13-Network Management and Monitoring
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10013-Network Management and Monitoring
11-SFLOW-MIB
11-SFLOW-MIB 91.75 KB
SFLOW-MIB
About this MIB
Use this MIB to configure sFlow, a traffic monitoring technology.
MIB file name
sflow.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).sflow(14706).sFlowMIB(1).sFlowAgent(1)
Scalar objects
sFlowVersion (1.3.6.1.4.1.14706.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Standard MIB values.
Version information.
As per the MIB.
sFlowAgentAddressType (1.3.6.1.4.1.14706.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
InetAddressType
Agent address type.
As per the MIB.
sFlowAgentAddress (1.3.6.1.4.1.14706.1.1.3)
Object (OID)
Access
Value range
Implementation
read-only
InetAddress
Agent address.
As per the MIB.
Tabular objects
sFlowRcvrTable
About this table
This table configures the sFlow collector information.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is sFlowRcvrIndex.
Object (OID)
Access
Value range
Implementation
sFlowRcvrIndex (1.3.6.1.4.1.14706.1.1.4.1.1)
not-accessible
INTEGER
Integer32(1..65535)
Collector index.
As per the MIB.
sFlowRcvrOwner (1.3.6.1.4.1.14706.1.1.4.1.2)
read-write
OwnerString
Collector description.
As per the MIB.
sFlowRcvrTimeout (1.3.6.1.4.1.14706.1.1.4.1.3)
read-write
INTEGER
Aging time.
As per the MIB.
sFlowRcvrMaximumDatagramSize (1.3.6.1.4.1.14706.1.1.4.1.4)
read-write
INTEGER
Integer32(200..3000)
Maximum number of data bytes that can be sent in a single sample datagram.
As per the MIB.
sFlowRcvrAddressType (1.3.6.1.4.1.14706.1.1.4.1.5)
read-write
InetAddressType
Collector address type.
As per the MIB.
sFlowRcvrAddress (1.3.6.1.4.1.14706.1.1.4.1.6)
read-write
InetAddress
OCTET STRING (0..255)
Collector IP address.
As per the MIB.
sFlowRcvrPort (1.3.6.1.4.1.14706.1.1.4.1.7)
read-write
INTEGER
UDP port number.
As per the MIB.
sFlowRcvrDatagramVersion (1.3.6.1.4.1.14706.1.1.4.1.8)
read-write
Integer32
Datagram version.
Supports only V5.
sFlowFsTable
About this table
This table configures sFlow flow sampling.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are sFlowFsDataSource and sFlowFsInstance.
Object (OID)
Access
Value range
Implementation
sFlowFsDataSource (1.3.6.1.4.1.14706.1.1.5.1.1)
not-accessible
SFlowDataSource
Data source.
As per the MIB.
sFlowFsInstance (1.3.6.1.4.1.14706.1.1.5.1.2)
not-accessible
SFlowInstance
Instance ID.
As per the MIB.
sFlowFsReceiver (1.3.6.1.4.1.14706.1.1.5.1.3)
read- write
SFlowReceiver
Receiver.
As per the MIB.
sFlowFsPacketSamplingRate (1.3.6.1.4.1.14706.1.1.5.1.4)
read- write
INTEGER
Sampling rate.
As per the MIB.
sFlowFsMaximumHeaderSize (1.3.6.1.4.1.14706.1.1.5.1.5)
read- write
INTEGER
Integer32(18..512)
Maximum number of bytes that should be copied from a sampled packet.
As per the MIB.
sFlowCpTable
About this table
This table configures sFlow counter sampling.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are sFlowCpDataSource and sFlowCpInstance.
Object (OID)
Access
Value range
Implementation
sFlowCpDataSource (1.3.6.1.4.1.14706.1.1.6.1.1)
not-accessible
SFlowDataSource
Data source.
As per the MIB.
sFlowCpInstance (1.3.6.1.4.1.14706.1.1.6.1.2)
not-accessible
SFlowInstance
Instance ID.
As per the MIB.
sFlowCpReceiver (1.3.6.1.4.1.14706.1.1.6.1.3)
read- write
INTEGER
Sampling collector.
As per the MIB.
sFlowCpInterval (1.3.6.1.4.1.14706.1.1.6.1.4)
read- write
INTEGER
Integer32(2..86400)
Sampling interval.
As per the MIB.
