13-Network Management and Monitoring
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10013-Network Management and Monitoring
06-HH3C-NTP-MIB
06-HH3C-NTP-MIB 156.48 KB
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNTP(22)
Scalar objects
hh3cNTPSysLeap (1.3.6.1.4.1.25506.8.22.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
noWarning(0), addSecond(1), subtractSecond(2), alarm(3)
Two-bit system leap indicator.
As per the MIB.
hh3cNTPSysStratum (1.3.6.1.4.1.25506.8.22.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (1..16)
Stratum level of the local system clock.
As per the MIB.
hh3cNTPSysPrecision (1.3.6.1.4.1.25506.8.22.1.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (-20..20)
Accuracy of the system clock.
As per the MIB.
hh3cNTPSysRootdelay (1.3.6.1.4.1.25506.8.22.1.1.4)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
OCTET STRING (1..128)
Round-trip delay from the local device to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRootdispersion (1.3.6.1.4.1.25506.8.22.1.1.5)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Maximum error of the system clock relative to the primary reference source at the root of the synchronization subnet.
As per the MIB.
hh3cNTPSysRefid (1.3.6.1.4.1.25506.8.22.1.1.6)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Reference clock ID of the local clock.
As per the MIB.
hh3cNTPSysReftime (1.3.6.1.4.1.25506.8.22.1.1.7)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Timestamp of the local system clock updated most recently.
As per the MIB.
hh3cNTPSysPoll (1.3.6.1.4.1.25506.8.22.1.1.8)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (-20..20)
System polling interval.
As per the MIB.
hh3cNTPSysPeer (1.3.6.1.4.1.25506.8.22.1.1.9)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (0..2147483647)
Reference synchronization source specified by the system.
This object is replaced by hh3cNTPSysSrcPeer.
hh3cNTPSysState (1.3.6.1.4.1.25506.8.22.1.1.10)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5)
Status of the local clock.
An integer indicates the status of the local clock. Currently, clockBySet(2) is not supported.
hh3cNTPSysOffset (1.3.6.1.4.1.25506.8.22.1.1.11)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Offset of the local clock updated most recently.
As per the MIB.
hh3cNTPSysDrift (1.3.6.1.4.1.25506.8.22.1.1.12)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Pre-made clock frequency.
As per the MIB.
hh3cNTPSysCompliance (1.3.6.1.4.1.25506.8.22.1.1.13)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
System error.
As per the MIB.
hh3cNTPSysClock (1.3.6.1.4.1.25506.8.22.1.1.14)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
System local time.
As per the MIB.
hh3cNTPSysStabil (1.3.6.1.4.1.25506.8.22.1.1.15)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
Clock frequency stability.
As per the MIB.
hh3cNTPSysAuthenticate (1.3.6.1.4.1.25506.8.22.1.1.16)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
noAuthenticate(0), authenticate(1)
An integer indicates that the system supports authentication.
As per the MIB.
hh3cNTPSysPollSec (1.3.6.1.4.1.25506.8.22.1.1.17)
Object (OID)
Access
Value range
Implementation
hh3cNTPSysPollSec
read-write
Integer32
Integer32 (2..1048576)
System polling interval, in seconds.
Only read operations are supported.
hh3cNTPSysClockSec (1.3.6.1.4.1.25506.8.22.1.1.18)
Object (OID)
Access
Value range
Implementation
hh3cNTPSysClockSec
read-only
Integer32
Standard MIB values.
System local time, in seconds.
As per the MIB.
hh3cNTPServerIP (1.3.6.1.4.1.25506.8.22.1.1.19)
Object (OID)
Access
Value range
Implementation
hh3cNTPServerIP
read-write
IpAddress
OCTET STRING (4)
IP address of the NTP server.
As per the MIB.
hh3cNTPSysSrcPeer (1.3.6.1.4.1.25506.8.22.1.1.20)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
As per the MIB.
hh3cNTPSysTimeOffsetThres (1.3.6.1.4.1.25506.8.22.1.1.27)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
Clock time offset threshold.
As per the MIB.
hh3cNTPSysTimeOffsetLimit (1.3.6.1.4.1.25506.8.22.1.1.28)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Upper limit of the clock time offset threshold.
As per the MIB.
Tabular objects
hh3cNTPPeerTable
About this table
This table provides information about the peers associated with the local NTP server.
Support for operations
CreateSupported. The hh3cNTPPeerRowStatus column supports only value createAndGo.
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cNTPPeerRemAdr and hh3cNTPPeerHMode.
Object (OID)
Access
Value range
Implementation
hh3cNTPPeerConfig (1.3.6.1.4.1.25506.8.22.2.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
A bit indicates the establishment of the association. If a peer is unreachable, the bit is not recoverable.
As per the MIB.
hh3cNTPPeerAuthenable (1.3.6.1.4.1.25506.8.22.2.1.1.1.2)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the peer system supports authentication.
As per the MIB.
hh3cNTPPeerAuthentic (1.3.6.1.4.1.25506.8.22.2.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
A bit indicates that the authentic message passes authentication.
As per the MIB.
hh3cNTPPeerRemAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.4)
not-accessible
IpAddress
OCTET STRING (4)
IP address of the peer. Set the object when creating a new association.
As per the MIB.
hh3cNTPPeerRemPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.5)
read-only
Integer32
Integer32 (1..65535)
The UDP port number on which the peer receives NTP messages.
As per the MIB.
hh3cNTPPeerLocAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.6)
read-only
IpAddress
OCTET STRING (4)
IP address of the local host.
