| 04-HQoS commands | 148.54 KB |
forwarding-group (forwarding group match criterion view)
display qos forwarding-profile
display qos scheduler-policy diagnosis interface
display qos scheduler-policy interface
forwarding-group profile (scheduler-policy match criterion view)
HQoS commands
Forwarding class commands
display qos forwarding-class
Use display qos forwarding-class to display forwarding classes.
display qos forwarding-class [ name fc-name ]
name fc-name: Specifies a forwarding class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding class, the command displays all forwarding classes.
# Display forwarding class BE.
<Sysname> display qos forwarding-class name BE
Forwarding class: BE, ID: 0
# Display all forwarding classes.
Forwarding class: L2, ID: 1
Forwarding class: AF, ID: 2
Forwarding class: L1, ID: 3
Forwarding class: H2, ID: 4
Forwarding class: EF, ID: 5
Forwarding class: H1, ID: 6
Forwarding group commands
display qos forwarding-group
Use display qos forwarding-group to display forwarding groups.
display qos forwarding-group [ name fg-name ]
name fg-name: Specifies a forwarding group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding group, the command displays all forwarding groups.
# Display forwarding group testfg1, which has child forwarding groups.
<Sysname> display qos forwarding-group name testfg1
Forwarding group: testfg1, ID: 10
match service-vlan-id 1
Forwarding group: subfg1, ID: 1, profile: fgprofile1
match service-vlan-id 11
Forwarding group: subfg2, ID: 2, profile: fgprofile2
# Display forwarding group testfg2, which has nested forwarding classes.
<Sysname> display qos forwarding-group name testfg2
Forwarding group: testfg2, ID: 10
Forwarding class: BE, ID: 0, profile: fcprofile1
Forwarding class: AF, ID: 1, profile: fcprofile2
Forwarding class: EF, ID: 2, profile: fcprofile3
Forwarding class: NC, ID: 3, profile: fcprofile4
forwarding-class
Use forwarding-class to nest a forwarding class in a forwarding group and specify a forwarding profile for the forwarding class.
Use undo forwarding-class to remove a nested forwarding class from a forwarding group.
forwarding-class fc-name profile fp-name
undo forwarding-class fc-name
A user-defined forwarding group does not have nested forwarding classes.
Forwarding group view
fc-name: Specifies a forwarding class by its name. Only these predefined forwarding classes can be specified: BE, L2, AF, L1, H2, EF, H1, and NC.
profile fp-name: Specifies a forwarding profile by its name, a case-sensitive string of 1 to 31 characters.
You cannot modify or remove the predefined forwarding classes nested in the predefined forwarding group.
The forwarding profile to be associated must already exist.
You cannot nest a forwarding class in a forwarding group with child forwarding groups nested.
# Nest forwarding class BE in forwarding group testfg and specify forwarding profile testfp for this forwarding class.
[Sysname] qos forwarding-group testfg
[Sysname-hqos-fg-testfg] forwarding-class BE profile testfp
Use forwarding-group to perform the following tasks:
· Nest a forwarding group (child) in a match criterion of another forwarding group (parent).
· Specify a forwarding profile for the child forwarding group.
Use undo forwarding-group to remove the nested forwarding group.
forwarding-group sub-fg-name profile fp-name
undo forwarding-group sub-fg-name
A user-defined forwarding group does not have child forwarding groups.
Forwarding group match criterion view
sub-fg-name: Specifies a child forwarding group by its name, a case-sensitive string of 1 to 31 characters.
The child forwarding group and the forwarding profile to be specified must already exist.
You cannot nest a forwarding group in a forwarding group with forwarding classes nested.
A forwarding group with forwarding groups nested cannot be nested in another forwarding group.
# Configure the match criterion VLAN ID 2 for forwarding group testfg. Nest forwarding group subfg in forwarding group testfg, and specify forwarding profile testfp for forwarding group subfg.
[Sysname-hqos-fg-testfg] match service-vlan-id 2
[Sysname-hqos-fg-testfg-match] forwarding-group subfg profile testfp
match
Use match to configure a match criterion for a parent forwarding group and enter forwarding group match criterion view, or enter the view of an existing match criterion.
