| 01-CFD commands | 266.04 KB |
CFD commands
cfd cc enable
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
The CCM sending feature is enabled.
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
# On GigabitEthernet 1/0/12, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface gigabitethernet 1/0/12
[Sysname-GigabitEthernet1/0/12] cfd cc service-instance 5 mep 3 enable
# On GigabitEthernet 1/0/12.1, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface gigabitethernet 1/0/12.1
[Sysname-GigabitEthernet1/0/12.1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to remove the value of the interval field in the CCM messages.
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval [ interval-value ] service-instance instance-id
The value of this field is 4 for all CCMs sent.
interval interval-value: Specifies the value of the interval field in CCM messages. The value range for the interval field is 1 to 7.
When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field |
Transmission interval |
Maximum CCM lifetime |
1 |
10/3 milliseconds |
35/3 milliseconds |
2 |
10 milliseconds |
35 milliseconds |
3 |
100 milliseconds |
350 milliseconds |
4 |
1 second |
3.5 seconds |
5 |
10 seconds |
35 seconds |
6 |
60 seconds |
210 seconds |
7 |
600 seconds |
2100 seconds |
# Set the value of the interval field to 3 in CCMs sent by MEPs in service instance 2.
[Sysname] cfd cc interval 3 service-instance 2
cfd cc enable
cfd dlm continual
Use cfd dlm continual to configure continual two-way loss measurement (LM).
Use undo cfd dlm continual to disable continual two-way LM.
cfd dlm continual service-instance instance-id mep mep-id target-mep target-mep-id [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ]
Continual two-way LM is disabled.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
mep mep-id: Specifies the source MEP by its ID in the range of 1 to 8191.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
peer ip-address: Specifies a remote PE device by its LSR ID. This option is required only if the target MEP resides on a remote PE device in a VPLS network.
pw-id pw-id: Specifies a PW by its ID in the range of 1 to 4294967295.
dot1p dot1p-value: Specifies an 802.1p priority for CCM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
The two-way LM function measures the frame loss between the source and target MEPs by using CCMs. The source MEP calculates the number of lost frames according to the counter values of two consecutive CCMs received (the current CCM and the previous CCM).
For the two-way LM function to take effect, you must configure it on both the local and peer devices.
If the frame counting mode is dot1p-based, you must specify the dot1p dot1p-value option. If the frame counting mode is port-based, do not specify the dot1p dot1p-value option.
To modify two-way LM settings for a source MEP, disable two-way LM and then reconfigure the function for the source MEP.
The two-way LM detection interval is the CCM interval. Before configuring two-way LM, configure the CCM interval field value to be greater than 2.
One-way LM and two-way LM cannot be configured at the same time for one source MEP. If you have configured short-period one-way LM or continual one-way LM, you can configure two-way LM only after you disable continual one-way LM or short-period one-way LM ends. If you have configured two-way LM, you can configure short-period one-way LM or continual one-way LM only after disable two-way LM.
To display the two-way LM result, use the display cfd dlm history command on the device where the source MEP or target MEP resides.
# Enable the continual two-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dlm continual service-instance 1 mep 1101 target-mep 2001
cfd cc interval
cfd slm
cfd slm continual
cfd dm two-way
Use cfd dm two-way to enable short-period two-way DM.
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ number number ] [ interval interval ]
target-mac mac-address: Specifies a target MEP by its bridge MAC address or specify a group of target MEPs by a multicast MAC address, which is in the format of H-H-H.
dot1p dot1p-value: Specifies an 802.1p priority for DMMs. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of DMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the DMM frame sending interval, in seconds. The value takes 1, 10, 60, or 600. The default value is 1.
The short-period two-way DM function measures the two-way frame delay between the source and target MEPs by using DMM frames and DMR frames.
To view the bridge MAC address of the target MEP, execute the display lacp system-id command on the target MEP.
Short-period two-way DM and continual two-way DM cannot be configured at the same time for one source MEP. If you have configured continual two-way DM, you can configure short-period two-way DM only after you disable continual two-way DM. If you have configured short-period two-way DM, you can configure continual two-way DM only after the short-period two-way DM ends.
