQNode AdvID |
PQNode prefix |
PQ node prefix. |
TI-LFA |
TI-LFA information. |
TiLfaInterface |
TI-LFA interface. |
TiLfaNexthop |
TI-LFA next hop address. |
PNode AdvID |
Router ID of the P node. |
QNode AdvID |
Protect |
Traffic protection type: Link or Node. |
LinkId |
Link ID. |
LinkType |
Link type: · RT2RT—Router to router. · NET2RT—Network to router. · RT2NET—Router to network. |
LinkCost |
Link cost. |
NextHopCnt |
Number of next hops. |
LinkData |
Link data. |
LinkNewCost |
New link cost. |
LinkFlag |
display ospf statistics
Use display ospf statistics to display OSPF statistics.
display ospf [ process-id ] statistics [ error | packet [ hello | interface-type interface-number ] ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF statistics for all OSPF processes.
error: Displays error statistics. If you do not specify this keyword, the command displays OSPF packet, LSA, and route statistics.
packet: Displays OSPF packet statistics.
hello: Displays statistics of the sent and received hello packets. If you do not specify this keyword, the command displays statistics of all types of sent and received packets.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays statistics for all interfaces.
# Display OSPF statistics.
<Sysname> display ospf statistics
Statistics
I/O statistics
Type Input Output
Hello 61 122
DB Description 2 3
Link-State Req 1 1
Link-State Update 3 3
Link-State Ack 3 2
LSAs originated by this router
Router : 4
Network : 0
Sum-Net : 0
Sum-Asbr: 0
External: 0
NSSA : 0
Opq-Link: 0
Opq-Area: 0
Opq-As : 0
LSAs originated: 4 LSAs received: 7
Routing table:
Intra area: 2 Inter area: 3 ASE/NSSA: 0
Table 38 Command output
I/O statistics |
Statistics about input/output packets and LSAs. |
Type |
OSPF packet type. |
Input |
Packets received. |
Output |
Packets sent. |
Hello |
Hell packet. |
DB Description |
Database Description packet. |
Link-State Req |
Link-State Request packet. |
Link-State Update |
Link-State Update packet. |
Link-State Ack |
Link-State Acknowledge packet. |
LSAs originated by this router |
LSAs originated by this router. |
Router |
Number of Type-1 LSAs originated. |
Network |
Number of Type-2 LSAs originated. |
Sum-Net |
Number of Type-3 LSAs originated. |
Sum-Asbr |
Number of Type-4 LSAs originated. |
External |
Number of Type-5 LSAs originated. |
NSSA |
Number of Type-7 LSAs originated. |
Opq-Link |
Number of Type-9 LSAs originated. |
Opq-Area |
Number of Type-10 LSAs originated. |
Opq-As |
Number of Type-11 LSAs originated. |
LSA originated |
Number of LSAs originated. |
LSA received |
Number of LSAs received. |
Routing table |
Routing table information. |
Intra area |
Number of intra-area routes. |
Inter area |
Number of inter-area routes. |
ASE/NSSA |
Number of ASE/NSSA routes. |
# Display OSPF error statistics.
<Sysname> display ospf statistics error
OSPF Process 1 with Router ID 192.168.1.112
OSPF Packet Error Statistics
0 : Router ID confusion 0 : Bad packet
0 : Bad version 0 : Bad checksum
0 : Bad area ID 0 : Drop on unnumbered link
0 : Bad virtual link 0 : Bad authentication type
0 : Bad authentication key 0 : Packet too small
0 : Neighbor state low 0 : Transmit error
0 : Interface down 0 : Unknown neighbor
0 : HELLO: Netmask mismatch 0 : HELLO: Hello-time mismatch
0 : HELLO: Dead-time mismatch 0 : HELLO: Ebit option mismatch
0 : HELLO: Mbit option mismatch 0 : DD: MTU option mismatch
0 : DD: Unknown LSA type 0 : DD: Ebit option mismatch
0 : ACK: Bad ack 0 : ACK: Unknown LSA type
0 : REQ: Empty request 0 : REQ: Bad request
0 : UPD: LSA checksum bad 0 : UPD: Unknown LSA type
0 : UPD: Less recent LSA
Table 39 Command output
Router ID confusion |
Packets with duplicate router ID. |
Bad packet |
Packets illegal. |
Bad version |
Packets with wrong version. |
Bad checksum |
Packets with wrong checksum. |
Bad area ID |
Packets with invalid area ID. |
Drop on unnumbered link |
Packets dropped on the unnumbered interface. |
Bad virtual link |
Packets on wrong virtual links. |
Bad authentication type |
Packets with invalid authentication type. |
Bad authentication key |
Packets with invalid authentication key. |
Packet too small |
Packets too small in length. |
Neighbor state low |
Packets received in low neighbor state. |
Transmit error |
Packets with error when being transmitted. |
Interface down |
Shutdown times of the interface. |
Unknown neighbor |
Packets received from unknown neighbors. |
HELLO: Netmask mismatch |
Hello packets with mismatched mask. |
HELLO: Hello-time mismatch |
Hello packets with mismatched hello timer. |
HELLO: Dead-time mismatch |
Hello packets with mismatched dead timer. |
HELLO: Ebit option mismatch |
Hello packets with mismatched E-bit in the option field. |
HELLO: Mbit option mismatch |
Hello packets with mismatched M-bit in the option field. |
DD: MTU option mismatch |
DD packets with mismatched MTU. |
DD: Unknown LSA type |
DD packets with unknown LSA type. |
DD: Ebit option mismatch |
DD packets with mismatched E-bit in the option field. |
ACK: Bad ack |
Bad LSAck packets for LSU packets. |
ACK: Unknown LSA type |
LSAck packets with unknown LSA type. |
REQ: Empty request |
LSR packets with no request information. |
REQ: Bad request |
Bad LSR packets. |
UPD: LSA checksum bad |
LSU packets with wrong LSA checksum. |
UPD: Unknown LSA type |
LSU packets with unknown LSA type. |
UPD: Less recent LSA |
LSU packets without the most recent LSA. |
# Display OSPF packet statistics for all processes and interfaces.
<Sysname> display ospf statistics packet
Packet Statistics
Waiting to send packet count: 0
Hello DD LSR LSU ACK Total
Input : 489 6 2 44 40 581
Output: 492 8 2 45 40 587
Area: 0.0.0.1
Interface: 20.1.1.1 (GigabitEthernet1/0/12)
Input : 0 0 0 0 0
Output: 0 0 0 0 0
Interface: 100.1.1.1 (GigabitEthernet1/0/13)
Input : 3 1 22 16 42
Output: 2 1 19 20 42
Table 40 Command output
Waiting to send packet count |
Number of packets waiting to be sent. |
Total |
Total number of packets. |
Input |
Number of received packets. |
Output |
Number of sent packets. |
Area |
Area ID. |
Interface address and interface name. |
# Display statistics of the sent and received hello packets.
<Sysname> display ospf statistics packet hello
OSPF Process 1 with Router ID 100.1.1.1
Hello Statistics
Total sent : 4
Total sent failed : 0
Sent after one and a half intervals : 0
Total received : 2
Total received dropped : 0
Received after one and a half intervals: 0
Table 41 Command output
Total sent |
Total number of hello packets sent. |
Total sent failed |
Total number of hello packets that failed to be sent. |
Sent after one and a half intervals |
Total number of hello packets sent at intervals greater than 1.5 times the hello interval. |
Total received |
Total number of hello packets received. |
Total received dropped |
Total number of received hello packets that were dropped. |
Received after one and a half intervals |
Total number of hello packets received at intervals greater than 1.5 times the hello interval. |
reset ospf statistics
display ospf troubleshooting
Use display ospf troubleshooting to display OSPF neighbor relationship troubleshooting information.
# Display OSPF neighbor relationship troubleshooting information.
<Sysname> display ospf troubleshooting
OSPF troubleshooting Information
Total count: 3
Time Sequence Description
2019-09-04 12:01:07 3 The state of OSPF 1 peer 12.1.1.2 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: GE1/0/12, peer address: 12.1.1.2).
2019-09-04 11:54:19 2 The state of OSPF 1 peer 12.1.1.2 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/12, peer address: 12.1.1.2; ping result: ping was not executed because of the disabled MTP; CPU usage: 29.0%; memory usage: 76.81%, memory state: normal).
2019-09-04 11:48:25 1 The state of OSPF 1 peer 12.1.1.2 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: GE1/0/12, peer address: 12.1.1.2).
Table 42 Command output
Total count |
Total number of OSPF neighbor relationship troubleshooting entries. |
Time |
Time when the OSPF neighbor was disconnected. The most recent entry is displayed first. |
Sequence |
Sequence number of the OSPF neighbor relationship troubleshooting entry. |
OSPF neighbor relationship troubleshooting information, including the OSPF process ID, neighbor ID, reason, and recommended action. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was reset. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was deleted. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF area was deleted. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF was disabled (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF packet receiving and sending are disabled (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface address was deleted or OSPF was disabled on interface. Please check the interface settings (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface went down or MTU changed. Please check the interface state and MTU settings (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link was deleted or the route it relies on was deleted. Please check the virtual link and the route it relies on (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link interface went down or the virtual link settings were deleted. Please check the virtual link and the route it relies on (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/12, peer address: 10.1.1.1; ping result: 5 packets in total, 5 packets timed out; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/12, peer address: 10.1.1.1; ping result: ping was not executed because of the disabled MTP; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/12, peer address: 10.1.1.1; ping result: waitting for the ping to execute; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the stub configuration changed in area 0.0.0.1. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the NSSA configuration changed in area 0.0.0.1. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the Opaque LSA capability configuration changed. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the out-of-band resynchronization capability configuration changed. · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the BFD session went down. Please check the BFD session information. · The state of OSPF 1 peer 1.1.1.1 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to DOWN because database-filter configuration changed or database-filter ACL configuration changed. Please check the OSPF database-filter and its ACL configuration (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a BadLSReq event was triggered upon the request for a nonexistent LSA. Please check the local OSPF LSDB and the OSPF request queue on the remote end (Interface: GE1/0/12, peer address: 10.1.1.1, LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is the same as that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: GE1/0/12, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is older than that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: GE1/0/12, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a non-retransmitted DD packet from the Loading or Full peer during the DD retransmit interval. Please check the OSPF peer state and LSDB on the remote end (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to external attribute. Please check the DD packets transmitted on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a retransmitted DD packet from the Loading or Full peer after the DD retransmit interval expired. Please check the OSPF peer state and LSDB on the remote end (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to receive AS external LSA. Please check the area configuration (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the master-slave relationship change. Please check the DD packets transmitted on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of an unexpected initial DD packet after DD transmission started. Please check the DD packets transmitted on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the slave. Please check the DD packets transmitted on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the master. Please check the DD packets transmitted on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing local opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing area opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing NSSA external LSA in a non-NSSA area. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing invalid LSA. Please check the specified LSA on the remote end (Interface: GE1/0/12, peer address: 10.1.1.1). · The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS external LSA in the stub area or on the virtual link. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: GE1/0/12, peer address: 10.1.1.1). |
reset ospf troubleshooting
display ospf vlink
Use display ospf vlink to display OSPF virtual link information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF virtual link information for all OSPF processes.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
Virtual Links
Virtual-link Neighbor-ID -> 2.2.2.2, Neighbor-State: Full
Interface: 10.1.2.1 (GigabitEthernet1/0/12)
Cost: 1562 State: P-2-P Type: Virtual
Transit Area: 0.0.0.1
Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
The last key is 3.