Use undo match to delete the configured match criterion.
match match-criteria
undo match match-criteria
No match criteria exist.
match-criteria: Specifies a match criterion. Table 1 shows the available match criteria.
Table 1 Available match criteria
Option |
local-precedence precedence-value |
Matches the local precedence. The precedence-value argument specifies a local precedence value in the range of 0 to 7. |
service-vlan-id vlan-id [ customer-vlan-id vlan-id ] |
Matches the service provider VLAN ID (SVLANs) and customer VLAN ID (CVLAN). The vlan-id argument specifies a VLAN ID in the range of 1 to 4094. |
Executing the match command only leads you to the forwarding group match criterion view. The configured match criterion takes effect only after a child forwarding group is configured in that view.
You cannot configure the group mode for a forwarding group with forwarding classes nested.
Removing a match criterion also removes the child forwarding group and its associated forwarding profile.
# Configure the match criterion service VLAN ID 2 and enter forwarding group match criterion view.
Use qos forwarding-group to create a user-defined forwarding group and enter its view, or enter the view of an existing forwarding group.
Use undo qos forwarding-group to delete a user-defined forwarding group.
qos forwarding-group fg-name
undo qos forwarding-group fg-name
No user-defined forwarding groups exist.
fg-name: Specifies a forwarding group name, a case-sensitive string of 1 to 31 characters. This argument cannot be the name of the predefined forwarding group (default).
You cannot modify or delete the predefined forwarding group default (numbered 0).
The system supports a maximum number of 8191 user-defined forwarding groups.
To delete a forwarding group nested in another forwarding group or a scheduler policy, first remove the nesting.
# Create a forwarding group named testfg.
Forwarding profile commands
Use display qos forwarding-profile to display forwarding profiles.
display qos forwarding-profile [ name fp-name ]
name fp-name: Specifies a forwarding profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a forwarding profile, the command displays all forwarding profiles.
# Display forwarding profile testfp.
<Sysname> display qos forwarding-profile name testfp
Forwarding profile: testfp, ID: 10
GTS: CIR 100(kbps)
WRR: weight 1
Drop profile |
Drop profile name. |
gts
Use gts to configure GTS parameters for a forwarding profile.
Use undo gts to restore the default.
gts cir cir-value
undo gts
No GTS configuration exists in a forwarding profile.
Forwarding profile view
cir-value: Specifies the CIR in kbps. The value range for cir-value is 8 to 10000000, in increments of 8.
# Configure GTS parameters for forwarding profile testfp.
[Sysname] qos forwarding-profile testfp
[Sysname-hqos-fp-testfp] gts cir 800
Use qos forwarding-profile to create a user-defined forwarding profile and enter its view, or enter the view of an existing forwarding profile.
Use undo qos forwarding-profile to delete a user-defined forwarding profile.
qos forwarding-profile fp-name
undo qos forwarding-profile fp-name
No user-defined forwarding profiles exist.
fp-name: Specifies a forwarding profile name, a case-sensitive string of 1 to 31 characters. This argument cannot be the name of the predefined forwarding profile (default).
You cannot modify or delete the predefined forwarding profile default.
# Create a forwarding profile named testfp.
sp
Use sp to enable SP queuing for a forwarding profile.
Use undo sp to restore the default.
sp
undo sp
No SP queuing configuration exists in a forwarding profile.
# Enable SP queuing for forwarding profile testfp.
[Sysname-hqos-fp-testfp] sp
wrr
Use wrr to configure WRR queuing for a forwarding profile.
Use undo wrr to restore the default.
wrr [ weight weight-value ]
undo wrr
No WRR queuing configuration exists in a forwarding profile.
weight weight-value: Specifies the scheduling weight in the range of 1 to 15. The default is 1.
The weight of a WRR queue determines the percentage of bandwidth assigned to the queue.
# Configure WRR queuing for forwarding profile testfp.
[Sysname-hqos-fp-testfp] wrr weight 2
Scheduler policy commands
Use display qos scheduler-policy to display scheduler policies.
display qos scheduler-policy [ name sp-name ]
name sp-name: Specifies a scheduler policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a scheduler policy, the command displays all scheduler policies.
