| 01-Ethernet link aggregation commands | 290.31 KB |
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
lacp default-selected-port disable
link-aggregation bfd-compatible enable
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation reversion delay
link-aggregation secondary-down
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-aggregation selected-port minimum percentage
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 3 aggregate interface 1.
[Sysname-Route-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Route-Aggregation 1 is Route-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
Bandwidth: 1000 kbps
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Port priority: 0
0 packets input, 0 bytes, - drops
0 packets output, 0 bytes, - drops
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps. |
Port priority |
Port priority of the interface. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
Port link-type |
Port link type: · Access. · Trunk. · Hybrid. |
Tagged VLANs |
VLAN whose packets are sent out of this interface with a tag. |
Untagged VLANs |
VLAN whose packets are sent out of this interface without a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input/output rate |
Average input or output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received or sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received or sent on the interface. |
0 packets input, 0 bytes, - drops |
Statistics about packets received on the interface. A hyphen (-) indicates that the statistical item is not supported. |
0 packets output, 0 bytes, - drops |
Statistics about packets sent on the interface. A hyphen (-) indicates that the statistical item is not supported. |
Line protocol state |
Data link layer state of the interface: · UP. · DOWN. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ route-aggregation interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
# Display the default global link-aggregation load sharing modes.
<Sysname> display link-aggregation load-sharing mode
Layer 2 traffic: destination-mac address source-mac address
Layer 3 traffic: destination-ip address source-ip address
# Display the global link-aggregation load sharing mode. This example displays a user-configured setting.
Link-aggregation load-sharing mode:
destination-mac address, source-mac address
# Display the default link-aggregation load sharing modes of Layer 3 aggregation group 1.
<Sysname> display link-aggregation load-sharing mode interface route-aggregation 1
Route-Aggregation1 load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the set link-aggregation load sharing mode of Layer 3 aggregation group 1.
destination-ip address, source-ip address
Link-aggregation load-sharing offset |
Hash offset to adjust the load sharing hash results on link aggregations. By default, this field displays the default setting. If you have configured a hash offset, this field displays the configured offset value. |
Tunneled traffic load-sharing mode |
Load sharing mode for tunneled traffic on aggregate links. By default, this field displays the default setting. If you have configured a load sharing mode for tunneled traffic, this field displays the configured mode. |
Link-aggregation load-sharing mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 3 traffic. If you have configured the global link-aggregation load sharing mode, this field displays the configured mode. |
Route-Aggregation1 load-sharing mode |
Link-aggregation load sharing mode of Layer 3 aggregation group 1. By default, this field displays the global link-aggregation load sharing modes. If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode. |
Layer 3 traffic: destination-ip address, source-ip address |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on source and destination IP addresses. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, the system automatically selects a load sharing mode for Layer 3 traffic. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination IP addresses. |
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed link aggregation information about GigabitEthernet 1/0/12, which is a member port of a static Layer 3 aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/12
G -- Defaulted, H -- Expired
GigabitEthernet1/0/12:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed link aggregation information about GigabitEthernet 1/0/13, which is a member port of a dynamic Layer 3 aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/13
GigabitEthernet1/0/13:
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0. · A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive. · B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no. · D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no. · E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no. · F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no. · G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no. · H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the system LACP priority and the system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None or nothing for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
BLAGG1 S None 0 0 0 Shar
RAGG10 S None 1 0 0 NonS
BAGG20 D 0x8000,00e0-fcff-ff01 2 0 0 Shar
SCH-B1 S None 0 0 0 Shar
Table 5 Command output
Aggregate Interface Type |
Aggregate interface type: · BAGG—Layer 2. This type is not available in the current software version. · RAGG—Layer 3. · BLAGG—Blade. This type is not available in the current software version. · SCH-B—S-channel bundle. This type is not available in the current software version. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load-sharing. · NonS—Non-load-sharing. |
Actor System ID |
Local system ID, which contains the local system LACP priority and the local system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Individual Ports |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { route-aggregation } [ interface-number ] ] [ all-configuration ]
interface-number: Specifies an existing aggregate interface by its number.
all-configuration: Specifies all member ports of the specified aggregate interfaces. If you do not specify this keyword, the command displays only the aggregation member ports on the present cards.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
The route-aggregation keyword is available only when Layer 3 aggregate interfaces exist on the device.