The rollover is in progress, 2 neighbor(s) left.
MTID Cost Disabled Topology name
0 16777215 No base
Table 43 Command output
Virtual-link Neighbor-ID |
ID of the neighbor on the virtual link. |
Neighbor-State |
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, Full. |
IP address and name of the local interface on the virtual link. |
Cost |
Interface route cost. |
State |
Interface state. |
Type |
Virtual link. |
Transit Area |
Transit area ID. |
Timers |
Values of timers (in seconds): Hello, Dead, and Retransmit. |
Transmit Delay |
LSA transmission delay on the interface, in seconds. |
Cryptographic authentication: Enabled, inherited |
Cryptographic authentication mode (MD5, HMAC-MD5, or HMAC-SHA-256) is used by the virtual link. If the virtual link uses the simple authentication mode, this field displays Simple authentication: Enabled. The inherited attribute indicates that the virtual link uses the authentication mode specified for the backbone area. |
The last key |
Most recent MD5, HMAC-MD5, or HMAC-SHA-256 authentication key ID. |
The rollover is in progress, 2 neighbor(s) left |
Key rollover for MD5, HMAC-MD5, or HMAC-SHA-256 authentication is in progress, and two neighbors have not completed the key rollover. |
MTID |
Cost |
Disabled |
Whether OSPF is disabled from advertising the topology for the virtual link: Yes or No. |
Topology name |
display router id
Use display router id to display the global router ID.
display router id
# Display the global router ID.
<Sysname> display router id
Configured router ID is 1.1.1.1
distribute bgp-ls
Use distribute bgp-ls to advertise OSPF link state information to BGP.
Use undo distribute bgp-ls to restore the default.
distribute bgp-ls [ instance-id id ] [ strict-link-checking ]
OSPF link state information cannot be advertised to BGP.
OSPF view
instance-id id: Specifies an instance by its ID in the range of 0 to 65535. If you do not specify an instance, this command advertises OSPF link state information of instance 0 to BGP.
strict-link-checking: Enables strict checking on link state information advertised to BGP. If you specify this keyword, the IP addresses of the local and remote ends of a link must be in the same subnet. If you do not specify this keyword, the IP addresses of both ends can be in different subnets. This keyword applies only to P2P links.
After the device advertises OSPF link state information to BGP, BGP can advertise the information for intended applications.
If multiple OSPF processes have the same link state information and instance ID, only the link state information of the OSPF process with the smallest process ID is advertised.
To advertise the same link state information of different OSPF processes to BGP, specify a different instance ID for each OSPF process.
As a best practice, enable strict link state information checking when the following conditions exist:
· The link state information advertised to BGP contains multiple equal-cost links.
· The local and remote ends of each equal-cost link are in the same subnet.
With this feature enabled, error link state information is not advertised to BGP when the equal-cost links flap.
Strict link state information checking and prefix suppression are mutually exclusive. Before you enable strict link state information checking, make sure prefix suppression is disabled.
Strict link state information checking does not take effect when MPLS TE is enabled. For more information about MPLS TE, see MPLS TE configuration in MPLS Configuration Guide.
# Advertise link state information of OSPF process 1 to BGP.
[Sysname] ospf 1
[Sysname-ospf-1] distribute bgp-ls
dscp
Use dscp to set the DSCP value for outgoing OSPF packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing OSPF packets is 48.
OSPF view
dscp-value: Specifies the DSCP value in the range of 0 to 63 for outgoing OSPF packets.
# Set the DSCP value for outgoing OSPF packets to 63 in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] dscp 63
enable link-local-signaling
Use enable link-local-signaling to enable the OSPF link-local signaling (LLS) capability.
Use undo enable link-local-signaling to disable the OSPF LLS capability.
OSPF link-local signaling capability is disabled.
OSPF view
# Enable link-local signaling for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
enable out-of-band-resynchronization
Use enable out-of-band-resynchronization to enable the OSPF out-of-band resynchronization (OOB-Resynch) capability.
Use undo enable out-of-band-resynchronization to disable the OSPF out-of-band resynchronization capability.
The OSPF out-of-band resynchronization capability is disabled.
OSPF view
Before you configure this command, enable the link-local signaling capability.
# Enable the out-of-band resynchronization capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
event-log
Use event-log to configure the OSPF logging feature.
Use undo event-log to remove the configuration.
event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | route | spf } size count
event-log lsa-history { asbr | ase | include-duplicate | link-state-id | network | nssa | opaque-area | opaque-as | opaque-link | originate-router advertising-router-id | router | size count | summary | verbose } *
undo event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | route | spf } size
undo event-log lsa-history
The device can generate a maximum of 100 logs for each type.
OSPF view
hello: Specifies the number of logs for received or sent hello packets.
received: Specifies the number of logs for received hello packets.
sent: Specifies the number of logs for sent hello packets.
abnormal: Specifies the number of logs for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies the number of logs for received hello packets that were dropped.
failed: Specifies the number of logs for hello packets that failed to be sent.
lsa-flush: Specifies the number of LSA aging logs.
peer: Specifies the number of neighbor logs.
route: Specifies the number of OSPF route logs.
spf: Specifies the number of route calculation logs.
size count: Specifies the number of OSPF logs, in the range of 0 to 65535.
lsa-history: Logs self-originated and received LSA information.
include-duplicate: Specifies all LSAs including duplicate LSAs. Duplicate LSAs refer to LSAs that carry the same options and contents.
verbose: Logs detailed information about self-originated and received LSAs. If you do not specify this keyword, the command logs brief information about self-originated and received LSAs.
asbr: Logs Type-4 LSA (ASBR Summary LSA) information.
ase: Logs Type-5 LSA (AS External LSA) information.
network: Logs Type-2 LSA (Network LSA) information.
nssa: Logs Type-7 LSA (NSSA External LSA) information.
opaque-area: Logs Type-10 LSA (Opaque-area LSA) information.
opaque-as: Logs Type-11 LSA (Opaque-AS LSA) information.
opaque-link: Logs Type-9 LSA (Opaque-link LSA) information.
router: Logs Type-1 LSA (Router LSA) information.
summary: Logs Type-3 LSA (Network Summary LSA) information.
originate-router advertising-router-id: Specifies an advertising router by its ID.
link-state-id: Specifies a link state ID in the IP address format.
# Set the number of route calculation logs to 50 in OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] event-log spf size 50
fast-reroute
Use fast-reroute to configure OSPF FRR.
Use undo fast-reroute to restore the default.
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
OSPF FRR is disabled.
OSPF view
lfa: Uses the LFA algorithm to calculate a backup next hop for all routes.
abr-only: Uses the next hop of the route to the ABR as the backup next hop.
route-policy route-policy-name: Uses a routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
When both OSPF FRR and PIC are configured, OSPF FRR takes effect.
Do not use the fast-reroute lfa command together with the vlink-peer command.
# Enable FRR to calculate a backup next hop for all routes by using LFA algorithm in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
fast-reroute remote-lfa maximum-cost
Use fast-reroute remote-lfa maximum-cost to set the maximum cost from the source node of a protected link to a PQ node.
Use undo fast-reroute remote-lfa maximum-cost to restore the default.
fast-reroute remote-lfa maximum-cost cost
The maximum cost from the source node of a protected link to a PQ node is 4294967295.
OSPF view
cost: Specifies a cost value in the range of 1 to 4294967295.
The cost values from different PQ nodes to the source node of a specific protected link might be different. You can use this command to filter PQ nodes based on the cost value.
# Set the maximum cost from the source node of a protected link to a PQ node to 200.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa maximum-cost 200
fast-reroute remote-lfa prefix-list
Use fast-reroute remote-lfa prefix-list to specify a prefix list to filter remote LFA PQ nodes.
Use undo fast-reroute remote-lfa prefix-list to restore the default.
fast-reroute remote-lfa prefix-list prefix-list-name
Any PQ node can be selected as the backup next hop by remote LFA FRR.
OSPF view
prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters.
Multiple PQ nodes might reach the source node of a specific protected link. You can use this command to specify a prefix list to filter PQ nodes.
# Use prefix list test1 to filter remote LFA PQ nodes.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa prefix-list 1
ip prefix-list
fast-reroute remote-lfa tunnel ldp
Use fast-reroute remote-lfa tunnel ldp to enable OSPF remote LFA FRR.
Use undo fast-reroute remote-lfa tunnel ldp to disable OSPF remote LFA FRR.
OSPF remote LFA FRR is disabled.
OSPF view
Configure remote LFA FRR to prevent traffic loss caused by link or node failures.
Before configuring remote LFA FRR, you must perform the following tasks:
· Use the mpls ldp command to enable MPLS LDP globally.
· Use the mpls ldp enable command to enable MPLS LDP on all interfaces participating in MPLS forwarding.
· Use the fast-reroute lfa command to enable LFA FRR for OSPF.
# Enable remote LFA FRR.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa tunnel ldp
fast-reroute
mpls ldp (MPLS Command Reference)
mpls ldp enable (MPLS Command Reference)
fast-reroute tiebreaker
Use fast-reroute tiebreaker to set the priority for an FRR backup path selection policy.
Use undo fast-reroute tiebreaker to restore the default.
fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint } preference preference
undo fast-reroute tiebreaker { lowest-cost | node-protecting | srlg-disjoint }
The priority values of the node-protection, lowest-cost, and SRLG-disjoint backup path selection policies are 40, 20, and 10, respectively.
OSPF view
lowest-cost: Sets a priority value for the lowest-cost backup path selection policy.
node-protecting: Sets a priority value for the node-protection backup path selection policy.
srlg-disjoint: Sets a priority value for the SRLG-disjoint backup path selection policy.
preference preference: Specifies a priority value in the range of 1 to 255. A higher value indicates a higher priority.
If you execute this command multiple times for a backup path selection policy, the most recent configuration takes effect.
When you configure multiple backup path selection policies for an OSPF process, OSPF first uses the policy with the highest priority to calculate a backup path. If the backup path calculation fails, OSPF works as follows:
· If the SRLG-disjoint policy has the highest priority but the backup path calculation fails, OSPF selects the one with the higher priority from the node-protection and lowest-cost policies:
¡ If the node-protection policy has the higher priority but the backup path calculation still fails, OSPF uses the lowest-cost policy for further calculation.
