- 13-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-MIRRORGROUP-MIB
- 05-HH3C-NQA-MIB
- 06-HH3C-NTP-MIB
- 07-HH3C-RMON-EXT2-MIB
- 08-HH3C-SNMP-EXT-MIB
- 09-RMON-MIB
- 10-RMON2-MIB
- 11-SFLOW-MIB
- 12-SNMP-FRAMEWORK-MIB
- 13-SNMP-MPD-MIB
- 14-SNMP-NOTIFICATION-MIB
- 15-SNMP-TARGET-MIB
- 16-SNMP-USER-BASED-SM-MIB
- 17-SNMP-VIEW-BASED-ACM-MIB
- 18-SNMPv2-MIB
02-DISMAN-PING-MIB | 160.31 KB |
DISMAN-PING-MIB
About this MIB
Use this MIB to implement the ping utility defined by RFC 2925. Ping operations are performed by NQA ICMP echo probes.
To implement DISMAN PING, the devices must support this MIB. This MIB cannot be used together with CLI.
MIB file name
rfc2925-disman-ping.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pingMIB(80)
Scalar objects
pingMaxConcurrentRequests (1.3.6.1.2.1.80.1.1)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pingMaxConcurrentRequests (1.3.6.1.2.1.80.1.1) |
read-write |
Unsigned32 |
Standard MIB values. |
Maximum number of concurrent active ping requests that are allowed within an agent implementation. |
Only read is supported. |
Tabular objects
pingCtlTable
About this table
Use this table to define parameters in a ping operation.
Support for operations
Create:You can create the pingCtlAdminStatus node only when the state for the node is disable.
Specify a value for the pingCtlType object when you create a ping operation entry. The value for this object is not modifiable after creation. The default value for the pingCtlType object is pingIcmpEcho.
The creation operation for a ping operation entry fails if the entry contains parameters not supported by the probe type specified by the pingCtlType object.
Edit/Modify:To save history probe information, set the state of the h3cNQACtlHistoryEnable object to enable.
You cannot configure parameters not supported by the probe type specified by the pingCtlType object.
Modifying any object in the pingCtlTable except the following objects will clear the corresponding probe results (not including the history records and statistics):
pingCtlTrapGeneration.
pingCtlTrapProbeFailureFilter.
pingCtlTrapTestFailureFilter.
pingCtlDescr.
pingCtlMaxRows. If the new value for this object is lower than the previous value, the system deletes the excessive history records.
You must specify pingCtlTargetAddressType and pingCtlTargetAddress in pairs in an SNMP request.
You must specify pingCtlSourceAddressType and pingCtlSourceAddress in pairs in an SNMP request.
Delete:A delete operation fails if the state of the pingCtlAdminStatus node is enable.
Read:Not supported.
The ping operation probe result is invalid if the read operation obtains information about parameters not supported by the probe type specified by the pingCtlType object.
Columns
The table indexes are pingCtlOwnerIndex and pingCtlTestName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pingCtlOwnerIndex (1.3.6.1.2.1.80.1.2.1.1) |
not-accessible |
SnmpAdminString |
OCTET STRING (0..32) |
Administrator name of a ping operation. |
For the set operation, the uppercase letters in the value will be converted to lowercase letters. The value cannot contain a minus sign (-). |
pingCtlTestName (1.3.6.1.2.1.80.1.2.1.2) |
not-accessible |
SnmpAdminString |
Operation tag. |
For the set operation, the uppercase letters in the value will be converted to lowercase letters. The value for this object cannot contain a minus sign (-). |
pingCtlTargetAddressType (1.3.6.1.2.1.80.1.2.1.3) |
read-create |
InetAddressType |
Destination address type. |
Supports only ipv4(1), ipv6(2), unknown(0), and dns(16). |
pingCtlTargetAddress (1.3.6.1.2.1.80.1.2.1.4) |
read-create |
InetAddress |
Destination address. |