# Enable the short-period two-way DM function to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd dm two-way service-instance 1 mep 1101 target-mep 2001
Frame delay:
Reply from 0010-fc00-6512: 10us
Reply from 0010-fc00-6512: 9us
Reply from 0010-fc00-6512: 11us
Reply from 0010-fc00-6512: 5us
Average: 8us
Frame delay variation: 1us 2us 6us 0us
Average: 2us
Packet statistics:
Sent DMMs: 5 Received: 5 Lost: 0
Reply from 0010-fc00-6512 |
Delay of the DMR frames returned from the MEP with MAC address 0010-FC00-6512. |
Average |
Average frame delay or average frame delay variation. |
Sent DMMs |
Number of sent DMM frames . |
Received |
Number of received DMR frames. |
Lost |
Number of lost DMM frames. |
cfd dm two-way continual
Use cfd dm two-way continual to enable continual two-way DM.
Use undo cfd dm two-way continual to disable continual two-way DM.
cfd dm two-way continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ interval interval ]
undo cfd dm two-way continual service-instance instance-id mep mep-id
Continual two-way DM is disabled.
dot1p dot1p-value: Specifies an 802.1p priority for DMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
Continual two-way DM continually sends DMM frames at a configurable interval. It measures the two-way frame delay between the source and target MEPs after receiving the returned DMR frames.
If the device supports hardware CC, you can only specify the target MEP by its MAC address. You cannot specify the target MEP by its ID.
To modify continual two-way DM settings for a source MEP, disable continual two-way DM and then reconfigure the function for the source MEP.
To display the continual two-way DM result, use the display cfd dm two-way history command on the device where the source MEP resides.
# Enable the continual two-way DM function to test the two-way frame delay between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd dm two-way continual service-instance 1 mep 1101 target-mep 2001
cfd dm two-way
cfd enable
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
cfd enable
undo cfd enable
CFD is disabled.
[Sysname] cfd enable
cfd frame-count mode
Use cfd frame-count mode to configure the frame counting mode for LM.
Use undo frame-count mode to restore the default.
cfd frame-count mode { dot1p-based | port-based }
undo cfd frame-count mode
No frame counting mode is configured for LM.
dot1p-based: Counts packets by 802.1p priority.
port-based: Counts packets by interface.
To obtain accurate test results, configure the same frame counting mode on the source MEP and target MEP.
If the frame counting mode is dot1p-based, you must specify the dot1p dot1p-value option when configuring the cfd slm, cfd slm continual, and cfd dlm continual commands. If the frame counting mode is port-based, do not specify the dot1p dot1p-value option when configuring the cfd slm, cfd slm continual, and cfd dlm continual commands.
If LM has been configured for a MEP, the frame counting mode on the interface where the MEP resides cannot be modified.
# Configure the frame counting mode for LM as dot1p-based on GigabitEthernet 1/0/12.1.
[Sysname-GigabitEthernet1/0/12.1] cfd frame-count mode dot1p-based
cfd dlm continual
cfd slm
cfd slm continual
cfd hardware-cc
Use cfd hardware-cc to enable hardware CC.
Use undo cfd hardware-cc to disable hardware CC.
cfd hardware-cc service-instance instance-id remote-mep mep-list
undo cfd hardware-cc service-instance instance-id remote-mep mep-list
Hardware CC is disabled.
remote-mep mep-list: Specifies remote MEPs. The mep-list argument specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id [ to mep-id ]. The value range for MEP IDs is 1 to 8191.
Do not modify the value of the interval field in CCM messages after hardware CC is enabled. If you modify the value of the interval field in CCM messages, hardware CC is automatically disabled.
# Enable hardware CC on GigabitEthernet 1/0/12 to detect remote MEP 5 in service instance 1.
[Sysname-GigabitEthernet1/0/12] cfd hardware-cc service-instance 1 remote-mep 5
# Enable hardware CC on GigabitEthernet 1/0/12.1 to detect remote MEP 5 in service instance 1.
[Sysname-GigabitEthernet1/0/12.1] cfd hardware-cc service-instance 1 remote-mep 5
cfd cc interval
cfd linktrace
Use cfd linktrace to identify the path between the source MEP and target MP.
cfd linktrace service-instance instance-id mep mep-id target-mac mac-address [ ttl ttl-value ] [ hw-only ]
target-mac mac-address: Specifies the target MEP by its bridge MAC address, in the format of H-H-H.
ttl ttl-value: Specifies the TTL value in the range of 1 to 255. The default value is 64.
hw-only: Sets the hw-only bits of the LTMs sent. If you specify this keyword, the source MEP does not flood LTM messages that have an unknown destination MAC address.