¡ If the lowest-cost policy has the higher priority but the backup path calculation still fails, OSPF does not perform further backup path calculation.
· If the node-protection policy has the highest priority but the backup path calculation fails, OSPF selects the one with the higher priority from the SRLG-disjoint and lowest-cost policies:
¡ If the SRLG-disjoint policy has the higher priority but the backup path calculation still fails, OSPF uses the lowest-cost policy for further calculation.
· If the lowest-cost policy has the highest priority but the backup path calculation fails, OSPF does not perform further backup path calculation.
# Set the priority value of the node-protection backup path selection policy to 100.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute tiebreaker node-protecting 100
fast-reroute
filter
Use filter to configure OSPF to filter inbound/outbound Type-3 LSAs on an ABR.
Use undo filter to disable Type-3 LSA filtering.
filter { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
Type-3 LSAs are not filtered.
OSPF area view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter inbound/outbound Type-3 LSAs.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
export: Filters Type-3 LSAs advertised to other areas.
import: Filters Type-3 LSAs advertised into the local area.
This command applies only to an ABR.
# Use IP prefix list my-prefix-list to filter inbound Type-3 LSAs. Use basic ACL 2000 to filter outbound Type-3 LSAs in OSPF Area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
filter-policy export
Use filter-policy export to configure OSPF to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ bgp | direct | { isis | ospf } [ process-id ] | static | unr ]
undo filter-policy export [ bgp | direct | { isis | ospf } [ process-id ] | static | unr ]
OSPF does not filter redistributed routes.
OSPF view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter redistributed routes by destination address.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
bgp: Filters redistributed BGP routes.
direct: Filters redistributed direct routes.
isis: Filters redistributed IS-IS routes.
ospf: Filters redistributed OSPF routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default value is 1.
static: Filters redistributed static routes.
unr: Filters redistributed user network routes.
If you do not specify any parameters, this command filters all redistributed routes.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
· To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
· To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address. For the mask configuration to take effect, specify a contiguous subnet mask.
# Configure OSPF process 100 to filter redistributed routes by using basic ACL 2000.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16. Configure OSPF process 100 to filter redistributed routes by using advanced ACL 3000.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
import-route
filter-policy import
Use filter-policy import to configure OSPF to filter routes calculated using received LSAs.
Use undo filter-policy import to restore the default.
filter-policy { ipv4-acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
OSPF does not filter routes calculated using received LSAs.
OSPF view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter received routes by destination.
gateway prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes by next hop.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes by destination.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
This command filters calculated routes instead of advertised or received LSAs. Only filtered routes can be added to the RIB.
To use an advanced ACL (with a number from 3000 to 3999) in the command or in the specified routing policy, configure the ACL in one of the following ways:
# Use basic ACL 2000 to filter received routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16. Use ACL 3000 to filter received routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
graceful-restart
Use graceful-restart to enable OSPF GR.
Use undo graceful-restart to disable OSPF GR.
graceful-restart [ ietf | nonstandard ] [ global | planned-only ] *
OSPF GR is disabled.
OSPF view
ietf: Enables IETF GR.
nonstandard: Enables non-IETF GR.
global: Enables global GR. In global GR mode, a GR process can be completed only when all GR helpers exist. A GR process fails if a GR helper fails (for example, the interface connected to the GR helper goes down). If you do not specify this keyword, the command enables partial GR. In partial GR mode, a GR process can be completed if a GR helper exists.
planned-only: Enables only planned GR. If you do not specify this keyword, the command enables both planned GR and unplanned GR.
GR includes planned GR and unplanned GR.
· Planned GR—Manually restarts OSPF by using the reset ospf process command or performs an active/standby process switchover by using the placement reoptimize command. Before OSPF restart or active/standby switchover, the GR restarter sends Grace-LSAs to GR helpers.
· Unplanned GR—OSPF restarts or an active/standby switchover occurs because of device failure. Before OSPF restart or active/standby switchover, the GR restarter does not send Grace-LSAs to GR helpers.
Before enabling IETF GR for OSPF, enable Opaque LSA advertisement and reception with the opaque-capability enable command.
Before enabling non-IETF GR for OSPF, enable OSPF LLS with the enable link-local-signaling command and OOB-Resynch with the enable out-of-band-resynchronization command.
If you do not specify the nonstandard or ietf keyword, this command enables non-IETF GR for OSPF.
OSPF GR and OSPF NSR are mutually exclusive. Do not configure the graceful-restart command and the non-stop-routing command at the same time.
# Enable IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# Enable non-IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
graceful-restart helper enable
Use graceful-restart helper enable to enable OSPF GR helper capability.
Use undo graceful-restart helper enable to disable OSPF GR helper capability.
OSPF GR helper capability is enabled.
OSPF view
planned-only: Enables only planned GR for the GR helper. If you do not specify this keyword, the command enables both planned GR and unplanned GR for the GR helper.
The planned-only keyword is available only for the IETF GR helper.
# Enable GR helper capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper enable
graceful-restart helper strict-lsa-checking
Use graceful-restart helper strict-lsa-checking to enable strict LSA checking capability for GR helper.
Use undo graceful-restart helper strict-lsa-checking to disable strict LSA checking capability for GR helper.
Strict LSA checking capability for GR helper is disabled.
OSPF view
When an LSA change on the GR helper is detected, the GR helper device exits the GR helper mode.
# Enable strict LSA checking capability for GR helper in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper strict-lsa-checking
graceful-restart interval
Use graceful-restart interval to set the GR interval.
Use undo graceful-restart interval to restore the default.
The GR interval is 120 seconds.
OSPF view
interval: Specifies the GR interval in the range of 40 to 1800 seconds.
For GR restart to succeed, the value of the GR restart interval cannot be smaller than the maximum OSPF neighbor dead time of all the OSPF interfaces.
# Set the GR interval for OSPF process 1 to 100 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
ospf timer dead
host-advertise
Use host-advertise to advertise a host route.
Use undo host-advertise to remove a host route.
host-advertise ip-address cost-value
undo host-advertise ip-address
No host route is advertised.
OSPF area view
ip-address: Specifies the IP address of a host.
cost-value: Specifies a cost for the route, in the range of 1 to 65535.
# Advertise host route 1.1.1.1 with a cost of 100.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
hostname
Use hostname to enable the OSPF dynamic host name mapping feature.
Use undo hostname disable the OSPF dynamic host name mapping feature.
hostname [ host-name ]
undo hostname
The OSPF dynamic host name mapping feature is disabled.
OSPF view
host-name: Specifies the host name mapped to the router ID of the OSPF process, a case-sensitive string of 1 to 255 characters. If you do not specify this argument, the device name is mapped to the router ID of the OSPF process.
OSPF uses Type-10 LSAs and Type-11 LSAs to carry information about the dynamic host name attribute. Before using this command, make sure the opaque LSA reception and advertisement capability is enabled.
# Enable the dynamic host name mapping feature for OSPF process 1, and specify the host name mapped to the router ID as red.
[Sysname] ospf 1
[Sysname-ospf-1] hostname red
display ospf hostname-table
import-route
Use import-route to enable route redistribution.
Use undo import-route to disable route redistribution.
import-route bgp [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static | unr } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isis | ospf } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
undo import-route { bgp | direct | { isis | ospf } [ process-id | all-processes ] | static | unr }
OSPF does not redistribute routes.
OSPF view
bgp: Redistributes BGP routes.
as-number: Redistributes routes in an AS specified by its number in the range of 1 to 4294967295. This argument applies only to the BGP protocol. If you do not specify this argument, this command redistributes all IPv4 EBGP routes. As a best practice, specify an AS number to prevent the system from redistributing excessive IPv4 EBGP routes.
direct: Redistributes direct routes.
isis: Redistributes IS-IS routes.
ospf: Redistributes OSPF routes.
process-id: Specifies a process ID in the range of 1 to 65535. The default is 1.
static: Redistributes static routes.
unr: Redistributes user network routes. User network routes are generated by access devices for online users.
all-processes: Redistributes routes from all the processes of the IS-IS or OSPF routing protocol.
allow-ibgp: Redistributes IBGP routes. The import-route bgp command redistributes only EBGP routes. Use the import-route bgp allow-ibgp command with caution, because the command redistributes both EBGP and IBGP routes and might cause routing loops.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. If you do not specify this keyword, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a route cost in the range of 0 to 16777214.
inherit-cost: Uses the original cost of redistributed routes.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. If you do not specify this keyword, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit is set to 0. This keyword applies to NSSA routers.
route-policy route-policy-name: Specifies a routing policy to filter redistributed routes. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag for external LSAs, in the range of 0 to 4294967295. The default is 1.
type type: Specifies a cost type, 1 or 2. The default is 2.
This command redistributes routes destined for other ASs from another protocol. AS external routes include the following types:
· Type-1 external routes—Have high credibility. The cost of Type-1 external routes is comparable with the cost of OSPF internal routes. The cost of a Type-1 external route equals the cost from the router to the ASBR plus the cost from the ASBR to the external route's destination.
· Type-2 external routes—Have low credibility. OSPF considers the cost from the ASBR to the destination of a Type-2 external route is much bigger than the cost from the ASBR to an OSPF internal router. The cost of a Type-2 external route equals the cost from the ASBR to the Type-2 external route's destination.
The import-route command redistributes only active routes. To display information about active routes, use the display ip routing-table protocol command. The import-route command cannot redistribute default external routes.
The import-route nssa-only command redistributes AS-external routes in Type-7 LSAs only into the NSSA area.
If you specify neither the cost nor the inherit-cost keyword, the cost of a redistributed route is 1.
When you execute the undo form of the command, per-process setting has higher priority than the all-processes setting.
· The undo import-route { isis | ospf | rip } all-processes command cannot remove the setting configured for a process by using the import-route { isis | ospf | rip } process-id command. To remove the setting for that process, you must specify the process ID in the undo form of the command.
# Redistribute routes from OSPF process 40 and specify the type, tag, and cost as 2, 33, and 50 for redistributed routes.
[Sysname] ospf 100
[Sysname-ospf-100] import-route ospf 40 type 2 tag 33 cost 50
default-route-advertise (OSPF view)
ispf enable
Use ispf enable to enable OSPF incremental SPF (ISPF).
Use undo ispf enable to disable OSPF ISPF.
ispf enable
undo ispf enable
OSPF ISPF is enabled.
OSPF view
Upon topology changes, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Disable ISPF for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo ispf enable
log-peer-change
Use log-peer-change to enable logging for OSPF neighbor state changes.