If the value for the pingCtlTargetAddressType object is ipv4(1), the value for this object must be an IPv4 address. If the value for the pingCtlTargetAddressType object is ipv6(2), the value for this object must be an IPv6 address. If the value for the pingCtlTargetAddressType object is dns(16), the value for this object can be a host name. If the value for the pingCtlTargetAddressType object is unknown(0), the value for this object must be a zero-length string. |
pingCtlDataSize (1.3.6.1.2.1.80.1.2.1.5) |
read-create |
Unsigned32 |
Unsigned32 (0..65507) |
Payload size for each probe packet. |
The maximum payload size of an IP packet is 65507 octets, excluding the size of the ICMP or UDP packet header (each of the header occupies eight octets) and the IP packet header (20 octets). If the system uses the default payload size, the value is 0 octets. For ICMP or UDP operations, the value range for this object is 20 to 65507 octets. For jitter operations, the value range for this object is 68 to 65507 octets. The default value is 100 octets. For voice operations, the value range for this object is 16 to 65507 octets. If the codec type is g711a or g711µ, the default value is 172 octets. For other codec types, the default value is 32 octets. This object does not take effect on ARP operations. |
pingCtlTimeOut (1.3.6.1.2.1.80.1.2.1.6) |
read-create |
Unsigned32 |
Unsigned32 (1..60) |
Timeout time for waiting for a response to a probe request.. |
The return value for the read operation is not accurate if the value is not set to integer seconds at the CLI. For example, if the value configured at the CLI is 1050 milliseconds, the return value for the read operation will be 2 seconds. If the value configured at the CLI exceeds 60 seconds, the return value for the read operation is 60 seconds. For voice operations, the default value is 5 seconds. For other operations, the default value is 3 seconds. |
pingCtlProbeCount (1.3.6.1.2.1.80.1.2.1.7) |
read-create |
Unsigned32 |
Unsigned32 (1..15) |
Number of probes per operation. |
For voice operations, the value for this object must be 1. |
pingCtlAdminStatus (1.3.6.1.2.1.80.1.2.1.8) |
read-create |
INTEGER |
enabled(1), disabled(2) |
Administrative status of the probe operation. |
As per the MIB. |
pingCtlDataFill (1.3.6.1.2.1.80.1.2.1.9) |
read-create |
OCTET STRING |
OCTET STRING (0..1024) |
Payload fill string for probe packets. |
Length: 0 to 200 characters. This object does not take effect on ARP operations. |
pingCtlFrequency (1.3.6.1.2.1.80.1.2.1.10) |
read-create |
Unsigned32 |
Interval between two consecutive probes. |
Value range: 0 to 604800 seconds. The return value for the read operation is not accurate if the value is not set to integer seconds at the CLI. For example, if the value configured at the CLI is 1050 milliseconds, the return value for the read operation will be 2 seconds. For voice operations, the default value is 60 seconds. For other operations, the default value is 0 seconds. If the value for this object is 0, the system does not generate statistics for the operation. |
pingCtlMaxRows (1.3.6.1.2.1.80.1.2.1.11) |
read-create |
Unsigned32 |
Maximum number of history records. |
Value range: 0 to 50. |
pingCtlStorageType (1.3.6.1.2.1.80.1.2.1.12) |
read-create |
StorageType |
Conceptual row storage type. |
pingCtlTrapGeneration (1.3.6.1.2.1.80.1.2.1.13) |
read-create |
BITS |
BITS { probeFailure(0), testFailure(1), testCompletion(2) } |
Conditions to generate notifications. |
ICMP jitter. voice, UDP jitter operations support only pingTestCompleted(2). |
pingCtlTrapProbeFailureFilter (1.3.6.1.2.1.80.1.2.1.14) |
read-create |
Unsigned32 |
Unsigned32 (0..15) |
Number of successive probe failures that are required before a notification can be generated. |