This command identifies the path between the source MEP and target MP by using LTMs and LTRs.
# Identify the path between source MEP 1101 and target MEP with MAC address 0010-fc00-6512 in service instance 1.
<Sysname> cfd linktrace service-instance 1 mep 1101 target-mac 0010-fc00-6512
Linktrace to 0010-fc00-6512 with the sequence number 1101-43361:
MAC address TTL Last MAC Relay action
0010-fc00-6512 63 0010-fc00-6500 Hit
Linktrace to 0010-fc00-6512 with the sequence number 1101-43361 |
Linktrace to target MEP with MAC address 0010-fc00-6512 with the sequence number 1101-43361. |
MAC address |
Source MAC address in the LTR messages. |
TTL |
TTL of the LTM when it passes the device. |
Last MAC |
MAC address of the last-hop device the LTM passes. |
Relay action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—The current device is the destination device. · FDB—The forwarding device found the destination MAC address. · MPDB—The destination MAC address is not found, or the destination MAC address is found in the MEP database. |
display cfd linktrace-reply
cfd loopback
Use cfd loopback to enable loopback (LB).
cfd loopback service-instance instance-id mep mep-id target-mac mac-address [ number number ]
number number: Specifies the number of the sent LBMs packets. The value is in the range of 1 to 10. The default value is 5.
The LB function verifies link connectivity between the source MEP and the target MP by using LBMs and LBRs.
# Enable LB for the link between MEP 1101 and MEP with MAC address 0010-fc00-6512 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mac 0010-fc00-6512
Loopback to 0010-fc00-6512 with the sequence number start from 1101-43404:
Reply from 0010-fc00-6512: sequence number=1101-43404 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43405 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43406 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43407 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43408 Time=5ms
Sent: 5 Received: 5 Lost: 0
# Enable LB for the link between MEP 1101 and MEP with MAC address 0010-fc00-6512 in service instance 1 (assume that the link status is abnormal).
Sent: 5 Received: 0 Lost: 5
Loopback to 0010-fc00-6512 with the sequence number start from 1101-43404 |
Sends LBMs to remote MEP with MAC address 0010-fc00-6512 with the sequence number starting with 1101-43404. |
Reply from the MP with the MAC address 0010-FC00-6512. |
sequence number |
Sequence number in the LBR messages. |
Time=5ms |
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds. |
Sent |
Number of sent LBMs. |
Received |
Number of received LBRs. |
Lost |
Number of lost LBRs. |
cfd md
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
cfd md md-name [ index index-value ] level level-value [ md-id { dns dns-name | mac mac-address subnumber | none } ]
undo cfd md md-name
No MDs exist.
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
index index-value: Specifies an MD index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
level level-value: Specifies an MD level in the range of 0 to 7.
md-id: Specifies the MD name carried by packets sent by the MEP. If you do not provide this keyword, the MD name is represented by md-name.
dns dns-name: Specifies an MD name in the format of DNS name, where dns-name represents the DNS name.
mac mac-address subnumber: Specifies an MD name containing the MAC address and an integer. The mac-address argument represents the MAC address of the MD, and the subnumber argument is in the range of 0 to 65535.
none: Specifies that no MD name is carried in the packets sent by the MEP.
An MD name must be in compliant with the specifications in IEEE802.1ag-2007.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name or the MD index is in use.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md1, with its level being 3.
[Sysname] cfd md test_md1 level 3
# Create an MD named test_md2, and the MD name carried in the packet sent by the MEP comprises the MAC address 1-1-1 and integer 1.
[Sysname] cfd md test_md2 level 5 md-id mac 1-1-1 1
cfd mep
Use cfd mep to create a MEP.