Use undo log-peer-change to disable logging for OSPF neighbor state changes.
log-peer-change
Logging for OSPF neighbor state changes is enabled.
OSPF view
This command enables output of OSPF neighbor state changes to the information center. The information center processes the logs according to user-defined output rules (whether and where to output logs). For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Disable logging for neighbor state changes for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
lsa-arrival-interval
Use lsa-arrival-interval to set the LSA arrival interval.
Use undo lsa-arrival-interval to restore the default.
lsa-arrival-interval maximum-interval [ minimum-interval [ incremental-interval ] ]
The maximum interval, incremental interval, and minimum interval are 1000 milliseconds, 500 milliseconds, and 500 milliseconds, respectively.
OSPF view
maximum-interval: Specifies the maximum LSA arrival interval in the range of 0 to 10000 milliseconds.
minimum-interval: Specifies the minimum LSA arrival interval in the range of 0 to 1000 milliseconds.
incremental-interval: Specifies the incremental LSA arrival interval in the range of 0 to 5000 milliseconds.
For a stable network, LSAs arrive at the minimum interval. If network changes become frequent, the LSA arrival interval increases by the incremental interval × 2n-2 for each arrival until the maximum interval is reached. The value n is the number of arrival times.
OSPF drops any duplicate LSAs within the LSA arrival interval. An LSA is a duplicate of a previous LSA if they have the same LSA type, LS ID, and router ID.
On a stable network that requires fast convergence, you can set the LSA arrival interval to 0. In this way, OSPF can learn the changes of the topology or routes immediately.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum, minimum, and incremental LSA arrival intervals to 2000 milliseconds, 100 milliseconds, and 300 milliseconds, respectively.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval 2000 100 300
lsa-generation-interval
lsa-arrival-interval suppress-flapping
Use lsa-arrival-interval suppress-flapping to suppress incoming LSAs during route flapping.
Use undo lsa-arrival-interval suppress-flapping to restore the default.
lsa-arrival-interval suppress-flapping delay-interval [ threshold threshold-value ]
Incoming LSAs are not suppressed during route flapping.
OSPF view
delay-interval: Specifies the suppression interval, which is the minimum interval for accepting instances of the same LSA during route flapping. The value range is 0 to 65535 seconds.
threshold threshold-value: Specifies the suppression trigger threshold as the number of route flaps. When the number of route flaps reaches the threshold, OSPF suppresses instances of the same LSA. The value range for the threshold-value argument is 3 to 100. The default value is 5.
Instances of an LSA have the same LSA type, LS ID, and originating router ID.
If OSPF receives multiple instances of the same LSA during the suppression interval, OSPF discards all the instances except the first one.
# Configure OSPF to suppress incoming LSAs after 10 route flaps, and set the LSA suppression interval to 5 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval suppress-flapping 5 threshold 10
Use lsa-generation-interval to set the OSPF LSA generation interval.
Use undo lsa-generation-interval to restore the default.
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF view
maximum-interval: Specifies the maximum LSA generation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum LSA generation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the LSA generation incremental interval in the range of 10 to 60000 milliseconds.
For a stable network, LSAs are generated at the minimum interval. If network changes become frequent, the LSA generation interval increases by the incremental interval × 2n-2 for each generation until the maximum interval is reached. The value n is the number of generation times.
# Set the maximum LSA generation interval to 2 seconds, minimum interval to 100 milliseconds, and incremental interval to 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
lsa-generation-interval suppress-flapping
Use lsa-generation-interval suppress-flapping to suppress the generation of LSAs during route flapping.
Use undo lsa-generation-interval suppress-flapping to restore the default.
lsa-generation-interval suppress-flapping delay-interval [ threshold threshold-value ]
The generation of LSAs is not suppressed during route flapping.
OSPF view
delay-interval: Specifies the suppression interval, which is the minimum interval for generating LSAs during route flapping. The value range is 0 to 65535 seconds.
threshold threshold-value: Specifies the suppression trigger threshold as the number of route flaps. When the number of route flaps reaches the threshold, OSPF suppresses the generation of LSAs. The value range for the threshold-value argument is 3 to 100. The default value is 5.
# Configure OSPF to suppress the LSA generation after 10 route flaps, and set the suppression interval to 3 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-generation-interval suppress-flapping 3 threshold 10
lsdb-overflow-interval
Use lsdb-overflow-interval to set the interval that OSPF exits overflow state.
Use undo lsdb-overflow-interval to restore the default.
The OSPF exit overflow interval is 300 seconds.
OSPF view
interval: Specifies the interval that OSPF exits overflow state, in the range of 0 to 2147483647 seconds.
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. In this state, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself to save system resources.
You can configure the interval that OSPF exits overflow state. An interval of 0 indicates that the timer is not started and OSPF does not exit overflow state.
# Set the OSPF exit overflow interval to 10 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-interval 10
lsdb-overflow-limit
Use lsdb-overflow-limit to set the upper limit of external LSAs in the LSDB.
Use undo lsdb-overflow-limit to restore the default.
lsdb-overflow-limit number
The number of external LSAs is not limited.
OSPF view
number: Specifies the upper limit of external LSAs in the LSDB, in the range of 1 to 1000000.
# Set the upper limit of external LSAs to 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
maxage-lsa route-calculate-delay
Use maxage-lsa route-calculate-delay to set the delay for route calculation triggered by router LSAs with max age.
Use undo maxage-lsa route-calculate-delay to restore the default.
maxage-lsa route-calculate-delay delay-interval
The delay is 10 seconds for route calculation triggered by router LSAs with max age.
OSPF view
delay-interval: Specifies the delay for route calculation triggered by router LSAs with max age, in the range of 0 to 65535 seconds.
When a router receives a router LSA with max age, it immediately computes routes with the SPF algorithm rather than with the router LSA. During route flapping, such a route calculation can make the situation worse. You can use this command to suppress frequent route flaps by setting the routing calculation delay.
# Set the delay to 20 seconds for route calculation triggered by router LSAs with max age.
[Sysname] ospf 1
[Sysname-ospf-1] maxage-lsa route-calculate-delay 20
maximum load-balancing
Use maximum load-balancing to set the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of OSPF ECMP routes equals the maximum number of ECMP routes, which is configurable by using the max-ecmp-num command.
OSPF view
number: Specifies the maximum number of ECMP routes. No ECMP load balancing is available when the number is set to 1. The value range for this argument is 1 to 32.
The maximum value for the number argument of the maximum load-balancing command is restricted by the maximum number of ECMP routes, which is configurable with the max-ecmp-num command. The maximum value is the value for the max-ecmp-num command if it is less than the specification supported by the device.
# Set the maximum number of ECMP routes to 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
max-ecmp-num
network
Use network to enable OSPF on the interface attached to the specified network in the area.
Use undo network to disable OSPF for the interface attached to the specified network in the area.
undo network ip-address wildcard-mask
OSPF is not enabled for any interface.
OSPF area view
ip-address: Specifies the IP address of a network.
wildcard-mask: Specifies the wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
This command enables OSPF on the interface attached to the specified network. The interface's primary IP address must be in the specified network. If only the interface's secondary IP address is on the network, the interface cannot run OSPF.
# Specify the interface whose primary IP address is on network 131.108.20.0/24 to run OSPF in Area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
ospf
non-stop-routing
Use non-stop-routing to enable OSPF NSR.
Use undo non-stop-routing to disable OSPF NSR.
non-stop-routing
OSPF NSR is disabled.
OSPF view
This command takes effect only for the current process. As a best practice, enable OSPF NSR for each process if multiple OSPF processes exist.
OSPF NSR and OSPF GR are mutually exclusive. Do not configure the non-stop-routing command and the graceful-restart command at the same time.
# Enable NSR for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] non-stop-routing
nssa
Use nssa to configure an area as an NSSA area.
Use undo nssa to restore the default.
In OSPF area view:
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
undo nssa [ default-route-advertise [ cost | nssa-only | route-policy | type ] * | no-import-route | no-summary | suppress-fa | [ translate-always | translate-never ] | translator-stability-interval ] *
No area is configured as an NSSA area.
OSPF area view
default-route-advertise: Used on an NSSA ABR or an ASBR only. With this keyword, an NSSA ABR redistributes a default route in a Type-7 LSA into the NSSA area. The ABR redistributes a default route regardless of whether a default route exists in the routing table. With this keyword, an ASBR redistributes a default route in a Type-7 LSA only when the default route exists in the routing table.
cost cost-value: Specifies a cost for the default route, in the range of 0 to 16777214. If you do not specify this option, the default cost specified by the default-cost command applies.
nssa-only: Limits the default route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. By default, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit is set to 0.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When a default route exists in the routing table and the routing policy is matched, the command redistributes a default route in a Type-7 LSA into the OSPF routing domain. The routing policy modifies values in the Type-7 LSA.
type type: Specifies a type for the Type-7 LSA, 1 or 2. If you do not specify this option, the default type specified by the default type command applies.
no-import-route: Used on an NSSA ABR to control the import-route command to not redistribute routes into the NSSA area.
no-summary: Used only on an ABR to advertise a default route in a Type-3 summary LSA into the NSSA area and to not advertise other summary LSAs into the area. The area is a totally NSSA area.
suppress-fa: Suppresses the forwarding address in the Type-7 LSAs from being placed in the Type-5 LSAs.
translate-always: Always translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
translate-ignore-checking-backbone: Ignores checking for FULL state neighbors in the backbone area during the translator election in the NSSA area.
translate-never: Never translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
translator-stability-interval value: Specifies the stability interval of the translator. During the interval, the translator can maintain its translating capability after another device becomes the new translator. The value argument is the stability interval in the range of 0 to 900 seconds and defaults to 0. A value of 0 means the translator does not maintain its translating capability when a new translator arises.
All routers attached to an NSSA area must be configured with the nssa command in area view.
If you specify the translate-ignore-checking-backbone keyword for an ABR, you must also specify the keyword for other ABRs in the NSSA area. This ensures that a translator can be elected among the ABRs.
# Configure Area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
default-cost (OSPF area view)
Use opaque-capability enable to enable opaque LSA advertisement and reception.
Use undo opaque-capability to disable opaque LSA advertisement and reception.
The feature is enabled.
OSPF view
After the opaque LSA advertisement and reception capability is enabled, OSPF can receive and advertise Type-9, Type-10, and Type-11 opaque LSAs.
# Disable opaque LSA advertisement and reception.
[Sysname] ospf 100
[Sysname-ospf-100] undo opaque-capability
ospf
Use ospf to enable OSPF and enter OSPF view.
Use undo ospf to disable OSPF.
ospf [ process-id | router-id { auto-select | router-id } | vpn-instance vpn-instance-name ] *
undo ospf [ process-id ] [ router-id ]
OSPF is disabled.
router-id: Specifies an OSPF router ID. If you do not specify an OSPF router ID, the global router ID is used.
auto-select: Automatically obtains an OSPF router ID.
router-id: Manually specifies an OSPF router ID in dotted decimal notation. The value range is from 0.0.0.1 to 255.255.255.255.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the OSPF process runs on the public network.