# Display scheduler policy test_sp.
<Sysname> display qos scheduler-policy name test_sp
SP -- Scheduler policy FG -- Forwarding group FC -- Forwarding class
FP -- Forwarding profile L -- Layer
SP: test_sp(1)
| Scheduler unit: byte-count
| | Match: service-vlan-id 2
| +--FG(L2): Customer1(2)
| | | FP: Customer1(1)
| | +--FC: BE(0)
| | | FP: BE(3)
| | +--FC: AF(1)
| | | FP: default(0)
| | +--FC: EF(2)
| | | FP: default(0)
| | +--FC: NC(3)
| | FP: default(0)
| | Match: service-vlan-id 11
| +--FG(L2): Customer2(5)
| | FP: Customer2(2)
| +--FC: BE(0)
| | FP: BE(3)
| +--FC: AF(1)
| | FP: default(0)
| +--FC: EF(2)
| | FP: default(0)
| +--FC: NC(3)
| FP: default(0)
| Match: service-vlan-id 21
+--FG(L2): Customer3(6)
| FP: Customer3(6)
+--FC: BE(0)
| FP: BE(3)
+--FC: AF(1)
| FP: default(0)
+--FC: EF(2)
| FP: default(0)
+--FC: NC(3)
FP: default(0)
match |
The match mode is used for configuring match criteria. |
Number in the brackets |
ID of the field (forwarding class/forwarding group/forwarding profile/scheduler policy). |
Use display qos scheduler-policy diagnosis interface to display diagnosis information about scheduler policies applied to subinterfaces.
display qos scheduler-policy diagnosis interface [ interface-type interface-number.subnumber ] outbound
interface-type interface-number.subnumber: Specifies a subinterface by its type and number.
outbound: Specifies scheduler policies applied to the outbound direction.
If you do not specify a subinterface, the command displays diagnosis information about all applied scheduler policies.
# Display diagnosis information about the scheduler policy applied to the outbound direction of Gigabitethernet 1/0/12.1.
<Sysname> display qos scheduler-policy diagnosis interface gigabitethernet 1/0/12.1 outbound
Interface: Gigabitethernet1/0/12.1
Direction: Outbound
SP: test_sp(1)
| | | FP: Customer1(1)
| | | Status: Success
| | +--FC: BE(0)
| | | FP: BE(3)
| | | Status: Queue Failed
| | +--FC: AF(1)
| | | FP: default(0)
| | | Status: GTS Failed
| | +--FC: EF(2)
| | | FP: default(0)
| | | Status: Success
| | +--FC: NC(3)
| | FP: default(0)
| | Status: Success
| | FP: Customer2(2)
| | Status: Incomplete
| +--FC: BE(0)
| | FP: BE(3)
| | Status: Incomplete
| +--FC: AF(1)
| | FP: default(0)
| | Status: Incomplete
| +--FC: NC(3)
| FP: default(0)
| Status: Incomplete
| FP: Customer3(6)
| Status: Insufficient resources
+--FC: BE(0)
| FP: BE(3)
+--FC: AF(1)
| FP: default(0)
+--FC: EF(2)
| FP: default(0)
+--FC: NC(3)
FP: default(0)
Forwarding profile |
Forwarding profile name. |
Status |
Issuing status of a forwarding profile: · Incomplete—Incomplete match criteria. · Success—All contents have been issued successfully. · Inactive—A forwarding profile does not take effect. · If a forwarding profile has failed to be issued completely, the following possible reasons are displayed: ¡ Insufficient resources. ¡ Conflicting match rule. ¡ Not support. ¡ GTS Failed—The GTS parameters failed to be issued to a forwarding class or forwarding group. |
Use display qos scheduler-policy interface to display the statistics and configuration for scheduler policies applied to subinterfaces.
display qos scheduler-policy interface [ interface-type interface-number.subnumber ] outbound
If you do not specify a subinterface, the command displays the statistics and configuration for all applied scheduler policies.
# Display the configuration and statistics for the scheduler policy applied to the outbound direction of Gigabitethernet 1/0/12.1.