Use undo cfd mep to delete a MEP.
cfd mep mep-id service-instance instance-id inbound
undo cfd mep mep-id service-instance instance-id
No MEPs exist.
mep mep-id: Specifies the MEP ID, in the range of 1 to 8191.
inbound: Creates an inward-facing MEP.
In creating a MEP, the service instance you specified defines the MD and MA to which the MEP belongs.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
# In an MPLS Layer 2 VPN, configure a MEP list in service instance 5, and create inward-facing MEP 3 in service instance 5 on GigabitEthernet 1/0/12.1.
[Sysname] cfd md vpnmd level 4
[Sysname] cfd service-instance 5 ma-id string vpnma md vpnmd xconnect-group vpn1 connection ac2pw
[Sysname] cfd meplist 3 service-instance 5
[Sysname-GigabitEthernet1/0/12.1] cfd mep 3 service-instance 5 inbound
cfd meplist
cfd meplist
Use cfd meplist to create a MEP list.
Use undo cfd meplist to delete a MEP list.
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
No MEP list is created.
meplist mep-list: Specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id 1 to mep-id 2. The value range for the MEP ID is 1 to 8191. The mep-id 2 must be equal to or greater than mep-id 1.
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Before creating a MEP list, create the relevant MD and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
# In an MPLS Layer 2 VPN, create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd md test_md level 3
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd md
Use cfd service-instance to create a service instance.
Use undo cfd service-instance to remove a service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name } [ ma-index index-value ] md md-name { xconnect-group group-name connection connection-name | vsi vsi-name }
undo cfd service-instance instance-id
No service instances exist.
ma-id: Creates an MA.
icc-based ma-name: Specifies that an MA is identified by an ICC. The ma-name argument is a string of 1 to 13 characters. An MA name must be compliant with the specifications in IEEE802.1ag-2007
integer ma-num: Specifies that an MA is identified by an integer, where the ma-num argument is in the range of 0 to 65535.
string ma-name: Specifies that an MA is identified by a string, where the ma-name argument is string of 1 to 45 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
ma-index index-value: Specifies an MA index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark (’), comma (,), period (.), and slash (/).
xconnect-group group-name: Specifies the cross-connect group that the MA serves. The group-name argument is a case-sensitive string of 1 to 31 characters excluding hyphens (-).
connection connection-name: Specifies the cross-connect that the MA serves. The connection-name argument is a case-sensitive string of 1 to 20 characters excluding hyphens (-).
vsi vsi-name: Specifies the VSI that the MA serves. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
You must create the relevant MD before creating a service instance.
Deleting a service instance also deletes the configurations related to that service instance.
Deleting a service instance not only removes the connection between the service instance and the relevant MA, but also deletes the MA.
In an MPLS Layer 2 VPN, you must create the relevant cross-connect group and cross-connect or the relevant VSI before creating a service instance. For more information about cross-connect groups and cross-connects, see MPLS L2VPN in MPLS Configuration Guide. For more information about VSIs, see VPLS in MPLS Configuration Guide.
# Create a level-4 MD named vpnmd and create service instance 10, in which the MA is identified by vpnma and serves cross-connect ac2pw in cross-connect group vpn1.
[Sysname] cfd service-instance 10 ma-id string vpnma md vpnmd xconnect-group vpn1 connection ac2pw
cfd md
cfd slm
Use cfd slm to enable short-period one-way loss measurement.
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ number number ] [ interval { interval | msec msec-interval } ]
dot1p dot1p-value: Specifies an 802.1p priority for LMM frames. The value range for the dot1p-value argument is 0 to 7. The default value is 7.
number number: Specifies the number of LMM frames to be sent. The value range for the number argument is 2 to 10, and the default is 5.
interval interval: Specifies the LMM frame sending interval, in seconds. The value takes 1, 10, 60, or 600. The default value is 1.
msec msec-interval: Specifies the LMM frame sending interval, in milliseconds. The value takes 100, 1000, 10000, 60000, or 600000. The default value is 1000.
The short-period one-way LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
Before enabling short-period one-way LM in an MPLS Layer 2 VPN, you must configure the same frame counting mode on the source MEP and target MEP.