You can enable multiple OSPF processes on a router and specify different router IDs for them.
Enable an OSPF process before performing other tasks.
If you specify the auto-select keyword, the OSPF process obtains a router ID in the following ways:
· During the startup of the OSPF process, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
· During the reboot of the router, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
· During the restart of the OSPF process, the highest primary IPv4 address of the loopback interface that runs the process is specified as the router ID. If no loopback address is available, the highest primary IPv4 address of the interface that runs the process is used, regardless of the interface state (up or down).
If you do not specify the router-id keyword, the undo ospf command shuts down an OSPF process. If you specify the router-id keyword, the undo ospf command specifies the global router ID as the router ID. The setting takes effect after the OSPF process restarts.
# Enable OSPF process 100 and specify router ID 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
ospf area
Use ospf area to enable OSPF on an interface.
Use undo ospf area to disable OSPF on an interface.
undo ospf process-id area [ exclude-subip ]
OSPF is not enabled on an interface.
Interface view
area-id: Specifies an area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format.
exclude-subip: Excludes secondary IP addresses. If you do not specify this keyword, the command enables OSPF also on secondary IP addresses.
The ospf area command has a higher priority than the network command.
If the specified process and area do not exist, the command creates the process and area. Disabling an OSPF process on an interface does not delete the OSPF process or the area.
# Enable OSPF process 1 on GigabitEthernet 1/0/13 that is in Area 2 and exclude secondary IP addresses.
[Sysname] interface gigabitethernet 1/0/13
[Sysname-GigabitEthernet1/0/13] ospf 1 area 2 exclude-subip
network
ospf authentication-mode
Use ospf authentication-mode to set the authentication mode and key on an interface.
Use undo ospf authentication-mode to remove specified configuration.
For MD5/HMAC-MD5/HMAC-SHA-256 authentication:
ospf authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
undo ospf authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id
For simple authentication:
ospf authentication-mode simple { cipher | plain } string
undo ospf authentication-mode simple
No authentication is performed for an interface.
Interface view
hmac-md5: Specifies HMAC-MD5 authentication.
hmac-sha-256: Specifies HMAC-SHA-256 authentication.
md5: Specifies MD5 authentication.
simple: Specifies simple authentication.
key-id: Specifies a key by its ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
· In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
· In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
· In HMAC-SHA-256 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
To establish or maintain adjacencies, interfaces attached to the same network segment must have the same authentication mode and key.
If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string. To minimize the risk of key compromise, use only one key for an interface and delete the old key after key replacement.
To replace the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication on an interface, you must configure the new key before removing the old key from each router. OSPF uses the key rollover mechanism to ensure that the routers can pass authentication before the replacement is complete on the interface. After you configure a new key on a router, the router sends copies of the same packet, each authenticated by a different key, including the new key and the keys in use. This practice continues until the router detects that all its neighbors have the new key.
# On GigabitEthernet 1/0/12, enable MD5 authentication, and set the interface key ID to 15 and the key to 123456 in plaintext form.
[Sysname] interface gigabitethernet 1/0/12
[Sysname-GigabitEthernet1/0/12] ospf authentication-mode md5 15 plain 123456
# On GigabitEthernet 1/0/12, enable simple authentication, and set the key to 123456 in plaintext form.
[Sysname-GigabitEthernet1/0/12] ospf authentication-mode simple plain 123456
authentication-mode
ospf bfd adjust-cost
Use ospf bfd adjust-cost to enable OSPF to adjust the interface cost according to the BFD session state.
Use undo ospf bfd adjust-cost to restore the default.
ospf bfd adjust-cost { cost-offset | max }
OSPF does not adjust the link cost according to the BFD session state.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the BFD session goes down. The value range for this argument is 1 to 65534. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost, and cannot exceed 65535.
max: Sets the interface cost to the maximum value 65535 when the BFD session goes down.
After you enable BFD for OSPF, the OSPF neighbor relationship goes down when the BFD session is down and comes up when the BFD session is up. When the BFD session state changes frequently, OSPF neighbor relationship flapping will occur and traffic forwarding might be affected.
To resolve this issue, enable OSPF to adjust the interface cost according to the BFD session state.
After you execute this command on an interface, OSPF adjusts the interface cost as follows:
· When the BFD session on the interface goes down, OSPF increases the cost value for the interface.
· When the BFD session on the interface comes up, OSPF restores the cost value for the interface.
# Enable OSPF to adjust the cost of interface GigabitEthernet 1/0/12 according to the BFD session state, and set the value to be added to the interface cost to 100.
[Sysname-GigabitEthernet1/0/12] ospf bfd enable
[Sysname-GigabitEthernet1/0/12] ospf bfd adjust-cost 100
display ospf
display ospf interface
ospf bfd enable
ospf bfd enable
Use ospf bfd enable to enable BFD on an OSPF interface.
Use undo ospf bfd enable to disable BFD on an OSPF interface.
ospf bfd enable [ echo ]
BFD for OSPF is disabled.
Interface view
echo: Enables BFD single-hop echo detection. If you do not specify this keyword, the command enables BFD bidirectional control detection.
# Enable BFD for OSPF on GigabitEthernet 1/0/12.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[Sysname-ospf-1-area-0.0.0.0] interface gigabitethernet 1/0/12
ospf cost
Use ospf cost to set an OSPF cost for an interface.
Use undo ospf cost to restore the default.
ospf cost cost-value
undo ospf cost
An interface computes its OSPF cost according to the interface bandwidth. For a loopback interface, the cost is 0.
Interface view
cost-value: Specifies an OSPF cost in the range of 0 to 65535 for a loopback interface, and in the range of 1 to 65535 for other interfaces.
If you do not execute this command, the interface automatically computes its OSPF cost.
# Set the OSPF cost on GigabitEthernet 1/0/12 to 65.
[Sysname-GigabitEthernet1/0/12] ospf cost 65
bandwidth-reference
ospf cost-fallback
Use ospf cost-fallback to change the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold.
Use undo ospf cost-fallback to remove the configuration.
ospf cost-fallback cost-value threshold bandwidth-value
A Layer 3 aggregate interface uses the original link cost.
cost-value: Specifies a link cost in the range of 1 to 65535. As a best practice, set the link cost to a value higher than the original link cost of the interface.
threshold bandwidth-value: Specifies the bandwidth threshold in the range of 1 to 4294967295 Mbps.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, execute this command to change the link cost of a Layer 3 aggregate interface as follows:
· When the bandwidth of the Layer 3 aggregate interface falls below the bandwidth threshold, the aggregate interface uses the specified link cost. Then, OSPF can select an optimal path for traffic forwarding.
· When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original link cost.
# Change the link cost of interface Route-Aggregation 1 to 100 when its bandwidth falls below 300 Mbps.
[Sysname] interface Route-Aggregation 1
[Sysname-Route-Aggregation1] ospf cost-fallback 100 threshold 300
ospf database-filter
Use ospf database-filter to filter outbound LSAs on an interface.
Use undo ospf database-filter to restore the default.
ospf database-filter { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
The outbound LSAs are not filtered on the interface.
Interface view
all: Filters all outbound LSAs except the Grace LSAs.
ase: Filters outbound Type-5 LSAs.
nssa: Filters outbound Type-7 LSAs.
summary: Filters outbound Type-3 LSAs.
acl ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
· To deny/permit LSAs with the specified link state ID, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
· To deny/permit LSAs with the specified link state ID and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the link state ID of an LSA and the destination keyword specifies the subnet mask of the LSA. For the mask configuration to take effect, specify a contiguous subnet mask.
If the neighbor has already received an LSA to be filtered, the LSA still exists in the LSDB of the neighbor after you execute the command.
# Filter all outbound LSAs (except the Grace LSAs) on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf database-filter all
# On GigabitEthernet 1/0/13, configure ACL 2000, 2100, and 2200 to filter outbound Type-5, Type-7, and Type-3 LSAs, respectively.
[Sysname-GigabitEthernet1/0/13] ospf database-filter ase acl 2000 nssa acl 2100 summary acl 2200
database-filter peer (OSPF view)
ospf dr-priority
Use ospf dr-priority to set the router priority for DR/BDR election on an interface.
Use undo ospf dr-priority to restore the default value.
ospf dr-priority priority
The router priority is 1.
Interface view
priority: Specifies the router priority for the interface, in the range of 0 to 255.
The greater the value, the higher the priority for DR/BDR election. If a device has a priority of 0, it will not be elected as a DR or BDR.
# Set the router priority on GigabitEthernet 1/0/12 to 8.
[Sysname-GigabitEthernet1/0/12] ospf dr-priority 8
ospf fast-reroute lfa-backup
Use ospf fast-reroute lfa-backup to enable LFA on an interface.
Use undo ospf fast-reroute lfa-backup to disable LFA on an interface.
LFA is enabled on an interface.
Interface view
An interface enabled with LFA can be selected as a backup interface. After you disable LFA on the interface, it cannot be selected as a backup interface.
# Disable GigabitEthernet 1/0/12 from calculating a backup next hop by using the LFA algorithm.
[Sysname-GigabitEthernet1/0/12] undo ospf fast-reroute lfa-backup
ospf fast-reroute remote-lfa disable
Use ospf fast-reroute remote-lfa disable to disable remote LFA calculation on an interface.
Use undo ospf fast-reroute remote-lfa disable to enable remote LFA calculation on an interface.
Remote LFA calculation is enabled on an interface.
Interface view
Use this command to disable remote LFA calculation on an interface to prevent it from participating in the calculation.
# Disable remote LFA calculation on interface GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf 1 area 0
[Sysname-GigabitEthernet1/0/12] ospf fast-reroute remote-lfa disable
ospf link-quality adjust-cost
Use ospf link-quality adjust-cost to enable OSPF to adjust the interface cost according to the link quality.
Use undo ospf link-quality adjust-cost to restore the default.
ospf link-quality adjust-cost { cost-offset | max }
OSPF does not adjust the interface cost according to the link quality.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the link quality changes to LOW. The value range for this argument is 1 to 65534. When the link quality changes to LOW, the interface cost is cost-offset plus the original interface cost, and cannot exceed 65535.
max: Sets the interface cost to the maximum value 65535 when the link quality changes to LOW.
Error codes, which refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption.
To reduce the impact of error codes on an OSPF network, you can enable OSPF to adjust the interface cost according to the link quality.
After you configure this command on an interface, OSPF adjusts the interface cost as follows:
· When the link quality of the interface becomes LOW, OSPF increases the cost value for the interface.
· When the link quality of the interface restores to GOOD, OSPF restores the cost value for the interface.