<Sysname> display qos scheduler-policy interface gigabitethernet 1/0/12.1 outbound
Direction: Outbound
SP: test_sp(1)
| | | FP: Customer1(1)
| | +--FC: BE(0)
| | | FP: BE(3)
| | +--FC: AF(1)
| | | FP: default(0)
| | +--FC: EF(2)
| | | FP: default(0)
| | +--FC: NC(3)
| | FP: default(0)
| | FP: Customer2(2)
| +--FC: BE(0)
| | FP: BE(3)
| +--FC: AF(1)
| | FP: default(0)
| +--FC: NC(3)
| FP: default(0)
| FP: Customer3(6)
+--FC: BE(0)
| FP: BE(3)
+--FC: AF(1)
| FP: default(0)
+--FC: EF(2)
| FP: default(0)
+--FC: NC(3)
FP: default(0)
Table 5 Command output
Use forwarding-group profile to nest a forwarding group in a match criterion of a scheduler policy and specify a forwarding profile for the forwarding group.
Use undo forwarding-group to remove the nested forwarding group from a match criterion of a scheduler policy.
forwarding-group fg-name profile fp-name
undo forwarding-group fg-name
The predefined forwarding group is nested in a scheduler policy in group mode.
Scheduler policy match criterion view
The forwarding group to be nested in a scheduler policy and the forwarding profile to be specified for the forwarding group must already exist.
You cannot remove the predefined forwarding group automatically nested in a scheduler policy.
# Configure the match criterion VLAN ID 1 for scheduler policy testsp. Nest forwarding group testfg in scheduler policy testsp, and specify the forwarding profile testfp for forwarding group testfg.
[Sysname] qos scheduler-policy testsp
[Sysname-hqos-sp-testsp] match service-vlan-id 1
[Sysname-hqos-sp-testsp-match] forwarding-group testfg profile testfp
match
match
Use match to configure a match criterion for a scheduler policy and enter its view, or enter the view of an existing scheduler policy match criterion.
Use undo match to delete the configured match criteria.
A user-defined scheduler policy has no match criteria.
Scheduler policy view
match-criteria: Specifies a match criterion. Table 6 shows the available match criteria.
Table 6 Available match criteria
Option |
Matches the outer VLAN ID (SVLAN) and inner VLAN ID (CVLAN). The vlan-id argument specifies a VLAN ID in the range of 1 to 4094. |
Executing the match command only leads you to the scheduler policy match criterion view. The configured match criterion takes effect only after a child forwarding group is configured in that view.
Removing a match criterion for a scheduler policy also removes the nested forwarding groups and their associated forwarding profiles for the scheduler policy.
qos apply scheduler-policy
Use qos apply scheduler-policy to apply a scheduler policy to a subinterface.
Use undo qos apply scheduler-policy to remove a scheduler policy from a subinterface.
qos apply scheduler-policy sp-name outbound
undo qos apply scheduler-policy sp-name outbound
No scheduler policy is applied to a subinterface.
Subinterface view
outbound: Applies a scheduler policy to the outbound direction of an interface.
# Apply scheduler policy testsp to the outbound direction of GigabitEthernet 1/0/12.1.
[Sysname] interface gigabitethernet 1/0/12.1
[Sysname-GigabitEthernet1/0/12.1] qos apply scheduler-policy testsp outbound
Use qos scheduler-policy to create a user-defined scheduler policy and enter its view, or enter the view of an existing scheduler policy.
Use undo qos scheduler-policy to delete a user-defined scheduler policy.
qos scheduler-policy sp-name
undo qos scheduler-policy sp-name
No user-defined scheduler policies exist.
sp-name: Specifies a scheduler policy name, a case-sensitive string of 1 to 31 characters.
The system supports a maximum number of 256 user-defined scheduler policies.
# Create a scheduler policy named testsp.
scheduler-unit
Use scheduler-unit to specify the scheduling unit for a scheduler policy.
Use undo scheduler-unit to restore the default.
scheduler-unit byte-count
undo scheduler-unit
The scheduling unit for a scheduler policy is byte-count.
byte-count: Allocates bandwidth based on the number of bytes.
# Set the scheduling unit to byte-count for scheduler policy named testsp.
[Sysname-hqos-sp-testsp] scheduler-unit byte-count