Short-period one-way LM and continual one-way LM cannot be configured at the same time for one source MEP. If you have configured continual one-way LM, you can configure short-period one-way LM only after you disable continual one-way LM. If you have configured short-period one-way LM, you can configure continual one-way LM only after the short-period one-way LM ends.
Short-period one-way LM and continual two-way LM cannot be configured at the same time for one source MEP. If you have configured short-period one-way LM, you can configure continual two-way LM only after the short-period one-way LM ends. If you have configured continual two-way LM, you can configure short-period one-way LM only after you disable continual two-way LM.
# Enable the short-period one-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd slm service-instance 1 mep 1101 target-mep 2001
Far-end frame loss : 10 Far-end frame loss rate : 10.00%
Near-end frame loss: 20 Near-end frame loss rate: 20.00%
Far-end frame loss : 40 Far-end frame loss rate : 40.00%
Near-end frame loss: 40 Near-end frame loss rate: 40.00%
Far-end frame loss : 0 Far-end frame loss rate : 0.00%
Near-end frame loss: 10 Near-end frame loss rate: 10.00%
Far-end frame loss : 30 Far-end frame loss rate : 30.00%
Near-end frame loss: 30 Near-end frame loss rate: 30.00%
Far-end frame loss : 20 Far-end frame loss rate : 20.00%
Near-end frame loss: 25 Near-end frame loss rate: 25.00%
Average
Packet statistics:
Sent LMMs: 5 Received: 5
Table 5 Command output
LMR frames returned from the target MEP with MAC address 0010-FC00-6512. |
Far-end frame loss |
Number of lost frames on the target MEP. |
Near-end frame loss |
Number of lost frames on the source MEP. |
Far-end frame loss rate |
Frame loss ratio on the target MEP. |
Near-end frame loss rate |
Frame loss ratio on the source MEP. |
Average |
Average number of lost frames. |
Sent LMMs |
Number of sent LMM frames. |
Received |
Number of received LMR frames. |
cfd dlm continual
cfd slm continual
cfd slm continual
Use cfd slm continual to configure continual one-way LM.
Use undo cfd slm continual to disable continual one-way LM.
cfd slm continual service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ peer ip-address pw-id pw-id ] [ dot1p dot1p-value ] [ interval { interval | msec msec-interval }] [ period period ]
undo cfd slm continual service-instance instance-id mep mep-id
Continual one-way LM is disabled.
period period: Specifies the statistics collection period in the range of 1 to 65535 seconds,
The continual one-way LM function measures the frame loss between the source and target MEPs by using LMM frames and LMR frames.
If the device supports hardware CC, you can specify the target MEP only by its MAC address. You cannot specify the target MEP by its ID.
To modify continual one-way LM settings for a source MEP, disable continual one-way LM and then reconfigure the function for the source MEP.
Before enabling continual one-way LM in an MPLS Layer 2 VPN, you must configure the same frame counting mode on the source MEP and target MEP.
To display the continual one-way LM result, use the display cfd slm history command on the device where the source MEP resides.
# Enable the continual one-way LM function to measure the frame loss between source MEP 1101 and target MEP 2001 in service instance 1.
[Sysname] cfd slm continual service-instance 1 mep 1101 target-mep 2001
cfd dlm continual
cfd slm
Use display cfd dlm history to display the two-way LM result.
display cfd dlm history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way LM results for all MEPs.
number number: Specifies the number of most recent two-way LM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the two-way LM result for source MEP 1101 in service instance 1.
<Sysname> display cfd dlm history service-instance 1 mep 1101
Service instance: 1
MEP ID: 1101
Send status: Testing
Reply from 0000-0000-0000:
Far-end frame loss : 1000 Far-end frame loss rate : 0.10%
Near-end frame loss: 2000 Near-end frame loss rate: 0.20%
Far-end frame loss : 4000 Far-end frame loss rate : 0.40%
Near-end frame loss: 4000 Near-end frame loss rate: 0.00%
Near-end frame loss: 1000 Near-end frame loss rate: 0.10%
Far-end frame loss : 3000 Far-end frame loss rate : 0.30%
Near-end frame loss: 3000 Near-end frame loss rate: 0.30%
Far-end frame loss : 2000 Far-end frame loss rate : 0.20%
Near-end frame loss: 1 Near-end frame loss rate: <0.01%
Average
Near-end frame loss: 2500 Near-end frame loss rate: 0.25%
Table 6 Command output
Send status |
LM test status: · Testing—An LM test is in progress. · Init—An LM test is in initialization state and is about to start. · Stop—An LM test stopped. If an LM test has never been performed on a source MEP, this field displays a hyphen (-). |
Reply from 0000-0000-0000 |
CCM frames returned from the target MEP. |
Average |
cfd dlm continual
Use display cfd dm two-way history to display the two-way DM result.