# Enable OSPF to adjust the cost of interface GigabitEthernet 1/0/12 according to the link quality, and set the value to be added to the interface cost to 200.
[Sysname-GigabitEthernet1/0/12] ospf link-quality adjust-cost 200
ospf mib-binding
Use ospf mib-binding to bind an OSPF process to MIB.
Use undo ospf mib-binding to restore the default.
ospf mib-binding process-id
MIB is bound to the OSPF process with the smallest process ID.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535.
To access information or data about an OSPF process in RFC4750-OSPF.MIB, use this command. To access information or data about an OSPF process in a Comware MIB for the device, you do not need to use this command. You can access information or data about all OSPF processes in the Comware MIBs.
If the specified process ID does not exist, a notification is displayed to report that the MIB binding configuration has failed.
Deleting an OSPF process that has been bound to MIB unbinds the OSPF process from MIB, and re-binds MIB to the OSPF process with the smallest process ID.
# Bind OSPF process 100 to MIB.
[Sysname] ospf mib-binding 100
ospf mtu-enable
Use ospf mtu-enable to enable an interface to add the interface MTU into DD packets.
Use undo ospf mtu-enable to restore the default.
ospf mtu-enable
The MTU in DD packets is 0.
Interface view
After a virtual link is established through a Virtual-Template or Tunnel, two devices on the link from different vendors might have different MTU values. To make them consistent, restore the interfaces' MTU to the default value 0.
After you configure this command, the interface checks whether the MTU in a received DD packet is greater than its own MTU. If yes, the interface discards the packet.
# Enable GigabitEthernet 1/0/12 to add the interface MTU value into DD packets.
[Sysname-GigabitEthernet1/0/12] ospf mtu-enable
ospf network-type
Use ospf network-type to specify the network type for an interface.
Use undo ospf network-type to restore the default.
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ peer-address-check ] }
By default, the network type for Ethernet and FDDI interfaces is broadcast.
Interface view
broadcast: Specifies the network type as broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
unicast: Specifies the P2MP interface to unicast OSPF packets. By default, a P2MP interface multicasts OSPF packets.
p2p: Specifies the network type as P2P.
peer-address-check: Checks whether the peer interface and the local interface are on the same network segment. Two P2P interfaces can establish a neighbor relationship only when they are on the same network segment.
If only two routers run OSPF on a network, you can configure the network type for the connected interfaces as P2P.
When the network type of an interface is P2MP unicast, all OSPF packets are unicast by the interface.
# Specify the OSPF network type for GigabitEthernet 1/0/12 as P2MP.
[Sysname-GigabitEthernet1/0/12] ospf network-type p2mp
ospf dr-priority
ospf packet-size
Use ospf packet-size to set the maximum length of OSPF packets that can be sent by an interface.
Use undo ospf packet-size to restore the default.
ospf packet-size value
The maximum length of OSPF packets that an interface can send equals the interface's MTU.
Interface view
value: Specifies the maximum length of OSPF packets that can be sent by an interface, in the range of 500 to 10000 bytes.
The interface chooses the smaller one between the value set in this command and the interface MTU, and uses it as the maximum length of OSPF packets that can be sent.
# Set the maximum length of OSPF packets that can be sent by GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf packet-size 1000
ospf peer suppress-flapping
Use ospf peer suppress-flapping to configure detection parameters for OSPF neighbor flapping suppression.
Use undo ospf peer suppress-flapping to remove the configuration.
ospf peer suppress-flapping { detect-interval detect-interval | threshold threshold | resume-interval resume-interval } *
undo ospf peer suppress-flapping { detect-interval | threshold | resume-interval } *
The detect interval is 60 seconds, the threshold value is 10, and the resume interval is 120 seconds.
Interface view
detect-interval detect-interval: Specifies the interval to detect OSPF neighbor flapping events, in the range of 1 to 300 seconds. The default value is 60. If the time interval between two consecutive neighbor state changes (from Full to another state) is less than the specified detect interval, a neighbor flapping event has occurred.
threshold threshold: Specifies the threshold value that triggers neighbor flapping suppression, in the range of 1 to 1000. The default value is 10.
resume-interval resume-interval: Specifies the resume interval of neighbor flapping suppression, in the range of 2 to 1000 seconds. The default value is 120.
Before executing this command, make sure OSPF neighbor flapping suppression is enabled by using the suppress-flapping hold-down or ospf peer suppress-flapping hold-max-cost command.
The OSPF neighbor flapping suppression mechanism is as follows:
· The interface starts a flapping counter to count neighbor flapping events. When the device detects a neighbor flapping event, it increases the flapping counter by 1.
A neighbor flapping event occurs when the time interval between two consecutive neighbor state changes (from Full to another state) is less than the specified detect interval.
· If the time interval between two consecutive neighbor state changes (from Full to another state) is greater than the specified resume interval, the flapping counter is reset.
· If the flapping counter reaches or exceeds the specified threshold, OSPF starts flapping suppression for all neighbors on the interface.
· During the flapping suppression period, if the device detects another neighbor flapping event, it resets the resume interval.
The resume interval value must be greater than the detect interval value.
The resume interval specifies the suppression period during which the maximum cost is used for neighbor flapping suppression enabled by using the ospf peer suppress-flapping hold-max-cost command.
# Set the detect interval, threshold, and resume interval values to 5, 40, and 20 for OSPF neighbor flapping suppression on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf peer suppress-flapping detect-interval 5 threshold 40 resume-interval 20
display ospf interface verbose
display ospf
ospf peer suppress-flapping hold-down
Use ospf peer suppress-flapping hold-down to enable OSPF neighbor flapping suppression and set the suppression timer.
Use undo ospf peer suppress-flapping to disable OSPF neighbor flapping suppression.
ospf peer suppress-flapping hold-down interval
undo ospf peer suppress-flapping hold-down
OSPF neighbor flapping suppression is disabled.
Interface view
interval: Specifies the neighbor flapping suppression timer in the range of 1 to 600 seconds. OSPF can establish neighbor relationships only when the suppression timer expires.
Neighbor state changes will cause neighbor relationship reestablishment, LSDB synchronization, and route calculation. A large number of packets will be exchanged, which affects stability of existing neighbors and operation of OSPF and relevant services. To resolve this issue, enable OSPF neighbor flapping suppression to delay neighbor relationship establishment or traffic forwarding through neighbor links.
Use this command to avoid frequent flooding and topology changes during neighbor relationship establishment. Before the specified neighbor flapping suppression timer expires, OSPF does not establish neighbor relationships.
If you execute both the suppress-flapping hold-down and ospf peer suppress-flapping hold-max-cost commands for an interface, the suppress-flapping hold-down command applies first. When neighbor suppression starts, OSPF performs the following operations in sequence:
1. Disables neighbor relationship establishment until the specified suppression timer expires.
2. Allows neighbor relationship establishment and sets the maximum cost for neighbor links until the specified resume interval expires.
3. Resumes the original link cost when the specified resume interval expires.
Neighbor flapping suppression applies to all neighbors attached to the interface.
# Enable OSPF neighbor flapping suppression and set the suppression timer to 200 seconds on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf peer suppress-flapping hold-down 200
display ospf
Use ospf peer suppress-flapping hold-max-cost to enable OSPF neighbor flapping suppression and set the maximum cost for flapping links.
Use undo ospf peer suppress-flapping hold-max-cost to disable OSPF neighbor flapping suppression.
Interface view
Frequent neighbor state changes will cause neighbor relationship reestablishment, LSDB synchronization, and route calculation. A large number of packets will be exchanged, which affects stability of existing neighbors and operation of OSPF and relevant services. To resolve this issue, enable OSPF neighbor flapping suppression to delay neighbor relationship establishment or traffic forwarding through neighbor links.
After you execute this command, OSPF sets the cost of all neighbor links to the maximum value 65535 within the neighbor flapping suppression period (resume interval). When the resume interval expires, OSPF resumes the original link cost.
# Enable OSPF neighbor flapping suppression and set the maximum cost for neighbor links on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf peer suppress-flapping hold-max-cost
display ospf
ospf prefix-suppression
Use ospf prefix-suppression to disable an OSPF interface from advertising all its IP prefixes, except for the prefixes of secondary IP addresses.
Use undo ospf prefix-suppression to restore the default.
Prefix suppression is disabled.
Interface view
disable: Disables prefix suppression for an interface.
To disable prefix suppression for an interface associated with an OSPF process that has been enabled with prefix suppression, use the ospf prefix-suppression disable command on that interface.
# Enable prefix suppression for GigabitEthernet 1/0/13.
[Sysname-GigabitEthernet1/0/13] ospf prefix-suppression
prefix-suppression
ospf primary-path-detect bfd
Use ospf primary-path-detect bfd to enable BFD for OSPF FRR or OSPF PIC.
Use undo ospf primary-path-detect bfd to disable BFD for OSPF FRR or OSPF PIC.
ospf primary-path-detect bfd { ctrl | echo }
BFD is disabled for OSPF FRR or OSPF PIC.
Interface view
ctrl: Enables BFD control packet mode.
echo: Enables BFD echo packet mode.
This command enables OSPF PIC or OSPF FRR to use BFD to detect primary link failures.
# On GigabitEthernet 1/0/12, enable BFD control packet mode for OSPF FRR.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
[Sysname-ospf-1] quit
[Sysname-GigabitEthernet1/0/12] ospf primary-path-detect bfd ctrl
# On GigabitEthernet 1/0/13, enable BFD echo packet mode for OSPF PIC.
[Sysname] ospf 1
[Sysname-ospf-1] pic additional-path-always
[Sysname-GigabitEthernet1/0/13] ospf primary-path-detect bfd echo
ospf timer dead
Use ospf timer dead to set the neighbor dead interval.
Use undo ospf timer dead to restore the default.
ospf timer dead seconds
The dead interval is 40 seconds for broadcast and P2P interfaces. The dead interval is 120 seconds for P2MP interfaces.
Interface view
seconds: Specifies the dead interval in the range of 1 to 2147483647 seconds.
If an interface receives no hello packet from a neighbor within the dead interval, the interface considers the neighbor down.
The dead interval on an interface is a minimum of four times the hello interval. Routers attached to the same segment must have the same dead interval.
# Set the dead interval for GigabitEthernet 1/0/12 to 60 seconds.
[Sysname-GigabitEthernet1/0/12] ospf timer dead 60
ospf timer hello
ospf timer hello
Use ospf timer hello to set the hello interval on an interface.
Use undo ospf timer hello to restore the default.
ospf timer hello seconds
The hello interval is 10 seconds for P2P and broadcast interfaces, and is 30 seconds for P2MP interfaces.
Interface view
seconds: Specifies the hello interval in the range of 1 to 65535 seconds.
The shorter the hello interval, the faster the topology converges, and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Set the hello interval on GigabitEthernet 1/0/12 to 20 seconds.