As per the MIB.
hh3cNTPPeerLocPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.7)
read-only
Integer32
The UDP port number on which the local host receives NTP messages.
As per the MIB.
hh3cNTPPeerLeap (1.3.6.1.4.1.25506.8.22.2.1.1.1.8)
read-only
INTEGER
Second leap indicator of the peer.
As per the MIB.
hh3cNTPPeerHMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.9)
not-accessible
INTEGER
unspecified (0), symmetricActive (1), symmetricPassive (2), client (3), server(4), broadcast (5), reservedControl (6), reservedPrivate (7), broadcastclient (8), multicastclient (9)
Host association mode.
As per the MIB.
hh3cNTPPeerStratum (1.3.6.1.4.1.25506.8.22.2.1.1.1.10)
read-only
Integer32
Integer32 (0..255)
Stratum level of the peer, indicating the clock accuracy.
As per the MIB.
hh3cNTPPeerPPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.11)
read-only
Integer32
Integer32 (-20..20)
The interval at which the peer polls the local host.
As per the MIB.
hh3cNTPPeerHPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.12)
read-only
Integer32
Integer32 (-20..20)
The interval at which the local host polls the peer.
As per the MIB.
hh3cNTPPeerPrecision (1.3.6.1.4.1.25506.8.22.2.1.1.1.13)
read-only
Integer32
Integer32 (-20..20)
Precision of the peer clock.
As per the MIB.
hh3cNTPPeerRootDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.14)
read-only
OCTET STRING
Round-trip delay from the peer clock to the local clock.
As per the MIB.
hh3cNTPPeerRootDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.15)
read-only
OCTET STRING
Clock time difference between the peer clock and the time source.
As per the MIB.
hh3cNTPPeerRefId (1.3.6.1.4.1.25506.8.22.2.1.1.1.16)
read-only
OCTET STRING
Reference source ID of the peer clock.
As per the MIB.
hh3cNTPPeerRefTime (1.3.6.1.4.1.25506.8.22.2.1.1.1.17)
read-only
OCTET STRING
Timestamp of the peer clock.
As per the MIB.
hh3cNTPPeerOrg (1.3.6.1.4.1.25506.8.22.2.1.1.1.18)
read-only
OCTET STRING
Local clock timestamp in the NTP message sent most recently.
As per the MIB.
hh3cNTPPeerRec (1.3.6.1.4.1.25506.8.22.2.1.1.1.19)
read-only
OCTET STRING
Local timestamp in the NTP message received most recently from the peer.
As per the MIB.
hh3cNTPPeerXmt (1.3.6.1.4.1.25506.8.22.2.1.1.1.20)
read-only
OCTET STRING
Local time after the sending of a NTP message.
As per the MIB.
hh3cNTPPeerReach (1.3.6.1.4.1.25506.8.22.2.1.1.1.21)
read-only
Integer32
Reachability count. A peer is unreachable if the object value is 0.
As per the MIB.
hh3cNTPPeerValid (1.3.6.1.4.1.25506.8.22.2.1.1.1.22)
read-only
Integer32
Integer32 (0..255)
Valid sampling data.
As per the MIB.
hh3cNTPPeerTimer (1.3.6.1.4.1.25506.8.22.2.1.1.1.23)
read-only
Integer32
The interval of transmitted NTP messages from the host to the peer.
As per the MIB.
hh3cNTPPeerDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.24)
read-only
OCTET STRING
Delay of messages from the host to the peer.
As per the MIB.
hh3cNTPPeerOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.25)
read-only
OCTET STRING
Offset of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerJitter (1.3.6.1.4.1.25506.8.22.2.1.1.1.26)
read-only
OCTET STRING
Sampling data flag.
As per the MIB.
hh3cNTPPeerDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.27)
read-only
OCTET STRING
Maximum error of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerKeyId (1.3.6.1.4.1.25506.8.22.2.1.1.1.28)
read-only
Unsigned32
Authentication key ID in NTP messages.
As per the MIB.
hh3cNTPPeerFiltDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.29)
read-only
OCTET STRING
Round-trip delay of the peer relative to the local clock.
As per the MIB.
hh3cNTPPeerFiltOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.30)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerFiltError (1.3.6.1.4.1.25506.8.22.2.1.1.1.31)
read-only
OCTET STRING
As per the MIB.
hh3cNTPPeerPMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.32)
read-only
INTEGER
Association mode of the peer.
As per the MIB.
hh3cNTPPeerReceived (1.3.6.1.4.1.25506.8.22.2.1.1.1.33)
read-only
INTEGER(0..4294967295)
Number of received NTP messages.
As per the MIB.
hh3cNTPPeerSent (1.3.6.1.4.1.25506.8.22.2.1.1.1.34)
read-only
Number of sent NTP messages.
As per the MIB.
hh3cNTPPeerFlash (1.3.6.1.4.1.25506.8.22.2.1.1.1.35)
read-only
Hh3cAlarmStatus
BITS{
recvRepeatMsg(0),
recvremanMsg(1),
unSynMsg(2),
dispBeyond(3),
unauthenticate(4), unSynClock(5), straBeyond(6), rootDispBeyond(7), noAuthen(8),
refuOperate(9) }
Message test flag.
As per the MIB.
hh3cNTPPeerRowStatus (1.3.6.1.4.1.25506.8.22.2.1.1.1.36)
read-create
RowStatus
Supports only values active, createAndGo, and destroy.
Row status.
Supports only values active, createAndGo, and destroy. If the value broadcast, broadcastclient, or multicastclient is used for hh3cNTPPeerHMode, this object supports only the read operation.