# Display detailed information about Layer 3 aggregation group 1, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 1
Port: A -- Auto
Role: P -- Primary, S -- Secondary
Aggregation Mode: Dynamic
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/12 S 32768 1 1 {ACDEF}
GE1/0/13 S 32768 2 1 {ACDEF}
GE1/0/14 S 32768 3 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/12 32768 1 1 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/13 32768 2 1 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/14 32768 3 1 0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 3 aggregation group 1, which is a static aggregation group.
Port: A -- Auto
Aggregation Mode: Static
Port Status Priority Oper-Key Role
GE1/0/12 S 32768 1 None
GE1/0/13 S 32768 1 None
GE1/0/14 S 32768 1 None
Table 6 Command output
Loadsharing Type |
Port Status |
Port state: · Selected. · Unselected. · Individual. |
Port |
Port type. Letter A indicates that the port was assigned to the aggregation group by the automatic link aggregation feature or the automatic member port assignment feature. |
Flags |
Name of the aggregate interface. |
Aggregation Mode |
System ID |
Local system ID, containing the local system LACP priority and the local system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Index—Port index. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Index and Flag field are not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. · Priority—Priority of the peer port. · Index—Index of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for this argument is 1 to 8.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
jumboframe enable
Use jumboframe enable to allow the jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames with a maximum length of 10240 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 10240. If you do not specify this argument, the default frame length is used.
# Enable the support for jumbo frames on Route-Aggregation 1, setting the maximum jumbo frame size to the default.
[Sysname-Route-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/12.
[Sysname] interface gigabitethernet 1/0/12
[Sysname-GigabitEthernet1/0/12] lacp mode passive
lacp period short
Use lacp period short to set the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
# Set the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] lacp period short
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero, all-F, or multicast MAC address.
To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
lacp transparent enable
Use lacp transparent enable to enable transparent LACPDU transmission on an interface.
Use undo lacp transparent enable to disable transparent LACPDU transmission on an interface.
Transparent LACPDU transmission is disabled on an interface.
To establish a dynamic aggregation between two remote CEs in an L2VPN network, use transparent LACPDU transmission on the PEs to which the CEs are attached.
On the PEs, enable transparent LACPDU transmission on the interfaces that transmit traffic between CEs and PEs and between PEs.
Do not use an interface for dynamic link aggregation if you enable transparent LACPDU transmission on that interface. With transparent LACPDU transmission enabled, an interface cannot be selected for aggregation.
# Enable transparent LACPDU transmission on GigabitEthernet 1/0/12.
<Sysname> system
[Sysname-GigabitEthernet1/0/12] lacp transparent enable
Use link-aggregation bfd to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ipv4-address destination ipv4-address
BFD is disabled for an aggregation group.
ipv4: Specifies IPv4 BFD.
source: Specifies the source IP address of BFD sessions.
destination: Specifies the destination IP address of BFD sessions.
ipv4-address: Specifies an IPv4 address. The address cannot be 0.0.0.0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If you configure BFD multiple times for an aggregate interface, the most recent configuration takes effect.
# Enable IPv4 BFD for Layer 3 aggregation group 1, and specify the source and destination IPv4 addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation bfd-compatible enable to enable BFD compatible mode on an aggregate interface.
Use undo link-aggregation bfd-compatible enable to disable BFD compatible mode on an aggregate interface.
BFD compatible mode is disabled on aggregate interfaces.
BFD compatible mode enables BFD to operate correctly on an aggregate link whose remote end is a third-party device that implements BFD differently from the device.