Value range: 1 to 15. This object is not available before you specify probeFailure for pingCtlTrapGeneration. If the value of pingCtlTrapGeneration does not contain probeFailure, the value for this object is 1. This object does not take effect on voice operations. |
pingCtlTrapTestFailureFilter (1.3.6.1.2.1.80.1.2.1.15) |
read-create |
Unsigned32 |
Number of accumulated probe failures that are required before a notification can be generated. |
Value range: 1 to 15. This object is not available before you specify testFailure for pingCtlTrapGeneration. If the value of pingCtlTrapGeneration does not contain testFailure, the value for this object is 1. This object does not take effect on voice operations. |
pingCtlType (1.3.6.1.2.1.80.1.2.1.16) |
read-create |
OBJECT IDENTIFIER |
Operation type. |
This object cannot be edited after creation. |
pingCtlDescr (1.3.6.1.2.1.80.1.2.1.17) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
Description string for the remote ping operation. |
Length: 0 to 200 characters. The value for this object cannot start with a space. |
pingCtlSourceAddressType (1.3.6.1.2.1.80.1.2.1.18) |
read-create |
InetAddressType |
Source address type. |
Only supports ipv4(1), ipv6(2),and unknown(0). Default: unknown(0). |
pingCtlSourceAddress (1.3.6.1.2.1.80.1.2.1.19) |
read-create |
InetAddress |
Source address. |
If the value for the pingCtlSourceAddressType is ipv4(1), the value for this object must be an IPv4 address. If the value for the pingCtlSourceAddressType object is ipv6(2), the value for this object must be an IPv6 address. If the value for the pingCtlSourceAddressType object is unknown(0), the value for this object must be a zero-length string. |
pingCtlIfIndex (1.3.6.1.2.1.80.1.2.1.20) |
read-create |
InterfaceIndexOrZero |
Interface index. |
pingCtlByPassRouteTable (1.3.6.1.2.1.80.1.2.1.21) |
read-create |
TruthValue |
Whether to bypass the routing table when sending data packets. |
This object does not take effect on ARP operation s. |
pingCtlDSField (1.3.6.1.2.1.80.1.2.1.22) |
read-create |
Unsigned32 |
Unsigned32 (0..255) |
Service type of data packets. |
pingCtlRowStatus (1.3.6.1.2.1.80.1.2.1.23) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndgo(4), and destroy(6). |
pingResultsTable
About this table
This table obtains ping result information.
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pingResultsOperStatus (1.3.6.1.2.1.80.1.3.1.1) |
read-only |
INTEGER |
enabled(1), disabled(2), completed(3) |
Operation status. |
As per the MIB. |
pingResultsIpTargetAddressType (1.3.6.1.2.1.80.1.3.1.2) |
read-only |
InetAddressType |
As per the MIB. |
pingResultsIpTargetAddress (1.3.6.1.2.1.80.1.3.1.3) |
read-only |
InetAddress |
As per the MIB. |
pingResultsMinRtt (1.3.6.1.2.1.80.1.3.1.4) |
read-only |
Unsigned32 |
Minimum round-trip time. |
As per the MIB. |
pingResultsMaxRtt (1.3.6.1.2.1.80.1.3.1.5) |
read-only |
Unsigned32 |
Maximum round-trip time. |
As per the MIB. |
pingResultsAverageRtt (1.3.6.1.2.1.80.1.3.1.6) |
read-only |
Unsigned32 |
Average round-trip time. |
As per the MIB. |
pingResultsProbeResponses (1.3.6.1.2.1.80.1.3.1.7) |
read-only |
Gauge32 |
Number of received echo replies. |
As per the MIB. |
pingResultsSentProbes (1.3.6.1.2.1.80.1.3.1.8) |
read-only |
Gauge32 |
Number of sent echo requests. |
As per the MIB. |
pingResultsRttSumOfSquares (1.3.6.1.2.1.80.1.3.1.9) |
read-only |
Unsigned32 |
Sum of squares for the round-trip time. |
As per the MIB. |
pingResultsLastGoodProbe (1.3.6.1.2.1.80.1.3.1.10) |
read-only |
DateAndTime |
Date and time when the last echo reply was received. |
As per the MIB. |
pingProbeHistoryTable
About this table
This table obtains information about ping history result information.