[Sysname-GigabitEthernet1/0/12] ospf timer hello 20
ospf timer dead
ospf timer retransmit
Use ospf timer retransmit to set the LSA retransmission interval on an interface.
Use undo ospf timer retransmit to restore the default.
ospf timer retransmit seconds
The LSA retransmission interval is 5 seconds on an interface.
Interface view
seconds: Specifies the LSA retransmission interval in the range of 1 to 3600 seconds.
After sending an LSA, an interface waits for an acknowledgment packet. If the interface receives no acknowledgment within the retransmission interval, it retransmits the LSA.
To avoid unnecessary retransmissions, set an appropriate retransmission interval. For example, you can set a large retransmission interval value on a low-speed link.
# Set the LSA retransmission interval to 8 seconds on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf timer retransmit 8
ospf trans-delay
Use ospf trans-delay to set the LSA transmission delay on an interface.
Use undo ospf trans-delay to restore the default.
ospf trans-delay seconds
The LSA transmission delay is 1 second.
Interface view
seconds: Specifies the LSA transmission delay in the range of 1 to 3600 seconds.
Each LSA in the LSDB has an age that increases by 1 every second, but the age does not change during transmission. Adding a transmission delay into the age time is important in low speed networks.
# Set the LSA transmission delay to 3 seconds on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] ospf trans-delay 3
ospf troubleshooting max-number
Use ospf troubleshooting max-number to set the maximum number of OSPF neighbor relationship troubleshooting entries.
Use undo ospf troubleshooting max-number to restore the default.
ospf troubleshooting max-number number
The maximum number of OSPF neighbor relationship troubleshooting entries is 100.
number: Specifies the maximum number of OSPF neighbor relationship troubleshooting entries, in the range of 0 to 65535. The value 0 means OSPF does not record neighbor relationship troubleshooting entries.
# Set the maximum number of OSPF neighbor relationship troubleshooting entries to 50.
[Sysname] ospf troubleshooting max-number 50
ospf ttl-security
Use ospf ttl-security to enable OSPF GTSM for an interface.
Use ospf ttl-security disable to disable OSPF GTSM for an interface.
Use undo ospf ttl-security to restore the default.
ospf ttl-security [ hops hop-count | disable ]
An interface uses the GTSM configuration of the area to which the interface belongs.
Interface view
hops hop-count: Specifies the hop limit for checking OSPF packets, in the range of 1 to 254. The default hop limit is 1 for packets from common neighbors, and is 255 for packets from virtual link neighbors.
disable: Disables OSPF GTSM for the interface.
GTSM checks OSPF packets from common neighbors and virtual link neighbors.
GTSM protects the device by comparing the TTL value in the IP header of incoming OSPF packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the OSPF packets sent by the device have a TTL of 255. To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
The GTSM configuration in OSPF area view applies to all OSPF interfaces in the area. The GTSM configuration in interface view takes precedence over the configuration in OSPF area view.
If a virtual link exists in an area, you can enable GTSM for the interfaces on the virtual link. If you do not know the interfaces on the virtual link, enable GTSM in area view to prevent packet loss.
# Enable OSPF GTSM for GigabitEthernet 1/0/12 and set the hop limit to 254.
[Sysname-GigabitEthernet1/0/12] ospf ttl-security hops 254
# Enable GTSM in OSPF area view and disable OSPF GTSM for GigabitEthernet 1/0/12.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] ttl-security
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-GigabitEthernet1/0/12] ospf ttl-security disable
ttl-security (OSPF area view)
pic
Use pic to enable OSPF PIC.
Use undo pic to disable OSPF PIC.
undo pic
OSPF PIC is enabled.
OSPF view
additional-path-always: Allows the indirect suboptimal route as the backup route.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes. PIC applies only to inter-area routes and external routes.
When both OSPF PIC and OSPF FRR are configured, OSPF FRR takes effect.
# Configure OSPF PIC to support the suboptimal route as the backup route.
[Sysname] ospf 1
preference
Use preference to set a preference for OSPF.
Use undo preference to remove the configuration.
undo preference [ ase ]
The preference is 10 for OSPF internal routes and 150 for OSPF external routes (ASE routes).
OSPF view
ase: Specifies a preference for OSPF external routes. If you do not specify this keyword, the command sets a preference for OSPF internal routes.
preference: Specifies the preference value in the range of 1 to 255. A smaller value represents a higher preference.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a preference for the specified routes.
If multiple routing protocols find routes to the same destination, the router uses the route found by the protocol with the highest preference.
When the route-policy route-policy-name option is specified, the following preferences take effect:
· For routes matching the routing policy, the preference set in the routing policy takes effect.
· For other routes, the preference set with the preference command takes effect.
# Set a preference of 200 for OSPF external routes.
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
# Set a preference of 100 for OSPF internal routes matching the specified routing policy, and set a preference of 150 for other routes.
[Sysname] ip prefix-list test index 10 permit 100.1.1.0 24
[Sysname] route-policy pre permit node 10
[Sysname-route-policy-pre-10] if-match ip address prefix-list test
[Sysname-route-policy-pre-10] apply preference 100
[Sysname-route-policy-pre-10] quit
[Sysname] ospf 100
[Sysname-ospf-100] preference route-policy pre 150
prefix-priority
Use prefix-priority to enable prefix prioritization.
Use undo prefix-priority to disable prefix prioritization.
Prefix prioritization is disabled.
OSPF view
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a priority for the specified route prefixes.
Prefix prioritization enables the device to install prefixes in descending priority order: critical, high, medium, and low. The prefix priorities are assigned through routing policies. When a route is assigned multiple prefix priorities, it uses the highest priority.
By default, the 32-bit OSPF host routes have a medium priority and other routes have a low priority.
# Use a routing policy to assign the medium priority to the specified route prefixes.
[Sysname-route-policy-pre-10] apply prefix-priority medium
[Sysname] ospf 100
[Sysname-ospf-100] prefix-priority route-policy pre
prefix-suppression
Use prefix-suppression to disable an OSPF process from advertising all IP prefixes except for the prefixes of loopback interfaces, secondary IP addresses, and passive interfaces.
Use undo prefix-suppression to restore the default.
prefix-suppression
An OSPF process advertises all prefixes.
OSPF view
By default, an OSPF interface advertises all of its prefixes in LSAs. To speed up OSPF convergence, you can suppress interfaces from advertising all their prefixes. This feature helps improve network security by preventing IP routing to the suppressed networks.
As a best practice, configure prefix suppression on all OSPF routers if you want to use prefix suppression.
To disable an OSPF process from advertising the prefixes of loopback and passive interfaces, configure prefix suppression on the interfaces by using the ospf prefix-suppression command.
When prefix suppression is enabled:
· On P2P and P2MP networks, OSPF does not advertise Type-3 links in Type-1 LSAs. Other routing information can still be advertised to ensure traffic forwarding.
· On broadcast networks, the DR generates Type-2 LSAs with a mask length of 32 to suppress network routes. Other routing information can still be advertised to ensure traffic forwarding. If no neighbors exist, the DR also does not advertise the primary IP addresses of interfaces in Type-1 LSAs.
# Enable prefix suppression for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] prefix-suppression
reset ospf event-log
Use reset ospf event-log to clear OSPF log information.
reset ospf [ process-id ] event-log [ lsa-flush | lsa-history | peer [ slot slot-number ] | route | spf ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears OSPF log information for all OSPF processes.
lsa-flush: Clears LSA aging log information.
lsa-history: Clears self-originated and received LSA log information.
peer: Clears neighbor state change log information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears neighbor state change log information on the member device where the active process resides.
route: Clears OSPF route log information.
spf: Clears route calculation log information.
If you do not specify a log type, this command clears all log information.
# Clear OSPF route calculation log information for all OSPF processes.
<Sysname> reset ospf event-log spf
display ospf event-log
reset ospf event-log hello
Use reset ospf event-log hello to clear OSPF log information about received or sent hello packets.
reset ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } [ slot slot-number ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears OSPF log information for all processes.
received: Specifies log information for received hello packets.
sent: Specifies log information for sent hello packets.
abnormal: Specifies log information for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies log information for received hello packets that were dropped.
failed: Specifies log information for hello packets that failed to be sent.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears received or sent hello packet log information on the member device where the active process resides.
# Clear sent hello packet log information for all OSPF processes.
<Sysname> reset ospf event-log hello sent
display ospf event-log hello
reset ospf process
Use reset ospf process to restart all OSPF processes or a specified process.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command restarts all OSPF processes.
graceful-restart: Resets the OSPF process by using GR.
The reset ospf process command performs the following actions:
· Clears all invalid LSAs without waiting for their timeouts.
· Makes a newly configured router ID take effect.
· Starts a new DR/BDR election.
· Keeps previous OSPF configurations.
The system prompts you to select whether to restart OSPF process upon execution of this command.
# Restart all OSPF processes.
<Sysname> reset ospf process
Reset OSPF process? [Y/N]:y
reset ospf redistribution
Use reset ospf redistribution to restart route redistribution.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
reset ospf statistics
Use reset ospf statistics to clear OSPF statistics.
process-id: Clears the statistics for an OSPF process specified by its ID in the range of 1 to 65535.
# Clear OSPF statistics for all processes.
<Sysname> reset ospf statistics
display ospf statistics
reset ospf troubleshooting
Use reset ospf troubleshooting to clear OSPF neighbor relationship troubleshooting information.
# Clear OSPF neighbor relationship troubleshooting information.
<Sysname> reset ospf troubleshooting
display ospf troubleshooting
rfc1583 compatible
Use rfc1583 compatible to enable compatibility with RFC 1583.
Use undo rfc1583 compatible to disable compatibility with RFC 1583.
rfc1583 compatible
Compatibility with RFC 1583 is enabled.
OSPF view
RFC 1583 specifies a different method than RFC 2328 for selecting the optimal route to a destination in another AS. When multiple routes are available to the ASBR, OSPF selects the optimal route by using the following procedure:
1. Selects the route with the highest preference.
¡ If RFC 2328 is compatible with RFC 1583, all these routes have equal preference.
¡ If RFC 2328 is not compatible with RFC 1583, the intra-area route in a non-backbone area is preferred to reduce the burden of the backbone area. The inter-area route and intra-area route in the backbone area have equal preference.
2. Selects the route with lower cost if two routes have equal preference.
3. Selects the route with larger originating area ID if two routes have equal cost.
To avoid routing loops, set identical RFC 1583-compatibility on all routers in a routing domain.
# Disable compatibility with RFC 1583.
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
router id
Use router id to configure a global router ID.
Use undo router id to restore the default.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies the global router ID in dotted decimal format. The value range for this argument is 0.0.0.1 to 255.255.255.254.