display cfd dm two-way history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the two-way DM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the two-way DM results for all MEPs.
number number: Specifies the number of most recent two-way DM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the two-way DM results for all the MEPs in all service instances.
<Sysname> display cfd dm two-way history
Service instance: 1
MEP ID: 1003
Frame delay:
Average: 8us
Average: 2us
Packet statistics:
MEP ID: 1004
Send status: Init
Frame delay:
Average: 8us
Average: 2us
Packet statistics:
Service instance: 2
No MEP exists in the service instance.
Table 7 Command output
Send status |
DM test status: · Testing—A DM test is in progress. · Init—A DM test is in initialization state and is about to start. · Stop—A DM test stopped. If a DM test has never been performed on a source MEP, this field displays a hyphen (-). |
Delay of DMR frames returned from the target MEP with MAC address 0010-FC00-6512. |
Average |
Received |
Lost |
Number of lost DMR frames. |
cfd dm two-way
Use display cfd linktrace-reply to display the LTR information received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767. If you do not specify this option, the command displays the LTR information for all service instances.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191. If you do not specify this option, the command displays the LTR information for all MEPs.
This command displays only information about LTRs received by execution of the cfd linktrace command.
# Display the LTR information saved on all the MEPs in every service instance.
[Sysname] display cfd linktrace-reply
Service instance: 1 MEP ID: 1003
0000-fc00-6505 63 0000-fc00-6504 MPDB
000f-e269-a852 62 0000-fc00-6505 FDB
0000-fc00-6508 61 000f-e269-a852 Hit
Service instance: 2 MEP ID: 1023
Table 8 Command output
Service instance |
Service instance to which the MEPs that send LTMs belong. |
MEP ID |
ID of the MEP that sends LTMs. |
MAC address |
Source MAC address in the LTR message. |
TTL |
Last MAC |
Relay action |
cfd linktrace
display cfd md
Use display cfd md to display the MD configuration information.
display cfd md
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
Maintenance domains configured: 4 in total
Level Index Maintenance domain MD format MD ID
0 1 md_0 CHARSTRING md_0
1 2 md_1 DNS dns1
2 3 md_2 MAC 0001-00
01-0001-1
3 4 md_3 NONE Without
ID
Table 9 Command output
Maintenance domains configured |
Number of MDs configured. |
Level |
Level of MD. |
Index |
MD index. |
Maintenance domain |
Name of MD. |
MD format |
MD name format: · CHARSTRING—Character string. · DNS—DNS name. · MAC—MAC address and an integer. · NONE—No MD name is carried. |
MD ID |
MD ID value: · A character string if the MD format is CHARSTRING. · A DNS name if the MD format is DNS. · A MAC address-subnumber if the MD format is MAC. · No ID if the MD format is NONE. |
display cfd mep
Use display cfd mep to display the attribute and operating information of a MEP.
display cfd mep mep-id service-instance instance-id
# In an MPLS Layer 2 VPN, display the attribute and operating information of MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: GigabitEthernet1/0/13.1
Maintenance domain: md_0
Maintenance domain index: 1
Maintenance association: ma_0
Maintenance association index: 1
Level: 0 Direction: Inbound
Current state: Active CCM send: Enabled
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s SendCCM: 12018 ReceiveCCM: 24036
Loopback:
NextSeqNumber: 8877
SendLBR: 0 ReceiveInOrderLBR: 0 ReceiveOutOrderLBR: 0
SendLBM: 0 ReceiveLBM: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0 ReceiveLTM: 0
SendLTM: 0 ReceiveLTR: 0
No CCM received from some remote MEPs.