Read:Not supported
Columns
The table index is pingProbeHistoryIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pingProeHistoryIndex (1.3.6.1.2.1.80.1.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..'ffffffff'h) |
History record index of a probe operation. |
As per the MIB. |
pingProbeHistoryResponse (1.3.6.1.2.1.80.1.4.1.2) |
read-only |
Unsigned32 |
Time taken for the probe operation. |
As per the MIB. |
pingProbeHistoryStatus (1.3.6.1.2.1.80.1.4.1.3) |
read-only |
OperationResponseStatus |
Probe result. |
Result of a particular probe done by a remote host. |
pingProbeHistoryTime (1.3.6.1.2.1.80.1.4.1.5) |
read-only |
DateAndTime |
Date and time when the result was determined. |
As per the MIB. |
Notifications
pingProbeFailed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.80.0.1 |
A ping operation failure was detected. |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
This notification is generated when the number of consecutive probe failures in a ping operation reaches the specified value. The following might be the ping failure reasons:
The destination address does not exist.
The destination address exists but is unreachable.
The network latency is large and the round-trip time of packets is larger than the specified timeout time.
System impact
The device cannot communicate with the ping destination.
Status control
ON
CLI: Use the reaction trap probe-failure command.
OFF
CLI: Use the undo reaction trap probe-failure command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.80.1.2.1.3 (pingCtlTargetAddressType) |
pingCtlOwnerIndex pingCtlTestName |
InetAddressType |
1.3.6.1.2.1.80.1.2.1.4 (pingCtlTargetAddress) |
InetAddress |
1.3.6.1.2.1.80.1.3.1.1 (pingResultsOperStatus) |
Operation status. |
INTEGER |
enabled(1),, disabled(2) |
1.3.6.1.2.1.80.1.3.1.2 (pingResultsIpTargetAddressType) |
Destination address type in the probe result. |
InetAddressType |
1.3.6.1.2.1.80.1.3.1.3 (pingResultsIpTargetAddress) |
Destination address in the probe result. |
InetAddress |
1.3.6.1.2.1.80.1.3.1.4 (pingResultsMinRtt) |
Minimum round-trip time in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.5 (pingResultsMaxRtt) |
Maximum round-trip time in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.6 (pingResultsAverageRtt) |
Average round-trip time in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.7 (pingResultsProbeResponses) |
Number of received echo replies in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.8 (pingResultsSentProbes) |
Number of sent echo requests in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.9 (pingResultsRttSumOfSquares) |
Sum of squares for the round-trip time in the probe result. |
Unsigned32 |
1.3.6.1.2.1.80.1.3.1.10 (pingResultsLastGoodProbe) |
Date and time when the last echo reply was received in the probe result. |
DateAndTime |
Recommended action
1.In NQA operation view, execute the display this command to identify whether the destination address is configured correctly.
- If the destination address is correct, go to step 2.
- If the destination address is incorrect, execute the destination ip command to change the destination address, and then perform the ping operation again.
If no notification is generated, the issue is cleared.
If the notification is generated, go to step 2.
2.In NQA operation view, execute the ping command to identify whether the destination address is reachable.
- If the destination address is reachable, go to step 3.
- If the destination address is unreachable, locate routing issues. For example, execute the display ip routing-table command to verify routing table information.
3.In NQA operation view, execute the probe timeout command to set the probe timeout time, and then perform the ping operation again.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
pingTestFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.80.0.2 |
A ping operation failed. |
Informational |
Warning |
N/A (N/A) |
OFF |
System impact
Status control
ON
CLI: Use the reaction trap test-failure [ accumulate-probe-failures ] command.
OFF
CLI: Use the undo reaction trap test-failure [ accumulate-probe-failures ] command.
Object
OID (object name) |
Index |
Type |
Value range |
InetAddressType |
InetAddress |
Operation status. |
INTEGER |
InetAddressType |
InetAddress |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
DateAndTime |
Recommended action
pingTestCompleted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.80.0.3 |
A ping operation completed. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is generated when a ping operation completes.
System impact
No impact on the system.
Status control
ON
CLI: Use the reaction trap test-complete command.
OFF
CLI: Use the undo reaction trap test-complete command.
Object
OID (object name) |
Index |
Type |
Value range |
InetAddressType |
InetAddress |
Operation status. |
INTEGER |
InetAddressType |
InetAddress |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
DateAndTime |
Recommended action
No action is required.
