13-Network Management and Monitoring
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10013-Network Management and Monitoring
08-HH3C-SNMP-EXT-MIB
08-HH3C-SNMP-EXT-MIB 85.46 KB
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (1..65535)
Maximum number of SNMP contexts supported by the system.
As per the MIB.
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
Object (OID)
Access
Value range
Implementation
read-write
BITS
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) }
SNMP version.
As per the MIB.
hh3cSnmpExtTrapSource (1.3.6.1.4.1.25506.2.104.1.6)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING (0..255)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its traps.
As per the MIB.
hh3cSnmpExtInformSource (1.3.6.1.4.1.25506.2.104.1.7)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING(1..63)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its informs.
As per the MIB.
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1)
not-accessible
SnmpSecurityModel
INTEGER (0..3)
Security model of a community or user.
As per the MIB.
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Security name of the community or user.
As per the MIB.
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3)
read-only
OCTET STRING
Community name or username.
As per the MIB.
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4)
read-write
Integer32
Integer32 (0 | 2000..3999)
IPv4 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5)
read-write
Integer32
IPv6 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP context extended properties.
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1)
not-accessible
SnmpAdminString
Context name.
As per the MIB.
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of this entry.
Supports only action, createAndGo, and destroy.