Table 10 Command output
Interface on which the MEP is configured. |
MD to which the MEP belongs. (If the MD does not have a name, this field is displayed as Without ID.) |
Maintenance domain index |
Index of the MD to which the MEP belongs.. |
Maintenance association |
MA to which the MEP belongs. |
Maintenance association index |
Index of the MA to which the MEP belongs. |
Level |
Level of the MD. |
Direction |
Direction of the MEPs. |
Current state |
State of MEP: · Active. · Inactive. |
CCM send |
Whether the MEP sends CCM. |
FNG state |
State of FNG (Fault Notification Generator): · FNG_RESET—A fault has been cleared. · FNG_DEFECT—A fault has been detected. · FNG_REPORT_DEFECT—Report a fault. · FNG_DEFECT_REPORTED—A fault has been reported. · FNG_DEFECT_CLEARING—A fault is being cleared. If this field is not supported, a hyphen (-) is displayed. |
CCM |
Information related to CCM. |
Current state |
State of CCMs sent: · CCI_IDLE—Initial state. · CCI_WAITING—Sending state. If this field is not supported, a hyphen (-) is displayed. |
Interval |
Interval to send CCM. Not supported means the MEP does not support CCM sending. |
SendCCM |
Number of CCMs that have been sent by the MEPs. If this field is not supported, a hyphen (-) is displayed. |
ReceiveCCM |
Number of CCMs that have been received by the MEPs. If this field is not supported, a hyphen (-) is displayed. |
Loopback |
Information related to Loopback. |
NextSeqNumber |
Sequence number of the next LBM to be sent. |
SendLBR |
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted. |
ReceiveInOrderLBR |
Number of LBR messages received in correct sequence. |
ReceiveOutOrderLBR |
Number of LBR messages received out of order. |
SendLBM |
Number of LBMs that have been sent. If the MEP is inward-facing, the number of LBMs will not be counted. |
ReceiveLBM |
Number of LBMs that have been received. |
Linktrace |
Information related to linktrace. |
NextSeqNumber |
Sequence number of the next LTM to be sent. |
SendLTR |
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted. |
ReceiveLTM |
Number of LTMs received. |
SendLTM |
Number of LTMs that have been sent. If the MEP is inward-facing, the number of LTMs will not be counted. |
ReceiveLTR |
Number of LTRs that have been received. |
No CCM received from some remote MEPs. |
Failure to receive CCMs from some remote MEPs. (This information is displayed only when some CCMs are lost.) |
One or more streams of error CCMs is received. The last received CCM: |
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.) |
MD of the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
MA of the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
MEP |
ID of the MEP that sent the last error CCM message. If this field is not supported, a hyphen (-) is displayed. |
Sequence Number |
Sequence number of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Received Time |
Time when the last error CCM is received. If this field is not supported, a hyphen (-) is displayed. |
One or more streams of cross-connect CCMs is received. The last received CCM: |
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.) |
Some other MEPs are transmitting the RDI bit. |
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.) |
display cfd meplist
Use display cfd meplist to display the MEP list in a service instance.
display cfd meplist [ service-instance instance-id ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
Use display cfd mp to display the MP information.
display cfd mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays MP information for all interfaces.