OSPF uses a router ID to identify a device. If no router ID is specified, the global router ID is used.
If no global router ID is configured, the highest loopback interface IP address is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status (up or down).
During an active/standby switchover, the new active main processing unit (MPU) checks whether the previously backed up router ID is valid. If not, it selects a new router ID.
A new router ID is selected only when the interface IP address used as the router ID is removed or changed. Other events will not trigger a router ID re-selection. For example, router ID re-selection is not triggered in the following situations:
· The interface goes down.
· You change the router ID to the address of a loopback interface after a physical interface address is selected as the router ID.
· A higher interface IP address is configured as the router ID.
After a router ID is changed, you must use the reset command to enable it.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
silent-interface
Use silent-interface to disable an interface or all interfaces from receiving and sending OSPF packets.
Use undo silent-interface to remove the configuration.
An interface can receive and send OSPF packets.
OSPF view
all: Specifies all interfaces.
To disable a network from receiving and sending OSPF routes, use the command on the interface connected to the network.
# Disable GigabitEthernet 1/0/12 from receiving and sending OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface gigabitethernet 1/0/12
snmp trap rate-limit
Use snmp trap rate-limit to set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
Use undo snmp trap rate-limit to restore the default.
OSPF outputs a maximum of seven SNMP notifications within 10 seconds.
OSPF view
interval trap-interval: Specifies the SNMP notification output interval in the range of 2 to 60 seconds.
count trap-number: Specifies the number of SNMP notifications output by OSPF at each interval, in the range of 0 to 300. The value of 0 indicates that OSPF does not output SNMP notifications.
# Configure OSPF to output a maximum of 10 SNMP notifications within 5 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] snmp trap rate-limit interval 5 count 10
snmp-agent trap enable ospf
Use snmp-agent trap enable ospf to enable SNMP notifications for OSPF.
Use undo snmp-agent trap enable ospf to disable SNMP notifications for OSPF.
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
SNMP notifications for OSPF are enabled.
authentication-failure: Specifies notifications about authentication failures on an interface.
bad-packet: Specifies notifications about error messages received on an interface.
config-error: Specifies notifications about error configuration of an interface.
grhelper-status-change: Specifies notifications about GR helper state change.
grrestarter-status-change: Specifies notifications about GR restarter state change.
if-state-change: Specifies notifications about interface state change.
lsa-maxage: Specifies LSA max age notifications.
lsa-originate: Specifies notifications about locally generated LSAs.
lsdb-approaching-overflow: Specifies notifications about approaching LSDB overflows.
lsdb-overflow: Specifies LSDB overflow notifications.
neighbor-state-change: Specifies notifications about neighbor state change.
nssatranslator-status-change: Specifies notifications about NSSA translator state change.
retransmit: Specifies notifications about packets that are received and forwarded on an interface.
virt-authentication-failure: Specifies notifications about authentication failures on a virtual interface.
virt-bad-packet: Specifies notifications about error messages received on a virtual interface.
virt-config-error: Specifies notifications about error configuration of a virtual interface.
virt-retransmit: Specifies notifications about packets that are received and forwarded on a virtual interface.
virtgrhelper-status-change: Specifies notifications about neighbor GR helper state changes of a virtual interface.
virtif-state-change: Specifies notifications about virtual interface state change.
virtneighbor-state-change: Specifies notifications about the neighbor state change of a virtual interface.
# Disable SNMP notifications for OSPF.
[Sysname] undo snmp-agent trap enable ospf
snmp-agent trap ospf neighbor-state-change extended
Use snmp-agent trap ospf neighbor-state-change extended to extend the format of SNMP notifications for neighbor state changes.
Use undo snmp-agent trap ospf neighbor-state-change extended to restore the default.
OSPF does not extend the format of SNMP notifications for neighbor state changes.
After you execute this command, OSPF generates a notification in extended format when the state of a neighbor changes. Compared with notifications in standard format, notifications in extended format include interface names additionally, which enables the network administrator to quickly locate problems.
If the NMS does not support notifications in extended format, the NMS might fail to parse the notifications after you execute this command.
# Extend the format of SNMP notifications for neighbor state changes.
[Sysname] snmp-agent trap ospf neighbor-state-change extended
spf-schedule-interval
Use spf-schedule-interval to set the OSPF SPF calculation interval.
Use undo spf-schedule-interval to restore the default.
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
The maximum calculation interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF view
maximum-interval: Specifies the maximum OSPF SPF calculation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
conservative: Keeps the maximum interval when route flapping occurs. If you do not specify this keyword, the OSPF SPF calculation is performed at the maximum interval for three consecutive times and then performed at the minimum interval.
millisecond interval: Specifies the fixed OSPF SPF calculation interval in the range of 0 to 10000 milliseconds.
Based on the LSDB, an OSPF router uses SPF to calculate a shortest path tree with itself as the root. OSPF uses the shortest path tree to determine the next hop to a destination. By adjusting the SPF calculation interval, you can prevent overconsumption of bandwidth and router resources due to frequent topology changes.
For a stable network, use the minimum interval set by the spf-schedule-interval maximum-interval [ minimum-interval [ incremental-interval ] ] command. If network changes become frequent, the SPF calculation interval increases by the incremental interval × 2n-2 for each calculation until the maximum interval is reached. The value n is the number of calculation times. The minimum interval and the incremental interval cannot be greater than the maximum interval.
For a network that requires fast route convergence, use the spf-schedule-interval millisecond interval command to set a short SPF calculation interval.
# Set the maximum SPF calculation interval to 10 seconds, minimum interval to 500 milliseconds, and incremental interval to 300 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 300
stub
Use stub to configure an area as a stub area.
Use undo stub to restore the default.
In OSPF area view:
undo stub
No area is a stub area.
OSPF area view
default-route-advertise-always: Enables the ABR to advertise a default route in a Type-3 LSA into the stub area regardless of whether FULL-state neighbors exist in the backbone area. If you do not specify this keyword, the ABR advertises a default route in a Type-3 LSA into the stub area only when a minimum of one FULL-state neighbor exists in the backbone area.
no-summary: Enables the ABR to advertise only a default route in a Type-3 LSA into the stub area without advertising any other Type-3 LSAs. The area is a totally stub area.
To configure an area as a stub area, use the stub command on all routers attached to the area.
# Configure Area 1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
stub-router
Use stub-router to configure a router as a stub router.
Use undo stub-router to restore the default.
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] }| summary-lsa [ max-metric-value ] ] *
undo stub-router
The router is not configured as a stub router.
OSPF view
external-lsa max-metric-value: Specifies a cost for the external LSAs, in the range of 1 to 16777215. The default is 16711680.
include-stub: Specifies the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535.
on-startup seconds: Specifies the router as a stub router during reboot, and specifies the timeout time in the range of 5 to 86400 seconds.
wait-for-bgp seconds: Specifies the router as a stub router during BGP route convergence after reboot, and specifies the timeout time in the range of 5 to 86400 seconds. The default timeout time is 600 seconds.
summary-lsa max-metric-value: Specifies a cost for the Type-3 LSAs, in the range of 1 to 16777215. The default cost value is 16711680.
The router LSAs sent by the stub router over different links contain different link type values. A value of 3 represents a link to a stub network, and the cost of the link is not changed. A value of 1, 2, or 4 represents a point-to-point link, a link to a transit network, or a virtual link. The cost of these links is set to 65535. Neighbors on such links will not send packets to the stub router as long as they have a route with a smaller cost.
# Configure a stub router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
transmit-pacing
Use transmit-pacing to set the LSU transmission interval and the maximum number of LSU packets that can be sent at each interval.
Use undo transmit-pacing to restore the default.
An OSPF interface sends a maximum of three LSU packets every 20 milliseconds.
OSPF view
interval interval: Specifies an interval at which an interface sends LSU packets, in the range of 0 to 1000 milliseconds. If the router has multiple OSPF interfaces, increase this interval to reduce the total number of LSU packets sent by the router every second. As a best practice to maintain network stability, do not set the interval to 0 milliseconds when the OSPF LSDB is large or network changes are frequent.
count count: Specifies the maximum number of LSU packets sent by an interface at each interval, in the range of 1 to 200. If the router has multiple OSPF interfaces, decrease the maximum number to reduce the total number of LSU packets sent by the router every second.
# Configure all the interfaces running OSPF process 1 to send a maximum of 10 LSU packets every 30 milliseconds.
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
ttl-security
Use ttl-security to enable OSPF GTSM for an area.
Use undo ttl-security to disable OSPF GTSM for an area.
ttl-security [ hops hop-count ]
undo ttl-security
OSPF GTSM is disabled for an OSPF area.
OSPF area view
After you enable GTSM in area view, GTSM checks OSPF packets from common neighbors and virtual link neighbors.
As a best practice, set the hop limit if a virtual link exists in an area. You can enable GTSM for the interfaces on the virtual link. If you do not know the interfaces on the virtual link, enable GTSM in area view to prevent packet loss.
# Enable OSPF GTSM for OSPF area 1.
[Sysname] ospf 100
ospf ttl-security
vlink-peer
Use vlink-peer to configure a virtual link.
Use undo vlink-peer to remove a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | simple { cipher | plain } string } | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | { hmac-md5 | hmac-sha-256 | md5 } key-id | retransmit | simple | trans-delay ] *
No virtual links exist.
OSPF area view
router-id: Specifies the router ID of the neighbor on the virtual link.
dead seconds: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40. The dead interval must be identical with that on the virtual link neighbor, and a minimum of four times the hello interval.
hello seconds: Specifies the hello interval in the range of 1 to 8192 seconds. The default is 10. It must be identical with the hello interval on the virtual link neighbor.
hmac-md5: Specifies the HMAC-MD5 authentication mode.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
key-id: Specifies the key ID for MD5 or HMAC-MD5 authentication, in the range of 1 to 255.
retransmit seconds: Specifies the retransmission interval in the range of 1 to 3600 seconds. The default is 5.
trans-delay seconds: Specifies the transmission delay interval in the range of 1 to 3600 seconds. The default is 1.
As defined in RFC 2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
When you configure this command, follow these guidelines:
· The smaller the hello interval is, the faster the network converges, and the more network resources are consumed.
· A retransmission interval that is too small can cause unnecessary retransmissions. A large value is appropriate for a low speed link.
· Specify an appropriate transmission delay with the trans-delay keyword.
If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string. As a best practice to minimize the risk of key compromise, use only one key for a virtual link and delete the old key after key replacement.
To replace the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication for a virtual link, you must configure the new key before removing the old key from each router. OSPF uses the key rollover mechanism to ensure that the routers can pass authentication before the replacement is complete on the interface. After you configure a new key on a router, the router sends copies of the same packet, each authenticated by a different key, including the new key and the keys in use. This practice continues until the router detects that all its neighbors have the new key.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
authentication-mode
display ospf vlink