With BFD compatible mode enabled, all member ports in an aggregation group establish BFD sessions with their peer ports. The BFD sessions are not deleted or re-established when the aggregation states of the member ports change.
# Enable BFD compatible mode on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
The device selects a load sharing mode for packets depending on their packet type.
destination-ip: Load shares traffic based on destination IP addresses.
destination-mac: Load shares traffic based on destination MAC addresses.
destination-port: Load shares traffic based on destination ports.
ingress-port: Load shares traffic based on ingress ports.
source-ip: Load shares traffic based on source IP addresses.
source-mac: Load shares traffic based on source MAC addresses.
source-port: Load shares traffic based on source ports.
If an unsupported load sharing mode is set, an error prompt appears.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
· The port is shut down by using the shutdown command.
· The slot that hosts the port reboots, but the aggregation group contains Selected ports on other slots.
NOTE: The device does not redirect traffic to member ports that become Selected during the traffic redirection process. |
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
link-aggregation mode
Use link-aggregation mode to set the aggregation mode of an aggregation group.
Use undo link-aggregation mode to restore the default.
link-aggregation mode { dynamic | static [ backup ] }
An aggregation group operates in static aggregation mode.
dynamic: Specifies dynamic mode and enables LACP.
static: Specifies static mode.
backup: Specifies static 1+1 backup mode. If you do not specify this keyword, 1+1 backup is not enabled. Only Layer 3 aggregate interfaces support this keyword.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
link-aggregation primary-port
Use link-aggregation primary-port to assign the primary role to a member port in a 1+1 backup aggregation group.
Use undo link-aggregation primary-port to restore the default.
A member port is not assigned the primary role in a 1+1 backup aggregation group.
In a 1+1 backup aggregation group, the primary member port is placed in Selected state to forward all traffic, and the secondary member port is placed in Unselected state as a standby. You can specify a primary member port with this command or let the system to select a primary member port. If you specify a primary member port for a 1+1 backup aggregation group, the aggregation group can revert to the primary member port when that port recovers from failure. As a best practice, use this command to manually specify a primary member port.
If you do not specify a primary member port for an aggregation group, the system acts as follows:
· Assigns the primary role to the reference port If the member ports join the aggregation group simultaneously.
· Assigns the primary role to the member port that first becomes Selected if the member ports join the aggregation group successively.
This command is not available on a port that is not an aggregation group member or is in an aggregation group not operating in 1+1 backup mode.
A 1+1 backup aggregation group can have only one primary member port.
# Assign the primary role to GigabitEthernet 1/0/12.
[Sysname-GigabitEthernet1/0/12] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/12] link-aggregation primary-port
Use link-aggregation reversion delay to set the reversion delay for a 1+1 backup aggregation group.
Use undo link-aggregation reversion delay to restore the default.
link-aggregation reversion delay time-value
A 1+1 backup aggregation group reverts to the primary member port immediately after that port recovers from failure.
time-value: Sets a reversion delay in the range of 1 to 65535 seconds.
The reversion delay is the time a 1+1 backup aggregation group must wait before reverting to the primary member port after that port recovers from failure. This timer prevents link flapping from causing frequent primary/secondary member port switchovers.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode and manually specify its primary member port.
# Set the reversion delay to 5 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation reversion delay 5
Use link-aggregation secondary-down to configure a 1+1 backup aggregation group to place its secondary member port in down state.
Use undo link-aggregation secondary-down to restore the default.
In a 1+1 backup aggregation group, the secondary member port is in Unselected state.
If the peer for a 1+1 backup aggregation group is unaware of the member port roles, it might send traffic to the secondary member port, and traffic loss occurs consequently. To prevent traffic loss, configure the aggregation group to place its secondary member port in down state. This allows the peer and local ends to use only up ports to transmit traffic.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode.