# Display the MP information on all interfaces.
<Sysname> display cfd mp
Interface GigabitEthernet1/0/13 VLAN NONE
MEP ID: 101 Level: 2 Service instance: 102 Direction: Inbound
Maintenance domain: md_2
Maintenance domain index: 3
Maintenance association: ma_2
Maintenance association index: 3
Table 11 Command output
Interface GigabitEthernet1/0/13 VLAN NONE |
Configuration of the MP that does not serve any VLAN or configuration of the MP in an MPLS Layer 2 VPN. |
Level |
MD level to which the MP belongs. |
Service instance |
Service instance to which the MP belongs. |
MD to which the MP belongs. |
Index of the MD to which the MP belongs. |
MA to which the MP belongs. |
Index of the MA to which the MP belongs. |
Direction |
Direction of the MEP: · Inbound. |
display cfd remote-mep
Use display cfd remote-mep to display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
# Display remote MEP information for MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID MAC address State Time MAC status
20 00e0-fc00-6565 OK 2013/03/06 02:36:38 UP
30 00e0-fc27-6502 OK 2013/03/06 02:36:38 DOWN
40 00e0-fc00-6510 FAILED 2013/03/06 02:36:39 DOWN
50 00e0-fc52-baa0 OK 2013/03/06 02:36:44 DOWN
60 0010-fc00-6502 OK 2013/03/06 02:36:42 DOWN
Table 12 Command output
MEP ID |
ID of the remote MED. |
MAC address |
MAC address of the remote MEP device. If this field is not supported, a hyphen (-) is displayed. |
State |
Running state of the remote MEP: · OK. · FAILED. |
Time |
Time when the remote MEP entered the FAILED or OK state for the last time. If this field is not supported, a hyphen (-) is displayed. |
MAC status |
State of the interface indicated by the last CCM received from the remote MEP: · UP—The interface is ready to pass packets. · DOWN—The interface cannot pass packets. · TESTING—The interface is in some test mode. · UNKNOWN—The interface status cannot be determined. · DORMANT—The interface is not in a state to pass packets. Instead, it is in a pending state, waiting for some external event. · NOT-PRESENT—Some component of the interface is missing. · LLD—The interface is down due to state of the lower layer interfaces. If this field is not supported, a hyphen (-) is displayed. |
display cfd service-instance
Use display cfd service-instance to display the configuration information of service instances.
display cfd service-instance [ instance-id ]
instance-id: Specifies a service instance ID in the range of 1 to 32767. If you do not specify this argument, the command displays configuration information for all service instances.
# In an MPLS Layer 2 VPN, display the configuration information of all service instances.
<Sysname> display cfd service-instance
Service instances configured (2 in total):
Service instance 5:
Maintenance domain: md_5
Maintenance domain index: 5
Maintenance association: ma_5
Maintenance association index: 5
Xconnect-group: vpn1
Xconnection: ldp1
Level: 5 MIP rule: NONE CCM interval: 1s
Direction: Inbound
MEP ID: 730 Interface: GigabitEthernet1/0/12
Service instance 6:
Maintenance domain: (Without ID)
Maintenance domain index: 6
Maintenance association: ma_6
Maintenance association index: 6
Xconnect-group: vpn2
Xconnection: ldp2
Level: 6 MIP rule: NONE CCM interval: 1s
Direction: Inbound
MEP ID: 731 Interface: GigabitEthernet1/0/13
Table 13 Command output
Service instances are configured. |
Number of service instances configured. |
Service instance |
Service instance ID. |
MD of the service instance. (If the MD does not have a name, this field displays Without ID.) |
Index of the MD to which the service instance belong. |
Maintenance association: |
MA of the service instance. |
Index of the MA to which the service instance belong. |
Xconnect-group |
Cross-connect group name. |
Xconnection |
Cross-connect name. |
Level |
MD level. |
CCM interval |
Interval to send CCMs. |
Direction |
Direction of the MEPs configured on the service instance. |
MEP ID |
ID of MEPs configured on the service instance. |
Interface of the MEP configured on the service instance. |
Use display cfd slm history to display the one-way LM result.
display cfd slm history [ service-instance instance-id [ mep mep-id ] ] [ number number ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the one-way LM results for all service instances.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191. If you do not specify this option, the command displays the one-way LM results for all MEPs.
number number: Specifies the number of most recent one-way LM result entries to be displayed, in the range of 1 to 64. The default is 5.
# Display the one-way LM result for source MEP 1101 in service instance 1.
<Sysname> display cfd slm history service-instance 1 mep 1101
Service instance: 1
MEP ID: 1101
Average
Packet statistics:
Sent LMMs: 100 Received: 100
Table 14 Command output
Send status |
Average |
Received |
Number of received frames. |
cfd slm
cfd slm continual
display cfd status
Use display cfd status to display the CFD status.
display cfd status
# Display the CFD status.
CFD is enabled.
AIS is disabled.
Table 15 Command output
AIS is enabled |
This field is not supported in the current software version. AIS is enabled. |
AIS is disabled |
This field is not supported in the current software version. AIS is disabled. |