# Configure Route-Aggregation 1 to place its secondary member port in down state.
[Sysname-Route-Aggregation1] link-aggregation secondary-down
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 8.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
For a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
For a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 8.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
Use link-aggregation selected-port minimum percentage to set the minimum percentage of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum percentage to restore the default.
link-aggregation selected-port minimum percentage number
The minimum percentage of Selected ports is not set for an aggregation group.
number: Specifies the minimum percentage of Selected ports. The value range for this argument is 1 to 100.
CAUTION: After you execute this command, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
· The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
· The limit set by using the link-aggregation selected-port minimum command.
The system calculates the minimum percentage of Selected ports based on the total number of member ports in an aggregation group, including the member ports on an absent card. To view the total number of member ports in an aggregation group, execute the display link-aggregation verbose all-configuration command.
For the device to calculate the minimum number of Selected ports correctly, save the running configuration and reboot the device after you execute the link-aggregation selected-port minimum percentage command.
# Set the minimum percentage of Selected ports to 50% for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-aggregation switchover
Use link-aggregation switchover to perform a primary/secondary member port switchover in a 1+1 backup aggregation group.
CAUTION: This command might cause traffic loss. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
Use this command to switch member port roles for a 1+1 backup aggregation group whose primary member port is set by the system when the state of peer ports changes.
If the link-aggregation secondary-down command has been executed for the aggregation group, the link-aggregation switchover command brings up the down secondary member port for it to take over the primary role.
Before you execute the link-aggregation switchover command for a 1+1 backup aggregation group, verify that the following requirements are met:
· The aggregation group contains one Selected port and one Unselected port.
· The primary member port is set by the system.
· The secondary member port can become Selected.
# Perform a primary/secondary member port switchover in the aggregation group of Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation switchover
This operation will change the current link status. Continue? [Y/N]:
link-delay
Use link-delay to set the physical state change suppression interval on an aggregate interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of an aggregate interface goes up or comes down, the system immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Sets the physical state change suppression interval in milliseconds. If you do not specify this keyword, the suppression interval is in seconds.
delay-time: Sets the physical state change suppression interval. To report a physical state change immediately to the CPU, set the interval to 0.
· If you do not specify the msec keyword, the value range is 0 to 600 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 10.
You can configure this feature to suppress link-down events, link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times for an event type, the most recent configuration takes effect on that event type.
When you configure suppression interval settings on an aggregate interface, make sure its peer interface is also an aggregate interface in the same aggregation mode. In addition, the suppression interval settings must be the same between the peer aggregate interfaces.
As a best practice, use the default setting in an S-MLAG environment.
# Set the link-down event suppression interval to 500 milliseconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-delay down msec 500
mtu
Use mtu to set the MTU for a Layer 3 aggregate interface or subinterface.
mtu size [ spread ]
undo mtu [ spread ]
The MTU for Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies the MTU in bytes, in the range of 46 to 9600.
spread: Issues the MTU of the interface to all its subinterfaces. This keyword is available only in Layer 3 aggregate interface view.
When you set the MTU of a Layer 3 aggregate interface, you can specify the spread keyword to issue the MTU setting to all its subinterfaces. If you do not specify the spread keyword, the MTU setting takes effect only on the Layer 3 aggregate interface.
On an aggregate subinterface, the MTU set in subinterface view takes precedence over the MTU inherited from the aggregate interface.
# Set the MTU to 1430 bytes for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mtu 1430
display interface
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to an aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for this argument is 1 to 8.
An Ethernet interface can belong to only one aggregation group.
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/13 to Layer 3 aggregation group 2.
[Sysname] interface gigabitethernet 1/0/13
[Sysname-GigabitEthernet1/0/13] port link-aggregation group 2
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ route-aggregation [ interface-number ] ]
interface-number: Specifies an aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics for all interfaces.
If you specify only an aggregate interface type, the command clears statistics for all aggregate interfaces of the specified type.
# Clear statistics for Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> reset counters interface route-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-type interface-number1 argument must be equal to or greater than the value for the interface-type interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface.
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
An interface is not manually shut down.
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] undo shutdown
